    4. ShellyPLUS 1PM in ioBroker einbinden
      Atticus @crunchip last edited by
      @crunchip
        crunchip Forum Testing Most Active @Atticus last edited by crunchip
        @atticus du hast immer noch 1883 drin stehen
        ja das steht dann auf connected, wenn deine mqtt Verbindung steht
          Atticus @crunchip last edited by Atticus
          @crunchip ```
          pi@ioBroker482:~ $ sudo netstat -ltp
          Aktive Internetverbindungen (Nur Server)
          Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
          tcp        0      0 ioBroker482.fritz.:2001 0.0.0.0:*               LISTEN      1207/io.hm-rpc.0
          tcp        0      0 127.0.0.53:domain       0.0.0.0:*               LISTEN      324/systemd-resolve
          tcp        0      0 0.0.0.0:ssh             0.0.0.0:*               LISTEN      464/sshd
          tcp        0      0 localhost:ipp           0.0.0.0:*               LISTEN      5466/cupsd
          tcp        0      0 0.0.0.0:55703           0.0.0.0:*               LISTEN      1670/rpc.statd
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1144/node-red
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      27615/io.shelly.1
          tcp        0      0 ioBroker482:pipe-server 0.0.0.0:*               LISTEN      1215/io.hm-rpc.1
          tcp        0      0 ioBroker482.fritz.:8701 0.0.0.0:*               LISTEN      1235/io.hm-rpc.2
          tcp        0      0 ioBroker482.fritz.:8702 0.0.0.0:*               LISTEN      1242/io.hm-rpc.3
          tcp        0      0 ioBroker482.fritz.:8100 0.0.0.0:*               LISTEN      1532/io.doorbird.0
          tcp        0      0 localhost:9000          0.0.0.0:*               LISTEN      440/iobroker.js-con
          tcp        0      0 localhost:9001          0.0.0.0:*               LISTEN      440/iobroker.js-con
          tcp        0      0 0.0.0.0:hostmon         0.0.0.0:*               LISTEN      324/systemd-resolve
          tcp        0      0 ioBroker482.fritz:18701 0.0.0.0:*               LISTEN      1257/io.hm-rpc.4
          tcp        0      0 0.0.0.0:sunrpc          0.0.0.0:*               LISTEN      1/init
          tcp6       0      0 [::]:tproxy             [::]:*                  LISTEN      1038/io.admin.0
          tcp6       0      0 [::]:8082               [::]:*                  LISTEN      1803/io.web.0
          tcp6       0      0 [::]:8084               [::]:*                  LISTEN      1689/io.socketio.0
          tcp6       0      0 [::]:ssh                [::]:*                  LISTEN      464/sshd
          tcp6       0      0 localhost:ipp           [::]:*                  LISTEN      5466/cupsd
          tcp6       0      0 [::]:8087               [::]:*                  LISTEN      1677/io.simple-api.
          tcp6       0      0 [::]:omniorb            [::]:*                  LISTEN      1713/io.terminal.0
          tcp6       0      0 [::]:40385              [::]:*                  LISTEN      1670/rpc.statd
          tcp6       0      0 [::]:hostmon            [::]:*                  LISTEN      324/systemd-resolve
          tcp6       0      0 [::]:sunrpc             [::]:*                  LISTEN      1/init
          pi@ioBroker482:~ $
          War der alte Scrennshot 🙂
            @atticus sagte in ShellyPLUS 1PM in ioBroker einbinden:
            ich seh keinen neuen
            was zeigt das Log an?
              @crunchip
                @atticus starte mal den shelly neu, stell die Instanz auf debug und zeig das Log
                  @crunchip
                  Shelly neu gestartet, Instanz auf Debug
                    @atticus ich seh keinen Fehler, steht nun die Verbindung?
                      @crunchip
                      Nein, es kommt keine Verbindung zu Stande.
