    4. [How-to] Node.js für ioBroker richtig updaten
      grazer75 last edited by grazer75
      @thomas-braun mit 18 wieder viele Meldungen
      erstmal iob diag
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       20:41:31 up 2 min,  2 users,  load average: 3.46, 1.59, 0.61
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=54.0'C
      volt=0.9460V
      *** Time and Time Zones ***
                     Local time: Sun 2023-04-16 20:41:32 CEST
                 Universal time: Sun 2023-04-16 18:41:32 UTC
                       RTC time: n/a
                      Time zone: Europe/Vienna (CEST, +0200)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      andreas
      /home/andreas
      andreas adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            7.8G        2.2G        5.2G        6.0M        409M        5.5G
      Swap:            99M          0B         99M
      Total:          7.9G        2.2G        5.3G
               7811 M total memory
               2207 M used memory
               2290 M active memory
                198 M inactive memory
               5194 M free memory
                 51 M buffer memory
                357 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      118G  6.3G  107G   6% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  924K  1.6G   1% /run
      /dev/sda1      vfat      253M   31M  222M  13% /boot
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Sun Apr 16 20:39:09 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:C5:38:E2 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=270f37e4-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Apr 16 20:39:11 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Apr 16 20:39:11 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sun Apr 16 20:39:12 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      2.2G    /var/
      1.6G    /var/log
      1.4G    /var/log/journal/deee1983c79b418b90418f11a8f1c85d
      317M    /var/cache
      Archived and active journals take up 1.3G in the file system.
      /opt/iobroker/backups:
      395M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      452M    /opt/iobroker/iobroker-data/
      333M    /opt/iobroker/iobroker-data/files
      87M     /opt/iobroker/iobroker-data/backup-objects
      72M     /opt/iobroker/iobroker-data/files/telegram.admin
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      23M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      15M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/bin/node           v18.16.0
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           16.19.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
              throw e;
      Error: Connection is closed.
          at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
          at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
          at Object.onceWrapper (node:events:628:26)
          at Socket.emit (node:events:513:28)
          at TCP.<anonymous> (node:net:322:12)
      Emitted 'error' event on ScanStream instance at:
          at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
          at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      Node.js v18.16.0
              throw e;
          at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
          at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
          at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
          at Readable.read (node:internal/streams/readable:496:12)
          at resume_ (node:internal/streams/readable:999:12)
          at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      Node.js v18.16.0
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     7.0.3
      Adapters from github:   4
      Adapter State
        system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.benchmark.0              : benchmark             : raspberrypi                              - disabled
      + system.adapter.bmw.0                    : bmw                   : raspberrypi                              -  enabled
        system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
        system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
      + system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi                              -  enabled
      + system.adapter.countdown.0              : countdown             : raspberrypi                              -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
        system.adapter.fb-checkpresence.1       : fb-checkpresence      : raspberrypi                              - disabled
      + system.adapter.firetv.0                 : firetv                : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
        system.adapter.followthesun.0           : followthesun          : raspberrypi                              -  enabled
        system.adapter.foobar2000.0             : foobar2000            : raspberrypi                              - disabled, port: 8888
      + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
        system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
      + system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : raspberrypi                              -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.lgtv11.0                 : lgtv11                : raspberrypi                              -  enabled, port: 8080
        system.adapter.life360.0                : life360               : raspberrypi                              - disabled
        system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi                              -  enabled
        system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
