    4. iob diag - Skript
    iob diag - Skript
    • wendy2702
      wendy2702 @Thomas Braun last edited by
      @thomas-braun mal auf einem Slave ausgeführt kommt die Multihost Info
      pi@pi-iobroker:~ $ iob status all
      At least one iobroker host is running.
      Instance "admin.0" is running
      Instance "admin.1" is running
      Instance "admin.2" is not running
      Instance "daswetter.0" is not running
      Instance "dwd.0" is not running
      Instance "email.0" is running
      Instance "enigma2.0" is running
      Instance "feiertage.0" is not running
      Instance "flot.0" is not running
      Instance "fritzbox.0" is running
      Instance "harmony.0" is running
      Instance "history.0" is running
      Instance "hm-rega.0" is running
      Instance "hm-rpc.0" is running
      Instance "hm-rpc.1" is running
      Instance "hm-rpc.2" is running
      Instance "hue.0" is running
      Instance "ical.0" is not running
      Instance "ical.1" is not running
      Instance "ical.2" is not running
      Instance "icons-addictive-flavour-png.0" is not running
      Instance "icons-fatcow-hosting.0" is not running
      Instance "icons-icons8.0" is not running
      Instance "icons-material-png.0" is not running
      Instance "icons-material-svg.0" is not running
      Instance "icons-mfd-png.0" is not running
      Instance "icons-mfd-svg.0" is not running
      Instance "icons-open-icon-library-png.0" is not running
      Instance "icons-ultimate-png.0" is not running
      Instance "javascript.0" is running
      Instance "javascript.1" is running
      Instance "javascript.2" is running
      Instance "js2fs.0" is not running
      Instance "modbus.0" is running
      Instance "modbus.2" is running
      Instance "modbus.3" is running
      Instance "modbus.4" is not running
      Instance "musiccast.0" is not running
      Instance "nut.0" is not running
      Instance "ping.0" is running
      Instance "rpi2.0" is not running
      Instance "rpi2.1" is not running
      Instance "sayit.0" is running
      Instance "simple-api.0" is running
      Instance "smartmeter.0" is running
      Instance "tankerkoenig.0" is running
      Instance "telegram.0" is running
      Instance "tr-064.0" is not running
      Instance "vis-bars.0" is not running
      Instance "vis-canvas-gauges.0" is not running
      Instance "vis-colorpicker.0" is not running
      Instance "vis-fancyswitch.0" is not running
      Instance "vis-google-fonts.0" is not running
      Instance "vis-hqwidgets.0" is not running
      Instance "vis-jqui-mfd.0" is not running
      Instance "vis-justgage.0" is not running
      Instance "vis-keyboard.0" is not running
      Instance "vis-metro.0" is not running
      Instance "vis-plumb.0" is not running
      Instance "vis-rgraph.0" is not running
      Instance "vis-timeandweather.0" is not running
      Instance "vis.0" is not running
      Instance "weatherunderground.0" is not running
      Instance "web.0" is running
      Instance "yahka.0" is running
      Instance "yahka.1" is running
      Instance "yamaha.0" is running
      Instance "yr.0" is not running
      Instance "yahka.2" is running
      Instance "trashschedule.0" is running
      Instance "vis-material-webfont.0" is not running
      Instance "vis-materialdesign.0" is not running
      Instance "vis-material.0" is not running
      Instance "influxdb.0" is running
      Instance "vis-inventwo.0" is running
      Instance "vis-icontwo.0" is not running
      Instance "yahka.3" is not running
      Instance "homeconnect.0" is not running
      Instance "hue-extended.0" is not running
      Instance "linux-control.0" is running
      Instance "yahka.4" is running
      Instance "socketio.0" is running
      Instance "birthdays.0" is not running
      Instance "birthdays.1" is not running
      Instance "pushover.0" is not running
      Instance "alias-manager.0" is not running
      Instance "discovery.0" is not running
      Instance "net-tools.0" is not running
      Instance "sayit.1" is not running
      Instance "modbus.5" is running
      Instance "enocean.0" is running
      Instance "modbus.1" is running
      Instance "shuttercontrol.0" is running
      Instance "energiefluss.0" is running
      Instance "ws.0" is running
      Instance "web.1" is running
      Instance "backitup.0" is not running
      Instance "modbus.6" is not running
      Instance "shelly.0" is running
      Instance "sourceanalytix.0" is running
      Instance "roborock.0" is not running
      Instance "vis-2-beta.0" is running
      Instance "vis-2-widgets-material.0" is not running
      Instance "vis-2-widgets-energy.0" is not running
      Instance "vis-2-widgets-gauges.0" is not running
      Instance "smartstate.0" is running
      Instance "smartmeter.1" is not running
      Instance "energiefluss.1" is not running
