    3. Einsteigerfragen
    4. Installation
    5. iobroker lässt sich nicht mehr starten
      balu67 @Thomas Braun last edited by
      @thomas-braun said in iobroker lässt sich nicht mehr starten:
      sagt?
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model		: Raspberry Pi 4 Model B Rev 1.5
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID:	Debian
      Description:	Debian GNU/Linux 11 (bullseye)
      Release:	11
      Codename:	bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       20:02:09 up 4 min,  2 users,  load average: 0.35, 0.55, 0.29
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=44.3'C
      volt=0.9460V
      *** Time and Time Zones ***
                     Local time: Sun 2023-04-23 20:02:10 CEST
                 Universal time: Sun 2023-04-23 18:02:10 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      al
      /home/al
      al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	true
      Desktop: 	LXDE-pi
      Terminal: 	x11
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:            3.8G        908M        2.2G         36M        667M        2.8G
      Swap:            99M          0B         99M
      Total:          3.9G        908M        2.3G
               3794 M total memory
                908 M used memory
                127 M active memory
               1298 M inactive memory
               2218 M free memory
                 43 M buffer memory
                624 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  9.4G   19G  34% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.3M  758M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  12% /boot
      tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
      [Sun Apr 23 19:57:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sun Apr 23 19:57:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun Apr 23 19:57:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Apr 23 19:57:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      3.9G	/var/
      3.4G	/var/log
      3.0G	/var/log/journal/20caf098a3be48108459316835c16c60
      274M	/var/lib
      Archived and active journals take up 2.9G in the file system.
      /opt/iobroker/backups:
      24M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      585M	/opt/iobroker/iobroker-data/
      446M	/opt/iobroker/iobroker-data/history
      99M	/opt/iobroker/iobroker-data/files
      59M	/opt/iobroker/iobroker-data/history/20230328
      58M	/opt/iobroker/iobroker-data/history/20230329
      12M	/opt/iobroker/iobroker-data/objects.jsonl
      9.4M	/opt/iobroker/iobroker-data/history/20230401/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
      9.3M	/opt/iobroker/iobroker-data/history/20230406/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
      9.3M	/opt/iobroker/iobroker-data/history/20230405/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
      9.3M	/opt/iobroker/iobroker-data/history/20230404/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v16.19.1
      /usr/bin/node 		v16.19.1
      /usr/bin/npm 		8.19.3
      /usr/bin/npx 		8.19.3
      nodejs:
        Installed: 16.19.1-deb-1nodesource1
        Candidate: 16.20.0-deb-1nodesource1
        Version table:
           16.20.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
       *** 16.19.1-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u3 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller: 	4.0.24
      admin: 		6.3.5
      javascript: 	6.1.4
      Adapters from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
      + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
      + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
      + system.adapter.history.0                : history               : Raspberry                                -  enabled
      + system.adapter.influxdb.0               : influxdb              : Raspberry                                -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
      + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                -  enabled
      + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.16   , installed 2.5.12 [Updatable]
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Objects and States
      Objects: 	548
      States: 	426
      W: GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      E: The repository 'https://repos.influxdata.com/debian stretch InRelease' is not signed.
      Pending Updates: 40
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        13646      544/influxd
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17929      2143/io.shelly.0
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          12873      563/vncserver-x11-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12797      574/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14191      545/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14178      545/iobroker.js-con
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15810      538/cupsd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15809      538/cupsd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17038      1420/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      116        13764      544/influxd
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          12872      563/vncserver-x11-c
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12799      574/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      117        14255      540/grafana
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15841      476/dhcpcd
      udp        0      0 0.0.0.0:55596           0.0.0.0:*                           108        13470      397/avahi-daemon: r
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15823      602/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13468      397/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          15852      476/dhcpcd
      udp6       0      0 :::40008                :::*                                108        13471      397/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        13469      397/avahi-daemon: r
      2023-04-23 19:58:17.450  - info: host.Raspberry instance system.adapter.shelly.0 started with pid 2143
      2023-04-23 19:58:18.819  - info: javascript.0 (2092) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.19.1, js-controller: 4.0.24
      2023-04-23 19:58:19.233  - info: javascript.0 (2092) requesting all states
      2023-04-23 19:58:19.234  - info: javascript.0 (2092) requesting all objects
      2023-04-23 19:58:19.618  - info: javascript.0 (2092) received all objects
      2023-04-23 19:58:19.631  - info: javascript.0 (2092) received all states
      2023-04-23 19:58:19.742  - info: javascript.0 (2092) Start javascript script.js.Test
      2023-04-23 19:58:19.819  - info: javascript.0 (2092) script.js.Test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2023-04-23 19:58:20.596  - info: shelly.0 (2143) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v16.19.1, js-controller: 4.0.24
      2023-04-23 19:58:20.838  - info: shelly.0 (2143) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
      2023-04-23 19:58:21.436  - info: host.Raspberry instance system.adapter.discovery.0 started with pid 2212
      2023-04-23 19:58:23.333  - info: discovery.0 (2212) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
      2023-04-23 19:58:25.433  - info: host.Raspberry instance system.adapter.backitup.0 started with pid 2227
      2023-04-23 19:58:27.498  - info: backitup.0 (2227) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
      2023-04-23 19:58:27.720  - info: backitup.0 (2227) [iobroker] backup was activated at 02:40 every 1 day(s)
      2023-04-23 19:58:29.423  - info: host.Raspberry instance system.adapter.echarts.0 started with pid 2242
      2023-04-23 19:58:31.022  - info: shelly.0 (2143) [MQTT] Device with client id "shellyem-244CAB418C05" connected!
