    4. ([gelöst]) Daten Sonnensystem Resol auslesen per VBUS
      RS_Tobi last edited by
      Hi, musste eine kurze auszeit nehmen….
      Heute Nacht ging mein BACKUP schief, da meine NAS nicht erreichbar war....
      Habe jetzt mein Backup wieder und hier das LOG seit der installation des Adapter.
      ! javascript.0 2017-09-23 23:07:50.093 error script.js.resol compile failed: SyntaxError: Unexpected identifier
      ! javascript.0 2017-09-23 23:07:50.053 info Start javascript script.js.resol
      ! javascript.0 2017-09-23 23:07:49.963 info received all objects
      ! javascript.0 2017-09-23 23:07:49.323 info received all states
      ! javascript.0 2017-09-23 23:07:48.572 info requesting all objects
      ! javascript.0 2017-09-23 23:07:48.563 info requesting all states
      ! javascript.0 2017-09-23 23:07:48.369 info └── sprintf@0.1.5
      ! javascript.0 2017-09-23 23:07:48.369 info │ └── object-keys@1.0.11
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── function-bind@1.1.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └── foreach@2.0.5
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├─┬ define-properties@1.1.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ └─┬ object.assign@4.0.4
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └── uid-number@0.0.6
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── util-deprecate@1.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── string_decoder@0.10.31
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── process-nextick-args@1.0.7
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── isarray@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── inherits@2.0.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── core-util-is@1.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── buffer-shims@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ readable-stream@2.1.5
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── wrappy@1.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ once@1.3.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── concat-map@0.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── balanced-match@0.4.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └─┬ brace-expansion@1.1.6
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └─┬ minimatch@3.0.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ fstream-ignore@1.0.5
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── inherits@2.0.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── graceful-fs@4.1.11
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ fstream@1.0.10
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── ms@0.7.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ debug@2.2.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └─┬ tar-pack@3.3.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── graceful-fs@4.1.11
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ fstream@1.0.10
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── block-stream@0.0.9
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ tar@2.2.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├── semver@5.3.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── path-is-absolute@1.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── wrappy@1.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ once@1.4.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── concat-map@0.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── balanced-match@0.4.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └─┬ brace-expansion@1.1.6
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ minimatch@3.0.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ inflight@1.0.6
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── fs.realpath@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └─┬ glob@7.1.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ rimraf@2.5.4
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── uuid@3.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── tunnel-agent@0.4.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── punycode@1.4.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ tough-cookie@2.3.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── stringstream@0.0.5
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── qs@6.3.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── oauth-sign@0.8.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── mime-db@1.25.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ mime-types@2.1.13
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── json-stringify-safe@5.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── isstream@0.1.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── is-typedarray@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── tweetnacl@0.14.4
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── jsbn@0.1.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── jodid25519@1.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── getpass@0.1.6
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── ecc-jsbn@0.1.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── dashdash@1.14.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── bcrypt-pbkdf@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── assert-plus@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── asn1@0.2.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └─┬ sshpk@1.10.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ └── verror@1.3.6
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ ├── json-schema@0.2.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ ├── extsprintf@1.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├─┬ jsprim@1.3.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── assert-plus@0.2.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ http-signature@1.1.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── sntp@1.0.9
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── hoek@2.16.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── cryptiles@2.0.5
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── boom@2.10.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ hawk@3.1.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── pinkie@2.0.4
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └─┬ pinkie-promise@2.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ └── xtend@4.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ ├── jsonpointer@4.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ │ └── is-property@1.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ ├─┬ generate-object-property@1.2.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ ├── generate-function@2.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├─┬ is-my-json-valid@2.15.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ └── supports-color@2.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ │ └── ansi-regex@2.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ ├─┬ strip-ansi@3.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ ├─┬ has-ansi@2.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ ├── escape-string-regexp@1.0.5
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ ├── ansi-styles@2.2.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├─┬ chalk@1.1.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ har-validator@2.0.6
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── asynckit@0.4.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ form-data@2.1.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── forever-agent@0.6.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── extend@3.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── delayed-stream@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ combined-stream@1.0.5
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── caseless@0.11.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── aws4@1.5.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── aws-sign2@0.6.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ request@2.79.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── strip-json-comments@1.0.4
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── minimist@1.2.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── ini@1.3.4
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── deep-extend@0.4.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ rc@1.1.6
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── set-blocking@2.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── wide-align@1.1.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── supports-color@0.2.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ └── ansi-regex@2.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├─┬ strip-ansi@3.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ └── number-is-nan@1.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ └─┬ is-fullwidth-code-point@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ │ ├── code-point-at@1.1.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├─┬ string-width@1.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── signal-exit@3.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── object-assign@4.1.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── has-unicode@2.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── aproba@1.0.4
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ gauge@2.7.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── console-control-strings@1.1.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └── util-deprecate@1.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── string_decoder@0.10.31
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── process-nextick-args@1.0.7
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── isarray@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── inherits@2.0.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── core-util-is@1.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── buffer-shims@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ └─┬ readable-stream@2.2.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ │ ├── delegates@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├─┬ are-we-there-yet@1.1.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ npmlog@4.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── abbrev@1.0.9
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ nopt@3.0.6
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── minimist@0.0.8
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ mkdirp@0.5.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├─┬ node-pre-gyp@0.6.32
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── nan@2.7.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └── immediate@3.0.6
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├─┬ lie@3.1.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └── ms@2.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├─┬ debug@2.6.9
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── commander@2.11.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── bindings@1.2.1
      ! javascript.0 2017-09-23 23:07:48.369 info ├─┬ serialport@4.0.7
      ! javascript.0 2017-09-23 23:07:48.369 info │ └── uuid@3.1.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── tunnel-agent@0.6.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └── punycode@1.4.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├─┬ tough-cookie@2.3.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── stringstream@0.0.5
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── safe-buffer@5.1.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── qs@6.5.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── performance-now@2.1.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── oauth-sign@0.8.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └── mime-db@1.30.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├─┬ mime-types@2.1.17
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── json-stringify-safe@5.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── isstream@0.1.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── is-typedarray@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └── tweetnacl@0.14.5
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├── jsbn@0.1.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├── getpass@0.1.7
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├── ecc-jsbn@0.1.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├── dashdash@1.14.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├── bcrypt-pbkdf@1.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├── asn1@0.2.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └─┬ sshpk@1.13.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── core-util-is@1.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └─┬ verror@1.10.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── json-schema@0.2.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── extsprintf@1.3.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ jsprim@1.4.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├── assert-plus@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├─┬ http-signature@1.2.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └── sntp@2.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├── hoek@4.2.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── boom@5.2.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ cryptiles@3.1.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├── boom@4.3.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├─┬ hawk@6.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └── har-schema@2.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └── jsonify@0.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ └─┬ json-stable-stringify@1.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── json-schema-traverse@0.3.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── fast-deep-equal@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ │ ├── co@4.6.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ ├─┬ ajv@5.2.2
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├─┬ har-validator@5.0.3
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └── asynckit@0.4.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├─┬ form-data@2.3.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── forever-agent@0.6.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── extend@3.0.1
      ! javascript.0 2017-09-23 23:07:48.369 info │ │ └── delayed-stream@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├─┬ combined-stream@1.0.5
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── caseless@0.12.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── aws4@1.6.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── aws-sign2@0.7.0
      ! javascript.0 2017-09-23 23:07:48.369 info ├─┬ request@2.82.0
      ! javascript.0 2017-09-23 23:07:48.369 info ├── q@1.5.0
      ! javascript.0 2017-09-23 23:07:48.369 info ├── numeral@1.5.6
      ! javascript.0 2017-09-23 23:07:48.369 info ├── moment-timezone@0.5.13
      ! javascript.0 2017-09-23 23:07:48.369 info ├── moment@2.18.1
      ! javascript.0 2017-09-23 23:07:48.369 info ├── lodash@2.4.1
      ! javascript.0 2017-09-23 23:07:48.369 info ├── buffer-more-ints@0.0.2
      ! javascript.0 2017-09-23 23:07:48.369 info └─┬ resol-vbus@0.16.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ └── sorted-array-functions@1.0.0
      ! javascript.0 2017-09-23 23:07:48.369 info │ ├── long-timeout@0.1.1
      ! javascript.0 2017-09-23 23:07:48.369 info ├─┬ node-schedule@1.2.1
      ! javascript.0 2017-09-23 23:07:48.369 info iobroker.javascript@3.4.0 /opt/iobroker/node_modules/iobroker.javascript
      ! javascript.0 2017-09-23 23:07:41.846 info make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build'
      ! javascript.0 2017-09-23 23:07:41.786 info COPY Release/serialport.node
      ! javascript.0 2017-09-23 23:07:41.119 info SOLINK_MODULE(target) Release/obj.target/serialport.node
      ! javascript.0 2017-09-23 23:07:38.593 error ^
      ! javascript.0 2017-09-23 23:07:38.593 error obj->fd_ = info[0]->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:38.593 error ../src/serialport_poller.cpp:86:31: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecate
      ! javascript.0 2017-09-23 23:07:38.593 error ../src/serialport_poller.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE SerialportPoller::New(Nan::NAN_METHOD_ARGS_TYPE)’:
      ! javascript.0 2017-09-23 23:07:33.865 info CXX(target) Release/obj.target/serialport/src/serialport_poller.o
      ! javascript.0 2017-09-23 23:07:31.934 error ^
      ! javascript.0 2017-09-23 23:07:31.934 error result->vtime = Nan::Get(options, Nan::New("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:31.934 error ../src/serialport_unix.cpp:45:111: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecate
      ! javascript.0 2017-09-23 23:07:31.928 error ^
      ! javascript.0 2017-09-23 23:07:31.928 error result->vmin = Nan::Get(options, Nan::New("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:31.928 error ../src/serialport_unix.cpp:44:109: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated
      ! javascript.0 2017-09-23 23:07:31.928 error ../src/serialport_unix.cpp: In function ‘OpenBatonPlatformOptions* ParsePlatformOptions(const v8::Local&)’:
      ! javascript.0 2017-09-23 23:07:26.440 info CXX(target) Release/obj.target/serialport/src/serialport_unix.o
      ! javascript.0 2017-09-23 23:07:16.449 error ^
      ! javascript.0 2017-09-23 23:07:16.449 error int fd = info[0]->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:16.449 error ../src/serialport.cpp:585:29: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-decl
      ! javascript.0 2017-09-23 23:07:16.449 error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
      ! javascript.0 2017-09-23 23:07:16.424 error ^
      ! javascript.0 2017-09-23 23:07:16.424 error int fd = info[0]->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:16.424 error ../src/serialport.cpp:528:29: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-decl
      ! javascript.0 2017-09-23 23:07:16.424 error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
      ! javascript.0 2017-09-23 23:07:16.405 error ^
      ! javascript.0 2017-09-23 23:07:16.405 error int fd = info[0]->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:16.405 error ../src/serialport.cpp:480:29: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-decl
      ! javascript.0 2017-09-23 23:07:16.405 error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
      ! javascript.0 2017-09-23 23:07:16.343 error ^
      ! javascript.0 2017-09-23 23:07:16.343 error baton->fd = info[0]->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:16.343 error ../src/serialport.cpp:369:32: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-decl
      ! javascript.0 2017-09-23 23:07:16.343 error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      ! javascript.0 2017-09-23 23:07:16.313 error ^
      ! javascript.0 2017-09-23 23:07:16.313 error int fd = info[0]->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:16.313 error ../src/serialport.cpp:252:29: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-decl
      ! javascript.0 2017-09-23 23:07:16.313 error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Write(Nan::NAN_METHOD_ARGS_TYPE)’:
      ! javascript.0 2017-09-23 23:07:16.284 error ^
      ! javascript.0 2017-09-23 23:07:16.284 error baton->baudRate = Nan::Get(options, Nan::New("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:16.284 error ../src/serialport.cpp:217:116: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-de
      ! javascript.0 2017-09-23 23:07:16.258 error ^
      ! javascript.0 2017-09-23 23:07:16.258 error int fd = info[0]->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:16.258 error ../src/serialport.cpp:193:29: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-decl
      ! javascript.0 2017-09-23 23:07:16.258 error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
      ! javascript.0 2017-09-23 23:07:16.249 error ^
      ! javascript.0 2017-09-23 23:07:16.249 error int fd = argv[1]->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:16.249 error ../src/serialport.cpp:174:31: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-decl
      ! javascript.0 2017-09-23 23:07:16.249 error ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
      ! javascript.0 2017-09-23 23:07:16.199 error ^
      ! javascript.0 2017-09-23 23:07:16.199 error return getValueFromObject(options, key)->ToNumber()->NumberValue();
      ! javascript.0 2017-09-23 23:07:16.199 error ../src/serialport.cpp:102:53: warning: ‘v8::Local v8::Value::ToNumber() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8173): Use maybe version [-Wdeprecated-de
      ! javascript.0 2017-09-23 23:07:16.199 error ../src/serialport.cpp: In function ‘double getDoubleFromObject(v8::Local, std::string)’:
      ! javascript.0 2017-09-23 23:07:16.186 error ^
      ! javascript.0 2017-09-23 23:07:16.186 error return getValueFromObject(options, key)->ToInt32()->Int32Value();
      ! javascript.0 2017-09-23 23:07:16.186 error ../src/serialport.cpp:90:52: warning: ‘v8::Local v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-decla
      ! javascript.0 2017-09-23 23:07:16.186 error ../src/serialport.cpp: In function ‘int getIntFromObject(v8::Local, std::string)’:
      ! javascript.0 2017-09-23 23:07:06.721 info CXX(target) Release/obj.target/serialport/src/serialport.o
      ! javascript.0 2017-09-23 23:07:06.712 info make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport/build'
      ! javascript.0 2017-09-23 23:06:54.350 error node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.11.1 (node-v48 ABI) (falling back to source compile with node-gyp)
      ! javascript.0 2017-09-23 23:06:54.350 error ERR! Tried to download(404): https://github.com/EmergingTechnologyAd … arm.tar.gz
      ! javascript.0 2017-09-23 23:06:54.347 error node-pre-gyp
      ! javascript.0 2017-09-23 23:06:48.164 info > node-pre-gyp install --fallback-to-build
      ! javascript.0 2017-09-23 23:06:48.164 info > serialport@4.0.7 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialport
      ! javascript.0 2017-09-23 23:04:52.143 info npm install resol-vbus --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
      ! javascript.0 2017-09-23 23:04:52.081 info starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
      ! host.IObroker 2017-09-23 23:04:45.269 info instance system.adapter.javascript.0 started with pid 1180
      ! host.IObroker 2017-09-23 23:04:45.189 info object change system.adapter.javascript.0
      ! host.IObroker 2017-09-23 23:03:38.078 info object change system.adapter.javascript.0
      ! iobroker 2017-09-23 23:03:10.902 info exit 0
      ! iobroker 2017-09-23 23:03:10.867 info host.IObroker object system.adapter.javascript.0 created
      ! host.IObroker 2017-09-23 23:03:10.852 info object change system.adapter.javascript.0
      ! iobroker 2017-09-23 23:03:10.790 info host.IObroker object system.adapter.javascript.0.alive created
      ! iobroker 2017-09-23 23:03:10.747 info host.IObroker object system.adapter.javascript.0.connected created
      ! iobroker 2017-09-23 23:03:10.701 info host.IObroker object system.adapter.javascript.0.memHeapUsed created
      ! iobroker 2017-09-23 23:03:10.660 info host.IObroker object system.adapter.javascript.0.memHeapTotal created
      ! iobroker 2017-09-23 23:03:10.607 info host.IObroker object system.adapter.javascript.0.memRss created
      ! iobroker 2017-09-23 23:03:10.567 info host.IObroker object system.adapter.javascript.0.uptime created
      ! iobroker 2017-09-23 23:03:10.517 info host.IObroker object system.adapter.javascript.0.inputCount created
      ! iobroker 2017-09-23 23:03:10.474 info host.IObroker object system.adapter.javascript.0.outputCount created
      ! iobroker 2017-09-23 23:03:10.450 info host.IObroker create instance javascript
      ! iobroker 2017-09-23 23:03:10.349 info host.IObroker object _design/script created
      ! iobroker 2017-09-23 23:03:10.292 info host.IObroker object system.adapter.javascript created
      ! iobroker 2017-09-23 23:03:09.876 info upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
      ! iobroker 2017-09-23 23:03:09.794 info upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/blockly.png blockly.png image/png
      ! iobroker 2017-09-23 23:03:09.713 info upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/coffeescript.png coffeescript.png image/png
      ! iobroker 2017-09-23 23:03:09.445 info upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/cron/jquery-cron.css cron/jquery-cron.css text/css
      ! iobroker 2017-09-23 23:03:09.368 info upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/cron/jquery-cron.js cron/jquery-cron.js application/javascript
      ! iobroker 2017-09-23 23:03:09.266 info upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/cron2text.js cron2text.js application/javascript
      ! iobroker 2017-09-23 23:03:09.193 info upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE application/octet-stream
      ! iobroker 2017-09-23 23:03:08.719 info upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
      ! iobroker 2017-09-23 23:03:08.613 info upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
      ! iobroker 2017-09-23 23:03:08.526 info upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
      ! iobroker 2017-09-23 23:03:08.463 info upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
      ! iobroker 2017-09-23 23:03:08.396 info upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/accessible.css google-blockly/media/accessible.css text/css
      ! iobroker 2017-09-23 23:03:08.323 info upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
      ! iobroker 2017-09-23 23:03:08.231 info upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
      ! iobroker 2017-09-23 23:03:08.148 info upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/x-wav
      ! iobroker 2017-09-23 23:03:08.068 info upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
      ! iobroker 2017-09-23 23:03:07.986 info upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
      ! iobroker 2017-09-23 23:03:07.903 info upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/x-wav
      ! iobroker 2017-09-23 23:03:07.804 info upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
      ! iobroker 2017-09-23 23:03:07.729 info upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
      ! iobroker 2017-09-23 23:03:07.639 info upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/x-wav
      ! iobroker 2017-09-23 23:03:06.908 info upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/ru.js google-blockly/msg/js/ru.js application/javascript
      ! iobroker 2017-09-23 23:03:06.083 info upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_trigger.js google-blockly/own/blocks_trigger.js application/javascript
      ! iobroker 2017-09-23 23:03:05.299 info upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/jquery.cron.js jquery.cron.js application/javascript
      ! iobroker 2017-09-23 23:03:04.344 info upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/tab.html tab.html text/html
      ! iobroker 2017-09-23 23:03:03.763 info got /opt/iobroker/node_modules/iobroker.javascript/admin
      ! iobroker 2017-09-23 23:03:03.710 info host.IObroker install adapter javascript
      ! iobroker 2017-09-23 23:03:03.512 info npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/tualo-commander/package.json'
      ! iobroker 2017-09-23 23:03:03.512 info npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-pifacedigital/package.json'
      ! iobroker 2017-09-23 23:03:03.512 info WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.piface/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-
      ! iobroker 2017-09-23 23:03:03.506 info npm
      ! node-red.0 2017-09-23 23:00:48.788 warn Reconnection to DB.
      ! node-red.0 2017-09-23 23:00:48.667 warn Reconnection to DB.
      ! iobroker 2017-09-23 23:00:13.558 info npm install iobroker.javascript –production --prefix "/opt/iobroker" (System call)
      • Dutchman
        Ok das ist ne Menge Log 😉
        Mal von vorne, was passiert wenn du das Script startest im Log?
        Ich sehe nur unexpected identifier, Mal Script stoppen/starten und dem Teil des logs Posten
        Du hast das npm Paket aber installiert bzw im js Adapter eingefügt?
        Send from mobile device
          hi!
          resol-vbus habe ich in jvascript adapter eingetragen.
          also wenn ich nur das script beende und neu starte dann kommt das…
          2017-09-24 13:24:54.129 - [32minfo[39m: javascript.0 Stop script script.js.resol
          2017-09-24 13:25:03.941 - [32minfo[39m: javascript.0 Start javascript script.js.resol
          2017-09-24 13:25:03.956 - [31merror[39m: javascript.0 script.js.resol compile failed: SyntaxError: Unexpected identifier
          wenn ich den javscrpt adapt neu start dann kommt dieses...