        system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
      + system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
        system.adapter.meteoalarm.0             : meteoalarm            : raspberrypi                              -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
        system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
      + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
        system.adapter.netatmo-energy.0         : netatmo-energy        : raspberrypi                              -  enabled
      + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
        system.adapter.nuki.0                   : nuki                  : raspberrypi                              -  enabled
        system.adapter.nut.0                    : nut                   : raspberrypi                              - disabled
        system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled
        system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
      + system.adapter.owntracks.0              : owntracks             : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
        system.adapter.paw.0                    : paw                   : raspberrypi                              - disabled, port: 8898
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.pushbullet.0             : pushbullet            : raspberrypi                              -  enabled
        system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
        system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
        system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
        system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 192.168.1.139
        system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
      + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
        system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.tr-064.1                 : tr-064                : raspberrypi                              - disabled
        system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
        system.adapter.virtualpowermeter.0      : virtualpowermeter     : raspberrypi                              -  enabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
        system.adapter.windows-control.0        : windows-control       : raspberrypi                              -  enabled
        system.adapter.withings.0               : withings              : raspberrypi                              -  enabled
        system.adapter.xbox.0                   : xbox                  : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
      + instance is alive
      + system.adapter.lgtv11.0                 : lgtv11                : raspberrypi                              -  enabled, port: 8080
      + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "alarm"        : 3.3.9    , installed 3.3.9
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "backitup"     : 2.6.16   , installed 2.6.16
      Adapter    "benchmark"    : 1.1.4    , installed 1.1.4
      Adapter    "bmw"          : 2.5.7    , installed 2.5.7
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "cloud"        : 4.3.0    , installed 4.3.0
      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
      Adapter    "countdown"    : 1.2.5    , installed 1.2.5
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
      Adapter    "email"        : 1.1.4    , installed 1.1.4
      Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
      Adapter    "firetv"       : 1.0.0    , installed 1.0.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "followthesun" : 0.4.1    , installed 0.4.1
      Adapter    "foobar2000"   : 2.0.4    , installed 2.0.4
      Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
      Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
      Adapter    "fuelpricemonitor": 0.3.4 , installed 0.3.4
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hmip"         : 1.20.0   , installed 1.20.0
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.14.2   , installed 1.14.2
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 6.1.4    , installed 7.0.3
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "linux-control": 1.1.3    , installed 1.1.3
      Adapter    "logparser"    : 2.1.1    , installed 2.1.1
      Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
      Adapter    "meteoalarm"   : 2.3.5    , installed 2.3.5
      Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "netatmo-energy": 2.3.1   , installed 2.3.1
      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
      Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "onvif"        : 1.0.4    , installed 1.0.4
      Adapter    "openweathermap": 0.3.3   , installed 0.3.3
      Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
      Adapter    "parser"       : 1.1.8    , installed 1.1.8
      Adapter    "paw"          : 0.3.2    , installed 0.3.2
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
      Adapter    "radar2"       : 2.0.3    , installed 2.0.3
      Adapter    "sayit"        : 1.12.3   , installed 1.12.3
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
      Adapter    "snmp"         : 2.4.6    , installed 2.4.6
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
      Adapter    "statistics"   : 2.3.0    , installed 2.3.0
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.13.1   , installed 3.13.1
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "withings"     : 0.0.13   , installed 0.0.13
      Adapter    "xbox"         : 1.0.2    , installed 1.0.2
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects:        29904
      States:         24682
