    3. Einsteigerfragen
    4. Installation
    5. iobroker lässt sich nicht mehr starten
      balu67 @Homoran last edited by balu67
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model		: Raspberry Pi 4 Model B Rev 1.5
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID:	Debian
      Description:	Debian GNU/Linux 11 (bullseye)
      Release:	11
      Codename:	bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       10:01:12 up 29 min,  2 users,  load average: 0.45, 0.59, 0.46
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=41.3'C
      volt=0.9460V
      *** Time and Time Zones ***
                     Local time: Mon 2023-04-24 10:01:12 CEST
                 Universal time: Mon 2023-04-24 08:01:12 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      al
      /home/al
      al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	true
      Desktop: 	LXDE-pi
      Terminal: 	x11
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:            3.8G        895M        2.0G         35M        918M        2.8G
      Swap:            99M          0B         99M
      Total:          3.9G        895M        2.1G
               3794 M total memory
                895 M used memory
               1263 M active memory
                395 M inactive memory
               1980 M free memory
                 58 M buffer memory
                860 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  9.6G   19G  35% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.3M  758M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
      [Mon Apr 24 09:31:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Mon Apr 24 09:31:17 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Apr 24 09:31:17 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Apr 24 09:31:19 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      4.0G	/var/
      3.3G	/var/log
      2.9G	/var/log/journal/20caf098a3be48108459316835c16c60
      304M	/var/cache
      Archived and active journals take up 2.8G in the file system.
      /opt/iobroker/backups:
      24M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      585M	/opt/iobroker/iobroker-data/
      446M	/opt/iobroker/iobroker-data/history
      99M	/opt/iobroker/iobroker-data/files
      59M	/opt/iobroker/iobroker-data/history/20230328
      58M	/opt/iobroker/iobroker-data/history/20230329
      9.4M	/opt/iobroker/iobroker-data/history/20230401/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
      9.3M	/opt/iobroker/iobroker-data/history/20230406/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
      9.3M	/opt/iobroker/iobroker-data/history/20230405/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
      9.3M	/opt/iobroker/iobroker-data/history/20230404/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
      9.3M	/opt/iobroker/iobroker-data/history/20230402/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v16.20.0
      /usr/bin/node 		v16.20.0
      /usr/bin/npm 		8.19.4
      /usr/bin/npx 		8.19.4
      nodejs:
        Installed: 16.20.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
           18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
       *** 16.20.0-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u3 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller: 	4.0.24
      admin: 		6.3.5
      javascript: 	6.1.4
      Adapters from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
      + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
      + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
      + system.adapter.history.0                : history               : Raspberry                                -  enabled
      + system.adapter.influxdb.0               : influxdb              : Raspberry                                -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
      + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                -  enabled
      + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.16   , installed 2.5.12 [Updatable]
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Objects and States
      Objects: 	548
      States: 	425
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:7 https://packages.grafana.com/oss/deb stable InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13870      581/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15088      539/cupsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18015      775/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17989      775/iobroker.js-con
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          1869       565/vncserver-x11-c
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       20615      2165/io.shelly.0
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        15362      551/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13872      581/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      117        17865      544/grafana
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15087      539/cupsd
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          1868       565/vncserver-x11-c
      tcp6       0      0 :::8086                 :::*                    LISTEN      116        15442      551/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18789      1561/io.admin.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15368      476/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13932      614/cups-browsed
      udp        0      0 0.0.0.0:46198           0.0.0.0:*                           108        13803      397/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13801      397/avahi-daemon: r
      udp6       0      0 :::50982                :::*                                108        13804      397/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          15379      476/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        13802      397/avahi-daemon: r
       / "{\"error\":\"timeout\"}\n""
      2023-04-24 09:57:37.921  - info: influxdb.0 (2111) Discard point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power, error-count=10