      SYSTEM/memoryLimitMB: 0
      SYSTEM/hostname:
      SYSTEM/statisticsInterval: 15000
      SYSTEM/checkDiskInterval: 300000
      SYSTEM/instanceStartInterval: 2000
      SYSTEM/compact: false
      SYSTEM/allowShellCommands: false
      SYSTEM/memLimitWarn: 100
      SYSTEM/memLimitError: 50
      MULTIHOSTSERVICE/enabled: false
      MULTIHOSTSERVICE/secure: true
      MULTIHOSTSERVICE/password:
      OBJECTS/type: jsonl
      OBJECTS/host: 192.168.178.18
      OBJECTS/port: 9001
      OBJECTS/noFileCache: false
      OBJECTS/maxQueue: 1000
      OBJECTS/connectTimeout: 5000
      OBJECTS/writeFileInterval: 5000
      OBJECTS/OPTIONS/retry_max_count: 19
      OBJECTS/OPTIONS/db: 0
      OBJECTS/OPTIONS/family: 0
      OBJECTS/OPTIONS/retryStrategy: reconnectCount => {
                  if (!ready && initError && ignoreErrors) {
                      return new Error('No more tries');
                  if (this.stop) {
                      return new Error('Client has stopped ... no retries anymore');
                  if (ready && reconnectCount >= retry_max_count) {
                      return new Error('Stop trying to reconnect');
                  // A function that receives an options object as parameter including the retry attempt,
                  // the total_retry_time indicating how much time passed since the last time connected,
                  // the error why the connection was lost and the number of times_connected in total.
                  // If you return a number from this function, the retry will happen exactly after that
                  // time in milliseconds. If you return a non-number, no further retry will happen and
                  // all offline commands are flushed with errors. Return an error to return that
                  // specific error to all offline commands.
                  if (!ready) {
                      return 300;
                  } else {
                      return retry_max_delay;
                  /*if (options.error.code === 'ECONNREFUSED') {
                      // End reconnecting on a specific error and flush all commands with a individual error
                      return new Error('The server refused the connection');
                  if (options.total_retry_time > 1000 * 60 * 60) {
                      // End reconnecting after a specific timeout and flush all commands with a individual error
                      return new Error('Retry time exhausted');
                  if (options.times_connected > 10) {
                      // End reconnecting with built in error
                      return undefined;
                  // reconnect after
                  return Math.max(options.attempt * 100, 3000);*/
      OBJECTS/OPTIONS/enableReadyCheck: true
      OBJECTS/OPTIONS/host: 192.168.178.18
      OBJECTS/OPTIONS/port: 9001
      OBJECTS/OPTIONS/autoResubscribe: false
      OBJECTS/OPTIONS/connectionName:
      OBJECTS/BACKUP/disabled: false
      OBJECTS/BACKUP/files: 24
      OBJECTS/BACKUP/hours: 48
      OBJECTS/BACKUP/period: 120
      OBJECTS/BACKUP/path:
      STATES/type: jsonl
      STATES/host: 192.168.178.18
      STATES/port: 9000
      STATES/connectTimeout: 5000
      STATES/writeFileInterval: 30000
      STATES/OPTIONS/retry_max_count: 19
      STATES/OPTIONS/db: 0
      STATES/OPTIONS/family: 0
      STATES/OPTIONS/retryStrategy: reconnectCount => {
                  if (!ready && initError) {
                  if (this.stop) {
                  if (!ready) {
                      return 300;
                      return undefined;
                  // reconnect after
      STATES/OPTIONS/enableReadyCheck: true
      STATES/OPTIONS/host: 192.168.178.18
      STATES/OPTIONS/port: 9000
      STATES/OPTIONS/autoResubscribe: false
      STATES/OPTIONS/connectionName:
      STATES/BACKUP/disabled: false
      STATES/BACKUP/files: 24
      STATES/BACKUP/hours: 48
      STATES/BACKUP/period: 120
      STATES/BACKUP/path:
      STATES/maxQueue: 1000
      LOG/level: info
      LOG/maxDays: 7
      LOG/noStdout: true
      LOG/TRANSPORT/FILE1/type: file
      LOG/TRANSPORT/FILE1/enabled: true
      LOG/TRANSPORT/FILE1/filename: log/iobroker
      LOG/TRANSPORT/FILE1/fileext: .log
      LOG/TRANSPORT/SYSLOG1/type: syslog
      LOG/TRANSPORT/SYSLOG1/enabled: false
      LOG/TRANSPORT/SYSLOG1/host: localhost
      LOG/TRANSPORT/SYSLOG1/protocol: udp4
      LOG/TRANSPORT/SYSLOG1/localhost: iobroker
      LOG/TRANSPORT/SEQ1/type: seq
      LOG/TRANSPORT/SEQ1/enabled: false
      LOG/TRANSPORT/SEQ1/serverUrl: http://IP:PORT
      LOG/TRANSPORT/SEQ1/apiKey:
      dataDir: ../../iobroker-data/
      bahnuhr Thomas Braun 2 Replies Last reply Reply Quote 0
      • bahnuhr
        bahnuhr Forum Testing Most Active @wendy2702 last edited by
        @wendy2702
        Warum hast du 3 admin ?