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://packages.sury.org/php bullseye InRelease
      Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:7 http://archive.raspberrypi.org/debian bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15749      514/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15742      514/iobroker.js-con
      tcp        0      0 192.168.1.139:1884      0.0.0.0:*               LISTEN      1001       14194      1063/io.sonoff.0
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       23895      1756/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11929      562/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13956      1009/io.owntracks.0
      tcp6       0      0 :::51989                :::*                    LISTEN      1001       17211      1210/io.nuki-extend
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15209      765/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       26807      2137/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24036      2065/io.socketio.0
      tcp6       0      0 :::80                   :::*                    LISTEN      0          15000      573/apache2
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11931      562/sshd: /usr/sbin
      tcp6       0      0 :::9999                 :::*                    LISTEN      0          15004      573/apache2
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       17814      1161/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       17815      1161/io.tuya.0
      udp        0      0 0.0.0.0:44617           0.0.0.0:*                           1001       26831      2048/io.snmp.0
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       22280      2003/io.radar2.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13240      827/dhcpcd
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       16758      964/io.mihome-vacuu
      udp        0    768 0.0.0.0:46003           0.0.0.0:*                           1001       32789      2241/io.xbox.0
      udp        0      0 0.0.0.0:42092           0.0.0.0:*                           1001       26718      2091/io.upnp.0
      udp        0      0 192.168.1.139:5353      0.0.0.0:*                           1001       17759      1144/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12881      397/avahi-daemon: r
      udp        0      0 0.0.0.0:38559           0.0.0.0:*                           1001       16663      857/io.javascript.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       25730      2091/io.upnp.0
      udp        0      0 0.0.0.0:59680           0.0.0.0:*                           108        12883      397/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12882      397/avahi-daemon: r
      udp6       0      0 :::51466                :::*                                108        12884      397/avahi-daemon: r
      2023-04-16 20:43:57.659  - info: radar2.0 (2003) first scan took 18.02 seconds
      2023-04-16 20:43:57.660  - info: radar2.0 (2003) will scan external network every  60  minutes
      2023-04-16 20:43:57.713  - info: followthesun.0 (2396) Started with JSON-Explorer version 0.1.10
      2023-04-16 20:43:57.716  - info: followthesun.0 (2396) Sun position calculation will be done every 120 seconds
      2023-04-16 20:43:57.722  - info: followthesun.0 (2396) Daily sun parameter calculation scheduled for 00:00:33
      2023-04-16 20:43:58.289  - info: radar2.0 (2003) Adapter initialization finished!
      2023-04-16 20:43:58.390  - info: netatmo-crawler.0 (1845) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2023-04-16 20:44:02.779  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-04-16 20:44:03.617  - info: info.0 (1670) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v18.16.0, js-controller: 4.0.24
      2023-04-16 20:44:04.083  - info: info.0 (1670) Reading/updating systemdata.
      2023-04-16 20:44:05.316  - info: xbox.0 (2241) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.xbox, node: v18.16.0, js-controller: 4.0.24
      2023-04-16 20:44:06.014  - info: xbox.0 (2241) Successfully loaded token
      2023-04-16 20:44:06.717  - info: xbox.0 (2241) Xbox login url available at: https://login.live.com/oauth20_authorize.srf?client_id=5e5ead27-ed60-482d-b3fc-702b28a97404&response_type=code&approval_prompt=auto&scope=XboxLive.signin%20XboxLive.offline_access&redirect_uri=http%3A%2F%2Flocalhost%3A8080%2Fauth%2Fcallback
      2023-04-16 20:44:06.720  - info: xbox.0 (2241) Copy the token (value after code=) after login into "apiToken" of the adapter config to enable the Xbox api
      2023-04-16 20:44:06.762  - warn: xbox.0 (2241) Could not poll API: "No oauth token found. Run authentication flow first"
      2023-04-16 20:44:07.626  - info: info.0 (1670) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
      2023-04-16 20:44:08.460  - info: info.0 (1670) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
      2023-04-16 20:44:08.814  - info: smartcontrol.0 (2036) Subscribing to all target devices and trigger states. 4 trigger schedules activated...
      2023-04-16 20:44:09.510  - info: info.0 (1670) cpu Temp res = {"main":55.504,"cores":[],"max":55.504,"socket":[],"chipset":null}
      2023-04-16 20:44:28.270  - info: netatmo-energy.0 (1948) API-Anfrage starten: homestatus
      2023-04-16 20:44:32.394  - info: coronavirus-statistics.0 (1281) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-04-16 20:44:33.280  - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-04-16 20:44:41.850  - info: fuelpricemonitor.0 (1616) Terminated (NO_ERROR): Without reason
      2023-04-16 20:44:42.436  - info: fuelpricemonitor.0 (1616) cleaned everything up...
