    4. DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus
      Homoran Global Moderator Administrators @helmut1963 last edited by
      @helmut1963 sagte in DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus:
      Hat irgendwer einen guten Tipp für mich?
      bitte keine Screenshots von Texten
      Log als Text in code-tags posten
        helmut1963 @Homoran last edited by
        Ok. Sorry. Soll das so sein?
        modbus.1
        2023-04-14 20:56:46.976	info	starting. Version 3.4.17 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.22.5, js-controller: 3.3.15
        host.iobroker-main-master
        2023-04-14 20:56:46.514	info	instance system.adapter.modbus.1 started with pid 3555546
        2023-04-14 20:56:45.469	info	Restart adapter system.adapter.modbus.1 because enabled
        2023-04-14 20:56:45.467	info	instance system.adapter.modbus.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        modbus.1
        2023-04-14 20:56:44.889	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        modbus.1
        2023-04-14 20:56:44.888	error	Reconnect did not help, restart adapter
        modbus.1
        2023-04-14 20:56:44.887	warn	Poll error count: 13 code: {"err":"timeout","timeout":5000}
        modbus.1
        2023-04-14 20:56:44.887	error	Client in error state.
        modbus.1
        2023-04-14 20:56:44.886	error	Request timed out.
        modbus.1
        2023-04-14 20:56:44.885	warn	Error: undefined
        modbus.1
        2023-04-14 20:56:39.883	info	Connected to slave
        modbus.1
        2023-04-14 20:56:33.882	info	Disconnected from slave 192.168.10.241
        modbus.1
        2023-04-14 20:56:32.881	warn	Poll error count: 12 code: {"err":"timeout","timeout":5000}
        modbus.1
        2023-04-14 20:56:32.881	error	Client in error state.
        modbus.1
        2023-04-14 20:56:32.880	error	Request timed out.
        modbus.1
        2023-04-14 20:56:32.880	warn	Error: undefined
        modbus.1
        2023-04-14 20:56:27.907	error	Wrong CRC for frame: 1,4,4,49,0,2,58,8,1
        modbus.1
        2023-04-14 20:56:27.878	info	Connected to slave
        modbus.1
        2023-04-14 20:56:21.876	info	Disconnected from slave 192.168.10.241
        Homoran Glasfaser 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @helmut1963 last edited by Homoran
          hatten wir die Tage erst.
          Zähler vom Strom nehmen und neu verbinden
          welche sind es denn genau?
          habe mit SDM72 UND SDM630 keinerlei Probleme
          die 230er hab ich nicht. Beim DC hast du den Shunt angeschlossen?
          • Glasfaser
            Glasfaser @helmut1963 last edited by
            nur mal als Hinweis .. aktualisiere es mal !
            Ist schon sehr alt !
            • Glasfaser
              Glasfaser @helmut1963 last edited by Glasfaser
              MODBUS Version 3.4.17
              Upps ...
              da ist ja alles sehr alt !
                Homoran Global Moderator Administrators @Glasfaser last edited by
                @glasfaser sagte in DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus:
                deswegen gibt es wahrscheinlich auch kein diag
                • Glasfaser
                  Glasfaser @Homoran last edited by Glasfaser
                  @homoran sagte in DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus:
                  den hast du ja in diesem Thread ja noch nicht angefragt ... nur im neben Thread ( Vis ... Dateimanger ) 🙂
                    helmut1963 @Glasfaser last edited by
                    @glasfaser
                    Ja, ich weiß, müsste alles mal aktualisiert werden. Aber alles andere läuft so schön stabil, wenn ich jetzt wieder in der Installation rumfummele, ist der Stress vorprogrammiert. 🙄
                    Der Gleichstromzähler mit 75 mV-Shunt-Eingang wird gerade mit Spannung 0-75mV zum Simulieren befeuert. Zeigt damit absolut korrekte Werte im Display an.... 20 echte Ampere sind schwerer zu simulieren....
                    Homoran Glasfaser Thomas Braun 3 Replies Last reply Reply Quote 0
                      wirklich?
                      was sagt denn iob diag?
                      Bitte die Vollversion!
                      was hängt denn alles am Bus?
                      im log ist ja der Zähler nicht zu identifizieren
                      • Glasfaser
                        den Gedanken würde ich mal langsam bei Seite legen ...
                        dein ioBroker ist wie schon erwähnt .. sehr alt .
                          Thomas Braun Most Active @helmut1963 last edited by
                          Wenn du es nicht aktuell hältst gibt es auch Stress. Früher oder später. Und je größer die Kluft zwischen den Versionen wird umso größer wird auch dieser Stress werden.
