    4. [HowTo] ioBroker Restore unter Linux durchführen
      Sebi_7_6 last edited by
      Das Backup hat soweit funktioniert nur das HABPanel nicht. Hab es entfernt und die Instanz wieder neu installiert.
      Aber es steht immer 2x drinn. Clicke ich drauf kommt so etwas ..
      URIError: Failed to decode param '%web_protocol%://%web_bind%:%web_port%/habpanel/index.html'
          at decodeURIComponent (<anonymous>)
          at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12)
          at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15)
          at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:585:18)
          at next (/opt/iobroker/node_modules/express/lib/router/index.js:226:15)
          at compression (/opt/iobroker/node_modules/compression/index.js:220:5)
          at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
          at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13)
          at /opt/iobroker/node_modules/express/lib/router/index.js:286:9
          at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
      • Glasfaser
        Glasfaser @Sebi_7_6 last edited by
        @sebi_7_6 sagte in [HowTo] ioBroker Restore unter Linux durchführen:
        Was entfernt , nur die Instanz ... oder auch den Adapter !?
        Zeige mal
        iob diag
          Sebi_7_6 last edited by Sebi_7_6
          Beides
          Adapter State
            system.adapter.accuweather.0            : accuweather           : raspberrypi                              - disabled
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
            system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
            system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
            system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              - disabled
            system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
          + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
            system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
            system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              - disabled
          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          + system.adapter.pushbullet.0             : pushbullet            : raspberrypi                              -  enabled
            system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              - disabled
            system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
          + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
            system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
            system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
            system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
          Adapter    "admin"        : 6.3.5    , installed 6.2.17 [Updatable]
          Adapter    "alexa2"       : 3.23.2   , installed 3.19.9 [Updatable]
          Adapter    "backitup"     : 2.6.16   , installed 2.4.10 [Updatable]
          Adapter    "bring"        : 1.8.1    , installed 1.8.1
          Adapter    "cloud"        : 4.3.0    , installed 4.2.2  [Updatable]
          Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
          Adapter    "discovery"    : 3.1.0    , installed 3.0.3  [Updatable]
          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
          Adapter    "ical"         : 1.13.2   , installed 1.13.2
          Adapter    "iot"          : 1.14.2   , installed 1.11.9 [Updatable]
          Adapter    "javascript"   : 6.1.4    , installed 6.0.0  [Updatable]
          Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
          Adapter    "lg-thinq"     : 0.1.4    , installed 0.0.7  [Updatable]
          Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
          Adapter    "openweathermap": 0.3.3   , installed 0.3.3
          Adapter    "ping"         : 1.5.3    , installed 1.5.3
          Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
          Adapter    "schoolfree"   : 1.1.1    , installed 1.0.1  [Updatable]
          Adapter    "smartthings"  : 0.0.4    , installed 0.0.3  [Updatable]
          Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
          Adapter    "tr-064"       : 4.2.18   , installed 4.2.16 [Updatable]
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "tuya"         : 3.13.1   , installed 3.13.1
          Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
          Adapter    "wled"         : 0.6.7    , installed 0.6.7
          Objects and States
          Objects:        9978
          States:         8091
          Wie ich gesehen habe ist es bei der VIS genauso.
          Hab jetzt beide deinstalliert und nur HABPanel wieder installiert.
          Aber es erscheint wieder 2x im Dashboard und dann der Fehler wenn man ihn aufruft.
          da ist auch nichts zum starten oder Einstellungen usw.
            Habedere last edited by Habedere
            habe die Tage auch mein Backup neu eingespielt und hab etwas Probleme...
            Los gings hiermit:
            No connection to states 127.0.0.1:6379
            Hab dann redis neu installiert. Soweit so gut...
            Nun wie folgt probiert bzw. Fehlermeldung erhalten:
            nulu@raspberrypi:~ $ iobroker stop
            iobroker host this
            iobroker start
            A host with the name "raspberrypi" already exists!