      2023-04-16 20:44:42.680  - info: host.raspberrypi instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
      Summary
                           v.2023-04-16
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Kernel:                 6.1.21-v8+
      Installation:           Native
      Timezone:               Europe/Vienna (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            7.8G        2.9G        4.1G        6.0M        797M        4.8G
      Swap:            99M          0B         99M
      Total:          7.9G        2.9G        4.2G
      Active iob-Instances:   57
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                29904
      States:                 24682
      Size of iob-Database:
      27M     /opt/iobroker/iobroker-data/objects.jsonl
      14M     /opt/iobroker/iobroker-data/states.jsonl
      Iobroker log
      javascript.0
      2023-04-16 20:48:57.954	warn	Read-only state "javascript.0.MiHomeAll.lumi.158d0002a3299c.info.rssi" has been written without ack-flag with value "0"
      javascript.0
      2023-04-16 20:48:57.946	warn	Read-only state "javascript.0.MiHomeAll.396976417.info.rssi" has been written without ack-flag with value "-55"
      javascript.0
      2023-04-16 20:48:57.943	warn	Read-only state "javascript.0.MiHomeAll.lumi.158d0004ac0836.info.rssi" has been written without ack-flag with value "0"
      javascript.0
      2023-04-16 20:48:57.939	warn	Read-only state "javascript.0.MiHomeAll.408471265.info.rssi" has been written without ack-flag with value "-46"
      javascript.0
      2023-04-16 20:48:57.717	warn	script.js.XiaomiGeraeteCN: No supported Devices found!
      tuya.0
      2023-04-16 20:49:52.026	warn	80157022e0980602099a: Error on Reconnect (1): connect ECONNRESET 192.168.1.212:6668
      tuya.0
      2023-04-16 20:49:52.016	warn	80248051e098069e47eb: Error on Reconnect (1): connect ECONNRESET 192.168.1.167:6668
      tuya.0
      2023-04-16 20:49:51.953	warn	47804507a4cf12ccd3ef: Error on Reconnect (1): connect ECONNRESET 192.168.1.161:6668
      tuya.0
      2023-04-16 20:49:51.820	warn	80157022e09806010425: Error on Reconnect (1): connect ECONNRESET 192.168.1.194:6668
      wifilight.0
      2023-04-16 20:49:51.495	error	wrong device type. not yet supported!
      wifilight.0
      2023-04-16 20:49:51.492	error	config.device.type "" (HF-LPT120) is not a known device type. Skipping this device! Known types are: LW12, LD382A, LD686, LD382, UFO, MiLight, MiLightRGB, MiLightW
      rpi2.0
      2023-04-16 20:49:30.607	error	No Value found for cpu_frequency
      netatmo.0
      2023-04-16 20:49:17.457	warn	API Error: Please Authenticate manually once using the Admin UI of this instance.
      backitup.0
      2023-04-16 20:50:13.179	error	Dropbox: "expired_access_token/."
      backitup.0
      2023-04-16 20:50:13.160	error	Dropbox: "expired_access_token/."
      nuki-extended.0
      2023-04-16 20:50:05.279	warn	getWebApi(): Error retrieving smartlocks: Cannot read properties of undefined (reading 'toLowerCase')
      zigbee.0
      2023-04-16 20:50:05.063	warn	Extended PAN ID is reversed (expected=51b8a11c004b1200, actual=00124b001ca1b851)
      nuki-extended.0
      2023-04-16 20:50:03.493	warn	Failed retrieving /list from Nuki Bridge with name Schiess Nuki Bridge (forcePlainToken: false)!