                            So, ich hab den Schritt gewagt und alles auf ich denke halbwegs aktuellen Stand gebracht, dabei Blut und Wasser geschwitzt... Zuerst lief das Log in orange und rot über.....Alle Datenpunkte des Wechselrichter-Modbus mussten überall neu verdrahtet werden....Ich hoffe nun ist alles erstmal in Reihe.
                            Das Ursprungsproblem löste dieses Aktion aber leider nicht....Die Einträge im Log für Instanz modbus.1 sind exact die gleichen....
                            Am Bus (verdrilltes Kabel, A+ / B+, 30 cm) nach dem Konverter hängt nur der Zähler (abwechselnd beide zum Testen) abgeschlossen mit 120 Ohm.
                            iob diag? Meinst Du damit dies: ? (Für mich das meiste Chinesisch.....)
                            Halt. Beim Einfügen des ellenlangen Textes sagt System: ERROR - Forbidden... Keine Ahnung warum. Ich versuchs morgen nochmal. Konzentration ist für heute dahin....
                            H Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                              helmut1963 @helmut1963 last edited by
                              Skript v.2023-04-02
                              *** BASE SYSTEM ***
                              Architecture    : x86_64
                              Docker          : false
                              Virtualization  : lxc
                              Distributor ID: Debian
                              Description:    Debian GNU/Linux 10 (buster)
                              Release:        10
                              Codename:       buster
                              PRETTY_NAME="Debian GNU/Linux 10 (buster)"
                              NAME="Debian GNU/Linux"
                              VERSION_ID="10"
                              VERSION="10 (buster)"
                              VERSION_CODENAME=buster
                              ID=debian
                              HOME_URL="https://www.debian.org/"
                              SUPPORT_URL="https://www.debian.org/support"
                              BUG_REPORT_URL="https://bugs.debian.org/"
                              Systemuptime and Load:
                               21:14:41 up 79 days, 13:59,  1 user,  load average: 0.73, 0.50, 0.48
                              CPU threads: 4
                              *** Time and Time Zones ***
                                             Local time: Fri 2023-04-14 21:14:41 UTC
                                         Universal time: Fri 2023-04-14 21:14:41 UTC
                                               RTC time: n/a
                                              Time zone: Etc/UTC (UTC, +0000)
                                            NTP service: inactive
                                        RTC in local TZ: no
                              *** User and Groups ***
                              root
                              /root
                              root
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:           7.9G        1.2G        6.2G         23M        520M        6.7G
                              Swap:            0B          0B          0B
                              Total:         7.9G        1.2G        6.2G
                                       7879 M total memory
                                       1172 M used memory
                                        357 M active memory
                                       1214 M inactive memory
                                       6186 M free memory
                                          0 M buffer memory
                                        520 M swap cache
                                          0 M total swap
                                          0 M used swap
                                          0 M free swap
                              *** FILESYSTEM ***
                              Filesystem                       Type      Size  Used Avail Use% Mounted on
                              /dev/mapper/pve-vm--100--disk--1 ext4       24G   11G   13G  47% /
                              none                             tmpfs     492K  4.0K  488K   1% /dev
                              udev                             devtmpfs  3.9G     0  3.9G   0% /dev/tty
                              tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
                              tmpfs                            tmpfs     3.9G   25M  3.9G   1% /run
                              tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                              tmpfs                            tmpfs     788M     0  788M   0% /run/user/0
                              dmesg: read kernel buffer failed: Operation not permitted
                              Show mounted filesystems (real ones only):
                              TARGET                           SOURCE                                FSTYPE     OPTIONS
                              /                                /dev/mapper/pve-vm--100--disk--1      ext4       rw,relatime,stripe=16
                              |-/proc/cpuinfo                  lxcfs[/proc/cpuinfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                              |-/proc/diskstats                lxcfs[/proc/diskstats]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                              |-/proc/loadavg                  lxcfs[/proc/loadavg]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                              |-/proc/meminfo                  lxcfs[/proc/meminfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                              |-/proc/stat                     lxcfs[/proc/stat]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                              |-/proc/swaps                    lxcfs[/proc/swaps]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                              |-/proc/uptime                   lxcfs[/proc/uptime]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                              `-/sys/devices/system/cpu/online lxcfs[/sys/devices/system/cpu/online] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                              /var:
                              407M    /var/
                              207M    /var/cache
                              203M    /var/cache/apt
                              179M    /var/lib
                              141M    /var/cache/apt/archives
                              /opt/iobroker/backups:
                              4.8G    /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              2.6G    /opt/iobroker/iobroker-data/
                              2.3G    /opt/iobroker/iobroker-data/history
                              197M    /opt/iobroker/iobroker-data/files
                              64M     /opt/iobroker/iobroker-data/backup-objects
                              53M     /opt/iobroker/iobroker-data/files/javascript.admin
                              20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
