    4. Wunsch: Adapter für Panasonic Viera Smart TV Steuerung
      matche last edited by
      Hallo ldittmar,
      Danke im Vorraus für Deinen Adapter, hat mich sehr gefreut…
      Ich habe einen TX-50DX780.. also relativ Neu...
      Ich habe mal versucht alle Befehle zu testen...
      Leider stürzte der Adapter nach jedem Tastendruck ab...
      ! panasonic-viera.0 2017-09-18 14:10:45.161 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v4.8.3
      ! panasonic-viera.0 2017-09-18 14:10:13.628 info cleaned everything up…
      ! panasonic-viera.0 2017-09-18 14:10:13.624 error at emitOne (events.js:77:13)
      ! panasonic-viera.0 2017-09-18 14:10:13.624 error at Socket.socketOnData (_http_client.js:322:20)
      ! panasonic-viera.0 2017-09-18 14:10:13.624 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
      ! panasonic-viera.0 2017-09-18 14:10:13.624 error at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:433:21)
      ! panasonic-viera.0 2017-09-18 14:10:13.624 error at ClientRequest.emit (events.js:169:7)
      ! panasonic-viera.0 2017-09-18 14:10:13.624 error at ClientRequest.g (events.js:260:16)
      ! panasonic-viera.0 2017-09-18 14:10:13.624 error at ClientRequest. (/opt/iobroker/node_modules/iobroker.panasonic-viera/node_modules/viera.js/viera.js:70:17)
      ! panasonic-viera.0 2017-09-18 14:10:13.624 error at IncomingMessage.Readable.on (_stream_readable.js:680:33)
      ! panasonic-viera.0 2017-09-18 14:10:13.624 error at IncomingMessage.addListener (events.js:197:11)
      ! panasonic-viera.0 2017-09-18 14:10:13.624 error TypeError: listener must be a function
      ! panasonic-viera.0 2017-09-18 14:10:13.615 error uncaught exception: listener must be a function
      ! panasonic-viera.0 2017-09-18 14:10:05.666 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v4.8.3
      ! panasonic-viera.0 2017-09-18 14:09:34.025 info cleaned everything up…
      ! panasonic-viera.0 2017-09-18 14:09:34.022 error at emitOne (events.js:77:13)
      ! panasonic-viera.0 2017-09-18 14:09:34.022 error at Socket.socketOnData (_http_client.js:322:20)
      ! panasonic-viera.0 2017-09-18 14:09:34.022 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
      ! panasonic-viera.0 2017-09-18 14:09:34.022 error at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:433:21)
      ! panasonic-viera.0 2017-09-18 14:09:34.022 error at ClientRequest.emit (events.js:169:7)
      ! panasonic-viera.0 2017-09-18 14:09:34.022 error at ClientRequest.g (events.js:260:16)
      ! panasonic-viera.0 2017-09-18 14:09:34.022 error at ClientRequest. (/opt/iobroker/node_modules/iobroker.panasonic-viera/node_modules/viera.js/viera.js:70:17)
      ! panasonic-viera.0 2017-09-18 14:09:34.022 error at IncomingMessage.Readable.on (_stream_readable.js:680:33)
      ! panasonic-viera.0 2017-09-18 14:09:34.022 error at IncomingMessage.addListener (events.js:197:11)
      ! panasonic-viera.0 2017-09-18 14:09:34.022 error TypeError: listener must be a function
      ! panasonic-viera.0 2017-09-18 14:09:34.017 error uncaught exception: listener must be a function
      ! panasonic-viera.0 2017-09-18 14:07:09.350 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v4.8.3
      ! panasonic-viera.0 2017-09-18 14:06:37.737 info cleaned everything up…
      ! panasonic-viera.0 2017-09-18 14:06:37.733 error at emitOne (events.js:77:13)
      ! panasonic-viera.0 2017-09-18 14:06:37.733 error at Socket.socketOnData (_http_client.js:322:20)
      ! panasonic-viera.0 2017-09-18 14:06:37.733 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
      ! panasonic-viera.0 2017-09-18 14:06:37.733 error at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:433:21)
      ! panasonic-viera.0 2017-09-18 14:06:37.733 error at ClientRequest.emit (events.js:169:7)
      ! panasonic-viera.0 2017-09-18 14:06:37.733 error at ClientRequest.g (events.js:260:16)
      ! panasonic-viera.0 2017-09-18 14:06:37.733 error at ClientRequest. (/opt/iobroker/node_modules/iobroker.panasonic-viera/node_modules/viera.js/viera.js:70:17)
      ! panasonic-viera.0 2017-09-18 14:06:37.733 error at IncomingMessage.Readable.on (_stream_readable.js:680:33)
      ! panasonic-viera.0 2017-09-18 14:06:37.733 error at IncomingMessage.addListener (events.js:197:11)
      ! panasonic-viera.0 2017-09-18 14:06:37.733 error TypeError: listener must be a function
      ! panasonic-viera.0 2017-09-18 14:06:37.724 error uncaught exception: listener must be a function
      ! panasonic-viera.0 2017-09-18 14:06:33.236 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v4.8.3
      Folgende Tastencodes funktionieren….
