    4. Viessmann-Adapter mit vcontrol
    • blauholsten
      blauholsten Developer @MartyBr last edited by
      @martybr
      Bitte nochmal testen, sollte jetzt klappen. Sobald das positive Feedback kommt, publishe ich es für alle.
        @blauholsten
        Ich war gerade Online, daher hier der schnelle Test. Adapter habe ich aus Github upgedatet.
        Test mit Standard vito.xml:
        essmann.0
        2023-03-20 21:04:19.741	debug	Wait for next run: 60000 in ms
        viessmann.0
        2023-03-20 21:04:19.740	info	Connect with Viessmann sytem!
        viessmann.0
        2023-03-20 21:04:19.711	info	starting. Version 1.4.2 (non-npm: misanorot/ioBroker.viessmann) in /opt/iobroker/node_modules/iobroker.viessmann, node: v18.15.0, js-controller: 4.0.24
        viessmann.0
        2023-03-20 21:04:19.517	debug	States connected to redis: 127.0.0.1:9000
        viessmann.0
        2023-03-20 21:04:19.435	debug	States create User PubSub Client
        viessmann.0
        2023-03-20 21:04:19.435	debug	States create System PubSub Client
        viessmann.0
        2023-03-20 21:04:19.415	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        viessmann.0
        2023-03-20 21:04:19.387	debug	Objects connected to redis: 127.0.0.1:9001
        viessmann.0
        2023-03-20 21:04:19.383	debug	Objects client initialize lua scripts
        viessmann.0
        2023-03-20 21:04:19.313	debug	Objects create User PubSub Client
        viessmann.0
        2023-03-20 21:04:19.312	debug	Objects create System PubSub Client
        viessmann.0
        2023-03-20 21:04:19.311	debug	Objects client ready ... initialize now
        viessmann.0
        2023-03-20 21:04:19.274	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        host.iobroker-test
        2023-03-20 21:04:18.650	info	instance system.adapter.viessmann.0 started with pid 23158
        host.iobroker-test
        2023-03-20 21:04:16.126	info	instance system.adapter.viessmann.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        viessmann.0
        2023-03-20 21:04:15.607	debug	States to delete: viessmann.0.set.VolstromIntensiv
        viessmann.0
        2023-03-20 21:04:15.607	debug	States to delete: viessmann.0.set.VolstromNormal
        viessmann.0
        2023-03-20 21:04:15.607	debug	States to delete: viessmann.0.set.VolstromRed
        viessmann.0
        2023-03-20 21:04:15.607	debug	States to delete: viessmann.0.set.AbluftTempSoll
        viessmann.0
        2023-03-20 21:04:15.607	debug	States to delete: viessmann.0.set.MinZuluftBypass
        viessmann.0
        2023-03-20 21:04:15.607	debug	States to delete: viessmann.0.set.Compressor
        viessmann.0
        2023-03-20 21:04:15.607	debug	States to delete: viessmann.0.set.Heater
        viessmann.0
        2023-03-20 21:04:15.606	debug	States to delete: viessmann.0.set.HeaterforRoomtemp
        viessmann.0
        2023-03-20 21:04:15.606	debug	States to delete: viessmann.0.set.HeaterforWW
        viessmann.0
        2023-03-20 21:04:15.606	debug	States to delete: viessmann.0.set.1xWWaus
        viessmann.0
        2023-03-20 21:04:15.606	debug	States to delete: viessmann.0.set.1xWWein
        viessmann.0
        2023-03-20 21:04:15.606	debug	States to delete: viessmann.0.set.Betriebsart2
        viessmann.0
        2023-03-20 21:04:15.606	debug	States to delete: viessmann.0.set.Betriebsart1
        viessmann.0
        2023-03-20 21:04:15.606	debug	States to delete: viessmann.0.set.Betriebsart0
        viessmann.0
        viessmann.0
        2023-03-20 21:04:15.606	debug	States to delete: viessmann.0.set.KKLNeigung
        viessmann.0
        2023-03-20 21:04:15.606	debug	States to delete: viessmann.0.set.KKLNiveau
        viessmann.0
        2023-03-20 21:04:15.605	debug	States to delete: viessmann.0.set.HKLNeigung
        viessmann.0
        2023-03-20 21:04:15.605	debug	States to delete: viessmann.0.set.HKLNiveau
        viessmann.0
        2023-03-20 21:04:15.605	debug	States to delete: viessmann.0.set.TempWWSoll_2
        viessmann.0
        viessmann.0
        2023-03-20 21:04:15.605	debug	States to delete: viessmann.0.set.Raumtemperatur25
        viessmann.0
        2023-03-20 21:04:15.605	debug	States to delete: viessmann.0.set.Raumtemperatur24
        viessmann.0
        2023-03-20 21:04:15.605	debug	States to delete: viessmann.0.set.Raumtemperatur23
        viessmann.0
        2023-03-20 21:04:15.605	debug	States to delete: viessmann.0.set.Raumtemperatur22
        viessmann.0
        2023-03-20 21:04:15.604	debug	States to delete: viessmann.0.set.Raumtemperatur21
        viessmann.0
        2023-03-20 21:04:15.604	debug	States to delete: viessmann.0.set.Raumtemperatur20
        viessmann.0
        2023-03-20 21:04:15.604	debug	States to delete: viessmann.0.set.Raumtemperatur19
        viessmann.0
        2023-03-20 21:04:15.604	debug	States to delete: viessmann.0.set.Raumtemperatur18
        viessmann.0
        2023-03-20 21:04:15.604	debug	States to delete: viessmann.0.set.Raumtemperatur17
        viessmann.0
        2023-03-20 21:04:15.604	debug	States to delete: viessmann.0.set.Raumtemperatur16
        viessmann.0
        viessmann.0
        2023-03-20 21:04:15.604	debug	States to delete: viessmann.0.set.TempRaumSollParty
        viessmann.0
        2023-03-20 21:04:15.604	debug	States to delete: viessmann.0.set.TempRaumSollRed
        viessmann.0
        2023-03-20 21:04:15.603	debug	States to delete: viessmann.0.set.TempRaumSollNormal
        viessmann.0
        2023-03-20 21:04:15.603	debug	States to delete: viessmann.0.get.VolstromIntensiv
        viessmann.0
        2023-03-20 21:04:15.603	debug	States to delete: viessmann.0.get.VolstromNormal
