    4. [How-to] Node.js für ioBroker richtig updaten
      Thomas Braun Most Active @Atifan last edited by
      @atifan
      Kannste jetzt gleich mit der Ausgabe zu
      sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
      uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      üben. Ich vermute aber stark, dass da die Pfade falsch sein werden.
      • Atifan
        Atifan @Thomas Braun last edited by
        OK 🙂 Dann hier meine Console als Code.
        iobroker@iobroker:~$ node -v
        v16.19.0
        iobroker@iobroker:~$ curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash
        ## Installing the NodeSource Node.js 18.x repo...
        ## Populating apt-get cache...
        + apt-get update
        Hit:1 http://ftp.debian.org/debian bullseye InRelease
        Hit:2 http://security.debian.org bullseye-security InRelease
        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
        Hit:5 https://dl.yarnpkg.com/debian stable InRelease
        Reading package lists... Done
        ## Confirming "bullseye" is supported...
        + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/bullseye/Release'
        ## Adding the NodeSource signing key to your keyring...
        + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
        ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
        + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
        + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
        ## Running `apt-get update` for you...
        + apt-get update
        Hit:1 http://security.debian.org bullseye-security InRelease
        Hit:2 http://ftp.debian.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
        Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
        ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
        ## You may also need development tools to build native addons:
             sudo apt-get install gcc g++ make
        ## To install the Yarn package manager, run:
             curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
             echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
             sudo apt-get update && sudo apt-get install yarn
        iobroker@iobroker:~$ sudo apt-get install -y nodejs
        Building dependency tree... Done
        nodejs is already the newest version (18.16.0-deb-1nodesource1).
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        v16.19.0
        Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
          @atifan
          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
          Atifan 1 Reply Last reply Reply Quote 0
          • Atifan
            @thomas-braun sagte in [How-to] Node.js für ioBroker richtig updaten:
            @atifan
            OK Danke probiere ich mal.
            Das hier spuckt er aus wenn ich oben das mache was du geschrieben hattest.
            iobroker@iobroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
            iobroker@iobroker:~$ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            x86_64
            /usr/bin/nodejs
            /usr/local/bin/node
            /usr/local/bin/npm
            /usr/local/bin/npx
            v18.16.0
            v16.19.0
            8.19.3
            8.19.3
            4.0.24
            iobroker
            iobroker tty dialout audio video
            tty
            /home/iobroker
            All packages are up to date.
            nodejs:
              Installed: 18.16.0-deb-1nodesource1
              Candidate: 18.16.0-deb-1nodesource1
              Version table:
             *** 18.16.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u3 500
                    500 http://security.debian.org bullseye-security/main amd64 Packages
                 12.22.5~dfsg-2~11u1 500
                    500 http://ftp.debian.org/debian bullseye/main amd64 Packages
              crunchip Forum Testing Most Active @Atifan last edited by
              @atifan und leg dir vllt nen neuen user an, der nicht gleich lautet wie der systeminterne iobroker
                @atifan
                Wie vorhergesagt: Falsche Pfade.
                v16.19.0 hast du also irgendwie am Paketmanager vorbei in das System geschraubt.
                • Atifan
                  Hi Danke für Eure Hilfe. Habe es nach der Anleitung hinbekommen, habe die Ordner wie in Anleitung gelöscht und danach gings 🙂
                  Aber keine Ahnung wieso da was falsch war.
                  Ich mache eig. immer nach der Anleitung die Updates.
                  Aber egal, funktioniert wieder, Danke 🙂
                    @atifan sagte in [How-to] Node.js für ioBroker richtig updaten:
                    Weil die v16.19.0 von dir irgendwie anders draufgeklatscht worden ist.
                    Eine ordentliche Installation über deinen Paketmanager landet nicht in /usr/local/bin
                      @atifan
                      Zeig mal die Ausgabe von
                      iob diag
                      Zusammenfassung reicht.
                      • Atifan
                        Atifan @Thomas Braun last edited by Atifan
                                             v.2023-04-16
                        Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                        Kernel:                 5.15.104-1-pve
                        Installation:           lxc
                        Timezone:               Europe/Berlin (CEST, +0200)
                        User-ID:                1000
                        X-Server:               false
                        Boot Target:            graphical.target
                        Pending OS-Updates:     0
                        Pending iob updates:    0
                        Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                                /usr/bin/node           v18.16.0
                                                /usr/bin/npm            9.5.1
                                                /usr/bin/npx            9.5.1
                        Recommended versions are nodejs 18.x.y and npm 9.x.y
                        MEMORY:
                        Mem:            4.1G        2.4G        1.2G        0.0K        549M        1.7G
                        Swap:             0B          0B          0B
                        Total:          4.1G        2.4G        1.2G
                        Active iob-Instances:   36
                        Active repo(s): beta
                        ioBroker Core:          js-controller           4.0.24
                                                admin                   6.4.3
                        Objects type: jsonl
                        States  type: jsonl
                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        Objects:                14041
                        States:                 18902
                        Size of iob-Database:
                        19M     /opt/iobroker/iobroker-data/objects.jsonl
                        11M     /opt/iobroker/iobroker-data/states.jsonl
                        • Romano Drews
                          Romano Drews @Stabilostick last edited by Romano Drews
                          @stabilostick
                          Ich habe nach der Ausführung der Anleitung leider mein iobroker zerlegt und erreiche diesen nicht mehr.