            Scheint aktiv zu sein, kann aber nicht darauf zugreifen:
            nulu@raspberrypi:~ $ iobroker list instances
              system.adapter.awattar.0                : awattar               : raspberrypi                              - disabled
              system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
              system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
              system.adapter.discovergy.0             : discovergy            : raspberrypi                              - disabled
              system.adapter.easee.0                  : easee                 : raspberrypi                              - disabled
              system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
              system.adapter.history.0                : history               : raspberrypi                              - disabled
              system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
              system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 0
              system.adapter.info.0                   : info                  : raspberrypi                              - disabled
              system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
              system.adapter.modbus.3                 : modbus                : raspberrypi                              - disabled
              system.adapter.modbus.4                 : modbus                : raspberrypi                              - disabled
              system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
              system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
              system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
              system.adapter.solarwetter.0            : solarwetter           : raspberrypi                              - disabled
              system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
              system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              - disabled
              system.adapter.sql.0                    : sql                   : raspberrypi                              - disabled, port: 3306
              system.adapter.statistics.0             : statistics            : raspberrypi                              - disabled
              system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
              system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
              system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
              system.adapter.yamaha.0                 : yamaha                : raspberrypi                              - disabled
              system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyUSB0
            + instance is alive
            Jemand einen Tipp wo ich ansezten kann?
            PS: hier noch der vollständige Diag
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Model           : Raspberry Pi 3 Model B Rev 1.2
            Architecture    : aarch64
            Docker          : false
            Virtualization  : none
            Distributor ID: Debian
            Description:    Debian GNU/Linux 11 (bullseye)
            Release:        11
            Codename:       bullseye
            PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
            NAME="Debian GNU/Linux"
            VERSION_ID="11"
            VERSION="11 (bullseye)"
            VERSION_CODENAME=bullseye
            ID=debian
            HOME_URL="https://www.debian.org/"
            SUPPORT_URL="https://www.debian.org/support"
            BUG_REPORT_URL="https://bugs.debian.org/"
            Systemuptime and Load:
             16:57:57 up 7 min,  1 user,  load average: 0.39, 0.39, 0.22
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            Other values than 0x0 hint to temperature/voltage problems
            temp=55.3'C
            volt=1.3000V
            *** Time and Time Zones ***
                           Local time: Tue 2023-04-25 16:57:58 CEST
                       Universal time: Tue 2023-04-25 14:57:58 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            nulu
            /home/nulu
            nulu adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            909M        150M        540M        1.0M        218M        702M
            Swap:            99M          0B         99M
            Total:          1.0G        150M        640M
                      909 M total memory
                      150 M used memory
                      233 M active memory
                       62 M inactive memory
                      540 M free memory
                       18 M buffer memory
                      199 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /dev/root      ext4      110G  2.8G  103G   3% /
            devtmpfs       devtmpfs  325M     0  325M   0% /dev
            tmpfs          tmpfs     455M     0  455M   0% /dev/shm
            tmpfs          tmpfs     182M  1.1M  181M   1% /run
            /dev/sda1      vfat      255M   31M  225M  13% /boot
            tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
            [Tue Apr 25 16:50:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e2d113b0-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Tue Apr 25 16:50:13 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
            [Tue Apr 25 16:50:13 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
            [Tue Apr 25 16:50:17 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
            Show mounted filesystems (real ones only):
            TARGET  SOURCE    FSTYPE OPTIONS
            /       /dev/sda2 ext4   rw,noatime
            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            644M    /var/
            271M    /var/lib
            196M    /var/cache
            191M    /var/cache/apt
            124M    /var/lib/mysql
            Archived and active journals take up 72.0M in the file system.
