    3. Einsteigerfragen
    4. Installation
    5. iobroker lässt sich nicht mehr starten
      balu67 @balu67 last edited by
      leider keine Veränderung, nur das intro kommt
      al@Raspberry:/opt $ iob fix
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installation fixer!
          Script version: 2023-04-02
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      OK:1 http://deb.debian.org/debian bullseye InRelease
      Holen:2 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
      OK:3 http://security.debian.org/debian-security bullseye-security InRelease
      OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:5 https://repos.influxdata.com/debian stable InRelease
      OK:6 https://deb.nodesource.com/node_18.x bullseye InRelease
      OK:7 https://packages.grafana.com/oss/deb stable InRelease
      Es wurden 44,1 kB in 2 s geholt (25,3 kB/s).
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/5)
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      crunchip Homoran 2 Replies Last reply Reply Quote 0
        crunchip Forum Testing Most Active @balu67 last edited by crunchip
        @balu67 sagte in iobroker lässt sich nicht mehr starten:
        hast du das eingegeben?
          Homoran Global Moderator Administrators @balu67 last edited by
          bei iob diag?
            balu67 @crunchip last edited by
            @crunchip said in iobroker lässt sich nicht mehr starten:
            ja, hab ich, kommt aber nur das
            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @balu67 last edited by
              @balu67
              Kiste neugestartet?
              iob diag
              sagt?
                balu67 @Homoran last edited by
                @homoran said in iobroker lässt sich nicht mehr starten:
                bei iob diag?
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Model		: Raspberry Pi 4 Model B Rev 1.5
                Architecture    : aarch64
                Docker          : false
                Virtualization  : none
                Distributor ID:	Debian
                Description:	Debian GNU/Linux 11 (bullseye)
                Release:	11
                Codename:	bullseye
                PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                NAME="Debian GNU/Linux"
                VERSION_ID="11"
                VERSION="11 (bullseye)"
                VERSION_CODENAME=bullseye
                ID=debian
                HOME_URL="https://www.debian.org/"
                SUPPORT_URL="https://www.debian.org/support"
                BUG_REPORT_URL="https://bugs.debian.org/"
                Systemuptime and Load:
                 14:51:31 up  4:26,  2 users,  load average: 0.68, 0.49, 0.21
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                Other values than 0x0 hint to temperature/voltage problems
                temp=42.8'C
                volt=0.9460V
                *** Time and Time Zones ***
                               Local time: Mon 2023-04-24 14:51:31 CEST
                           Universal time: Mon 2023-04-24 12:51:31 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                al
                /home/al
                al adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server: 	true
                Desktop: 	LXDE-pi
                Terminal: 	x11
                Boot Target: 	graphical.target
                *** MEMORY ***
                Mem:            3.8G        950M        1.5G         41M        1.3G        2.8G
                Swap:            99M          0B         99M
                Total:          3.9G        950M        1.6G
                         3794 M total memory
                          950 M used memory
                         1447 M active memory
                          590 M inactive memory
                         1525 M free memory
                          135 M buffer memory
                         1183 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/root      ext4       29G  9.6G   19G  35% /
                devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                tmpfs          tmpfs     759M  1.3M  758M   1% /run
                /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                [Mon Apr 24 10:25:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FD:FE:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9be8b122-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Mon Apr 24 10:25:08 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Mon Apr 24 10:25:08 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Mon Apr 24 10:25:10 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                Show mounted filesystems (real ones only):
                TARGET  SOURCE         FSTYPE OPTIONS
                /       /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                4.0G	/var/
                3.4G	/var/log
                3.0G	/var/log/journal/20caf098a3be48108459316835c16c60
                304M	/var/cache
                Archived and active journals take up 2.9G in the file system.
