    3. Einsteigerfragen
    4. Installation
    5. Troubleshooting NodeJS update
      Habedere @Thomas Braun last edited by
      er bleibt erst wieder mal hier stehen
      nulu@raspberrypi:/opt/iobroker $ cd /opt/iobroker
      npm ls | grep -E 'github|ERR'
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
      npm ERR!     /home/iobroker/.npm/_logs/2023-04-23T11_39_17_688Z-debug-0.log
      sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not tran        sfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      (##################) ⠧ reify:iobroker.admin: http fetch GET 200 https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-6.3.5.tgz 52083ms (cache miss)
      Evtl. gehts danach aber weiter - war vorhin auch ähnlich.
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
        Thomas Braun Most Active @Habedere last edited by
        @habedere
        Und kommt der jetzt auf die Beine?
          Leider nein - hängt immer noch an der selben stelle 😞
          Also quasi noch schlechter wie vorher....
            @habedere sagte in Troubleshooting NodeJS update:
            Heißt?
              Freeze
              ^C^C###############) ⠧ reify:iobroker.admin: http fetch GET 200 https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-6.3.5.tgz 52083ms (cache miss)
                Freeze
                Glaube ich nicht. Lass das mal laufen.
                  Habedere @Thomas Braun last edited by Habedere
                  Mach ich - steht halt schon seit ner guten 2 Stunden an der selben Stelle 😉
                    Habedere @Habedere last edited by
                    @habedere
                    Also Shell hat sich nicht mehr bewegt und nach dem ich das Terminal geschlossen habe war eine erneute Anmeldung über SSH nicht möglich. Hab dann den Strom ziehen müssen - aber siehe da, es läuft 🙂
                    nulu@raspberrypi:~ $ /opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs &>        /dev/null
                    uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx        -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt u        pdate &> /dev/null && sudo apt update && apt policy nodejs
                    aarch64
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    /usr/bin/npx
                    v18.16.0
                    v18.16.0
                    9.5.1
                    9.5.1
                    4.0.24
                    nulu
                    nulu adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobr                                                           oker
                    tty
                    /home/nulu
                    OK:1 http://deb.debian.org/debian bullseye InRelease
                    OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                    OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                    OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    OK:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                    Paketlisten werden gelesen… Fertig
                    Abhängigkeitsbaum wird aufgebaut… Fertig
                    Statusinformationen werden eingelesen… Fertig
                    Alle Pakete sind aktuell.
                    nodejs:
                      Installiert:           18.16.0-deb-1nodesource1
                      Installationskandidat: 18.16.0-deb-1nodesource1
                      Versionstabelle:
                     *** 18.16.0-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                            100 /var/lib/dpkg/status
                         12.22.12~dfsg-1~deb11u3 500
                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                         12.22.5~dfsg-2~11u1 500
                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    Werde jetzt mal das Backup einspielen...
                    Vielen vielen Dank für die Hilfe!
                    Homoran H 3 Replies Last reply Reply Quote 0
                      Homoran Global Moderator Administrators @Habedere last edited by
                      nein!
                        wirklich oder nur scheinbar?
                        bitte Ausgabe von iob diag in der Vollversion
                          @habedere
                          Gestopt! Why?
                            @habedere
                            Gestopt! Why?
                            einmal s.o. und zum zweiten: hast du vis manuell installiert?
                            und gestoppt ist abgebrochen ist undefinierter Zustand?
                              Habedere @Homoran last edited by Homoran
                              sorry - mit gestopt meinte ich mich. Hab das Backup noch nicht gestartet weil ich gerade noch deine Nachricht gelesen habe. Hab nur die json des Backup-Adapter eingespielt damit die Zugangsdaten zum Server etc. wieder drin sind...