          ! 2017-09-24 13:32:01.854 - [32minfo[39m: host.IObroker object change system.adapter.javascript.0
          ! 2017-09-24 13:32:01.892 - [32minfo[39m: host.IObroker stopInstance system.adapter.javascript.0
          ! 2017-09-24 13:32:01.895 - [32minfo[39m: host.IObroker stopInstance system.adapter.javascript.0 killing pid 1831
          ! 2017-09-24 13:32:01.957 - [32minfo[39m: javascript.0 terminating
          ! 2017-09-24 13:32:02.038 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 0 (OK)
          ! 2017-09-24 13:32:04.515 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 started with pid 4514
          ! 2017-09-24 13:32:11.526 - [32minfo[39m: javascript.0 starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
          ! 2017-09-24 13:32:11.586 - [32minfo[39m: javascript.0 requesting all states
          ! 2017-09-24 13:32:11.597 - [32minfo[39m: javascript.0 requesting all objects
          ! 2017-09-24 13:32:12.479 - [32minfo[39m: javascript.0 received all states
          ! 2017-09-24 13:32:13.147 - [32minfo[39m: javascript.0 received all objects
          ! 2017-09-24 13:32:13.253 - [32minfo[39m: javascript.0 Start javascript script.js.resol
          ! 2017-09-24 13:32:13.319 - [31merror[39m: javascript.0 script.js.resol compile failed: SyntaxError: Unexpected identifier[/spoiler]
          kannst du damit etwas anfangen?
          danke
          tobi
          • Dutchman
            @RS_Tobi:
            hi!
            danke
            tobi
            es sieht so aus als wen das resol-vbus modul nicht richtig installiert ist, probier mal bitte es manuel zu installieren:
            javascript adapter stoppen, dan auf der console:
            cd /opt/iobroker/node_modules/iobroker.javascript
            sudo npm install resol-vbus
              Hi.
              Der installiert ohne erkennbare Fehler.
              Aber selbiges Ergebnis!
              Kann es ein Problem mit meinem npm geben?
              Mein MODBUS Adapter läuft auch nicht…
              Ich versuche es schon seit Tagen ohne Erfolg.
              Aber ich habe es jetzt schon am 2. System ausprobiert.... Es will nicht... [emoji26]
              Gesendet von meinem D5803 mit Tapatalk
              • Dutchman
                Spuct der modbus denselbwr Fehler ? Welche node und npm Version hast du?
                  Ja,
                  Diese komischen npm errors habe ich bei dem MODBUS auch…
                  Aber da mir mein System erst vor 2 Monaten abgeraucht ist. Ist es eh komplett neu aufgesetzt..
                  Node 6.11.1
                  Npm 3.10.10
                  Nodejs 6.11.1
                  Soll ich mal npm Cache clean?
                  Ich weiß nur nicht was mir dieser Befehl alles bewirkt? Kann ich da etwas kaputt machen?
                  • Dutchman
                    Kaputt mache Nein löscht ja nur den Cache.
                    Keine Ahnung was da bei dir los ist 😕
                      ich habe jetzt mal deinen Script verwendet und nicht den von meifi2017.
                      habe auch einen npm cache clean gemacht….
                      Nun alles wieder installiert und jetzt macht er was anderes als gestern...
                      habe jetzt folgenden log...
                      ! ost.IObroker 2017-09-25 18:45:00.483 error instance system.adapter.javascript.0 terminated with code 0 (OK)
                      ! javascript.0 2017-09-25 18:44:55.869 info script.js.resol2: registered 0 subscriptions and 1 schedule
                      ! javascript.0 2017-09-25 18:44:55.862 info Start javascript script.js.resol2
                      ! javascript.0 2017-09-25 18:44:39.474 info received all objects
                      ! javascript.0 2017-09-25 18:44:38.816 info received all states
                      ! javascript.0 2017-09-25 18:44:37.925 info requesting all objects
                      ! javascript.0 2017-09-25 18:44:37.924 info requesting all states
                      ! javascript.0 2017-09-25 18:44:37.921 info starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                      ! host.IObroker 2017-09-25 18:44:31.200 info instance system.adapter.javascript.0 started with pid 15343
                      ! host.IObroker 2017-09-25 18:44:01.171 info Restart adapter system.adapter.javascript.0 because enabled
                      ! host.IObroker 2017-09-25 18:44:01.170 error instance system.adapter.javascript.0 terminated with code 0 (OK)
                      ! javascript.0 2017-09-25 18:43:54.497 info script.js.resol2: registered 0 subscriptions and 1 schedule
                      ! javascript.0 2017-09-25 18:43:54.495 info Start javascript script.js.resol2
                      ! javascript.0 2017-09-25 18:43:38.747 info Start javascript script.js.resol2
                      ! javascript.0 2017-09-25 18:43:38.624 info received all objects
                      ! javascript.0 2017-09-25 18:43:37.930 info received all states
                      ! javascript.0 2017-09-25 18:43:36.946 info requesting all objects
                      ! javascript.0 2017-09-25 18:43:36.935 info requesting all states
                      ! javascript.0 2017-09-25 18:43:36.874 info starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                      ! host.IObroker 2017-09-25 18:43:30.521 info instance system.adapter.javascript.0 started with pid 15321
                      ! host.IObroker 2017-09-25 18:43:00.445 info Restart adapter system.adapter.javascript.0 because enabled
                      ! host.IObroker 2017-09-25 18:43:00.443 error instance system.adapter.javascript.0 terminated with code 0 (OK)
                      ! javascript.0 2017-09-25 18:43:00.324 error at TCP.onread (net.js:547:20)
                      ! javascript.0 2017-09-25 18:43:00.324 error at Socket.Readable.push (_stream_readable.js:134:10)
                      ! javascript.0 2017-09-25 18:43:00.324 error at readableAddChunk (_stream_readable.js:176:18)
                      ! javascript.0 2017-09-25 18:43:00.324 error at Socket.emit (events.js:188:7)
                      ! javascript.0 2017-09-25 18:43:00.324 error at emitOne (events.js:96:13)
                      ! javascript.0 2017-09-25 18:43:00.324 error at Socket.onSocketData (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/tcp-connection.js:301:29)
                      ! javascript.0 2017-09-25 18:43:00.324 error at onLine (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/tcp-connection.js:241:22)
                      ! javascript.0 2017-09-25 18:43:00.324 error Error: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                      ! javascript.0 2017-09-25 18:43:00.322 error uncaught exception: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                      ! javascript.0 2017-09-25 18:42:53.226 info script.js.resol2: registered 0 subscriptions and 1 schedule
                      ! javascript.0 2017-09-25 18:42:36.948 info Start javascript script.js.resol2
                      aber der javascript adapter schnellte von knapp 30Mb auf fast 130Mb hoch.
                      Ist das normal?
                      wenn ich mit der IP vom RESOL im Browser aufrufe dann komm ich auf eine RESOL website dort kann man Einstellung und Status auswählen.
                      Ist das so richtig?
                      Oder hat meiner vielleicht eine abgespeckte Version drauf und kann das nicht?
                      tobi
                      • Dutchman
                        Mach mal screenshot vom Interface , was für ein Gerät hast du ?
                          Anbei ein Screenshot der Weboberfläche
                          Ich habe ein TISUN DUPLEX welche optisch und laut INFO von RESOL geliefert und Baugleich der DeltaSol (SSL bzw. Vorgänger) sein soll.
                          http://www.tisun.at/assets/brochures/20 … -Part2.pdf
                          Als Schnittstelle steht auch VBUS in der Anleitung, aber dabei steht noch MODUL wird benötigt.
                          Jedoch, so ist meine Auffassung, ist das Modul nur zur Aufzeichung und zur Aufbereitung und Abfrage über das Inter-/Intranet zu gebrauchen.
                          Ich glaube, dass dein Script und IOBROKER zusammen das selbe machen wie dieses WEBMODUL, oder?
                          DANKE FÜR DEINE MÜHE!
                          Tobi
                          • Dutchman
                            Hmm, komt drauf an ob das Gerät vbus per Interface ausspukt, deltasol musste gehen
                            IP richtig, username Passwort ?
                            Die externen Module sind meist zum aufzeichnen und genau das macht mein Script per ioBroker da hast du Recht
                              wie kann ich das testen?
                              ob per INTERFACE etwas raus kommt?
                              IP ist richtig
                              username: keine Eingabe
                              Passwort: vbus
                              genauso kam ich auch in die WEBoberfläche auf die Einstellungen
                              kann ich noch etwas tun bzw testen?
                              Tobi
                              • Dutchman
                                @RS_Tobi:
                                IP ist richtig
                                Passwort: vbus
                                Tobi `
                                Hi Tobi,
                                Ich habe da noch so einige feher im script gefunden und korrigiert, probiere bitte mal version 0.8 hier unten:
                                //************Dutchman & meifi2017**********
                                //*******************V 0.8******************
                                // define variable
                                var vbus = require('resol-vbus');
                                var headerSet = new vbus.HeaderSet();
                                var conn;
                                var create_states = true; // !!! set initial on true to create states once, disable value afterwards to update states !!
                                // Schedule every 20 seconds
                                schedule("*/20 * * * * *", function () {
                                    // Define connection values
                                    conn = new vbus.TcpConnection({
                                    host: 'xxxxx.via.vbus.net',   // Can be used with via.vbus.net OR internal 192xxxxx adress !
                                    viaTag: 'xxxxx',                  // only necessary if connected using VBus.net otherwise leave empty
                                    password: 'vbus',
                                    //   channel: 1,                                // only necessary if connected to a DL3
                                    // Log connection status
                                    var onConnectionStateChange = function(state) {
                                    console.debug(state);
                                    var onPacket = function(packet) {
                                        headerSet.addHeader(packet);
                                    conn.on('connectionState', onConnectionStateChange);
                                    conn.on('packet', onPacket);
                                    conn.connect().done(function() {
                                        setTimeout(function() {
                                            conn.disconnect();
                                            //create header packages
                                            var packets = headerSet.getSortedHeaders();
                                            var spec = vbus.Specification.getDefaultSpecification();
                                            var packetFields = spec.getPacketFieldsForHeaders(packets);
                                            var packet = null;
                                            var counter = 0;
                                            packetFields.forEach(function(packetField) {
                                                counter = counter + 1;
                                                if (packet !== packetField.packet) {
                                                    packet = packetField.packet;
                                                    console.debug(packetField.packetSpec.fullName);
                                                // write values in memory
                                                packetField.name = packetField.name.replace(/ /g,"");
                                                console.debug("Value received : " + packetField.name + " = " + packetField.formatTextValue());
                                                rawvalue = packetField.formatTextValue();
                                                rawvalue = rawvalue.replace(/[^0-9.,]/g,"");
                                                console.debug("Value translated to raw format : " + rawvalue);
                                                // Create new objects only if "var create_states = true"
                                                if (create_states === true){
                                                    // create objects real data
                                                    createState("vbus.values." + packetField.name ,{
                                                        type: 'string',
                                                        role: 'value'
                                                    // create objects raw data only
                                                    createState("vbus.values_raw." + packetField.name ,{
                                                        name: packetField.name + "_raw",
                                                        type: 'string',
                                                        role: 'value'
                                                } else {
                                                    // Update values
                                                    setState("vbus.values." + packetField.name , packetField.formatTextValue(), true);
                                                    setState("vbus.values_raw." + packetField.name , rawvalue, true);
                                                console.warn("States created change var create_states to False !!!");
                                        // 10 second timer, collection all information takes some seconds [emoji6]
                                        }, 10000);
                                  hi.
                                  DANKE für deine Mühe.
                                  Jedoch kommt immer dieser ERROR…
                                  ! host.IObroker 2017-09-30 22:23:20.743 info Restart adapter system.adapter.javascript.0 because enabled
                                  ! host.IObroker 2017-09-30 22:23:20.740 error instance system.adapter.javascript.0 terminated with code 0 (OK)
                                  ! javascript.0 2017-09-30 22:23:15.143 info script.js.resol3: registered 0 subscriptions and 1 schedule
                                  ! javascript.0 2017-09-30 22:23:15.140 info Start javascript script.js.resol3
                                  ! javascript.0 2017-09-30 22:22:58.827 info received all objects
                                  ! javascript.0 2017-09-30 22:22:58.123 info received all states
                                  ! javascript.0 2017-09-30 22:22:57.218 info requesting all objects
                                  ! javascript.0 2017-09-30 22:22:57.216 info requesting all states
                                  ! javascript.0 2017-09-30 22:22:57.214 info starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                  ! host.IObroker 2017-09-30 22:22:50.550 info instance system.adapter.javascript.0 started with pid 12535
                                  ! host.IObroker 2017-09-30 22:22:20.544 info Restart adapter system.adapter.javascript.0 because enabled
                                  ! host.IObroker 2017-09-30 22:22:20.528 error instance system.adapter.javascript.0 terminated with code 0 (OK)
                                  ! javascript.0 2017-09-30 22:22:15.983 info script.js.resol3: registered 0 subscriptions and 1 schedule
                                  ! javascript.0 2017-09-30 22:22:15.980 info Start javascript script.js.resol3
                                  Wie kann ich es testen ob mein Gerät das kann?
                                  Wie ist dein Aufbau? (Hardware)
                                  Meiner ist folgender
                                  TISUN DUPLEX (RESOL) –> ETHERNET KAbel --> SWITCH --> RASPBERRY/IOBROKER
                                  Oder muss ich die VBUS KLEMMEN am Gerät direkt nutzen?
                                  Dann macht aber das WEBINTERFACE der TISUN und deine IP Adress Einstellung im Script keinen Sinn, für mich.
                                  • Dutchman
                                    Setze den JavaScript adapter Mal bitte auf Log Level debug ich hab da ein par Sachen eingebaut die mehr Details geben
                                      welchen debug meinst du genau?
                                      mein log sagt folgendes…
                                      ! javascript.0 2017-10-01 21:46:59.426 info received all objects
                                      ! javascript.0 2017-10-01 21:46:58.751 info received all states
                                      ! javascript.0 2017-10-01 21:46:57.870 info requesting all objects
                                      ! javascript.0 2017-10-01 21:46:57.869 info requesting all states
                                      ! javascript.0 2017-10-01 21:46:57.867 info starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                      ! host.IObroker 2017-10-01 21:46:51.228 info instance system.adapter.javascript.0 started with pid 22208
                                      ! host.IObroker 2017-10-01 21:46:21.201 info Restart adapter system.adapter.javascript.0 because enabled
                                      ! host.IObroker 2017-10-01 21:46:21.200 error instance system.adapter.javascript.0 terminated with code 0 (OK)
                                      ! javascript.0 2017-10-01 21:46:15.651 info script.js.resol3: registered 0 subscriptions and 1 schedule
                                      ! javascript.0 2017-10-01 21:46:15.650 info script.js.resol3: schedule(cron=*/20 * * * * *)
                                      ! javascript.0 2017-10-01 21:46:15.643 info Start javascript script.js.resol3
                                      ! javascript.0 2017-10-01 21:45:58.829 info received all objects
                                      ! javascript.0 2017-10-01 21:45:58.125 info received all states
                                      ! javascript.0 2017-10-01 21:45:57.215 info requesting all objects
                                      ! javascript.0 2017-10-01 21:45:57.214 info requesting all states
                                      ! javascript.0 2017-10-01 21:45:57.212 info starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                      ! host.FroelingRPi 2017-10-01 21:42:48.749 info object change system.adapter.javascript.0
                                      mein debug mode im script bringt folgendes…
                                      ! 21:43:13.494 [info] javascript.0 Start javascript script.js.resol3
                                      ! 21:43:13.505 [info] javascript.0 script.js.resol3: schedule(cron=*/20 * * * * )
                                      ! 21:43:13.505 [info] javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                      ! 21:44:15.299 [info] javascript.0 Start javascript script.js.resol3
                                      ! 21:44:15.324 [info] javascript.0 script.js.resol3: schedule(cron=
                                      /20 * * * * )
                                      ! 21:44:15.325 [info] javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                      ! 21:45:16.298 [info] javascript.0 Start javascript script.js.resol3
                                      ! 21:45:16.300 [info] javascript.0 script.js.resol3: schedule(cron=
                                      /20 * * * * )
                                      ! 21:45:16.301 [info] javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                      ! 21:46:15.643 [info] javascript.0 Start javascript script.js.resol3
                                      ! 21:46:15.650 [info] javascript.0 script.js.resol3: schedule(cron=
                                      /20 * * * * )
                                      ! 21:46:15.651 [info] javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                      ! 21:47:15.966 [info] javascript.0 Start javascript script.js.resol3
                                      ! 21:47:15.968 [info] javascript.0 script.js.resol3: schedule(cron=
                                      /20 * * * * )
                                      ! 21:47:15.969 [info] javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                      ! 21:48:16.198 [info] javascript.0 Start javascript script.js.resol3
                                      ! 21:48:16.203 [info] javascript.0 script.js.resol3: schedule(cron=
                                      /20 * * * * *)
                                      ! 21:48:16.212 [info] javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                      und mein Adapter hat innerhalb kürzester Zeit 130Mb auslastung…
                                      Tobi
                                      • Dutchman
                                        @RS_Tobi:
                                        /20 * * * * )
                                        /20 * * * * )
                                        /20 * * * * )
                                        /20 * * * * )
                                        /20 * * * * *)
                                        Tobi `
                                        Hat du deinen JavaScript adapter auf debug Mode gesetzt?
                                        ~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201710 ... eb9377.png">https://uploads.tapatalk-cdn.com/20171001/941495112bcef514cc618f65f0eb9377.png</link_text>" />
                                        PS: dazu musst du Experten Modus an haben siehe oben links
                                        Send from mobile device~~
                                          habe ihn jetzt auf debug…
                                          zur timeline...
                                          erstt javascript adapter gestartet, dann etwas gewartet und danach den skript gestartet.
                                          dann alles für einige Zeit laufen lassen.
                                          tobi
                                          p.s. da log zulange, habe ich passagen mit . . . . gekennzeichnet und herausgeschnitten.
