    • MichMein
      MichMein last edited by
      @simatec hast du den Wunsch / Vorschlag von @eurofinder gelesen? Ich habe auch schon mal daran gedacht, wäre ein tolles Feature.
      erster Beitrag
      zweiter Beitrag
      Vielen Dank und ein schönes Wochenende
        erazor86 @erazor86 last edited by
        @erazor86 said in Test Adapter shuttercontrol v1.4.x:
        @michael-sauer said in Test Adapter shuttercontrol v1.4.x:
        @simatec
        So wie es aussieht versucht der shuttercontrol Adapter das falsche Format in die Shelly Variable zu schreiben.
        2021-11-16 16:37:00.077 - info: shuttercontrol.0 (25035) #17 Set ID: Esszimmer Shutter left value: 50%
        2021-11-16 16:37:00.083 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Esszimmer.Shutter.left.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:00.107 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#40F52022AD50#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:00.119 - error: shelly.0 (8611) Datatype for SHSW-25#40F52022AD50#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:00.296 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Esszimmer.Shutter.Esszimmer_Rollladen" has to be type "number" but received type "string"
        2021-11-16 16:37:02.073 - info: shuttercontrol.0 (25035) #17 Set ID: Esszimmer Shutter right value: 50%
        2021-11-16 16:37:02.075 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Esszimmer.Shutter.right.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:02.085 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#C4A7A3#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:02.089 - error: shelly.0 (8611) Datatype for SHSW-25#C4A7A3#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:02.284 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Esszimmer.Shutter.Esszimmer_Rollladen" has to be type "number" but received type "string"
        2021-11-16 16:37:04.074 - info: shuttercontrol.0 (25035) #17 Set ID: Küche Shutter right value: 59%
        2021-11-16 16:37:04.077 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Küche.Shutter.right.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:04.087 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#C47EF7#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:04.091 - error: shelly.0 (8611) Datatype for SHSW-25#C47EF7#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:04.287 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Küche.Shutter.Küche_Rolladen" has to be type "number" but received type "string"
        2021-11-16 16:37:06.073 - info: shuttercontrol.0 (25035) #17 Set ID: Küche Shutter left value: 50%
        2021-11-16 16:37:06.075 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Küche.Shutter.left.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:06.085 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#C45BD6#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:06.089 - error: shelly.0 (8611) Datatype for SHSW-25#C45BD6#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:08.074 - info: shuttercontrol.0 (25035) #17 Set ID: Wohnzimmer Shutter right value: 0%
        2021-11-16 16:37:08.284 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Wohnzimmer.Shutter.Wohnzimmer_Rolladen" has to be type "number" but received type "string"
        2021-11-16 16:37:10.074 - info: shuttercontrol.0 (25035) #17 Set ID: Wohnzimmer Shutter left value: 80%
        2021-11-16 16:37:10.080 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Wohnzimmer.Shutter.left.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:10.092 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#C4D14F#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:10.096 - error: shelly.0 (8611) Datatype for SHSW-25#C4D14F#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:12.073 - info: shuttercontrol.0 (25035) #17 Set ID: Büro links value: 40%
        2021-11-16 16:37:12.077 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Wohnzimmer.Shutter.Büro_left.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:12.085 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#40F5200469DA#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:12.089 - error: shelly.0 (8611) Datatype for SHSW-25#40F5200469DA#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:14.074 - info: shuttercontrol.0 (25035) #17 Set ID: Büro mitte value: 40%
        2021-11-16 16:37:14.078 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Wohnzimmer.Shutter.Büro_center.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:14.087 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#84CCA8A115DC#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:14.091 - error: shelly.0 (8611) Datatype for SHSW-25#84CCA8A115DC#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:16.075 - info: shuttercontrol.0 (25035) #17 Set ID: Büro rechts value: 40%
        2021-11-16 16:37:16.079 - info: shuttercontrol.0 (25035) State value to set for "linkeddevices.0.Wohnzimmer.Shutter.Büro_right.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:16.087 - info: linkeddevices.0 (3698) State value to set for "shelly.0.SHSW-25#40F52004A0D1#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:16.091 - error: shelly.0 (8611) Datatype for SHSW-25#40F52004A0D1#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:18.015 - info: shuttercontrol.0 (25035) #26 Set ID: Schlafzimmer links value: 50%
        2021-11-16 16:37:18.018 - info: shuttercontrol.0 (25035) State value to set for "shelly.0.SHSW-25#B939B4#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:18.023 - error: shelly.0 (8611) Datatype for SHSW-25#B939B4#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:18.025 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Schlafzimmer.Shutter.left.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:20.014 - info: shuttercontrol.0 (25035) #26 Set ID: Schlafzimmer rechts value: 50%
        2021-11-16 16:37:20.018 - info: shuttercontrol.0 (25035) State value to set for "shelly.0.SHSW-25#76CB7A#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:20.022 - error: shelly.0 (8611) Datatype for SHSW-25#76CB7A#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:20.029 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Schlafzimmer.Shutter.right.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:22.026 - info: shuttercontrol.0 (25035) #26 Set ID: Spielzimmer value: 50%
        2021-11-16 16:37:22.030 - info: shuttercontrol.0 (25035) State value to set for "shelly.0.SHSW-25#76C3C3#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:22.036 - error: shelly.0 (8611) Datatype for SHSW-25#76C3C3#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:22.038 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Spielzimmer.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:24.025 - info: shuttercontrol.0 (25035) #26 Set ID: Kinderzimmer value: 50%
        2021-11-16 16:37:24.028 - info: shuttercontrol.0 (25035) State value to set for "shelly.0.SHSW-25#E098068CEDDB#1.Shutter.Position" has to be type "number" but received type "string"
        2021-11-16 16:37:24.032 - error: shelly.0 (8611) Datatype for SHSW-25#E098068CEDDB#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
        2021-11-16 16:37:24.038 - info: linkeddevices.0 (3698) State value to set for "linkeddevices.0.Kinderzimmer.Shutter.Position" has to be type "number" but received type "string"
        Ich habe genau das gleiche Problem, allerdings nicht bei der xmas Einstellung, sondern nur bei dem Fenstern, wo ich den Frostschutz aktiviert habe... Gibt es dazu eine Lösung?