                /opt/iobroker/backups:
                24M	/opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                580M	/opt/iobroker/iobroker-data/
                447M	/opt/iobroker/iobroker-data/history
                99M	/opt/iobroker/iobroker-data/files
                59M	/opt/iobroker/iobroker-data/history/20230328
                58M	/opt/iobroker/iobroker-data/history/20230329
                9.4M	/opt/iobroker/iobroker-data/history/20230401/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
                9.3M	/opt/iobroker/iobroker-data/history/20230406/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
                9.3M	/opt/iobroker/iobroker-data/history/20230405/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
                9.3M	/opt/iobroker/iobroker-data/history/20230404/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
                9.3M	/opt/iobroker/iobroker-data/history/20230402/history.shelly.0.SHEM#244CAB418C05#1.Emeter0.Power.json
                *** NodeJS-Installation ***
                /usr/bin/nodejs 	v18.16.0
                /usr/bin/node 		v18.16.0
                /usr/bin/npm 		9.5.1
                /usr/bin/npx 		9.5.1
                nodejs:
                  Installed: 18.16.0-deb-1nodesource1
                  Candidate: 18.16.0-deb-1nodesource1
                  Version table:
                 *** 18.16.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                        100 /var/lib/dpkg/status
                     12.22.12~dfsg-1~deb11u3 500
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                     12.22.5~dfsg-2~11u1 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                No problems detected
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                MULTIHOSTSERVICE/enabled: false
                Core adapters versions
                js-controller: 	4.0.24
                admin: 		6.3.5
                javascript: 	6.1.4
                Adapters from github: 	0
                Adapter State
                + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
                + system.adapter.discovery.0              : discovery             : Raspberry                                -  enabled
                + system.adapter.echarts.0                : echarts               : Raspberry                                -  enabled
                + system.adapter.history.0                : history               : Raspberry                                -  enabled
                + system.adapter.influxdb.0               : influxdb              : Raspberry                                -  enabled, port: 8086
                + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
                + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: Raspberry                                -  enabled
                + system.adapter.shelly.0                 : shelly                : Raspberry                                -  enabled, port: 1882, bind: 0.0.0.0
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.3.5    , installed 6.3.5
                Adapter    "backitup"     : 2.6.16   , installed 2.5.12 [Updatable]
                Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                Adapter    "history"      : 2.2.4    , installed 2.2.4
                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                Controller "js-controller": 4.0.24   , installed 4.0.24
                Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
                Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                Objects and States
                Objects: 	548
                States: 	426
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 https://packages.grafana.com/oss/deb stable InRelease
                Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                Hit:4 http://deb.debian.org/debian bullseye InRelease
                Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:7 https://repos.influxdata.com/debian stable InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15485      534/cupsd
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       123254     6824/iobroker.js-co
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       123247     6824/iobroker.js-co
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14033      583/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        1848       554/influxd
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       122473     6917/io.shelly.0
                tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15495      567/vncserver-x11-c
                tcp6       0      0 :::3000                 :::*                    LISTEN      117        15946      542/grafana
                tcp6       0      0 :::22                   :::*                    LISTEN      0          14044      583/sshd: /usr/sbin
                tcp6       0      0 :::5900                 :::*                    LISTEN      0          15494      567/vncserver-x11-c
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15484      534/cupsd
                tcp6       0      0 :::8086                 :::*                    LISTEN      116        15042      554/influxd
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       121728     6842/io.admin.0
                udp        0      0 0.0.0.0:45059           0.0.0.0:*                           108        13969      403/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15531      477/dhcpcd
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15522      616/cups-browsed
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13967      403/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          15550      477/dhcpcd
                udp6       0      0 :::35639                :::*                                108        13970      403/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        13968      403/avahi-daemon: r
                2023-04-24 14:47:28.051  - info: javascript.0 (6902) requesting all objects
                2023-04-24 14:47:28.425  - info: javascript.0 (6902) received all objects
                2023-04-24 14:47:28.467  - info: javascript.0 (6902) received all states
                2023-04-24 14:47:28.494  - info: host.Raspberry instance system.adapter.shelly.0 started with pid 6917
                2023-04-24 14:47:28.567  - info: javascript.0 (6902) Start javascript script.js.Test
                2023-04-24 14:47:28.632  - info: javascript.0 (6902) script.js.Test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                2023-04-24 14:47:30.990  - info: shelly.0 (6917) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.16.0, js-controller: 4.0.24
                2023-04-24 14:47:31.209  - info: shelly.0 (6917) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
                2023-04-24 14:47:32.475  - info: host.Raspberry instance system.adapter.discovery.0 started with pid 6932
                2023-04-24 14:47:34.385  - info: discovery.0 (6932) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                2023-04-24 14:47:36.472  - info: host.Raspberry instance system.adapter.backitup.0 started with pid 6947
                2023-04-24 14:47:38.590  - info: backitup.0 (6947) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                2023-04-24 14:47:38.700  - info: backitup.0 (6947) [iobroker] backup was activated at 02:40 every 1 day(s)
                2023-04-24 14:47:39.424  - info: shelly.0 (6917) [MQTT] Device with client id "shellyem-244CAB418C05" connected!