        viessmann.0
        2023-03-20 21:04:15.603	debug	States to delete: viessmann.0.get.VolstromRed
        viessmann.0
        2023-03-20 21:04:15.603	debug	States to delete: viessmann.0.get.AbluftTempSoll
        viessmann.0
        2023-03-20 21:04:15.603	debug	States to delete: viessmann.0.get.FortluftTemp
        viessmann.0
        viessmann.0
        2023-03-20 21:04:15.603	debug	States to delete: viessmann.0.get.ZuluftTemp
        viessmann.0
        2023-03-20 21:04:15.603	debug	States to delete: viessmann.0.get.AussenLuftTemp
        viessmann.0
        2023-03-20 21:04:15.603	debug	States to delete: viessmann.0.get.MinZuluftBypass
        viessmann.0
        2023-03-20 21:04:15.603	debug	States to delete: viessmann.0.get.Compressor
        viessmann.0
        2023-03-20 21:04:15.602	debug	States to delete: viessmann.0.get.Heater
        viessmann.0
        2023-03-20 21:04:15.602	debug	States to delete: viessmann.0.get.1xWW
        viessmann.0
        2023-03-20 21:04:15.602	debug	States to delete: viessmann.0.get.Betriebsart
        viessmann.0
        2023-03-20 21:04:15.602	debug	States to delete: viessmann.0.get.COPHeiz
        viessmann.0
        2023-03-20 21:04:15.602	debug	States to delete: viessmann.0.get.JAZWW
        viessmann.0
        2023-03-20 21:04:15.602	debug	States to delete: viessmann.0.get.JAZHeiz
        viessmann.0
        viessmann.0
        2023-03-20 21:04:15.602	debug	States to delete: viessmann.0.get.EnergieWWelektro
        viessmann.0
        2023-03-20 21:04:15.602	debug	States to delete: viessmann.0.get.EnergieHeizelektro
        viessmann.0
        2023-03-20 21:04:15.602	debug	States to delete: viessmann.0.get.EnergieHeizwaermeWW
        viessmann.0
        2023-03-20 21:04:15.601	debug	States to delete: viessmann.0.get.EnergieHeizwaerme
        viessmann.0
        2023-03-20 21:04:15.601	debug	States to delete: viessmann.0.get.KKLNeigung
        viessmann.0
        2023-03-20 21:04:15.601	debug	States to delete: viessmann.0.get.KKLNiveau
        viessmann.0
        2023-03-20 21:04:15.601	debug	States to delete: viessmann.0.get.PwrSollVerdichter
        viessmann.0
        2023-03-20 21:04:15.601	debug	States to delete: viessmann.0.get.HKLNeigung
        viessmann.0
        2023-03-20 21:04:15.601	debug	States to delete: viessmann.0.get.HKLNiveau
        viessmann.0
        2023-03-20 21:04:15.601	debug	States to delete: viessmann.0.get.LastVerdichter
        viessmann.0
        2023-03-20 21:04:15.601	debug	States to delete: viessmann.0.get.TempVLSoll
        viessmann.0
        2023-03-20 21:04:15.601	debug	States to delete: viessmann.0.get.StatusAC
        viessmann.0
        2023-03-20 21:04:15.601	debug	States to delete: viessmann.0.get.StatusVentilWW2
        viessmann.0
        2023-03-20 21:04:15.600	debug	States to delete: viessmann.0.get.StatusVentilWW
        viessmann.0
        2023-03-20 21:04:15.600	debug	States to delete: viessmann.0.get.StatusSekPumpe
        viessmann.0
        2023-03-20 21:04:15.600	debug	States to delete: viessmann.0.get.StatusQuellePri1
        viessmann.0
        2023-03-20 21:04:15.600	debug	States to delete: viessmann.0.get.TempKuehlVL
        viessmann.0
        2023-03-20 21:04:15.600	debug	States to delete: viessmann.0.get.TempPriRL
        viessmann.0
        2023-03-20 21:04:15.600	debug	States to delete: viessmann.0.get.TempPriVL
        viessmann.0
        2023-03-20 21:04:15.599	debug	States to delete: viessmann.0.get.TempSekRL
        viessmann.0
        2023-03-20 21:04:15.599	debug	States to delete: viessmann.0.get.TempSekVL
        viessmann.0
        2023-03-20 21:04:15.599	debug	States to delete: viessmann.0.get.BetriebsstundenPumpeHK1
        viessmann.0
        2023-03-20 21:04:15.599	debug	States to delete: viessmann.0.get.StatusSpeicherPumpe
        viessmann.0
        2023-03-20 21:04:15.599	debug	States to delete: viessmann.0.get.PumpZirk_Betriebsstunden
        viessmann.0
        2023-03-20 21:04:15.599	debug	States to delete: viessmann.0.get.StatusPumpeZirk
        viessmann.0
        viessmann.0
        2023-03-20 21:04:15.599	debug	States to delete: viessmann.0.get.StatusV1
        viessmann.0
        2023-03-20 21:04:15.598	debug	States to delete: viessmann.0.get.TempWWSoll_2
        viessmann.0
        viessmann.0
        2023-03-20 21:04:15.598	debug	States to delete: viessmann.0.get.TempWWIstOben
        viessmann.0
        2023-03-20 21:04:15.598	debug	States to delete: viessmann.0.get.Raumtemperatur
        viessmann.0
        2023-03-20 21:04:15.598	debug	States to delete: viessmann.0.get.TempRaumSollParty
        viessmann.0
        2023-03-20 21:04:15.597	debug	States to delete: viessmann.0.get.TempRaumSollRed
        viessmann.0
        2023-03-20 21:04:15.597	debug	States to delete: viessmann.0.get.TempRaumSollNormal
        viessmann.0
        viessmann.0
        2023-03-20 21:04:15.597	debug	States to delete: viessmann.0.get.TempRaumIst
        viessmann.0
        2023-03-20 21:04:15.596	debug	States to delete: viessmann.0.get.Aussentemperatur
        host.iobroker-test
        2023-03-20 21:04:15.560	info	stopInstance system.adapter.viessmann.0 send kill signal
        viessmann.0
        2023-03-20 21:04:15.527	debug	Wait for next run: 60000 in ms
        viessmann.0
        2023-03-20 21:04:15.526	info	Connect with Viessmann sytem!
        viessmann.0
        2023-03-20 21:04:15.522	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        viessmann.0
        2023-03-20 21:04:15.522	info	terminating
        viessmann.0
        2023-03-20 21:04:15.522	info	cleaned everything up...
