    4. [HowTo] ioBroker Restore unter Linux durchführen
      Thomas Braun Most Active @Sebi_7_6 last edited by
      @sebi_7_6 sagte in [HowTo] ioBroker Restore unter Linux durchführen:
      Wo liegt hier das Problem?
      Keine Ahnung. Log File sagt?
        Sebi_7_6 @Thomas Braun last edited by Sebi_7_6
        Nix.
        backitup.0
        2023-04-22 18:13:34.853 info [iobroker] backup was activated at 02:40 every 1 day(s)
        backitup.0
        2023-04-22 18:13:34.561 info starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
        backitup.0
        2023-04-22 17:58:20.510 info Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        backitup.0
        2023-04-22 17:58:20.476 info Got terminate signal TERMINATE_YOURSELF
        backitup.0
        2023-04-22 17:58:20.342 info cleaned everything up...
          @sebi_7_6
          Schau per
          iob logs --watch | uniq
          dem Backup in der Konsole zu.
            @thomas-braun said in [HowTo] ioBroker Restore unter Linux durchführen:
            irgendwie stoppt er nur alles...Ab 18:23:30 habe ich die Wiederherstellung gestartet.
            2023-04-22 18:23:30.999  - info: bring.0 (10071) [END] Stopping Bring! adapter...
            2023-04-22 18:23:31.013  - info: host.raspberrypi received SIGTERM
            2023-04-22 18:23:31.019  - info: backitup.0 (9766) cleaned everything up...
            2023-04-22 18:23:30.999  - info: trashschedule.0 (9969) cleaned everything up...
            2023-04-22 18:23:31.033  - info: admin.0 (9373) terminating http server on port 8081
            2023-04-22 18:23:31.034  - info: wled.0 (10341) cleaned everything up...
            2023-04-22 18:23:31.025  - info: accuweather.0 (9854) cleaned everything up...
            2023-04-22 18:23:31.022  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
            2023-04-22 18:23:31.025  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=true)
            2023-04-22 18:23:31.028  - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
            2023-04-22 18:23:31.030  - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=true)
            2023-04-22 18:23:31.033  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
            2023-04-22 18:23:31.035  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
            2023-04-22 18:23:31.037  - info: host.raspberrypi stopInstance system.adapter.accuweather.0 (force=false, process=true)
            2023-04-22 18:23:31.040  - info: host.raspberrypi stopInstance system.adapter.iot.0 (force=false, process=false)
            2023-04-22 18:23:31.047  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=true)
            2023-04-22 18:23:31.049  - info: host.raspberrypi stopInstance system.adapter.bring.0 (force=false, process=true)
            2023-04-22 18:23:31.050  - info: host.raspberrypi stopInstance system.adapter.daswetter.0 (force=false, process=false)
            2023-04-22 18:23:31.053  - info: host.raspberrypi stopInstance canceled schedule system.adapter.daswetter.0
            2023-04-22 18:23:31.054  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
            2023-04-22 18:23:31.056  - info: host.raspberrypi stopInstance system.adapter.habpanel.0 (force=false, process=false)
            2023-04-22 18:23:31.057  - info: host.raspberrypi stopInstance system.adapter.wled.0 (force=false, process=true)
            2023-04-22 18:23:31.160  - info: bring.0 (10071) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2023-04-22 18:23:31.182  - info: alexa2.0 (9495) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2023-04-22 18:23:31.188  - info: admin.0 (9373) Got terminate signal TERMINATE_YOURSELF
            2023-04-22 18:23:31.200  - info: backitup.0 (9766) Got terminate signal TERMINATE_YOURSELF
            2023-04-22 18:23:31.202  - info: accuweather.0 (9854) Got terminate signal TERMINATE_YOURSELF
            2023-04-22 18:23:31.208  - info: bring.0 (10071) Got terminate signal TERMINATE_YOURSELF
            2023-04-22 18:23:31.195  - info: tuya.0 (9601) Got terminate signal TERMINATE_YOURSELF
            2023-04-22 18:23:31.205  - info: trashschedule.0 (9969) Got terminate signal TERMINATE_YOURSELF
            2023-04-22 18:23:31.192  - info: alexa2.0 (9495) Got terminate signal TERMINATE_YOURSELF
            2023-04-22 18:23:31.230  - info: web.0 (10270) Got terminate signal TERMINATE_YOURSELF
            2023-04-22 18:23:31.220  - info: wled.0 (10341) Got terminate signal TERMINATE_YOURSELF
            2023-04-22 18:23:31.237  - info: admin.0 (9373) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2023-04-22 18:23:31.224  - info: discovery.0 (9680) Got terminate signal TERMINATE_YOURSELF