      firetv.0
      2023-04-16 20:50:33.728	error	can not connect to 192.168.1.208 Error=spawn adb ENOENT
      firetv.0
      2023-04-16 20:50:33.634	error	adb executable not found. undefined
      zigbee.0
      2023-04-16 20:50:49.101	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x003c84fffeb3dbf7 TS0044 (Error: Read 0x003c84fffeb3dbf7/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
      onvif.0
      2023-04-16 20:51:56.636	error	Error during discovery: Error: Wrong ONVIF SOAP response,Error: Wrong ONVIF SOAP response,Error: Wrong ONVIF SOAP response,TypeError: Cannot read properties of undefined (reading 'endpointReference'),TypeError: Cannot read properties of undefined (reading 'endpointReference')
      onvif.0
      2023-04-16 20:51:52.776	error	Error Error: ONVIF SOAP Fault: The action requested requires authorization and the sender is not authorized
      onvif.0
      2023-04-16 20:51:52.775	error	Failed to login to 192.168.1.218:8000 with admin:$*****************************************************************************7
      onvif.0
      2023-04-16 20:51:52.539	error	Error Error: ONVIF SOAP Fault: The action requested requires authorization and the sender is not authorized
      onvif.0
      2023-04-16 20:51:52.538	error	Failed to login to 192.168.1.211:8000 with admin:$*****************************************************************************7
      onvif.0
      2023-04-16 20:51:52.320	error	undefined
      onvif.0
      2023-04-16 20:51:52.320	error	<?xml version="1.0" ?> <soap:Envelope > <soap:Header> <wsa:Action>http://schemas.xmlsoap.org/ws/2005/04/discovery/ProbeMatches</wsa:Action> <wsa:MessageID>urn:uuid:0eaaa933-a101-4933-86f1-3ce46179ab26</wsa:MessageID> <wsa:RelatesTo>urn:uuid:8d65c8dd-fa75-977b-db4d-fc1d23082a1c</wsa:RelatesTo> <wsa:To>http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</wsa:To> <wsd:AppSequence InstanceId="1170846535" MessageNumber="1"/> </soap:Header> <soap:Body> <wsd:ProbeMatches/> </soap:Body> </soap:Envelope>
      onvif.0
      2023-04-16 20:51:52.319	error	Discovery error Wrong SOAP message from 192.168.1.135:35191
      onvif.0
      2023-04-16 20:51:52.222	error	undefined
      onvif.0
      2023-04-16 20:51:52.221	error	<?xml version="1.0" ?> <soap:Envelope > <soap:Header> <wsa:Action>http://schemas.xmlsoap.org/ws/2005/04/discovery/ProbeMatches</wsa:Action> <wsa:MessageID>urn:uuid:0eaaa933-a101-4933-86f1-3ce46179ab26</wsa:MessageID> <wsa:RelatesTo>urn:uuid:8d65c8dd-fa75-977b-db4d-fc1d23082a1c</wsa:RelatesTo> <wsa:To>http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</wsa:To> <wsd:AppSequence InstanceId="1170846535" MessageNumber="1"/> </soap:Header> <soap:Body> <wsd:ProbeMatches/> </soap:Body> </soap:Envelope>
      onvif.0
      2023-04-16 20:51:52.219	error	Discovery error Wrong SOAP message from 192.168.1.135:35191
      onvif.0
      2023-04-16 20:51:52.137	error	Error Error: connect ECONNREFUSED 192.168.1.115:8000
      onvif.0
      2023-04-16 20:51:52.136	error	Failed to login to 192.168.1.115:8000 with admin:$*****************************************************************************7
      onvif.0
      2023-04-16 20:51:51.863	error	undefined
      onvif.0
      2023-04-16 20:51:51.862	error
      onvif.0
      2023-04-16 20:51:51.862	error	Discovery error Wrong SOAP message from 192.168.1.211:3702
      onvif.0
      2023-04-16 20:51:51.848	error	undefined
      onvif.0
      2023-04-16 20:51:51.847	error
      onvif.0
      2023-04-16 20:51:51.846	error	Discovery error Wrong SOAP message from 192.168.1.218:3702
      onvif.0
      2023-04-16 20:51:51.816	error	undefined
      onvif.0
      2023-04-16 20:51:51.814	error
      onvif.0
      2023-04-16 20:51:51.813	error	Discovery error Wrong SOAP message from 192.168.1.115:3702
      linux-control.0
      2023-04-16 20:51:44.647	warn	This object will not be created in future versions. Please report this to the developer.
      linux-control.0
      2023-04-16 20:51:44.645	warn	Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      linux-control.0
      2023-04-16 20:51:40.863	warn	This object will not be created in future versions. Please report this to the developer.
      linux-control.0
      2023-04-16 20:51:40.855	warn	Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      Werde daher wieder auf 16 gehen, außer ihr wisst eine Lösung für die Fehler
      Mein aktueller Status
      which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.19.1
      v16.19.1
      8.19.3
      nodejs:
        Installed: 16.19.1-deb-1nodesource1
        Version table:
       *** 16.19.1-deb-1nodesource1 500
        Thomas Braun Most Active @grazer75 last edited by
        @grazer75
        Schaut für mich eher nach Netzwerk / PW Encoding aus.