        viessmann.0
        2023-03-20 21:04:15.521	info	Got terminate signal TERMINATE_YOURSELF
        viessmann.0
        2023-03-20 21:04:15.517	info	read vito.xml successfull
        host.iobroker-test
        2023-03-20 21:04:15.516	info	stopInstance system.adapter.viessmann.0 (force=false, process=true)
        viessmann.0
        2023-03-20 21:04:15.486	debug	Objects are: {"gets":{"Aussentemperatur":{"name":"Aussentemperatur","unit":"°C","type":"number","description":"Ermittle Aussentemperatur in Grad C (-40..70)","polling":-1,"command":"getAussentemperatur"},"TempRaumIst":{"name":"TempRaumIst","unit":"°C","type":"number","description":"Heizkreis HK1: Raumtemperatur HK1 (0..40)","polling":-1,"command":"getTempRaumIst"},"TempRaumSoll":{"name":"TempRaumSoll","unit":"°C","type":"number","description":"Heizkreis HK1: Raumsolltemperatur HK1 von FB (10..30)","polling":-1,"command":"getTempRaumSoll"},"TempRaumSollNormal":{"name":"TempRaumSollNormal","unit":"°C","type":"number","description":"Bedienung HK1 - Heizkreis 1: Raumsolltemperatur normal ","polling":-1,"command":"getTempRaumSollNormal"},"TempRaumSollRed":{"name":"TempRaumSollRed","unit":"°C","type":"number","description":"Raumsolltemperatur reduzierter Betrieb","polling":-1,"command":"getTempRaumSollRed"},"TempRaumSollParty":{"name":"TempRaumSollParty","unit":"°C","type":"number","description":"Bedienung HK1 - Heizkreis 1: Party Solltemperatur (10..30)","polling":-1,"command":"getTempRaumSollParty"},"Raumtemperatur":{"name":"Raumtemperatur","unit":"°C","type":"number","description":"HK1 Heizkreis 1 Wertebereich 10 - 30","polling":-1,"command":"getRaumtemperatur"},"TempWWIstOben":{"name":"TempWWIstOben","unit":"°C","type":"number","description":"Information Warmwasser Wertebereich 0 - 95","polling":-1,"command":"getTempWWIstOben"},"TempWWSoll":{"name":"TempWWSoll","unit":"°C","type":"number","description":"WW - Warmwassersolltemperatur (10..60 (95))","polling":-1,"command":"getTempWWSoll"},"TempWWSoll_2":{"name":"TempWWSoll_2","unit":"°C","type":"number","description":"WW - Zweiter Sollwert (10..60 (95))","polling":-1,"command":"getTempWWSoll_2"},"StatusV1":{"name":"StatusV1","unit":"","type":"string","description":"Status Verdichter 1 (0..1)","polling":-1,"command":"getStatusV1"},"StatusPumpe":{"name":"StatusPumpe","unit":"","type":"string","description":"Status HK1: Heizkreispumpe (0..1)","polling":-1,"command":"getStatusPumpe"},"StatusPumpeZirk":{"name":"StatusPumpeZirk","unit":"","type":"string","description":"Status Zirkulationspumpe (0..1","polling":-1,"command":"getStatusPumpeZirk"},"PumpZirk_Betriebsstunden":{"name":"PumpZirk_Betriebsstunden","unit":"Stunden","type":"number","description":"Betriebsstunden Zirkulationspumpe","polling":-1,"command":"getPumpZirk_Betriebsstunden"},"StatusSpeicherPumpe":{"name":"StatusSpeicherPumpe","unit":"","type":"string","description":"Information - Warmwasser: Speicherladepumpe (0..1)","polling":-1,"command":"getStatusSpeicherPumpe"},"BetriebsstundenPumpeHK1":{"name":"BetriebsstundenPumpeHK1","unit":"","type":"number","description":"Betriebsstunden Anlage Wertebereich 0 - 1150000","polling":-1,"command":"getBetriebsstundenPumpeHK1"},"TempSekVL":{"name":"TempSekVL","unit":"°C","type":"number","description":"HK1: Vorlauftemperatur Sekundaer 1 (0..95)","polling":-1,"command":"getTempSekVL"},"TempSekRL":{"name":"TempSekRL","unit":"°C","type":"number","description":"HK1: Ruecklauftemperatur Sekundaer 1 (0..95)","polling":-1,"command":"getTempSekRL"},"TempPriVL":{"name":"TempPriVL","unit":"°C","type":"number","description":"Vorlauftemperatur Primaerquelle (-20..95)","polling":-1,"command":"getTempPriVL"},"TempPriRL":{"name":"TempPriRL","unit":"°C","type":"number","description":"Ruecklauftemperatur Primaerquelle (-20..95)","polling":-1,"command":"getTempPriRL"},"TempKuehlVL":{"name":"TempKuehlVL","unit":"°C","type":"number","description":"Heizkreis HK1: Vorlauftemperatur Kuehlkreis 1 (0..95)","polling":-1,"command":"getTempKuehlVL"},"StatusQuellePri1":{"name":"StatusQuellePri1","unit":"","type":"string","description":"Diagnose - Anlagenuebersicht: Primaerquelle 1 (Vent. oder Primaerpumpe (0..1)","polling":-1,"command":"getStatusQuellePri1"},"StatusSekPumpe":{"name":"StatusSekPumpe","unit":"","type":"string","description":"Anlagenuebersicht: Sekundaerpumpe 1 (0..1)","polling":-1,"command":"getStatusSekPumpe"},"StatusVentilWW":{"name":"StatusVentilWW","unit":"","type":"string","description":"Waermepumpe: 3-W-Ventil Heizen WW1 (0 (Heizen)..1 (WW))","polling":-1,"command":"getStatusVentilWW"},"StatusVentilWW2":{"name":"StatusVentilWW2","unit":"","type":"string","description":"Waermepumpe: 3-W-Ventil Heizen WW2 (0 (Heizen)..1 (WW))","polling":-1,"command":"getStatusVentilWW2"},"StatusAC":{"name":"StatusAC","unit":"","type":"string","description":"Heizkreis HK1: Kuehlung fuer HK1 (0..1)","polling":-1,"command":"getStatusAC"},"TempVLSoll":{"name":"TempVLSoll","unit":"°C","type":"number","description":"Heizkreis HK1: Vorlaufsolltemperatur HK1 (0..95)","polling":-1,"command":"getTempVLSoll"},"LastVerdichter":{"name":"LastVerdichter","unit":"","type":"number","description":"Last am Verdichter","polling":-1,"command":"getLastVerdichter"},"HKLNiveau":{"name":"HKLNiveau","unit":"","type":"number","description":"Heizkreis 1: Niveau der Heizkennlinie (-15..40)","polling":-1,"command":"getHKLNiveau"},"HKLNeigung":{"name":"HKLNeigung","unit":"","type":"number","description":"Heizkreis 1: Neigung der Heizkennlinie (0..35)","polling":-1,"command":"getHKLNeigung"},"PwrSollVerdichter":{"name":"PwrSollVerdichter","unit":"","type":"number","description":"Anlagenuebersicht: Soll-Leistung Verdichter 1 (0..100)","polling":-1,"command":"getPwrSollVerdichter"},"KKLNiveau":{"name":"KKLNiveau","unit":"","type":"number","description":"Heizkreis 1: Niveau Kuehlkennlinie (-15..40)","polling":-1,"command":"getKKLNiveau"},"KKLNeigung":{"name":"KKLNeigung","unit":"","type":"number","description":"Heizkreis 1: Neigung Kuehlkennlinie (0..35)","polling":-1,"command":"getKKLNeigung"},"EnergieHeizwaerme":{"name":"EnergieHeizwaerme","unit":"","type":"number","description":"Energiebilanz: Heizwärme \"Heizbetrieb\", Verdichter 1","polling":-1,"command":"getEnergieHeizwaerme"},"EnergieHeizwaermeWW":{"name":"EnergieHeizwaermeWW","unit":"","type":"number","description":"Energiebilanz: Heizwärme \"WW-Betrieb\", Verdichter 1","polling":-1,"command":"getEnergieHeizwaermeWW"},"EnergieHeizelektro":{"name":"EnergieHeizelektro","unit":"","type":"number","description":"Energiebilanz: Elektroenergie \"Heizbetrieb\", Verdichter 1","polling":-1,"command":"getEnergieHeizelektro"},"EnergieWWelektro":{"name":"EnergieWWelektro","unit":"","type":"number","description":"Energiebilanz: Elektroenergie \"WW-Betrieb\", Verdichter 1","polling":-1,"command":"getEnergieWWelektro"},"JAZ":{"name":"JAZ","unit":"","type":"number","description":"Energiebilanz: Jahresarbeitszahl (0..10)","polling":-1,"command":"getJAZ"},"JAZHeiz":{"name":"JAZHeiz","unit":"","type":"number","description":"Energiebilanz: Jahresarbeitszahl Heizen (0..10)","polling":-1,"command":"getJAZHeiz"},"JAZWW":{"name":"JAZWW","unit":"","type":"number","description":"Energiebilanz: Jahresarbeitszahl WW (0..10)","polling":-1,"command":"getJAZWW"},"COPHeiz":{"name":"COPHeiz","unit":"","type":"number","description":"Energiebilanz: COP Heizbetrieb (0..10)","polling":-1,"command":"getCOPHeiz"},"Betriebsart":{"name":"Betriebsart","unit":"","type":"string","description":"Heizkreis 1: Betriebsart (0..4)","polling":-1,"command":"getBetriebsart"},"1xWW":{"name":"1xWW","unit":"","type":"string","description":"1 malige Warmwasserbereitung","polling":-1,"command":"get1xWW"},"Heater":{"name":"Heater","unit":"","type":"number","description":"Leistung Durchlauferhitzer (1=3, 2=6 oder 3=9kW)","polling":-1,"command":"getHeater"},"Compressor":{"name":"Compressor","unit":"","type":"number","description":"Freigabe Verdichterstufe (1=WW 2=Heiz 3=WW+Heiz 15=default)","polling":-1,"command":"getCompressor"},"MinZuluftBypass":{"name":"MinZuluftBypass","unit":"°C","type":"number","description":"Minimale Zulufttemperatur für den ByPass in Grad 0,1 °C","polling":-1,"command":"getMinZuluftBypass"},"AussenLuftTemp":{"name":"AussenLuftTemp","unit":"°C","type":"number","description":"Aussentemperatur VitoVent in Grad 0,1 °C","polling":-1,"command":"getAussenLuftTemp"},"ZuluftTemp":{"name":"ZuluftTemp","unit":"°C","type":"number","description":"Zulufttemperatur VitoVent in Grad 0,1 °C","polling":-1,"command":"getZuluftTemp"},"AbluftTemp":{"name":"AbluftTemp","unit":"°C","type":"number","description":"Ablufttemperatur VitoVent in Grad 0,1 °C","polling":-1,"command":"getAbluftTemp"},"FortluftTemp":{"name":"FortluftTemp","unit":"°C","type":"number","description":"Fortlufttemperatur VitoVent in Grad 0,1 °C","polling":-1,"command":"getFortluftTemp"},"AbluftTempSoll":{"name":"AbluftTempSoll","unit":"°C","type":"number","description":"Ablufttemperatur-Sollwert in Grad 0,1 °C","polling":-1,"command":"getAbluftTempSoll"},"VolstromRed":{"name":"VolstromRed","unit":"","type":"number","description":"Volumenstrom reduzierte Lüftung in m3","polling":-1,"command":"getVolstromRed"},"VolstromNormal":{"name":"VolstromNormal","unit":"","type":"number","description":"Volumenstrom normale Lüftung in m3","polling":-1,"command":"getVolstromNormal"},"VolstromIntensiv":{"name":"VolstromIntensiv","unit":"","type":"number","description":"Volumenstrom intensive Lüftung in m3","polling":-1,"command":"getVolstromIntensiv"}},"sets":{"TempRaumSollNormal":{"name":"TempRaumSollNormal","description":"Setze Soll-Raumtemperatur (10..30)","polling":"nicht möglich","type":"number","command":"setTempRaumSollNormal"},"TempRaumSollRed":{"name":"TempRaumSollRed","description":"Setze Raumsolltemperatur reduzierter Betrieb (10..30)","polling":"nicht möglich","type":"number","command":"setTempRaumSollRed"},"TempRaumSollParty":{"name":"TempRaumSollParty","description":"Setze Party Solltemperatur (10..30)","polling":"nicht möglich","type":"number","command":"setTempRaumSollParty"},"Raumtemperatur":{"name":"Raumtemperatur","description":"RT auf xxC","polling":"nicht möglich","type":"number","command":"setRaumtemperatur"},"Raumtemperatur16":{"name":"Raumtemperatur16","description":"Raumtemperatur auf 16C","polling":"nicht möglich","type":"number","command":"setRaumtemperatur16"},"Raumtemperatur17":{"name":"Raumtemperatur17","description":"Raumtemperatur auf 17C","polling":"nicht möglich","type":"number","command":"setRaumtemperatur17"},"Raumtemperatur18":{"name":"Raumtemperatur18","description":"Raumtemperatur auf 18C","polling":"nicht möglich","type":"number","command":"setRaumtemperatur18"},"Raumtemperatur19":{"name":"Raumtemperatur19","description":"Raumtemperatur auf 19C","polling":"nicht möglich","type":"number","command":"setRaumtemperatur19"},"Raumtemperatur20":{"name":"Raumtemperatur20","description":"Raumtemperatur auf 20C","polling":"nicht möglich","type":"number","command":"setRaumtemperatur20"},"Raumtemperatur21":{"name":"Raumtemperatur21","description":"Raumtemperatur auf 21C","polling":"nicht möglich","type":"number","command":"setRaumtemperatur21"},"Raumtemperatur22":{"name":"Raumtemperatur22","description":"Raumtemperatur auf 22C","polling":"nicht möglich","type":"number","command":"setRaumtemperatur22"},"Raumtemperatur23":{"name":"Raumtemperatur23","description":"Raumtemperatur auf 23C","polling":"nicht möglich","type":"number","command":"setRaumtemperatur23"},"Raumtemperatur24":{"name":"Raumtemperatur24","description":"Raumtemperatur auf 24C","polling":"nicht möglich","type":"number","command":"setRaumtemperatur24"},"Raumtemperatur25":{"name":"Raumtemperatur25","description":"Raumtemperatur