            2023-04-22 18:23:31.244  - info: backitup.0 (9766) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2023-04-22 18:23:31.244  - info: wled.0 (10341) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2023-04-22 18:23:31.253  - info: trashschedule.0 (9969) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2023-04-22 18:23:31.276  - info: discovery.0 (9680) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2023-04-22 18:23:31.286  - info: accuweather.0 (9854) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2023-04-22 18:23:31.289  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
            2023-04-22 18:23:31.305  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal
            2023-04-22 18:23:31.307  - info: host.raspberrypi stopInstance system.adapter.tuya.0 send kill signal
            2023-04-22 18:23:31.309  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
            2023-04-22 18:23:31.310  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
            2023-04-22 18:23:31.311  - info: host.raspberrypi stopInstance system.adapter.accuweather.0 send kill signal
            2023-04-22 18:23:31.312  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 send kill signal
            2023-04-22 18:23:31.313  - info: host.raspberrypi stopInstance system.adapter.bring.0 send kill signal
            2023-04-22 18:23:31.314  - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
            2023-04-22 18:23:31.315  - info: host.raspberrypi stopInstance system.adapter.wled.0 send kill signal
            2023-04-22 18:23:31.496  - info: web.0 (10270) terminated http server on port 8082
            2023-04-22 18:23:31.510  - info: web.0 (10270) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2023-04-22 18:23:31.808  - info: host.raspberrypi instance system.adapter.bring.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-04-22 18:23:31.917  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-04-22 18:23:32.107  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-04-22 18:23:32.115  - info: host.raspberrypi instance system.adapter.wled.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-04-22 18:23:32.227  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-04-22 18:23:32.229  - info: host.raspberrypi instance system.adapter.accuweather.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-04-22 18:23:32.231  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-04-22 18:23:32.272  - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-04-22 18:23:32.349  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-04-22 18:23:34.043  - info: tuya.0 (9601) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2023-04-22 18:23:34.663  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
            2023-04-22 18:23:34.665  - info: host.raspberrypi All instances are stopped.
            2023-04-22 18:23:34.804  - info: host.raspberrypi terminated
              Wollte mein Backup einspiele und er sagt Wiederherstellung wird gestartet
              Was machst du da genau?
                Stelle meine Sicherung wieder her .
                  @sebi_7_6
                  Mach es mal komplett im Terminal.
                  iobroker restore <backup name or path>
                    iobroker controller daemon is not running
                    host.raspberrypi OK.
                    The current version of js-controller differs from the version in the backup.
                    The js-controller version of the backup can not be restored automatically.
                    To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.23 --production" inside your ioBroker directory
                    If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                      Dann hast du ja den Grund.
                        Jaja 🙂 Warum sagt er mir das in der GUI nicht. Denke jeder hat nich immer sein Version aktuell obwohl ich es eigentlich dachte, dass sie es wäre.
                        Und was mache ich jetzt ?
                          @sebi_7_6
                          Steht doch da. Die alte Version installieren.
                          Dann passt auch das Backup da wieder rein.
                          Weil GUIs notorisch lügen und Informationen zurückhalten.
                          Bitte gewöhn dir an für Texte aus der Konsole die CodeTags zu verwenden.
                            Danke für den Hinweis.
                            Ich danke dir aufjedenfall recht Herzlich für deine Hilfe!
                              Das Backup hat soweit funktioniert nur das HABPanel nicht. Hab es entfernt und die Instanz wieder neu installiert.
                              Aber es steht immer 2x drinn. Clicke ich drauf kommt so etwas ..
