    3. Entwicklung
    4. Adapter: Worx Landroid v2.x.x
    • falke69
      falke69 @Lucky_ESA last edited by
      @lucky_esa
      habe aktuell die v2.1.1 installiert.
      Jetzt war er das erste mal mit der Version des Adapters unterwegs.
      Das kam dabei raus.
      worx.0
         2023-04-17 16:54:06.862	info	Start MQTT connection
      worx.0
         2023-04-17 16:54:06.811	info	Autolock found! Create State : AutoLockTimer
      worx.0
         2023-04-17 16:54:06.805	info	Autolock found! Create State : AutoLock
      worx.0
         2023-04-17 16:54:06.757	info	ACS Module found! Create State : ACS_Status
      worx.0
         2023-04-17 16:54:06.749	info	ACS Module found! Create State : ACS
      worx.0
         2023-04-17 16:54:06.724	info	found torque control, create states...
      worx.0
         2023-04-17 16:54:06.215	info	Create product folder and states for WR141E
      worx.0
         2023-04-17 16:54:05.985	info	Create folder activityLog and set states.
      worx.0
         2023-04-17 16:54:05.728	info	found PartyModus, create states...
      worx.0
         2023-04-17 16:54:05.650	info	found available firmware, create states...
      worx.0
         2023-04-17 16:54:05.648	info	found OneTimeShedule, create states...
      worx.0
         2023-04-17 16:54:05.575	info	found DoubleShedule, create states...
      worx.0
         2023-04-17 16:54:05.246	info	Found device Horst with id xxxxxxxxxxxxxxxx
      worx.0
         2023-04-17 16:54:05.245	info	Found 1 devices
      worx.0
         2023-04-17 16:54:04.973	info	Connected to worx server
      worx.0
         2023-04-17 16:54:03.772	info	Login to worx
      worx.0
         2023-04-17 16:54:03.723	info	starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.worx, node: v18.16.0, js-controller: 4.0.24
      worx.0
         2023-04-17 16:54:03.261	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      worx.0
         2023-04-17 16:53:29.453	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      worx.0
         2023-04-17 16:53:29.450	info	terminating
      worx.0
         2023-04-17 16:53:29.437	error	Unexpected token
      Ob das nur eine einmalige Sache war, kann ich nicht beurteilen.
      Ich beobahte einfach mal weiter. 🙂
      Ansonsten sehr gute Arbeit 👍 👍 👍
        emil70 last edited by emil70
        Habe mein Mäher auch mal wieder aktiviert und den Adapter upgedatet.
        Nutzte die VIS mit Blockly und kann noch keinen Fehlereintrag oder Sperrung sehen. Habe am Blockly nix geändert
          Lucky_ESA Developer Most Active @emil70 last edited by
          @emil70 auch dieses Blockly muss angepasst werden sonst wird es nicht funktionieren.
          Gruß//Lucky
            saeft_2003 Most Active @Lucky_ESA last edited by
            @lucky_esa
            Ich habe am Freitag das Update auf 2.1.0 gemacht und heute ist er nicht losgefahren. Was genau muss denn im blockly angepasst werden?
            L falke69 2 Replies Last reply Reply Quote 0
              Lucky_ESA Developer Most Active @saeft_2003 last edited by
              @saeft_2003 Welches Blockly benutzt du? Bitte einen Link posten.
              Gruß//Lucky
                @lucky_esa
                Einen link hab ich nicht. Das nutze ich schon seit Jahren, weiß gar nicht mehr wo ich das her hatte…
                Kannst du mir sagen was geändert wurde dann geh ich im Skript auf die Suche.
                  Lucky_ESA Developer Most Active @saeft_2003 last edited by Lucky_ESA
                  @saeft_2003 ist alles hier im Thread beschieben.
                  Link
                  Es gibt auch Blocklys die um Mitternacht den letzten und aktuellen Tag auf 00:00 setzt. Das kann man auch reduzieren auf Sonntag 00:00 Uhr alle 7 Tage auf 00:00 setzen.