        Wie kann ich den debug Mode aktivieren um die mehr Infos zu liefern?
        anbei mein protokoll-Auszug:
        2023-04-22 23:40:52.601 - debug: shuttercontrol.0 (25598) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-04-22 23:40:52.649 - debug: shuttercontrol.0 (25598) Objects client ready ... initialize now
        2023-04-22 23:40:52.652 - debug: shuttercontrol.0 (25598) Objects create System PubSub Client
        2023-04-22 23:40:52.653 - debug: shuttercontrol.0 (25598) Objects create User PubSub Client
        2023-04-22 23:40:52.702 - debug: shuttercontrol.0 (25598) Objects client initialize lua scripts
        2023-04-22 23:40:52.710 - debug: shuttercontrol.0 (25598) Objects connected to redis: 127.0.0.1:9001
        2023-04-22 23:40:52.767 - debug: shuttercontrol.0 (25598) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-04-22 23:40:52.784 - debug: shuttercontrol.0 (25598) States create System PubSub Client
        2023-04-22 23:40:52.786 - debug: shuttercontrol.0 (25598) States create User PubSub Client
        2023-04-22 23:40:52.815 - debug: shuttercontrol.0 (25598) States connected to redis: 127.0.0.1:9000
        2023-04-22 23:40:52.893 - debug: shuttercontrol.0 (25598) Plugin sentry Initialize Plugin (enabled=true)
        2023-04-22 23:40:52.910 - info: shuttercontrol.0 (25598) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-04-22 23:40:53.378 - info: shuttercontrol.0 (25598) starting. Version 1.4.23 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v16.19.0, js-controller: 4.0.24
        2023-04-22 23:40:53.433 - debug: shuttercontrol.0 (25598) shutter Config Check started
        2023-04-22 23:40:53.435 - debug: shuttercontrol.0 (25598) shutter Config Check successfully completed
        2023-04-22 23:40:53.443 - debug: shuttercontrol.0 (25598) trigger for outside temperature: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL
        2023-04-22 23:40:53.445 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rollade_Wohnzimmer_groß.SET
        2023-04-22 23:40:53.445 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rollade_Wohnzimmer_klein.SET
        2023-04-22 23:40:53.446 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rollade_Esszimmer.SET
        2023-04-22 23:40:53.446 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Küche_klein.SET
        2023-04-22 23:40:53.447 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Küche_groß.SET
        2023-04-22 23:40:53.448 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Büro_Straße.SET
        2023-04-22 23:40:53.449 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Büro_Einfahrt.SET
        2023-04-22 23:40:53.449 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Gäste-Wc.SET
        2023-04-22 23:40:53.450 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_HWR.SET
        2023-04-22 23:40:53.451 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Werkstatt.SET
        2023-04-22 23:40:53.451 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Badezimmer.SET
        2023-04-22 23:40:53.452 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Schlafzimmer.SET
        2023-04-22 23:40:53.452 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Ankleidezimmer.SET
        2023-04-22 23:40:53.452 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Elias.SET
        2023-04-22 23:40:53.453 - debug: shuttercontrol.0 (25598) Shutter State: alias.0.Shellys.Rolladen_Kinderzimmer_2.SET
        2023-04-22 23:40:53.507 - debug: shuttercontrol.0 (25598) Wohnzimmer_groß: save settings
        2023-04-22 23:40:53.623 - debug: shuttercontrol.0 (25598) Wohnzimmer_klein: save settings
        2023-04-22 23:40:53.724 - debug: shuttercontrol.0 (25598) Esszimmer: save settings
        2023-04-22 23:40:53.826 - debug: shuttercontrol.0 (25598) Küche_klein: save settings
        2023-04-22 23:40:53.928 - debug: shuttercontrol.0 (25598) Küche_groß: save settings
        2023-04-22 23:40:54.029 - debug: shuttercontrol.0 (25598) Büro_Straße: save settings
        2023-04-22 23:40:54.178 - debug: shuttercontrol.0 (25598) Büro_Einfahrt: save settings
        2023-04-22 23:40:54.317 - debug: shuttercontrol.0 (25598) Gäste-WC: save settings
        2023-04-22 23:40:54.452 - debug: shuttercontrol.0 (25598) HWR: save settings
        2023-04-22 23:40:54.554 - debug: shuttercontrol.0 (25598) Werkstatt: save settings
        2023-04-22 23:40:54.655 - debug: shuttercontrol.0 (25598) Badezimmer: save settings
        2023-04-22 23:40:54.756 - debug: shuttercontrol.0 (25598) Schlafzimmer: save settings
        2023-04-22 23:40:54.857 - debug: shuttercontrol.0 (25598) Ankleidezimmer: save settings
        2023-04-22 23:40:54.958 - debug: shuttercontrol.0 (25598) Elias: save settings
        2023-04-22 23:40:55.059 - debug: shuttercontrol.0 (25598) Kinderzimmer_2: save settings
        2023-04-22 23:40:56.644 - debug: shuttercontrol.0 (25598) Travel times of the shutters are calculated
        2023-04-22 23:40:56.646 - debug: shuttercontrol.0 (25598) calculate astrodata ...
        2023-04-22 23:40:56.646 - debug: shuttercontrol.0 (25598) goldenHourEnd today: 07:12
        2023-04-22 23:40:56.648 - debug: shuttercontrol.0 (25598) goldenHour today: 19:54
        2023-04-22 23:40:56.649 - debug: shuttercontrol.0 (25598) current day: 6
        2023-04-22 23:40:56.649 - debug: shuttercontrol.0 (25598) Sunrise today: 06:27
        2023-04-22 23:40:56.650 - debug: shuttercontrol.0 (25598) Sunset today: 20:38
        2023-04-22 23:40:56.651 - debug: shuttercontrol.0 (25598) Starting up shutters GoldenHour area: 07:12
        2023-04-22 23:40:56.652 - debug: shuttercontrol.0 (25598) Shutdown shutters GoldenHour area: 20:24
        2023-04-22 23:40:56.652 - debug: shuttercontrol.0 (25598) Starting up shutters Sunrise area: 06:27
        2023-04-22 23:40:56.652 - debug: shuttercontrol.0 (25598) Shutdown shutters Sunset area: 21:08
        2023-04-22 23:40:56.707 - debug: shuttercontrol.0 (25598) check IsLater : 06:27 07:30
        2023-04-22 23:40:56.708 - debug: shuttercontrol.0 (25598) check IsEqual : 07:30 07:30
        2023-04-22 23:40:56.709 - debug: shuttercontrol.0 (25598) yes, IsEqual : 07:30 07:30
        2023-04-22 23:40:56.709 - debug: shuttercontrol.0 (25598) Starting up shutters living area: 07:30 debug 12
        2023-04-22 23:40:56.730 - debug: shuttercontrol.0 (25598) check IsLater : 06:27 09:00
        2023-04-22 23:40:56.731 - debug: shuttercontrol.0 (25598) check IsLater : 06:27 08:30
        2023-04-22 23:40:56.731 - debug: shuttercontrol.0 (25598) check IsEqual : 08:30 09:00
        2023-04-22 23:40:56.732 - debug: shuttercontrol.0 (25598) check IsEqual : 06:27 09:00
        2023-04-22 23:40:56.733 - debug: shuttercontrol.0 (25598) check IsEarlier : 06:27 08:30
        2023-04-22 23:40:56.733 - debug: shuttercontrol.0 (25598) yes, IsEarlier : 06:27 08:30
        2023-04-22 23:40:56.734 - debug: shuttercontrol.0 (25598) Starting up shutters sleep area: 08:30 debug 14
        2023-04-22 23:40:56.753 - debug: shuttercontrol.0 (25598) check IsLater : 06:27 10:00
        2023-04-22 23:40:56.753 - debug: shuttercontrol.0 (25598) check IsLater : 06:27 09:00
        2023-04-22 23:40:56.754 - debug: shuttercontrol.0 (25598) check IsEqual : 09:00 10:00