      ! CH_DOWN - channel down
      ! CH_UP - channel up
      ! VOLUP - volume up
      ! VOLDOWN - volume down
      ! POWER - Power off
      ! MUTE - mute
      ! TV - TV
      ! CHG_INPUT - AV
      ! HOME - Home screen
      ! APPS - Apps
      ! GUIDE - Guide
      ! RED - red
      ! GREEN - green
      ! YELLOW - yellow
      ! BLUE – blue
      ! RETURN - Return
      ! ENTER - Control Center click / enter
      ! RIGHT - Control RIGHT
      ! LEFT - Control LEFT
      ! UP - Control UP
      ! DOWN - Control DOWN
      ! MENU - Menu
      ! EPG - Guide / EPG
      ! numeric buttons
      ! D1 D2 D3 D4 D5 D6 D7 D8 D9 D0
      ! FAVORITE
      ! DMS_CH_UP
      ! DMS_CH_DOWN
      Die restlichen Tasten teste ich noch, aber durch die Abstürze ist das sehr mühsam….
      Ich hoffe ich konnt Dir ein wenig helfen...
      Mario
      • ldittmar
        ldittmar Developer last edited by
        Hi Mario,
        vielen Dank für die Tests. Ich glaube deine Abstürze daran liegen, dass du Node.js 4.x nutzt. Scheinbar wurde die benutzte Bibliothek für Node ab 6 geschrieben. 😞
        Ich schaue mal nach…
        Grüße,
        ldittmar
          Servus ldittmar,
          habe ich getestet, siehe unten
          ! panasonic-viera.0 2017-09-18 21:46:59.464 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.panasonic-viera, node: v6.11.3
          ! host.HM-Wir 2017-09-18 21:46:57.661 info instance system.adapter.panasonic-viera.0 started with pid 31197
          ! host.HM-Wir 2017-09-18 21:46:27.606 info Restart adapter system.adapter.panasonic-viera.0 because enabled
          ! host.HM-Wir 2017-09-18 21:46:27.604 error instance system.adapter.panasonic-viera.0 terminated with code 0 (OK)
          ! panasonic-viera.0 2017-09-18 21:46:27.526 info cleaned everything up…
          ! panasonic-viera.0 2017-09-18 21:46:27.521 error at Socket.emit (events.js:169:7)
          ! panasonic-viera.0 2017-09-18 21:46:27.521 error at emitOne (events.js:77:13)
          ! panasonic-viera.0 2017-09-18 21:46:27.521 error at Socket.socketOnData (_http_client.js:322:20)
          ! panasonic-viera.0 2017-09-18 21:46:27.521 error at HTTPParser.parserOnHeadersComplete (_http_common.js:97:23)
          ! panasonic-viera.0 2017-09-18 21:46:27.521 error at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:433:21)
          ! panasonic-viera.0 2017-09-18 21:46:27.521 error at ClientRequest.emit (events.js:169:7)
          ! panasonic-viera.0 2017-09-18 21:46:27.521 error at ClientRequest.g (events.js:260:16)
          ! panasonic-viera.0 2017-09-18 21:46:27.521 error at ClientRequest. (/opt/iobroker/node_modules/iobroker.panasonic-viera/node_modules/viera.js/viera.js:70:17)
          ! panasonic-viera.0 2017-09-18 21:46:27.521 error at IncomingMessage.Readable.on (_stream_readable.js:680:33)
          ! panasonic-viera.0 2017-09-18 21:46:27.521 error at IncomingMessage.addListener (events.js:197:11)
          ! panasonic-viera.0 2017-09-18 21:46:27.521 error TypeError: listener must be a function
          ! panasonic-viera.0 2017-09-18 21:46:27.510 error uncaught exception: listener must be a function
          Mario
          • Bluefox
            Bluefox last edited by
            Ich habe auch versucht zu analysieren und sehe immer noch das Problem nicht. 😞
            • ldittmar
              Soo… eine neue Version steht zum Testen bereit. Ich hoffe die Abstürze sind jetzt weg 😉
              Grüße,
              ldittmar
                Servus ldittmar,
                jetzt funktionierts enwandfrei…
                Teste die Tage noch aller Befehle durch...
                Frage:
                ist es auch möglich sich Infos anzeigen zu lassen:
                Ist der Fernseher eingeschaltet?
                Welcher Eingang ist gewählt?
                usw.?
                Danke für Deine tolle Arbeit
                Mario
                • ldittmar
                  @matche:
                  Teste die Tage noch aller Befehle durch... `
                  Hi Mario,
                  freut mich! Ich werde noch die einzelnen Tasten ein bisschen gruppieren, damit nicht so viele Funktionen auf einem Schlag auftauchen.
                  @matche:
                  Ist der Fernseher eingeschaltet? `
                  das geht jetzt schon… unter info.connection
                  @matche:
                  usw.? `
                  Leider ist mir kein Weg bekannt. Ich bekomme nur die aktuelle Lautstärke raus.. Sorry
                  Grüße,
                  ldittmar
                  • Bluefox
                    @Lditmar hast du schon an discovery gedacht?