                              URIError: Failed to decode param '%web_protocol%://%web_bind%:%web_port%/habpanel/index.html'
                                  at decodeURIComponent (<anonymous>)
                                  at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12)
                                  at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15)
                                  at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:585:18)
                                  at next (/opt/iobroker/node_modules/express/lib/router/index.js:226:15)
                                  at compression (/opt/iobroker/node_modules/compression/index.js:220:5)
                                  at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
                                  at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13)
                                  at /opt/iobroker/node_modules/express/lib/router/index.js:286:9
                                  at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
                              • Glasfaser
                                Glasfaser @Sebi_7_6 last edited by
                                Was entfernt , nur die Instanz ... oder auch den Adapter !?
                                Zeige mal
                                iob diag
                                  Sebi_7_6 last edited by Sebi_7_6
                                  Beides
                                  Adapter State
                                    system.adapter.accuweather.0            : accuweather           : raspberrypi                              - disabled
                                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                  + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
                                    system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                                    system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                    system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                    system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                    system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                    system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              - disabled
                                    system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
                                  + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                    system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
                                  + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
                                    system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
                                    system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              - disabled
                                  + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                  + system.adapter.pushbullet.0             : pushbullet            : raspberrypi                              -  enabled
                                    system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              - disabled
                                    system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
                                  + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
                                    system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
                                    system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                                  + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                  + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                    system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                                    system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                                  + instance is alive
                                  ioBroker-Repositories
                                  Active repo(s): stable
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
                                  Adapter    "admin"        : 6.3.5    , installed 6.2.17 [Updatable]
                                  Adapter    "alexa2"       : 3.23.2   , installed 3.19.9 [Updatable]
                                  Adapter    "backitup"     : 2.6.16   , installed 2.4.10 [Updatable]
                                  Adapter    "bring"        : 1.8.1    , installed 1.8.1
                                  Adapter    "cloud"        : 4.3.0    , installed 4.2.2  [Updatable]
                                  Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                                  Adapter    "discovery"    : 3.1.0    , installed 3.0.3  [Updatable]
                                  Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                  Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                  Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                                  Adapter    "ical"         : 1.13.2   , installed 1.13.2
                                  Adapter    "iot"          : 1.14.2   , installed 1.11.9 [Updatable]
                                  Adapter    "javascript"   : 6.1.4    , installed 6.0.0  [Updatable]
                                  Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
                                  Adapter    "lg-thinq"     : 0.1.4    , installed 0.0.7  [Updatable]
                                  Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
                                  Adapter    "openweathermap": 0.3.3   , installed 0.3.3
                                  Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                  Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
                                  Adapter    "schoolfree"   : 1.1.1    , installed 1.0.1  [Updatable]
                                  Adapter    "smartthings"  : 0.0.4    , installed 0.0.3  [Updatable]
                                  Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
                                  Adapter    "tr-064"       : 4.2.18   , installed 4.2.16 [Updatable]
                                  Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                  Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                                  Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
                                  Adapter    "wled"         : 0.6.7    , installed 0.6.7
                                  Objects and States
                                  Objects:        9978
                                  States:         8091
                                  Wie ich gesehen habe ist es bei der VIS genauso.
                                  Hab jetzt beide deinstalliert und nur HABPanel wieder installiert.
                                  Aber es erscheint wieder 2x im Dashboard und dann der Fehler wenn man ihn aufruft.
                                  da ist auch nichts zum starten oder Einstellungen usw.
                                    Habedere last edited by Habedere
                                    habe die Tage auch mein Backup neu eingespielt und hab etwas Probleme...
                                    Los gings hiermit:
                                    No connection to states 127.0.0.1:6379
                                    Hab dann redis neu installiert. Soweit so gut...
                                    Nun wie folgt probiert bzw. Fehlermeldung erhalten:
                                    nulu@raspberrypi:~ $ iobroker stop
                                    iobroker host this
                                    iobroker start
                                    A host with the name "raspberrypi" already exists!
