    3. Off Topic
    4. Neustart von Raspberry
    • Gargano
      Gargano @Codierknecht last edited by
      @codierknecht
      Woher kommt eigentlich der Zeitsprung von Apr 20 09:34:38 nach Apr 20 09:17:05 in der nächsten Zeile vom syslog ?
      iob diag :
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       10:33:15 up 45 min,  1 user,  load average: 1.56, 1.56, 1.30
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=47.7'C
      volt=0.9060V
      *** Time and Time Zones ***
                     Local time: Thu 2023-04-20 10:33:15 CEST
                 Universal time: Thu 2023-04-20 08:33:15 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            7.8G        4.2G        2.2G        0.0K        1.4G        3.5G
      Swap:            99M          0B         99M
      Total:          7.9G        4.2G        2.3G
               7811 M total memory
               4173 M used memory
               4654 M active memory
                738 M inactive memory
               2235 M free memory
                 88 M buffer memory
               1314 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      113G   16G   93G  15% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  868K  1.6G   1% /run
      /dev/sda1      vfat      253M   31M  222M  13% /boot
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Thu Apr 20 09:47:21 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:49:70:4C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=d1247dc3-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Thu Apr 20 09:47:23 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Thu Apr 20 09:47:23 2023] EXT4-fs (sda2): write access will be enabled during recovery
      [Thu Apr 20 09:47:23 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Thu Apr 20 09:47:23 2023] EXT4-fs (sda2): 15 orphan inodes deleted
      [Thu Apr 20 09:47:23 2023] EXT4-fs (sda2): recovery complete
      [Thu Apr 20 09:47:23 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Thu Apr 20 09:47:23 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Thu Apr 20 09:47:25 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      6.5G    /var/
      4.0G    /var/log/journal/56316a157fb543a194ea0c2f0809a8d2
      4.0G    /var/log
      2.2G    /var/lib
      Archived and active journals take up 3.9G in the file system.
      /opt/iobroker/backups:
      2.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      12M     /opt/iobroker/iobroker-data/
      1.1M    /opt/iobroker/iobroker-data/files
      472K    /opt/iobroker/iobroker-data/files/discovery.admin
      384K    /opt/iobroker/iobroker-data/files/backitup.admin
      252K    /opt/iobroker/iobroker-data/files/admin.admin
      5.2M    /opt/iobroker/iobroker-data/objects.json.bak
      200K    /opt/iobroker/iobroker-data/files/discovery.admin/words.js
      148K    /opt/iobroker/iobroker-data/files/backitup.admin/words.js
      120K    /opt/iobroker/iobroker-data/files/discovery.admin/index_m.html
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.15.0
      /usr/bin/node           v18.15.0
      /usr/bin/npm            9.5.0
      /usr/bin/npx            9.5.0
      nodejs:
        Installed: 18.15.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
           18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
       *** 18.15.0-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           16.19.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.4.3
      javascript:     7.0.3
      Adapters from github:   1
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              - disabled
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      + system.adapter.e3dc-rscp.0              : e3dc-rscp             : raspberrypi                              -  enabled
        system.adapter.easee.0                  : easee                 : raspberrypi                              - disabled
        system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
      + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.javascript.1             : javascript            : raspberrypi                              -  enabled
      + system.adapter.javascript.2             : javascript            : raspberrypi                              -  enabled
      + system.adapter.javascript.3             : javascript            : raspberrypi                              -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
        system.adapter.linux-control.0          : linux-control         : raspberrypi                              - disabled
        system.adapter.meteoalarm.0             : meteoalarm            : raspberrypi                              -  enabled
      + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, port: 1884, bind: 192.168.178.35
      + system.adapter.mqtt.2                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 192.168.178.35
      + system.adapter.mqtt.3                   : mqtt                  : raspberrypi                              -  enabled, port: 1890, bind: 0.0.0.0