            /opt/iobroker/backups:
            4.0K    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            47M     /opt/iobroker/iobroker-data/
            16M     /opt/iobroker/iobroker-data/files
            13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
            14M     /opt/iobroker/iobroker-data/objects.jsonl
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            5.2M    /opt/iobroker/iobroker-data/states.jsonl
            2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
            1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.16.0
            /usr/bin/node           v18.16.0
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Installed: 18.16.0-deb-1nodesource1
              Candidate: 18.16.0-deb-1nodesource1
              Version table:
             *** 18.16.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u3 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                 12.22.5~dfsg-2~11u1 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            No problems detected
            *** ioBroker-Installation ***
            ioBroker Status
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            MULTIHOSTSERVICE/enabled: false
            Core adapters versions
            js-controller:  4.0.24
            admin:          6.3.5
            javascript:     "javascript" not found
            Adapters from github:   0
            Adapter State
            + instance is alive
            Adapter    "admin"        : 6.3.5    , installed 6.3.5
            Adapter    "backitup"     : 2.6.16   , installed 2.5.9  [Updatable]
            Adapter    "flot"         : 1.11.0   , installed 1.11.0
            Adapter    "history"      : 2.2.4    , installed 2.2.4
            Controller "js-controller": 4.0.24   , installed 4.0.24
            Objects and States
            Objects:        9496
            States:         83
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14720      558/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        12805      612/mariadbd
            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      111        13827      544/redis-server 12
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14722      558/sshd: /usr/sbin
            tcp6       0      0 ::1:6379                :::*                    LISTEN      111        13828      544/redis-server 12
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12790      779/dhcpcd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14624      432/avahi-daemon: r
            udp        0      0 0.0.0.0:44832           0.0.0.0:*                           108        14626      432/avahi-daemon: r
            udp6       0      0 :::60532                :::*                                108        14627      432/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        14625      432/avahi-daemon: r
            2023-04-25 16:58:01.301  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
            2023-04-25 16:58:01.327  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2023-04-25 16:58:01.331  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
            2023-04-25 16:58:01.332  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
            2023-04-25 16:58:05.120  - info: host.raspberrypi-Server  Error inMem-objects listening on port 6379: Error: listen EADDRINUSE: address already in use 127.0.0.1:6379
            2023-04-25 16:58:31.388  - error: host.raspberrypi No connection to databases possible, restart
            2023-04-25 16:58:31.401  - info: host.raspberrypi iobroker _restart
            2023-04-25 16:58:39.163  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
            2023-04-25 16:58:39.176  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2023-04-25 16:58:39.179  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
            2023-04-25 16:58:39.180  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
            2023-04-25 16:58:43.156  - info: host.raspberrypi-Server  Error inMem-objects listening on port 6379: Error: listen EADDRINUSE: address already in use 127.0.0.1:6379
            2023-04-25 16:59:09.234  - error: host.raspberrypi No connection to databases possible, restart
            2023-04-25 16:59:09.245  - info: host.raspberrypi iobroker _restart
            2023-04-25 16:59:16.522  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
            2023-04-25 16:59:16.536  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2023-04-25 16:59:16.539  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
            2023-04-25 16:59:16.541  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
            2023-04-25 16:59:20.553  - info: host.raspberrypi-Server  Error inMem-objects listening on port 6379: Error: listen EADDRINUSE: address already in use 127.0.0.1:6379
            2023-04-25 16:59:46.590  - error: host.raspberrypi No connection to databases possible, restart
            2023-04-25 16:59:46.602  - info: host.raspberrypi iobroker _restart
            2023-04-25 16:59:54.337  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
            2023-04-25 16:59:54.353  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2023-04-25 16:59:54.356  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
            2023-04-25 16:59:54.357  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @Habedere last edited by
              @habedere
              iob start admin
              liefert?
                Habedere @Thomas Braun last edited by
                @thomas-braun sagte in [HowTo] ioBroker Restore unter Linux durchführen:
                iob start admin
                Garnichts
                  @habedere
                  Starte die Kiste komplett durch.
                    Reboot mehrmals durchgeführt - keine Reaktion auf den Befehl
                      crunchip Forum Testing Most Active @Habedere last edited by
                      @habedere sagte in [HowTo] ioBroker Restore unter Linux durchführen:
                      Objects type: jsonl States type: jsonl
                      https://www.iobroker.net/#de/documentation/config/redis.md
                      ist zwar eingeschaltet aber läuft nicht
                        Habedere @crunchip last edited by Habedere
                        @crunchip
                        Du meinst redis?
                        Dachte schon:
                        nulu@raspberrypi:~ $ sudo systemctl status redis-server
                        sudo systemctl enable redis-server
                        ● redis-server.service - Advanced key-value store
                             Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor >
                             Active: active (running) since Tue 2023-04-25 17:06:50 CEST; 12min ago
                               Docs: http://redis.io/documentation,
                                     man:redis-server(1)
                           Main PID: 544 (redis-server)
                             Status: "Ready to accept connections"
                              Tasks: 5 (limit: 779)
                                CPU: 3.902s
                             CGroup: /system.slice/redis-server.service
                                     └─544 /usr/bin/redis-server 127.0.0.1:6379
                        Apr 25 17:06:49 raspberrypi systemd[1]: Starting Advanced key-value store...