      2023-04-23 19:58:31.254  - info: echarts.0 (2242) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.echarts, node: v16.19.1, js-controller: 4.0.24
      2023-04-23 19:58:33.431  - info: host.Raspberry instance system.adapter.panasonic-comfort-cloud.0 started with pid 2257
      2023-04-23 19:58:34.777  - info: shelly.0 (2143) [MQTT] Device with client id "shellyplus1pm-a8032ab5f934" connected!
      2023-04-23 19:58:35.382  - info: panasonic-comfort-cloud.0 (2257) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud, node: v16.19.1, js-controller: 4.0.24
      2023-04-23 19:58:35.558  - info: panasonic-comfort-cloud.0 (2257) state panasonic-comfort-cloud.0.info.connection changed: false (ack = true)
      2023-04-23 19:58:36.564  - info: shelly.0 (2143) [MQTT] Device with client id "shellyplug-s-4022D880D8D8" connected!
      2023-04-23 19:58:37.126  - info: panasonic-comfort-cloud.0 (2257) Login successful.
      2023-04-23 19:58:37.150  - info: panasonic-comfort-cloud.0 (2257) state panasonic-comfort-cloud.0.info.connection changed: true (ack = true)
      B crunchip Thomas Braun 3 Replies Last reply Reply Quote 0
        balu67 @balu67 last edited by
        es gibt noch eine Zusammenfassung
        ====================== SUMMARY =======================
        		     v.2023-04-16
        Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
        Kernel: 		5.15.84-v8+
        Installation: 		Native
        Timezone: 		Europe/Berlin (CEST, +0200)
        User-ID: 		1000
        X-Server: 		true
        Pending OS-Updates: 	40
        Pending iob updates: 	1
        Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.1
        			/usr/bin/npm 		8.19.3
        			/usr/bin/npx 		8.19.3
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            3.8G        941M        1.9G         31M        951M        2.8G
        Swap:            99M          0B         99M
        Total:          3.9G        941M        2.0G
        Active iob-Instances: 	10
        ioBroker Core: 		js-controller 		4.0.24
        			admin 			6.3.5
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		548
        States: 		426
        Size of iob-Database:
        1.2M	/opt/iobroker/iobroker-data/states.jsonl
          balu67 @Thomas Braun last edited by balu67
          mal ausgeführt?
          ja,
              Welcome to the ioBroker installation fixer!
              Script version: 2023-04-02
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          OK:1 http://deb.debian.org/debian bullseye InRelease
          OK:2 http://deb.debian.org/debian bullseye-updates InRelease
          OK:3 http://security.debian.org/debian-security bullseye-security InRelease
          OK:4 https://packages.grafana.com/oss/deb stable InRelease
          OK:5 http://archive.raspberrypi.org/debian bullseye InRelease
          OK:6 https://deb.nodesource.com/node_16.x bullseye InRelease
          Holen:7 https://repos.influxdata.com/debian stretch InRelease [7.030 B]
          Fehl:7 https://repos.influxdata.com/debian stretch InRelease
            Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
          W: GPG-Fehler: https://repos.influxdata.com/debian stretch InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
          E: Das Depot »https://repos.influxdata.com/debian stretch InRelease« ist nicht signiert.