      + system.adapter.mqtt.4                   : mqtt                  : raspberrypi                              -  enabled, port: 1888, bind: 0.0.0.0
      + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
        system.adapter.proxy.0                  : proxy                 : raspberrypi                              -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      + system.adapter.pushover.1               : pushover              : raspberrypi                              -  enabled
      + system.adapter.resol.0                  : resol                 : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        system.adapter.vis-2-beta.0             : vis-2-beta            : raspberrypi                              - disabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
        system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : raspberrypi                              -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
      + system.adapter.wiffi-wz.0               : wiffi-wz              : raspberrypi                              -  enabled
      + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
      + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D9CD6C-if00
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Live (stable) : http://repo.iobroker.live/sources-dist.json
      Live (latest) : http://repo.iobroker.live/sources-dist-latest.json
      Active repo(s): Beta (latest)
      Installed ioBroker-Instances
      Used repository: Beta (latest)
      Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
      Adapter    "admin"        : 6.4.3    , installed 6.4.3
      Adapter    "backitup"     : 2.6.18   , installed 2.6.17 [Updatable]
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "device-watcher": 2.8.4   , installed 2.8.4
      Adapter    "devices"      : 1.1.2    , installed 1.1.1  [Updatable]
      Adapter    "e3dc-rscp"    : 1.1.2    , installed 1.1.2
      Adapter    "easee"        : 1.0.7    , installed 1.0.7
      Adapter    "echarts"      : 1.4.13   , installed 1.4.13
      Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "logparser"    : 2.1.2    , installed 2.1.2
      Adapter    "meteoalarm"   : 2.3.5    , installed 2.3.5
      Adapter    "mielecloudservice": 6.5.0, installed 6.4.0  [Updatable]
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "resol"        : 1.3.0    , installed 1.3.0
      Adapter    "socketio"     : 6.3.5    , installed 6.3.5
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-2-widgets-energy": 0.1.12, installed 0.1.12
      Adapter    "vis-2-widgets-gauges": 0.1.12, installed 0.1.12
      Adapter    "vis-2-widgets-material": 0.2.13, installed 0.2.13
      Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "web"          : 5.5.3    , installed 5.5.3
      Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
      Adapter    "worx"         : 2.1.3    , installed 2.1.2  [Updatable]
      Adapter    "ws"           : 2.3.6    , installed 2.3.6
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects:        13305
      States:         11985
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 10
      *** Listening Ports ***
      tcp        0      0 192.168.178.35:8181     0.0.0.0:*               LISTEN      1001       17101      1756/io.wiffi-wz.0
      tcp        0      0 192.168.178.35:2010     0.0.0.0:*               LISTEN      1001       17694      1563/io.hm-rpc.2
      tcp        0      0 192.168.178.35:2001     0.0.0.0:*               LISTEN      1001       12184      1053/io.hm-rpc.0
      tcp        0      0 192.168.178.35:2000     0.0.0.0:*               LISTEN      1001       16678      1154/io.hm-rpc.1
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        13899      488/redis-server 12
      tcp        0      0 127.0.0.1:38989         0.0.0.0:*               LISTEN      999        13956      414/influxd
      tcp        0      0 192.168.178.35:1886     0.0.0.0:*               LISTEN      1001       17512      1227/io.mqtt.2
      tcp        0      0 192.168.178.35:1885     0.0.0.0:*               LISTEN      1001       17511      1227/io.mqtt.2
      tcp        0      0 192.168.178.35:1884     0.0.0.0:*               LISTEN      1001       16130      1404/io.mqtt.1
      tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1001       16906      1517/io.mqtt.3
      tcp        0      0 0.0.0.0:1891            0.0.0.0:*               LISTEN      1001       16907      1517/io.mqtt.3
      tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       16708      1174/io.mqtt.4
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18521      1337/io.mqtt.0
      tcp        0      0 192.168.178.35:8701     0.0.0.0:*               LISTEN      1001       17419      1091/io.hm-rpc.3
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15381      513/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21780      2946/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12196      1030/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        11698      414/influxd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22636      2934/io.simple-api.
