    4. DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus
      helmut1963 @Homoran last edited by
      Ok. Sorry. Soll das so sein?
      modbus.1
      2023-04-14 20:56:46.976	info	starting. Version 3.4.17 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.22.5, js-controller: 3.3.15
      host.iobroker-main-master
      2023-04-14 20:56:46.514	info	instance system.adapter.modbus.1 started with pid 3555546
      2023-04-14 20:56:45.469	info	Restart adapter system.adapter.modbus.1 because enabled
      2023-04-14 20:56:45.467	info	instance system.adapter.modbus.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      modbus.1
      2023-04-14 20:56:44.889	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      modbus.1
      2023-04-14 20:56:44.888	error	Reconnect did not help, restart adapter
      modbus.1
      2023-04-14 20:56:44.887	warn	Poll error count: 13 code: {"err":"timeout","timeout":5000}
      modbus.1
      2023-04-14 20:56:44.887	error	Client in error state.
      modbus.1
      2023-04-14 20:56:44.886	error	Request timed out.
      modbus.1
      2023-04-14 20:56:44.885	warn	Error: undefined
      modbus.1
      2023-04-14 20:56:39.883	info	Connected to slave
      modbus.1
      2023-04-14 20:56:33.882	info	Disconnected from slave 192.168.10.241
      modbus.1
      2023-04-14 20:56:32.881	warn	Poll error count: 12 code: {"err":"timeout","timeout":5000}
      modbus.1
      2023-04-14 20:56:32.881	error	Client in error state.
      modbus.1
      2023-04-14 20:56:32.880	error	Request timed out.
      modbus.1
      2023-04-14 20:56:32.880	warn	Error: undefined
      modbus.1
      2023-04-14 20:56:27.907	error	Wrong CRC for frame: 1,4,4,49,0,2,58,8,1
      modbus.1
      2023-04-14 20:56:27.878	info	Connected to slave
      modbus.1
      2023-04-14 20:56:21.876	info	Disconnected from slave 192.168.10.241
      Homoran Glasfaser 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @helmut1963 last edited by Homoran
        @helmut1963 sagte in DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus:
        hatten wir die Tage erst.
        Zähler vom Strom nehmen und neu verbinden
        welche sind es denn genau?
        habe mit SDM72 UND SDM630 keinerlei Probleme
        die 230er hab ich nicht. Beim DC hast du den Shunt angeschlossen?
        • Glasfaser
          Glasfaser @helmut1963 last edited by
          nur mal als Hinweis .. aktualisiere es mal !
          Ist schon sehr alt !
          • Glasfaser
            Glasfaser @helmut1963 last edited by Glasfaser
            MODBUS Version 3.4.17
            Upps ...
            da ist ja alles sehr alt !
              Homoran Global Moderator Administrators @Glasfaser last edited by
              @glasfaser sagte in DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus:
              deswegen gibt es wahrscheinlich auch kein diag
              • Glasfaser
                Glasfaser @Homoran last edited by Glasfaser
                @homoran sagte in DCM230 und SDM230-Zähler arbeiten nicht am IOBroker Modbus:
                den hast du ja in diesem Thread ja noch nicht angefragt ... nur im neben Thread ( Vis ... Dateimanger ) 🙂
                  helmut1963 @Glasfaser last edited by
                  @glasfaser
                  Ja, ich weiß, müsste alles mal aktualisiert werden. Aber alles andere läuft so schön stabil, wenn ich jetzt wieder in der Installation rumfummele, ist der Stress vorprogrammiert. 🙄
                  Der Gleichstromzähler mit 75 mV-Shunt-Eingang wird gerade mit Spannung 0-75mV zum Simulieren befeuert. Zeigt damit absolut korrekte Werte im Display an.... 20 echte Ampere sind schwerer zu simulieren....
                  Homoran Glasfaser Thomas Braun 3 Replies Last reply Reply Quote 0
                    wirklich?
                    was sagt denn iob diag?
                    Bitte die Vollversion!
                    was hängt denn alles am Bus?
                    im log ist ja der Zähler nicht zu identifizieren
                    • Glasfaser
                      den Gedanken würde ich mal langsam bei Seite legen ...
                      dein ioBroker ist wie schon erwähnt .. sehr alt .
                        Thomas Braun Most Active @helmut1963 last edited by
                        Wenn du es nicht aktuell hältst gibt es auch Stress. Früher oder später. Und je größer die Kluft zwischen den Versionen wird umso größer wird auch dieser Stress werden.