      2023-04-24 09:57:38.924  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:28.911Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
      2023-04-24 09:57:38.925  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=1
      2023-04-24 09:57:39.922  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:29.912Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
      2023-04-24 09:57:39.922  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=2
      2023-04-24 09:57:40.921  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:30.913Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
      2023-04-24 09:57:40.922  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=3
      2023-04-24 09:57:41.924  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:31.915Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
      2023-04-24 09:57:41.924  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=4
      2023-04-24 09:57:42.930  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:32.918Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
      2023-04-24 09:57:42.931  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=5
      2023-04-24 09:57:43.928  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:33.920Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
      2023-04-24 09:57:43.928  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=6
      2023-04-24 09:57:44.929  - warn: influxdb.0 (2111) Error on writePoint("{"value":0,"time":"2023-04-24T07:57:34.921Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
      2023-04-24 09:57:44.930  - info: influxdb.0 (2111) Add point that had error for shelly.0.SHEM#244CAB418C05#1.Emeter0.Power to buffer again, error-count=7
      2023-04-24 09:57:51.533  - info: panasonic-comfort-cloud.0 (2229) state panasonic-comfort-cloud.0.info.connection changed: true (ack = true)
      2023-04-24 09:57:53.328  - info: panasonic-comfort-cloud.0 (2229) state panasonic-comfort-cloud.0.Wohnzimmer .insideTemperature changed: 22 (ack = true)
        Homoran Global Moderator Administrators @balu67 last edited by Homoran
        @balu67 sagte in iobroker lässt sich nicht mehr starten:
        Desktop: LXDE-pi
        du hast ja immer noch einen Desktop
        und node v16
        ich hab auch dein sudo apt upgrade nicht zu sehen bekommen
        Pending Updates: 1
        wahrscheinlich ist es nicht gelaufen!
          @homoran said in iobroker lässt sich nicht mehr starten:
          doch
          al@Raspberry:~ $ sudo apt update
          OK:1 http://security.debian.org/debian-security bullseye-security InRelease
          OK:2 https://repos.influxdata.com/debian stable InRelease
          OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
          OK:4 http://deb.debian.org/debian bullseye InRelease
          OK:5 http://deb.debian.org/debian bullseye-updates InRelease
          OK:6 https://packages.grafana.com/oss/deb stable InRelease
          OK:7 https://deb.nodesource.com/node_18.x bullseye InRelease
          Abhängigkeitsbaum wird aufgebaut... Fertig
          Statusinformationen werden eingelesen... Fertig
          Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
            Thomas Braun Most Active @balu67 last edited by
            @balu67
            iob stop
            sudo apt full-upgrade
            iob fix
            sudo reboot
              doch
              Nein!
              das ist
              sudo apt update
                doch
                Nein!
                das ist
                sudo apt update
                mann, bin ich bescheuert
                  balu67 @balu67 last edited by
                  leider keine Veränderung, nur das intro kommt
                  al@Raspberry:/opt $ iob fix
                  library: loaded
                  Library version=2022-12-09
                      Welcome to the ioBroker installation fixer!
                      Script version: 2023-04-02
                      You might need to enter your password a couple of times.
                      Installing prerequisites (1/5)
                  OK:1 http://deb.debian.org/debian bullseye InRelease
                  Holen:2 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                  OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                  OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  OK:5 https://repos.influxdata.com/debian stable InRelease
                  OK:6 https://deb.nodesource.com/node_18.x bullseye InRelease
                  OK:7 https://packages.grafana.com/oss/deb stable InRelease
                  Es wurden 44,1 kB in 2 s geholt (25,3 kB/s).
                  Installed gcc-c++
                      Checking ioBroker user and directory permissions (2/5)
                  Created /etc/sudoers.d/iobroker
                  Fixing directory permissions...
                      Check and cleanup npm temporary directories (3/5)
                  Done.
                      Database maintenance (4/5)
                  Checking for uncompressed JSONL databases... This might take a while!
                  Compressing /opt/iobroker/iobroker-data/states.jsonl
                  Compressing /opt/iobroker/iobroker-data/objects.jsonl
                  Compressed 2 JSONL files. Done
                      Checking autostart (5/5)
                  Enabling autostart...
                  Autostart enabled!
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                  crunchip Homoran 2 Replies Last reply Reply Quote 0
                    crunchip Forum Testing Most Active @balu67 last edited by crunchip
                    hast du das eingegeben?
                      bei iob diag?
                        balu67 @crunchip last edited by
                        @crunchip said in iobroker lässt sich nicht mehr starten:
                        ja, hab ich, kommt aber nur das
                        Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                          @balu67
                          Kiste neugestartet?