        2023-04-22 23:40:56.754 - debug: shuttercontrol.0 (25598) check IsEqual : 06:27 10:00
        2023-04-22 23:40:56.754 - debug: shuttercontrol.0 (25598) check IsEarlier : 06:27 09:00
        2023-04-22 23:40:56.755 - debug: shuttercontrol.0 (25598) yes, IsEarlier : 06:27 09:00
        2023-04-22 23:40:56.755 - debug: shuttercontrol.0 (25598) Starting up shutters children area: 09:00 debug 14
        2023-04-22 23:40:56.760 - debug: shuttercontrol.0 (25598) check IsEarlier : 23:00 21:08
        2023-04-22 23:40:56.760 - debug: shuttercontrol.0 (25598) check IsLater : 23:00 21:08
        2023-04-22 23:40:56.760 - debug: shuttercontrol.0 (25598) yes, IsLater : 23:00 21:08
        2023-04-22 23:40:56.761 - debug: shuttercontrol.0 (25598) Shutdown shutters living area: 21:08 debug 4
        2023-04-22 23:40:56.761 - debug: shuttercontrol.0 (25598) shutterDownLiving
        2023-04-22 23:40:56.770 - debug: shuttercontrol.0 (25598) Shutdown shutters children area: 19:15 debug 3
        2023-04-22 23:40:56.780 - debug: shuttercontrol.0 (25598) Shutdown shutters sleep area: 21:08 debug 4
        2023-04-22 23:40:56.797 - debug: shuttercontrol.0 (25598) late down at 00:00
        2023-04-22 23:40:56.799 - debug: shuttercontrol.0 (25598) complete down at 00:00
        2023-04-22 23:41:43.353 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#B9416B#1.Shutter.Close, sourceObj={"type":"state","common":{"name":"Close","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#B9416B#1.Shutter.Close","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411742855}
        2023-04-22 23:41:43.354 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#B9416B#1.Shutter.Open, sourceObj={"type":"state","common":{"name":"Open","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#B9416B#1.Shutter.Open","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411742855}
        2023-04-22 23:41:43.354 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#B9416B#1.Shutter.Position, sourceObj={"type":"state","common":{"name":"Position","type":"number","role":"level.blind","read":true,"write":true,"unit":"%","min":0,"max":100},"native":{},"_id":"shelly.0.SHSW-25#B9416B#1.Shutter.Position","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411743113}
        2023-04-22 23:41:43.757 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#B9416B#1.Shutter.Pause, sourceObj={"type":"state","common":{"name":"Pause","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#B9416B#1.Shutter.Pause","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411742855}
        2023-04-22 23:41:43.759 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76CED0#1.Shutter.state, sourceObj={"type":"state","common":{"name":"Roller state","type":"string","role":"state","read":true,"write":true,"states":{"close":"close","open":"open","stop":"stop"}},"native":{},"_id":"shelly.0.SHSW-25#76CED0#1.Shutter.state","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411763010}
        2023-04-22 23:41:43.759 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76CED0#1.Shutter.Close, sourceObj={"type":"state","common":{"name":"Close","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#76CED0#1.Shutter.Close","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411751182}
        2023-04-22 23:41:43.760 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76CED0#1.Shutter.Open, sourceObj={"type":"state","common":{"name":"Open","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#76CED0#1.Shutter.Open","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411751182}
        2023-04-22 23:41:43.760 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76CED0#1.Shutter.Position, sourceObj={"type":"state","common":{"name":"Position","type":"number","role":"level.blind","read":true,"write":true,"unit":"%","min":0,"max":100},"native":{},"_id":"shelly.0.SHSW-25#76CED0#1.Shutter.Position","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411751182}
        2023-04-22 23:41:43.761 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76CED0#1.Shutter.Pause, sourceObj={"type":"state","common":{"name":"Pause","type":"boolean","role":"button","read":false,"write":true},"native":{},"_id":"shelly.0.SHSW-25#76CED0#1.Shutter.Pause","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411751182}
        2023-04-22 23:41:43.772 - error: admin.0 (16939) Alias subscription error. Please check your alias definitions: sourceId=shelly.0.SHSW-25#76C797#1.Shutter.Position, sourceObj={"type":"state","common":{"name":"Position","type":"number","role":"level.blind","read":true,"write":true,"unit":"%","min":0,"max":100},"native":{},"_id":"shelly.0.SHSW-25#76C797#1.Shutter.Position","acl":{"object":1636,"state":1636,"file":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1676411754193}
        2023-04-22 23:42:00.090 - debug: shuttercontrol.0 (25598) Alarm Frost changed: false
        2023-04-22 23:42:00.096 - debug: shuttercontrol.0 (25598) start shutterAlarm
        2023-04-22 23:42:00.097 - debug: shuttercontrol.0 (25598) start pendingAlarm to check if an alarm is currently pending (exept frost)
        2023-04-22 23:42:00.098 - debug: shuttercontrol.0 (25598) status alarm pending for alias.0.Shellys.Rolladen_Kinderzimmer_2.SET: false
        2023-04-22 23:42:01.131 - debug: shuttercontrol.0 (25598) shutter alarm frost endet and no other alarm is pending Kinderzimmer 2 already at: 0% - setting current action: down
        2023-04-22 23:42:18.432 - info: jarvis.0 (4801) Client with IP 192.168.178.139 disconnected.
        2023-04-22 23:42:41.705 - info: admin.0 (16939) ==> Connected system.user.admin from ::ffff:192.168.178.148
        2023-04-22 23:43:07.275 - info: admin.0 (16939) <== Disconnect system.user.admin from ::ffff:192.168.178.148
        2023-04-22 23:44:00.151 - debug: shuttercontrol.0 (25598) Alarm Frost changed: false
        2023-04-22 23:44:00.151 - debug: shuttercontrol.0 (25598) start shutterAlarm
        2023-04-22 23:44:00.152 - debug: shuttercontrol.0 (25598) start pendingAlarm to check if an alarm is currently pending (exept frost)
        2023-04-22 23:44:00.152 - debug: shuttercontrol.0 (25598) status alarm pending for alias.0.Shellys.Rolladen_Kinderzimmer_2.SET: false
        2023-04-22 23:44:01.224 - debug: shuttercontrol.0 (25598) shutter alarm frost endet and no other alarm is pending Kinderzimmer 2 already at: 0% - setting current action: down
        2023-04-22 23:44:08.398 - debug: shuttercontrol.0 (25598) outsidetemperature changed: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL Value: 10.4
        2023-04-22 23:44:23.429 - debug: shuttercontrol.0 (25598) outsidetemperature changed: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL Value: 10.5
        2023-04-22 23:44:38.436 - debug: shuttercontrol.0 (25598) outsidetemperature changed: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL Value: 10.4
        2023-04-22 23:44:43.397 - debug: shuttercontrol.0 (25598) outsidetemperature changed: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL Value: 10.5
        2023-04-22 23:44:53.436 - debug: shuttercontrol.0 (25598) outsidetemperature changed: alias.0.Shellys.Außentemperatur+Luftfeuchte.ACTUAL Value: 10.4
        2023-04-22 23:45:00.042 - debug: shuttercontrol.0 (25598) calculate astrodata ...