        Log dich jeweils bei den Dingern nochmal ein.
          @grazer75 sagte in [How-to] Node.js für ioBroker richtig updaten:
          Du musst auch schon die Chance lassen den Output auch zu lesen...
            grazer75 @Thomas Braun last edited by
            @thomas-braun ich bin auf 16 zurück allerdings sind die Fehler noch da
            zigbee.0
            2023-04-16 21:07:43.024	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x003c84fffeb3dbf7 TS0044 (Error: Read 0x003c84fffeb3dbf7/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
            firetv.0
            2023-04-16 21:07:32.731	error	can not connect to 192.168.1.208 Error=spawn adb ENOENT
            firetv.0
            2023-04-16 21:07:32.614	error	adb executable not found. undefined
            2023-04-16 21:07:14.106	warn	Hospital Data Warning: Error: Cannot get german hospital data from divi: TypeError: Cannot read properties of undefined (reading 'toLowerCase')
            backitup.0
            2023-04-16 21:07:13.950	error	Dropbox: "expired_access_token/.."
            backitup.0
            2023-04-16 21:07:13.948	error	Dropbox: "expired_access_token/.."
            2023-04-16 21:07:09.893	warn	This object will not be created in future versions. Please report this to the developer.
            2023-04-16 21:07:09.888	warn	Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
            zigbee.0
            2023-04-16 21:06:59.736	warn	Extended PAN ID is reversed (expected=51b8a11c004b1200, actual=00124b001ca1b851)
            nuki-extended.0
            2023-04-16 21:06:58.499	warn	getWebApi(): Error retrieving smartlocks: Cannot read properties of undefined (reading 'toLowerCase')
            nuki-extended.0
            2023-04-16 21:06:56.839	warn	Failed retrieving /list from Nuki Bridge with name Schiesstattgasse Nuki Bridge (forcePlainToken: false)!
            tuya.0
            2023-04-16 21:06:52.531	warn	47804507a4cf12ccd3ef: Error on Reconnect (1): connect ECONNRESET 192.168.1.161:6668
            tuya.0
            2023-04-16 21:06:52.501	warn	80248051e098069e47eb: Error on Reconnect (1): connect ECONNRESET 192.168.1.167:6668
            tuya.0
            2023-04-16 21:06:51.754	warn	80157022e0980602099a: Error on Reconnect (1): connect ECONNRESET 192.168.1.212:6668
            tuya.0
            2023-04-16 21:06:51.625	warn	43024001f4cfa2de874f: Error on Reconnect (1): connect ECONNRESET 192.168.1.249:6668
            tuya.0
            2023-04-16 21:06:51.455	warn	80157022e09806010425: Error on Reconnect (1): connect ECONNRESET 192.168.1.194:6668
            wifilight.0
            2023-04-16 21:06:43.474	error	wrong device type. not yet supported!
            wifilight.0
            2023-04-16 21:06:43.470	error	config.device.type "" (HF-LPT120) is not a known device type. Skipping this device!Known types are: LW12, LD382A, LD686, LD382, UFO, MiLight, MiLightRGB, MiLightW
            rpi2.0
            2023-04-16 21:06:18.496	error	No Value found for cpu_frequency
            mihome-vacuum.0
            2023-04-16 21:06:09.094	warn	No Answer for DeviceModel use model from Config
            mihome-vacuum.0
            2023-04-16 21:06:09.092	warn	No Answer for DeviceModel use old one
            mihome-vacuum.0
            2023-04-16 21:06:09.090	error	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
            netatmo.0
            2023-04-16 21:06:07.174	warn	API Error: Please Authenticate manually once using the Admin UI of this instance.
            Gestern hatte ich es geschafft das wieder weg geht.
            Eventuell Cache purge bzw npm rebuild?
            Überall alles neu machen, hab ich nicht wirklich Zeit.