          N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
          N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/5)
          Created /etc/sudoers.d/iobroker
          Fixing directory permissions...
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 2 JSONL files. Done
              Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          keine Veränderung, es kommt nur das Intro
            crunchip Forum Testing Most Active @balu67 last edited by
            @balu67 sagte in iobroker lässt sich nicht mehr starten:
            debian stretch
              Thomas Braun Most Active @balu67 last edited by
              X-Server: true
              Ausschalten.
              Nodejs 18 installieren.
              iobroker und die Adapter aktuell halten.
              Stretch ist eh falsch und die Keys müssen neuangelegt werden. Zieh das repo nochmal aktuell neu rein.
                Homoran Global Moderator Administrators @balu67 last edited by
                ich hab aber PC und Raspberry neu gestartet und nichts geöffnet
                PC ist irrelevant und iobroker startet automatisch nach reboot des Raspi!
                also iob stop!
                  balu67 @crunchip last edited by
                  @crunchip said in iobroker lässt sich nicht mehr starten:
                  debian stretch
                  was meinst du ?
                    X-Server: true
                    Ausschalten.
                    wie mach ich das?
                      was meinst du ?
                      Damit ist gemeint, das du Ersatzteile vom Modell 'Stretch' in deinen 'Bullseye' schraubst. Funktioniert aber nicht (immer) und daher verbaut man auch zu seiner Version passende Teile.
                        Thomas Braun Most Active @balu67 last edited by Thomas Braun
                        wie mach ich das?
                        sudo raspi-config
                        Menüpunkte:
                        1 System Options
                        S5 Boot / Auto Login
                        B1 Console
                        Alternativ:
                        sudo systemctl set-default multi-user.target
                          wie mach ich das?
                          sudo raspi-config
                          Menüpunkte:
                          1 System Options
                          B1 Console
                          Alternativ:
                          ok, hab ich gemacht. Und jetzt soll ich Nodejs18 installieren?
                            @balu67
                            Zuerst musst du die influxdb-Quelle richtig einbinden, sonst blockt auch die nodejs-Installation.
                            sudo rm /etc/apt/sources.list.d/influ*
                            wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                            echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                            echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                              das Verzeichnis gibt es scheinbar nicht
                              es gibt direkt unter "apt" einen Ordnenr mit dem Namen influxdb und darin ist eine Datei "influxdb.conf"
                              Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
                                @balu67 text bitte als Text in code-tags posten
                                Hier steht warum
                                  @balu67
                                  grep -rnw '/etc/apt/' -e 'stretch'
                                    Das ist auch falsch. Eine influxdb.conf hat in /etc/apt nix zu suchen.
                                      @balu67
                                      grep: /etc/apt/trusted.gpg.d/debian-archive-stretch-security-automatic.gpg: Übereinstimmungen in Binärdatei
                                      grep: /etc/apt/trusted.gpg.d/debian-archive-stretch-automatic.gpg: Übereinstimmungen in Binärdatei
                                      grep: /etc/apt/trusted.gpg.d/debian-archive-stretch-stable.gpg: Übereinstimmungen in Binärdatei
                                        ich hab da nichts gemacht, wurde so bei der Installation abgelegt
                                          @balu67
                                          sudo apt update
                                          sudo apt update
                                          apt policy influxdb*
                                            al@Raspberry:~ $ sudo apt update
                                            OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                            OK:5 https://packages.grafana.com/oss/deb stable InRelease
                                            Abhängigkeitsbaum wird aufgebaut... Fertig
                                            Statusinformationen werden eingelesen... Fertig
                                            Aktualisierung für 40 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                            al@Raspberry:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                            OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                            OK:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                                            OK:3 http://deb.debian.org/debian bullseye InRelease
                                            OK:4 http://deb.debian.org/debian bullseye-updates InRelease
                                            OK:6 http://security.debian.org/debian-security bullseye-security InRelease
                                            al@Raspberry:~ $ apt policy influxdb*
                                            influxdb-client:
                                              Installiert:           (keine)
                                              Installationskandidat: 1.6.7~rc0-1+b5
                                              Versionstabelle:
                                                 1.6.7~rc0-1+b5 500
                                            influxdb-dev:
                                              Installationskandidat: (keine)
                                              Versionstabelle:
                                            influxdb:
                                              Installiert:           1.6.7~rc0-1+b5
                                              Versionstabelle:
                                             *** 1.6.7~rc0-1+b5 500
                                            1.0k
                                            7757