        Nur mal so zur Info.
          Thomas Braun Most Active @wendy2702 last edited by
          @wendy2702
          Aber auch mit false.
          Schade, ich hatte gedacht/erwartet, man könnte damit ein Multihost-Setup erkennen.
          • wendy2702
            wendy2702 @bahnuhr last edited by
            @bahnuhr historisch gewachsen da es früher mal drei einzelne Installation waren.
            @Thomas-Braun : ja, merkwürdig das da false steht.
            • bahnuhr
              bahnuhr Forum Testing Most Active @Thomas Braun last edited by
              @wendy2702
              habe auch ein multihost
              Und bei mir steht auch false
              MULTIHOSTSERVICE/password: $/aes-192-cbc:08dab1f
              MULTIHOSTSERVICE/persist: false
                Thomas Braun Most Active @bahnuhr last edited by Thomas Braun
                @bahnuhr @wendy2702 @emil70
                Danke fürs nachschauen.
                Aber so kann ich den Punkt für iob diag leider nicht brauchen. Muss ich mal nach was anderem schauen.
                • haselchen
                  haselchen Most Active @Thomas Braun last edited by haselchen
                  Habs in Docker in nem Container auch mal laufen lassen.
                  Wird auch false angezeigt, obwohl es ein Multihostsystem ist.
                    Thomas Braun Most Active @haselchen last edited by
                    @haselchen
                    Ja, der Code funktioniert nicht. Ist im github auch schon wieder verschwunden.
                    • haselchen
                      Feilst Du da noch einer Lösung ?
                        @haselchen
                        Im Moment sehe ich keine Möglichkeit das verlässlich abzugreifen. Vor allen Dingen nicht von 'extern' über ein bash-skript.
                        • haselchen
                          Lustigerweise, ich weiss ja nicht ob meine Vorredner da nachgesehen haben,
                          steht in der iobroker.json das schon falsch drin.
                          "multihostService": {
                              "enabled": false,
                              "secure": true,
                          Thomas Braun andre 2 Replies Last reply Reply Quote 0
                            @haselchen
                            Ja, das dürfte die Ursache dafür sein. Also grundsätzlich funktioniert der Abruf der Info schon, nur ist die Info selber falsch.
                            • haselchen
                              Ich kann da ja mal true reinballern und sehen was dein Skript macht.
                              Die Frage ist, wer korrigiert den Fehler in der iobroker.json?
                                fastfoot last edited by
                                es gibt auch noch den Befehl iob multihost status
                                  Thomas Braun Most Active @fastfoot last edited by
                                  @fastfoot
                                  Okay, ich greppe im Skript danach.
                                  iobroker status all | grep MULTIHOSTSERVICE/enabled
                                  vielleicht kann @haselchen mal beides auf seinem Multihost-System ausführen?
                                  • haselchen
                                    haselchen Most Active last edited by
                                    Was hat das mit persistent.....auf sich?
                                    Sollte da enable stehen?
                                    • Glasfaser
                                      Glasfaser @Thomas Braun last edited by
                                      @thomas-braun sagte in iob diag - Skript:
                                      hatten wir schonmal ganz am Anfang !
                                      https://forum.iobroker.net/post/884438
                                      • andre
                                        andre Developer @haselchen last edited by
                                        @haselchen sagte in iob diag - Skript:
                                            "enabled": false,
                                            "secure": true,
                                        Das ist nicht lustigerweise so und auch nicht falsch. 🙂
                                        Im Docker Container wird schlicht nicht mit dem "multihostService" gearbeitet.
                                        MfG,
                                        André
                                        haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @Glasfaser last edited by
                                          @glasfaser
                                          Ah, guter Hinweis. Hat also damals schon nicht wie erwartet funktioniert.
                                          Ich werde alt und senil... 👴
                                          • haselchen
                                            haselchen Most Active @andre last edited by
                                            @andre
                                            Die Befehle dazu und die Umsetzung werden aber abgearbeitet und ausgeführt ohne Fehler.
                                            738
                                            154520