                              Full diag:
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Model           : Raspberry Pi 3 Model B Rev 1.2
                              Architecture    : aarch64
                              Docker          : false
                              Virtualization  : none
                              Distributor ID: Debian
                              Description:    Debian GNU/Linux 11 (bullseye)
                              Release:        11
                              Codename:       bullseye
                              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                              NAME="Debian GNU/Linux"
                              VERSION_ID="11"
                              VERSION="11 (bullseye)"
                              VERSION_CODENAME=bullseye
                              ID=debian
                              HOME_URL="https://www.debian.org/"
                              SUPPORT_URL="https://www.debian.org/support"
                              BUG_REPORT_URL="https://bugs.debian.org/"
                              Systemuptime and Load:
                               19:51:34 up 14 min,  3 users,  load average: 0.91, 0.88, 0.56
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              Other values than 0x0 hint to temperature/voltage problems
                              temp=54.2'C
                              volt=1.3000V
                              *** Time and Time Zones ***
                                             Local time: Sun 2023-04-23 19:51:34 CEST
                                         Universal time: Sun 2023-04-23 17:51:34 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              *** User and Groups ***
                              nulu
                              /home/nulu
                              nulu adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                              *** X-Server-Setup ***
                              X-Server:       true
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            909M        447M        105M        9.0M        356M        389M
                              Swap:            99M        3.0M         96M
                              Total:          1.0G        450M        201M
                                        909 M total memory
                                        447 M used memory
                                        491 M active memory
                                        192 M inactive memory
                                        105 M free memory
                                          2 M buffer memory
                                        354 M swap cache
                                         99 M total swap
                                          3 M used swap
                                         96 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /dev/root      ext4      110G  4.3G  101G   5% /
                              devtmpfs       devtmpfs  325M     0  325M   0% /dev
                              tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                              tmpfs          tmpfs     182M  1.2M  181M   1% /run
                              /dev/sda1      vfat      255M   31M  225M  13% /boot
                              tmpfs          tmpfs      91M   20K   91M   1% /run/user/1000
                              [Sun Apr 23 19:37:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bdb8b6dd-02 rootfstype=ext4 fsck.repair=yes rootwait
                              [Sun Apr 23 19:37:10 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                              [Sun Apr 23 19:37:10 2023] EXT4-fs (sda2): write access will be enabled during recovery
                              [Sun Apr 23 19:37:11 2023] EXT4-fs (sda2): recovery complete
                              [Sun Apr 23 19:37:11 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Sun Apr 23 19:37:11 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                              [Sun Apr 23 19:37:14 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                              Show mounted filesystems (real ones only):
                              TARGET  SOURCE    FSTYPE OPTIONS
                              /       /dev/sda2 ext4   rw,noatime
                              `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              628M    /var/
                              245M    /var/cache
                              239M    /var/cache/apt
                              184M    /var/lib
                              138M    /var/cache/apt/archives
                              Archived and active journals take up 96.0M in the file system.
                              /opt/iobroker/backups:
                              4.0K    /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              18M     /opt/iobroker/iobroker-data/
                              15M     /opt/iobroker/iobroker-data/files
                              13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                              3.5M    /opt/iobroker/iobroker-data/objects.jsonl
                              2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                              1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                              652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v18.16.0
                              /usr/bin/node           v18.16.0
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
                              nodejs:
                                Installed: 18.16.0-deb-1nodesource1
                                Candidate: 18.16.0-deb-1nodesource1
                                Version table:
                              No problems detected
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              MULTIHOSTSERVICE/enabled: false
                              Core adapters versions
                              js-controller:  4.0.24
                              admin:          6.3.5
                              javascript:     "javascript" not found
                              npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
                              npm ERR! invalid: iobroker.backitup@2.6.16 /opt/iobroker/node_modules/iobroker.backitup
                              npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                              npm ERR! invalid: iobroker.js-controller@4.0.24 /opt/iobroker/node_modules/iobroker.js-controller
                              npm ERR!     /home/nulu/.npm/_logs/2023-04-23T17_52_10_992Z-debug-0.log
                              Adapters from github:   0