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       18885      1928/io.ws.0
      tcp6       0      0 :::20002                :::*                    LISTEN      1001       17206      2142/io.web.1
      tcp6       0      0 ::1:6379                :::*                    LISTEN      109        13900      488/redis-server 12
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15383      513/sshd: /usr/sbin
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       18854      1714/io.broadlink2.
      udp        0      0 0.0.0.0:40293           0.0.0.0:*                           1001       18856      1714/io.broadlink2.
      udp        0      0 0.0.0.0:45032           0.0.0.0:*                           1001       17765      1714/io.broadlink2.
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13914      775/dhcpcd
      udp        0      0 0.0.0.0:45249           0.0.0.0:*                           108        13753      389/avahi-daemon: r
      udp        0      0 192.168.178.35:5353     0.0.0.0:*                           1001       12193      1013/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13751      389/avahi-daemon: r
      udp6       0      0 :::33251                :::*                                108        13754      389/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13940      775/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        13752      389/avahi-daemon: r
      2023-04-20 09:50:18.053  - info: vis-google-fonts.0 (2344) Terminated (NO_ERROR): Without reason
      2023-04-20 09:50:18.932  - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
      2023-04-20 09:50:19.915  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 2632
      2023-04-20 09:50:23.814  - info: host.raspberrypi instance system.adapter.accuweather.0 started with pid 2778
      2023-04-20 09:50:27.909  - info: host.raspberrypi instance scheduled system.adapter.meteoalarm.0 */10 * * * *
      2023-04-20 09:50:31.822  - info: host.raspberrypi instance system.adapter.worx.0 started with pid 2918
      2023-04-20 09:50:35.872  - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 2934
      2023-04-20 09:50:39.897  - info: host.raspberrypi instance system.adapter.web.0 started with pid 2946
      2023-04-20 09:50:43.996  - info: host.raspberrypi instance system.adapter.e3dc-rscp.0 started with pid 2965
      2023-04-20 09:50:51.264  - error: javascript.0 (961) Cannot create directory /home/iobroker/iobroker-data/js-scripte/: Error: ENOENT: no such file or directory, mkdir '/home/iobroker/iobroker-data/js-scripte/'
      2023-04-20 09:50:54.670  - warn: javascript.1 (990) script.js.Monitoring.CheckCCUFirmwareUpdate: Fehler bei der Abfrage der Firmware: AxiosError: timeout of 4500ms exceeded
      2023-04-20 10:00:00.267  - info: host.raspberrypi instance system.adapter.meteoalarm.0 started with pid 3931
      2023-04-20 10:00:04.297  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 3992
      2023-04-20 10:00:05.417  - info: host.raspberrypi instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-04-20 10:00:13.391  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2023-04-20 10:10:00.130  - info: host.raspberrypi instance system.adapter.meteoalarm.0 started with pid 4953
      2023-04-20 10:10:05.288  - info: host.raspberrypi instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-04-20 10:20:00.138  - info: host.raspberrypi instance system.adapter.meteoalarm.0 started with pid 5970
      2023-04-20 10:20:05.456  - info: host.raspberrypi instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-04-20 10:30:00.205  - info: host.raspberrypi instance system.adapter.meteoalarm.0 started with pid 6979
      2023-04-20 10:30:04.249  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 7039
      2023-04-20 10:30:05.168  - info: host.raspberrypi instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-04-20 10:30:13.477  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2023-04-20 10:33:00.250  - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 7316
      2023-04-20 10:33:39.063  - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                           v.2023-04-16
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Kernel:                 6.1.19-v8+
      Installation:           Native
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     10
      Pending iob updates:    4
      Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                              /usr/bin/npm            9.5.0
                              /usr/bin/npx            9.5.0
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            7.8G        4.5G        1.7G        0.0K        1.7G        3.2G
      Swap:            99M          0B         99M
      Total:          7.9G        4.5G        1.8G
      Active iob-Instances:   43
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.4.3
      Objects type: redis
      States  type: redis
      Objects:                13305
      States:                 11985
      Size of iob-Database:
      40K     /opt/iobroker/iobroker-data/states.json.bak
      Codierknecht Homoran 2 Replies Last reply Reply Quote 0
      • Codierknecht
        Codierknecht Developer Most Active @Gargano last edited by
        @gargano
        Mal abgesehen von den 10 fehlenden OS-Updates sieht das für mich unverdächtig aus.