                          So, ich hab den Schritt gewagt und alles auf ich denke halbwegs aktuellen Stand gebracht, dabei Blut und Wasser geschwitzt... Zuerst lief das Log in orange und rot über.....Alle Datenpunkte des Wechselrichter-Modbus mussten überall neu verdrahtet werden....Ich hoffe nun ist alles erstmal in Reihe.
                          Das Ursprungsproblem löste dieses Aktion aber leider nicht....Die Einträge im Log für Instanz modbus.1 sind exact die gleichen....
                          Am Bus (verdrilltes Kabel, A+ / B+, 30 cm) nach dem Konverter hängt nur der Zähler (abwechselnd beide zum Testen) abgeschlossen mit 120 Ohm.
                          iob diag? Meinst Du damit dies: ? (Für mich das meiste Chinesisch.....)
                          Halt. Beim Einfügen des ellenlangen Textes sagt System: ERROR - Forbidden... Keine Ahnung warum. Ich versuchs morgen nochmal. Konzentration ist für heute dahin....
                          H Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                            helmut1963 @helmut1963 last edited by
                            Skript v.2023-04-02
                            *** BASE SYSTEM ***
                            Architecture    : x86_64
                            Docker          : false
                            Virtualization  : lxc
                            Distributor ID: Debian
                            Description:    Debian GNU/Linux 10 (buster)
                            Release:        10
                            Codename:       buster
                            PRETTY_NAME="Debian GNU/Linux 10 (buster)"
                            NAME="Debian GNU/Linux"
                            VERSION_ID="10"
                            VERSION="10 (buster)"
                            VERSION_CODENAME=buster
                            ID=debian
                            HOME_URL="https://www.debian.org/"
                            SUPPORT_URL="https://www.debian.org/support"
                            BUG_REPORT_URL="https://bugs.debian.org/"
                            Systemuptime and Load:
                             21:14:41 up 79 days, 13:59,  1 user,  load average: 0.73, 0.50, 0.48
                            CPU threads: 4
                            *** Time and Time Zones ***
                                           Local time: Fri 2023-04-14 21:14:41 UTC
                                       Universal time: Fri 2023-04-14 21:14:41 UTC
                                             RTC time: n/a
                                            Time zone: Etc/UTC (UTC, +0000)
                                          NTP service: inactive
                                      RTC in local TZ: no
                            *** User and Groups ***
                            root
                            /root
                            root
                            *** X-Server-Setup ***
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:           7.9G        1.2G        6.2G         23M        520M        6.7G
                            Swap:            0B          0B          0B
                            Total:         7.9G        1.2G        6.2G
                                     7879 M total memory
                                     1172 M used memory
                                      357 M active memory
                                     1214 M inactive memory
                                     6186 M free memory
                                        0 M buffer memory
                                      520 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            *** FILESYSTEM ***
                            Filesystem                       Type      Size  Used Avail Use% Mounted on
                            /dev/mapper/pve-vm--100--disk--1 ext4       24G   11G   13G  47% /
                            none                             tmpfs     492K  4.0K  488K   1% /dev
                            udev                             devtmpfs  3.9G     0  3.9G   0% /dev/tty
                            tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
                            tmpfs                            tmpfs     3.9G   25M  3.9G   1% /run
                            tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                            tmpfs                            tmpfs     788M     0  788M   0% /run/user/0
                            dmesg: read kernel buffer failed: Operation not permitted
                            Show mounted filesystems (real ones only):
                            TARGET                           SOURCE                                FSTYPE     OPTIONS
                            /                                /dev/mapper/pve-vm--100--disk--1      ext4       rw,relatime,stripe=16
                            |-/proc/cpuinfo                  lxcfs[/proc/cpuinfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                            |-/proc/diskstats                lxcfs[/proc/diskstats]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                            |-/proc/loadavg                  lxcfs[/proc/loadavg]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                            |-/proc/meminfo                  lxcfs[/proc/meminfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                            |-/proc/stat                     lxcfs[/proc/stat]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                            |-/proc/swaps                    lxcfs[/proc/swaps]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                            |-/proc/uptime                   lxcfs[/proc/uptime]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                            `-/sys/devices/system/cpu/online lxcfs[/sys/devices/system/cpu/online] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                            /var:
                            407M    /var/
                            207M    /var/cache
                            203M    /var/cache/apt
                            179M    /var/lib
                            141M    /var/cache/apt/archives
                            /opt/iobroker/backups:
                            4.8G    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            2.6G    /opt/iobroker/iobroker-data/
                            2.3G    /opt/iobroker/iobroker-data/history
                            197M    /opt/iobroker/iobroker-data/files
                            64M     /opt/iobroker/iobroker-data/backup-objects
                            53M     /opt/iobroker/iobroker-data/files/javascript.admin
                            20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
                            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                            14M     /opt/iobroker/iobroker-data/influxdata.json
                            13M     /opt/iobroker/iobroker-data/objects.jsonl