                          Bedauerlicherweise bin ich nicht so der Liebhaber Putty und Co.
                          Ich habe folgende Meldung:
                          pi@raspberrypi:/opt/iobroker $ iob fix
                          library: loaded
                          Library version=2022-12-09
                          ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                          pi@raspberrypi:/opt/iobroker $ iob install
                          node:internal/modules/cjs/loader:1080
                            throw err;
                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                              at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                              at Module._load (node:internal/modules/cjs/loader:922:27)
                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                              at node:internal/main/run_main_module:23:47 {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: []
                          Node.js v18.17.1
                          Ein Backup habe ich zuvor von IO Broker gemacht, bevor ich mit der Anleitung angefangen habe.
                          Also wie auch in der Anleitung hier beschrieben habe ich dafür:
                          iobroker backup
                          verwendet.
                          Ich würde mich freuen, wenn mir jemand von euch ein wenig unter die Arme greifen kann, um meine IO Broker Installation wieder herzustellen, sodass alles wieder läuft.
                          Ich bin über Google auf den Beitrag hier gekommen, da ich durch IO Broker gezwungen wurde an Node herumzuspielen.
                          Das ging ungünstigerweise schief und ich habe leider zu wenig Ahnung, um das allein wieder hinzubekommen.
                          crunchip Homoran 3 Replies Last reply Reply Quote 0
                            crunchip Forum Testing Most Active @Romano Drews last edited by
                            @romano-drews kurz um, wenn du wirklich ein funktionierendes backup hast, installiere dein OS 64bit ohne Desktop neu, mit dem Einzeiler iobroker und anschließend dein Backup einspielen.
                            schau da mal nach, da findest du alles
                            https://forum.iobroker.net/user/thomas-braun
                            bzw direkt hier
                            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht?_=1692846419216
                            Romano Drews 1 Reply Last reply Reply Quote 0
                            • Romano Drews
                              Romano Drews @crunchip last edited by
                              Danke für die Rückmeldung
                              @crunchip sagte in [How-to] Node.js für ioBroker richtig updaten:
                              Das Backup habe ich ja vorher mit dem Befehl erstellt.
                              In welchem Verzeichnis finde ich das jetzt?
                              Ist auch nicht das erste Mal, dass ich mit dem Befehl ein IO Broker Backup gemacht habe.
                              Da wo die Backups also hingehen sollte, auch eins liegen ^^ weiß nur nicht wo.
                                Homoran Global Moderator Administrators @Romano Drews last edited by
                                @romano-drews sagte in [How-to] Node.js für ioBroker richtig updaten:
                                @stabilostick
                                dass diese Anleitung von 2019 ist und nicht mehr unbedingt auf heitige Systeme passen muss hast du schon erkannt?
                                bedeutet was?
                                in welcher Form zwingt iobroker dich an node "herumzuspielen"?
                                was genau bedeutet das?
                                  da wo es hingehört 😉 /opt/iobroker/backups/
                                    crunchip Forum Testing Most Active @Romano Drews last edited by crunchip
                                    vllt öfter mal im Forum mitlesen
                                    @homoran sagte in [How-to] Node.js für ioBroker richtig updaten:
                                    selbst das hier sollte eigentlich jeder finden
                                    wenn man nodejs updaten muss
                                    kannst du auch mal mit folgendem Befehl versuchen
                                    cd /opt/iobroker
                                    sudo -H -u iobroker npm install iobroker.js-controller
                                    falls das klappt, danach
                                    iob diag
                                    • Romano Drews
                                      Romano Drews @Homoran last edited by
                                      Hallöchen.
                                      Der Admin Adapter stand, dass ich nicht updaten kann, wenn ich nicht auf 16 bei node glaube ich update.
                                      Bei dem Dlink Adapter stand das auch.
                                      Da lief das Update auf die neuste Version deshalb nicht durch.
                                      Da hab ich wie eingangs beschrieben leider gar keine Ahnung ein.
                                      Ich spiele an der Eingabezeile nur dann herum, wenns nicht anders geht.
                                      Also wie ein Update, das erforderlich ist.
                                      Update fürs Betriebssystem und was halt so Standard befohlen sind wie Update und Upgrade und danach den Ordner leeren.
                                      Wenn eine Anleitung funktioniert, passiert ja eigentlich auch nichts.
                                      Beim letzten Mal scheint wohl was in die Hose gegangen zu sein.
                                      da wo es hingehört /opt/iobroker/backups/
                                      Genau dieser Ordner ist bei mir bedauerlicherweise leer.
