    4. Test Adapter OpenDTU
    • Friedhofsblond
      Friedhofsblond @Thomas Braun last edited by
      Hm, was sagt mir das Log?:
      2023-04-14 13:59:55.345 - debug: opendtu.0 (2001) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-04-14 13:59:55.366 - debug: opendtu.0 (2001) Objects client ready ... initialize now
      2023-04-14 13:59:55.368 - debug: opendtu.0 (2001) Objects create System PubSub Client
      2023-04-14 13:59:55.368 - debug: opendtu.0 (2001) Objects create User PubSub Client
      2023-04-14 13:59:55.378 - debug: opendtu.0 (2001) Objects client initialize lua scripts
      2023-04-14 13:59:55.382 - debug: opendtu.0 (2001) Objects connected to redis: 127.0.0.1:9001
      2023-04-14 13:59:55.394 - debug: opendtu.0 (2001) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-04-14 13:59:55.399 - debug: opendtu.0 (2001) States create System PubSub Client
      2023-04-14 13:59:55.400 - debug: opendtu.0 (2001) States create User PubSub Client
      2023-04-14 13:59:55.406 - debug: opendtu.0 (2001) States connected to redis: 127.0.0.1:9000
      2023-04-14 13:59:55.470 - info: opendtu.0 (2001) starting. Version 0.1.4 (non-npm: o0shojo0o/ioBroker.opendtu#b92c7de2d0ab38296f6e1c401d63fbb7fad4829a) in /opt/iobroker/node_modules/iobroker.opendtu, node: v16.19.1, js-controller: 4.0.24
      2023-04-14 13:59:55.496 - error: opendtu.0 (2001) SyntaxError: The URL contains a fragment identifier
      2023-04-14 13:59:55.498 - error: opendtu.0 (2001) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-04-14 13:59:55.499 - error: opendtu.0 (2001) unhandled promise rejection: Cannot read properties of undefined (reading 'on')
      2023-04-14 13:59:55.501 - error: opendtu.0 (2001) TypeError: Cannot read properties of undefined (reading 'on')
      at Opendtu.startWebsocket (/opt/iobroker/node_modules/iobroker.opendtu/main.js:137:18)
      at Opendtu.onReady (/opt/iobroker/node_modules/iobroker.opendtu/main.js:46:14)
      at Opendtu.emit (node:events:513:28)
      at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
      2023-04-14 13:59:55.501 - error: opendtu.0 (2001) Cannot read properties of undefined (reading 'on')
      2023-04-14 13:59:55.511 - info: opendtu.0 (2001) terminating
      2023-04-14 13:59:55.512 - warn: opendtu.0 (2001) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-04-14 13:59:56.068 - error: host.homeserv instance system.adapter.opendtu.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-04-14 13:59:56.069 - info: host.homeserv Restart adapter system.adapter.opendtu.0 because enabled
      2023-04-14 14:00:26.102 - info: host.homeserv instance system.adapter.opendtu.0 started with pid 2126
      2023-04-14 14:00:26.906 - debug: opendtu.0 (2126) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-04-14 14:00:26.939 - debug: opendtu.0 (2126) Objects client ready ... initialize now
      2023-04-14 14:00:26.940 - debug: opendtu.0 (2126) Objects create System PubSub Client
      2023-04-14 14:00:26.941 - debug: opendtu.0 (2126) Objects create User PubSub Client
      2023-04-14 14:00:26.950 - debug: opendtu.0 (2126) Objects client initialize lua scripts
      2023-04-14 14:00:26.954 - debug: opendtu.0 (2126) Objects connected to redis: 127.0.0.1:9001
      2023-04-14 14:00:26.964 - debug: opendtu.0 (2126) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-04-14 14:00:26.968 - debug: opendtu.0 (2126) States create System PubSub Client
      2023-04-14 14:00:26.969 - debug: opendtu.0 (2126) States create User PubSub Client
      2023-04-14 14:00:26.974 - debug: opendtu.0 (2126) States connected to redis: 127.0.0.1:9000
      2023-04-14 14:00:27.023 - info: opendtu.0 (2126) starting. Version 0.1.4 (non-npm: o0shojo0o/ioBroker.opendtu#b92c7de2d0ab38296f6e1c401d63fbb7fad4829a) in /opt/iobroker/node_modules/iobroker.opendtu, node: v16.19.1, js-controller: 4.0.24
      2023-04-14 14:00:27.048 - error: opendtu.0 (2126) SyntaxError: The URL contains a fragment identifier
      2023-04-14 14:00:27.050 - error: opendtu.0 (2126) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-04-14 14:00:27.050 - error: opendtu.0 (2126) unhandled promise rejection: Cannot read properties of undefined (reading 'on')
      2023-04-14 14:00:27.053 - error: opendtu.0 (2126) TypeError: Cannot read properties of undefined (reading 'on')
      2023-04-14 14:00:27.053 - error: opendtu.0 (2126) Cannot read properties of undefined (reading 'on')
      2023-04-14 14:00:27.063 - info: opendtu.0 (2126) terminating
      2023-04-14 14:00:27.064 - warn: opendtu.0 (2126) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-04-14 14:00:27.619 - error: host.homeserv instance system.adapter.opendtu.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-04-14 14:00:27.620 - info: host.homeserv Restart adapter system.adapter.opendtu.0 because enabled
        crunchip Forum Testing Most Active @Friedhofsblond last edited by
        @friedhofsblond auch das beachtet?
