    4. [How-to] Node.js für ioBroker richtig updaten
      grazer75 last edited by
      @thomas-braun wie gesagt gestern hab ich mehrere Sachen probiert, ohne das ich ein Backup zurück restored habe
      und dann waren die Fehler weg und ich zurück auf Version 16
      Nun bin ich auf 16, krieg schon wieder die Fehler nicht weg
      host.raspberrypi
      2023-04-16 21:20:00.149	warn	instance system.adapter.netatmo-crawler.0 already running with pid 1571
      zigbee.0
      2023-04-16 21:19:34.992	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x003c84fffeb3dbf7 TS0044 (Error: Read 0x003c84fffeb3dbf7/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
      firetv.0
      2023-04-16 21:19:09.339	error	can not connect to 192.168.1.208 Error=spawn adb ENOENT
      firetv.0
      2023-04-16 21:19:09.136	error	adb executable not found. undefined
      coronavirus-statistics.0
      2023-04-16 21:19:06.257	warn	Hospital Data Warning: Error: Cannot get german hospital data from divi: TypeError: Cannot read properties of undefined (reading 'toLowerCase')
      zigbee.0
      2023-04-16 21:18:54.487	warn	DeviceAvailability:Failed to ping 0x5c0272fffe5b8c0e TRADFRI Signal Repeater
      backitup.0
      2023-04-16 21:18:53.396	error	Dropbox: "expired_access_token/."
      backitup.0
      2023-04-16 21:18:53.395	error	Dropbox: "expired_access_token/."
      2023-04-16 21:18:51.607	warn	This object will not be created in future versions. Please report this to the developer.
      2023-04-16 21:18:51.603	warn	Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
      zigbee.0
      2023-04-16 21:18:49.027	warn	Extended PAN ID is reversed (expected=51b8a11c004b1200, actual=00124b001ca1b851)
      nuki-extended.0
      2023-04-16 21:18:43.554	warn	getWebApi(): Error retrieving smartlocks: Cannot read properties of undefined (reading 'toLowerCase')
      nuki-extended.0
      2023-04-16 21:18:42.175	warn	Failed retrieving /list from Nuki Bridge with name Schiesstattgasse Nuki Bridge (forcePlainToken: false)!
      wifilight.0
      2023-04-16 21:18:26.393	error	wrong device type. not yet supported!
      wifilight.0
      2023-04-16 21:18:26.388	error	config.device.type "" (HF-LPT120) is not a known device type. Skipping this device!Known types are: LW12, LD382A, LD686, LD382, UFO, MiLight, MiLightRGB, MiLightW
      rpi2.0
      2023-04-16 21:18:03.613	error	No Value found for cpu_frequency
      netatmo.0
      2023-04-16 21:17:51.067	warn	API Error: Please Authenticate manually once using the Admin UI of this instance.
      wie komm ich wieder zu einer funktionierenden 16 Version außer jetzt wieder alles mögliche wie gestern zu probieren?`
      Thomas Braun DJMarc75 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @grazer75 last edited by
        @grazer75
        Du wirst dir die einzelnen Adapter und deren Einstellungen anschauen müssen.
        War der iobroker eigentlich heruntergefahren, als du nodejs upgedated hast?
        • DJMarc75
          DJMarc75 @grazer75 last edited by
          @grazer75 sagte in [How-to] Node.js für ioBroker richtig updaten:
          warum nicht ein sauberes/frisches System aufsetzen und wenn alles aktuell ist iobroker und ein Backup einspielen ?
          Der Beitrag wird ja sonst weiter aufgebläht ...
            @djmarc75 weil auch andere Sachen auf dem pi habe?
            Tasmotaadmin etc
              grazer75 @Thomas Braun last edited by grazer75
              @thomas-braun war er, iob stop
              Wie gesagt gestern war das gleiche mit dem Update auf 18, waren dann Fehler auch nach dem downgrade auf 16.
              Hab dann alles mögliche probiert und dann ging es wieder.
              Leider nichts mitgeschrieben, sondern nur in panik google durchsucht.
               sudo npm cache clean --force
              sudo -H -u iobroker npm install iobroker.js-controller
              iob fix
              probiert.
              Und jetzt hab ich es wieder geschafft das es geht ...
              BLE Adapter installiert und danach wieder gelöscht und die Fehler sind weg.
              Versteh ich irgendwie nicht ganz.
              16er läuft wieder
              • DJMarc75
                kann ja nicht hellsehen - dann viel Glück
                  Das ist schlecht. Also Panik.
                  Ich würde auf 18 gehen und mir dann die jeweiligen Adapter/Instanzen Stück für Stück anschauen.
                    @thomas-braun 16er läuft wieder, weiß nicht ob es nur ble Adapter installieren und löschen war und deshalb alles wieder geht. Fehler sind alle wieder weg.
                      Du weißt schon, dass gerade der BLE-Adapter neugebaut wird? Geht i.d.R. automatisch.
                        @thomas-braun aber das installieren von ble und deinstallieren hat die Fehler bereinigt irgendwie
                        Es geht wieder mit 16.x weiß nicht ob ich den Trick auf mit 18.x probieren sollte oder lieber froh sein das ich wieder einen funktionierenden iobroker hab ohne Fehler 🐶
                          apollon77 @grazer75 last edited by
                          @grazer75 Hi,
                          also ich kann es nur nochmals wiederholen ... alle Fehler aus dem ioBroker Log haben NICHTS mit der Node.js Version zu tun!! Da die plötzlich bei node.js 16 weg sind und bei 18 da sind ist aber mal soooowas von unerklärbar!