                              19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                              14M     /opt/iobroker/iobroker-data/influxdata.json
                              13M     /opt/iobroker/iobroker-data/objects.jsonl
                              12M     /opt/iobroker/iobroker-data/objects.json.migrated
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v14.21.3
                              /usr/bin/node           v14.21.3
                              /usr/bin/npm            6.14.18
                              /usr/bin/npx            6.14.18
                              nodejs:
                                Installed: 14.21.3-deb-1nodesource1
                                Candidate: 14.21.3-deb-1nodesource1
                                Version table:
                               *** 14.21.3-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_14.x buster/main amd64 Packages
                                      100 /var/lib/dpkg/status
                                   10.24.0~dfsg-1~deb10u3 500
                                      500 http://security.debian.org buster/updates/main amd64 Packages
                                   10.24.0~dfsg-1~deb10u1 500
                                      500 http://ftp.debian.org/debian buster/main amd64 Packages
                              No problems detected
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  4.0.24
                              admin:          6.4.3
                              javascript:     7.0.3
                              npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
                              npm ERR! peer dep missing: onvif@^0.5.5, required by onvif-snapshot@1.0.3
                              Adapters from github:   3
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : iobroker-main-master                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.alexa2.0                 : alexa2                : iobroker-main-master                     - disabled
                              + system.adapter.backitup.0               : backitup              : iobroker-main-master                     -  enabled
                                system.adapter.daswetter.0              : daswetter             : iobroker-main-master                     -  enabled
                              + system.adapter.discovery.0              : discovery             : iobroker-main-master                     -  enabled
                                system.adapter.dwd.0                    : dwd                   : iobroker-main-master                     -  enabled
                                system.adapter.email.0                  : email                 : iobroker-main-master                     - disabled
                                system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-main-master                     - disabled
                                system.adapter.flot.0                   : flot                  : iobroker-main-master                     - disabled
                              + system.adapter.fritzbox.0               : fritzbox              : iobroker-main-master                     -  enabled
                              + system.adapter.history.0                : history               : iobroker-main-master                     -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : iobroker-main-master                     -  enabled
                              + system.adapter.hm-rega.1                : hm-rega               : iobroker-main-master                     -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-main-master                     -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-main-master                     -  enabled, port: 0
                              + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-main-master                     -  enabled, port: 0
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-main-master                     -  enabled
                                system.adapter.influxdb.0               : influxdb              : iobroker-main-master                     - disabled, port: 8086
                                system.adapter.iot.0                    : iot                   : iobroker-main-master                     - disabled
                              + system.adapter.javascript.0             : javascript            : iobroker-main-master                     -  enabled
                                system.adapter.mbus.0                   : mbus                  : iobroker-main-master                     - disabled, port: 502
                              + system.adapter.modbus.0                 : modbus                : iobroker-main-master                     -  enabled
                              + system.adapter.modbus.1                 : modbus                : iobroker-main-master                     -  enabled
                                system.adapter.nina.0                   : nina                  : iobroker-main-master                     - disabled
                                system.adapter.nut.0                    : nut                   : iobroker-main-master                     - disabled
                                system.adapter.odl.0                    : odl                   : iobroker-main-master                     - disabled
                                system.adapter.onvif.0                  : onvif                 : iobroker-main-master                     - disabled
                              + system.adapter.proxmox.0                : proxmox               : iobroker-main-master                     -  enabled, port: 8006
                                system.adapter.ring.0                   : ring                  : iobroker-main-master                     - disabled
                              + system.adapter.shelly.0                 : shelly                : iobroker-main-master                     -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.socketio.0               : socketio              : iobroker-main-master                     -  enabled, port: 8084, bind: 192.168.10.219, run as: admin
                              + system.adapter.telegram.0               : telegram              : iobroker-main-master                     -  enabled, port: 8443, bind: 0.0.0.0
                                system.adapter.tr-064.0                 : tr-064                : iobroker-main-master                     - disabled
                                system.adapter.tradfri.0                : tradfri               : iobroker-main-master                     - disabled
                                system.adapter.trashschedule.0          : trashschedule         : iobroker-main-master                     - disabled
                                system.adapter.unifi-protect.0          : unifi-protect         : iobroker-main-master                     - disabled