        Es wir die Version von 15.02.2023 oder neuer benötigt!
        Friedhofsblond 1 Reply Last reply Reply Quote 0
        • Friedhofsblond
          Friedhofsblond @crunchip last edited by
          @crunchip
          hm, sorry was meinst du jetzt?
          IdleBit 1 Reply Last reply Reply Quote 0
          • IdleBit
            IdleBit @Friedhofsblond last edited by
            @friedhofsblond Zeig mal deine Einstellungen vom Adapter, sieht so aus ob da was faul ist.
            • Friedhofsblond
              @idlebit
              • IdleBit
                @friedhofsblond kann es sein das sich Leerzeichen eingeschlichen haben?
                Also bei der IP z.B.
                • Friedhofsblond
                  Friedhofsblond @IdleBit last edited by Friedhofsblond
                  @idlebit
                  hm,
                  nö habe die instanz nochmal gelöscht und eine neue erzeugt.
                  Dann alles händisch sauber eingetragen - kein Erfolg.
                  Kein Port hinter der IP:
                  • IdleBit
                    IdleBit @Friedhofsblond last edited by IdleBit
                    @friedhofsblond Port 80 ist default bei HTTP und wird daher nicht dargestellt.
                    Muss Du bitte eine vollen Logmitschnitt mal posten von start bis zum Ende.
                    Kann mir das aber erst später ansehen, habe jetzt erstmal andere Verpflichtungen.
                    • Friedhofsblond
                      @idlebit
                      Jo alles klar - kein Druck 😄
                      • Friedhofsblond
                        Friedhofsblond @Friedhofsblond last edited by
                        so habs gefunden.
                        Es lag am Passwort - keine Sonderzeichen !! bei mir "#" 😞
                        IdleBit 1 Reply Last reply Reply Quote 1
                        • IdleBit
                          @friedhofsblond Mal mal bitte auf GitHub ein Issues dafür auf. Werde mir das dann ansehen.
                          • I
                            indie last edited by indie
                            Hallo zusammen, ich hab ein Problem mit dem Adapter und sowohl die neueste Firmware von opendtu geflasht, als auch das passende node.js drauf und die aktuelle Adapter Installation drauf. Das Problem trat auch mit einer älteren Firmware Version von opendtu schon auf, ich hatte gehofft, dass es mit der neuen Version gelöst wäre, aber nach ca 18 Stunden Betrieb ging das ganze schon wieder los: nach einer Weile ganz normalem Betriebs wird im Adapter eine unhandled exception geworfen und der Adapter Gerät dann in eine "restart loop", sodass iobroker den Adapter killt, nachdem 4-5 Mal in 1,5 min neu gestartet wurde.
                            Das logfile zu dem Fehler im Adapter in iobroker ist folgendes (nur eine "Fehlerinstanz", diese tritt dann mehrfach nacheinander auf). 2 hinweise noch zur Fehler Eingrenzung:
                            1. Mqtt ist in opendtu aus, zufriff läuft über http.
                            2. Im Kontext des Fehlers verändern sich die Namen der 2 verbundenen wechselrichter in der Webansicht und enthalten plötzlich seltsame Sonderzeichen oder werden komplett durch solche ersetzt.
