    4. Node-Red
    5. Shelly addon über Node Red
      Dirk 4 @Dirk 4 last edited by
      • mickym
        mickym Most Active @Dirk 4 last edited by
        @dirk-4
        So was bitte in Zukunft immer in Code-Tags posten:
         Aktive Internetverbindungen (Nur Server)
        Proto Recv-Q Send-Q Local Address Foreign Address State Benutzer Inode PID/Program name
        tcp 0 0 localhost:omniorb 0.0.0.0:* LISTEN influxdb 14684 616/influxd
        tcp 0 0 0.0.0.0:8085 0.0.0.0:* LISTEN iobroker 104952393 2635893/io.shelly.0
        tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN iobroker 15790 1176/io.sonoff.0
        tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN iobroker 16592 1113/node-red
        tcp 0 0 localhost:9001 0.0.0.0:* LISTEN iobroker 12268 685/iobroker.js-con
        tcp 0 0 localhost:9000 0.0.0.0:* LISTEN iobroker 12275 685/iobroker.js-con
        tcp 0 0 0.0.0.0:8400 0.0.0.0:* LISTEN iobroker 18622 1419/io.jarvis.0
        tcp 0 0 0.0.0.0:ssh 0.0.0.0:* LISTEN root 11876 544/sshd: /usr/sbin
        tcp6 0 0 [::]:8090 [::]:* LISTEN iobroker 12726 612/hyperiond
        tcp6 0 0 [::]:8092 [::]:* LISTEN iobroker 14703 612/hyperiond
        tcp6 0 0 [::]:8082 [::]:* LISTEN iobroker 17638 1362/io.web.0
        tcp6 0 0 [::]:tproxy [::]:* LISTEN iobroker 9159 924/io.admin.0
        tcp6 0 0 [::]:8086 [::]:* LISTEN influxdb 8987 616/influxd
        tcp6 0 0 [::]:ssh [::]:* LISTEN root 11878 544/sshd: /usr/sbin
        tcp6 0 0 [::]:19400 [::]:* LISTEN iobroker 12225 612/hyperiond
        tcp6 0 0 [::]:19445 [::]:* LISTEN iobroker 12724 612/hyperiond
        tcp6 0 0 [::]:19444 [::]:* LISTEN iobroker 8944 612/hyperiond
        udp 0 0 0.0.0.0:mdns 0.0.0.0:* iobroker 17349 1892/io.wled.0
        udp 0 0 0.0.0.0:mdns 0.0.0.0:* iobroker 14688 612/hyperiond
        udp 0 0 0.0.0.0:mdns 0.0.0.0:* iobroker 8939 612/hyperiond
        udp 0 0 0.0.0.0:mdns 0.0.0.0:* avahi 8756 410/avahi-daemon: r
        udp 0 0 0.0.0.0:1900 0.0.0.0:* iobroker 8959 612/hyperiond
        udp 0 0 0.0.0.0:bootpc 0.0.0.0:* root 8803 611/dhcpcd
        udp 0 0 0.0.0.0:56330 0.0.0.0:* avahi 8758 410/avahi-daemon: r
        udp6 0 0 [::]:mdns [::]:* iobroker 14689 612/hyperiond
        udp6 0 0 [::]:mdns [::]:* iobroker 8940 612/hyperiond
        udp6 0 0 [::]:mdns [::]:* avahi 8757 410/avahi-daemon: r
        udp6 0 0 [::]:dhcpv6-client [::]:* root 12793 611/dhcpcd
        udp6 0 0 [::]:48052 [::]:* avahi 8759 410/avahi-daemon: r
          Dirk 4 @mickym last edited by
          @mickym OK Mache ich
            @dirk-4 said in Shelly addon über Node Red:
            Die anderen werte hab ich alle nur halt das vom addon nicht
            • mickym
              mickym Most Active @Dirk 4 last edited by mickym
              @dirk-4 sagte in Shelly addon über Node Red:
              Ja das habe ich nun alles verstanden. 😉
              Die Sache klar, Du nutzt den Shelly- Adapter- der ist aber kein MQTT-Broker, sondern verhält sich nur gegenüber dem Shelly - wie ein mqtt-Broker. Er interpretiert aber nur die Nachrichten und wenn der was nicht kennt, dann bekommst Du diese Informationen nicht.
              Das mit den Adapter ist zwar bequem, aber wie gesagt, wenn er was nicht kennt, dann bist Du halt aufgeschmissen.
              Nun hast Du 2 Möglichkeiten:
              1. Du fragst Leute bzw. gehst an die Threads von dem Shelly Adapter und fragst dort. Vielleicht kann auch @da_Woody oder @haus-automatisierung helfen.
