    3. Einsteigerfragen
    4. Installation
    5. Troubleshooting NodeJS update
      Habedere @Thomas Braun last edited by
      Leider nein - hängt immer noch an der selben stelle 😞
      Also quasi noch schlechter wie vorher....
        Thomas Braun Most Active @Habedere last edited by
        @habedere sagte in Troubleshooting NodeJS update:
        Heißt?
          Freeze
          nulu@raspberrypi:/opt/iobroker $ cd /opt/iobroker
          npm ls | grep -E 'github|ERR'
          npm ERR! code ELSPROBLEMS
          npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
          npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
          npm ERR!     /home/iobroker/.npm/_logs/2023-04-23T11_39_17_688Z-debug-0.log
          sudo -H -u iobroker npm install iobroker.js-controller
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not tran        sfer it over to other users. You may safely remove the package from your dependencies.
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          ^C^C###############) ⠧ reify:iobroker.admin: http fetch GET 200 https://registry.npmjs.org/iobroker.admin/-/iobroker.admin-6.3.5.tgz 52083ms (cache miss)
          mikeal created this issue in request/request
          open Request’s Past, Present and Future #3142
            Freeze
            Glaube ich nicht. Lass das mal laufen.
              Habedere @Thomas Braun last edited by Habedere
              Mach ich - steht halt schon seit ner guten 2 Stunden an der selben Stelle 😉
                Habedere @Habedere last edited by
                @habedere
                Also Shell hat sich nicht mehr bewegt und nach dem ich das Terminal geschlossen habe war eine erneute Anmeldung über SSH nicht möglich. Hab dann den Strom ziehen müssen - aber siehe da, es läuft 🙂
                nulu@raspberrypi:~ $ /opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs &>        /dev/null
                uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx        -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt u        pdate &> /dev/null && sudo apt update && apt policy nodejs
                aarch64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                v18.16.0
                v18.16.0
                9.5.1
                9.5.1
                4.0.24
                nulu
                nulu adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobr                                                           oker
                tty
                /home/nulu
                OK:1 http://deb.debian.org/debian bullseye InRelease
                OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                OK:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                Paketlisten werden gelesen… Fertig
                Abhängigkeitsbaum wird aufgebaut… Fertig
                Statusinformationen werden eingelesen… Fertig
                Alle Pakete sind aktuell.
                nodejs:
                  Installiert:           18.16.0-deb-1nodesource1
                  Installationskandidat: 18.16.0-deb-1nodesource1
                  Versionstabelle:
                 *** 18.16.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                        100 /var/lib/dpkg/status
                     12.22.12~dfsg-1~deb11u3 500
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                     12.22.5~dfsg-2~11u1 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                Werde jetzt mal das Backup einspielen...
                Vielen vielen Dank für die Hilfe!
                Homoran H 3 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @Habedere last edited by
                  nein!
                    wirklich oder nur scheinbar?
                    bitte Ausgabe von iob diag in der Vollversion
                      @habedere
                      Gestopt! Why?
                        @habedere
                        Gestopt! Why?
                        einmal s.o. und zum zweiten: hast du vis manuell installiert?
                        und gestoppt ist abgebrochen ist undefinierter Zustand?
                          Habedere @Homoran last edited by Homoran
                          sorry - mit gestopt meinte ich mich. Hab das Backup noch nicht gestartet weil ich gerade noch deine Nachricht gelesen habe. Hab nur die json des Backup-Adapter eingespielt damit die Zugangsdaten zum Server etc. wieder drin sind...