                        Apr 25 17:06:50 raspberrypi systemd[1]: Started Advanced key-value store.
                        lines 1-14/14 (END)...skipping...
                             Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
                                     man:redis-server(1)
                                CPU: 3.902s
                        Irgendwas passt da nicht - läuft ioBroker nun oder nicht?
                        nulu@raspberrypi:~ $ iobroker status
                        Objects type: jsonl
                        States  type: jsonl
                          @habedere ja dein iobroker läuft, aus deinem Beitrag weiter oben aber der admin nicht
                          redis ist zwar installiert aber nicht in Benutzung, da du aktuell jsonl verwendest, wenn du vorher redis verwendet hast musst du auch wieder umstellen auf redis
                          da laufen scheinbar mehrere Prozesse
                            @crunchip
                            Denke dein Zitat der Objects und States sollte eine Anspielung sein?
                            Objects type: file
                            States  type: redis
                            Hab nochmal vorsichtshalber "iob start admin" durchgeführt und jetzt kann ich wieder darauf zugreifen 🙂
                            Kann/soll ich irgendwie noch checken ob alls ordentlich drauf ist und nichts doppelt oder so?
                            Soll ich im nächsten Schritt erst Datenbanken wie Zigbee etc. einlesen oder erst alle Adapter updaten?
                              @crunchip
                              hat sich überschnitten... Ich habe nie etwas mit redis eingestellt - scheint aber zu funktionieren 🙂
                              Wie kann ich prüfen ob mehere Prozesse laufen bzw. was tue ich dagegen?
                                crunchip Forum Testing Most Active @Habedere last edited by crunchip
                                warum hast du dann redis installiert?
                                ps -ef |grep redis
                                mach deine updates und danach spielst du deine backups rein
                                  @crunchip sagte in [HowTo] ioBroker Restore unter Linux durchführen:
                                  Weil "google" meinte das wäre die Lösung auf mein Problem der "no Connection"
                                  nulu@raspberrypi:~ $ ps -ef |grep redis
                                  redis        544       1  0 17:07 ?        00:00:11 /usr/bin/redis-server 127.0.0.1:6379
                                  nulu        1996     814  0 17:37 pts/0    00:00:00 grep --color=auto redis
                                  Erst Updates - geht klar...
                                    kann aber erst kommen, wenn du redis angefasst hast, denn Port 6379 ist redis, wenn du zuvor nie was mit redis gemacht hast, würde diese Meldung erst gar nicht auftreten
                                      Ich habe ehrlich gesagt keine Ahnung was redis überhaupt ist 🙂 also wenn dann muss es Zufall gewesen sein...
                                      Soweit alles wieder zurück gespielt. Habe sogar ein Backup von Redis! Hier hat das Backup aber nicht geklappt glaube ich. Hat erst fehlgeschlagen geschrieben und dann restore erfolgreich. Mal sehen ob mir noch was einfällt...
                                      Einzig was aktuell nicht klappt ist seltsamerweise der Flot-Adapter:
                                      URIError: Failed to decode param '%web_protocol%://192.168.178.3:%web_port%/flot/edit.html'
                                      Mal sehen ob ich das noch hin bekomme...
                                        Ich habe ehrlich gesagt keine Ahnung was redis überhaupt ist also wenn dann muss es Zufall gewesen sein...
                                        dass passt aber irgendwie gar nicht zusammen deine Aussage
                                        192.168.178.3
                                        war auch vorher deine IP?
                                          @crunchip
                                          Ich weiß - wundert mich selber 🙂 Scheinbar war Redis standardmäßig angehakt im Adapter? keine Ahnung. Hauptsache es läuft! Welche ein Kampf wenn man keinen Plan hat...
                                          Danke dir vielmals!
                                            nö, man muss das explizit installieren und einrichten, ist kein default und auch kein Standard
                                            backitup how-to restore restore backup
                                            76
                                            513
                                            130493