        2023-04-22 23:45:00.044 - debug: shuttercontrol.0 (25598) Sun Azimut: 331.3°
        2023-04-22 23:45:00.045 - debug: shuttercontrol.0 (25598) Sun Elevation: -23.1°
        2023-04-22 23:46:00.130 - debug: shuttercontrol.0 (25598) Alarm Frost changed: false
        2023-04-22 23:46:00.131 - debug: shuttercontrol.0 (25598) start shutterAlarm
        2023-04-22 23:46:00.131 - debug: shuttercontrol.0 (25598) start pendingAlarm to check if an alarm is currently pending (exept frost)
        2023-04-22 23:46:00.131 - debug: shuttercontrol.0 (25598) status alarm pending for alias.0.Shellys.Rolladen_Kinderzimmer_2.SET: false
        2023-04-22 23:46:01.160 - debug: shuttercontrol.0 (25598) shutter alarm frost endet and no other alarm is pending Kinderzimmer 2 already at: 0% - setting current action: down
          Tottbeck last edited by
          Hallo, ich habe gestern auf die Version v1.4.23 aktualisiert. (von 1.4.18)
          Jetzt fuhren heute meine Rolladen zwar in den Sonnenschutz ("Sunprotect #414") aber nicht mehr raus.
          Ich lasse die über die "Außentemperatur/Lichtsensor und Himmelsrichtung" steuern, wobei ich für die Außentemperatur ein gefiltertetes Powersignal meiner PV-Anlage als Trigger nehme. Hat bisher auch gut funktioniert.
          Spätestens wenn die Himmelsrichtung nicht mehr passt, hätte hochgefahren werden müssen, aber das Event "Sunprotect #415" fehlt bei allen Rolläden. Bei 'autoState' stehen die im "Manu_Mode" habe ich dann gesehen, obwohl die nicht manuell verfahren wurden. 🤔
          Habe sie dann wieder in der AutoMode gezwungen. Danach sind die Rolladen die dann aus dem Sonnenschutz fuhren sofort wieder im "Manu_Mode" gelandet. Gibt es evtl. ein Feedback vom Shellys, was ihn durcheinander bringt? Das war mit der alten Version definitiv nicht.
            firebowl @Tottbeck last edited by
            @tottbeck nimm die 1.4.28
              Tottbeck @firebowl last edited by
              @firebowl
              OK, danke ist nun installiert. Dann ist die 1.4.23 wohl doch nicht so stable.
              Mal schauen was morgen passiert.
              • rtwl
                rtwl last edited by
                @simatec wann kommt denn die 28er ins stable? Die "instabile" 23er ist aktuell dort zu finden.
                • simatec
                  simatec Developer Most Active @rtwl last edited by
                  @rtwl Die v1.4.28 kommt garnicht ins Stable... Und grundsätzlich kommen Versionen ins Stable, wenn die Beta Tests erfolgreich abgeschlossen sind
                  • rtwl
                    rtwl last edited by
                    okay anders gefragt:
                    wann kommt eine neue Version anstelle der 23er ins stable welche nicht den Fehler aufweist, dass die Rollläden im manu_mode landen nach dem sie in den Sonnenschutz gefahren sind?
                    RaspiUser simatec 2 Replies Last reply Reply Quote 0
                    • RaspiUser
                      RaspiUser @rtwl last edited by
                      @rtwl
                      ... schließe mich deiner Frage an ...
                      • simatec
                        @rtwl sagte in Test Adapter shuttercontrol v1.4.x:
                        Hatte ich doch in meinem letzten Post geschrieben.
                        Wenn die Beta Versionen soweit getestet sind, dass sie Fehlerfrei sind.
                        Wann das ist, kann man nicht in Tage oder Wochen definieren.
                        Die aktuelle Beta 1.4.29 sieht recht gut aus.
                        Wenn ihr nicht warten wollt, installiert die Version aus der Beta Repo
                          steimi last edited by steimi
                          @simatec
                          Ich habe immer wieder Probleme mit shuttercontrol das Rollladen nicht so fahren wie ich mir das vorstelle.
                          1. Heute morgen z.B. hat Junior vor der upChildren-Zeit ein Fenster (KZ_2_F1) geöffnet, das Rollo ist dann hochgefahren. Er hat es nach der upChildren-Zeit geschlossen. Das Fenster wurde aber bei Durchlauf von Shuttercontrol während der upChildren-Zeit nicht neu gesetzt. Ich bin davon ausgegangen, dass das Fenster beim Durchlauf auf 100% und 'nicht getriggert' gesetzt wird. Das Rollo ist dann anschliessend wieder runter gefahren.
                          2. Ich habe im Kinderzimmer (z.B. KZ_1_F1) Dreh/Kippsensoren an den Fenster(griffen). Ich öffne das Fenster vor der downChildren-Zeit zum Lüften. Wenn ich nach der downChildren-Zeit das Fenster schliesse und sofort in den Kippmodus bringe hatte ich gehofft, das das Fenster dann sofort ich die Lüftungsstellung fährt. Das Fenster schliesst jedoch. Was habe ich falsch konfiguriert
                          2023-04-27 05:20:00.004 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                          2023-04-27 05:20:00.004 - debug: shuttercontrol.0 (1088236) Sun Azimut: 60.5°
                          2023-04-27 05:20:00.004 - debug: shuttercontrol.0 (1088236) Sun Elevation: -5.2°
                          2023-04-27 05:25:00.006 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                          2023-04-27 05:25:00.006 - debug: shuttercontrol.0 (1088236) Sun Azimut: 61.5°
                          2023-04-27 05:25:00.006 - debug: shuttercontrol.0 (1088236) Sun Elevation: -4.6°
                          2023-04-27 05:27:51.968 - debug: shuttercontrol.0 (1088236) TriggerID changed: hm-rpc.0.0007DF29950C05.1.STATE Value: 2
                          2023-04-27 05:27:51.971 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter conversion is:false
                          2023-04-27 05:27:52.016 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter current state.val is:20
                          2023-04-27 05:27:52.016 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter trigger drive-up is:100
                          2023-04-27 05:27:52.016 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter trigger change is:upDown
                          2023-04-27 05:27:52.017 - debug: shuttercontrol.0 (1088236) #1 save trigger height: 20% for device KZ_2_F1
                          2023-04-27 05:27:52.017 - debug: shuttercontrol.0 (1088236) #1 save trigger action: none for device KZ_2_F1
                          2023-04-27 05:27:52.017 - info: shuttercontrol.0 (1088236) #1 Set ID: KZ_2_F1 value: 100%
                          2023-04-27 05:27:52.018 - debug: shuttercontrol.0 (1088236) #1 current height: 100% for device KZ_2_F1
                          2023-04-27 05:27:52.018 - debug: shuttercontrol.0 (1088236) #1 current action: triggered for device KZ_2_F1
                          2023-04-27 05:27:52.018 - info: shuttercontrol.0 (1088236) triggered #1 Set ID: KZ_2_F1 value: 100%
                          2023-04-27 05:27:52.066 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:27:52.076 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:27:52.077 - debug: shuttercontrol.0 (1088236) Shutter state changed: KZ_2_F1 old value = 20 new value = 100
                          2023-04-27 05:27:52.077 - debug: shuttercontrol.0 (1088236) KZ_2_F1 Old value = 20. New value = 100. automatic is active
                          2023-04-27 05:27:52.126 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - window is still open -> driving now to :100
                          2023-04-27 05:30:00.004 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                          2023-04-27 05:30:00.005 - debug: shuttercontrol.0 (1088236) Sun Azimut: 62.5°
                          2023-04-27 05:30:00.005 - debug: shuttercontrol.0 (1088236) Sun Elevation: -3.9°
                          2023-04-27 05:31:00.015 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:00.016 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.Kueche_F1: false
                          2023-04-27 05:31:00.016 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:00.017 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.OG_1_F1: false
                          2023-04-27 05:31:00.028 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: Kueche_F1_Rollo value: 100%
                          2023-04-27 05:31:00.038 - info: shuttercontrol.0 (1088236) Children Up #21 Set ID: KZ_1_F1 value: 100%
                          2023-04-27 05:31:00.048 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:00.052 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:00.059 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:00.064 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:00.067 - debug: shuttercontrol.0 (1088236) Shutter state changed: Kueche_F1_Rollo old value = 20 new value = 100
