    3. Einsteigerfragen
    4. Installation
    5. iobroker lässt sich nicht mehr starten
      Thomas Braun Most Active @balu67 last edited by
      @balu67
      iob stop
      sudo apt full-upgrade
      iob fix
      sudo reboot
        Homoran Global Moderator Administrators @balu67 last edited by
        @balu67 sagte in iobroker lässt sich nicht mehr starten:
        doch
        Nein!
        das ist
        sudo apt update
          balu67 @Homoran last edited by
          @homoran said in iobroker lässt sich nicht mehr starten:
          doch
          Nein!
          das ist
          sudo apt update
          mann, bin ich bescheuert
            balu67 @balu67 last edited by
            leider keine Veränderung, nur das intro kommt
            al@Raspberry:/opt $ iob fix
            library: loaded
            Library version=2022-12-09
                Welcome to the ioBroker installation fixer!
                Script version: 2023-04-02
                You might need to enter your password a couple of times.
                Installing prerequisites (1/5)
            OK:1 http://deb.debian.org/debian bullseye InRelease
            Holen:2 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
            OK:3 http://security.debian.org/debian-security bullseye-security InRelease
            OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
            OK:5 https://repos.influxdata.com/debian stable InRelease
            OK:6 https://deb.nodesource.com/node_18.x bullseye InRelease
            OK:7 https://packages.grafana.com/oss/deb stable InRelease
            Es wurden 44,1 kB in 2 s geholt (25,3 kB/s).
            Installed gcc-c++
                Checking ioBroker user and directory permissions (2/5)
            Created /etc/sudoers.d/iobroker
            Fixing directory permissions...
                Check and cleanup npm temporary directories (3/5)
            Done.
                Database maintenance (4/5)
            Checking for uncompressed JSONL databases... This might take a while!
            Compressing /opt/iobroker/iobroker-data/states.jsonl
            Compressing /opt/iobroker/iobroker-data/objects.jsonl
            Compressed 2 JSONL files. Done
                Checking autostart (5/5)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            crunchip Homoran 2 Replies Last reply Reply Quote 0
              crunchip Forum Testing Most Active @balu67 last edited by crunchip
              hast du das eingegeben?
                bei iob diag?
                  balu67 @crunchip last edited by
                  @crunchip said in iobroker lässt sich nicht mehr starten:
                  ja, hab ich, kommt aber nur das
                  Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                    @balu67
                    Kiste neugestartet?
                    iob diag
                    sagt?
                      bei iob diag?
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Model		: Raspberry Pi 4 Model B Rev 1.5
                      Architecture    : aarch64
                      Docker          : false
                      Virtualization  : none
                      Distributor ID:	Debian
                      Description:	Debian GNU/Linux 11 (bullseye)
                      Release:	11
                      Codename:	bullseye
                      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                      NAME="Debian GNU/Linux"
                      VERSION_ID="11"
                      VERSION="11 (bullseye)"
                      VERSION_CODENAME=bullseye
                      ID=debian
                      HOME_URL="https://www.debian.org/"
                      SUPPORT_URL="https://www.debian.org/support"
                      BUG_REPORT_URL="https://bugs.debian.org/"
                      Systemuptime and Load:
                       14:51:31 up  4:26,  2 users,  load average: 0.68, 0.49, 0.21
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      Other values than 0x0 hint to temperature/voltage problems
                      temp=42.8'C
                      volt=0.9460V
                      *** Time and Time Zones ***
                                     Local time: Mon 2023-04-24 14:51:31 CEST
                                 Universal time: Mon 2023-04-24 12:51:31 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      al
                      /home/al
                      al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server: 	true
                      Desktop: 	LXDE-pi
                      Terminal: 	x11
                      Boot Target: 	graphical.target
                      *** MEMORY ***
                      Mem:            3.8G        950M        1.5G         41M        1.3G        2.8G
                      Swap:            99M          0B         99M
                      Total:          3.9G        950M        1.6G
                               3794 M total memory
                                950 M used memory
                               1447 M active memory
                                590 M inactive memory
                               1525 M free memory
                                135 M buffer memory
                               1183 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4       29G  9.6G   19G  35% /
                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                      tmpfs          tmpfs     759M  1.3M  758M   1% /run
                      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                      tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                      [Mon Apr 24 10:25:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      [Mon Apr 24 10:25:08 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Mon Apr 24 10:25:08 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Mon Apr 24 10:25:10 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      Show mounted filesystems (real ones only):
                      TARGET  SOURCE         FSTYPE OPTIONS
                      /       /dev/mmcblk0p2 ext4   rw,noatime
                      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      4.0G	/var/
                      3.4G	/var/log
                      3.0G	/var/log/journal/20caf098a3be48108459316835c16c60
                      304M	/var/cache
                      Archived and active journals take up 2.9G in the file system.