                                          ! 2017-10-01 22:40:01.779 - [32minfo[39m: host.IObroker object change system.adapter.javascript.0
                                          ! 2017-10-01 22:40:01.827 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 started with pid 23973
                                          ! 2017-10-01 22:40:09.007 - [34mdebug[39m: javascript.0 objectDB connected
                                          ! 2017-10-01 22:40:09.176 - [34mdebug[39m: javascript.0 statesDB connected
                                          ! 2017-10-01 22:40:09.289 - [32minfo[39m: javascript.0 starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                          ! 2017-10-01 22:40:09.322 - [32minfo[39m: javascript.0 requesting all states
                                          ! 2017-10-01 22:40:09.331 - [32minfo[39m: javascript.0 requesting all objects
                                          ! 2017-10-01 22:40:10.343 - [32minfo[39m: javascript.0 received all states
                                          ! 2017-10-01 22:40:10.999 - [32minfo[39m: javascript.0 received all objects
                                          ! 2017-10-01 22:40:11.147 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol val=false, ack=true, ts=1506890411134, q=0, from=system.adapter.javascript.0, lc=1506550059065
                                          ! 2017-10-01 22:40:11.181 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol2 val=false, ack=true, ts=1506890411144, q=0, from=system.adapter.javascript.0, lc=1506550016921
                                          ! 2017-10-01 22:40:11.190 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol3 val=false, ack=true, ts=1506890411150, q=0, from=system.adapter.javascript.0, lc=1506890411150
                                          ! 2017-10-01 22:40:12.327 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.alive val=true, ack=true, ts=1506890412319, q=0, from=system.host.IObroker, lc=1506539950508
                                          ! 2017-10-01 22:40:12.365 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.load val=0.09, ack=true, ts=1506890412325, q=0, from=system.host.IObroker, lc=1506890412325
                                          ! 2017-10-01 22:40:12.371 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.mem val=15, ack=true, ts=1506890412327, q=0, from=system.host.IObroker, lc=1506890412327
                                          ! 2017-10-01 22:40:12.379 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memRss val=101.24, ack=true, ts=1506890412330, q=0, from=system.host.IObroker, lc=1506890412330
                                          ! 2017-10-01 22:40:12.385 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memHeapTotal val=37.66, ack=true, ts=1506890412335, q=0, from=system.host.IObroker, lc=1506890412335
                                          ! 2017-10-01 22:40:12.390 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memHeapUsed val=25.74, ack=true, ts=1506890412338, q=0, from=system.host.IObroker, lc=1506890412338
                                          ! 2017-10-01 22:40:12.404 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.uptime val=352278, ack=true, ts=1506890412340, q=0, from=system.host.IObroker, lc=1506890412340
                                          ! 2017-10-01 22:40:12.413 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.freemem val=138, ack=true, ts=1506890412342, q=0, from=system.host.IObroker, lc=1506890412342
                                          ! 2017-10-01 22:40:12.421 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.inputCount val=8, ack=true, ts=1506890412344, q=0, from=system.host.IObroker, lc=1506890412344
                                          ! 2017-10-01 22:40:12.426 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.outputCount val=10, ack=true, ts=1506890412346, q=0, from=system.host.IObroker, lc=1506889420760
                                          ! 2017-10-01 22:40:13.981 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.alive val=true, ack=true, ts=1506890413967, q=0, from=system.adapter.tr-064.0, lc=1506540436438
                                          ! 2017-10-01 22:40:13.998 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.connected val=true, ack=true, ts=1506890413986, q=0, from=system.adapter.tr-064.0, lc=1506540436444
                                          ! 2017-10-01 22:40:14.029 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memRss val=35.62, ack=true, ts=1506890413996, q=0, from=system.adapter.tr-064.0, lc=1506890413996
                                          ! 2017-10-01 22:40:14.034 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memHeapTotal val=19, ack=true, ts=1506890413998, q=0, from=system.adapter.tr-064.0, lc=1506890293908
                                          ! 2017-10-01 22:40:14.038 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memHeapUsed val=14.15, ack=true, ts=1506890414001, q=0, from=system.adapter.tr-064.0, lc=1506890414001
                                          ! 2017-10-01 22:40:14.042 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.uptime val=349986, ack=true, ts=1506890414004, q=0, from=system.adapter.tr-064.0, lc=1506890414004
                                          ! 2017-10-01 22:40:14.046 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.inputCount val=0, ack=true, ts=1506890414006, q=0, from=system.adapter.tr-064.0, lc=1506540556560
                                          ! 2017-10-01 22:40:14.052 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.outputCount val=8, ack=true, ts=1506890414008, q=0, from=system.adapter.tr-064.0, lc=1506538226478
                                          ! 2017-10-01 22:40:14.082 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.alive val=true, ack=true, ts=1506890414060, q=0, from=system.adapter.node-red.0, lc=1506540433921
                                          ! 2017-10-01 22:40:14.114 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.connected val=true, ack=true, ts=1506890414076, q=0, from=system.adapter.node-red.0, lc=1506540433928
                                          ! 2017-10-01 22:40:14.122 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memRss val=27.73, ack=true, ts=1506890414079, q=0, from=system.adapter.node-red.0, lc=1506890369020
                                          ! 2017-10-01 22:40:14.127 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memHeapTotal val=12, ack=true, ts=1506890414082, q=0, from=system.adapter.node-red.0, lc=1506542610355
                                          ! 2017-10-01 22:40:14.131 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memHeapUsed val=8.56, ack=true, ts=1506890414085, q=0, from=system.adapter.node-red.0, lc=1506890414085
                                          ! 2017-10-01 22:40:14.135 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.uptime val=349985, ack=true, ts=1506890414087, q=0, from=system.adapter.node-red.0, lc=1506890414087
                                          ! 2017-10-01 22:40:14.141 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.inputCount val=0, ack=true, ts=1506890414089, q=0, from=system.adapter.node-red.0, lc=1506540553967
                                          ! 2017-10-01 22:40:14.146 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.outputCount val=8, ack=true, ts=1506890414091, q=0, from=system.adapter.node-red.0, lc=1500588052060
                                          ! 2017-10-01 22:40:17.405 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.alive val=true, ack=true, ts=1506890417395, q=0, from=system.adapter.discovery.0, lc=1506538148270
                                          ! 2017-10-01 22:40:17.435 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.connected val=true, ack=true, ts=1506890417408, q=0, from=system.adapter.discovery.0, lc=1506538148279
                                          ! 2017-10-01 22:40:17.442 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memRss val=27.55, ack=true, ts=1506890417410, q=0, from=system.adapter.discovery.0, lc=1506890357338
                                          ! 2017-10-01 22:40:17.447 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memHeapTotal val=12, ack=true, ts=1506890417412, q=0, from=system.adapter.discovery.0, lc=1506539799771
                                          ! 2017-10-01 22:40:17.451 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memHeapUsed val=8.37, ack=true, ts=1506890417415, q=0, from=system.adapter.discovery.0, lc=1506890417415
                                          ! 2017-10-01 22:40:17.455 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.uptime val=352274, ack=true, ts=1506890417417, q=0, from=system.adapter.discovery.0, lc=1506890417417
                                          ! 2017-10-01 22:40:17.459 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.inputCount val=0, ack=true, ts=1506890417419, q=0, from=system.adapter.discovery.0, lc=1506540550376
                                          ! 2017-10-01 22:40:17.463 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.outputCount val=8, ack=true, ts=1506890417421, q=0, from=system.adapter.discovery.0, lc=1506538178377
                                          ! 2017-10-01 22:42:05.559 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890525549, q=0, from=system.adapter.admin.2, lc=1506540438557
                                          ! 2017-10-01 22:42:05.625 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890525563, q=0, from=system.adapter.admin.2, lc=1506540438589
                                          ! 2017-10-01 22:42:05.628 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.96, ack=true, ts=1506890525568, q=0, from=system.adapter.admin.2, lc=1506890525568
                                          ! 2017-10-01 22:42:05.630 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890525571, q=0, from=system.adapter.admin.2, lc=1506890465559
                                          ! 2017-10-01 22:42:05.632 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=15.67, ack=true, ts=1506890525573, q=0, from=system.adapter.admin.2, lc=1506890525573
                                          ! 2017-10-01 22:42:05.635 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350096, ack=true, ts=1506890525575, q=0, from=system.adapter.admin.2, lc=1506890525575
                                          ! 2017-10-01 22:42:05.639 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=152, ack=true, ts=1506890525577, q=0, from=system.adapter.admin.2, lc=1506890525577
                                          ! 2017-10-01 22:42:05.641 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890525578, q=0, from=system.adapter.admin.2, lc=1506888484820
                                          ! 2017-10-01 22:42:06.151 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890526140, q=0, from=system.adapter.web.0, lc=1506540396929
                                          ! 2017-10-01 22:42:06.161 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890526153, q=0, from=system.adapter.web.0, lc=1506540396952
                                          ! 2017-10-01 22:42:06.186 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=49.18, ack=true, ts=1506890526158, q=0, from=system.adapter.web.0, lc=1506890526158
                                          ! 2017-10-01 22:42:06.189 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890526160, q=0, from=system.adapter.web.0, lc=1506889640821
                                          ! 2017-10-01 22:42:06.192 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=13.2, ack=true, ts=1506890526161, q=0, from=system.adapter.web.0, lc=1506890526161
                                          ! 2017-10-01 22:42:06.195 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350135, ack=true, ts=1506890526163, q=0, from=system.adapter.web.0, lc=1506890526163
                                          ! 2017-10-01 22:42:06.197 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=76, ack=true, ts=1506890526165, q=0, from=system.adapter.web.0, lc=1506890511159
                                          ! 2017-10-01 22:42:06.200 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890526166, q=0, from=system.adapter.web.0, lc=1506890196064
                                          ! 2017-10-01 22:42:06.234 - [34mdebug[39m: javascript.0 inMem message * script.js.resol3 name=resol3, engineType=Javascript/js, source=//******************************************
                                          ! //Dutchman & meifi2017
                                          ! //V 0.8
                                          ! // define variable
                                          ! var vbus = require('resol-vbus');
                                          ! var headerSet = new vbus.HeaderSet();
                                          ! var conn;
                                          ! var create_states = true; // !!! set initial on true to create states once, disable value afterwards to update states !!
                                          ! // Schedule every 20 seconds
                                          ! schedule("/20 * * * * ", function () {
                                          ! // Define connection values
                                          ! conn = new vbus.TcpConnection({
                                          ! host: '192.168.178.110', // Can be used with via.vbus.net OR internal 192xxxxx adress !
                                          ! viaTag: 'xxxxx', // only necessary if connected using VBus.net otherwise leave empty
                                          ! password: 'vbus',
                                          ! // channel: 1, // only necessary if connected to a DL3
                                          ! // Log connection status
                                          ! var onConnectionStateChange = function(state) {
                                          ! console.debug(state);
                                          ! var onPacket = function(packet) {
                                          ! headerSet.addHeader(packet);
                                          ! conn.on('connectionState', onConnectionStateChange);
                                          ! conn.on('packet', onPacket);
                                          ! conn.connect().done(function() {
                                          ! setTimeout(function() {
                                          ! conn.disconnect();
                                          ! //create header packages
                                          ! var packets = headerSet.getSortedHeaders();
                                          ! var spec = vbus.Specification.getDefaultSpecification();
                                          ! var packetFields = spec.getPacketFieldsForHeaders(packets);
                                          ! var packet = null;
                                          ! var counter = 0;
                                          ! packetFields.forEach(function(packetField) {
                                          ! counter = counter + 1;
                                          ! if (packet !== packetField.packet) {
                                          ! packet = packetField.packet;
                                          ! console.debug(packetField.packetSpec.fullName);
                                          ! // write values in memory
                                          ! packetField.name = packetField.name.replace(/ /g,"");
                                          ! console.debug("Value received : " + packetField.name + " = " + packetField.formatTextValue());
                                          ! rawvalue = packetField.formatTextValue();
                                          ! rawvalue = rawvalue.replace(/[^0-9.,]/g,"");
                                          ! console.debug("Value translated to raw format : " + rawvalue);
                                          ! // Create new objects only if "var create_states = true"
                                          ! if (create_states === true){
                                          ! // create objects real data
                                          ! createState("vbus.values." + packetField.name ,{
                                          ! name: packetField.name,
                                          ! type: 'string',
                                          ! role: 'value'
                                          ! // create objects raw data only
                                          ! createState("vbus.values_raw." + packetField.name ,{
                                          ! name: packetField.name + "_raw",
                                          ! type: 'string',
                                          ! role: 'value'
                                          ! } else {
                                          ! // Update values
                                          ! setState("vbus.values." + packetField.name , packetField.formatTextValue(), true);
                                          ! setState("vbus.values_raw." + packetField.name , rawvalue, true);
                                          ! console.warn("States created change var create_states to False !!!");
                                          ! // 10 second timer, collection all information takes some seconds [emoji6]
                                          ! }, 10000);
                                          ! });, enabled=false, engine=system.adapter.javascript.0, debug=true, verbose=true, type=script, _id=script.js.resol3
                                          ! 2017-10-01 22:42:06.255 - [32minfo[39m: javascript.0 Stop script script.js.resol3
                                          ! 2017-10-01 22:42:06.274 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol3 val=false, ack=true, ts=1506890526262, q=0, from=system.adapter.javascript.0, lc=1506890411150
                                          ! 2017-10-01 22:42:06.311 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol3 val=false, ack=true, ts=1506890526303, q=0, from=system.adapter.javascript.0, lc=1506890411150
                                          ! 2017-10-01 22:42:06.377 - [34mdebug[39m: javascript.0 inMem message * script.js.resol3 name=resol3, engineType=Javascript/js, source=//
                                          ! //V 0.8
                                          ! var conn;
                                          ! schedule("*/20 * * * * ", function () {
                                          ! password: 'vbus',
                                          ! var counter = 0;
                                          ! type: 'string',
                                          ! role: 'value'
                                          ! type: 'string',
                                          ! role: 'value'
                                          ! } else {
                                          ! // Update values
                                          ! }, 10000);
                                          ! });, enabled=true, engine=system.adapter.javascript.0, debug=true, verbose=true, type=script, _id=script.js.resol3
                                          ! 2017-10-01 22:42:06.404 - [32minfo[39m: javascript.0 Start javascript script.js.resol3
                                          ! 2017-10-01 22:42:24.291 - [32minfo[39m: javascript.0 script.js.resol3: schedule(cron=
                                          /20 * * * * )
                                          ! 2017-10-01 22:42:24.294 - [32minfo[39m: javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                          ! 2017-10-01 22:42:24.331 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol3 val=true, ack=true, ts=1506890526402, q=0, from=system.adapter.javascript.0, lc=1506890526402
                                          ! 2017-10-01 22:42:24.339 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890527078, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                          ! 2017-10-01 22:42:24.342 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.05, ack=true, ts=1506890527097, q=0, from=system.host.FroelingRPi, lc=1506890527097
                                          ! 2017-10-01 22:42:24.346 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890527106, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                          ! 2017-10-01 22:42:24.349 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=37.27, ack=true, ts=1506890527112, q=0, from=system.host.FroelingRPi, lc=1506890527112
                                          ! 2017-10-01 22:42:24.352 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890527122, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                          ! 2017-10-01 22:42:24.357 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=10.06, ack=true, ts=1506890527128, q=0, from=system.host.FroelingRPi, lc=1506890527128
                                          ! 2017-10-01 22:42:24.361 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185354, ack=true, ts=1506890527131, q=0, from=system.host.FroelingRPi, lc=1506890527131
                                          ! 2017-10-01 22:42:24.365 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=184, ack=true, ts=1506890527133, q=0, from=system.host.FroelingRPi, lc=1506890482091
                                          ! 2017-10-01 22:42:24.369 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=7, ack=true, ts=1506890527147, q=0, from=system.host.FroelingRPi, lc=1506890422054
                                          ! 2017-10-01 22:42:24.372 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890527152, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                          ! 2017-10-01 22:42:24.376 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890528107, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                          ! 2017-10-01 22:42:24.382 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890528124, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                          ! 2017-10-01 22:42:24.385 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=34.39, ack=true, ts=1506890528131, q=0, from=system.adapter.modbus.1, lc=1506890528131
                                          ! 2017-10-01 22:42:24.387 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=15, ack=true, ts=1506890528149, q=0, from=system.adapter.modbus.1, lc=1506890453039
                                          ! 2017-10-01 22:42:24.396 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=12.51, ack=true, ts=1506890528164, q=0, from=system.adapter.modbus.1, lc=1506890528164
                                          ! 2017-10-01 22:42:24.400 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122603, ack=true, ts=1506890528166, q=0, from=system.adapter.modbus.1, lc=1506890528166
                                          ! 2017-10-01 22:42:24.403 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890528168, q=0, from=system.adapter.modbus.1, lc=1506890483101
                                          ! 2017-10-01 22:42:24.416 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890528169, q=0, from=system.adapter.modbus.1, lc=1506890483103
                                          ! 2017-10-01 22:42:24.419 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Windfang val=19.937, ack=true, ts=1506890530611, q=0, from=system.adapter.node-red.0, lc=1506890426450
                                          ! 2017-10-01 22:42:24.426 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_WC val=20.062, ack=true, ts=1506890530651, q=0, from=system.adapter.node-red.0, lc=1506890426495
                                          ! 2017-10-01 22:42:24.429 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Gang val=22.312, ack=true, ts=1506890530684, q=0, from=system.adapter.node-red.0, lc=1506890495410
                                          ! 2017-10-01 22:42:24.432 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_HWR val=22.25, ack=true, ts=1506890530690, q=0, from=system.adapter.node-red.0, lc=1506890530690
                                          ! 2017-10-01 22:42:24.434 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Wohnzimmer val=22.187, ack=true, ts=1506890530692, q=0, from=system.adapter.node-red.0, lc=1506890495631
                                          ! 2017-10-01 22:42:24.437 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.alive val=true, ack=true, ts=1506890532525, q=0, from=system.host.IObroker, lc=1506539950508
                                          ! 2017-10-01 22:42:24.439 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.load val=0.2, ack=true, ts=1506890532531, q=0, from=system.host.IObroker, lc=1506890532531
                                          ! 2017-10-01 22:42:24.442 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.mem val=16, ack=true, ts=1506890532533, q=0, from=system.host.IObroker, lc=1506890532533
                                          ! 2017-10-01 22:42:24.444 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memRss val=92.66, ack=true, ts=1506890532536, q=0, from=system.host.IObroker, lc=1506890532536
                                          ! 2017-10-01 22:42:24.447 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memHeapTotal val=25.88, ack=true, ts=1506890532538, q=0, from=system.host.IObroker, lc=1506890532538
                                          ! 2017-10-01 22:42:24.449 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memHeapUsed val=19.61, ack=true, ts=1506890532539, q=0, from=system.host.IObroker, lc=1506890532539
                                          ! 2017-10-01 22:42:24.452 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.uptime val=352399, ack=true, ts=1506890532541, q=0, from=system.host.IObroker, lc=1506890532541
                                          ! 2017-10-01 22:42:24.454 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.freemem val=151, ack=true, ts=1506890532542, q=0, from=system.host.IObroker, lc=1506890532542
                                          ! 2017-10-01 22:42:24.457 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.inputCount val=7, ack=true, ts=1506890532544, q=0, from=system.host.IObroker, lc=1506890427370
                                          ! 2017-10-01 22:42:24.459 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.outputCount val=10, ack=true, ts=1506890532546, q=0, from=system.host.IObroker, lc=1506889420760
                                          ! 2017-10-01 22:42:24.462 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.alive val=true, ack=true, ts=1506890534046, q=0, from=system.adapter.tr-064.0, lc=1506540436438
                                          ! 2017-10-01 22:42:24.464 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.connected val=true, ack=true, ts=1506890534059, q=0, from=system.adapter.tr-064.0, lc=1506540436444