                                system.adapter.vis-history.0            : vis-history           : iobroker-main-master                     - disabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-main-master                     - disabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-main-master                     - disabled
                                system.adapter.vis.0                    : vis                   : iobroker-main-master                     -  enabled
                              + system.adapter.web.0                    : web                   : iobroker-main-master                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): beta
                              Installed ioBroker-Instances
                              Used repository: beta
                              Adapter    "admin"        : 6.4.3    , installed 6.4.3
                              Adapter    "alexa2"       : 3.23.2   , installed 3.3.1  [Updatable]
                              Adapter    "backitup"     : 2.6.17   , installed 2.6.17
                              Adapter    "daswetter"    : 3.1.8    , installed 3.0.1  [Updatable]
                              Adapter    "discovery"    : 3.1.0    , installed 2.7.0  [Updatable]
                              Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                              Adapter    "email"        : 1.1.4    , installed 1.0.7  [Updatable]
                              Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
                              Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                              Adapter    "history"      : 2.2.4    , installed 2.2.4
                              Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                              Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
                              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                              Adapter    "iot"          : 1.14.5   , installed 1.14.5
                              Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                              Controller "js-controller": 4.0.24   , installed 4.0.24
                              Adapter    "mbus"         : 2.4.0    , installed 2.4.0
                              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                              Adapter    "nina"         : 0.0.25   , installed 0.0.22 [Updatable]
                              Adapter    "nut"          : 1.6.0    , installed 1.6.0
                              Adapter    "odl"          : 2.0.5    , installed 1.0.5  [Updatable]
                              Adapter    "onvif"        : 1.0.5    , installed 0.0.2  [Updatable]
                              Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                              Adapter    "ring"         : 3.3.0    , installed 1.1.3  [Updatable]
                              Adapter    "shelly"       : 6.4.0    , installed 4.0.8  [Updatable]
                              Adapter    "socketio"     : 6.3.5    , installed 6.3.5
                              Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                              Adapter    "tradfri"      : 3.1.3    , installed 3.1.2  [Updatable]
                              Adapter    "trashschedule": 2.2.0    , installed 0.0.11 [Updatable]
                              Adapter    "unifi-protect": 0.0.13   , installed 0.0.11 [Updatable]
                              Adapter    "vis"          : 1.4.16   , installed 1.4.16
                              Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
                              Adapter    "web"          : 5.5.3    , installed 5.5.3
                              Adapter    "ws"           : 2.3.6    , installed 2.3.6
                              Objects and States
                              Objects:        8857
                              States:         7354
                              Hit:1 http://security.debian.org buster/updates InRelease
                              Hit:2 http://ftp.debian.org/debian buster InRelease
                              Hit:3 http://ftp.debian.org/debian buster-updates InRelease
                              Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       199270240  3585075/iobroker.js
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       199270233  3585075/iobroker.js
                              tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      105        199235807  3575373/systemd-res
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30286      1/systemd
                              tcp        0      0 192.168.10.219:2000     0.0.0.0:*               LISTEN      1000       199274100  3585209/io.hm-rpc.1
                              tcp        0      0 192.168.10.219:2001     0.0.0.0:*               LISTEN      1000       199272164  3585194/io.hm-rpc.0
                              tcp        0      0 192.168.10.219:2002     0.0.0.0:*               LISTEN      1000       199274194  3585239/io.hm-rpc.2
                              tcp        0      0 192.168.10.219:8084     0.0.0.0:*               LISTEN      1000       199276621  3585359/io.socketio
                              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      105        199235813  3575373/systemd-res
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          199238426  3577902/master
                              tcp6       0      0 :::5355                 :::*                    LISTEN      105        199235810  3575373/systemd-res
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          30288      1/systemd
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       199270313  3585096/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       199276671  3585374/io.web.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          30464      1/systemd
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          199238427  3577902/master
                              udp        0      0 127.0.0.53:53           0.0.0.0:*                           105        199235812  3575373/systemd-res
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          30287      1/systemd
                              udp        0      0 0.0.0.0:5355            0.0.0.0:*                           105        199235806  3575373/systemd-res
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       199273427  3585329/io.shelly.0
                              udp6       0      0 :::111                  :::*                                0          30289      1/systemd
                              udp6       0      0 :::5355                 :::*                                105        199235809  3575373/systemd-res
                              2023-04-14 21:14:30.976  - info: modbus.1 (3589548) Disconnected from slave 192.168.10.241
                              2023-04-14 21:14:36.978  - info: modbus.1 (3589548) Connected to slave
                              2023-04-14 21:14:41.980  - warn: modbus.1 (3589548) Error: undefined
                              2023-04-14 21:14:41.981  - error: modbus.1 (3589548) Request timed out.