                          2023-04-27 05:31:00.068 - debug: shuttercontrol.0 (1088236) Kueche_F1_Rollo Old value = 20. New value = 100. automatic is active
                          2023-04-27 05:31:00.073 - debug: shuttercontrol.0 (1088236) Shutter state changed: KZ_1_F1 old value = 20 new value = 100
                          2023-04-27 05:31:00.075 - debug: shuttercontrol.0 (1088236) KZ_1_F1 Old value = 20. New value = 100. automatic is active
                          2023-04-27 05:31:00.080 - debug: shuttercontrol.0 (1088236) last automatic Action for Kueche_F1_Rollo: up_LivingTime
                          2023-04-27 05:31:00.081 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 Kueche_F1_Rollo old height: 20% new height: 100%
                          2023-04-27 05:31:00.081 - debug: shuttercontrol.0 (1088236) last automatic Action for KZ_1_F1: up_ChidrenTime
                          2023-04-27 05:31:00.081 - debug: shuttercontrol.0 (1088236) shutterUpChildren #1 KZ_1_F1 old height: 20% new height: 100%
                          2023-04-27 05:31:01.081 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:01.081 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.Kueche_F2: false
                          2023-04-27 05:31:01.082 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:01.082 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.OG_2_F1: false
                          2023-04-27 05:31:01.123 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: Kueche_F2_Rollo value: 100%
                          2023-04-27 05:31:01.125 - info: shuttercontrol.0 (1088236) Children Up #21 Set ID: Buero_F1 value: 100%
                          2023-04-27 05:31:01.128 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:01.131 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:01.138 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:01.139 - debug: shuttercontrol.0 (1088236) Shutter state changed: Kueche_F2_Rollo old value = 20 new value = 100
                          2023-04-27 05:31:01.139 - debug: shuttercontrol.0 (1088236) Kueche_F2_Rollo Old value = 20. New value = 100. automatic is active
                          2023-04-27 05:31:01.142 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:01.144 - debug: shuttercontrol.0 (1088236) Shutter state changed: Buero_F1 old value = 0 new value = 100
                          2023-04-27 05:31:01.145 - debug: shuttercontrol.0 (1088236) Buero_F1 Old value = 0. New value = 100. automatic is active
                          2023-04-27 05:31:01.145 - debug: shuttercontrol.0 (1088236) last automatic Action for Kueche_F2_Rollo: up_LivingTime
                          2023-04-27 05:31:01.145 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 Kueche_F2_Rollo old height: 20% new height: 100%
                          2023-04-27 05:31:01.189 - debug: shuttercontrol.0 (1088236) last automatic Action for Buero_F1: up_ChidrenTime
                          2023-04-27 05:31:01.189 - debug: shuttercontrol.0 (1088236) shutterUpChildren #1 Buero_F1 old height: 0% new height: 100%
                          2023-04-27 05:31:02.145 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:02.145 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F1: false
                          2023-04-27 05:31:02.188 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F1_Rollo value: 100%
                          2023-04-27 05:31:02.192 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:02.194 - info: shuttercontrol.0 (1088236) Children Up #21 Set ID: Buero_F2 value: 100%
                          2023-04-27 05:31:02.202 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:02.203 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F1_Rollo old value = 20 new value = 100
                          2023-04-27 05:31:02.203 - debug: shuttercontrol.0 (1088236) WZ_F1_Rollo Old value = 20. New value = 100. automatic is active
                          2023-04-27 05:31:02.205 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:02.210 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F1_Rollo: up_LivingTime
                          2023-04-27 05:31:02.210 - debug: shuttercontrol.0 (1088236) shutterUpLiving #1 WZ_F1_Rollo old height: 20% new height: 100%
                          2023-04-27 05:31:02.215 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:02.216 - debug: shuttercontrol.0 (1088236) Shutter state changed: Buero_F2 old value = 50 new value = 100
                          2023-04-27 05:31:02.216 - debug: shuttercontrol.0 (1088236) Buero_F2 Old value = 50. New value = 100. automatic is active
                          2023-04-27 05:31:02.259 - debug: shuttercontrol.0 (1088236) last automatic Action for Buero_F2: up_ChidrenTime
                          2023-04-27 05:31:02.259 - debug: shuttercontrol.0 (1088236) shutterUpChildren #1 Buero_F2 old height: 50% new height: 100%
                          2023-04-27 05:31:03.210 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:03.210 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F2: false
                          2023-04-27 05:31:03.251 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F2_Rollo value: 100%
                          2023-04-27 05:31:03.259 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:03.260 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.OG_3_F1: false
                          2023-04-27 05:31:03.262 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:03.272 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:03.273 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F2_Rollo old value = 20 new value = 100
                          2023-04-27 05:31:03.274 - debug: shuttercontrol.0 (1088236) WZ_F2_Rollo Old value = 20. New value = 100. automatic is active
                          2023-04-27 05:31:03.320 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F2_Rollo: up_LivingTime
                          2023-04-27 05:31:03.320 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 WZ_F2_Rollo old height: 20% new height: 100%
                          2023-04-27 05:31:04.274 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:04.274 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.OG_3_F2: false
                          2023-04-27 05:31:04.319 - info: shuttercontrol.0 (1088236) Children Up #21 Set ID: KZ_2_F2 value: 100%
                          2023-04-27 05:31:04.321 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:04.321 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F3: false
                          2023-04-27 05:31:04.323 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:04.333 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:04.334 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F3_Rollo value: 100%
                          2023-04-27 05:31:04.334 - debug: shuttercontrol.0 (1088236) Shutter state changed: KZ_2_F2 old value = 20 new value = 100
                          2023-04-27 05:31:04.334 - debug: shuttercontrol.0 (1088236) KZ_2_F2 Old value = 20. New value = 100. automatic is active
                          2023-04-27 05:31:04.381 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:04.390 - debug: shuttercontrol.0 (1088236) last automatic Action for KZ_2_F2: up_ChidrenTime
                          2023-04-27 05:31:04.390 - debug: shuttercontrol.0 (1088236) shutterUpChildren #1 KZ_2_F2 old height: 20% new height: 100%
                          2023-04-27 05:31:04.393 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:04.394 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F3_Rollo old value = 20 new value = 100
                          2023-04-27 05:31:04.394 - debug: shuttercontrol.0 (1088236) WZ_F3_Rollo Old value = 20. New value = 100. automatic is active
                          2023-04-27 05:31:04.395 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F3_Rollo: up_LivingTime
                          2023-04-27 05:31:04.396 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 WZ_F3_Rollo old height: 20% new height: 100%
                          2023-04-27 05:31:05.396 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:05.396 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F4: false
                          2023-04-27 05:31:05.439 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F4_Rollo value: 100%
                          2023-04-27 05:31:05.485 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:05.495 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:05.496 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F4_Rollo old value = 0 new value = 100