                          Full diag:
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Model           : Raspberry Pi 3 Model B Rev 1.2
                          Architecture    : aarch64
                          Docker          : false
                          Virtualization  : none
                          Distributor ID: Debian
                          Description:    Debian GNU/Linux 11 (bullseye)
                          Release:        11
                          Codename:       bullseye
                          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                          NAME="Debian GNU/Linux"
                          VERSION_ID="11"
                          VERSION="11 (bullseye)"
                          VERSION_CODENAME=bullseye
                          ID=debian
                          HOME_URL="https://www.debian.org/"
                          SUPPORT_URL="https://www.debian.org/support"
                          BUG_REPORT_URL="https://bugs.debian.org/"
                          Systemuptime and Load:
                           19:51:34 up 14 min,  3 users,  load average: 0.91, 0.88, 0.56
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          Other values than 0x0 hint to temperature/voltage problems
                          temp=54.2'C
                          volt=1.3000V
                          *** Time and Time Zones ***
                                         Local time: Sun 2023-04-23 19:51:34 CEST
                                     Universal time: Sun 2023-04-23 17:51:34 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          nulu
                          /home/nulu
                          nulu adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                          *** X-Server-Setup ***
                          X-Server:       true
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            909M        447M        105M        9.0M        356M        389M
                          Swap:            99M        3.0M         96M
                          Total:          1.0G        450M        201M
                                    909 M total memory
                                    447 M used memory
                                    491 M active memory
                                    192 M inactive memory
                                    105 M free memory
                                      2 M buffer memory
                                    354 M swap cache
                                     99 M total swap
                                      3 M used swap
                                     96 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /dev/root      ext4      110G  4.3G  101G   5% /
                          devtmpfs       devtmpfs  325M     0  325M   0% /dev
                          tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                          tmpfs          tmpfs     182M  1.2M  181M   1% /run
                          /dev/sda1      vfat      255M   31M  225M  13% /boot
                          tmpfs          tmpfs      91M   20K   91M   1% /run/user/1000
                          [Sun Apr 23 19:37:04 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bdb8b6dd-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Sun Apr 23 19:37:10 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                          [Sun Apr 23 19:37:10 2023] EXT4-fs (sda2): write access will be enabled during recovery
                          [Sun Apr 23 19:37:11 2023] EXT4-fs (sda2): recovery complete
                          [Sun Apr 23 19:37:11 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Sun Apr 23 19:37:11 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                          [Sun Apr 23 19:37:14 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                          Show mounted filesystems (real ones only):
                          TARGET  SOURCE    FSTYPE OPTIONS
                          /       /dev/sda2 ext4   rw,noatime
                          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          628M    /var/
                          245M    /var/cache
                          239M    /var/cache/apt
                          184M    /var/lib
                          138M    /var/cache/apt/archives
                          Archived and active journals take up 96.0M in the file system.
                          /opt/iobroker/backups:
                          4.0K    /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          18M     /opt/iobroker/iobroker-data/
                          15M     /opt/iobroker/iobroker-data/files
                          13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                          3.5M    /opt/iobroker/iobroker-data/objects.jsonl
                          2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                          1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                          652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs         v18.16.0
                          /usr/bin/node           v18.16.0
                          /usr/bin/npm            9.5.1
                          /usr/bin/npx            9.5.1
                          nodejs:
                            Installed: 18.16.0-deb-1nodesource1
                            Candidate: 18.16.0-deb-1nodesource1
                            Version table:
                          No problems detected
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          MULTIHOSTSERVICE/enabled: false
                          Core adapters versions
                          js-controller:  4.0.24
                          admin:          6.3.5
                          javascript:     "javascript" not found
                          npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
                          npm ERR! invalid: iobroker.backitup@2.6.16 /opt/iobroker/node_modules/iobroker.backitup
                          npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                          npm ERR! invalid: iobroker.js-controller@4.0.24 /opt/iobroker/node_modules/iobroker.js-controller