                    Das soll super einfach gehen. Einfach https://github.com/ioBroker/ioBroker.di … ers/hue.js kopieren und anpassen.
                    • ldittmar
                      Natürlich habe ich schon an Discovery gedacht. Hab ja schon den Worx und Fronius Adapter hinzugefügt. Jetzt kommen Panasonic und Sony 8-)
                      Grüße,
                      ldittmar
                      • ldittmar
                        Die neue Version 0.0.6 ist jetzt online und kann getestet werden. Bitte um Feedback.
                        https://github.com/ldittmar81/ioBroker.panasonic-viera
                        Grüße,
                        ldittmar
                        • O
                          onkeltom9 last edited by
                          hallo
                          Adapter funktioniert
                          starten des TV geht über wake on lan
                          mein TV TX50EXW
                          tolle Arbeit
                          gruß
                            Bobohne last edited by
                            Hallo!
                            Kann den Adapter zwar installieren, er erscheint dann aber nicht unter Instanzen. Somit kann ich ihn auch nicht konfigurieren. Mach ich was falsch?
                            LG
                            Michael
                              @Bobohne:
                              Kann den Adapter zwar installieren `
                              gut!
                              @Bobohne:
                              er erscheint dann aber nicht unter Instanzen `
                              ist üblicherweise immer so ;.)
                              hast du denn versucht eine Instanz anzulegen?
                              http://www.iobroker.net/docu/?page_id=1 … _Instanzen
                              Rainer
                                @Homoran:
                                @Bobohne:
                                gut!
                                @Bobohne:
                                Rainer `
                                Jetzt funktionierts! Danke! 😄
                                Wie peinlich :oops:
                                Mal eine Frage. Ist es möglich mit dem Adapter eine Nachricht auf dem TV einblenden zu lassen? Gibt die API das her?
                                LG
                                Michael
                                • ldittmar
                                  @Bobohne:
                                  LG
                                  Michael `
                                  Hi Michael,
                                  leider nicht und da ich kein Panasonic TV besitze, wird auch schwierig neue Funktionen einzubauen. Wenn es aber eine Anleitung dazu gibt, baue ich es gerne ein 😉
                                  Grüße,
                                  ldittmar
                                    schittl last edited by
                                    Danke, der Adapter funktioniert. Sehr gute Arbeit. Mein TV ist ein TX-P50GT50E. Das Einschalten funktioniert leider nicht. Ist aber kein Adapter-Problem sondern API-Problem. Ich habe gelesen, dass über WOL der TV eingeschaltet werden kann? Kann mir jemand sagen wie im Detail? @onkeltom9
                                    Derzeit nutze ich noch den Broadlink-Adapter, denn damit geht sogar das Einschalten zuverlässig 😄
                                    • ldittmar
                                      @schittl:
                                      Derzeit nutze ich noch den Broadlink-Adapter, denn damit geht sogar das Einschalten zuverlässig 😄 `
                                      habe ich gern gemacht… Ich schaue mal ob ich was mit der Einschaltfunktion machen kann. Wird zwar ohne Gerät eher so eine Ratestunde werden, aber das kriegen wir bestimmt hin. 😉
                                      Grüße,
                                      ldttmar
                                        > habe ich gern gemacht… Ich schaue mal ob ich was mit der Einschaltfunktion machen kann. Wird zwar ohne Gerät eher so eine Ratestunde werden, aber das kriegen wir bestimmt hin. ;)
                                        Das wäre prima. Würde mich natürlich dann auch zum testen anbieten 😉 Ich habe aber leider schon davon gelesen, dass dieses nicht möglich ist. War glaube ich bei fhem bzw. openhab. Das liegt wohl direkt an dem Typ, da man beim Einschalten den Power-Knopf länger halten muss, damit er startet. Wie bereits berichtet, nutze ich Broadlink fürs Einschalten. Damit funktioniert der "längere" Tastendruck. Also schlag Dir nicht deswegen soviel Stunden um die Ohren 😉 Finde ich aber echt klasse dein Engagement. TOP!!
                                        Hast Du oder gibt es vielleicht auch schon ne schöne VIS-Ansicht/Steuerung?
                                        mfg
                                        Falk
                                          TimoS. last edited by
                                          Vielen Dank, funktioniert bisher einwandfrei. Genau danach habe ich gesucht.
                                            wuchti last edited by
                                            Ich bin auch neu hier und möchte die Programme meines Panasonic Fernsehers über Alexa aufrufen.
                                            Ich habe die Programme umbenannt (D1 = ARD, D2=ZDF, etc..).
                                            Was muss ich machen, damit die Befehle im Cloud Adapter erscheinen, so dass ich sie über Alexa aufrufen kann?
                                            Der Cloud Adapter ist soweit konfiguriert meine Homematic Aktoren kann ich über steuern.
                                            Danke und Gruß Markus
                                            175
                                            30879