                      /opt/iobroker/backups:
                      24M	/opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      580M	/opt/iobroker/iobroker-data/
                      447M	/opt/iobroker/iobroker-data/history
                      99M	/opt/iobroker/iobroker-data/files
                      59M	/opt/iobroker/iobroker-data/history/20230328
                      58M	/opt/iobroker/iobroker-data/history/20230329
                      9.4M	/opt/iobroker/iobroker-data/history/20230401/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
                      9.3M	/opt/iobroker/iobroker-data/history/20230406/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
                      9.3M	/opt/iobroker/iobroker-data/history/20230405/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
                      9.3M	/opt/iobroker/iobroker-data/history/20230404/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
                      9.3M	/opt/iobroker/iobroker-data/history/20230402/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs 	v18.16.0
                      /usr/bin/node 		v18.16.0
                      /usr/bin/npm 		9.5.1
                      /usr/bin/npx 		9.5.1
                      nodejs:
                        Installed: 18.16.0-deb-1nodesource1
                        Candidate: 18.16.0-deb-1nodesource1
                        Version table:
                       *** 18.16.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                              100 /var/lib/dpkg/status
                           12.22.12~dfsg-1~deb11u3 500
                              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                           12.22.5~dfsg-2~11u1 500
                              500 http://deb.debian.org/debian bullseye/main arm64 Packages
                      No problems detected
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      MULTIHOSTSERVICE/enabled: false
                      Core adapters versions
                      js-controller: 	4.0.24
                      admin: 		6.3.5
                      javascript: 	6.1.4
                      Adapters from github: 	0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
                      + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
                      + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
                      + system.adapter.history.0                : history               : Raspberry                                -  enabled
                      + system.adapter.influxdb.0               : influxdb              : Raspberry                                -  enabled, port: 8086
                      + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
                      + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                -  enabled
                      + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Installed ioBroker-Instances
                      Used repository: stable
                      Adapter    "admin"        : 6.3.5    , installed 6.3.5
                      Adapter    "backitup"     : 2.6.16   , installed 2.5.12 [Updatable]
                      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                      Adapter    "history"      : 2.2.4    , installed 2.2.4
                      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                      Controller "js-controller": 4.0.24   , installed 4.0.24
                      Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
                      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                      Objects and States
                      Objects: 	548
                      States: 	426
                      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:2 https://packages.grafana.com/oss/deb stable InRelease
                      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                      Hit:4 http://deb.debian.org/debian bullseye InRelease
                      Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:7 https://repos.influxdata.com/debian stable InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15485      534/cupsd
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       123254     6824/iobroker.js-co
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       123247     6824/iobroker.js-co
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14033      583/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        1848       554/influxd
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       122473     6917/io.shelly.0
                      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15495      567/vncserver-x11-c
                      tcp6       0      0 :::3000                 :::*                    LISTEN      117        15946      542/grafana
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          14044      583/sshd: /usr/sbin
                      tcp6       0      0 :::5900                 :::*                    LISTEN      0          15494      567/vncserver-x11-c
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15484      534/cupsd
                      tcp6       0      0 :::8086                 :::*                    LISTEN      116        15042      554/influxd
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       121728     6842/io.admin.0
                      udp        0      0 0.0.0.0:45059           0.0.0.0:*                           108        13969      403/avahi-daemon: r
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15531      477/dhcpcd
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15522      616/cups-browsed
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13967      403/avahi-daemon: r
                      udp6       0      0 :::546                  :::*                                0          15550      477/dhcpcd
                      udp6       0      0 :::35639                :::*                                108        13970      403/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        13968      403/avahi-daemon: r
                      2023-04-24 14:47:28.051  - info: javascript.0 (6902) requesting all objects
                      2023-04-24 14:47:28.425  - info: javascript.0 (6902) received all objects
                      2023-04-24 14:47:28.467  - info: javascript.0 (6902) received all states
                      2023-04-24 14:47:28.494  - info: host.Raspberry instance system.adapter.shelly.0 started with pid 6917
                      2023-04-24 14:47:28.567  - info: javascript.0 (6902) Start javascript script.js.Test
                      2023-04-24 14:47:28.632  - info: javascript.0 (6902) script.js.Test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                      2023-04-24 14:47:30.990  - info: shelly.0 (6917) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.16.0, js-controller: 4.0.24
                      2023-04-24 14:47:31.209  - info: shelly.0 (6917) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
                      2023-04-24 14:47:32.475  - info: host.Raspberry instance system.adapter.discovery.0 started with pid 6932
                      2023-04-24 14:47:34.385  - info: discovery.0 (6932) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                      2023-04-24 14:47:36.472  - info: host.Raspberry instance system.adapter.backitup.0 started with pid 6947
                      2023-04-24 14:47:38.590  - info: backitup.0 (6947) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                      2023-04-24 14:47:38.700  - info: backitup.0 (6947) [iobroker] backup was activated at 02:40 every 1 day(s)
                      2023-04-24 14:47:39.424  - info: shelly.0 (6917) [MQTT] Device with client id "shellyem-244CAB418C05" connected!
