    3. Einsteigerfragen
    4. Installation
    5. iobroker lässt sich nicht mehr starten
      Homoran Global Moderator Administrators @balu67 last edited by
      @balu67 sudo apt upgrade
      und wenn das durch ist
      iob diag
        balu67 @Homoran last edited by balu67
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model		: Raspberry Pi 4 Model B Rev 1.5
        Architecture    : aarch64
        Docker          : false
        Virtualization  : none
        Distributor ID:	Debian
        Description:	Debian GNU/Linux 11 (bullseye)
        Release:	11
        Codename:	bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         10:01:12 up 29 min,  2 users,  load average: 0.45, 0.59, 0.46
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=41.3'C
        volt=0.9460V
        *** Time and Time Zones ***
                       Local time: Mon 2023-04-24 10:01:12 CEST
                   Universal time: Mon 2023-04-24 08:01:12 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        al
        /home/al
        al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	true
        Desktop: 	LXDE-pi
        Terminal: 	x11
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            3.8G        895M        2.0G         35M        918M        2.8G
        Swap:            99M          0B         99M
        Total:          3.9G        895M        2.1G
                 3794 M total memory
                  895 M used memory
                 1263 M active memory
                  395 M inactive memory
                 1980 M free memory
                   58 M buffer memory
                  860 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4       29G  9.6G   19G  35% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.3M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
        [Mon Apr 24 09:31:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Mon Apr 24 09:31:17 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Apr 24 09:31:17 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Mon Apr 24 09:31:19 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        4.0G	/var/
        3.3G	/var/log
        2.9G	/var/log/journal/20caf098a3be48108459316835c16c60
        304M	/var/cache
        Archived and active journals take up 2.8G in the file system.
        /opt/iobroker/backups:
        24M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        585M	/opt/iobroker/iobroker-data/
        446M	/opt/iobroker/iobroker-data/history
        99M	/opt/iobroker/iobroker-data/files
        59M	/opt/iobroker/iobroker-data/history/20230328
        58M	/opt/iobroker/iobroker-data/history/20230329
        9.4M	/opt/iobroker/iobroker-data/history/20230401/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
        9.3M	/opt/iobroker/iobroker-data/history/20230406/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
        9.3M	/opt/iobroker/iobroker-data/history/20230405/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
        9.3M	/opt/iobroker/iobroker-data/history/20230404/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
        9.3M	/opt/iobroker/iobroker-data/history/20230402/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v16.20.0
        /usr/bin/node 		v16.20.0
        /usr/bin/npm 		8.19.4
        /usr/bin/npx 		8.19.4
        nodejs:
          Installed: 16.20.0-deb-1nodesource1
          Candidate: 18.16.0-deb-1nodesource1
          Version table:
             18.16.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         *** 16.20.0-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u3 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller: 	4.0.24
        admin: 		6.3.5
        javascript: 	6.1.4
        Adapters from github: 	0
        Adapter State
        + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
        + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
        + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
        + system.adapter.history.0                : history               : Raspberry                                -  enabled
        + system.adapter.influxdb.0               : influxdb              : Raspberry                                -  enabled, port: 8086
        + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
        + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                -  enabled
        + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.3.5    , installed 6.3.5
        Adapter    "backitup"     : 2.6.16   , installed 2.5.12 [Updatable]
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "echarts"      : 1.0.12   , installed 1.0.12
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
        Adapter    "shelly"       : 6.3.1    , installed 6.3.1
        Objects and States
        Objects: 	548
        States: 	425
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
        Hit:7 https://packages.grafana.com/oss/deb stable InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13870      581/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15088      539/cupsd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18015      775/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17989      775/iobroker.js-con
        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          1869       565/vncserver-x11-c
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       20615      2165/io.shelly.0
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        15362      551/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13872      581/sshd: /usr/sbin
        tcp6       0      0 :::3000                 :::*                    LISTEN      117        17865      544/grafana
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15087      539/cupsd
        tcp6       0      0 :::5900                 :::*                    LISTEN      0          1868       565/vncserver-x11-c
        tcp6       0      0 :::8086                 :::*                    LISTEN      116        15442      551/influxd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18789      1561/io.admin.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15368      476/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13932      614/cups-browsed