                          2023-04-27 05:31:05.496 - debug: shuttercontrol.0 (1088236) WZ_F4_Rollo Old value = 0. New value = 100. automatic is active
                          2023-04-27 05:31:05.611 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F4_Rollo: up_LivingTime
                          2023-04-27 05:31:05.611 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 WZ_F4_Rollo old height: 0% new height: 100%
                          2023-04-27 05:31:06.611 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:06.611 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F5: false
                          2023-04-27 05:31:06.825 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F5_Rollo value: 100%
                          2023-04-27 05:31:07.011 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:07.021 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:07.022 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F5_Rollo old value = 0 new value = 100
                          2023-04-27 05:31:07.022 - debug: shuttercontrol.0 (1088236) WZ_F5_Rollo Old value = 0. New value = 100. automatic is active
                          2023-04-27 05:31:07.073 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F5_Rollo: up_LivingTime
                          2023-04-27 05:31:07.073 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 WZ_F5_Rollo old height: 0% new height: 100%
                          2023-04-27 05:31:08.074 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:08.074 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.WZ_F6: false
                          2023-04-27 05:31:08.119 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: WZ_F6_Rollo value: 100%
                          2023-04-27 05:31:08.165 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:08.176 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:08.177 - debug: shuttercontrol.0 (1088236) Shutter state changed: WZ_F6_Rollo old value = 0 new value = 100
                          2023-04-27 05:31:08.177 - debug: shuttercontrol.0 (1088236) WZ_F6_Rollo Old value = 0. New value = 100. automatic is active
                          2023-04-27 05:31:08.227 - debug: shuttercontrol.0 (1088236) last automatic Action for WZ_F6_Rollo: up_LivingTime
                          2023-04-27 05:31:08.227 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 WZ_F6_Rollo old height: 0% new height: 100%
                          2023-04-27 05:31:09.227 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:09.227 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.Bad_EG_F1: false
                          2023-04-27 05:31:09.271 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: Bad_EG_F1_Rollo value: 100%
                          2023-04-27 05:31:09.317 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:09.327 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:09.328 - debug: shuttercontrol.0 (1088236) Shutter state changed: Bad_EG_F1_Rollo old value = 0 new value = 100
                          2023-04-27 05:31:09.328 - debug: shuttercontrol.0 (1088236) Bad_EG_F1_Rollo Old value = 0. New value = 100. automatic is active
                          2023-04-27 05:31:09.374 - debug: shuttercontrol.0 (1088236) last automatic Action for Bad_EG_F1_Rollo: up_LivingTime
                          2023-04-27 05:31:09.375 - debug: shuttercontrol.0 (1088236) shutterUpLiving #2 Bad_EG_F1_Rollo old height: 0% new height: 100%
                          2023-04-27 05:31:10.375 - debug: shuttercontrol.0 (1088236) start pendingAlarm to check if an alarm is currently pending (exept frost)
                          2023-04-27 05:31:10.375 - debug: shuttercontrol.0 (1088236) status alarm pending for 0_userdata.0.Rollladen.HWR_F1: false
                          2023-04-27 05:31:10.419 - info: shuttercontrol.0 (1088236) Living up #13 Set ID: HWR_F1_Rollo value: 100%
                          2023-04-27 05:31:10.430 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:31:10.440 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:31:10.440 - debug: shuttercontrol.0 (1088236) Shutter state changed: HWR_F1_Rollo old value = 0 new value = 100
                          2023-04-27 05:31:10.441 - debug: shuttercontrol.0 (1088236) HWR_F1_Rollo Old value = 0. New value = 100. automatic is active
                          2023-04-27 05:31:10.486 - debug: shuttercontrol.0 (1088236) last automatic Action for HWR_F1_Rollo: up_LivingTime
                          2023-04-27 05:31:10.486 - debug: shuttercontrol.0 (1088236) shutterUpLiving #1 HWR_F1_Rollo old height: 0% new height: 100%
                          2023-04-27 05:35:00.004 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                          2023-04-27 05:35:00.004 - debug: shuttercontrol.0 (1088236) Sun Azimut: 63.5°
                          2023-04-27 05:35:00.004 - debug: shuttercontrol.0 (1088236) Sun Elevation: -3.2°
                          2023-04-27 05:35:24.446 - debug: shuttercontrol.0 (1088236) TriggerID changed: hm-rpc.0.0007DF299508E8.1.STATE Value: 2
                          2023-04-27 05:35:24.446 - debug: shuttercontrol.0 (1088236) KZ_1_F1 - shutter conversion is:false
                          2023-04-27 05:35:24.492 - debug: shuttercontrol.0 (1088236) KZ_1_F1 - shutter current state.val is:100
                          2023-04-27 05:35:24.492 - debug: shuttercontrol.0 (1088236) KZ_1_F1 - shutter trigger drive-up is:100
                          2023-04-27 05:35:24.492 - debug: shuttercontrol.0 (1088236) KZ_1_F1 - shutter trigger change is:upDown
                          2023-04-27 05:35:24.492 - debug: shuttercontrol.0 (1088236) #2 save trigger action: up for device: KZ_1_F1
                          2023-04-27 05:35:24.492 - debug: shuttercontrol.0 (1088236) #2 save trigger height: 100% for device: KZ_1_F1
                          2023-04-27 05:39:59.693 - debug: shuttercontrol.0 (1088236) outsidetemperature changed: 0_userdata.0.Wetter_Klima.var_weather_temperature_sun_gleitend Value: -5.8
                          2023-04-27 05:40:00.003 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                          2023-04-27 05:40:00.004 - debug: shuttercontrol.0 (1088236) Sun Azimut: 64.5°
                          2023-04-27 05:40:00.004 - debug: shuttercontrol.0 (1088236) Sun Elevation: -2.5°
                          2023-04-27 05:45:00.003 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                          2023-04-27 05:45:00.004 - debug: shuttercontrol.0 (1088236) Sun Azimut: 65.5°
                          2023-04-27 05:45:00.004 - debug: shuttercontrol.0 (1088236) Sun Elevation: -1.8°
                          2023-04-27 05:47:51.537 - debug: shuttercontrol.0 (1088236) TriggerID changed: hm-rpc.0.0007DF29950C05.1.STATE Value: 0
                          2023-04-27 05:47:51.538 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter conversion is:false
                          2023-04-27 05:47:51.580 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter current state.val is:100
                          2023-04-27 05:47:51.580 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter current Height is:100
                          2023-04-27 05:47:51.580 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter trigger Height is:20
                          2023-04-27 05:47:51.580 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter trigger Action is:none
                          2023-04-27 05:47:51.581 - debug: shuttercontrol.0 (1088236) KZ_2_F1 - shutter trigger Change is:upDown
                          2023-04-27 05:47:51.623 - info: shuttercontrol.0 (1088236) Window is still closed -> drive to last height: Set ID: KZ_2_F1 value: 20%
                          2023-04-27 05:47:51.670 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check started
                          2023-04-27 05:47:51.681 - debug: shuttercontrol.0 (1088236) #0 wait for shutter check end
                          2023-04-27 05:47:51.681 - debug: shuttercontrol.0 (1088236) Shutter state changed: KZ_2_F1 old value = 100 new value = 20
                          2023-04-27 05:47:51.681 - debug: shuttercontrol.0 (1088236) KZ_2_F1 Old value = 100. New value = 20. automatic is active
                          2023-04-27 05:47:51.730 - debug: shuttercontrol.0 (1088236) save back trigger action: none for device: KZ_2_F1
                          2023-04-27 05:50:00.005 - debug: shuttercontrol.0 (1088236) calculate astrodata ...