                2023-04-24 14:47:40.479  - info: host.Raspberry instance system.adapter.echarts.0 started with pid 6962
                2023-04-24 14:47:42.480  - info: echarts.0 (6962) starting. Version 1.0.12 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.16.0, js-controller: 4.0.24
                2023-04-24 14:47:43.124  - info: shelly.0 (6917) [MQTT] Device with client id "shellyplug-s-4022D880D8D8" connected!
                2023-04-24 14:47:44.472  - info: host.Raspberry instance system.adapter.panasonic-comfort-cloud.0 started with pid 6977
                2023-04-24 14:47:46.305  - info: panasonic-comfort-cloud.0 (6977) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud, node: v18.16.0, js-controller: 4.0.24
                2023-04-24 14:47:46.514  - info: panasonic-comfort-cloud.0 (6977) state panasonic-comfort-cloud.0.info.connection changed: false (ack = true)
                2023-04-24 14:47:48.970  - info: shelly.0 (6917) [MQTT] Device with client id "shellyplus1pm-a8032ab5f934" connected!
                2023-04-24 14:47:51.127  - info: panasonic-comfort-cloud.0 (6977) Login successful.
                2023-04-24 14:47:51.145  - info: panasonic-comfort-cloud.0 (6977) state panasonic-comfort-cloud.0.info.connection changed: true (ack = true)
                2023-04-24 14:50:28.444  - info: admin.0 (6842) ==> Connected system.user.admin from ::ffff:192.168.178.28
                2023-04-24 14:52:20.614  - info: admin.0 (6842) <== Disconnect system.user.admin from ::ffff:192.168.178.28 admin
                B Thomas Braun 2 Replies Last reply Reply Quote 0
                  und noch das summary
                  		     v.2023-04-16
                  Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
                  Kernel: 		6.1.21-v8+
                  Installation: 		Native
                  Timezone: 		Europe/Berlin (CEST, +0200)
                  User-ID: 		1000
                  X-Server: 		true
                  Pending OS-Updates: 	0
                  Pending iob updates: 	1
                  Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
                  			/usr/bin/npm 		9.5.1
                  			/usr/bin/npx 		9.5.1
                  Recommended versions are nodejs 18.x.y and npm 9.x.y
                  MEMORY:
                  Mem:            3.8G        961M        1.5G         35M        1.3G        2.8G
                  Swap:            99M          0B         99M
                  Total:          3.9G        961M        1.6G
                  Active iob-Instances: 	10
                  ioBroker Core: 		js-controller 		4.0.24
                  			admin 			6.3.5
                  ioBroker Status: 	iobroker is running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		548
                  States: 		426
                  Size of iob-Database:
                  7.3M	/opt/iobroker/iobroker-data/objects.jsonl
                  296K	/opt/iobroker/iobroker-data/states.jsonl
                    @balu67 sieht mir eher nach nem Browsercache Fehler aus
                      X-Server: true Desktop: LXDE-pi
                      Keinen Desktop!
                        was kann ich noch machen?
                          balu67 @Thomas Braun last edited by
                          @thomas-braun said in iobroker lässt sich nicht mehr starten:
                          Keinen Desktop!
                          den brauch ich, da ich sonst gar nichts machen kann......nicht mal nach Dateien sehen oder......
                            @balu67
                            Macht man natürlich im Terminal.
                              STRG-F5
                              und was kommt Jetzt als Meldung?
                                @balu67 das kannst du z.b mit WinSCP von deinem Rechner aus, falls es unbedingt sein muss
                                  Homoran Global Moderator Administrators @crunchip last edited by
                                  @crunchip sagte in iobroker lässt sich nicht mehr starten:
                                  aber nur mit dem richtigen user und Editor (wenn benutzt)
                                    das kann ich leider nicht bedienen. Bin froh, dass ich eure Vorgaben eingeben konnte
                                    crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                      @balu67 was ist jetzt mit dem Browser?
                                        @balu67
                                        Dann nimm halt WinSCP oder sowas her. Jedenfalls tust du dir selber keinen Gefallen mit dem mitgeschleppten vollen Desktop.
                                        Das halbe Dutzend Befehle für die Navigation durch das Dateisystem und sonstige Operationen man sich aber auch drauf schaffen, denke ich.
                                          STRG-F5
                                          keine Meldung kommt nur
                                            @balu67 im Browser nicht in der Konsole
                                            dein Browserfenster anklicken wo dir die Iobroker startseite angezeigt wird und F5 drücken, damit die Seite neu geladen wird
                                            7757