              2. Du nutzt für den Shelly einen eigenen mqtt-Broker und verarbeitest die originalen Mqtt-Nachrichten.
              Mit Nutzung des Shelly-Adapters bist Du darauf angewiesen, was der ausspukt.
              ad 1: da kann ich Dir nicht helfen
              ad 2: kann ich helfen, aber Du müsstest dann noch einen mqtt-Broker installieren und Dich entscheiden, den Shelly 2PM nicht über den Shelly Adapter zu steuern.
              Deshalb haben wir auch in dem anderen Thread einen eigenen mqtt-Broker auf Basis von mosquitto installiert. Du könntest ggf. auch den mqtt-Broker im Adapter nutzen, der spukt aber manchmal Fehler aus.
              Wie gesagt in dem anderen Thread haben wir mosquitto und den mqtt-Adadpter installiert - aber diese Umgebung läuft dann völlig unabhängig von Deinen bisherigen Shellies.
              Wie willst Du weiter vorgehen?
              Ich sehe gerade Du hast auch noch den sonoff - der simuliert auch noch einen mqtt-Broker. Das ist genau die Konfiguration mit den x-Adaptern die alle mqtt-Nachrichten interpretieren - das ist der Grund warum ich diese Adapter nicht so mag. 😉
              Du hast also mqtt-Broker, die auf den Ports:
              1883, 8085 hören.
              Wenn Du nun noch einen mqtt-Broker hast, dann ist noch ein Port weg - und das finde ich nicht so prickelnd. Aber Du musst wissen, ob Du eben diese Adapter nutzen willst oder lieber mit originalen mqtt-Nachrichten arbeitest.
                @mickym Mit dem mosquitto das wuste ich nicht. Wenn du Zeit hast können wir das gerne machen den kan ich ja dann vielleicht auch für andere sachen nutzen. Den mosquitto instalieren.
                • mickym
                  @dirk-4 Ja - wobei ich Dir dann empfehlen würde, lieber den Standard mqtt-Port zu nutzen. Deswegen eine andere Frage, wieviele Geräte verbinden sich mit deinem Sonoff Adapter? Und wäre es ein vertretbarer Aufwand diesen Port und den der entsprechenden Geräte zu ändern?
                    Dirk 4 @mickym last edited by Dirk 4
                    @mickym mit dem Sonoff Adapter sind das 8 Geräte.Die möchte ich aber nicht unbedigt ändern
                    • mickym
                      Na ich hätte es Dir zwar empfohlen die zu ändern, da die den Standard - Mqtt Port verwenden, aber man kann den mosquitto natürlich auch umbiegen.
                      Also dann installiere halt mal mosquitto - du brauchst nur den Server. 😉
                      Also
                      sudo apt install mosquitto
                        @mickym said in Shelly addon über Node Red:
                        Fertig
                        • mickym
                          @dirk-4 Dann solltest Du ein Verzeichnis
                          /etc/mosquitto
                          haben.
                          Dann schau mal was in der mosquitto.conf steht.
                          cd /etc/mosquitto
                          cat mosquitto.conf
                          und den Inhalt posten.
                            cat mosquitto.conf
                            • mickym
                              @dirk-4 Auch diese Ausgaben bitte in Codetags. 😉
                              Gut dann wechsle mal in das Verzeichnis
                              conf.d
                              und schau, ob es da irgendwelche Konigurationsdateien gibt?
                                @mickym Wie mach ich das
                                • mickym
                                  @dirk-4
                                  Du bist ja in dem Verzeichnis
                                  /etc/mosquitto
                                  dann einfach schauen mit
                                  ls -la conf.d
                                    • mickym
                                      @dirk-4 Ok wie gesagt die Ausgaben kopieren und in CodeTags hier rein.
                                      Gut dann wechselst Du in das Verzeichnis.
                                      cd conf.d
                                      und erstellst dort eine Konfigurationsdatei:
                                      sudo nano local.conf
                                      in diese Datei trägst Du dann mal folgende beiden Zeilen ein:
                                      listener 1884
                                      allow_anonymous true
                                      Eine Leerzeile als letztes machen.
                                      Dann abspeichern.
                                      Später kannst du Authentifizierung noch dazu konfigurieren. Nun machen wir alles einfach.
                                        @mickym OK Hab ich
                                        • mickym
                                          Gut dann startest Du den mosquitto neu und lässt Dir dann den Status ausgeben:
                                          sudo systemctl restart mosquitto
                                          dann status überprüfen:
                                          systemctl status mosquitto
                                          Die Ausgabe dann wieder in CodeTags hier posten.
                                            1.4k
                                            8084