                              2023-04-14 21:14:41.981  - error: modbus.1 (3589548) Client in error state.
                              2023-04-14 21:14:41.981  - warn: modbus.1 (3589548) Poll error count: 9 code: {"err":"timeout","timeout":5000}
                              2023-04-14 21:14:42.981  - info: modbus.1 (3589548) Disconnected from slave 192.168.10.241
                              2023-04-14 21:14:48.982  - info: modbus.1 (3589548) Connected to slave
                              2023-04-14 21:14:49.010  - error: modbus.1 (3589548) Wrong CRC for frame: 1,4,4,49,0,2,58,8,1
                              2023-04-14 21:14:53.983  - warn: modbus.1 (3589548) Error: undefined
                              2023-04-14 21:14:53.984  - error: modbus.1 (3589548) Request timed out.
                              2023-04-14 21:14:53.984  - error: modbus.1 (3589548) Client in error state.
                              2023-04-14 21:14:53.985  - warn: modbus.1 (3589548) Poll error count: 10 code: {"err":"timeout","timeout":5000}
                              2023-04-14 21:14:54.984  - info: modbus.1 (3589548) Disconnected from slave 192.168.10.241
                              2023-04-14 21:15:00.030  - info: host.iobroker-main-master instance system.adapter.dwd.0 started with pid 3589829
                              2023-04-14 21:15:00.640  - info: dwd.0 (3589829) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.21.3, js-controller: 4.0.24
                              2023-04-14 21:15:00.665  - warn: dwd.0 (3589829) No geo coordinates found in iobroker system configuration. Disable Rain Radar.
                              2023-04-14 21:15:00.986  - info: modbus.1 (3589548) Connected to slave
                              2023-04-14 21:15:01.058  - info: dwd.0 (3589829) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2023-04-14 21:15:01.585  - info: host.iobroker-main-master instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2023-04-14 21:15:04.043  - info: host.iobroker-main-master instance system.adapter.daswetter.0 started with pid 3590135
                              2023-04-14 21:15:04.652  - info: daswetter.0 (3590135) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.21.3, js-controller: 4.0.24
                              2023-04-14 21:15:04.668  - info: daswetter.0 (3590135) Terminated (NO_ERROR): Without reason
                              2023-04-14 21:15:05.175  - info: daswetter.0 (3590135) cleaned everything up...
                              2023-04-14 21:15:05.180  - info: host.iobroker-main-master instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                F5 drücken, dann geht es.
                                  helmut1963 @Thomas Braun last edited by
                                  ...habs gerade gemerkt und nachgeschoben.
                                    buster
                                    Ist nicht mehr aktuell, das wäre 'bullseye'.
                                    Keine Zeitzone gesetzt.
                                    root
                                    Nicht als root herumkaspern, man verwendet einen Standarduser.
                                    nodejs v14.21.3
                                    Zwar richtig installiert, die empfohlene Version wäre allerdings v18.
                                    Dürfte sich auch mit nodejs v18 ergeben.
                                    Bring die ganzen Adapter auf Stand. Ich würde dir allerdings vom Beta-Repository abraten und stable empfehlen. Da muss man auch weniger Updates einspielen.
                                      und den hast du mal vollständig stromlos gemacht?
                                      nimm mal nur den SDM und lass den Widerstand weg.
                                      Waveshare RS485 / TCP) Adapter mit IP
                                      den kenn ich nicht. weiss nicht was da zu konfigurieren ist.
                                        So Leute, an alle die mitgeholfen haben: Vielen Dank !
                                        Nach einer halb schlaflosen Nacht, den ganzen Updates und viel Herumprobiererei spricht zumindest mal der AC-Zähler auf einem Datenpunkt mit mir, Dh. der Iobroker hält nun die Verbindung und fragt in den eingestellten Abständen den Zähler ab und liefert sogar den richtigen Wert.... ("Spannung_DC-Panel" stammt noch vom Probieren, wird noch geändert...)
                                        Das Datenformat ist übrigens "Float (Big Endian)...
                                        Da ich keinen anderen Grund erkennen kann, bleibt als Ursache tatsächlich nur die veraltete Installation.
                                        Danke für`s Anstacheln, das Update endlich anzupacken. Liegt mir schon lange auf dem Magen.
                                        Ich denke da wird die endgültige Installation in der Backup-PV-Anlage mit den restlichen Datenpunkten schon irgendwie funktionieren. Ansonsten hört Ihr wieder von mir 😉
                                        Wen`s interessiert: https://www.qrz.com/db/DL1HJA und ein bisschen runterscrollen bis zum PV-Beitrag.
                                        Grüße, Helmut
                                        1409