                            12M     /opt/iobroker/iobroker-data/objects.json.migrated
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v14.21.3
                            /usr/bin/node           v14.21.3
                            /usr/bin/npm            6.14.18
                            /usr/bin/npx            6.14.18
                            nodejs:
                              Installed: 14.21.3-deb-1nodesource1
                              Candidate: 14.21.3-deb-1nodesource1
                              Version table:
                             *** 14.21.3-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_14.x buster/main amd64 Packages
                                    100 /var/lib/dpkg/status
                                 10.24.0~dfsg-1~deb10u3 500
                                    500 http://security.debian.org buster/updates/main amd64 Packages
                                 10.24.0~dfsg-1~deb10u1 500
                                    500 http://ftp.debian.org/debian buster/main amd64 Packages
                            No problems detected
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller:  4.0.24
                            admin:          6.4.3
                            javascript:     7.0.3
                            npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
                            npm ERR! peer dep missing: onvif@^0.5.5, required by onvif-snapshot@1.0.3
                            Adapters from github:   3
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : iobroker-main-master                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.alexa2.0                 : alexa2                : iobroker-main-master                     - disabled
                            + system.adapter.backitup.0               : backitup              : iobroker-main-master                     -  enabled
                              system.adapter.daswetter.0              : daswetter             : iobroker-main-master                     -  enabled
                            + system.adapter.discovery.0              : discovery             : iobroker-main-master                     -  enabled
                              system.adapter.dwd.0                    : dwd                   : iobroker-main-master                     -  enabled
                              system.adapter.email.0                  : email                 : iobroker-main-master                     - disabled
                              system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-main-master                     - disabled
                              system.adapter.flot.0                   : flot                  : iobroker-main-master                     - disabled
                            + system.adapter.fritzbox.0               : fritzbox              : iobroker-main-master                     -  enabled
                            + system.adapter.history.0                : history               : iobroker-main-master                     -  enabled
                            + system.adapter.hm-rega.0                : hm-rega               : iobroker-main-master                     -  enabled
                            + system.adapter.hm-rega.1                : hm-rega               : iobroker-main-master                     -  enabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-main-master                     -  enabled, port: 0
                            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-main-master                     -  enabled, port: 0
                            + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-main-master                     -  enabled, port: 0
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-main-master                     -  enabled
                              system.adapter.influxdb.0               : influxdb              : iobroker-main-master                     - disabled, port: 8086
                              system.adapter.iot.0                    : iot                   : iobroker-main-master                     - disabled
                            + system.adapter.javascript.0             : javascript            : iobroker-main-master                     -  enabled
                              system.adapter.mbus.0                   : mbus                  : iobroker-main-master                     - disabled, port: 502
                            + system.adapter.modbus.0                 : modbus                : iobroker-main-master                     -  enabled
                            + system.adapter.modbus.1                 : modbus                : iobroker-main-master                     -  enabled
                              system.adapter.nina.0                   : nina                  : iobroker-main-master                     - disabled
                              system.adapter.nut.0                    : nut                   : iobroker-main-master                     - disabled
                              system.adapter.odl.0                    : odl                   : iobroker-main-master                     - disabled
                              system.adapter.onvif.0                  : onvif                 : iobroker-main-master                     - disabled
                            + system.adapter.proxmox.0                : proxmox               : iobroker-main-master                     -  enabled, port: 8006
                              system.adapter.ring.0                   : ring                  : iobroker-main-master                     - disabled
                            + system.adapter.shelly.0                 : shelly                : iobroker-main-master                     -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.socketio.0               : socketio              : iobroker-main-master                     -  enabled, port: 8084, bind: 192.168.10.219, run as: admin
                            + system.adapter.telegram.0               : telegram              : iobroker-main-master                     -  enabled, port: 8443, bind: 0.0.0.0
                              system.adapter.tr-064.0                 : tr-064                : iobroker-main-master                     - disabled
                              system.adapter.tradfri.0                : tradfri               : iobroker-main-master                     - disabled
                              system.adapter.trashschedule.0          : trashschedule         : iobroker-main-master                     - disabled
                              system.adapter.unifi-protect.0          : unifi-protect         : iobroker-main-master                     - disabled
                              system.adapter.vis-history.0            : vis-history           : iobroker-main-master                     - disabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-main-master                     - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-main-master                     - disabled