            Mit einem zurück auf 16 gestern ging es ohne das ich weiter was anpassen musste
              @grazer75
              Alles keine Dinge die ich primär auf nodejs schieben würde.
                @thomas-braun wie gesagt gestern hab ich mehrere Sachen probiert, ohne das ich ein Backup zurück restored habe
                und dann waren die Fehler weg und ich zurück auf Version 16
                Nun bin ich auf 16, krieg schon wieder die Fehler nicht weg
                host.raspberrypi
                2023-04-16 21:20:00.149	warn	instance system.adapter.netatmo-crawler.0 already running with pid 1571
                zigbee.0
                2023-04-16 21:19:34.992	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x003c84fffeb3dbf7 TS0044 (Error: Read 0x003c84fffeb3dbf7/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
                firetv.0
                2023-04-16 21:19:09.339	error	can not connect to 192.168.1.208 Error=spawn adb ENOENT
                firetv.0
                2023-04-16 21:19:09.136	error	adb executable not found. undefined
                2023-04-16 21:19:06.257	warn	Hospital Data Warning: Error: Cannot get german hospital data from divi: TypeError: Cannot read properties of undefined (reading 'toLowerCase')
                zigbee.0
                2023-04-16 21:18:54.487	warn	DeviceAvailability:Failed to ping 0x5c0272fffe5b8c0e TRADFRI Signal Repeater
                backitup.0
                2023-04-16 21:18:53.396	error	Dropbox: "expired_access_token/."
                backitup.0
                2023-04-16 21:18:53.395	error	Dropbox: "expired_access_token/."
                2023-04-16 21:18:51.607	warn	This object will not be created in future versions. Please report this to the developer.
                2023-04-16 21:18:51.603	warn	Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
                zigbee.0
                2023-04-16 21:18:49.027	warn	Extended PAN ID is reversed (expected=51b8a11c004b1200, actual=00124b001ca1b851)
                nuki-extended.0
                2023-04-16 21:18:43.554	warn	getWebApi(): Error retrieving smartlocks: Cannot read properties of undefined (reading 'toLowerCase')
                nuki-extended.0
                2023-04-16 21:18:42.175	warn	Failed retrieving /list from Nuki Bridge with name Schiesstattgasse Nuki Bridge (forcePlainToken: false)!
                wifilight.0
                2023-04-16 21:18:26.393	error	wrong device type. not yet supported!
                wifilight.0
                2023-04-16 21:18:26.388	error	config.device.type "" (HF-LPT120) is not a known device type. Skipping this device!Known types are: LW12, LD382A, LD686, LD382, UFO, MiLight, MiLightRGB, MiLightW
                rpi2.0
                2023-04-16 21:18:03.613	error	No Value found for cpu_frequency
                netatmo.0
                2023-04-16 21:17:51.067	warn	API Error: Please Authenticate manually once using the Admin UI of this instance.
                wie komm ich wieder zu einer funktionierenden 16 Version außer jetzt wieder alles mögliche wie gestern zu probieren?`
                Thomas Braun DJMarc75 2 Replies Last reply Reply Quote 0
                  @grazer75
                  Du wirst dir die einzelnen Adapter und deren Einstellungen anschauen müssen.
                  War der iobroker eigentlich heruntergefahren, als du nodejs upgedated hast?
                  • DJMarc75
                    DJMarc75 @grazer75 last edited by
                    warum nicht ein sauberes/frisches System aufsetzen und wenn alles aktuell ist iobroker und ein Backup einspielen ?
                    Der Beitrag wird ja sonst weiter aufgebläht ...
                      @djmarc75 weil auch andere Sachen auf dem pi habe?
                      Tasmotaadmin etc
                        grazer75 @Thomas Braun last edited by grazer75
                        @thomas-braun war er, iob stop
                        Wie gesagt gestern war das gleiche mit dem Update auf 18, waren dann Fehler auch nach dem downgrade auf 16.
                        Hab dann alles mögliche probiert und dann ging es wieder.
                        Leider nichts mitgeschrieben, sondern nur in panik google durchsucht.