                            Ein Ansatz könnte sein, dass es einen overflow beim opendtu gibt, der zb durch nicht geschlossene web connections Auftritt und durch den Adapter ausgelöst wird?
                            Würde mich sehr freuen, wenn ich einen Tipp von euch bekomme oder mit der Fehlerbeschreibung die Weiterentwicklung des Adapters unterstützten kann 🙂
                            Vielen Dank!
                            Edit: hab es auch auf GitHub als issue geöffnet
                            2023-04-18 12:56:52.639 error The id is empty! Please provide a valid id.
                            opendtu.0
                            2023-04-18 12:56:52.638 error Error: The id is empty! Please provide a valid id. at Utils.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/utils.js:114:19) at Opendtu.extendObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1935:23) at /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2126:16 at new Promise (<anonymous>) at Opendtu.extendObjectAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2125:16) at DataController.processInverterData (/opt/iobroker/node_modules/iobroker.opendtu/lib/dataController.js:23:36) at Opendtu.processMessage (/opt/iobroker/node_modules/iobroker.opendtu/main.js:163:28) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.opendtu/main.js:142:18) at WebSocket.emit (node:events:525:35) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1184:20)
                            opendtu.0
                            2023-04-18 12:56:52.634 error unhandled promise rejection: The id is empty! Please provide a valid id.
                            opendtu.0
                            2023-04-18 12:56:52.616 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              Thomas Braun Most Active @indie last edited by Thomas Braun
                              @indie
                              Wie hast du die beiden denn benannt? Versuch mal Umlaute oder ggf. sonstige 'Sonderzeichen' zu vermeiden.
                              Irgendwas ist da wohl nicht eingetragen. Hast du für die Panele auch schöne Namen vergeben?
                              • I
                                indie @Thomas Braun last edited by indie
                                @thomas-braun eigentlich ja, "Garagendach" und "Balkon". Hier sollte eigentlich das Problem nicht liegen 🤔... Ah ja und die panele (also strings der Wechselrichter) habe ich nicht umbenannt (also weiterhin "string 1" und "2").
                                  @indie Die meinte ich. Trag da mal just for fun irgendwas simples ein.
                                  Dick & Doof, Bonny & Clyde, Tom & Jerry oder sowas. 😉
                                  • I
                                    @thomas-braun okay, ich mache alles, was helfen kann, auch wenn ich nicht sehe, wie das helfen kann...(klar, es steht jetzt etwas an einer Stelle, wo vorher nichts stand, das war aber btw vor dem Firmware Update inkl. Reflash anders, da hatte ich jeweils einen Namen für die Strings). Mal sehen ...evtl kann man aus dem langen logeintrag ja rauslesen, wo genau der Fehler Auftritt, aber mir fehlt da der konkrete Einblick in den Code (bzw die Fähigkeit dazu)
                                    • I
                                      indie @indie last edited by
                                      Kurzes Update: nachdem ich in der dtu das refresh interval von 2s auf 5s gesetzt habe und jeder String einen Namen bekommen hat, tritt das Problem seit 30h schon nicht mehr auf. Ich gehe also davon aus, dass die dtu tatsächlich mit der Last überfordert war und der Fehler im Adapter durch fehlerhafte Übertragung von der dtu ausgelöst wurde. Ich entschuldige mich für die falsche Verdächtigung des Adapters und habe auch auf GitHub das issue geschlossen :-). Danke für die Hilfe!
                                      L I crunchip 3 Replies Last reply Reply Quote 0
                                        lars72 @indie last edited by
                                        Hallo, ich habe eine dumme Anfängerfrage:
                                        Wo und wie installiere ich den Adapter OpenDTU? Habe den Raspberry erst seit gestern und ich weiß, dass ich nicht viel weiss 😉
                                        Ich brauche da eine genaue Befehlsanleitung für die Konsole / Eingabeaufforderung.
                                        Vielen Dank schon mal,
                                        Lars
                                          Thomas Braun Most Active @lars72 last edited by
                                          @lars72
                                          Es muss der Experten-Modus aktiviert sein.
                                            lars72 @Thomas Braun last edited by
                                            Vielen Dank! Hat geklappt.
                                            dtu hoymiles opendtu solar
                                            47
                                            457
                                            121612