                          1.) Javascript "Read-only state "javascript.0.MiHomeAll.lumi.158d0002a3299c.info.rssi" has been written ..." ist ein Fehler in einem deiner Skripte. Ein Objekt mit write:false darf nur mit ack=true beschrieben werden. Dieser Fehler KANN NICHT mit der Nodejs version zu tun haben, tut aber auch erstmal nicht weh
                          2.) Tuya connect ECONNRESET bedeutet das das Tuya-Gerät die Verbindung resettet/abgelehnt/abgebrochen hat. Kann ebenso NICHTS mit Nodejs zu tun haben
                          3.) Wifilight "(HF-LPT120) is not a known device type. Skipping this device!" ... die Meldung spricht auch für sich.
                          4.) firetv "adb executable not found. undefined" sagt das ein executable nicht da ist ...
                          ALso Wenn da vorher was tat und nach nodejs 18 nicht mehr dann ist das schon eher komisch und seehr unerklärlich. Da solltest Du denke ich mit etwas Zeit mal das Gesamtsysteme aus einem Backup restoren und neu aufsetzen und alles sauber wieder zum Laufen bekommen
                          Atifan 1 Reply Last reply Reply Quote 0
                          • Atifan
                            Atifan @apollon77 last edited by Atifan
                            Hi. irgendwie komme ich nicht auf node.js 18.16.0
                            Ich mache " curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -"
                            Danach "sudo apt-get install -y nodejs`"
                            Es ist zwar dann 18.16.0 installiert. Aber wenn ich "node -v" eingebe, dann sagt er 16.19.0
                              Thomas Braun Most Active @Atifan last edited by
                              @atifan
                              Wie immer:
                              Keine Screenshots aus der Konsole.
                              • Atifan
                                Atifan @Thomas Braun last edited by
                                @thomas-braun sagte in [How-to] Node.js für ioBroker richtig updaten:
                                @atifan
                                Wie immer:
                                Hm, wieso das denn? Ist das verboten? Wusste ich nicht. Aber wieso keine Screens von Console?
                                  Thomas Braun Most Active @Atifan last edited by Thomas Braun
                                  @atifan
                                  Weil man die nicht immer lesen kann, man nicht daraus kopieren kann, der Text als Bild nicht von der Suchfunktion erfasst werden kann, ein Bild fetter ist als der reine Text, usw...
                                    @atifan
                                    Kannste jetzt gleich mit der Ausgabe zu
                                    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                    uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    üben. Ich vermute aber stark, dass da die Pfade falsch sein werden.
                                    • Atifan
                                      OK 🙂 Dann hier meine Console als Code.
                                      iobroker@iobroker:~$ node -v
                                      v16.19.0
                                      iobroker@iobroker:~$ curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash
                                      ## Installing the NodeSource Node.js 18.x repo...
                                      ## Populating apt-get cache...
                                      + apt-get update
                                      Hit:1 http://ftp.debian.org/debian bullseye InRelease
                                      Hit:2 http://security.debian.org bullseye-security InRelease
                                      Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                                      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                                      Hit:5 https://dl.yarnpkg.com/debian stable InRelease
                                      Reading package lists... Done
                                      ## Confirming "bullseye" is supported...
                                      + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/bullseye/Release'
                                      ## Adding the NodeSource signing key to your keyring...
                                      + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                                      ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                                      + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
                                      + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
                                      ## Running `apt-get update` for you...
                                      + apt-get update
                                      Hit:1 http://security.debian.org bullseye-security InRelease
                                      Hit:2 http://ftp.debian.org/debian bullseye InRelease
                                      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                                      Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
                                      ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                                      ## You may also need development tools to build native addons:
                                           sudo apt-get install gcc g++ make
                                      ## To install the Yarn package manager, run:
                                           curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                                           echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                           sudo apt-get update && sudo apt-get install yarn
                                      iobroker@iobroker:~$ sudo apt-get install -y nodejs
                                      Building dependency tree... Done
                                      nodejs is already the newest version (18.16.0-deb-1nodesource1).
                                      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                      v16.19.0
                                      Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                        @atifan
                                        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
                                        • Atifan
                                          @atifan
                                          OK Danke probiere ich mal.
                                          Das hier spuckt er aus wenn ich oben das mache was du geschrieben hattest.
                                          iobroker@iobroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                          iobroker@iobroker:~$ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                          x86_64
                                          /usr/bin/nodejs
                                          /usr/local/bin/node
                                          /usr/local/bin/npm
                                          /usr/local/bin/npx
                                          v18.16.0
                                          v16.19.0
                                          8.19.3
                                          8.19.3
                                          4.0.24
                                          iobroker
                                          iobroker tty dialout audio video
                                          tty
                                          /home/iobroker
                                          All packages are up to date.
                                          nodejs:
                                            Installed: 18.16.0-deb-1nodesource1
                                            Candidate: 18.16.0-deb-1nodesource1
                                            Version table:
                                           *** 18.16.0-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                                                  100 /var/lib/dpkg/status
                                               12.22.12~dfsg-1~deb11u3 500
                                                  500 http://security.debian.org bullseye-security/main amd64 Packages
                                               12.22.5~dfsg-2~11u1 500
                                                  500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                                            crunchip Forum Testing Most Active @Atifan last edited by
                                            @atifan und leg dir vllt nen neuen user an, der nicht gleich lautet wie der systeminterne iobroker
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            734065