                      Die Instanz sieht immer noch so aus:
                      Soll ich den Shelly noch mal auf Werkseinstellungen resetten? Die Instanz hab ich schon noch mal gelöscht und neu installiert.
                      crunchip S 2 Replies Last reply Reply Quote 0
                        kannst du probieren
                        ansonsten, geh mal mit der Firmware zurück, vllt liegt es daran
                        http://archive.shelly-tools.de/
                          @crunchip
                          Auf der Archive Seite von Shelly ist dem Shelly Plus 1PM nicht zu finden, das Ding hat aktuell FW 0.14.1 installiert, da ist nichts vergleichbares zu sehen
                          Friedhofsblond crunchip 2 Replies Last reply Reply Quote 0
                          • Friedhofsblond
                            Friedhofsblond @Atticus last edited by Friedhofsblond
                            @atticus
                            Moin,
                            habe auch Probleme den Shelly Plus 1 pm einzubinden.
                            Die Plug S 2 und 3EM wurden sofort erkannt.
                            Der Plus 1 PM ist der für das Balkonkraftwerk. Wäre wichtig den einzubinden, weil ich mit dem 3EM den Energiefluß darstellen wollte und noch paar andere Sachen.
                            Kann bestätigen, daß man dort kein Benutzer/Passwort anlegen kann. Ich gehe aber nicht über MQTT sondern CoAP.
                            Beim start wird auch die IP-Adresse des PM garn nicht gefunden.
                              SpacerX last edited by
                              @atticus Mach noch mal bitte einen aktuellen Screenshot von den Mqtt Einstellungen des Shellys
                                SpacerX @Friedhofsblond last edited by SpacerX
                                @friedhofsblond
                                Edit: Sorry war eine Fehlbedienung.😊
                                Der Shelly Plus 1PM unterstütz doch gar kein COAP!
                                Friedhofsblond 1 Reply Last reply Reply Quote 0
                                • Friedhofsblond
                                  Friedhofsblond @SpacerX last edited by
                                  @spacerx
                                  meinst du mich mit MQTT ? - falls ja - ich habe nix bei MQTT aktiviert - nutze ich nicht
                                  • da_Woody
                                    da_Woody @Friedhofsblond last edited by
                                    @friedhofsblond aber die plus funktionieren nur mit MQTT
                                    • Friedhofsblond
                                      Friedhofsblond @da_Woody last edited by
                                      @da_woody
                                      also muß ich dann bei allen MQTT aktivieren?
                                      Mist - hab da keinen Schimmer von.
                                      da_Woody S 2 Replies Last reply Reply Quote 0
                                        SpacerX @Atticus last edited by SpacerX
                                        @atticus Noch mal der Auszug aus der md zu Plus Geräten.
                                        • Aktiviere MQTT und gib die gerade konfigurierten Benutzerdaten und die IP-Adresse deiner ioBroker-Installation ein - gefolgt vom konfigurierten Port (beispielsweise 192.168.1.2:1882)
                                          Speichere die Konfiguration - der Shelly startet automatisch neu
                                        • Ändere nicht die "client id" in dieser Konfiguration
                                        • Für Generation 2 Geräte müssen alle RPC-Optionen aktiviert werden (siehe Screenshots)!
                                        • SSL darf nicht aktiviert werden
                                        In deinem letzten Screenshot der Einstellungen ist zu sehen das du die Client-ID geändert hast.
                                        • da_Woody
                                          @friedhofsblond ist keine raketen wissenschaft.
                                          entweder für die neuen dinger ne 2. instanz, oder alle auf mqtt umstellen. da brauchst du keinen schimmer haben. ist easy, weil kein extra mqtt server benötigt wird.
                                            @friedhofsblond Da COAP bei den neuen Geräten nicht mehr unterstützt wird wäre es doch naheliegend alle Shelly's auf MQTT umzustellen. So Brauchst du nur eine Instanz.
                                            da_Woody Friedhofsblond 2 Replies Last reply Reply Quote 0
                                            shellyplus 1pm
                                            11
                                            76
                                            8345