        Bootet die Kiste regelmäßig neu?
        Gargano 1 Reply Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Gargano last edited by
          @gargano sagte in Neustart von Raspberry:
          ich tippe mal
          RTC in local TZ: no
          • Gargano
            @codierknecht sagte in Neustart von Raspberry:
            Nicht regelmäßig, aber in letzter Zeit häufiger. Alle paar Wochen.
            Ich habe auch den Watchdog aktiviert, damit der Raspi neu started wenn er mal hängt.
            Einstellung :
            file                    = /var/log/syslog
            change                  = 1407
            max-load-1              = 75
            Ich habe aber diesmal im syslog kein Watchdog gesehen.
            • N
              Nordischerjung @Gargano last edited by
              @gargano Spannungsversorgung noch OK?
              Gargano 2 Replies Last reply Reply Quote 0
              • Gargano
                Gargano @Nordischerjung last edited by Gargano
                @nordischerjung
                Ja, original Netzteil
                • Gargano
                  @nordischerjung Was mir grad eingefallen ist, der Restart war beim Update von BackitUp
                    TT-Tom @Gargano last edited by TT-Tom
                    @gargano Wo schiebst du das Backup hin?? War es seit dem Update?
                    • Gargano
                      Gargano @TT-Tom last edited by
                      @tt-tom sagte in Neustart von Raspberry:
                      Google Drive.
                      Der Reboot beim Update war jetzt das erste mal.
                      Jetzt läuft er wieder ganz normal.
                      Htop zeigt auch nichts Verdächtiges.
                        @gargano
                        in deinem iob diag steht der Adapter "backitup" : 2.6.18 , installed 2.6.17 [Updatable] immer noch so. ist das Update sauber durchgelaufen?
                        • Gargano
                          Gargano @TT-Tom last edited by Gargano
                          Während des Updates hat er ja neu gebootet.
                          Nach dem Restart war der Backitup noch auf 2.6.17. Ich habe jetzt das Update nochmal laufen lassen, ohne Probleme.
                          Warum der Raspi beim Update neu gebootet hat, ist mir schleierhaft.
                          Aber die Frage war ja , ob man aus dem syslog was erkennen kann
                          N T 2 Replies Last reply Reply Quote 0
                          • N
                            Da musst du bestimmt noch mehr Log liefern vor 09:17
                              @gargano vielleicht kündigt sich da ein Speicherproblem mit der SD Karte an. nur so eine Vermutung
                              • Gargano
                                Ich hab eine ssd
                                • Gargano
                                  @nordischerjung
                                  Log :syslog.txt
                                  Der Permission denied kommt vom rpi Adapter
                                  • Gargano
                                    Gargano @Homoran last edited by
                                    @homoran sagte in Neustart von Raspberry:
                                    RTC in local TZ: no
                                    Muss ich das ändern ?
                                      Thomas Braun Most Active @Gargano last edited by
                                      @gargano
                                      Der Raspberry hat keine RTC (real time clock), da kannst du so erstmal nix ändern.
                                      Aber das Dateisystem hatte ein paar Einschläge zu verzeichnen:
                                      Ich würde das auf ein frisches Speichermedium neuaufsetzen.
                                      753