                          npm ERR!     /home/nulu/.npm/_logs/2023-04-23T17_52_10_992Z-debug-0.log
                          Adapters from github:   0
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "admin"        : 6.3.5    , installed 6.3.5
                          Adapter    "backitup"     : 2.6.16   , installed 2.6.16
                          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                          Controller "js-controller": 4.0.24   , installed 4.0.24
                          Objects and States
                          Objects:        142
                          States:         104
                          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:3 http://deb.debian.org/debian bullseye InRelease
                          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13265      586/cupsd
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          747        610/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15706      591/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15697      591/iobroker.js-con
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13264      586/cupsd
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21681      2506/io.admin.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          749        610/sshd: /usr/sbin
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14638      429/avahi-daemon: r
                          udp        0      0 0.0.0.0:55672           0.0.0.0:*                           108        14640      429/avahi-daemon: r
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13255      525/dhcpcd
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15364      629/cups-browsed
                          udp6       0      0 :::5353                 :::*                                108        14639      429/avahi-daemon: r
                          udp6       0      0 :::53577                :::*                                108        14641      429/avahi-daemon: r
                          2023-04-23 19:47:34.054  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-04-23 19:47:34.292  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-04-23 19:47:36.168  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2506
                          2023-04-23 19:47:36.527  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 2513
                          2023-04-23 19:47:36.801  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 2520
                          2023-04-23 19:47:41.401  - info: discovery.0 (2520) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                          2023-04-23 19:47:41.573  - info: admin.0 (2506) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                          2023-04-23 19:47:41.828  - info: discovery.0 (2520) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                          2023-04-23 19:47:41.912  - info: backitup.0 (2513) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                          2023-04-23 19:47:42.042  - info: admin.0 (2506) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                          2023-04-23 19:47:42.169  - info: admin.0 (2506) requesting all states
                          2023-04-23 19:47:42.221  - info: backitup.0 (2513) [iobroker] backup was activated at 02:00 every 90 day(s)
                          2023-04-23 19:47:42.171  - info: admin.0 (2506) requesting all objects
                          2023-04-23 19:47:44.040  - info: admin.0 (2506) received all objects
                          2023-04-23 19:47:44.833  - info: admin.0 (2506) http server listening on port 8081
                          2023-04-23 19:47:44.837  - info: admin.0 (2506) Use link "http://localhost:8081" to configure.
                          2023-04-23 19:47:44.866  - info: admin.0 (2506) socket.io server listening on port 8081
                          2023-04-23 19:47:45.104  - error: backitup.0 (2513) Error: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.5/Daten1/ioBrokerBackup/MainRaspiWohnz /opt/iobroker/backups
                          mount error(13): Permission denied
                          Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                          2023-04-23 19:47:46.111  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                          2023-04-23 19:47:46.661  - info: admin.0 (2506) <== Disconnect system.user.admin from ::ffff:192.168.178.10 admin
                          2023-04-23 19:47:47.674  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                          2023-04-23 19:48:00.026  - info: admin.0 (2506) ==> Connected system.user.admin from ::ffff:192.168.178.10
                          Ein paar Error scheinen schon noch drin zu sein...
                          Hab nie VIS genutzt geschweige denn installiert.
                            Dann schalte den Desktop an der Kiste aus.
                              Homoran Global Moderator Administrators @Habedere last edited by Homoran
                              X-Server: true
                              warum schleppst du mit den mickrigen 1GB RAM noch einen kompletten Desktop mit?
                              und die ELSPROBLEMS gefallen mir auch nicht.
                                Du meinst am Raspberry OS oder am ioBroker?
                                VIS möchte ich zukünftig evtl. schon nutzen...
                                  Weil ich nur Bahnhof verstehe 🙂
                                  Ich schau gleich mal in die Einstellungen vom Raspberry OS
                                    Mit Display an der gleichen Kiste?
                                    Ich würde das nochmal installieren, diesmal gleich in der Lite-Version, ohne X-Server und ohne CUPS.
                                      nene - extern.
                                      Alles klar - ich mach nochmal alles neu...
                                        nene - extern.
                                        Dann brauchst du natürlich auf dem Server auch keinen X-Server/Desktop.
                                          Neuer Versuch...