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                              + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): stable
                              Installed ioBroker-Instances
                              Used repository: stable
                              Adapter    "admin"        : 6.3.5    , installed 6.3.5
                              Adapter    "backitup"     : 2.6.16   , installed 2.6.16
                              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                              Controller "js-controller": 4.0.24   , installed 4.0.24
                              Objects and States
                              Objects:        142
                              States:         104
                              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:3 http://deb.debian.org/debian bullseye InRelease
                              Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                              Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13265      586/cupsd
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          747        610/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15706      591/iobroker.js-con
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15697      591/iobroker.js-con
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13264      586/cupsd
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21681      2506/io.admin.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          749        610/sshd: /usr/sbin
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14638      429/avahi-daemon: r
                              udp        0      0 0.0.0.0:55672           0.0.0.0:*                           108        14640      429/avahi-daemon: r
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13255      525/dhcpcd
                              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15364      629/cups-browsed
                              udp6       0      0 :::5353                 :::*                                108        14639      429/avahi-daemon: r
                              udp6       0      0 :::53577                :::*                                108        14641      429/avahi-daemon: r
                              2023-04-23 19:47:34.054  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2023-04-23 19:47:34.292  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2023-04-23 19:47:36.168  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2506
                              2023-04-23 19:47:36.527  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 2513
                              2023-04-23 19:47:36.801  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 2520
                              2023-04-23 19:47:41.401  - info: discovery.0 (2520) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                              2023-04-23 19:47:41.573  - info: admin.0 (2506) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                              2023-04-23 19:47:41.828  - info: discovery.0 (2520) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                              2023-04-23 19:47:41.912  - info: backitup.0 (2513) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                              2023-04-23 19:47:42.042  - info: admin.0 (2506) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                              2023-04-23 19:47:42.169  - info: admin.0 (2506) requesting all states
                              2023-04-23 19:47:42.221  - info: backitup.0 (2513) [iobroker] backup was activated at 02:00 every 90 day(s)
                              2023-04-23 19:47:42.171  - info: admin.0 (2506) requesting all objects
                              2023-04-23 19:47:44.040  - info: admin.0 (2506) received all objects
                              2023-04-23 19:47:44.833  - info: admin.0 (2506) http server listening on port 8081
                              2023-04-23 19:47:44.837  - info: admin.0 (2506) Use link "http://localhost:8081" to configure.
                              2023-04-23 19:47:44.866  - info: admin.0 (2506) socket.io server listening on port 8081
                              2023-04-23 19:47:45.104  - error: backitup.0 (2513) Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Daten1/ioBrokerBackup/MainRaspiWohnz /opt/iobroker/backups
                              mount error(13): Permission denied
                              Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                              2023-04-23 19:47:46.111  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                              2023-04-23 19:47:46.661  - info: admin.0 (2506) <== Disconnect system.user.admin from ::ffff:192.168.178.10 admin
                              2023-04-23 19:47:47.674  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                              2023-04-23 19:48:00.026  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                              Ein paar Error scheinen schon noch drin zu sein...
                              Hab nie VIS genutzt geschweige denn installiert.
                                Dann schalte den Desktop an der Kiste aus.
                                  Homoran Global Moderator Administrators @Habedere last edited by Homoran
                                  X-Server: true
                                  warum schleppst du mit den mickrigen 1GB RAM noch einen kompletten Desktop mit?
                                  und die ELSPROBLEMS gefallen mir auch nicht.
                                    Du meinst am Raspberry OS oder am ioBroker?
                                    VIS möchte ich zukünftig evtl. schon nutzen...
                                      Weil ich nur Bahnhof verstehe 🙂
                                      Ich schau gleich mal in die Einstellungen vom Raspberry OS
                                        Mit Display an der gleichen Kiste?
                                        Ich würde das nochmal installieren, diesmal gleich in der Lite-Version, ohne X-Server und ohne CUPS.
                                          nene - extern.
                                          Alles klar - ich mach nochmal alles neu...
                                            nene - extern.
                                            Dann brauchst du natürlich auf dem Server auch keinen X-Server/Desktop.
                                            nodejs 18 nodejs update
                                            60
                                            504
                                            143180