auf 25C","polling":"nicht möglich","type":"number","command":"setRaumtemperatur25"},"TempWWSoll":{"name":"TempWWSoll","description":"Setze WW: Warmwassersolltemperatur (10..60 (95))","polling":"nicht möglich","type":"number","command":"setTempWWSoll"},"TempWWSoll_2":{"name":"TempWWSoll_2","description":"Setze WW - Zweiter Sollwert (10..60 (95))","polling":"nicht möglich","type":"number","command":"setTempWWSoll_2"},"HKLNiveau":{"name":"HKLNiveau","description":"Setzen Heizkreis 1: Niveau der Heizkennlinie (-15..40)","polling":"nicht möglich","type":"number","command":"setHKLNiveau"},"HKLNeigung":{"name":"HKLNeigung","description":"Setzen Heizkreis 1: Neigung der Heizkennlinie (0..35)","polling":"nicht möglich","type":"number","command":"setHKLNeigung"},"KKLNiveau":{"name":"KKLNiveau","description":"Setzen Heizkreis 1: Niveau Kuehlkennlinie (-15..40)","polling":"nicht möglich","type":"number","command":"setKKLNiveau"},"KKLNeigung":{"name":"KKLNeigung","description":"Setzen Heizkreis 1: Neigung Kuehlkennlinie (0..35)","polling":"nicht möglich","type":"number","command":"setKKLNeigung"},"Betriebsart":{"name":"Betriebsart","description":"Setze Betriebsart (0..4)","polling":"nicht möglich","type":"string","command":"setBetriebsart"},"Betriebsart0":{"name":"Betriebsart0","description":"Abschaltbetrieb","polling":"nicht möglich","type":"string","command":"setBetriebsart0"},"Betriebsart1":{"name":"Betriebsart1","description":"Warmwasser","polling":"nicht möglich","type":"string","command":"setBetriebsart1"},"Betriebsart2":{"name":"Betriebsart2","description":"Heizen und Warmwasser","polling":"nicht möglich","type":"string","command":"setBetriebsart2"},"1xWWein":{"name":"1xWWein","description":"1 malige Warmwasserbereitung","polling":"nicht möglich","type":"string","command":"set1xWWein"},"1xWWaus":{"name":"1xWWaus","description":"1 malige Warmwasserbereitung","polling":"nicht möglich","type":"string","command":"set1xWWaus"},"HeaterforWW":{"name":"HeaterforWW","description":"Druchlauferhitzer für Warmwasser aktivieren","polling":"nicht möglich","type":"number","command":"setHeaterforWW"},"HeaterforRoomtemp":{"name":"HeaterforRoomtemp","description":"Durchlauferhitzer für Heizung aktivieren","polling":"nicht möglich","type":"number","command":"setHeaterforRoomtemp"},"Heater":{"name":"Heater","description":"Leistung Durchlauferhitzer (1=3, 2=6 oder 3=9kW)","polling":"nicht möglich","type":"number","command":"setHeater"},"Compressor":{"name":"Compressor","description":"Freigabe Verdichterstufe (1=WW 2=Heiz 3=WW+Heiz 15=default)","polling":"nicht möglich","type":"number","command":"setCompressor"},"MinZuluftBypass":{"name":"MinZuluftBypass","description":"Setze Minimale Zulufttemperatur für den ByPass in Grad 0,1 °C","polling":"nicht möglich","type":"number","command":"setMinZuluftBypass"},"AbluftTempSoll":{"name":"AbluftTempSoll","description":"Setze Ablufttemperatur-Sollwert in Grad 0,1 °C","polling":"nicht möglich","type":"number","command":"setAbluftTempSoll"},"VolstromRed":{"name":"VolstromRed","description":"Setze Volumenstrom reduzierte Lüftung in m3 xxx","polling":"nicht möglich","type":"number","command":"setVolstromRed"},"VolstromNormal":{"name":"VolstromNormal","description":"Setze Volumenstrom normale Lüftung in m3 xxx","polling":"nicht möglich","type":"number","command":"setVolstromNormal"},"VolstromIntensiv":{"name":"VolstromIntensiv","description":"Setze Volumenstrom intensive Lüftung in m3 xxx","polling":"nicht möglich","type":"number","command":"setVolstromIntensiv"}},"system":{"-ID":"204D","-name":"V200-S","-protocol":"P300"}}
        viessmann.0
        2023-03-20 21:04:15.462	info	read vcontrold.xml successfull
        viessmann.0
        2023-03-20 21:04:15.462	debug	Units in vcontrold.xml: {"UT":{"unit":"°C"},"UTH":{"unit":"°C"},"UN":{"unit":""},"UT1":{"unit":"°C"},"UT1U":{"unit":"°C"},"UTI":{"unit":"°C"},"ST":{"unit":""},"XX":{"unit":""},"COL":{"unit":""},"CO":{"unit":""},"PR":{"unit":"%"},"PR1":{"unit":"%"},"PR2":{"unit":"%"},"PR3":{"unit":"%"},"UCH":{"unit":""},"VS":{"unit":"l/h"},"CS":{"unit":"Stunden"},"JAZ":{"unit":""},"PS":{"unit":"Bar"},"BH":{"unit":"h"}}
        viessmann.0
        2023-03-20 21:04:15.462	debug	Types in vcontrold.xml: {"UT":{"type":"short"},"UTH":{"type":"short"},"UN":{"type":"short"},"UT1":{"type":"char"},"UT1U":{"type":"uchar"},"UTI":{"type":"uchar"},"ST":{"type":"char"},"XX":{"type":"uchar"},"WW":{"type":"enum"},"COL":{"type":"int"},"CO":{"type":"int"},"PR":{"type":"short"},"PR1":{"type":"uchar"},"PR2":{"type":"uchar"},"PR3":{"type":"uchar"},"UCH":{"type":"uchar"},"VS":{"type":"ushort"},"CS":{"type":"uint"},"CT":{"type":"cycletime"},"RT":{"type":"enum"},"JAZ":{"type":"int"},"BA":{"type":"enum"},"PS":{"type":"short"},"SR":{"type":"enum"},"TI":{"type":"systime"},"DT":{"type":"enum"},"BH":{"type":"uchar"},"BST":{"type":"uchar"},"BST2":{"type":"enum"},"HKT":{"type":"uchar"},"PL":{"type":"short"},"SN":{"type":"uint"},"USV":{"type":"enum"},"BFB":{"type":"uchar"},"ES":{"type":"errstate"}}
        viessmann.0
        2023-03-20 21:04:15.436	debug	Copy vcontrold.xml from server to host successfully
        viessmann.0
        2023-03-20 21:04:15.402	debug	Copy vito.xml from server to host successfully
        viessmann.0
        2023-03-20 21:04:15.360	debug	Try to copy Vito from: /etc/vcontrold/vito.xml to: /opt/iobroker/node_modules/iobroker.viessmann
        viessmann.0
        2023-03-20 21:04:14.949	debug	FTP session ready
        viessmann.0
        2023-03-20 21:04:14.202	debug	try to create a ssh session
        viessmann.0
        2023-03-20 21:04:14.201	debug	try to read xml files
        viessmann.0
        2023-03-20 21:04:14.189	info	starting. Version 1.4.2 (non-npm: misanorot/ioBroker.viessmann) in /opt/iobroker/node_modules/iobroker.viessmann, node: v18.15.0, js-controller: 4.0.24
        Test mit geänderter vito.xml:
        viessmann.0
        2023-03-20 21:12:55.717	debug	Wait for next run: 60000 in ms
        viessmann.0
        2023-03-20 21:12:55.716	info	Connect with Viessmann sytem!
        viessmann.0
        2023-03-20 21:12:55.696	info	starting. Version 1.4.2 (non-npm: misanorot/ioBroker.viessmann) in /opt/iobroker/node_modules/iobroker.viessmann, node: v18.15.0, js-controller: 4.0.24
        viessmann.0
        2023-03-20 21:12:55.553	debug	States connected to redis: 127.0.0.1:9000
        viessmann.0
        2023-03-20 21:12:55.485	debug	States create User PubSub Client
        viessmann.0
        2023-03-20 21:12:55.484	debug	States create System PubSub Client
        viessmann.0
        2023-03-20 21:12:55.470	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        viessmann.0
        2023-03-20 21:12:55.444	debug	Objects connected to redis: 127.0.0.1:9001
        viessmann.0
        2023-03-20 21:12:55.442	debug	Objects client initialize lua scripts
        viessmann.0
        2023-03-20 21:12:55.401	debug	Objects create User PubSub Client
        viessmann.0
        2023-03-20 21:12:55.401	debug	Objects create System PubSub Client
        viessmann.0
        2023-03-20 21:12:55.400	debug	Objects client ready ... initialize now
        viessmann.0
        2023-03-20 21:12:55.373	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        host.iobroker-test
        2023-03-20 21:12:54.951	info	instance system.adapter.viessmann.0 started with pid 23256
        host.iobroker-test
        2023-03-20 21:12:52.429	info	instance system.adapter.viessmann.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        viessmann.0
        2023-03-20 21:12:51.920	debug	States to delete: viessmann.0.set.VolstromIntensiv
        viessmann.0
        2023-03-20 21:12:51.920	debug	States to delete: viessmann.0.set.VolstromRed
        viessmann.0
        2023-03-20 21:12:51.920	debug	States to delete: viessmann.0.set.AbluftTempSoll
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.Compressor
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.HeaterforRoomtemp
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.1xWWaus
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.Betriebsart2
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.Betriebsart0
        viessmann.0
        2023-03-20 21:12:51.920	debug	States to delete: viessmann.0.set.VolstromNormal
        viessmann.0
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.Betriebsart1
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.1xWWein
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.HeaterforWW
        viessmann.0
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.MinZuluftBypass
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.KKLNeigung
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.KKLNiveau
        viessmann.0
        2023-03-20 21:12:51.919	debug	States to delete: viessmann.0.set.HKLNeigung
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.HKLNiveau
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.TempWWSoll_2
        viessmann.0
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.Raumtemperatur25
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.Raumtemperatur24
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.Raumtemperatur23
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.Raumtemperatur22
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.Raumtemperatur21
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.Raumtemperatur20
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.Raumtemperatur19
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.Raumtemperatur18
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.Raumtemperatur17
        viessmann.0
        2023-03-20 21:12:51.918	debug	States to delete: viessmann.0.set.Raumtemperatur16
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.set.Raumtemperatur
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.set.TempRaumSollParty
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.set.TempRaumSollRed
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.set.TempRaumSollNormal
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.get.VolstromIntensiv
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.get.VolstromNormal
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.get.VolstromRed
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.get.AbluftTempSoll
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.get.FortluftTemp
        viessmann.0
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.get.ZuluftTemp
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.get.AussenLuftTemp
        viessmann.0
        2023-03-20 21:12:51.917	debug	States to delete: viessmann.0.get.MinZuluftBypass
        viessmann.0
        2023-03-20 21:12:51.916	debug	States to delete: viessmann.0.get.Compressor
        viessmann.0
        2023-03-20 21:12:51.916	debug	States to delete: viessmann.0.get.Heater
        viessmann.0
        2023-03-20 21:12:51.916	debug	States to delete: viessmann.0.get.1xWW
        viessmann.0
        2023-03-20 21:12:51.916	debug	States to delete: viessmann.0.get.Betriebsart
        viessmann.0
        2023-03-20 21:12:51.916	debug	States to delete: viessmann.0.get.COPHeiz
        viessmann.0
        2023-03-20 21:12:51.916	debug	States to delete: viessmann.0.get.JAZWW
        viessmann.0
        2023-03-20 21:12:51.916	debug	States to delete: viessmann.0.get.JAZHeiz
        viessmann.0
        viessmann.0
        2023-03-20 21:12:51.916	debug	States to delete: viessmann.0.get.EnergieWWelektro
        viessmann.0
        2023-03-20 21:12:51.916	debug	States to delete: viessmann.0.get.EnergieHeizelektro
        viessmann.0
        2023-03-20 21:12:51.916	debug	States to delete: viessmann.0.get.EnergieHeizwaermeWW
        viessmann.0
        viessmann.0