                                          ! 2017-10-01 22:42:24.467 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memRss val=35.74, ack=true, ts=1506890534064, q=0, from=system.adapter.tr-064.0, lc=1506890534064
                                          ! 2017-10-01 22:42:24.469 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memHeapTotal val=19, ack=true, ts=1506890534066, q=0, from=system.adapter.tr-064.0, lc=1506890293908
                                          ! 2017-10-01 22:42:24.472 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memHeapUsed val=14.73, ack=true, ts=1506890534069, q=0, from=system.adapter.tr-064.0, lc=1506890534069
                                          ! 2017-10-01 22:42:24.479 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.uptime val=350106, ack=true, ts=1506890534071, q=0, from=system.adapter.tr-064.0, lc=1506890534071
                                          ! 2017-10-01 22:42:24.482 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.inputCount val=0, ack=true, ts=1506890534083, q=0, from=system.adapter.tr-064.0, lc=1506540556560
                                          ! 2017-10-01 22:42:24.486 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.outputCount val=8, ack=true, ts=1506890534089, q=0, from=system.adapter.tr-064.0, lc=1506538226478
                                          ! 2017-10-01 22:42:24.489 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.alive val=true, ack=true, ts=1506890534097, q=0, from=system.adapter.node-red.0, lc=1506540433921
                                          ! 2017-10-01 22:42:24.491 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.connected val=true, ack=true, ts=1506890534114, q=0, from=system.adapter.node-red.0, lc=1506540433928
                                          ! 2017-10-01 22:42:24.494 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memRss val=27.99, ack=true, ts=1506890534120, q=0, from=system.adapter.node-red.0, lc=1506890504116
                                          ! 2017-10-01 22:42:24.497 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memHeapTotal val=12, ack=true, ts=1506890534123, q=0, from=system.adapter.node-red.0, lc=1506542610355
                                          ! 2017-10-01 22:42:24.499 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memHeapUsed val=8.79, ack=true, ts=1506890534126, q=0, from=system.adapter.node-red.0, lc=1506890534126
                                          ! 2017-10-01 22:42:24.501 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.uptime val=350105, ack=true, ts=1506890534128, q=0, from=system.adapter.node-red.0, lc=1506890534128
                                          ! 2017-10-01 22:42:24.504 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.inputCount val=0, ack=true, ts=1506890534130, q=0, from=system.adapter.node-red.0, lc=1506540553967
                                          ! 2017-10-01 22:42:24.506 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.outputCount val=8, ack=true, ts=1506890534131, q=0, from=system.adapter.node-red.0, lc=1500588052060
                                          ! 2017-10-01 22:42:32.514 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.alive val=true, ack=true, ts=1506890552499, q=0, from=system.adapter.discovery.0, lc=1506538148270
                                          ! 2017-10-01 22:42:32.546 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.connected val=true, ack=true, ts=1506890552510, q=0, from=system.adapter.discovery.0, lc=1506538148279
                                          ! 2017-10-01 22:42:32.551 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memRss val=27.81, ack=true, ts=1506890552512, q=0, from=system.adapter.discovery.0, lc=1506890492472
                                          ! 2017-10-01 22:42:32.554 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memHeapTotal val=12, ack=true, ts=1506890552517, q=0, from=system.adapter.discovery.0, lc=1506539799771
                                          ! 2017-10-01 22:42:32.557 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memHeapUsed val=8.61, ack=true, ts=1506890552519, q=0, from=system.adapter.discovery.0, lc=1506890552519
                                          ! 2017-10-01 22:42:32.559 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.uptime val=352409, ack=true, ts=1506890552521, q=0, from=system.adapter.discovery.0, lc=1506890552521
                                          ! 2017-10-01 22:42:32.562 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.inputCount val=0, ack=true, ts=1506890552522, q=0, from=system.adapter.discovery.0, lc=1506540550376
                                          ! 2017-10-01 22:42:32.565 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.outputCount val=8, ack=true, ts=1506890552524, q=0, from=system.adapter.discovery.0, lc=1506538178377
                                          ! 2017-10-01 22:42:35.586 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890555569, q=0, from=system.adapter.admin.2, lc=1506540438557
                                          ! 2017-10-01 22:42:35.634 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890555578, q=0, from=system.adapter.admin.2, lc=1506540438589
                                          ! 2017-10-01 22:42:35.638 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.51, ack=true, ts=1506890555580, q=0, from=system.adapter.admin.2, lc=1506890555580
                                          ! 2017-10-01 22:42:35.640 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890555581, q=0, from=system.adapter.admin.2, lc=1506890465559
                                          ! 2017-10-01 22:42:35.643 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=15.27, ack=true, ts=1506890555583, q=0, from=system.adapter.admin.2, lc=1506890555583
                                          ! 2017-10-01 22:42:35.646 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350126, ack=true, ts=1506890555591, q=0, from=system.adapter.admin.2, lc=1506890555591
                                          ! 2017-10-01 22:42:35.650 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=217, ack=true, ts=1506890555593, q=0, from=system.adapter.admin.2, lc=1506890555593
                                          ! 2017-10-01 22:42:35.653 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890555594, q=0, from=system.adapter.admin.2, lc=1506888484820
                                          ! 2017-10-01 22:42:36.156 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890556149, q=0, from=system.adapter.web.0, lc=1506540396929
                                          ! 2017-10-01 22:42:36.167 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890556161, q=0, from=system.adapter.web.0, lc=1506540396952
                                          ! 2017-10-01 22:42:36.182 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=48.41, ack=true, ts=1506890556165, q=0, from=system.adapter.web.0, lc=1506890556165
                                          ! 2017-10-01 22:42:36.186 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890556167, q=0, from=system.adapter.web.0, lc=1506889640821
                                          ! 2017-10-01 22:42:36.189 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=12.46, ack=true, ts=1506890556169, q=0, from=system.adapter.web.0, lc=1506890556169
                                          ! 2017-10-01 22:42:36.192 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350165, ack=true, ts=1506890556171, q=0, from=system.adapter.web.0, lc=1506890556171
                                          ! 2017-10-01 22:42:36.195 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=78, ack=true, ts=1506890556172, q=0, from=system.adapter.web.0, lc=1506890556172
                                          ! 2017-10-01 22:42:36.197 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890556173, q=0, from=system.adapter.web.0, lc=1506890196064
                                          ! 2017-10-01 22:42:37.120 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890557113, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                          ! 2017-10-01 22:42:37.135 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.1, ack=true, ts=1506890557128, q=0, from=system.host.FroelingRPi, lc=1506890557128
                                          ! 2017-10-01 22:42:37.145 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890557137, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                          ! 2017-10-01 22:42:37.155 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=37.44, ack=true, ts=1506890557143, q=0, from=system.host.FroelingRPi, lc=1506890557143
                                          ! 2017-10-01 22:42:37.160 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890557145, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                          ! 2017-10-01 22:42:37.170 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=10.23, ack=true, ts=1506890557160, q=0, from=system.host.FroelingRPi, lc=1506890557160
                                          ! 2017-10-01 22:42:37.191 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185384, ack=true, ts=1506890557167, q=0, from=system.host.FroelingRPi, lc=1506890557167
                                          ! 2017-10-01 22:42:37.196 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=183, ack=true, ts=1506890557169, q=0, from=system.host.FroelingRPi, lc=1506890557169
                                          ! 2017-10-01 22:42:37.200 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=8, ack=true, ts=1506890557172, q=0, from=system.host.FroelingRPi, lc=1506890557172
                                          ! 2017-10-01 22:42:37.204 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890557174, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                          ! 2017-10-01 22:42:38.156 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890558144, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                          ! 2017-10-01 22:42:38.178 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890558166, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                          ! 2017-10-01 22:42:38.191 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=34.73, ack=true, ts=1506890558176, q=0, from=system.adapter.modbus.1, lc=1506890558176
                                          ! 2017-10-01 22:42:38.210 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=16, ack=true, ts=1506890558199, q=0, from=system.adapter.modbus.1, lc=1506890543157
                                          ! 2017-10-01 22:42:38.226 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=12.78, ack=true, ts=1506890558204, q=0, from=system.adapter.modbus.1, lc=1506890558204
                                          ! 2017-10-01 22:42:38.230 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122633, ack=true, ts=1506890558207, q=0, from=system.adapter.modbus.1, lc=1506890558207
                                          ! 2017-10-01 22:42:38.233 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890558209, q=0, from=system.adapter.modbus.1, lc=1506890483101
                                          ! 2017-10-01 22:42:38.237 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890558211, q=0, from=system.adapter.modbus.1, lc=1506890483103
                                          ! 2017-10-01 22:42:39.320 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.alive val=true, ack=true, ts=1506890559309, q=0, from=system.adapter.javascript.0, lc=1506890544302
                                          ! 2017-10-01 22:42:39.330 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.connected val=true, ack=true, ts=1506890559322, q=0, from=system.adapter.javascript.0, lc=1506890544312
                                          ! 2017-10-01 22:42:39.646 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.memRss val=125.09, ack=true, ts=1506890559327, q=0, from=system.adapter.javascript.0, lc=1506890559327
                                          ! 2017-10-01 22:42:39.648 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.memHeapTotal val=104.89, ack=true, ts=1506890559330, q=0, from=system.adapter.javascript.0, lc=1506890544339
                                          ! 2017-10-01 22:42:39.650 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.memHeapUsed val=92.51, ack=true, ts=1506890559332, q=0, from=system.adapter.javascript.0, lc=1506890559332
                                          ! 2017-10-01 22:42:39.652 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.uptime val=157, ack=true, ts=1506890559334, q=0, from=system.adapter.javascript.0, lc=1506890559334
                                          ! 2017-10-01 22:42:39.655 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.inputCount val=170, ack=true, ts=1506890559348, q=0, from=system.adapter.javascript.0, lc=1506890559348
                                          ! 2017-10-01 22:42:39.657 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.outputCount val=8, ack=true, ts=1506890559355, q=0, from=system.adapter.javascript.0, lc=1506890559355
                                          ! 2017-10-01 22:42:40.273 - [34mdebug[39m: javascript.0 script.js.resol3: CONNECTING
                                          ! 2017-10-01 22:42:40.371 - [31merror[39m: javascript.0 uncaught exception: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                          ! 2017-10-01 22:42:40.373 - [31merror[39m: javascript.0 Error: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                          ! at onLine (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/tcp-connection.js:241:22)
                                          ! at Socket.onSocketData (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/tcp-connection.js:301:29)
                                          ! at emitOne (events.js:96:13)
                                          ! at Socket.emit (events.js:188:7)
                                          ! at readableAddChunk (_stream_readable.js:176:18)
                                          ! at Socket.Readable.push (_stream_readable.js:134:10)
                                          ! at TCP.onread (net.js:547:20)
                                          ! 2017-10-01 22:42:40.402 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.alive val=false, ack=true, ts=1506890560390, q=0, from=system.adapter.javascript.0, lc=1506890560390
                                          ! 2017-10-01 22:42:40.507 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 0 (OK)
                                          ! 2017-10-01 22:42:40.520 - [32minfo[39m: host.IObroker Restart adapter system.adapter.javascript.0 because enabled
                                          ! 2017-10-01 22:43:10.592 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 started with pid 24043
                                          ! 2017-10-01 22:43:16.974 - [34mdebug[39m: javascript.0 objectDB connected
                                          ! 2017-10-01 22:43:17.140 - [34mdebug[39m: javascript.0 statesDB connected
                                          ! 2017-10-01 22:43:17.254 - [32minfo[39m: javascript.0 starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                          ! 2017-10-01 22:43:17.287 - [32minfo[39m: javascript.0 requesting all states
                                          ! 2017-10-01 22:43:17.296 - [32minfo[39m: javascript.0 requesting all objects
                                          ! 2017-10-01 22:43:18.332 - [32minfo[39m: javascript.0 received all states
                                          ! 2017-10-01 22:43:19.010 - [32minfo[39m: javascript.0 received all objects
                                          ! 2017-10-01 22:43:19.138 - [32minfo[39m: javascript.0 Start javascript script.js.resol3
                                          ! 2017-10-01 22:43:35.302 - [32minfo[39m: javascript.0 script.js.resol3: schedule(cron=
                                          /20 * * * * )
                                          ! 2017-10-01 22:43:35.305 - [32minfo[39m: javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                          ! 2017-10-01 22:43:35.579 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol val=false, ack=true, ts=1506890599136, q=0, from=system.adapter.javascript.0, lc=1506550059065
                                          ! 2017-10-01 22:43:35.616 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Windfang val=19.875, ack=true, ts=1506890599572, q=0, from=system.adapter.node-red.0, lc=1506890565090
                                          ! 2017-10-01 22:43:35.625 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_WC val=20.062, ack=true, ts=1506890599616, q=0, from=system.adapter.node-red.0, lc=1506890599616
                                          ! 2017-10-01 22:43:35.630 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Gang val=22.312, ack=true, ts=1506890599633, q=0, from=system.adapter.node-red.0, lc=1506890599633
                                          ! 2017-10-01 22:43:35.636 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_HWR val=22.187, ack=true, ts=1506890599643, q=0, from=system.adapter.node-red.0, lc=1506890565146
                                          ! 2017-10-01 22:43:35.643 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Wohnzimmer val=22.187, ack=true, ts=1506890599650, q=0, from=system.adapter.node-red.0, lc=1506890599650
                                          ! 2017-10-01 22:43:35.951 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890615579, q=0, from=system.adapter.admin.2, lc=1506540438557
                                          ! 2017-10-01 22:43:35.955 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890615595, q=0, from=system.adapter.admin.2, lc=1506540438589
                                          ! 2017-10-01 22:43:35.958 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.78, ack=true, ts=1506890615601, q=0, from=system.adapter.admin.2, lc=1506890615601
                                          ! 2017-10-01 22:43:35.997 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890615603, q=0, from=system.adapter.admin.2, lc=1506890465559
                                          ! 2017-10-01 22:43:36.010 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=15.61, ack=true, ts=1506890615606, q=0, from=system.adapter.admin.2, lc=1506890615606
                                          ! 2017-10-01 22:43:36.020 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350186, ack=true, ts=1506890615608, q=0, from=system.adapter.admin.2, lc=1506890615608
                                          ! 2017-10-01 22:43:36.023 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=78, ack=true, ts=1506890615609, q=0, from=system.adapter.admin.2, lc=1506890615609
                                          ! 2017-10-01 22:43:36.027 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890615611, q=0, from=system.adapter.admin.2, lc=1506888484820
                                          ! 2017-10-01 22:43:36.352 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890616340, q=0, from=system.adapter.web.0, lc=1506540396929
                                          ! 2017-10-01 22:43:36.386 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890616347, q=0, from=system.adapter.web.0, lc=1506540396952
                                          ! 2017-10-01 22:43:36.390 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=48.67, ack=true, ts=1506890616349, q=0, from=system.adapter.web.0, lc=1506890616349
                                          ! 2017-10-01 22:43:36.394 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890616351, q=0, from=system.adapter.web.0, lc=1506889640821
                                          ! 2017-10-01 22:43:36.398 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=12.8, ack=true, ts=1506890616354, q=0, from=system.adapter.web.0, lc=1506890616354
                                          ! 2017-10-01 22:43:36.401 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350225, ack=true, ts=1506890616357, q=0, from=system.adapter.web.0, lc=1506890616357
                                          ! 2017-10-01 22:43:36.411 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=78, ack=true, ts=1506890616358, q=0, from=system.adapter.web.0, lc=1506890616358
                                          ! 2017-10-01 22:43:36.414 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890616360, q=0, from=system.adapter.web.0, lc=1506890196064
                                          ! 2017-10-01 22:43:37.182 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890617174, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                          ! 2017-10-01 22:43:37.200 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.26, ack=true, ts=1506890617192, q=0, from=system.host.FroelingRPi, lc=1506890617192
                                          ! 2017-10-01 22:43:37.222 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890617198, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                          ! 2017-10-01 22:43:37.244 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=36.83, ack=true, ts=1506890617232, q=0, from=system.host.FroelingRPi, lc=1506890617232
                                          ! 2017-10-01 22:43:37.260 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890617238, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                          ! 2017-10-01 22:43:37.265 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=9.62, ack=true, ts=1506890617240, q=0, from=system.host.FroelingRPi, lc=1506890617240
                                          ! 2017-10-01 22:43:37.269 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185444, ack=true, ts=1506890617243, q=0, from=system.host.FroelingRPi, lc=1506890617243
                                          ! 2017-10-01 22:43:37.280 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=183, ack=true, ts=1506890617245, q=0, from=system.host.FroelingRPi, lc=1506890557169
                                          ! 2017-10-01 22:43:37.283 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=7, ack=true, ts=1506890617247, q=0, from=system.host.FroelingRPi, lc=1506890602236
                                          ! 2017-10-01 22:43:37.286 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890617249, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                          ! 2017-10-01 22:43:38.222 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890618214, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                          ! 2017-10-01 22:43:38.248 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890618234, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                          ! 2017-10-01 22:43:38.256 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=35.25, ack=true, ts=1506890618242, q=0, from=system.adapter.modbus.1, lc=1506890618242
                                          ! 2017-10-01 22:43:38.262 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=16, ack=true, ts=1506890618248, q=0, from=system.adapter.modbus.1, lc=1506890543157
                                          ! 2017-10-01 22:43:38.268 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=13.3, ack=true, ts=1506890618250, q=0, from=system.adapter.modbus.1, lc=1506890618250
                                          ! 2017-10-01 22:43:38.288 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122693, ack=true, ts=1506890618265, q=0, from=system.adapter.modbus.1, lc=1506890618265
                                          ! 2017-10-01 22:43:38.291 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890618271, q=0, from=system.adapter.modbus.1, lc=1506890483101
                                          ! 2017-10-01 22:43:38.303 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890618274, q=0, from=system.adapter.modbus.1, lc=1506890483103
                                          ! 2017-10-01 22:43:40.293 - [34mdebug[39m: javascript.0 script.js.resol3: CONNECTING
                                          ! 2017-10-01 22:43:40.395 - [31merror[39m: javascript.0 uncaught exception: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                          ! 2017-10-01 22:43:40.396 - [31merror[39m: javascript.0 Error: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                          ! 2017-10-01 22:43:40.534 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 0 (OK)
                                          ! 2017-10-01 22:43:40.535 - [32minfo[39m: host.IObroker Restart adapter system.adapter.javascript.0 because enabled
                                          ! 2017-10-01 22:44:10.569 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 started with pid 24079
                                          ! 2017-10-01 22:44:16.926 - [34mdebug[39m: javascript.0 objectDB connected
                                          ! 2017-10-01 22:44:17.092 - [34mdebug[39m: javascript.0 statesDB connected
                                          ! 2017-10-01 22:44:17.182 - [32minfo[39m: javascript.0 starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                          ! 2017-10-01 22:44:17.206 - [32minfo[39m: javascript.0 requesting all states
                                          ! 2017-10-01 22:44:17.213 - [32minfo[39m: javascript.0 requesting all objects
                                          ! 2017-10-01 22:44:18.483 - [32minfo[39m: javascript.0 received all states
                                          ! 2017-10-01 22:44:19.189 - [32minfo[39m: javascript.0 received all objects
                                          ! 2017-10-01 22:44:19.401 - [32minfo[39m: javascript.0 Start javascript script.js.resol3
                                          ! 2017-10-01 22:44:35.495 - [32minfo[39m: javascript.0 script.js.resol3: schedule(cron=
                                          /20 * * * * )
                                          ! 2017-10-01 22:44:35.498 - [32minfo[39m: javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                          ! 2017-10-01 22:44:35.835 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol val=false, ack=true, ts=1506890659395, q=0, from=system.adapter.javascript.0, lc=1506550059065
                                          ! 2017-10-01 22:44:36.238 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890675601, q=0, from=system.adapter.admin.2, lc=1506540438557
                                          ! 2017-10-01 22:44:36.241 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890675612, q=0, from=system.adapter.admin.2, lc=1506540438589
                                          ! 2017-10-01 22:44:36.244 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.28, ack=true, ts=1506890675630, q=0, from=system.adapter.admin.2, lc=1506890675630
                                          ! 2017-10-01 22:44:36.263 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890675636, q=0, from=system.adapter.admin.2, lc=1506890465559
