    4. [Gelöst] Blockly-script zur steuerung Aussenbeleuchtung mit Bewegungsmelder
      sveni_lee last edited by
      gern doch… here we go...
      <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="oiewU1qs!kCPH3d=a.Tc" x="-551" y="39"><mutation items="1"></mutation>
      <value name="OID0"><shadow type="field_oid" id="VvOVXB/reB=4U*dhV)]}"><field name="oid">default</field></shadow>
        <block type="logic_operation" id="j[`~JE}oyE~SXHoXl4a("><field name="OP">OR</field>
          <value name="A"><block type="get_value" id="m*P/2![f2%RdPGM_v7|m"><field name="ATTR">val</field>
              <field name="OID">rflink.1.channels.Conrad_3.SWITCH_0a</field></block></value>
          <value name="B"><block type="get_value" id="|{HUUHlyiqXw/PQ]_gaX"><field name="ATTR">val</field>
              <field name="OID">rflink.1.channels.Conrad_4.SWITCH_0a</field></block></value></block></value>
      <statement name="STATEMENT"><block type="controls_if" id="4;vR;%_{-c9P4?HlaWQC"><value name="IF0"><block type="logic_compare" id="LF_8|{k7jr(at2mCsJ(H"><field name="OP">EQ</field>
              <value name="A"><block type="get_value" id="_@R}oJlpTzS=.p(VYB3/"><field name="ATTR">val</field>
                  <field name="OID">javascript.0.Außenbeleuchtung.Wegbeleuchtung.BW_Melder</field></block></value>
              <value name="B"><block type="logic_boolean" id=")1oY1U:IqMU9O05Z]fg8"><field name="BOOL">FALSE</field></block></value></block></value>
          <statement name="DO0"><block type="controls_if" id="v`*Jm|Ie9|;bQO!(*2vl"><value name="IF0"><block type="logic_operation" id="zH!I#Sjz+d,jL;60l?T6"><field name="OP">OR</field>
                  <value name="A"><block type="get_value" id="nGD.:?)BAY_+`Ft.|v~l"><field name="ATTR">val</field>
                  <value name="B"><block type="logic_compare" id="JOq:tT0C;C0VI:91Wo^1"><field name="OP">EQ</field>
                      <value name="A"><block type="get_value" id="^JjjnGaqN~.tzLV(:)se"><field name="ATTR">val</field>
                      <value name="B"><block type="logic_boolean" id="uabCcKFsHHAlyknfuQE#"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
              <statement name="DO0"><block type="control" id="%XUQe^8,3,HMNEx(JHQA"><mutation delay_input="false"></mutation>
                  <field name="OID">rflink.1.channels.Conrad_1.SWITCH_07</field>
                  <value name="VALUE"><block type="logic_boolean" id="9r.qeS7l7a]!]dT108[,"><field name="BOOL">TRUE</field></block></value>
                  <next><block type="control" id="aFOn,DM/2%T@w+d3)Wl4"><mutation delay_input="true"></mutation>
                      <field name="DELAY_MS">200</field>
                      <field name="UNIT">ms</field>
                      <value name="VALUE"><block type="logic_boolean" id="r.cmdjwe_UMoqhMC7`ID"><field name="BOOL">TRUE</field></block></value>
                      <next><block type="control" id="TitTy_,DsI/-+!ABc8@b"><mutation delay_input="true"></mutation>
                          <value name="VALUE"><block type="logic_boolean" id="}9dURa}]uGl/-0(*OfCx"><field name="BOOL">TRUE</field></block></value>
                          <next><block type="control" id="5-Kf^4THebiAPRojskby"><mutation delay_input="true"></mutation>
                              <value name="VALUE"><block type="logic_boolean" id="-%2SuzFZjnZXc4f04O1`"><field name="BOOL">TRUE</field></block></value>
                              <next><block type="control" id="7z3YY!mXR`C9bLdcaO*B"><mutation delay_input="true"></mutation>
                                  <value name="VALUE"><block type="logic_boolean" id="+xfr+]nS3(%m[sXuA)(2"><field name="BOOL">TRUE</field></block></value></block></next></block></next></block></next></block></next></block></statement>
              <next><block type="controls_if" id="YM.GNK~r26fixh=%X9-e"><value name="IF0"><block type="logic_operation" id="9K~D.nDvop57#B}*|3~J"><field name="OP">OR</field>
                      <value name="A"><block type="get_value" id="k4Yq]GiZTNr/.%p(uETT"><field name="ATTR">val</field>
                      <value name="B"><block type="logic_compare" id="oyY()e)U92+I4{Bwx47U"><field name="OP">EQ</field>
                          <value name="A"><block type="get_value" id="?CFZ;zIv69Hm{2nX0ZYX"><field name="ATTR">val</field>
                          <value name="B"><block type="logic_boolean" id="PpgHu@xc]E,xUt^W2Ir%"><field name="BOOL">FALSE</field></block></value></block></value></block></value>