        udp        0      0 0.0.0.0:46198           0.0.0.0:*                           108        13803      397/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13801      397/avahi-daemon: r
        udp6       0      0 :::50982                :::*                                108        13804      397/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          15379      476/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        13802      397/avahi-daemon: r
         / "{\"error\":\"timeout\"}\n""
        2023-04-24 09:57:37.921  - info: influxdb.0 (2111) Discard point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power, error-count=10
        2023-04-24 09:57:38.924  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:28.911Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
        2023-04-24 09:57:38.925  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=1
        2023-04-24 09:57:39.922  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:29.912Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
        2023-04-24 09:57:39.922  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=2
        2023-04-24 09:57:40.921  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:30.913Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
        2023-04-24 09:57:40.922  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=3
        2023-04-24 09:57:41.924  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:31.915Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
        2023-04-24 09:57:41.924  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=4
        2023-04-24 09:57:42.930  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:32.918Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
        2023-04-24 09:57:42.931  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=5
        2023-04-24 09:57:43.928  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:33.920Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
        2023-04-24 09:57:43.928  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=6
        2023-04-24 09:57:44.929  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:34.921Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
        2023-04-24 09:57:44.930  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=7
        2023-04-24 09:57:51.533  - info: panasonic-comfort-cloud.0 (2229) state panasonic-comfort-cloud.0.info.connection changed: true (ack = true)
        2023-04-24 09:57:53.328  - info: panasonic-comfort-cloud.0 (2229) state panasonic-comfort-cloud.0.Wohnzimmer .insideTemperature changed: 22 (ack = true)
          Homoran Global Moderator Administrators @balu67 last edited by Homoran
          @balu67 sagte in iobroker lässt sich nicht mehr starten:
          Desktop: LXDE-pi
          du hast ja immer noch einen Desktop
          und node v16
          ich hab auch dein sudo apt upgrade nicht zu sehen bekommen
          Pending Updates: 1
          wahrscheinlich ist es nicht gelaufen!
            @homoran said in iobroker lässt sich nicht mehr starten:
            doch
            al@Raspberry:~ $ sudo apt update
            OK:1 http://security.debian.org/debian-security bullseye-security InRelease
            OK:2 https://repos.influxdata.com/debian stable InRelease
            OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
            OK:4 http://deb.debian.org/debian bullseye InRelease
            OK:5 http://deb.debian.org/debian bullseye-updates InRelease
            OK:6 https://packages.grafana.com/oss/deb stable InRelease
            OK:7 https://deb.nodesource.com/node_18.x bullseye InRelease
            Abhängigkeitsbaum wird aufgebaut... Fertig
            Statusinformationen werden eingelesen... Fertig
            Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
              Thomas Braun Most Active @balu67 last edited by
              @balu67
              iob stop
              sudo apt full-upgrade
              iob fix
              sudo reboot
                doch
                Nein!
                das ist
                sudo apt update
                  doch
                  Nein!
                  das ist
                  sudo apt update
                  mann, bin ich bescheuert
                    balu67 @balu67 last edited by
                    leider keine Veränderung, nur das intro kommt
                    al@Raspberry:/opt $ iob fix
                    library: loaded
                    Library version=2022-12-09
                        Welcome to the ioBroker installation fixer!
                        Script version: 2023-04-02
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/5)
                    OK:1 http://deb.debian.org/debian bullseye InRelease
                    Holen:2 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                    OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                    OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    OK:5 https://repos.influxdata.com/debian stable InRelease
                    OK:6 https://deb.nodesource.com/node_18.x bullseye InRelease
                    OK:7 https://packages.grafana.com/oss/deb stable InRelease
                    Es wurden 44,1 kB in 2 s geholt (25,3 kB/s).
                    Installed gcc-c++
                        Checking ioBroker user and directory permissions (2/5)
                    Created /etc/sudoers.d/iobroker
                    Fixing directory permissions...
                        Check and cleanup npm temporary directories (3/5)
                    Done.
                        Database maintenance (4/5)
                    Checking for uncompressed JSONL databases... This might take a while!
                    Compressing /opt/iobroker/iobroker-data/states.jsonl
                    Compressing /opt/iobroker/iobroker-data/objects.jsonl
                    Compressed 2 JSONL files. Done
                        Checking autostart (5/5)
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    crunchip Homoran 2 Replies Last reply Reply Quote 0
                      crunchip Forum Testing Most Active @balu67 last edited by crunchip
                      hast du das eingegeben?