                            "_id": "system.adapter.shuttercontrol.0",
                            "common": {
                              "name": "shuttercontrol",
                              "version": "1.4.29",
                              "title": "shuttercontrol",
                              "authors": [
                                "simatec <shuttercontrol@simateccloud.de>"
                              "keywords": [
                                "ioBroker",
                                "Smart Home",
                                "home automation",
                                "Rollladen",
                                "Jalousie",
                                "Rollladensteuerung"
                              "license": "MIT",
                              "platform": "Javascript/Node.js",
                              "main": "main.js",
                              "icon": "shuttercontrol.png",
                              "enabled": true,
                              "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
                              "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
                              "loglevel": "debug",
                              "mode": "daemon",
                              "type": "climate-control",
                              "compact": true,
                              "materialize": true,
                              "connectionType": "local",
                              "dataSource": "push",
                              "stopBeforeUpdate": true,
                              "adminUI": {
                                "config": "materialize"
                              "plugins": {
                                "sentry": {
                                  "dsn": "https://5f58df7167d846e3a90bae5414d4fc09@sentry.iobroker.net/62"
                              "installedFrom": "iobroker.shuttercontrol@1.4.29",
                              "installedVersion": "1.4.29",
                              "host": "iobroker"
                            "native": {
                              "livingAutomatic": "livingSunriseSunset",
                              "W_shutterDownLiving": "22:00",
                              "W_shutterUpLivingMin": "05:00",
                              "W_shutterUpLivingMax": "06:00",
                              "driveDelayUpLiving": "1",
                              "WE_shutterDownLiving": "22:00",
                              "WE_shutterUpLivingMin": "07:00",
                              "WE_shutterUpLivingMax": "07:30",
                              "sleepAutomatic": "sleepSunriseSunset",
                              "W_shutterDownSleep": "21:30",
                              "W_shutterUpSleepMin": "06:00",
                              "W_shutterUpSleepMax": "07:00",
                              "driveDelayUpSleep": "0",
                              "WE_shutterDownSleep": "22:00",
                              "WE_shutterUpSleepMin": "07:00",
                              "WE_shutterUpSleepMax": "07:30",
                              "childrenAutomatic": "childrenSunriseSunset",
                              "W_shutterDownChildren": "19:30",
                              "W_shutterUpChildrenMin": "05:30",
                              "W_shutterUpChildrenMax": "06:00",
                              "driveDelayUpChildren": "1",
                              "WE_shutterDownChildren": "20:00",
                              "WE_shutterUpChildrenMin": "08:00",
                              "WE_shutterUpChildrenMax": "08:00",
                              "latitude": "xx.xxxxxxxx",
                              "longitude": "xx.xxxxxxxx",
                              "sunProtEndElevation": "15",
                              "astroDelayUp": "-20",
                              "astroDelayDown": "23",
                              "driveDelayUpAstro": "0",
                              "SummerStart": "01.03.",
                              "SummerEnd": "30.09.",
                              "XMasStart": "01.12.",
                              "XMasEnd": "06.01.",
                              "publicHolidays": true,
                              "publicHolInstance": "feiertage.0",
                              "HolidayDP": "ical.0.events.0.today.Urlaub",
                              "lightsensorDown": "400",
                              "lightsensorUp": "500",
                              "lightsensorUpTime": "06:00",
                              "lightsensorDownTime": "17:30",
                              "lightsensorUpDown": "",
                              "schoolfree": true,
                              "schoolfreeInstance": "schoolfree.0",
                              "schoolfreeDP": "",
                              "schoolfreeChildrenArea": true,
                              "schoolfreeSleepArea": false,
                              "schoolfreeLivingArea": false,
                              "LateAllDown": false,
                              "LateAllDownTime": "22:15",
                              "betweenPositionTime": "22:00",
                              "noGoTime": "0",
                              "currentShutterState": false,
                              "currentShutterStateTime": "30",
                              "triggerAutoSleep": "",
                              "triggerAutoLiving": "",
                              "triggerAutoChildren": "",
                              "alarmWind1Level": "100",
                              "alarmWind1": "",
                              "alarmWind2Level": "100",
                              "alarmWind2": "",
                              "alarmRainLevel": "100",
                              "alarmRain": "",
                              "alarmFrostLevel": "20",
                              "alarmFrost": "0_userdata.0.Wetter_Klima.var_weather_frost",
                              "alarmFireLevel": "100",
                              "alarmFire": "",
                              "events": [
                                  "enabled": true,
                                  "shutterName": "Kueche_F1_Rollo",
                                  "name": "0_userdata.0.Rollladen.Kueche_F1",
                                  "triggerID": "",
                                  "typeUp": "living",
                                  "typeDown": "living",
                                  "type": "outside temperature and direction",
                                  "heightDownSun": "30",
                                  "direction": "110",
                                  "directionRange": "50",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "outsideTempSensor": "0_userdata.0.Wetter_Klima.var_weather_temperature_sun_gleitend",
                                  "tempOutside": "37",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerState": "none",
                                  "triggerStateTilted": "none",
                                  "triggerDrive": "100",
                                  "triggerDriveTildet": "20",
                                  "triggerChange": "off",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "hysteresisOutside": "15",
                                  "hysteresisInside": "5",
                                  "hysteresisLight": "5",
                                  "currentAction": "",
                                  "currentHeight": "",
                                  "oldHeight": "",
                                  "firstCompleteUp": "",
                                  "triggerHeight": "",
                                  "LateDown": false,
                                  "inSummerNotDown": false,
                                  "KeepSunProtect": true,
                                  "triggerAction": "",
                                  "driveAfterClose": true,
                                  "useXmasLevel": false,
                                  "XmasLevel": "",
                                  "betweenPosition": false,
                                  "betweenPositionLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "sunProtectEndDely": "2",
                                  "sunProtectEndtimerid": "",
                                  "enableAlarmWind1": false,
                                  "enableAlarmWind2": false,
                                  "enableAlarmRain": false,
                                  "enableAlarmFrost": true,
                                  "enableAlarmFire": false,
                                  "alarmTriggerAction": "",
                                  "alarmTriggerLevel": "",
                                  "lastAutoAction": ""
                                  "enabled": true,
                                  "shutterName": "Kueche_F2_Rollo",
                                  "name": "0_userdata.0.Rollladen.Kueche_F2",
                                  "triggerID": "",
                                  "typeUp": "living",
                                  "direction": "200",
                                  "directionRange": "75",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerState": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "sunProtectEndDely": "5",
                                  "enabled": true,
                                  "shutterName": "WZ_F1_Rollo",