                      2023-04-24 14:47:40.479  - info: host.Raspberry instance system.adapter.echarts.0 started with pid 6962
                      2023-04-24 14:47:42.480  - info: echarts.0 (6962) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.16.0, js-controller: 4.0.24
                      2023-04-24 14:47:43.124  - info: shelly.0 (6917) [MQTT] Device with client id "shellyplug-s-4022D880D8D8" connected!
                      2023-04-24 14:47:44.472  - info: host.Raspberry instance system.adapter.panasonic-comfort-cloud.0 started with pid 6977
                      2023-04-24 14:47:46.305  - info: panasonic-comfort-cloud.0 (6977) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud, node: v18.16.0, js-controller: 4.0.24
                      2023-04-24 14:47:46.514  - info: panasonic-comfort-cloud.0 (6977) state panasonic-comfort-cloud.0.info.connection changed: false (ack = true)
                      2023-04-24 14:47:48.970  - info: shelly.0 (6917) [MQTT] Device with client id "shellyplus1pm-a8032ab5f934" connected!
                      2023-04-24 14:47:51.127  - info: panasonic-comfort-cloud.0 (6977) Login successful.
                      2023-04-24 14:47:51.145  - info: panasonic-comfort-cloud.0 (6977) state panasonic-comfort-cloud.0.info.connection changed: true (ack = true)
                      2023-04-24 14:50:28.444  - info: admin.0 (6842) ==> Connected system.user.admin from ::ffff:192.168.178.28
                      2023-04-24 14:52:20.614  - info: admin.0 (6842) <== Disconnect system.user.admin from ::ffff:192.168.178.28 admin
                      B Thomas Braun 2 Replies Last reply Reply Quote 0
                        und noch das summary
                        		     v.2023-04-16
                        Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
                        Kernel: 		6.1.21-v8+
                        Installation: 		Native
                        Timezone: 		Europe/Berlin (CEST, +0200)
                        User-ID: 		1000
                        X-Server: 		true
                        Pending OS-Updates: 	0
                        Pending iob updates: 	1
                        Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
                        			/usr/bin/npm 		9.5.1
                        			/usr/bin/npx 		9.5.1
                        Recommended versions are nodejs 18.x.y and npm 9.x.y
                        MEMORY:
                        Mem:            3.8G        961M        1.5G         35M        1.3G        2.8G
                        Swap:            99M          0B         99M
                        Total:          3.9G        961M        1.6G
                        Active iob-Instances: 	10
                        ioBroker Core: 		js-controller 		4.0.24
                        			admin 			6.3.5
                        ioBroker Status: 	iobroker is running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                        Objects: 		548
                        States: 		426
                        Size of iob-Database:
                        7.3M	/opt/iobroker/iobroker-data/objects.jsonl
                        296K	/opt/iobroker/iobroker-data/states.jsonl
                          @balu67 sieht mir eher nach nem Browsercache Fehler aus
                            X-Server: true Desktop: LXDE-pi
                            Keinen Desktop!
                              was kann ich noch machen?
                                balu67 @Thomas Braun last edited by
                                @thomas-braun said in iobroker lässt sich nicht mehr starten:
                                Keinen Desktop!
                                den brauch ich, da ich sonst gar nichts machen kann......nicht mal nach Dateien sehen oder......
                                  @balu67
                                  Macht man natürlich im Terminal.
                                    STRG-F5
                                    und was kommt Jetzt als Meldung?
                                      @balu67 das kannst du z.b mit WinSCP von deinem Rechner aus, falls es unbedingt sein muss
                                        Homoran Global Moderator Administrators @crunchip last edited by
                                        @crunchip sagte in iobroker lässt sich nicht mehr starten:
                                        aber nur mit dem richtigen user und Editor (wenn benutzt)
                                          das kann ich leider nicht bedienen. Bin froh, dass ich eure Vorgaben eingeben konnte
                                          crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                            @balu67 was ist jetzt mit dem Browser?
                                            1.2k
                                            7757