                        bei iob diag?
                          balu67 @crunchip last edited by
                          @crunchip said in iobroker lässt sich nicht mehr starten:
                          ja, hab ich, kommt aber nur das
                          Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                            @balu67
                            Kiste neugestartet?
                            iob diag
                            sagt?
                              bei iob diag?
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:	11
                              Codename:	bullseye
                              VERSION_ID="11"
                              ID=debian
                               14:51:31 up  4:26,  2 users,  load average: 0.68, 0.49, 0.21
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=42.8'C
                              volt=0.9460V
                                             Local time: Mon 2023-04-24 14:51:31 CEST
                                         Universal time: Mon 2023-04-24 12:51:31 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              al
                              /home/al
                              X-Server: 	true
                              Desktop: 	LXDE-pi
                              Terminal: 	x11
                              *** MEMORY ***
                              Mem:            3.8G        950M        1.5G         41M        1.3G        2.8G
                              Swap:            99M          0B         99M
                              Total:          3.9G        950M        1.6G
                                       3794 M total memory
                                        950 M used memory
                                       1447 M active memory
                                        590 M inactive memory
                                       1525 M free memory
                                        135 M buffer memory
                                       1183 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              [Mon Apr 24 10:25:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                              [Mon Apr 24 10:25:08 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Mon Apr 24 10:25:08 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                              [Mon Apr 24 10:25:10 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                              /var:
                              4.0G	/var/
                              3.4G	/var/log
                              3.0G	/var/log/journal/20caf098a3be48108459316835c16c60
                              304M	/var/cache
                              Archived and active journals take up 2.9G in the file system.
                              580M	/opt/iobroker/iobroker-data/
                              447M	/opt/iobroker/iobroker-data/history
                              /usr/bin/nodejs 	v18.16.0
                              /usr/bin/node 		v18.16.0
                              /usr/bin/npm 		9.5.1
                              /usr/bin/npx 		9.5.1
                              nodejs:
                                Installed: 18.16.0-deb-1nodesource1
                                Version table:
                               *** 18.16.0-deb-1nodesource1 500
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin: 		6.3.5
                              javascript: 	6.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects: 	548
                              States: 	426
                              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                              Hit:2 https://packages.grafana.com/oss/deb stable InRelease
                              Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                              Hit:4 http://deb.debian.org/debian bullseye InRelease
                              Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
                              Hit:7 https://repos.influxdata.com/debian stable InRelease
                              Pending Updates: 0
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15485      534/cupsd
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       123254     6824/iobroker.js-co
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       123247     6824/iobroker.js-co
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14033      583/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        1848       554/influxd
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       122473     6917/io.shelly.0
                              tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15495      567/vncserver-x11-c
                              tcp6       0      0 :::3000                 :::*                    LISTEN      117        15946      542/grafana
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          14044      583/sshd: /usr/sbin
                              tcp6       0      0 :::5900                 :::*                    LISTEN      0          15494      567/vncserver-x11-c
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15484      534/cupsd
                              tcp6       0      0 :::8086                 :::*                    LISTEN      116        15042      554/influxd
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       121728     6842/io.admin.0
                              udp        0      0 0.0.0.0:45059           0.0.0.0:*                           108        13969      403/avahi-daemon: r
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15531      477/dhcpcd
                              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15522      616/cups-browsed
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13967      403/avahi-daemon: r
                              udp6       0      0 :::546                  :::*                                0          15550      477/dhcpcd
                              udp6       0      0 :::35639                :::*                                108        13970      403/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                108        13968      403/avahi-daemon: r
                              2023-04-24 14:47:28.051  - info: javascript.0 (6902) requesting all objects
                              2023-04-24 14:47:28.425  - info: javascript.0 (6902) received all objects
                              2023-04-24 14:47:28.467  - info: javascript.0 (6902) received all states
                              2023-04-24 14:47:28.494  - info: host.Raspberry instance system.adapter.shelly.0 started with pid 6917
                              2023-04-24 14:47:28.567  - info: javascript.0 (6902) Start javascript script.js.Test
                              2023-04-24 14:47:28.632  - info: javascript.0 (6902) script.js.Test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              2023-04-24 14:47:30.990  - info: shelly.0 (6917) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.16.0, js-controller: 4.0.24
                              2023-04-24 14:47:31.209  - info: shelly.0 (6917) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
                              2023-04-24 14:47:32.475  - info: host.Raspberry instance system.adapter.discovery.0 started with pid 6932
                              2023-04-24 14:47:34.385  - info: discovery.0 (6932) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                              2023-04-24 14:47:36.472  - info: host.Raspberry instance system.adapter.backitup.0 started with pid 6947
                              2023-04-24 14:47:38.590  - info: backitup.0 (6947) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                              2023-04-24 14:47:38.700  - info: backitup.0 (6947) [iobroker] backup was activated at 02:40 every 1 day(s)
                              2023-04-24 14:47:39.424  - info: shelly.0 (6917) [MQTT] Device with client id "shellyem-244CAB418C05" connected!