                          iob diag
                          sagt?
                            bei iob diag?
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Docker          : false
                            Release:	11
                            Codename:	bullseye
                            VERSION_ID="11"
                            ID=debian
                             14:51:31 up  4:26,  2 users,  load average: 0.68, 0.49, 0.21
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=42.8'C
                            volt=0.9460V
                                           Local time: Mon 2023-04-24 14:51:31 CEST
                                       Universal time: Mon 2023-04-24 12:51:31 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            al
                            /home/al
                            X-Server: 	true
                            Desktop: 	LXDE-pi
                            Terminal: 	x11
                            *** MEMORY ***
                            Mem:            3.8G        950M        1.5G         41M        1.3G        2.8G
                            Swap:            99M          0B         99M
                            Total:          3.9G        950M        1.6G
                                     3794 M total memory
                                      950 M used memory
                                     1447 M active memory
                                      590 M inactive memory
                                     1525 M free memory
                                      135 M buffer memory
                                     1183 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            [Mon Apr 24 10:25:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                            [Mon Apr 24 10:25:08 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Mon Apr 24 10:25:08 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Mon Apr 24 10:25:10 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                            /var:
                            4.0G	/var/
                            3.4G	/var/log
                            3.0G	/var/log/journal/20caf098a3be48108459316835c16c60
                            304M	/var/cache
                            Archived and active journals take up 2.9G in the file system.
                            580M	/opt/iobroker/iobroker-data/
                            447M	/opt/iobroker/iobroker-data/history
                            /usr/bin/nodejs 	v18.16.0
                            /usr/bin/node 		v18.16.0
                            /usr/bin/npm 		9.5.1
                            /usr/bin/npx 		9.5.1
                            nodejs:
                              Installed: 18.16.0-deb-1nodesource1
                              Version table:
                             *** 18.16.0-deb-1nodesource1 500
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin: 		6.3.5
                            javascript: 	6.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects: 	548
                            States: 	426
                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:2 https://packages.grafana.com/oss/deb stable InRelease
                            Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                            Hit:4 http://deb.debian.org/debian bullseye InRelease
                            Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:7 https://repos.influxdata.com/debian stable InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15485      534/cupsd
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       123254     6824/iobroker.js-co
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       123247     6824/iobroker.js-co
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14033      583/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        1848       554/influxd
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       122473     6917/io.shelly.0
                            tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15495      567/vncserver-x11-c
                            tcp6       0      0 :::3000                 :::*                    LISTEN      117        15946      542/grafana
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          14044      583/sshd: /usr/sbin
                            tcp6       0      0 :::5900                 :::*                    LISTEN      0          15494      567/vncserver-x11-c
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15484      534/cupsd
                            tcp6       0      0 :::8086                 :::*                    LISTEN      116        15042      554/influxd
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       121728     6842/io.admin.0
                            udp        0      0 0.0.0.0:45059           0.0.0.0:*                           108        13969      403/avahi-daemon: r
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15531      477/dhcpcd
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15522      616/cups-browsed
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13967      403/avahi-daemon: r
                            udp6       0      0 :::546                  :::*                                0          15550      477/dhcpcd
                            udp6       0      0 :::35639                :::*                                108        13970      403/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                108        13968      403/avahi-daemon: r
                            2023-04-24 14:47:28.051  - info: javascript.0 (6902) requesting all objects
                            2023-04-24 14:47:28.425  - info: javascript.0 (6902) received all objects
                            2023-04-24 14:47:28.467  - info: javascript.0 (6902) received all states
                            2023-04-24 14:47:28.494  - info: host.Raspberry instance system.adapter.shelly.0 started with pid 6917
                            2023-04-24 14:47:28.567  - info: javascript.0 (6902) Start javascript script.js.Test
                            2023-04-24 14:47:28.632  - info: javascript.0 (6902) script.js.Test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            2023-04-24 14:47:30.990  - info: shelly.0 (6917) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.16.0, js-controller: 4.0.24
                            2023-04-24 14:47:31.209  - info: shelly.0 (6917) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
                            2023-04-24 14:47:32.475  - info: host.Raspberry instance system.adapter.discovery.0 started with pid 6932
                            2023-04-24 14:47:34.385  - info: discovery.0 (6932) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                            2023-04-24 14:47:36.472  - info: host.Raspberry instance system.adapter.backitup.0 started with pid 6947
                            2023-04-24 14:47:38.590  - info: backitup.0 (6947) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                            2023-04-24 14:47:38.700  - info: backitup.0 (6947) [iobroker] backup was activated at 02:40 every 1 day(s)
                            2023-04-24 14:47:39.424  - info: shelly.0 (6917) [MQTT] Device with client id "shellyem-244CAB418C05" connected!