        2023-03-20 21:12:51.916	debug	States to delete: viessmann.0.get.KKLNeigung
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.KKLNiveau
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.PwrSollVerdichter
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.HKLNeigung
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.HKLNiveau
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.LastVerdichter
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.TempVLSoll
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.StatusAC
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.StatusVentilWW2
        viessmann.0
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.StatusSekPumpe
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.StatusQuellePri1
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.TempKuehlVL
        viessmann.0
        2023-03-20 21:12:51.915	debug	States to delete: viessmann.0.get.TempPriRL
        viessmann.0
        2023-03-20 21:12:51.914	debug	States to delete: viessmann.0.get.TempPriVL
        viessmann.0
        2023-03-20 21:12:51.914	debug	States to delete: viessmann.0.get.TempSekRL
        viessmann.0
        2023-03-20 21:12:51.914	debug	States to delete: viessmann.0.get.TempSekVL
        viessmann.0
        2023-03-20 21:12:51.914	debug	States to delete: viessmann.0.get.BetriebsstundenPumpeHK1
        viessmann.0
        2023-03-20 21:12:51.914	debug	States to delete: viessmann.0.get.StatusSpeicherPumpe
        viessmann.0
        2023-03-20 21:12:51.914	debug	States to delete: viessmann.0.get.PumpZirk_Betriebsstunden
        viessmann.0
        2023-03-20 21:12:51.914	debug	States to delete: viessmann.0.get.StatusPumpeZirk
        viessmann.0
        viessmann.0
        2023-03-20 21:12:51.914	debug	States to delete: viessmann.0.get.StatusV1
        viessmann.0
        2023-03-20 21:12:51.914	debug	States to delete: viessmann.0.get.TempWWSoll_2
        viessmann.0
        2023-03-20 21:12:51.913	debug	States to delete: viessmann.0.get.TempWWSoll
        viessmann.0
        2023-03-20 21:12:51.913	debug	States to delete: viessmann.0.get.TempWWIstOben
        viessmann.0
        2023-03-20 21:12:51.913	debug	States to delete: viessmann.0.get.Raumtemperatur
        viessmann.0
        2023-03-20 21:12:51.913	debug	States to delete: viessmann.0.get.TempRaumSollParty
        viessmann.0
        2023-03-20 21:12:51.913	debug	States to delete: viessmann.0.get.TempRaumSollRed
        viessmann.0
        2023-03-20 21:12:51.913	debug	States to delete: viessmann.0.get.TempRaumSollNormal
        viessmann.0
        viessmann.0
        2023-03-20 21:12:51.913	debug	States to delete: viessmann.0.get.TempRaumIst
        viessmann.0
        2023-03-20 21:12:51.912	debug	States to delete: viessmann.0.get.Aussentemperatur
        host.iobroker-test
        2023-03-20 21:12:51.880	info	stopInstance system.adapter.viessmann.0 send kill signal
        viessmann.0
        2023-03-20 21:12:51.847	debug	Wait for next run: 60000 in ms
        viessmann.0
        2023-03-20 21:12:51.846	info	Connect with Viessmann sytem!
        viessmann.0
        2023-03-20 21:12:51.841	info	read vito.xml successfull
        viessmann.0
        2023-03-20 21:12:51.840	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        viessmann.0
        2023-03-20 21:12:51.839	info	terminating
        viessmann.0
        2023-03-20 21:12:51.839	info	cleaned everything up...
        viessmann.0
        2023-03-20 21:12:51.839	info	Got terminate signal TERMINATE_YOURSELF
        Der Adapter ist mit der geänderten vito.xml wieder grün geworden.
        Auch sind die neuen Datenpunkte im Adapter sichtbar 👍
        Das scheint alles geklappt haben. Also mein Test war positiv.
        Vielen Dank
          MartyBr @blauholsten last edited by
          @blauholsten
          Ich habe gerade die neue Version 1.4.3 installiert. Der Test war erfolgreich 👍
          blauholsten 1 Reply Last reply Reply Quote 0
          • blauholsten
            @martybr
            Sehr gut.... Danke
            Issr4k 1 Reply Last reply Reply Quote 0
            • Issr4k
              Issr4k @blauholsten last edited by Issr4k
              @blauholsten Bei mir klappt es jetzt auch mit der 1.4.3
              DANKE!
                @blauholsten
                Ich habe die 1.4.3 nun auch auf meinem Produktivsystem installiert. Der Adapter läuft stabil und liefert die Werte. Ich meine auch stabiler als die Vorgängerversion. Das liegt möglicherweise auch an den VControld-Server.
                Herzlichen Dank für deine Mühe und die gute Arbeit. 👍
                  Axel 0 last edited by
                  Hallo, eine Frage in die Runde: Ich benötige den USB-Opto-Link-Adapter für die Vitotronic 200. Kann mir jemand einen Tipp geben, außer dem überteuerten von Fa. Viessmann?
                  Danke schon mal im Voraus
                  Axel
                    Darth2010 @Micha487 last edited by
                    @axel-0
                    Ich habe mein Originalkabel über ebay bestellt.
                    Der Verkäufter hat aber leider keine mehr, hatte 40 EUR gekostet.
                    Sonst gibt es auf openv-wiki diverese Selbstbauanleitungen.
                    @micha487 said in Viessmann-Adapter mit vcontrol:
                    @issr4k Ich logge aktuell das Verhalten meines Warmwasser-Tanks um genau das rauszufinden. Brauche aber noch etwas um ausreichend Daten zu sammeln.
                    Konntest du schon belastbare Daten sammeln?
                    Überlege gerade auch stark, den PV-Überschuss in Warmwasser umzuwandeln.
                    • Issr4k
                      Issr4k @Darth2010 last edited by Issr4k
                      @darth2010 Habe tatsächlich nicht mehr aktiv nachgeschaut. Ich schaue mir die Grafana Daten im Laufe des Wochenendes mal an und melde mich.