                                          ! 2017-10-01 22:44:36.279 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=14.94, ack=true, ts=1506890675639, q=0, from=system.adapter.admin.2, lc=1506890675639
                                          ! 2017-10-01 22:44:36.295 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350246, ack=true, ts=1506890675642, q=0, from=system.adapter.admin.2, lc=1506890675642
                                          ! 2017-10-01 22:44:36.299 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=83, ack=true, ts=1506890675644, q=0, from=system.adapter.admin.2, lc=1506890660629
                                          ! 2017-10-01 22:44:36.307 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890675647, q=0, from=system.adapter.admin.2, lc=1506888484820
                                          ! 2017-10-01 22:44:36.311 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890676214, q=0, from=system.adapter.web.0, lc=1506540396929
                                          ! 2017-10-01 22:44:36.314 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890676226, q=0, from=system.adapter.web.0, lc=1506540396952
                                          ! 2017-10-01 22:44:36.317 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=48.93, ack=true, ts=1506890676228, q=0, from=system.adapter.web.0, lc=1506890676228
                                          ! 2017-10-01 22:44:36.319 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890676230, q=0, from=system.adapter.web.0, lc=1506889640821
                                          ! 2017-10-01 22:44:36.321 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=13.08, ack=true, ts=1506890676232, q=0, from=system.adapter.web.0, lc=1506890676232
                                          ! 2017-10-01 22:44:36.324 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350285, ack=true, ts=1506890676235, q=0, from=system.adapter.web.0, lc=1506890676235
                                          ! 2017-10-01 22:44:36.326 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=83, ack=true, ts=1506890676236, q=0, from=system.adapter.web.0, lc=1506890676236
                                          ! 2017-10-01 22:44:36.328 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890676238, q=0, from=system.adapter.web.0, lc=1506890196064
                                          ! 2017-10-01 22:44:37.256 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890677235, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                          ! 2017-10-01 22:44:37.282 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.09, ack=true, ts=1506890677249, q=0, from=system.host.FroelingRPi, lc=1506890677249
                                          ! 2017-10-01 22:44:37.312 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890677258, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                          ! 2017-10-01 22:44:37.316 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=37.16, ack=true, ts=1506890677264, q=0, from=system.host.FroelingRPi, lc=1506890677264
                                          ! 2017-10-01 22:44:37.319 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890677267, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                          ! 2017-10-01 22:44:37.323 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=9.95, ack=true, ts=1506890677280, q=0, from=system.host.FroelingRPi, lc=1506890677280
                                          ! 2017-10-01 22:44:37.328 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185504, ack=true, ts=1506890677287, q=0, from=system.host.FroelingRPi, lc=1506890677287
                                          ! 2017-10-01 22:44:37.339 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=183, ack=true, ts=1506890677293, q=0, from=system.host.FroelingRPi, lc=1506890557169
                                          ! 2017-10-01 22:44:37.342 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=7, ack=true, ts=1506890677295, q=0, from=system.host.FroelingRPi, lc=1506890662299
                                          ! 2017-10-01 22:44:37.346 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890677298, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                          ! 2017-10-01 22:44:38.302 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890678294, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                          ! 2017-10-01 22:44:38.330 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890678316, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                          ! 2017-10-01 22:44:38.338 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=35.79, ack=true, ts=1506890678322, q=0, from=system.adapter.modbus.1, lc=1506890678322
                                          ! 2017-10-01 22:44:38.351 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=17, ack=true, ts=1506890678339, q=0, from=system.adapter.modbus.1, lc=1506890663307
                                          ! 2017-10-01 22:44:38.367 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=13.8, ack=true, ts=1506890678345, q=0, from=system.adapter.modbus.1, lc=1506890678345
                                          ! 2017-10-01 22:44:38.386 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122753, ack=true, ts=1506890678348, q=0, from=system.adapter.modbus.1, lc=1506890678348
                                          ! 2017-10-01 22:44:38.390 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890678350, q=0, from=system.adapter.modbus.1, lc=1506890483101
                                          ! 2017-10-01 22:44:38.413 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890678353, q=0, from=system.adapter.modbus.1, lc=1506890483103
                                          ! 2017-10-01 22:44:40.485 - [34mdebug[39m: javascript.0 script.js.resol3: CONNECTING
                                          ! 2017-10-01 22:44:40.586 - [31merror[39m: javascript.0 uncaught exception: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                          ! 2017-10-01 22:44:40.587 - [31merror[39m: javascript.0 Error: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                          ! 2017-10-01 22:44:40.635 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.alive val=false, ack=true, ts=1506890680593, q=0, from=system.adapter.javascript.0, lc=1506890680593
                                          ! 2017-10-01 22:44:40.795 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 0 (OK)
                                          ! 2017-10-01 22:44:40.797 - [32minfo[39m: host.IObroker Restart adapter system.adapter.javascript.0 because enabled
                                          ! 2017-10-01 22:45:10.842 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 started with pid 24114
                                          ! 2017-10-01 22:45:16.574 - [34mdebug[39m: javascript.0 objectDB connected
                                          ! 2017-10-01 22:45:16.739 - [34mdebug[39m: javascript.0 statesDB connected
                                          ! 2017-10-01 22:45:16.855 - [32minfo[39m: javascript.0 starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                          ! 2017-10-01 22:45:16.890 - [32minfo[39m: javascript.0 requesting all states
                                          ! 2017-10-01 22:45:16.899 - [32minfo[39m: javascript.0 requesting all objects
                                          ! 2017-10-01 22:45:18.281 - [32minfo[39m: javascript.0 received all states
                                          ! 2017-10-01 22:45:18.980 - [32minfo[39m: javascript.0 received all objects
                                          ! 2017-10-01 22:45:19.125 - [32minfo[39m: javascript.0 Start javascript script.js.resol3
                                          ! 2017-10-01 22:45:34.919 - [32minfo[39m: javascript.0 script.js.resol3: schedule(cron=
                                          /20 * * * * )
                                          ! 2017-10-01 22:45:34.922 - [32minfo[39m: javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                          ! 2017-10-01 22:45:35.226 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol val=false, ack=true, ts=1506890719123, q=0, from=system.adapter.javascript.0, lc=1506550059065
                                          ! 2017-10-01 22:45:35.760 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890735750, q=0, from=system.adapter.admin.2, lc=1506540438557
                                          ! 2017-10-01 22:45:35.786 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890735758, q=0, from=system.adapter.admin.2, lc=1506540438589
                                          ! 2017-10-01 22:45:35.791 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.29, ack=true, ts=1506890735760, q=0, from=system.adapter.admin.2, lc=1506890735760
                                          ! 2017-10-01 22:45:35.795 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890735762, q=0, from=system.adapter.admin.2, lc=1506890465559
                                          ! 2017-10-01 22:45:35.800 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=15.09, ack=true, ts=1506890735766, q=0, from=system.adapter.admin.2, lc=1506890735766
                                          ! 2017-10-01 22:45:35.815 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350306, ack=true, ts=1506890735768, q=0, from=system.adapter.admin.2, lc=1506890735768
                                          ! 2017-10-01 22:45:35.830 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=88, ack=true, ts=1506890735769, q=0, from=system.adapter.admin.2, lc=1506890735769
                                          ! 2017-10-01 22:45:35.850 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890735771, q=0, from=system.adapter.admin.2, lc=1506888484820
                                          ! 2017-10-01 22:45:36.238 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890736229, q=0, from=system.adapter.web.0, lc=1506540396929
                                          ! 2017-10-01 22:45:36.258 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890736236, q=0, from=system.adapter.web.0, lc=1506540396952
                                          ! 2017-10-01 22:45:36.263 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=49.18, ack=true, ts=1506890736238, q=0, from=system.adapter.web.0, lc=1506890736238
                                          ! 2017-10-01 22:45:36.267 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890736241, q=0, from=system.adapter.web.0, lc=1506889640821
                                          ! 2017-10-01 22:45:36.272 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=13.32, ack=true, ts=1506890736243, q=0, from=system.adapter.web.0, lc=1506890736243
                                          ! 2017-10-01 22:45:36.276 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350345, ack=true, ts=1506890736245, q=0, from=system.adapter.web.0, lc=1506890736245
                                          ! 2017-10-01 22:45:36.279 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=78, ack=true, ts=1506890736246, q=0, from=system.adapter.web.0, lc=1506890736246
                                          ! 2017-10-01 22:45:36.283 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890736262, q=0, from=system.adapter.web.0, lc=1506890196064
                                          ! 2017-10-01 22:45:37.303 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890737296, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                          ! 2017-10-01 22:45:37.332 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.03, ack=true, ts=1506890737314, q=0, from=system.host.FroelingRPi, lc=1506890737314
                                          ! 2017-10-01 22:45:37.353 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890737346, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                          ! 2017-10-01 22:45:37.384 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=37.5, ack=true, ts=1506890737351, q=0, from=system.host.FroelingRPi, lc=1506890737351
                                          ! 2017-10-01 22:45:37.389 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890737354, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                          ! 2017-10-01 22:45:37.393 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=10.29, ack=true, ts=1506890737358, q=0, from=system.host.FroelingRPi, lc=1506890737358
                                          ! 2017-10-01 22:45:37.397 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185564, ack=true, ts=1506890737360, q=0, from=system.host.FroelingRPi, lc=1506890737360
                                          ! 2017-10-01 22:45:37.401 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=182, ack=true, ts=1506890737388, q=0, from=system.host.FroelingRPi, lc=1506890692322
                                          ! 2017-10-01 22:45:37.427 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=7, ack=true, ts=1506890737413, q=0, from=system.host.FroelingRPi, lc=1506890722332
                                          ! 2017-10-01 22:45:37.430 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890737415, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                          ! 2017-10-01 22:45:37.460 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Windfang val=19.875, ack=true, ts=1506890737453, q=0, from=system.adapter.node-red.0, lc=1506890565090
                                          ! 2017-10-01 22:45:37.480 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_WC val=20, ack=true, ts=1506890737467, q=0, from=system.adapter.node-red.0, lc=1506890634012
                                          ! 2017-10-01 22:45:37.663 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Gang val=22.312, ack=true, ts=1506890737642, q=0, from=system.adapter.node-red.0, lc=1506890599633
                                          ! 2017-10-01 22:45:37.670 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_HWR val=22.25, ack=true, ts=1506890737659, q=0, from=system.adapter.node-red.0, lc=1506890703116
                                          ! 2017-10-01 22:45:37.678 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Wohnzimmer val=22.187, ack=true, ts=1506890737667, q=0, from=system.adapter.node-red.0, lc=1506890737667
                                          ! 2017-10-01 22:45:38.377 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890738368, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                          ! 2017-10-01 22:45:38.394 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890738385, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                          ! 2017-10-01 22:45:38.404 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=36.28, ack=true, ts=1506890738396, q=0, from=system.adapter.modbus.1, lc=1506890738396
                                          ! 2017-10-01 22:45:38.412 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=17, ack=true, ts=1506890738402, q=0, from=system.adapter.modbus.1, lc=1506890663307
                                          ! 2017-10-01 22:45:38.424 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=14.29, ack=true, ts=1506890738416, q=0, from=system.adapter.modbus.1, lc=1506890738416
                                          ! 2017-10-01 22:45:38.446 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122813, ack=true, ts=1506890738421, q=0, from=system.adapter.modbus.1, lc=1506890738421
                                          ! 2017-10-01 22:45:38.450 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890738424, q=0, from=system.adapter.modbus.1, lc=1506890483101
                                          ! 2017-10-01 22:45:38.457 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890738427, q=0, from=system.adapter.modbus.1, lc=1506890483103
                                          ! 2017-10-01 22:45:40.897 - [34mdebug[39m: javascript.0 script.js.resol3: CONNECTING
                                          ! 2017-10-01 22:45:40.997 - [31merror[39m: javascript.0 uncaught exception: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                          ! 2017-10-01 22:45:40.998 - [31merror[39m: javascript.0 Error: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                          ! 2017-10-01 22:45:41.176 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 0 (OK)
                                          ! 2017-10-01 22:45:41.179 - [32minfo[39m: host.IObroker Restart adapter system.adapter.javascript.0 because enabled
                                          ! 2017-10-01 22:46:11.222 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 started with pid 24136
                                          ! 2017-10-01 22:46:17.398 - [34mdebug[39m: javascript.0 objectDB connected
                                          ! 2017-10-01 22:46:17.572 - [34mdebug[39m: javascript.0 statesDB connected
                                          ! 2017-10-01 22:46:17.692 - [32minfo[39m: javascript.0 starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                          ! 2017-10-01 22:46:17.735 - [32minfo[39m: javascript.0 requesting all states
                                          ! 2017-10-01 22:46:17.744 - [32minfo[39m: javascript.0 requesting all objects
                                          ! 2017-10-01 22:46:18.757 - [32minfo[39m: javascript.0 received all states
                                          ! 2017-10-01 22:46:19.479 - [32minfo[39m: javascript.0 received all objects
                                          ! 2017-10-01 22:46:19.621 - [32minfo[39m: javascript.0 Start javascript script.js.resol3
                                          ! 2017-10-01 22:46:35.431 - [32minfo[39m: javascript.0 script.js.resol3: schedule(cron=
                                          /20 * * * * *)
                                          ! 2017-10-01 22:46:35.435 - [32minfo[39m: javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                          ! 2017-10-01 22:46:35.741 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol val=false, ack=true, ts=1506890779619, q=0, from=system.adapter.javascript.0, lc=1506550059065
                                          ! 2017-10-01 22:46:35.773 - [34mdebug[39m: javascript.0 inMem message * modbus.1.inputRegisters.30001_Kessel val=62, ack=true, ts=1506890779652, q=0, from=system.adapter.modbus.1, lc=1506890779652
                                          ! 2017-10-01 22:46:36.066 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890795682, q=0, from=system.adapter.admin.2, lc=1506540438557
                                          ! 2017-10-01 22:46:36.085 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890795696, q=0, from=system.adapter.admin.2, lc=1506540438589
                                          ! 2017-10-01 22:46:36.089 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.61, ack=true, ts=1506890795721, q=0, from=system.adapter.admin.2, lc=1506890795721
                                          ! 2017-10-01 22:46:36.092 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890795722, q=0, from=system.adapter.admin.2, lc=1506890465559
                                          ! 2017-10-01 22:46:36.097 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=15.37, ack=true, ts=1506890795724, q=0, from=system.adapter.admin.2, lc=1506890795724
                                          ! 2017-10-01 22:46:36.100 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350366, ack=true, ts=1506890795726, q=0, from=system.adapter.admin.2, lc=1506890795726
                                          ! 2017-10-01 22:46:36.103 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=79, ack=true, ts=1506890795728, q=0, from=system.adapter.admin.2, lc=1506890795728
                                          ! 2017-10-01 22:46:36.133 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890795742, q=0, from=system.adapter.admin.2, lc=1506888484820
                                          ! 2017-10-01 22:46:36.383 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890796370, q=0, from=system.adapter.web.0, lc=1506540396929
                                          ! 2017-10-01 22:46:36.407 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890796378, q=0, from=system.adapter.web.0, lc=1506540396952
                                          ! 2017-10-01 22:46:36.422 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=48.68, ack=true, ts=1506890796380, q=0, from=system.adapter.web.0, lc=1506890796380
                                          ! 2017-10-01 22:46:36.427 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890796383, q=0, from=system.adapter.web.0, lc=1506889640821
                                          ! 2017-10-01 22:46:36.431 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=12.69, ack=true, ts=1506890796385, q=0, from=system.adapter.web.0, lc=1506890796385
                                          ! 2017-10-01 22:46:36.435 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350405, ack=true, ts=1506890796387, q=0, from=system.adapter.web.0, lc=1506890796387
                                          ! 2017-10-01 22:46:36.439 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=78, ack=true, ts=1506890796388, q=0, from=system.adapter.web.0, lc=1506890796388
                                          ! 2017-10-01 22:46:36.442 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890796390, q=0, from=system.adapter.web.0, lc=1506890196064
                                          ! 2017-10-01 22:46:37.368 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890797361, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                          ! 2017-10-01 22:46:37.389 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.09, ack=true, ts=1506890797375, q=0, from=system.host.FroelingRPi, lc=1506890797375
                                          ! 2017-10-01 22:46:37.405 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890797388, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                          ! 2017-10-01 22:46:37.446 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=36.88, ack=true, ts=1506890797399, q=0, from=system.host.FroelingRPi, lc=1506890797399
                                          ! 2017-10-01 22:46:37.451 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890797402, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                          ! 2017-10-01 22:46:37.472 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=9.67, ack=true, ts=1506890797426, q=0, from=system.host.FroelingRPi, lc=1506890797426
                                          ! 2017-10-01 22:46:37.477 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185625, ack=true, ts=1506890797431, q=0, from=system.host.FroelingRPi, lc=1506890797431
                                          ! 2017-10-01 22:46:37.481 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=182, ack=true, ts=1506890797434, q=0, from=system.host.FroelingRPi, lc=1506890782413
                                          ! 2017-10-01 22:46:37.484 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=7, ack=true, ts=1506890797447, q=0, from=system.host.FroelingRPi, lc=1506890782423
                                          ! 2017-10-01 22:46:37.487 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890797449, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                          ! 2017-10-01 22:46:38.454 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890798445, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                          ! 2017-10-01 22:46:38.473 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890798465, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                          ! 2017-10-01 22:46:38.484 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=36.87, ack=true, ts=1506890798474, q=0, from=system.adapter.modbus.1, lc=1506890798474
                                          ! 2017-10-01 22:46:38.500 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=18, ack=true, ts=1506890798481, q=0, from=system.adapter.modbus.1, lc=1506890768437
                                          ! 2017-10-01 22:46:38.505 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=14.84, ack=true, ts=1506890798484, q=0, from=system.adapter.modbus.1, lc=1506890798484
                                          ! 2017-10-01 22:46:38.522 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122873, ack=true, ts=1506890798505, q=0, from=system.adapter.modbus.1, lc=1506890798505
                                          ! 2017-10-01 22:46:38.532 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890798511, q=0, from=system.adapter.modbus.1, lc=1506890798511
                                          ! 2017-10-01 22:46:38.538 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890798514, q=0, from=system.adapter.modbus.1, lc=1506890798514
                                          ! 2017-10-01 22:46:40.411 - [34mdebug[39m: javascript.0 script.js.resol3: CONNECTING
                                          ! 2017-10-01 22:46:40.544 - [31merror[39m: javascript.0 uncaught exception: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                          ! 2017-10-01 22:46:40.546 - [31merror[39m: javascript.0 Error: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                          ! 2017-10-01 22:46:40.653 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 0 (OK)
                                          ! 2017-10-01 22:46:40.655 - [32minfo[39m: host.IObroker Restart adapter system.adapter.javascript.0 because enabled
                                          ! 2017-10-01 22:46:46.069 - [32minfo[39m: host.IObroker object change system.adapter.javascript.0
                                          ! 2017-10-01 22:47:16.626 - [34mdebug[39m: javascript.0 objectDB connected
                                          ! 2017-10-01 22:47:16.762 - [34mdebug[39m: javascript.0 statesDB connected
                                          ! 2017-10-01 22:47:16.865 - [31merror[39m: javascript.0 adapter disabled
                                          ! 2017-10-01 22:47:16.953 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 3 (Adapter disabled or invalid config)
                                          ! 2017-10-01 22:47:16.954 - [32minfo[39m: host.IObroker Do not restart adapter system.adapter.javascript.0 because disabled or deleted[/spoiler]
                                          • Dutchman
                                            @RS_Tobi:
                                            habe ihn jetzt auf debug…
                                            zur timeline...
                                            erstt javascript adapter gestartet, dann etwas gewartet und danach den skript gestartet.
                                            dann alles für einige Zeit laufen lassen.
                                            tobi
                                            p.s. da log zulange, habe ich passagen mit . . . . gekennzeichnet und herausgeschnitten.