                                    Scheint aktiv zu sein, kann aber nicht darauf zugreifen:
                                    nulu@raspberrypi:~ $ iobroker list instances
                                      system.adapter.awattar.0                : awattar               : raspberrypi                              - disabled
                                      system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
                                      system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
                                      system.adapter.discovergy.0             : discovergy            : raspberrypi                              - disabled
                                      system.adapter.easee.0                  : easee                 : raspberrypi                              - disabled
                                      system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                                      system.adapter.history.0                : history               : raspberrypi                              - disabled
                                      system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
                                      system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 0
                                      system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                                      system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                                      system.adapter.modbus.3                 : modbus                : raspberrypi                              - disabled
                                      system.adapter.modbus.4                 : modbus                : raspberrypi                              - disabled
                                      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                                      system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
                                      system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                      system.adapter.solarwetter.0            : solarwetter           : raspberrypi                              - disabled
                                      system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
                                      system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              - disabled
                                      system.adapter.sql.0                    : sql                   : raspberrypi                              - disabled, port: 3306
                                      system.adapter.statistics.0             : statistics            : raspberrypi                              - disabled
                                      system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                                      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                      system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
                                      system.adapter.yamaha.0                 : yamaha                : raspberrypi                              - disabled
                                      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyUSB0
                                    + instance is alive
                                    Jemand einen Tipp wo ich ansezten kann?
                                    PS: hier noch der vollständige Diag
                                    Skript v.2023-04-16
                                    *** BASE SYSTEM ***
                                    Model           : Raspberry Pi 3 Model B Rev 1.2
                                    Architecture    : aarch64
                                    Docker          : false
                                    Virtualization  : none
                                    Distributor ID: Debian
                                    Description:    Debian GNU/Linux 11 (bullseye)
                                    Release:        11
                                    Codename:       bullseye
                                    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                    NAME="Debian GNU/Linux"
                                    VERSION_ID="11"
                                    VERSION="11 (bullseye)"
                                    VERSION_CODENAME=bullseye
                                    ID=debian
                                    HOME_URL="https://www.debian.org/"
                                    SUPPORT_URL="https://www.debian.org/support"
                                    BUG_REPORT_URL="https://bugs.debian.org/"
                                    Systemuptime and Load:
                                     16:57:57 up 7 min,  1 user,  load average: 0.39, 0.39, 0.22
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    Other values than 0x0 hint to temperature/voltage problems
                                    temp=55.3'C
                                    volt=1.3000V
                                    *** Time and Time Zones ***
                                                   Local time: Tue 2023-04-25 16:57:58 CEST
                                               Universal time: Tue 2023-04-25 14:57:58 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** User and Groups ***
                                    nulu
                                    /home/nulu
                                    nulu adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                    *** X-Server-Setup ***
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    Boot Target:    multi-user.target
                                    *** MEMORY ***
                                    Mem:            909M        150M        540M        1.0M        218M        702M
                                    Swap:            99M          0B         99M
                                    Total:          1.0G        150M        640M
                                              909 M total memory
                                              150 M used memory
                                              233 M active memory
                                               62 M inactive memory
                                              540 M free memory
                                               18 M buffer memory
                                              199 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4      110G  2.8G  103G   3% /
                                    devtmpfs       devtmpfs  325M     0  325M   0% /dev
                                    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                                    tmpfs          tmpfs     182M  1.1M  181M   1% /run
                                    /dev/sda1      vfat      255M   31M  225M  13% /boot
                                    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                    [Tue Apr 25 16:50:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e2d113b0-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Tue Apr 25 16:50:13 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Tue Apr 25 16:50:13 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                    [Tue Apr 25 16:50:17 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                    Show mounted filesystems (real ones only):
                                    TARGET  SOURCE    FSTYPE OPTIONS
                                    /       /dev/sda2 ext4   rw,noatime
                                    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    644M    /var/
                                    271M    /var/lib
                                    196M    /var/cache
                                    191M    /var/cache/apt
                                    124M    /var/lib/mysql
                                    Archived and active journals take up 72.0M in the file system.
                                    /opt/iobroker/backups:
                                    4.0K    /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    47M     /opt/iobroker/iobroker-data/
                                    16M     /opt/iobroker/iobroker-data/files
                                    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                    14M     /opt/iobroker/iobroker-data/objects.jsonl
                                    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                    5.2M    /opt/iobroker/iobroker-data/states.jsonl
                                    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs         v18.16.0
                                    /usr/bin/node           v18.16.0
                                    /usr/bin/npm            9.5.1
                                    /usr/bin/npx            9.5.1
                                    nodejs:
                                      Installed: 18.16.0-deb-1nodesource1
                                      Candidate: 18.16.0-deb-1nodesource1
                                      Version table:
                                     *** 18.16.0-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                            100 /var/lib/dpkg/status
                                         12.22.12~dfsg-1~deb11u3 500
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                         12.22.5~dfsg-2~11u1 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    No problems detected
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    iobroker is not running on this host.