                            2023-04-24 14:47:40.479  - info: host.Raspberry instance system.adapter.echarts.0 started with pid 6962
                            2023-04-24 14:47:42.480  - info: echarts.0 (6962) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.16.0, js-controller: 4.0.24
                            2023-04-24 14:47:43.124  - info: shelly.0 (6917) [MQTT] Device with client id "shellyplug-s-4022D880D8D8" connected!
                            2023-04-24 14:47:44.472  - info: host.Raspberry instance system.adapter.panasonic-comfort-cloud.0 started with pid 6977
                            2023-04-24 14:47:46.305  - info: panasonic-comfort-cloud.0 (6977) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud, node: v18.16.0, js-controller: 4.0.24
                            2023-04-24 14:47:46.514  - info: panasonic-comfort-cloud.0 (6977) state panasonic-comfort-cloud.0.info.connection changed: false (ack = true)
                            2023-04-24 14:47:48.970  - info: shelly.0 (6917) [MQTT] Device with client id "shellyplus1pm-a8032ab5f934" connected!
                            2023-04-24 14:47:51.127  - info: panasonic-comfort-cloud.0 (6977) Login successful.
                            2023-04-24 14:47:51.145  - info: panasonic-comfort-cloud.0 (6977) state panasonic-comfort-cloud.0.info.connection changed: true (ack = true)
                            2023-04-24 14:50:28.444  - info: admin.0 (6842) ==> Connected system.user.admin from ::ffff:192.168.178.28
                            2023-04-24 14:52:20.614  - info: admin.0 (6842) <== Disconnect system.user.admin from ::ffff:192.168.178.28 admin
                            B Thomas Braun 2 Replies Last reply Reply Quote 0
                              und noch das summary
                              		     v.2023-04-16
                              Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
                              Kernel: 		6.1.21-v8+
                              Installation: 		Native
                              Timezone: 		Europe/Berlin (CEST, +0200)
                              User-ID: 		1000
                              X-Server: 		true
                              Pending OS-Updates: 	0
                              Pending iob updates: 	1
                              Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
                              			/usr/bin/npm 		9.5.1
                              			/usr/bin/npx 		9.5.1
                              Recommended versions are nodejs 18.x.y and npm 9.x.y
                              MEMORY:
                              Mem:            3.8G        961M        1.5G         35M        1.3G        2.8G
                              Swap:            99M          0B         99M
                              Total:          3.9G        961M        1.6G
                              Active iob-Instances: 	10
                              ioBroker Core: 		js-controller 		4.0.24
                              			admin 			6.3.5
                              ioBroker Status: 	iobroker is running on this host.
                              Objects type: jsonl
                              States  type: jsonl
                              Objects: 		548
                              States: 		426
                              Size of iob-Database:
                              7.3M	/opt/iobroker/iobroker-data/objects.jsonl
                              296K	/opt/iobroker/iobroker-data/states.jsonl
                                @balu67 sieht mir eher nach nem Browsercache Fehler aus
                                  X-Server: true Desktop: LXDE-pi
                                  Keinen Desktop!
                                    was kann ich noch machen?
                                      balu67 @Thomas Braun last edited by
                                      @thomas-braun said in iobroker lässt sich nicht mehr starten:
                                      Keinen Desktop!
                                      den brauch ich, da ich sonst gar nichts machen kann......nicht mal nach Dateien sehen oder......
                                        @balu67
                                        Macht man natürlich im Terminal.
                                          STRG-F5
                                          und was kommt Jetzt als Meldung?
                                            @balu67 das kannst du z.b mit WinSCP von deinem Rechner aus, falls es unbedingt sein muss
                                            1.2k
                                            7757