                                            ! 2017-10-01 22:40:01.779 - [32minfo[39m: host.IObroker object change system.adapter.javascript.0
                                            ! 2017-10-01 22:40:01.827 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 started with pid 23973
                                            ! 2017-10-01 22:40:09.007 - [34mdebug[39m: javascript.0 objectDB connected
                                            ! 2017-10-01 22:40:09.176 - [34mdebug[39m: javascript.0 statesDB connected
                                            ! 2017-10-01 22:40:09.289 - [32minfo[39m: javascript.0 starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                            ! 2017-10-01 22:40:09.322 - [32minfo[39m: javascript.0 requesting all states
                                            ! 2017-10-01 22:40:09.331 - [32minfo[39m: javascript.0 requesting all objects
                                            ! 2017-10-01 22:40:10.343 - [32minfo[39m: javascript.0 received all states
                                            ! 2017-10-01 22:40:10.999 - [32minfo[39m: javascript.0 received all objects
                                            ! 2017-10-01 22:40:11.147 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol val=false, ack=true, ts=1506890411134, q=0, from=system.adapter.javascript.0, lc=1506550059065
                                            ! 2017-10-01 22:40:11.181 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol2 val=false, ack=true, ts=1506890411144, q=0, from=system.adapter.javascript.0, lc=1506550016921
                                            ! 2017-10-01 22:40:11.190 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol3 val=false, ack=true, ts=1506890411150, q=0, from=system.adapter.javascript.0, lc=1506890411150
                                            ! 2017-10-01 22:40:12.327 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.alive val=true, ack=true, ts=1506890412319, q=0, from=system.host.IObroker, lc=1506539950508
                                            ! 2017-10-01 22:40:12.365 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.load val=0.09, ack=true, ts=1506890412325, q=0, from=system.host.IObroker, lc=1506890412325
                                            ! 2017-10-01 22:40:12.371 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.mem val=15, ack=true, ts=1506890412327, q=0, from=system.host.IObroker, lc=1506890412327
                                            ! 2017-10-01 22:40:12.379 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memRss val=101.24, ack=true, ts=1506890412330, q=0, from=system.host.IObroker, lc=1506890412330
                                            ! 2017-10-01 22:40:12.385 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memHeapTotal val=37.66, ack=true, ts=1506890412335, q=0, from=system.host.IObroker, lc=1506890412335
                                            ! 2017-10-01 22:40:12.390 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memHeapUsed val=25.74, ack=true, ts=1506890412338, q=0, from=system.host.IObroker, lc=1506890412338
                                            ! 2017-10-01 22:40:12.404 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.uptime val=352278, ack=true, ts=1506890412340, q=0, from=system.host.IObroker, lc=1506890412340
                                            ! 2017-10-01 22:40:12.413 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.freemem val=138, ack=true, ts=1506890412342, q=0, from=system.host.IObroker, lc=1506890412342
                                            ! 2017-10-01 22:40:12.421 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.inputCount val=8, ack=true, ts=1506890412344, q=0, from=system.host.IObroker, lc=1506890412344
                                            ! 2017-10-01 22:40:12.426 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.outputCount val=10, ack=true, ts=1506890412346, q=0, from=system.host.IObroker, lc=1506889420760
                                            ! 2017-10-01 22:40:13.981 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.alive val=true, ack=true, ts=1506890413967, q=0, from=system.adapter.tr-064.0, lc=1506540436438
                                            ! 2017-10-01 22:40:13.998 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.connected val=true, ack=true, ts=1506890413986, q=0, from=system.adapter.tr-064.0, lc=1506540436444
                                            ! 2017-10-01 22:40:14.029 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memRss val=35.62, ack=true, ts=1506890413996, q=0, from=system.adapter.tr-064.0, lc=1506890413996
                                            ! 2017-10-01 22:40:14.034 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memHeapTotal val=19, ack=true, ts=1506890413998, q=0, from=system.adapter.tr-064.0, lc=1506890293908
                                            ! 2017-10-01 22:40:14.038 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memHeapUsed val=14.15, ack=true, ts=1506890414001, q=0, from=system.adapter.tr-064.0, lc=1506890414001
                                            ! 2017-10-01 22:40:14.042 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.uptime val=349986, ack=true, ts=1506890414004, q=0, from=system.adapter.tr-064.0, lc=1506890414004
                                            ! 2017-10-01 22:40:14.046 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.inputCount val=0, ack=true, ts=1506890414006, q=0, from=system.adapter.tr-064.0, lc=1506540556560
                                            ! 2017-10-01 22:40:14.052 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.outputCount val=8, ack=true, ts=1506890414008, q=0, from=system.adapter.tr-064.0, lc=1506538226478
                                            ! 2017-10-01 22:40:14.082 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.alive val=true, ack=true, ts=1506890414060, q=0, from=system.adapter.node-red.0, lc=1506540433921
                                            ! 2017-10-01 22:40:14.114 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.connected val=true, ack=true, ts=1506890414076, q=0, from=system.adapter.node-red.0, lc=1506540433928
                                            ! 2017-10-01 22:40:14.122 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memRss val=27.73, ack=true, ts=1506890414079, q=0, from=system.adapter.node-red.0, lc=1506890369020
                                            ! 2017-10-01 22:40:14.127 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memHeapTotal val=12, ack=true, ts=1506890414082, q=0, from=system.adapter.node-red.0, lc=1506542610355
                                            ! 2017-10-01 22:40:14.131 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memHeapUsed val=8.56, ack=true, ts=1506890414085, q=0, from=system.adapter.node-red.0, lc=1506890414085
                                            ! 2017-10-01 22:40:14.135 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.uptime val=349985, ack=true, ts=1506890414087, q=0, from=system.adapter.node-red.0, lc=1506890414087
                                            ! 2017-10-01 22:40:14.141 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.inputCount val=0, ack=true, ts=1506890414089, q=0, from=system.adapter.node-red.0, lc=1506540553967
                                            ! 2017-10-01 22:40:14.146 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.outputCount val=8, ack=true, ts=1506890414091, q=0, from=system.adapter.node-red.0, lc=1500588052060
                                            ! 2017-10-01 22:40:17.405 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.alive val=true, ack=true, ts=1506890417395, q=0, from=system.adapter.discovery.0, lc=1506538148270
                                            ! 2017-10-01 22:40:17.435 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.connected val=true, ack=true, ts=1506890417408, q=0, from=system.adapter.discovery.0, lc=1506538148279
                                            ! 2017-10-01 22:40:17.442 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memRss val=27.55, ack=true, ts=1506890417410, q=0, from=system.adapter.discovery.0, lc=1506890357338
                                            ! 2017-10-01 22:40:17.447 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memHeapTotal val=12, ack=true, ts=1506890417412, q=0, from=system.adapter.discovery.0, lc=1506539799771
                                            ! 2017-10-01 22:40:17.451 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memHeapUsed val=8.37, ack=true, ts=1506890417415, q=0, from=system.adapter.discovery.0, lc=1506890417415
                                            ! 2017-10-01 22:40:17.455 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.uptime val=352274, ack=true, ts=1506890417417, q=0, from=system.adapter.discovery.0, lc=1506890417417
                                            ! 2017-10-01 22:40:17.459 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.inputCount val=0, ack=true, ts=1506890417419, q=0, from=system.adapter.discovery.0, lc=1506540550376
                                            ! 2017-10-01 22:40:17.463 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.outputCount val=8, ack=true, ts=1506890417421, q=0, from=system.adapter.discovery.0, lc=1506538178377
                                            ! 2017-10-01 22:42:05.559 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890525549, q=0, from=system.adapter.admin.2, lc=1506540438557
                                            ! 2017-10-01 22:42:05.625 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890525563, q=0, from=system.adapter.admin.2, lc=1506540438589
                                            ! 2017-10-01 22:42:05.628 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.96, ack=true, ts=1506890525568, q=0, from=system.adapter.admin.2, lc=1506890525568
                                            ! 2017-10-01 22:42:05.630 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890525571, q=0, from=system.adapter.admin.2, lc=1506890465559
                                            ! 2017-10-01 22:42:05.632 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=15.67, ack=true, ts=1506890525573, q=0, from=system.adapter.admin.2, lc=1506890525573
                                            ! 2017-10-01 22:42:05.635 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350096, ack=true, ts=1506890525575, q=0, from=system.adapter.admin.2, lc=1506890525575
                                            ! 2017-10-01 22:42:05.639 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=152, ack=true, ts=1506890525577, q=0, from=system.adapter.admin.2, lc=1506890525577
                                            ! 2017-10-01 22:42:05.641 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890525578, q=0, from=system.adapter.admin.2, lc=1506888484820
                                            ! 2017-10-01 22:42:06.151 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890526140, q=0, from=system.adapter.web.0, lc=1506540396929
                                            ! 2017-10-01 22:42:06.161 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890526153, q=0, from=system.adapter.web.0, lc=1506540396952
                                            ! 2017-10-01 22:42:06.186 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=49.18, ack=true, ts=1506890526158, q=0, from=system.adapter.web.0, lc=1506890526158
                                            ! 2017-10-01 22:42:06.189 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890526160, q=0, from=system.adapter.web.0, lc=1506889640821
                                            ! 2017-10-01 22:42:06.192 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=13.2, ack=true, ts=1506890526161, q=0, from=system.adapter.web.0, lc=1506890526161
                                            ! 2017-10-01 22:42:06.195 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350135, ack=true, ts=1506890526163, q=0, from=system.adapter.web.0, lc=1506890526163
                                            ! 2017-10-01 22:42:06.197 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=76, ack=true, ts=1506890526165, q=0, from=system.adapter.web.0, lc=1506890511159
                                            ! 2017-10-01 22:42:06.200 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890526166, q=0, from=system.adapter.web.0, lc=1506890196064
                                            ! 2017-10-01 22:42:06.234 - [34mdebug[39m: javascript.0 inMem message * script.js.resol3 name=resol3, engineType=Javascript/js, source=//******************************************
                                            ! //Dutchman & meifi2017
                                            ! //V 0.8
                                            ! // define variable
                                            ! var vbus = require('resol-vbus');
                                            ! var headerSet = new vbus.HeaderSet();
                                            ! var conn;
                                            ! var create_states = true; // !!! set initial on true to create states once, disable value afterwards to update states !!
                                            ! // Schedule every 20 seconds
                                            ! schedule("/20 * * * * ", function () {
                                            ! // Define connection values
                                            ! conn = new vbus.TcpConnection({
                                            ! host: '192.168.178.110', // Can be used with via.vbus.net OR internal 192xxxxx adress !
                                            ! viaTag: 'xxxxx', // only necessary if connected using VBus.net otherwise leave empty
                                            ! password: 'vbus',
                                            ! // channel: 1, // only necessary if connected to a DL3
                                            ! // Log connection status
                                            ! var onConnectionStateChange = function(state) {
                                            ! console.debug(state);
                                            ! var onPacket = function(packet) {
                                            ! headerSet.addHeader(packet);
                                            ! conn.on('connectionState', onConnectionStateChange);
                                            ! conn.on('packet', onPacket);
                                            ! conn.connect().done(function() {
                                            ! setTimeout(function() {
                                            ! conn.disconnect();
                                            ! //create header packages
                                            ! var packets = headerSet.getSortedHeaders();
                                            ! var spec = vbus.Specification.getDefaultSpecification();
                                            ! var packetFields = spec.getPacketFieldsForHeaders(packets);
                                            ! var packet = null;
                                            ! var counter = 0;
                                            ! packetFields.forEach(function(packetField) {
                                            ! counter = counter + 1;
                                            ! if (packet !== packetField.packet) {
                                            ! packet = packetField.packet;
                                            ! console.debug(packetField.packetSpec.fullName);
                                            ! // write values in memory
                                            ! packetField.name = packetField.name.replace(/ /g,"");
                                            ! console.debug("Value received : " + packetField.name + " = " + packetField.formatTextValue());
                                            ! rawvalue = packetField.formatTextValue();
                                            ! rawvalue = rawvalue.replace(/[^0-9.,]/g,"");
                                            ! console.debug("Value translated to raw format : " + rawvalue);
                                            ! // Create new objects only if "var create_states = true"
                                            ! if (create_states === true){
                                            ! // create objects real data
                                            ! createState("vbus.values." + packetField.name ,{
                                            ! name: packetField.name,
                                            ! type: 'string',
                                            ! role: 'value'
                                            ! // create objects raw data only
                                            ! createState("vbus.values_raw." + packetField.name ,{
                                            ! name: packetField.name + "_raw",
                                            ! type: 'string',
                                            ! role: 'value'
                                            ! } else {
                                            ! // Update values
                                            ! setState("vbus.values." + packetField.name , packetField.formatTextValue(), true);
                                            ! setState("vbus.values_raw." + packetField.name , rawvalue, true);
                                            ! console.warn("States created change var create_states to False !!!");
                                            ! // 10 second timer, collection all information takes some seconds [emoji6]
                                            ! }, 10000);
                                            ! });, enabled=false, engine=system.adapter.javascript.0, debug=true, verbose=true, type=script, _id=script.js.resol3
                                            ! 2017-10-01 22:42:06.255 - [32minfo[39m: javascript.0 Stop script script.js.resol3
                                            ! 2017-10-01 22:42:06.274 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol3 val=false, ack=true, ts=1506890526262, q=0, from=system.adapter.javascript.0, lc=1506890411150
                                            ! 2017-10-01 22:42:06.311 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol3 val=false, ack=true, ts=1506890526303, q=0, from=system.adapter.javascript.0, lc=1506890411150
                                            ! 2017-10-01 22:42:06.377 - [34mdebug[39m: javascript.0 inMem message * script.js.resol3 name=resol3, engineType=Javascript/js, source=//
                                            ! //V 0.8
                                            ! var conn;
                                            ! schedule("*/20 * * * * ", function () {
                                            ! password: 'vbus',
                                            ! var counter = 0;
                                            ! type: 'string',
                                            ! role: 'value'
                                            ! type: 'string',
                                            ! role: 'value'
                                            ! } else {
                                            ! // Update values
                                            ! }, 10000);
                                            ! });, enabled=true, engine=system.adapter.javascript.0, debug=true, verbose=true, type=script, _id=script.js.resol3
                                            ! 2017-10-01 22:42:06.404 - [32minfo[39m: javascript.0 Start javascript script.js.resol3
                                            ! 2017-10-01 22:42:24.291 - [32minfo[39m: javascript.0 script.js.resol3: schedule(cron=
                                            /20 * * * * )
                                            ! 2017-10-01 22:42:24.294 - [32minfo[39m: javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                            ! 2017-10-01 22:42:24.331 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol3 val=true, ack=true, ts=1506890526402, q=0, from=system.adapter.javascript.0, lc=1506890526402
                                            ! 2017-10-01 22:42:24.339 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890527078, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                            ! 2017-10-01 22:42:24.342 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.05, ack=true, ts=1506890527097, q=0, from=system.host.FroelingRPi, lc=1506890527097
                                            ! 2017-10-01 22:42:24.346 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890527106, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                            ! 2017-10-01 22:42:24.349 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=37.27, ack=true, ts=1506890527112, q=0, from=system.host.FroelingRPi, lc=1506890527112
                                            ! 2017-10-01 22:42:24.352 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890527122, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                            ! 2017-10-01 22:42:24.357 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=10.06, ack=true, ts=1506890527128, q=0, from=system.host.FroelingRPi, lc=1506890527128
                                            ! 2017-10-01 22:42:24.361 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185354, ack=true, ts=1506890527131, q=0, from=system.host.FroelingRPi, lc=1506890527131
                                            ! 2017-10-01 22:42:24.365 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=184, ack=true, ts=1506890527133, q=0, from=system.host.FroelingRPi, lc=1506890482091
                                            ! 2017-10-01 22:42:24.369 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=7, ack=true, ts=1506890527147, q=0, from=system.host.FroelingRPi, lc=1506890422054
                                            ! 2017-10-01 22:42:24.372 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890527152, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                            ! 2017-10-01 22:42:24.376 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890528107, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                            ! 2017-10-01 22:42:24.382 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890528124, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                            ! 2017-10-01 22:42:24.385 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=34.39, ack=true, ts=1506890528131, q=0, from=system.adapter.modbus.1, lc=1506890528131
                                            ! 2017-10-01 22:42:24.387 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=15, ack=true, ts=1506890528149, q=0, from=system.adapter.modbus.1, lc=1506890453039
                                            ! 2017-10-01 22:42:24.396 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=12.51, ack=true, ts=1506890528164, q=0, from=system.adapter.modbus.1, lc=1506890528164
                                            ! 2017-10-01 22:42:24.400 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122603, ack=true, ts=1506890528166, q=0, from=system.adapter.modbus.1, lc=1506890528166
                                            ! 2017-10-01 22:42:24.403 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890528168, q=0, from=system.adapter.modbus.1, lc=1506890483101
                                            ! 2017-10-01 22:42:24.416 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890528169, q=0, from=system.adapter.modbus.1, lc=1506890483103
                                            ! 2017-10-01 22:42:24.419 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Windfang val=19.937, ack=true, ts=1506890530611, q=0, from=system.adapter.node-red.0, lc=1506890426450
                                            ! 2017-10-01 22:42:24.426 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_WC val=20.062, ack=true, ts=1506890530651, q=0, from=system.adapter.node-red.0, lc=1506890426495
                                            ! 2017-10-01 22:42:24.429 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Gang val=22.312, ack=true, ts=1506890530684, q=0, from=system.adapter.node-red.0, lc=1506890495410
                                            ! 2017-10-01 22:42:24.432 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_HWR val=22.25, ack=true, ts=1506890530690, q=0, from=system.adapter.node-red.0, lc=1506890530690
                                            ! 2017-10-01 22:42:24.434 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Wohnzimmer val=22.187, ack=true, ts=1506890530692, q=0, from=system.adapter.node-red.0, lc=1506890495631
                                            ! 2017-10-01 22:42:24.437 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.alive val=true, ack=true, ts=1506890532525, q=0, from=system.host.IObroker, lc=1506539950508
                                            ! 2017-10-01 22:42:24.439 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.load val=0.2, ack=true, ts=1506890532531, q=0, from=system.host.IObroker, lc=1506890532531
                                            ! 2017-10-01 22:42:24.442 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.mem val=16, ack=true, ts=1506890532533, q=0, from=system.host.IObroker, lc=1506890532533
                                            ! 2017-10-01 22:42:24.444 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memRss val=92.66, ack=true, ts=1506890532536, q=0, from=system.host.IObroker, lc=1506890532536
                                            ! 2017-10-01 22:42:24.447 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memHeapTotal val=25.88, ack=true, ts=1506890532538, q=0, from=system.host.IObroker, lc=1506890532538
                                            ! 2017-10-01 22:42:24.449 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.memHeapUsed val=19.61, ack=true, ts=1506890532539, q=0, from=system.host.IObroker, lc=1506890532539
                                            ! 2017-10-01 22:42:24.452 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.uptime val=352399, ack=true, ts=1506890532541, q=0, from=system.host.IObroker, lc=1506890532541
                                            ! 2017-10-01 22:42:24.454 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.freemem val=151, ack=true, ts=1506890532542, q=0, from=system.host.IObroker, lc=1506890532542
                                            ! 2017-10-01 22:42:24.457 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.inputCount val=7, ack=true, ts=1506890532544, q=0, from=system.host.IObroker, lc=1506890427370
                                            ! 2017-10-01 22:42:24.459 - [34mdebug[39m: javascript.0 inMem message * system.host.IObroker.outputCount val=10, ack=true, ts=1506890532546, q=0, from=system.host.IObroker, lc=1506889420760
                                            ! 2017-10-01 22:42:24.462 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.alive val=true, ack=true, ts=1506890534046, q=0, from=system.adapter.tr-064.0, lc=1506540436438
                                            ! 2017-10-01 22:42:24.464 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.connected val=true, ack=true, ts=1506890534059, q=0, from=system.adapter.tr-064.0, lc=1506540436444
                                            ! 2017-10-01 22:42:24.467 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memRss val=35.74, ack=true, ts=1506890534064, q=0, from=system.adapter.tr-064.0, lc=1506890534064
                                            ! 2017-10-01 22:42:24.469 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memHeapTotal val=19, ack=true, ts=1506890534066, q=0, from=system.adapter.tr-064.0, lc=1506890293908