                      EDIT (21.04.23):
                      Hier mal ein Auszug, gestern 17:30Uhr 1xWW Anforderung gestartet, bei 43,8°C. Das hat dann selbstständig ca. 18:10 Uhr wieder ausgeschaltet bei 56,5°C.
                      Dabei waren meine Einstellwerte:
                      • Sollwert 1 WW = 48°C
                      • Sollwert 2 WW = 60°C
                      Zu Berücksichtigen wären dann natürlich die Abweichungen von den Sollwerten, das liegt vermutlich an der Warmwasser-Hysterese WP (siehe dazu Adresse 6007 und ggf. 6008).
                      Demnach in ~12 h ein Verlust von 5° bei geringem Verbrauch.
                      Ob und wieviel in die Fußbodenheizung geschickt wurde kann ich nicht sagen, jedenfalls wurden keine Thermostate verändert. Ein paar wenige Liter sind möglicherweise über die Abendroutine abhanden gekommen, aber meinem Mädel habe ich jedenfalls verboten in die Wanne zu gehen 😄
                      Den Warmwasser Sollwert 2 kann ich direkt an der WP auf max. 63° einstellen.
                        Darth2010 @Issr4k last edited by
                        @issr4k
                        Danke für die Info.
                        Ich poste meine Messung ebenfalls, wenn ich den Pi wieder angeschlossen habe.
                        Neben dem vcontrol, wird dieser einen iob Slave bekommen, dann ziehe ich das Auslesen der Zählerstände auf diesen um.
                          jumbo125 @Darth2010 last edited by
                          Ihr nutzt doch die viesmann anlage mit vcontrol
                          ich würde dies auch gerne machen.
                          Wie habt ihr die anlage ins netzwerk gebracht? der vitocal hat doch kein wlan. gibt es etwa einen eterneth lan anschluss??
                          danke für eure hilfe
                            MartyBr @jumbo125 last edited by
                            @jumbo125
                            Dazu gibt es eine fundierte Anleitung mit Bauvorschlägen der Optolink-Schnittstelle.
                            https://github.com/openv/openv/wiki/
                            • Issr4k
                              Issr4k @MartyBr last edited by
                              @jumbo125
                              Wie @MartyBr schreibt....
                              Das einfachste (und teuerste) ist das offizielle Kabel von Viessmann, das kannst du an einen Raspberry stöpseln und der Rest ist Software etc und dann ohne Probleme in ioBroker zu bringen.
                                mading last edited by mading
                                bevor ihr nur das Kabel kauft, würde ich vorschlagen, dass die Box genutzt wird (https://www.elektroshopwagner.de/product_info.php?info=p290008&utm_campaign=froogle_290008&utm_source=froogle&utm_medium=CPC&utm_content=textanzeige&campaign=froogle&gclid=EAIaIQobChMIypC6ufzG_gIVEM7VCh2H2gGLEAQYAiABEgLkFPD_BwE). GGf ist es für eure Anlage eine ältere. Meine Optolink Box aus 2017 sieht älter aus.
                                Damit habt ihr beide Optionen: entweder das mitgelieferte Kabel nutzen oder über die viessmann Cloud. Ich habe früher vcontrol genutzt und bin zum viessmann-api Adapter gewechselt. Läuft stabiler und es kostet nichts, wenn man unter den API Restriktionen bleibt.
                                Mit vcontrol hatte ich hin und wieder Probleme, dass sich die Verbindung aufgehängt hat und ich neu einstöpseln musste. Über viessmann-api ist es wartungsärmer und neue Funktionalitäten kommen direkt mit rein. Zudem war die Installation von vcontrol/ openv ein ziemliches Gefrickel.
                                Das ist aber meine pers. Meinung :).
                                  @mading super, werde überlegen mir die viconnect zu kaufen. mit dieser habe ich dann kabel und cloud wenn ich das richtig verstanden habe.
                                  gibt es hierfür einen adapter im iobroker?
                                    mading @jumbo125 last edited by
                                    @jumbo125 schau mal nach ob das Kabel mitgeliefert wird, muss aber so sein. Ja, wie oben erwähnt "viessman-api"
                                    • Issr4k
                                      Issr4k @mading last edited by Issr4k
                                      @mading .
                                      Meines Wissens nach ist das Kabel nur bei Vitoconnect dabei. Nicht bei der Heizung bzw. der Vitocal selbst.
                                      Bei Vitoconnect handelt es sich um ein weißes Kistchen was die Schnittstellenfunktion (Umsetzer Optisch auf WLAN) in die Viessmann-Cloud übernimmt, um die Heizung online zukriegen um über iOS oder Android Apps an Daten und Einstellungen ranzukommen. Man bekommt die Daten für ioBroker dann aber nur über den Cloudumweg wieder nach Hause
                                      ... und soweit ich informiert bin, sind die Zugriffe pro Tag relativ beschränkt bzw. wenn mehr gewünscht ist, werden direkt mehrere Euros pro Monat fällig.
                                      Das läuft dann über den ioBroker-Adapter Viessmann-API
                                      Die Variante mit vcontrold und dem ioBroker-Adpater von @blauholsten stellt die cloudfreie Lösung dar.
                                      Beides Parallel geht aber nicht, da die Schnittstelle an der Heizung selbst dann belegt ist.
                                      M J 2 Replies Last reply Reply Quote 0
                                        mading @Issr4k last edited by
                                        @issr4k richtig
                                          jumbo125 @Issr4k last edited by
                                          @issr4k
                                          Das heißt:
                                          Variante 1:
                                          vconrtold mit dem Kabel um knapp 100€. Hier ist alles möglich, abfragen, steuern etc.
                                          Variante 2:
                                          vitoconnect um knapp 200€, Wlan lösung mittels API. Eingeschränkte abfragen pro Tag(1450/tag) lt. dieser seite https://developer.viessmann.com/start/pricing.html.
                                          Hier kann nicht alles mit dem free-account geschalten werden.
                                          ist das richtig?
                                          was würdet ihr empfehlen?
                                          danke
                                          M Issr4k 2 Replies Last reply Reply Quote 0
                                            @jumbo125
                                            Das kommt auf deine Anforderungen an. Wenn nur mit dem Basic-Angebot auskommst, also keine Photovoltaik oder Geräte aus dem Energy-Bereich (z.B. Heizstab im Boiler) auslesen möchtest, oder keine VitoVent (zentrale Lüftung) auslesen und steuern möchtest, bis du mit der API-Lösung gut bedient.
                                            354
                                            87093