                              2023-04-24 14:47:40.479  - info: host.Raspberry instance system.adapter.echarts.0 started with pid 6962
                              2023-04-24 14:47:42.480  - info: echarts.0 (6962) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.16.0, js-controller: 4.0.24
                              2023-04-24 14:47:43.124  - info: shelly.0 (6917) [MQTT] Device with client id "shellyplug-s-4022D880D8D8" connected!
                              2023-04-24 14:47:44.472  - info: host.Raspberry instance system.adapter.panasonic-comfort-cloud.0 started with pid 6977
                              2023-04-24 14:47:46.305  - info: panasonic-comfort-cloud.0 (6977) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud, node: v18.16.0, js-controller: 4.0.24
                              2023-04-24 14:47:46.514  - info: panasonic-comfort-cloud.0 (6977) state panasonic-comfort-cloud.0.info.connection changed: false (ack = true)
                              2023-04-24 14:47:48.970  - info: shelly.0 (6917) [MQTT] Device with client id "shellyplus1pm-a8032ab5f934" connected!
                              2023-04-24 14:47:51.127  - info: panasonic-comfort-cloud.0 (6977) Login successful.
                              2023-04-24 14:47:51.145  - info: panasonic-comfort-cloud.0 (6977) state panasonic-comfort-cloud.0.info.connection changed: true (ack = true)
                              2023-04-24 14:50:28.444  - info: admin.0 (6842) ==> Connected system.user.admin from ::ffff:192.168.178.28
                              2023-04-24 14:52:20.614  - info: admin.0 (6842) <== Disconnect system.user.admin from ::ffff:192.168.178.28 admin
                              B Thomas Braun 2 Replies Last reply Reply Quote 0
                                und noch das summary
                                		     v.2023-04-16
                                Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
                                Kernel: 		6.1.21-v8+
                                Installation: 		Native
                                Timezone: 		Europe/Berlin (CEST, +0200)
                                User-ID: 		1000
                                X-Server: 		true
                                Pending OS-Updates: 	0
                                Pending iob updates: 	1
                                Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
                                			/usr/bin/npm 		9.5.1
                                			/usr/bin/npx 		9.5.1
                                Recommended versions are nodejs 18.x.y and npm 9.x.y
                                MEMORY:
                                Mem:            3.8G        961M        1.5G         35M        1.3G        2.8G
                                Swap:            99M          0B         99M
                                Total:          3.9G        961M        1.6G
                                Active iob-Instances: 	10
                                ioBroker Core: 		js-controller 		4.0.24
                                			admin 			6.3.5
                                ioBroker Status: 	iobroker is running on this host.
                                Objects type: jsonl
                                States  type: jsonl
                                Objects: 		548
                                States: 		426
                                Size of iob-Database:
                                7.3M	/opt/iobroker/iobroker-data/objects.jsonl
                                296K	/opt/iobroker/iobroker-data/states.jsonl
                                  @balu67 sieht mir eher nach nem Browsercache Fehler aus
                                    X-Server: true Desktop: LXDE-pi
                                    Keinen Desktop!
                                      was kann ich noch machen?
                                        balu67 @Thomas Braun last edited by
                                        @thomas-braun said in iobroker lässt sich nicht mehr starten:
                                        Keinen Desktop!
                                        den brauch ich, da ich sonst gar nichts machen kann......nicht mal nach Dateien sehen oder......
                                          @balu67
                                          Macht man natürlich im Terminal.
                                            STRG-F5
                                            und was kommt Jetzt als Meldung?
                                            1.2k
                                            7757