                                            ! 2017-10-01 22:42:24.472 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.memHeapUsed val=14.73, ack=true, ts=1506890534069, q=0, from=system.adapter.tr-064.0, lc=1506890534069
                                            ! 2017-10-01 22:42:24.479 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.uptime val=350106, ack=true, ts=1506890534071, q=0, from=system.adapter.tr-064.0, lc=1506890534071
                                            ! 2017-10-01 22:42:24.482 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.inputCount val=0, ack=true, ts=1506890534083, q=0, from=system.adapter.tr-064.0, lc=1506540556560
                                            ! 2017-10-01 22:42:24.486 - [34mdebug[39m: javascript.0 inMem message * system.adapter.tr-064.0.outputCount val=8, ack=true, ts=1506890534089, q=0, from=system.adapter.tr-064.0, lc=1506538226478
                                            ! 2017-10-01 22:42:24.489 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.alive val=true, ack=true, ts=1506890534097, q=0, from=system.adapter.node-red.0, lc=1506540433921
                                            ! 2017-10-01 22:42:24.491 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.connected val=true, ack=true, ts=1506890534114, q=0, from=system.adapter.node-red.0, lc=1506540433928
                                            ! 2017-10-01 22:42:24.494 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memRss val=27.99, ack=true, ts=1506890534120, q=0, from=system.adapter.node-red.0, lc=1506890504116
                                            ! 2017-10-01 22:42:24.497 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memHeapTotal val=12, ack=true, ts=1506890534123, q=0, from=system.adapter.node-red.0, lc=1506542610355
                                            ! 2017-10-01 22:42:24.499 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.memHeapUsed val=8.79, ack=true, ts=1506890534126, q=0, from=system.adapter.node-red.0, lc=1506890534126
                                            ! 2017-10-01 22:42:24.501 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.uptime val=350105, ack=true, ts=1506890534128, q=0, from=system.adapter.node-red.0, lc=1506890534128
                                            ! 2017-10-01 22:42:24.504 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.inputCount val=0, ack=true, ts=1506890534130, q=0, from=system.adapter.node-red.0, lc=1506540553967
                                            ! 2017-10-01 22:42:24.506 - [34mdebug[39m: javascript.0 inMem message * system.adapter.node-red.0.outputCount val=8, ack=true, ts=1506890534131, q=0, from=system.adapter.node-red.0, lc=1500588052060
                                            ! 2017-10-01 22:42:32.514 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.alive val=true, ack=true, ts=1506890552499, q=0, from=system.adapter.discovery.0, lc=1506538148270
                                            ! 2017-10-01 22:42:32.546 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.connected val=true, ack=true, ts=1506890552510, q=0, from=system.adapter.discovery.0, lc=1506538148279
                                            ! 2017-10-01 22:42:32.551 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memRss val=27.81, ack=true, ts=1506890552512, q=0, from=system.adapter.discovery.0, lc=1506890492472
                                            ! 2017-10-01 22:42:32.554 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memHeapTotal val=12, ack=true, ts=1506890552517, q=0, from=system.adapter.discovery.0, lc=1506539799771
                                            ! 2017-10-01 22:42:32.557 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.memHeapUsed val=8.61, ack=true, ts=1506890552519, q=0, from=system.adapter.discovery.0, lc=1506890552519
                                            ! 2017-10-01 22:42:32.559 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.uptime val=352409, ack=true, ts=1506890552521, q=0, from=system.adapter.discovery.0, lc=1506890552521
                                            ! 2017-10-01 22:42:32.562 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.inputCount val=0, ack=true, ts=1506890552522, q=0, from=system.adapter.discovery.0, lc=1506540550376
                                            ! 2017-10-01 22:42:32.565 - [34mdebug[39m: javascript.0 inMem message * system.adapter.discovery.0.outputCount val=8, ack=true, ts=1506890552524, q=0, from=system.adapter.discovery.0, lc=1506538178377
                                            ! 2017-10-01 22:42:35.586 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890555569, q=0, from=system.adapter.admin.2, lc=1506540438557
                                            ! 2017-10-01 22:42:35.634 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890555578, q=0, from=system.adapter.admin.2, lc=1506540438589
                                            ! 2017-10-01 22:42:35.638 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.51, ack=true, ts=1506890555580, q=0, from=system.adapter.admin.2, lc=1506890555580
                                            ! 2017-10-01 22:42:35.640 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890555581, q=0, from=system.adapter.admin.2, lc=1506890465559
                                            ! 2017-10-01 22:42:35.643 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=15.27, ack=true, ts=1506890555583, q=0, from=system.adapter.admin.2, lc=1506890555583
                                            ! 2017-10-01 22:42:35.646 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350126, ack=true, ts=1506890555591, q=0, from=system.adapter.admin.2, lc=1506890555591
                                            ! 2017-10-01 22:42:35.650 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=217, ack=true, ts=1506890555593, q=0, from=system.adapter.admin.2, lc=1506890555593
                                            ! 2017-10-01 22:42:35.653 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890555594, q=0, from=system.adapter.admin.2, lc=1506888484820
                                            ! 2017-10-01 22:42:36.156 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890556149, q=0, from=system.adapter.web.0, lc=1506540396929
                                            ! 2017-10-01 22:42:36.167 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890556161, q=0, from=system.adapter.web.0, lc=1506540396952
                                            ! 2017-10-01 22:42:36.182 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=48.41, ack=true, ts=1506890556165, q=0, from=system.adapter.web.0, lc=1506890556165
                                            ! 2017-10-01 22:42:36.186 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890556167, q=0, from=system.adapter.web.0, lc=1506889640821
                                            ! 2017-10-01 22:42:36.189 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=12.46, ack=true, ts=1506890556169, q=0, from=system.adapter.web.0, lc=1506890556169
                                            ! 2017-10-01 22:42:36.192 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350165, ack=true, ts=1506890556171, q=0, from=system.adapter.web.0, lc=1506890556171
                                            ! 2017-10-01 22:42:36.195 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=78, ack=true, ts=1506890556172, q=0, from=system.adapter.web.0, lc=1506890556172
                                            ! 2017-10-01 22:42:36.197 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890556173, q=0, from=system.adapter.web.0, lc=1506890196064
                                            ! 2017-10-01 22:42:37.120 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890557113, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                            ! 2017-10-01 22:42:37.135 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.1, ack=true, ts=1506890557128, q=0, from=system.host.FroelingRPi, lc=1506890557128
                                            ! 2017-10-01 22:42:37.145 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890557137, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                            ! 2017-10-01 22:42:37.155 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=37.44, ack=true, ts=1506890557143, q=0, from=system.host.FroelingRPi, lc=1506890557143
                                            ! 2017-10-01 22:42:37.160 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890557145, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                            ! 2017-10-01 22:42:37.170 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=10.23, ack=true, ts=1506890557160, q=0, from=system.host.FroelingRPi, lc=1506890557160
                                            ! 2017-10-01 22:42:37.191 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185384, ack=true, ts=1506890557167, q=0, from=system.host.FroelingRPi, lc=1506890557167
                                            ! 2017-10-01 22:42:37.196 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=183, ack=true, ts=1506890557169, q=0, from=system.host.FroelingRPi, lc=1506890557169
                                            ! 2017-10-01 22:42:37.200 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=8, ack=true, ts=1506890557172, q=0, from=system.host.FroelingRPi, lc=1506890557172
                                            ! 2017-10-01 22:42:37.204 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890557174, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                            ! 2017-10-01 22:42:38.156 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890558144, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                            ! 2017-10-01 22:42:38.178 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890558166, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                            ! 2017-10-01 22:42:38.191 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=34.73, ack=true, ts=1506890558176, q=0, from=system.adapter.modbus.1, lc=1506890558176
                                            ! 2017-10-01 22:42:38.210 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=16, ack=true, ts=1506890558199, q=0, from=system.adapter.modbus.1, lc=1506890543157
                                            ! 2017-10-01 22:42:38.226 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=12.78, ack=true, ts=1506890558204, q=0, from=system.adapter.modbus.1, lc=1506890558204
                                            ! 2017-10-01 22:42:38.230 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122633, ack=true, ts=1506890558207, q=0, from=system.adapter.modbus.1, lc=1506890558207
                                            ! 2017-10-01 22:42:38.233 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890558209, q=0, from=system.adapter.modbus.1, lc=1506890483101
                                            ! 2017-10-01 22:42:38.237 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890558211, q=0, from=system.adapter.modbus.1, lc=1506890483103
                                            ! 2017-10-01 22:42:39.320 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.alive val=true, ack=true, ts=1506890559309, q=0, from=system.adapter.javascript.0, lc=1506890544302
                                            ! 2017-10-01 22:42:39.330 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.connected val=true, ack=true, ts=1506890559322, q=0, from=system.adapter.javascript.0, lc=1506890544312
                                            ! 2017-10-01 22:42:39.646 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.memRss val=125.09, ack=true, ts=1506890559327, q=0, from=system.adapter.javascript.0, lc=1506890559327
                                            ! 2017-10-01 22:42:39.648 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.memHeapTotal val=104.89, ack=true, ts=1506890559330, q=0, from=system.adapter.javascript.0, lc=1506890544339
                                            ! 2017-10-01 22:42:39.650 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.memHeapUsed val=92.51, ack=true, ts=1506890559332, q=0, from=system.adapter.javascript.0, lc=1506890559332
                                            ! 2017-10-01 22:42:39.652 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.uptime val=157, ack=true, ts=1506890559334, q=0, from=system.adapter.javascript.0, lc=1506890559334
                                            ! 2017-10-01 22:42:39.655 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.inputCount val=170, ack=true, ts=1506890559348, q=0, from=system.adapter.javascript.0, lc=1506890559348
                                            ! 2017-10-01 22:42:39.657 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.outputCount val=8, ack=true, ts=1506890559355, q=0, from=system.adapter.javascript.0, lc=1506890559355
                                            ! 2017-10-01 22:42:40.273 - [34mdebug[39m: javascript.0 script.js.resol3: CONNECTING
                                            ! 2017-10-01 22:42:40.371 - [31merror[39m: javascript.0 uncaught exception: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                            ! 2017-10-01 22:42:40.373 - [31merror[39m: javascript.0 Error: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                            ! at onLine (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/tcp-connection.js:241:22)
                                            ! at Socket.onSocketData (/opt/iobroker/node_modules/iobroker.javascript/node_modules/resol-vbus/src/tcp-connection.js:301:29)
                                            ! at emitOne (events.js:96:13)
                                            ! at Socket.emit (events.js:188:7)
                                            ! at readableAddChunk (_stream_readable.js:176:18)
                                            ! at Socket.Readable.push (_stream_readable.js:134:10)
                                            ! at TCP.onread (net.js:547:20)
                                            ! 2017-10-01 22:42:40.402 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.alive val=false, ack=true, ts=1506890560390, q=0, from=system.adapter.javascript.0, lc=1506890560390
                                            ! 2017-10-01 22:42:40.507 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 0 (OK)
                                            ! 2017-10-01 22:42:40.520 - [32minfo[39m: host.IObroker Restart adapter system.adapter.javascript.0 because enabled
                                            ! 2017-10-01 22:43:10.592 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 started with pid 24043
                                            ! 2017-10-01 22:43:16.974 - [34mdebug[39m: javascript.0 objectDB connected
                                            ! 2017-10-01 22:43:17.140 - [34mdebug[39m: javascript.0 statesDB connected
                                            ! 2017-10-01 22:43:17.254 - [32minfo[39m: javascript.0 starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                            ! 2017-10-01 22:43:17.287 - [32minfo[39m: javascript.0 requesting all states
                                            ! 2017-10-01 22:43:17.296 - [32minfo[39m: javascript.0 requesting all objects
                                            ! 2017-10-01 22:43:18.332 - [32minfo[39m: javascript.0 received all states
                                            ! 2017-10-01 22:43:19.010 - [32minfo[39m: javascript.0 received all objects
                                            ! 2017-10-01 22:43:19.138 - [32minfo[39m: javascript.0 Start javascript script.js.resol3
                                            ! 2017-10-01 22:43:35.302 - [32minfo[39m: javascript.0 script.js.resol3: schedule(cron=
                                            /20 * * * * )
                                            ! 2017-10-01 22:43:35.305 - [32minfo[39m: javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                            ! 2017-10-01 22:43:35.579 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol val=false, ack=true, ts=1506890599136, q=0, from=system.adapter.javascript.0, lc=1506550059065
                                            ! 2017-10-01 22:43:35.616 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Windfang val=19.875, ack=true, ts=1506890599572, q=0, from=system.adapter.node-red.0, lc=1506890565090
                                            ! 2017-10-01 22:43:35.625 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_WC val=20.062, ack=true, ts=1506890599616, q=0, from=system.adapter.node-red.0, lc=1506890599616
                                            ! 2017-10-01 22:43:35.630 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Gang val=22.312, ack=true, ts=1506890599633, q=0, from=system.adapter.node-red.0, lc=1506890599633
                                            ! 2017-10-01 22:43:35.636 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_HWR val=22.187, ack=true, ts=1506890599643, q=0, from=system.adapter.node-red.0, lc=1506890565146
                                            ! 2017-10-01 22:43:35.643 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Wohnzimmer val=22.187, ack=true, ts=1506890599650, q=0, from=system.adapter.node-red.0, lc=1506890599650
                                            ! 2017-10-01 22:43:35.951 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890615579, q=0, from=system.adapter.admin.2, lc=1506540438557
                                            ! 2017-10-01 22:43:35.955 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890615595, q=0, from=system.adapter.admin.2, lc=1506540438589
                                            ! 2017-10-01 22:43:35.958 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.78, ack=true, ts=1506890615601, q=0, from=system.adapter.admin.2, lc=1506890615601
                                            ! 2017-10-01 22:43:35.997 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890615603, q=0, from=system.adapter.admin.2, lc=1506890465559
                                            ! 2017-10-01 22:43:36.010 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=15.61, ack=true, ts=1506890615606, q=0, from=system.adapter.admin.2, lc=1506890615606
                                            ! 2017-10-01 22:43:36.020 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350186, ack=true, ts=1506890615608, q=0, from=system.adapter.admin.2, lc=1506890615608
                                            ! 2017-10-01 22:43:36.023 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=78, ack=true, ts=1506890615609, q=0, from=system.adapter.admin.2, lc=1506890615609
                                            ! 2017-10-01 22:43:36.027 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890615611, q=0, from=system.adapter.admin.2, lc=1506888484820
                                            ! 2017-10-01 22:43:36.352 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890616340, q=0, from=system.adapter.web.0, lc=1506540396929
                                            ! 2017-10-01 22:43:36.386 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890616347, q=0, from=system.adapter.web.0, lc=1506540396952
                                            ! 2017-10-01 22:43:36.390 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=48.67, ack=true, ts=1506890616349, q=0, from=system.adapter.web.0, lc=1506890616349
                                            ! 2017-10-01 22:43:36.394 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890616351, q=0, from=system.adapter.web.0, lc=1506889640821
                                            ! 2017-10-01 22:43:36.398 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=12.8, ack=true, ts=1506890616354, q=0, from=system.adapter.web.0, lc=1506890616354
                                            ! 2017-10-01 22:43:36.401 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350225, ack=true, ts=1506890616357, q=0, from=system.adapter.web.0, lc=1506890616357
                                            ! 2017-10-01 22:43:36.411 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=78, ack=true, ts=1506890616358, q=0, from=system.adapter.web.0, lc=1506890616358
                                            ! 2017-10-01 22:43:36.414 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890616360, q=0, from=system.adapter.web.0, lc=1506890196064
                                            ! 2017-10-01 22:43:37.182 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890617174, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                            ! 2017-10-01 22:43:37.200 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.26, ack=true, ts=1506890617192, q=0, from=system.host.FroelingRPi, lc=1506890617192
                                            ! 2017-10-01 22:43:37.222 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890617198, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                            ! 2017-10-01 22:43:37.244 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=36.83, ack=true, ts=1506890617232, q=0, from=system.host.FroelingRPi, lc=1506890617232
                                            ! 2017-10-01 22:43:37.260 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890617238, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                            ! 2017-10-01 22:43:37.265 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=9.62, ack=true, ts=1506890617240, q=0, from=system.host.FroelingRPi, lc=1506890617240
                                            ! 2017-10-01 22:43:37.269 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185444, ack=true, ts=1506890617243, q=0, from=system.host.FroelingRPi, lc=1506890617243
                                            ! 2017-10-01 22:43:37.280 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=183, ack=true, ts=1506890617245, q=0, from=system.host.FroelingRPi, lc=1506890557169
                                            ! 2017-10-01 22:43:37.283 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=7, ack=true, ts=1506890617247, q=0, from=system.host.FroelingRPi, lc=1506890602236
                                            ! 2017-10-01 22:43:37.286 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890617249, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                            ! 2017-10-01 22:43:38.222 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890618214, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                            ! 2017-10-01 22:43:38.248 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890618234, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                            ! 2017-10-01 22:43:38.256 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=35.25, ack=true, ts=1506890618242, q=0, from=system.adapter.modbus.1, lc=1506890618242
                                            ! 2017-10-01 22:43:38.262 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=16, ack=true, ts=1506890618248, q=0, from=system.adapter.modbus.1, lc=1506890543157
                                            ! 2017-10-01 22:43:38.268 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=13.3, ack=true, ts=1506890618250, q=0, from=system.adapter.modbus.1, lc=1506890618250
                                            ! 2017-10-01 22:43:38.288 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122693, ack=true, ts=1506890618265, q=0, from=system.adapter.modbus.1, lc=1506890618265
                                            ! 2017-10-01 22:43:38.291 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890618271, q=0, from=system.adapter.modbus.1, lc=1506890483101
                                            ! 2017-10-01 22:43:38.303 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890618274, q=0, from=system.adapter.modbus.1, lc=1506890483103
                                            ! 2017-10-01 22:43:40.293 - [34mdebug[39m: javascript.0 script.js.resol3: CONNECTING
                                            ! 2017-10-01 22:43:40.395 - [31merror[39m: javascript.0 uncaught exception: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                            ! 2017-10-01 22:43:40.396 - [31merror[39m: javascript.0 Error: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                            ! 2017-10-01 22:43:40.534 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 0 (OK)
                                            ! 2017-10-01 22:43:40.535 - [32minfo[39m: host.IObroker Restart adapter system.adapter.javascript.0 because enabled
                                            ! 2017-10-01 22:44:10.569 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 started with pid 24079
                                            ! 2017-10-01 22:44:16.926 - [34mdebug[39m: javascript.0 objectDB connected
                                            ! 2017-10-01 22:44:17.092 - [34mdebug[39m: javascript.0 statesDB connected
                                            ! 2017-10-01 22:44:17.182 - [32minfo[39m: javascript.0 starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                            ! 2017-10-01 22:44:17.206 - [32minfo[39m: javascript.0 requesting all states
                                            ! 2017-10-01 22:44:17.213 - [32minfo[39m: javascript.0 requesting all objects
                                            ! 2017-10-01 22:44:18.483 - [32minfo[39m: javascript.0 received all states
                                            ! 2017-10-01 22:44:19.189 - [32minfo[39m: javascript.0 received all objects
                                            ! 2017-10-01 22:44:19.401 - [32minfo[39m: javascript.0 Start javascript script.js.resol3
                                            ! 2017-10-01 22:44:35.495 - [32minfo[39m: javascript.0 script.js.resol3: schedule(cron=
                                            /20 * * * * )
                                            ! 2017-10-01 22:44:35.498 - [32minfo[39m: javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                            ! 2017-10-01 22:44:35.835 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol val=false, ack=true, ts=1506890659395, q=0, from=system.adapter.javascript.0, lc=1506550059065
                                            ! 2017-10-01 22:44:36.238 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890675601, q=0, from=system.adapter.admin.2, lc=1506540438557
                                            ! 2017-10-01 22:44:36.241 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890675612, q=0, from=system.adapter.admin.2, lc=1506540438589
                                            ! 2017-10-01 22:44:36.244 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.28, ack=true, ts=1506890675630, q=0, from=system.adapter.admin.2, lc=1506890675630
                                            ! 2017-10-01 22:44:36.263 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890675636, q=0, from=system.adapter.admin.2, lc=1506890465559
                                            ! 2017-10-01 22:44:36.279 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=14.94, ack=true, ts=1506890675639, q=0, from=system.adapter.admin.2, lc=1506890675639
                                            ! 2017-10-01 22:44:36.295 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350246, ack=true, ts=1506890675642, q=0, from=system.adapter.admin.2, lc=1506890675642
                                            ! 2017-10-01 22:44:36.299 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=83, ack=true, ts=1506890675644, q=0, from=system.adapter.admin.2, lc=1506890660629
                                            ! 2017-10-01 22:44:36.307 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890675647, q=0, from=system.adapter.admin.2, lc=1506888484820