                              system.adapter.vis.0                    : vis                   : iobroker-main-master                     -  enabled
                            + system.adapter.web.0                    : web                   : iobroker-main-master                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + instance is alive
                            ioBroker-Repositories
                            Active repo(s): beta
                            Installed ioBroker-Instances
                            Used repository: beta
                            Adapter    "admin"        : 6.4.3    , installed 6.4.3
                            Adapter    "alexa2"       : 3.23.2   , installed 3.3.1  [Updatable]
                            Adapter    "backitup"     : 2.6.17   , installed 2.6.17
                            Adapter    "daswetter"    : 3.1.8    , installed 3.0.1  [Updatable]
                            Adapter    "discovery"    : 3.1.0    , installed 2.7.0  [Updatable]
                            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                            Adapter    "email"        : 1.1.4    , installed 1.0.7  [Updatable]
                            Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
                            Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                            Adapter    "history"      : 2.2.4    , installed 2.2.4
                            Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                            Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
                            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                            Adapter    "iot"          : 1.14.5   , installed 1.14.5
                            Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                            Controller "js-controller": 4.0.24   , installed 4.0.24
                            Adapter    "mbus"         : 2.4.0    , installed 2.4.0
                            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                            Adapter    "nina"         : 0.0.25   , installed 0.0.22 [Updatable]
                            Adapter    "nut"          : 1.6.0    , installed 1.6.0
                            Adapter    "odl"          : 2.0.5    , installed 1.0.5  [Updatable]
                            Adapter    "onvif"        : 1.0.5    , installed 0.0.2  [Updatable]
                            Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                            Adapter    "ring"         : 3.3.0    , installed 1.1.3  [Updatable]
                            Adapter    "shelly"       : 6.4.0    , installed 4.0.8  [Updatable]
                            Adapter    "socketio"     : 6.3.5    , installed 6.3.5
                            Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                            Adapter    "tradfri"      : 3.1.3    , installed 3.1.2  [Updatable]
                            Adapter    "trashschedule": 2.2.0    , installed 0.0.11 [Updatable]
                            Adapter    "unifi-protect": 0.0.13   , installed 0.0.11 [Updatable]
                            Adapter    "vis"          : 1.4.16   , installed 1.4.16
                            Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
                            Adapter    "web"          : 5.5.3    , installed 5.5.3
                            Adapter    "ws"           : 2.3.6    , installed 2.3.6
                            Objects and States
                            Objects:        8857
                            States:         7354
                            Hit:1 http://security.debian.org buster/updates InRelease
                            Hit:2 http://ftp.debian.org/debian buster InRelease
                            Hit:3 http://ftp.debian.org/debian buster-updates InRelease
                            Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
                            Reading package lists...
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       199270240  3585075/iobroker.js
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       199270233  3585075/iobroker.js
                            tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      105        199235807  3575373/systemd-res
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30286      1/systemd
                            tcp        0      0 192.168.10.219:2000     0.0.0.0:*               LISTEN      1000       199274100  3585209/io.hm-rpc.1
                            tcp        0      0 192.168.10.219:2001     0.0.0.0:*               LISTEN      1000       199272164  3585194/io.hm-rpc.0
                            tcp        0      0 192.168.10.219:2002     0.0.0.0:*               LISTEN      1000       199274194  3585239/io.hm-rpc.2
                            tcp        0      0 192.168.10.219:8084     0.0.0.0:*               LISTEN      1000       199276621  3585359/io.socketio
                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      105        199235813  3575373/systemd-res
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          199238426  3577902/master
                            tcp6       0      0 :::5355                 :::*                    LISTEN      105        199235810  3575373/systemd-res
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          30288      1/systemd
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       199270313  3585096/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       199276671  3585374/io.web.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          30464      1/systemd
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          199238427  3577902/master
                            udp        0      0 127.0.0.53:53           0.0.0.0:*                           105        199235812  3575373/systemd-res
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          30287      1/systemd
                            udp        0      0 0.0.0.0:5355            0.0.0.0:*                           105        199235806  3575373/systemd-res
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       199273427  3585329/io.shelly.0
                            udp6       0      0 :::111                  :::*                                0          30289      1/systemd
                            udp6       0      0 :::5355                 :::*                                105        199235809  3575373/systemd-res
                            2023-04-14 21:14:30.976  - info: modbus.1 (3589548) Disconnected from slave 192.168.10.241
                            2023-04-14 21:14:36.978  - info: modbus.1 (3589548) Connected to slave
                            2023-04-14 21:14:41.980  - warn: modbus.1 (3589548) Error: undefined
                            2023-04-14 21:14:41.981  - error: modbus.1 (3589548) Request timed out.