                  Gruß//Lucky
                    Semmy @Lucky_ESA last edited by
                    @lucky_esa sagte in Adapter: Worx Landroid v2.x.x:
                    Link
                    Gruß//Lucky
                    Hallo
                    Wie macht man das mit diesen Blockly?
                    Viele Grüße
                    Semmy
                    • falke69
                      falke69 @saeft_2003 last edited by
                      @saeft_2003
                      ich habe es so gemacht:
                      Einfach die ganzen Timeouts entfernt und dann den Datenpunkt worx.0.xxxxxxxxxxx.calendar.calJson_tosend nach 15 Sekunden auf wahr gesetzt.
                      Dein Hinweis mit dem Zurücksetzen der Zeiten am Sonntag wäre auch noch eine Option, muss man auch nicht unbedingt täglich machen.👍
                        emil70 @falke69 last edited by
                        @falke69
                        Reicht es nur in dem Part
                        Datensetzung 3min vor Startzeit
                        vom ganzen Blockly das anzupassen?
                        falke69 1 Reply Last reply Reply Quote 0
                        • falke69
                          falke69 @emil70 last edited by
                          @emil70
                          ich habe bei Löschung des von vor zwei Tagen um 00:01
                          ganz unten nochmal einen Trigger auf worx.0.xxxxxxxxxxx.calendar.calJson_tosend gesetzt.
                          Bisher funktioniert das ganze. Ich bin mir noch nicht sicher, ob ich die ganzen Timeouts da drüber weglassen kann, bzw. das ganze umbaue, damit es nur einmal in der Woche gesendet wird und nicht täglich.
                            Lucky_ESA Developer Most Active last edited by Lucky_ESA
                            @emil70
                            @falke69
                            Ihr habt ja beide das gleiche Blockly. Hier mal eine angepasste Version die ihr zum Abgleich nehmen könnt.
                            Geändert habe ich die Anlage der DP, Zeiten_setzen, Zeiten_setzen2 gelöscht, 3 Minuten vor Start 2 x gelöscht und neu erstellt, 2 x Mitternacht reset gelöscht und eine neue erstellt und ein neuer Block für Sonntags alles auf Null setzen.
                            maeher_28_04_2023.txt
                            Achtung! Habe ich nicht getestet!!!!
                            Gruß//Lucky
                              lessthanmore last edited by lessthanmore
                              Versuche gerade die 2.1.3 zu installieren, aber wir der Adapter ohne Beschreibung und Titel angezeigt und ein Update funktioniert nicht.
                              Die Installation schließt (erfolgreich) mit 0 ab, aber der Adapter bleibt auf 2.1.1.
                              Ist der Issue bekannt?
                              /edit: Repot ist Stable. Im Beta Repo wird die 2.1.2 angezeigt.
                                tombox @lessthanmore last edited by
                                @lessthanmore probier mal nochmal
                                  lessthanmore @tombox last edited by
                                  @tombox Ist jetzt installiert, aber einen Namen und Beschreibung hat der Adapter nicht mehr.
                                  • falke69
                                    falke69 @lessthanmore last edited by
                                    @lessthanmore
                                    bei mir scheint alles funktioniert zu haben
                                      lessthanmore @falke69 last edited by
                                      @falke69 Das ist ja die Instanz. Schau mal in die Adapterliste. Da sollte er dann ohne Name und Beschreibung ganz oben auftauchen.
                                      • falke69
                                        @lessthanmore
                                        stimmt, sieht bei mir auch so aus.
                                        Brauche warscheinlich doch mal ne Brille. 🙂
                                          Kann ich nicht bestätigen.
                                          Gruß//Lucky
                                            lessthanmore @Lucky_ESA last edited by lessthanmore
                                            @lucky_esa Ja, weil dein Rep auf Beta steht. Stell es um auf Stable und dann solltest du es sehen.
                                            1194
                                            456633