                                      mit ```
                                      iobroker backup
                                      Kann das noch irgendwo anders hin gespeichert sein?
                                        Thomas Braun Most Active @Romano Drews last edited by
                                        Nein.
                                        Ein
                                        iob backup
                                        in der Konsole liefert was?
                                        Bevorzugt aber den backitup-Adapter verwenden.
                                        • Romano Drews
                                          Sagt sich immer so einfach ^^
                                          Würde sehr gerne viel mehr Zeit mit io Broker verbringen.
                                          Genau genommen habe ich aber so wenig Zeit, dass mein eigentliches Smarthome traurigerweise noch heute bei der Telekom rum schimmelt und auch nicht richtig funktioniert.
                                          Auf IO Broker habe ich nur paar dinge, die ich öfters mal vom Telefon aus überwachen möchte bzw. informiert werden möchte.
                                          Ich versuche es auf jeden fall 🙂
                                          cd /opt/iobroker
                                          Ergebnis:
                                          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                          up to date in 4s
                                          46 packages are looking for funding
                                            run `npm fund` for details
                                          2023-08-24 01:23:11.983  - info: host.raspberrypi All instances are stopped.
                                          2023-08-24 01:23:12.096  - info: host.raspberrypi terminated
                                          2023-08-24 13:59:46.528  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                                          2023-08-24 13:59:46.536  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                          2023-08-24 13:59:46.537  - info: host.raspberrypi hostname: raspberrypi, node: v18.17.1
                                          2023-08-24 13:59:46.538  - info: host.raspberrypi ip addresses: 192.168.20.53 fe80::1655:b3c0:7054:fa10
                                          2023-08-24 13:59:47.194  - info: host.raspberrypi connected to Objects and States
                                          2023-08-24 13:59:47.227  - info: host.raspberrypi Node.js version has changed from unknown to 18.17.1
                                          2023-08-24 13:59:47.283  - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                          2023-08-24 13:59:47.303  - info: host.raspberrypi added notifications configuration of host
                                          2023-08-24 13:59:47.791  - info: host.raspberrypi 3 instances found
                                          2023-08-24 13:59:47.801  - info: host.raspberrypi starting 3 instances
                                          2023-08-24 13:59:47.870  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2489894
                                          2023-08-24 13:59:50.428  - info: admin.0 (2489894) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 4.0.24
                                          2023-08-24 13:59:50.488  - info: admin.0 (2489894) requesting all states
                                          2023-08-24 13:59:50.489  - info: admin.0 (2489894) requesting all objects
                                          2023-08-24 13:59:51.104  - info: admin.0 (2489894) received all objects
                                          2023-08-24 13:59:51.446  - info: admin.0 (2489894) http server listening on port 8081
                                          2023-08-24 13:59:51.447  - info: admin.0 (2489894) Use link "http://localhost:8081" to configure.
                                          2023-08-24 13:59:51.460  - info: admin.0 (2489894) socket.io server listening on port 8081
                                          2023-08-24 13:59:51.841  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 2489921
                                          2023-08-24 13:59:54.029  - info: discovery.0 (2489921) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.17.1, js-controller: 4.0.24
                                          2023-08-24 13:59:55.835  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 2489936
                                          2023-08-24 13:59:58.132  - info: backitup.0 (2489936) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 4.0.24
                                          2023-08-24 13:59:58.255  - info: backitup.0 (2489936) [iobroker] backup will be activated at 02:40 every 1 day(s)
                                          iob diag has finished.
                                          Copy text starting here:
                                                               v.2023-04-16
                                          Kernel:                 5.15.84-v8+
                                          Installation:           Native
                                          User-ID:                1000
                                          X-Server:               true
                                          io Broker startet aber noch nicht.
                                          • Romano Drews
                                            Romano Drews @Thomas Braun last edited by
                                            Lieben Dank für die schnelle Rückmeldung.
                                            Den Adapter hab ich vorher auch öfter verwendet und lokal speichern lassen.
                                            Ein
                                            iob backup
                                            pi@raspberrypi:/opt/iobroker $ iob backup
                                            host.raspberrypi 103 states saved
                                            host.raspberrypi 142 objects saved
                                            Backup created: /opt/iobroker/backups/2023_08_24-14_04_59_backupiobroker.tar.gz
                                            Jetzt befindet sich auch eine Datei im Ordner Backups.
                                            Vorher habe ich den Befehl aber in der Vergangenheit auch schon öfters ausgeführt.
                                            Die Dateien davon sind jedoch scheinbar weg.
                                            Vermutlich wurden sie bei der Neuinstallation gestern gelöscht?
                                            Nun hab ich ja scheine bar wieder ein Backup.
                                            Wie kann ich aus diesem Backup denn io Broker neu installieren, sodass es meine alte Struktur wieder hat?
                                            Ps. Bin gleich bis heute Abend leider nicht am PC, melde mich aber wieder.
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            734141