                                          Skript v.2023-04-16
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Release:        11
                                          Codename:       bullseye
                                          VERSION_ID="11"
                                          ID=debian
                                           20:04:34 up 50 min,  2 users,  load average: 0.30, 0.24, 0.30
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x0
                                          temp=51.5'C
                                          volt=1.2938V
                                                         Local time: Sun 2023-04-23 20:04:35 BST
                                                     Universal time: Sun 2023-04-23 19:04:35 UTC
                                                           RTC time: n/a
                                                          Time zone: Europe/London (BST, +0100)
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          nulu
                                          /home/nulu
                                          nulu adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          Boot Target:    multi-user.target
                                          *** MEMORY ***
                                          Mem:            909M        232M        452M        0.0K        224M        613M
                                          Swap:            99M         18M         81M
                                          Total:          1.0G        250M        533M
                                                    909 M total memory
                                                    232 M used memory
                                                    122 M active memory
                                                    233 M inactive memory
                                                    452 M free memory
                                                     24 M buffer memory
                                                    200 M swap cache
                                                     99 M total swap
                                                     18 M used swap
                                                     81 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /dev/root      ext4      110G  2.3G  104G   3% /
                                          tmpfs          tmpfs     182M  1.1M  181M   1% /run
                                          /dev/sda1      vfat      255M   31M  225M  12% /boot
                                          tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                          [Sun Apr 23 19:13:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e2d113b0-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Sun Apr 23 19:14:02 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                          [Sun Apr 23 19:14:02 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                          [Sun Apr 23 19:14:06 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
                                          /var:
                                          458M    /var/
                                          179M    /var/cache
                                          173M    /var/cache/apt
                                          147M    /var/lib
                                          122M    /var/lib/apt/lists
                                          Archived and active journals take up 32.0M in the file system.
                                          384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.3.5
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        142
                                          States:         104
                                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                                          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Pending Updates: 19
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12940      821/sshd: /usr/sbin
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32536      7399/iobroker.js-co
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32529      7399/iobroker.js-co
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          12942      821/sshd: /usr/sbin
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31304      7481/io.admin.0
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14288      920/dhcpcd
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11804      428/avahi-daemon: r
                                          udp        0      0 0.0.0.0:47649           0.0.0.0:*                           108        11806      428/avahi-daemon: r
                                          udp6       0      0 :::54407                :::*                                108        11807      428/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                108        11805      428/avahi-daemon: r
                                          2023-04-23 19:25:03.203  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                                          2023-04-23 19:25:03.206  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
                                          2023-04-23 19:25:04.032  - info: host.raspberrypi connected to Objects and States
                                          2023-04-23 19:25:04.118  - info: host.raspberrypi Node.js version has changed from unknown to 18.16.0
                                          2023-04-23 19:25:04.231  - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                          2023-04-23 19:25:04.292  - info: host.raspberrypi added notifications configuration of host
                                          2023-04-23 19:25:05.103  - info: host.raspberrypi 3 instances found
                                          2023-04-23 19:25:05.124  - info: host.raspberrypi starting 3 instances
                                          2023-04-23 19:25:05.241  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 7481
                                          2023-04-23 19:25:09.197  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 7488
                                          2023-04-23 19:25:10.651  - info: admin.0 (7481) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                                          2023-04-23 19:25:10.780  - info: admin.0 (7481) requesting all states
                                          2023-04-23 19:25:10.782  - info: admin.0 (7481) requesting all objects
                                          2023-04-23 19:25:11.389  - info: admin.0 (7481) received all objects
                                          2023-04-23 19:25:12.036  - info: admin.0 (7481) http server listening on port 8081
                                          2023-04-23 19:25:12.039  - info: admin.0 (7481) Use link "http://localhost:8081" to configure.
                                          2023-04-23 19:25:12.101  - info: admin.0 (7481) socket.io server listening on port 8081
                                          2023-04-23 19:25:12.257  - warn: admin.0 (7481) Repository cannot be read: Active repo - stable
                                          2023-04-23 19:25:12.262  - warn: admin.0 (7481) Active repository "stable" cannot be read
                                          2023-04-23 19:25:13.215  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7516
                                          2023-04-23 19:25:14.316  - info: discovery.0 (7488) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                                          2023-04-23 19:25:18.369  - info: backitup.0 (7516) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                                          2023-04-23 19:25:18.629  - info: backitup.0 (7516) [iobroker] backup was activated at 02:40 every 1 day(s)
                                          2023-04-23 19:25:24.768  - info: admin.0 (7481) ==> Connected system.user.admin from ::ffff:192.168.178.10
                                          2023-04-23 19:25:44.524  - info: admin.0 (7481) ==> Connected system.user.admin from ::ffff:192.168.178.10
                                            Zeitzone setzen.
                                            Pending Updates: 19
                                            System auf Stand halten.
                                            nodejs 18 nodejs update
                                            60
                                            504
                                            143132