                            2023-04-14 21:14:41.981  - error: modbus.1 (3589548) Client in error state.
                            2023-04-14 21:14:41.981  - warn: modbus.1 (3589548) Poll error count: 9 code: {"err":"timeout","timeout":5000}
                            2023-04-14 21:14:42.981  - info: modbus.1 (3589548) Disconnected from slave 192.168.10.241
                            2023-04-14 21:14:48.982  - info: modbus.1 (3589548) Connected to slave
                            2023-04-14 21:14:49.010  - error: modbus.1 (3589548) Wrong CRC for frame: 1,4,4,49,0,2,58,8,1
                            2023-04-14 21:14:53.983  - warn: modbus.1 (3589548) Error: undefined
                            2023-04-14 21:14:53.984  - error: modbus.1 (3589548) Request timed out.
                            2023-04-14 21:14:53.984  - error: modbus.1 (3589548) Client in error state.
                            2023-04-14 21:14:53.985  - warn: modbus.1 (3589548) Poll error count: 10 code: {"err":"timeout","timeout":5000}
                            2023-04-14 21:14:54.984  - info: modbus.1 (3589548) Disconnected from slave 192.168.10.241
                            2023-04-14 21:15:00.030  - info: host.iobroker-main-master instance system.adapter.dwd.0 started with pid 3589829
                            2023-04-14 21:15:00.640  - info: dwd.0 (3589829) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.21.3, js-controller: 4.0.24
                            2023-04-14 21:15:00.665  - warn: dwd.0 (3589829) No geo coordinates found in iobroker system configuration. Disable Rain Radar.
                            2023-04-14 21:15:00.986  - info: modbus.1 (3589548) Connected to slave
                            2023-04-14 21:15:01.058  - info: dwd.0 (3589829) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2023-04-14 21:15:01.585  - info: host.iobroker-main-master instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2023-04-14 21:15:04.043  - info: host.iobroker-main-master instance system.adapter.daswetter.0 started with pid 3590135
                            2023-04-14 21:15:04.652  - info: daswetter.0 (3590135) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.21.3, js-controller: 4.0.24
                            2023-04-14 21:15:04.668  - info: daswetter.0 (3590135) Terminated (NO_ERROR): Without reason
                            2023-04-14 21:15:05.175  - info: daswetter.0 (3590135) cleaned everything up...
                            2023-04-14 21:15:05.180  - info: host.iobroker-main-master instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                              F5 drücken, dann geht es.
                                helmut1963 @Thomas Braun last edited by
                                ...habs gerade gemerkt und nachgeschoben.
                                  buster
                                  Ist nicht mehr aktuell, das wäre 'bullseye'.
                                  Keine Zeitzone gesetzt.
                                  root
                                  Nicht als root herumkaspern, man verwendet einen Standarduser.
                                  nodejs v14.21.3
                                  Zwar richtig installiert, die empfohlene Version wäre allerdings v18.
                                  Dürfte sich auch mit nodejs v18 ergeben.
                                  Bring die ganzen Adapter auf Stand. Ich würde dir allerdings vom Beta-Repository abraten und stable empfehlen. Da muss man auch weniger Updates einspielen.
                                    und den hast du mal vollständig stromlos gemacht?
                                    nimm mal nur den SDM und lass den Widerstand weg.
                                    Waveshare RS485 / TCP) Adapter mit IP
                                    den kenn ich nicht. weiss nicht was da zu konfigurieren ist.
                                      So Leute, an alle die mitgeholfen haben: Vielen Dank !
                                      Nach einer halb schlaflosen Nacht, den ganzen Updates und viel Herumprobiererei spricht zumindest mal der AC-Zähler auf einem Datenpunkt mit mir, Dh. der Iobroker hält nun die Verbindung und fragt in den eingestellten Abständen den Zähler ab und liefert sogar den richtigen Wert.... ("Spannung_DC-Panel" stammt noch vom Probieren, wird noch geändert...)
                                      Das Datenformat ist übrigens "Float (Big Endian)...
                                      Da ich keinen anderen Grund erkennen kann, bleibt als Ursache tatsächlich nur die veraltete Installation.
                                      Danke für`s Anstacheln, das Update endlich anzupacken. Liegt mir schon lange auf dem Magen.
                                      Ich denke da wird die endgültige Installation in der Backup-PV-Anlage mit den restlichen Datenpunkten schon irgendwie funktionieren. Ansonsten hört Ihr wieder von mir 😉
                                      Wen`s interessiert: https://www.qrz.com/db/DL1HJA und ein bisschen runterscrollen bis zum PV-Beitrag.
                                      Grüße, Helmut
                                      1409