                  <statement name="DO0"><block type="control" id="(#[2apThGXfH~lrV`ZjG"><mutation delay_input="false"></mutation>
                      <value name="VALUE"><block type="logic_boolean" id="}Uvxu8{OTQX7n[o;HWrs"><field name="BOOL">FALSE</field></block></value>
                      <next><block type="control" id="Vc|*:b=X5*AvC)2K*X^r"><mutation delay_input="true"></mutation>
                          <value name="VALUE"><block type="logic_boolean" id="bOBAq~TkV9sQ{rzaz=e,"><field name="BOOL">FALSE</field></block></value>
                          <next><block type="control" id="jr9U96b]Rp83wWh*)D*K"><mutation delay_input="true"></mutation>
                              <value name="VALUE"><block type="logic_boolean" id="ax;/1`;)./6=LEarA##`"><field name="BOOL">FALSE</field></block></value>
                              <next><block type="control" id="eFH-sOfUG2Mc^7ispPIv"><mutation delay_input="true"></mutation>
                                  <value name="VALUE"><block type="logic_boolean" id="qOFc0emb%eaqD7{H2)+^"><field name="BOOL">FALSE</field></block></value>
                                  <next><block type="control" id="K[@rcPW3w!joTD@%g=eF"><mutation delay_input="true"></mutation>
                                      <value name="VALUE"><block type="logic_boolean" id="(6Jx=v6R-?[c*PUa9]ay"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></next></block></next></block></statement></block></next></block></statement></block></statement></block></xml>
      • rantanplan
        rantanplan last edited by
        So auf den ersten Blick…
        KEINE "oder" Bedingung im Trigger!!!
        Mach es mal so.
        Export
        <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="oiewU1qs!kCPH3d=a.Tc" x="-551" y="39"><mutation items="2"></mutation>
        <value name="OID0"><shadow type="field_oid" id="XK;_I,FL^S26_a4cPHn9"><field name="oid">default</field></shadow>
        <value name="OID1"><shadow type="field_oid" id="7agAjRcutccGpq~M9441"><field name="oid">default</field></shadow>
        Weiter habe ich es mir nicht angeschaut.
        [EDIT] Ein kleiner Schönheitsfehler bei Blocky. Die Trigger-Bedingung hat sich verändert und ich habe nicht drauf geachtet.
          gibt folgende Fehlermeldung:
          javascript.0	2017-09-26 22:16:29.856	error	script.js.common.Bewegungsmelder compile failed: SyntaxError: missing ) after argument list
          • Dutchman
            @sveni_lee:
            Du benutzt einen falschen Block in Trigger, nicht wert von object sondern nur object nehmen bitte
            Send from mobile device
            • rantanplan
              @Dutchman:
              Du benutzt einen falschen Block in Trigger, nicht wert von object sondern nur object nehmen bitte `
              Danke Dutchman :!:
              Ich war zu schnell "mit mal eben nebenbei" :oops:
                Danke an euch Beide… Jetzt funtioniert es...
                Ich musste allerding die beiden Bewegungsmelder einzeln tiggern da einer von beiden ja false sein kann und dann
                das licht gleich wieder abgeschalten wird...
                • Dutchman
                  @sveni_lee:
                  das licht gleich wieder abgeschalten wird... `
                  Sehr gerade das blockly mich komplett aber wenn du auf beide triggerst und dan eine oder Abfrage hast (bw1 = true oder bw2 = true) sollte das doch hinhauen?
                    richtig… aber ich trigger ja auch das false signal zu abschalten.
                    Wenn der erste Bewegungsmelder 1 auf true geht, steht der zweite noch auf false. wenn ich zum Abschalten nun
                    trigger das BW1 oder BW2 auf false steht, schaltet das Licht sofort wieder aus...
                    • Dutchman
                      @sveni_lee:
                      trigger das BW1 oder BW2 auf false steht, schaltet das Licht sofort wieder aus... `
                      Ehm ja ok und wen du:
                      Wen Bw1 = true oder bw2 = true {Schalte ein} Lampe ein
                      Sonst wenn
                      bw1 = false UND bw2 = false {Schalte aus} Lampe ein
                      Es gibt ja die "sonst" (Englisch "Else") aber auch die sonst wenn (Englisch "Else if) Funktion [emoji3]
                        ja, das würde natürlich auch funktionieren…
                        1425