                                            ! 2017-10-01 22:44:36.311 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890676214, q=0, from=system.adapter.web.0, lc=1506540396929
                                            ! 2017-10-01 22:44:36.314 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890676226, q=0, from=system.adapter.web.0, lc=1506540396952
                                            ! 2017-10-01 22:44:36.317 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=48.93, ack=true, ts=1506890676228, q=0, from=system.adapter.web.0, lc=1506890676228
                                            ! 2017-10-01 22:44:36.319 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890676230, q=0, from=system.adapter.web.0, lc=1506889640821
                                            ! 2017-10-01 22:44:36.321 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=13.08, ack=true, ts=1506890676232, q=0, from=system.adapter.web.0, lc=1506890676232
                                            ! 2017-10-01 22:44:36.324 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350285, ack=true, ts=1506890676235, q=0, from=system.adapter.web.0, lc=1506890676235
                                            ! 2017-10-01 22:44:36.326 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=83, ack=true, ts=1506890676236, q=0, from=system.adapter.web.0, lc=1506890676236
                                            ! 2017-10-01 22:44:36.328 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890676238, q=0, from=system.adapter.web.0, lc=1506890196064
                                            ! 2017-10-01 22:44:37.256 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890677235, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                            ! 2017-10-01 22:44:37.282 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.09, ack=true, ts=1506890677249, q=0, from=system.host.FroelingRPi, lc=1506890677249
                                            ! 2017-10-01 22:44:37.312 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890677258, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                            ! 2017-10-01 22:44:37.316 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=37.16, ack=true, ts=1506890677264, q=0, from=system.host.FroelingRPi, lc=1506890677264
                                            ! 2017-10-01 22:44:37.319 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890677267, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                            ! 2017-10-01 22:44:37.323 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=9.95, ack=true, ts=1506890677280, q=0, from=system.host.FroelingRPi, lc=1506890677280
                                            ! 2017-10-01 22:44:37.328 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185504, ack=true, ts=1506890677287, q=0, from=system.host.FroelingRPi, lc=1506890677287
                                            ! 2017-10-01 22:44:37.339 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=183, ack=true, ts=1506890677293, q=0, from=system.host.FroelingRPi, lc=1506890557169
                                            ! 2017-10-01 22:44:37.342 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=7, ack=true, ts=1506890677295, q=0, from=system.host.FroelingRPi, lc=1506890662299
                                            ! 2017-10-01 22:44:37.346 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890677298, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                            ! 2017-10-01 22:44:38.302 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890678294, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                            ! 2017-10-01 22:44:38.330 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890678316, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                            ! 2017-10-01 22:44:38.338 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=35.79, ack=true, ts=1506890678322, q=0, from=system.adapter.modbus.1, lc=1506890678322
                                            ! 2017-10-01 22:44:38.351 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=17, ack=true, ts=1506890678339, q=0, from=system.adapter.modbus.1, lc=1506890663307
                                            ! 2017-10-01 22:44:38.367 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=13.8, ack=true, ts=1506890678345, q=0, from=system.adapter.modbus.1, lc=1506890678345
                                            ! 2017-10-01 22:44:38.386 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122753, ack=true, ts=1506890678348, q=0, from=system.adapter.modbus.1, lc=1506890678348
                                            ! 2017-10-01 22:44:38.390 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890678350, q=0, from=system.adapter.modbus.1, lc=1506890483101
                                            ! 2017-10-01 22:44:38.413 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890678353, q=0, from=system.adapter.modbus.1, lc=1506890483103
                                            ! 2017-10-01 22:44:40.485 - [34mdebug[39m: javascript.0 script.js.resol3: CONNECTING
                                            ! 2017-10-01 22:44:40.586 - [31merror[39m: javascript.0 uncaught exception: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                            ! 2017-10-01 22:44:40.587 - [31merror[39m: javascript.0 Error: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                            ! 2017-10-01 22:44:40.635 - [34mdebug[39m: javascript.0 inMem message * system.adapter.javascript.0.alive val=false, ack=true, ts=1506890680593, q=0, from=system.adapter.javascript.0, lc=1506890680593
                                            ! 2017-10-01 22:44:40.795 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 0 (OK)
                                            ! 2017-10-01 22:44:40.797 - [32minfo[39m: host.IObroker Restart adapter system.adapter.javascript.0 because enabled
                                            ! 2017-10-01 22:45:10.842 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 started with pid 24114
                                            ! 2017-10-01 22:45:16.574 - [34mdebug[39m: javascript.0 objectDB connected
                                            ! 2017-10-01 22:45:16.739 - [34mdebug[39m: javascript.0 statesDB connected
                                            ! 2017-10-01 22:45:16.855 - [32minfo[39m: javascript.0 starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                            ! 2017-10-01 22:45:16.890 - [32minfo[39m: javascript.0 requesting all states
                                            ! 2017-10-01 22:45:16.899 - [32minfo[39m: javascript.0 requesting all objects
                                            ! 2017-10-01 22:45:18.281 - [32minfo[39m: javascript.0 received all states
                                            ! 2017-10-01 22:45:18.980 - [32minfo[39m: javascript.0 received all objects
                                            ! 2017-10-01 22:45:19.125 - [32minfo[39m: javascript.0 Start javascript script.js.resol3
                                            ! 2017-10-01 22:45:34.919 - [32minfo[39m: javascript.0 script.js.resol3: schedule(cron=
                                            /20 * * * * )
                                            ! 2017-10-01 22:45:34.922 - [32minfo[39m: javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                            ! 2017-10-01 22:45:35.226 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol val=false, ack=true, ts=1506890719123, q=0, from=system.adapter.javascript.0, lc=1506550059065
                                            ! 2017-10-01 22:45:35.760 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890735750, q=0, from=system.adapter.admin.2, lc=1506540438557
                                            ! 2017-10-01 22:45:35.786 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890735758, q=0, from=system.adapter.admin.2, lc=1506540438589
                                            ! 2017-10-01 22:45:35.791 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.29, ack=true, ts=1506890735760, q=0, from=system.adapter.admin.2, lc=1506890735760
                                            ! 2017-10-01 22:45:35.795 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890735762, q=0, from=system.adapter.admin.2, lc=1506890465559
                                            ! 2017-10-01 22:45:35.800 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=15.09, ack=true, ts=1506890735766, q=0, from=system.adapter.admin.2, lc=1506890735766
                                            ! 2017-10-01 22:45:35.815 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350306, ack=true, ts=1506890735768, q=0, from=system.adapter.admin.2, lc=1506890735768
                                            ! 2017-10-01 22:45:35.830 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=88, ack=true, ts=1506890735769, q=0, from=system.adapter.admin.2, lc=1506890735769
                                            ! 2017-10-01 22:45:35.850 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890735771, q=0, from=system.adapter.admin.2, lc=1506888484820
                                            ! 2017-10-01 22:45:36.238 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890736229, q=0, from=system.adapter.web.0, lc=1506540396929
                                            ! 2017-10-01 22:45:36.258 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890736236, q=0, from=system.adapter.web.0, lc=1506540396952
                                            ! 2017-10-01 22:45:36.263 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=49.18, ack=true, ts=1506890736238, q=0, from=system.adapter.web.0, lc=1506890736238
                                            ! 2017-10-01 22:45:36.267 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890736241, q=0, from=system.adapter.web.0, lc=1506889640821
                                            ! 2017-10-01 22:45:36.272 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=13.32, ack=true, ts=1506890736243, q=0, from=system.adapter.web.0, lc=1506890736243
                                            ! 2017-10-01 22:45:36.276 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350345, ack=true, ts=1506890736245, q=0, from=system.adapter.web.0, lc=1506890736245
                                            ! 2017-10-01 22:45:36.279 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=78, ack=true, ts=1506890736246, q=0, from=system.adapter.web.0, lc=1506890736246
                                            ! 2017-10-01 22:45:36.283 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890736262, q=0, from=system.adapter.web.0, lc=1506890196064
                                            ! 2017-10-01 22:45:37.303 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890737296, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                            ! 2017-10-01 22:45:37.332 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.03, ack=true, ts=1506890737314, q=0, from=system.host.FroelingRPi, lc=1506890737314
                                            ! 2017-10-01 22:45:37.353 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890737346, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                            ! 2017-10-01 22:45:37.384 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=37.5, ack=true, ts=1506890737351, q=0, from=system.host.FroelingRPi, lc=1506890737351
                                            ! 2017-10-01 22:45:37.389 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890737354, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                            ! 2017-10-01 22:45:37.393 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=10.29, ack=true, ts=1506890737358, q=0, from=system.host.FroelingRPi, lc=1506890737358
                                            ! 2017-10-01 22:45:37.397 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185564, ack=true, ts=1506890737360, q=0, from=system.host.FroelingRPi, lc=1506890737360
                                            ! 2017-10-01 22:45:37.401 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=182, ack=true, ts=1506890737388, q=0, from=system.host.FroelingRPi, lc=1506890692322
                                            ! 2017-10-01 22:45:37.427 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=7, ack=true, ts=1506890737413, q=0, from=system.host.FroelingRPi, lc=1506890722332
                                            ! 2017-10-01 22:45:37.430 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890737415, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                            ! 2017-10-01 22:45:37.460 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Windfang val=19.875, ack=true, ts=1506890737453, q=0, from=system.adapter.node-red.0, lc=1506890565090
                                            ! 2017-10-01 22:45:37.480 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_WC val=20, ack=true, ts=1506890737467, q=0, from=system.adapter.node-red.0, lc=1506890634012
                                            ! 2017-10-01 22:45:37.663 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Gang val=22.312, ack=true, ts=1506890737642, q=0, from=system.adapter.node-red.0, lc=1506890599633
                                            ! 2017-10-01 22:45:37.670 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_HWR val=22.25, ack=true, ts=1506890737659, q=0, from=system.adapter.node-red.0, lc=1506890703116
                                            ! 2017-10-01 22:45:37.678 - [34mdebug[39m: javascript.0 inMem message * node-red.0.Temp_Ist_Wohnzimmer val=22.187, ack=true, ts=1506890737667, q=0, from=system.adapter.node-red.0, lc=1506890737667
                                            ! 2017-10-01 22:45:38.377 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890738368, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                            ! 2017-10-01 22:45:38.394 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890738385, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                            ! 2017-10-01 22:45:38.404 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=36.28, ack=true, ts=1506890738396, q=0, from=system.adapter.modbus.1, lc=1506890738396
                                            ! 2017-10-01 22:45:38.412 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=17, ack=true, ts=1506890738402, q=0, from=system.adapter.modbus.1, lc=1506890663307
                                            ! 2017-10-01 22:45:38.424 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=14.29, ack=true, ts=1506890738416, q=0, from=system.adapter.modbus.1, lc=1506890738416
                                            ! 2017-10-01 22:45:38.446 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122813, ack=true, ts=1506890738421, q=0, from=system.adapter.modbus.1, lc=1506890738421
                                            ! 2017-10-01 22:45:38.450 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890738424, q=0, from=system.adapter.modbus.1, lc=1506890483101
                                            ! 2017-10-01 22:45:38.457 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890738427, q=0, from=system.adapter.modbus.1, lc=1506890483103
                                            ! 2017-10-01 22:45:40.897 - [34mdebug[39m: javascript.0 script.js.resol3: CONNECTING
                                            ! 2017-10-01 22:45:40.997 - [31merror[39m: javascript.0 uncaught exception: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                            ! 2017-10-01 22:45:40.998 - [31merror[39m: javascript.0 Error: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                            ! 2017-10-01 22:45:41.176 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 0 (OK)
                                            ! 2017-10-01 22:45:41.179 - [32minfo[39m: host.IObroker Restart adapter system.adapter.javascript.0 because enabled
                                            ! 2017-10-01 22:46:11.222 - [32minfo[39m: host.IObroker instance system.adapter.javascript.0 started with pid 24136
                                            ! 2017-10-01 22:46:17.398 - [34mdebug[39m: javascript.0 objectDB connected
                                            ! 2017-10-01 22:46:17.572 - [34mdebug[39m: javascript.0 statesDB connected
                                            ! 2017-10-01 22:46:17.692 - [32minfo[39m: javascript.0 starting. Version 3.4.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.11.1
                                            ! 2017-10-01 22:46:17.735 - [32minfo[39m: javascript.0 requesting all states
                                            ! 2017-10-01 22:46:17.744 - [32minfo[39m: javascript.0 requesting all objects
                                            ! 2017-10-01 22:46:18.757 - [32minfo[39m: javascript.0 received all states
                                            ! 2017-10-01 22:46:19.479 - [32minfo[39m: javascript.0 received all objects
                                            ! 2017-10-01 22:46:19.621 - [32minfo[39m: javascript.0 Start javascript script.js.resol3
                                            ! 2017-10-01 22:46:35.431 - [32minfo[39m: javascript.0 script.js.resol3: schedule(cron=
                                            /20 * * * * *)
                                            ! 2017-10-01 22:46:35.435 - [32minfo[39m: javascript.0 script.js.resol3: registered 0 subscriptions and 1 schedule
                                            ! 2017-10-01 22:46:35.741 - [34mdebug[39m: javascript.0 inMem message * javascript.0.scriptEnabled.resol val=false, ack=true, ts=1506890779619, q=0, from=system.adapter.javascript.0, lc=1506550059065
                                            ! 2017-10-01 22:46:35.773 - [34mdebug[39m: javascript.0 inMem message * modbus.1.inputRegisters.30001_Kessel val=62, ack=true, ts=1506890779652, q=0, from=system.adapter.modbus.1, lc=1506890779652
                                            ! 2017-10-01 22:46:36.066 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.alive val=true, ack=true, ts=1506890795682, q=0, from=system.adapter.admin.2, lc=1506540438557
                                            ! 2017-10-01 22:46:36.085 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.connected val=true, ack=true, ts=1506890795696, q=0, from=system.adapter.admin.2, lc=1506540438589
                                            ! 2017-10-01 22:46:36.089 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memRss val=42.61, ack=true, ts=1506890795721, q=0, from=system.adapter.admin.2, lc=1506890795721
                                            ! 2017-10-01 22:46:36.092 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapTotal val=21, ack=true, ts=1506890795722, q=0, from=system.adapter.admin.2, lc=1506890465559
                                            ! 2017-10-01 22:46:36.097 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.memHeapUsed val=15.37, ack=true, ts=1506890795724, q=0, from=system.adapter.admin.2, lc=1506890795724
                                            ! 2017-10-01 22:46:36.100 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.uptime val=350366, ack=true, ts=1506890795726, q=0, from=system.adapter.admin.2, lc=1506890795726
                                            ! 2017-10-01 22:46:36.103 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.inputCount val=79, ack=true, ts=1506890795728, q=0, from=system.adapter.admin.2, lc=1506890795728
                                            ! 2017-10-01 22:46:36.133 - [34mdebug[39m: javascript.0 inMem message * system.adapter.admin.2.outputCount val=8, ack=true, ts=1506890795742, q=0, from=system.adapter.admin.2, lc=1506888484820
                                            ! 2017-10-01 22:46:36.383 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.alive val=true, ack=true, ts=1506890796370, q=0, from=system.adapter.web.0, lc=1506540396929
                                            ! 2017-10-01 22:46:36.407 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.connected val=true, ack=true, ts=1506890796378, q=0, from=system.adapter.web.0, lc=1506540396952
                                            ! 2017-10-01 22:46:36.422 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memRss val=48.68, ack=true, ts=1506890796380, q=0, from=system.adapter.web.0, lc=1506890796380
                                            ! 2017-10-01 22:46:36.427 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapTotal val=19, ack=true, ts=1506890796383, q=0, from=system.adapter.web.0, lc=1506889640821
                                            ! 2017-10-01 22:46:36.431 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.memHeapUsed val=12.69, ack=true, ts=1506890796385, q=0, from=system.adapter.web.0, lc=1506890796385
                                            ! 2017-10-01 22:46:36.435 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.uptime val=350405, ack=true, ts=1506890796387, q=0, from=system.adapter.web.0, lc=1506890796387
                                            ! 2017-10-01 22:46:36.439 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.inputCount val=78, ack=true, ts=1506890796388, q=0, from=system.adapter.web.0, lc=1506890796388
                                            ! 2017-10-01 22:46:36.442 - [34mdebug[39m: javascript.0 inMem message * system.adapter.web.0.outputCount val=8, ack=true, ts=1506890796390, q=0, from=system.adapter.web.0, lc=1506890196064
                                            ! 2017-10-01 22:46:37.368 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.alive val=true, ack=true, ts=1506890797361, q=0, from=system.host.FroelingRPi, lc=1506705183690
                                            ! 2017-10-01 22:46:37.389 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.load val=0.09, ack=true, ts=1506890797375, q=0, from=system.host.FroelingRPi, lc=1506890797375
                                            ! 2017-10-01 22:46:37.405 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.mem val=42, ack=true, ts=1506890797388, q=0, from=system.host.FroelingRPi, lc=1506890482056
                                            ! 2017-10-01 22:46:37.446 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memRss val=36.88, ack=true, ts=1506890797399, q=0, from=system.host.FroelingRPi, lc=1506890797399
                                            ! 2017-10-01 22:46:37.451 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapTotal val=14, ack=true, ts=1506890797402, q=0, from=system.host.FroelingRPi, lc=1506889566114
                                            ! 2017-10-01 22:46:37.472 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.memHeapUsed val=9.67, ack=true, ts=1506890797426, q=0, from=system.host.FroelingRPi, lc=1506890797426
                                            ! 2017-10-01 22:46:37.477 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.uptime val=185625, ack=true, ts=1506890797431, q=0, from=system.host.FroelingRPi, lc=1506890797431
                                            ! 2017-10-01 22:46:37.481 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.freemem val=182, ack=true, ts=1506890797434, q=0, from=system.host.FroelingRPi, lc=1506890782413
                                            ! 2017-10-01 22:46:37.484 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.inputCount val=7, ack=true, ts=1506890797447, q=0, from=system.host.FroelingRPi, lc=1506890782423
                                            ! 2017-10-01 22:46:37.487 - [34mdebug[39m: javascript.0 inMem message * system.host.FroelingRPi.outputCount val=10, ack=true, ts=1506890797449, q=0, from=system.host.FroelingRPi, lc=1506767946200
                                            ! 2017-10-01 22:46:38.454 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.alive val=true, ack=true, ts=1506890798445, q=0, from=system.adapter.modbus.1, lc=1506767936603
                                            ! 2017-10-01 22:46:38.473 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.connected val=true, ack=true, ts=1506890798465, q=0, from=system.adapter.modbus.1, lc=1506767936617
                                            ! 2017-10-01 22:46:38.484 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memRss val=36.87, ack=true, ts=1506890798474, q=0, from=system.adapter.modbus.1, lc=1506890798474
                                            ! 2017-10-01 22:46:38.500 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapTotal val=18, ack=true, ts=1506890798481, q=0, from=system.adapter.modbus.1, lc=1506890768437
                                            ! 2017-10-01 22:46:38.505 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.memHeapUsed val=14.84, ack=true, ts=1506890798484, q=0, from=system.adapter.modbus.1, lc=1506890798484
                                            ! 2017-10-01 22:46:38.522 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.uptime val=122873, ack=true, ts=1506890798505, q=0, from=system.adapter.modbus.1, lc=1506890798505
                                            ! 2017-10-01 22:46:38.532 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.inputCount val=0, ack=true, ts=1506890798511, q=0, from=system.adapter.modbus.1, lc=1506890798511
                                            ! 2017-10-01 22:46:38.538 - [34mdebug[39m: javascript.0 inMem message * system.adapter.modbus.1.outputCount val=8, ack=true, ts=1506890798514, q=0, from=system.adapter.modbus.1, lc=1506890798514
                                            ! 2017-10-01 22:46:40.411 - [34mdebug[39m: javascript.0 script.js.resol3: CONNECTING
                                            ! 2017-10-01 22:46:40.544 - [31merror[39m: javascript.0 uncaught exception: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                            ! 2017-10-01 22:46:40.546 - [31merror[39m: javascript.0 Error: Remote side responded with "-ERROR: Sacre bleu. Unknown command"
                                            ! 2017-10-01 22:46:40.653 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 0 (OK)
                                            ! 2017-10-01 22:46:40.655 - [32minfo[39m: host.IObroker Restart adapter system.adapter.javascript.0 because enabled
                                            ! 2017-10-01 22:46:46.069 - [32minfo[39m: host.IObroker object change system.adapter.javascript.0
                                            ! 2017-10-01 22:47:16.626 - [34mdebug[39m: javascript.0 objectDB connected
                                            ! 2017-10-01 22:47:16.762 - [34mdebug[39m: javascript.0 statesDB connected
                                            ! 2017-10-01 22:47:16.865 - [31merror[39m: javascript.0 adapter disabled
                                            ! 2017-10-01 22:47:16.953 - [31merror[39m: host.IObroker instance system.adapter.javascript.0 terminated with code 3 (Adapter disabled or invalid config)
                                            ! 2017-10-01 22:47:16.954 - [32minfo[39m: host.IObroker Do not restart adapter system.adapter.javascript.0 because disabled or deleted[/spoiler]
                                            Danke, lustige ist das meine debug meldungen fehlen was bedeuten sollte das er gar keine verbindung hinbekommt.
                                            Was mir nog auffahlet ist diese zeile:
                                            viaTag: 'xxxxx',
                                            bitte aendern in
                                            viaTag: '',
                                            und lasse den hier mal bitte auf false, sonst fehlt mir werte die als debug reinkommen sollten (mein fehler muss ich in nen neuen version noch verbessern:
                                            var create_states = true;
                                            118
                                            24241