                         sudo npm cache clean --force
                        sudo -H -u iobroker npm install iobroker.js-controller
                        iob fix
                        probiert.
                        Und jetzt hab ich es wieder geschafft das es geht ...
                        BLE Adapter installiert und danach wieder gelöscht und die Fehler sind weg.
                        Versteh ich irgendwie nicht ganz.
                        16er läuft wieder
                        • DJMarc75
                          kann ja nicht hellsehen - dann viel Glück
                            Das ist schlecht. Also Panik.
                            Ich würde auf 18 gehen und mir dann die jeweiligen Adapter/Instanzen Stück für Stück anschauen.
                              @thomas-braun 16er läuft wieder, weiß nicht ob es nur ble Adapter installieren und löschen war und deshalb alles wieder geht. Fehler sind alle wieder weg.
                                Du weißt schon, dass gerade der BLE-Adapter neugebaut wird? Geht i.d.R. automatisch.
                                  @thomas-braun aber das installieren von ble und deinstallieren hat die Fehler bereinigt irgendwie
                                  Es geht wieder mit 16.x weiß nicht ob ich den Trick auf mit 18.x probieren sollte oder lieber froh sein das ich wieder einen funktionierenden iobroker hab ohne Fehler 🐶
                                    apollon77 @grazer75 last edited by
                                    @grazer75 Hi,
                                    also ich kann es nur nochmals wiederholen ... alle Fehler aus dem ioBroker Log haben NICHTS mit der Node.js Version zu tun!! Da die plötzlich bei node.js 16 weg sind und bei 18 da sind ist aber mal soooowas von unerklärbar!
                                    1.) Javascript "Read-only state "javascript.0.MiHomeAll.lumi.158d0002a3299c.info.rssi" has been written ..." ist ein Fehler in einem deiner Skripte. Ein Objekt mit write:false darf nur mit ack=true beschrieben werden. Dieser Fehler KANN NICHT mit der Nodejs version zu tun haben, tut aber auch erstmal nicht weh
                                    2.) Tuya connect ECONNRESET bedeutet das das Tuya-Gerät die Verbindung resettet/abgelehnt/abgebrochen hat. Kann ebenso NICHTS mit Nodejs zu tun haben
                                    3.) Wifilight "(HF-LPT120) is not a known device type. Skipping this device!" ... die Meldung spricht auch für sich.
                                    4.) firetv "adb executable not found. undefined" sagt das ein executable nicht da ist ...
                                    ALso Wenn da vorher was tat und nach nodejs 18 nicht mehr dann ist das schon eher komisch und seehr unerklärlich. Da solltest Du denke ich mit etwas Zeit mal das Gesamtsysteme aus einem Backup restoren und neu aufsetzen und alles sauber wieder zum Laufen bekommen
                                    Atifan 1 Reply Last reply Reply Quote 0
                                    • Atifan
                                      Atifan @apollon77 last edited by Atifan
                                      Hi. irgendwie komme ich nicht auf node.js 18.16.0
                                      Ich mache " curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -"
                                      Danach "sudo apt-get install -y nodejs`"
                                      Es ist zwar dann 18.16.0 installiert. Aber wenn ich "node -v" eingebe, dann sagt er 16.19.0
                                        Thomas Braun Most Active @Atifan last edited by
                                        @atifan
                                        Wie immer:
                                        Keine Screenshots aus der Konsole.
                                        • Atifan
                                          Atifan @Thomas Braun last edited by
                                          @thomas-braun sagte in [How-to] Node.js für ioBroker richtig updaten:
                                          @atifan
                                          Wie immer:
                                          Hm, wieso das denn? Ist das verboten? Wusste ich nicht. Aber wieso keine Screens von Console?
                                            Thomas Braun Most Active @Atifan last edited by Thomas Braun
                                            @atifan
                                            Weil man die nicht immer lesen kann, man nicht daraus kopieren kann, der Text als Bild nicht von der Suchfunktion erfasst werden kann, ein Bild fetter ist als der reine Text, usw...
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            733993