                                    Objects type: jsonl
                                    States  type: jsonl
                                    MULTIHOSTSERVICE/enabled: false
                                    Core adapters versions
                                    admin:          6.3.5
                                    javascript:     "javascript" not found
                                    Adapters from github:   0
                                    Adapter State
                                    + instance is alive
                                    Adapter    "admin"        : 6.3.5    , installed 6.3.5
                                    Adapter    "backitup"     : 2.6.16   , installed 2.5.9  [Updatable]
                                    Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                    Adapter    "history"      : 2.2.4    , installed 2.2.4
                                    Controller "js-controller": 4.0.24   , installed 4.0.24
                                    Objects and States
                                    Objects:        9496
                                    States:         83
                                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14720      558/sshd: /usr/sbin
                                    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        12805      612/mariadbd
                                    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      111        13827      544/redis-server 12
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14722      558/sshd: /usr/sbin
                                    tcp6       0      0 ::1:6379                :::*                    LISTEN      111        13828      544/redis-server 12
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12790      779/dhcpcd
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14624      432/avahi-daemon: r
                                    udp        0      0 0.0.0.0:44832           0.0.0.0:*                           108        14626      432/avahi-daemon: r
                                    udp6       0      0 :::60532                :::*                                108        14627      432/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        14625      432/avahi-daemon: r
                                    2023-04-25 16:58:01.301  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                                    2023-04-25 16:58:01.327  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2023-04-25 16:58:01.331  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                                    2023-04-25 16:58:01.332  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
                                    2023-04-25 16:58:05.120  - info: host.raspberrypi-Server  Error inMem-objects listening on port 6379: Error: listen EADDRINUSE: address already in use 127.0.0.1:6379
                                    2023-04-25 16:58:31.388  - error: host.raspberrypi No connection to databases possible, restart
                                    2023-04-25 16:58:31.401  - info: host.raspberrypi iobroker _restart
                                    2023-04-25 16:58:39.163  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                                    2023-04-25 16:58:39.176  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2023-04-25 16:58:39.179  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                                    2023-04-25 16:58:39.180  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
                                    2023-04-25 16:58:43.156  - info: host.raspberrypi-Server  Error inMem-objects listening on port 6379: Error: listen EADDRINUSE: address already in use 127.0.0.1:6379
                                    2023-04-25 16:59:09.234  - error: host.raspberrypi No connection to databases possible, restart
                                    2023-04-25 16:59:09.245  - info: host.raspberrypi iobroker _restart
                                    2023-04-25 16:59:16.522  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                                    2023-04-25 16:59:16.536  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2023-04-25 16:59:16.539  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                                    2023-04-25 16:59:16.541  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
                                    2023-04-25 16:59:20.553  - info: host.raspberrypi-Server  Error inMem-objects listening on port 6379: Error: listen EADDRINUSE: address already in use 127.0.0.1:6379
                                    2023-04-25 16:59:46.590  - error: host.raspberrypi No connection to databases possible, restart
                                    2023-04-25 16:59:46.602  - info: host.raspberrypi iobroker _restart
                                    2023-04-25 16:59:54.337  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                                    2023-04-25 16:59:54.353  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2023-04-25 16:59:54.356  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                                    2023-04-25 16:59:54.357  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
                                    Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                      Thomas Braun Most Active @Habedere last edited by
                                      @habedere
                                      iob start admin
                                      liefert?
                                        Habedere @Thomas Braun last edited by
                                        @thomas-braun sagte in [HowTo] ioBroker Restore unter Linux durchführen:
                                        iob start admin
                                        Garnichts
                                          @habedere
                                          Starte die Kiste komplett durch.
                                            Reboot mehrmals durchgeführt - keine Reaktion auf den Befehl
                                            backitup how-to restore restore backup
                                            76
                                            513
                                            130474