                                  "name": "0_userdata.0.Rollladen.WZ_F1",
                                  "triggerID": "0_userdata.0.Rollladen.Dummy_Fensterkontakt",
                                  "typeUp": "living",
                                  "direction": "200",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "enabled": true,
                                  "shutterName": "WZ_F2_Rollo",
                                  "name": "0_userdata.0.Rollladen.WZ_F2",
                                  "triggerID": "",
                                  "typeUp": "living",
                                  "heightDownSun": "15",
                                  "direction": "290",
                                  "directionRange": "90",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "driveAfterClose": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "enabled": true,
                                  "shutterName": "WZ_F3_Rollo",
                                  "name": "0_userdata.0.Rollladen.WZ_F3",
                                  "triggerID": "",
                                  "typeUp": "living",
                                  "heightDownSun": "25",
                                  "direction": "245",
                                  "directionRange": "55",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerDriveTildet": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "enabled": true,
                                  "shutterName": "WZ_F4_Rollo",
                                  "name": "0_userdata.0.Rollladen.WZ_F4",
                                  "triggerID": "",
                                  "typeUp": "living",
                                  "type": "off",
                                  "heightDownSun": "20",
                                  "direction": "290",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "KeepSunProtect": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "sunProtectEndDely": "0",
                                  "enabled": true,
                                  "shutterName": "WZ_F5_Rollo",
                                  "name": "0_userdata.0.Rollladen.WZ_F5",
                                  "triggerID": "",
                                  "typeUp": "living",
                                  "heightDownSun": "35",
                                  "direction": "335",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "enabled": true,
                                  "shutterName": "WZ_F6_Rollo",
                                  "name": "0_userdata.0.Rollladen.WZ_F6",
                                  "triggerID": "",
                                  "typeUp": "living",
                                  "direction": "290",
                                  "directionRange": "70",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "enabled": true,
                                  "shutterName": "Bad_EG_F1_Rollo",
                                  "name": "0_userdata.0.Rollladen.Bad_EG_F1",
                                  "triggerID": "",
                                  "typeUp": "living",
                                  "heightDownSun": "40",
                                  "direction": "20",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "enabled": true,
                                  "shutterName": "HWR_F1_Rollo",
                                  "name": "0_userdata.0.Rollladen.HWR_F1",
                                  "triggerID": "hm-rpc.0.00109D898C3CC9.1.STATE",
                                  "typeUp": "living",
                                  "direction": "20",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerChange": "upDown",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "enabled": true,
                                  "shutterName": "KZ_1_F1",
                                  "name": "0_userdata.0.Rollladen.OG_1_F1",
                                  "triggerID": "hm-rpc.0.0007DF299508E8.1.STATE",
                                  "typeUp": "children",
                                  "typeDown": "children",
                                  "direction": "200",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "tempOutside": "33",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "triggerStateTilted": "1",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "",
                                  "betweenPositionLevel": "50",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "enabled": true,
                                  "shutterName": "Buero_F1",
                                  "name": "0_userdata.0.Rollladen.OG_2_F1",
                                  "triggerID": "hm-rpc.0.0007DF29950946.1.STATE",
                                  "direction": "200",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "0",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "enabled": true,
                                  "shutterName": "Buero_F2",
                                  "name": "0_userdata.0.Rollladen.OG_2_F2",
                                  "triggerID": "hm-rpc.0.0007DF29950BFB.1.STATE",
                                  "direction": "290",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "tempOutside": "36",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "50",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "enableAlarmFrost": false,
                                  "enabled": true,
                                  "shutterName": "KZ_2_F1",
                                  "name": "0_userdata.0.Rollladen.OG_3_F1",
                                  "triggerID": "hm-rpc.0.0007DF29950C05.1.STATE",
                                  "direction": "290",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                                  "enabled": true,
                                  "shutterName": "KZ_2_F2",
                                  "name": "0_userdata.0.Rollladen.OG_3_F2",
                                  "triggerID": "hm-rpc.0.0007DF29950C91.1.STATE",
                                  "direction": "20",
                                  "tempInside": "23",
                                  "tempSensor": "",
                                  "tempOutside": "40",
                                  "lightSensor": "",
                                  "valueLight": "15",
                                  "heightUp": "100",
                                  "heightDown": "0",
                                  "elevation": "8",
                                  "autoDrive": "off",
                                  "oldHeight": "",
                                  "LateDown": false,
                                  "XmasLevel": "",
                                  "trigDelyUp": "",
                                  "trigDelyDown": "",
                            @simatec
                            ich habe bis vor kurzem meine Rolladen direkt über shelly gesteuert. Jedoch habe ich letztes Wochenende, aufgrund mehr Funktionsumfang wie Frostschutz etc., auf deinen Adapter in 23er Version umgestellt.
                            Ich habe den Frostschutz bei diversen Rolladen aktiviert, wo es bei mir im Winter schonmal zerrissene Panzer gegeben hat, da der interne Motorschutz der Rollade nicht sensibel genug war.
                            Genau bei diesen Rolladen hatte ich nach der ersten Nacht diverse Fehlermeldungen, dass ein falscher Wert geschrieben wurde. Siehe Post
                            Nachdem ich den Debug-Modus aktiviert und wieder auf Info umgestellt habe, waren komischerweise die Fehlermeldungen nicht mehr aufgekommen.
                            Jedoch hatte ich folgende Auffälligkeiten an den Fenstern mit eingestelltem aber nicht aktivem Frostschutz:
                            Mittags habe ich die Rollade bei meinem Sohn manuell für seinen Mittagsschlaf runtergefahren. Kurz darauf (ca. 1-2min) fuhr die Rollade grundlos wieder auf 100% (offen). An der Rollade ist kein Sonnenschutz etc. eingestellt. Diesen Fehlerfall konnte ich an allen Rolladen mit eingestelltem, aber derzeit nich aktiven Frostschutz, nachstellen. Habe ich den Haken für Frostschutz entfernt, blieben die Rolladen unten.
                            Der Frostschutz ist so eingestellt, dass bei aktivem Frostschutz der Rolladen auf 0% stehen bleiben soll.
                            Weiterhin habe ich getestet ob der Rolladenfrostschutz funktioniert, indem ich den Schwellwert hoch gesetzt habe. Also auch bei +10° hatte ich den Frostschutz dann auf "wahr" stehen. Eigentlich hatte ich erwartet, dass der Rolladen dann morgens nicht öffnet und stattdessen bei 0% stehen bleibt, jedoch hat die Rollade wie auch sonst ohne Frostschutz normal im Automatik geöffnet. Ansonsten habe ich keine extra Alarme eingestellt.
                            Ist der Fehler bekannt? Habe ich ggf. einen Denkfehler und hier etwas falsch eingestellt?
                              steimi @erazor86 last edited by
                              @erazor86 mit Frostschutz gab es in den letzten Betas noch Fehlerbeseitigungen. Vlt mal auf die aktuelle Beta 1.4..29 wechseln und probieren.
                              • David Kurtze
                                David Kurtze last edited by
                                Ich habe eine Frage zur Steuerung der Rolläden zwecks Verschattung, ohne diese aber nachts zu schließen. Das soll manuell geschehen.
                                Ich habe ein Kinderzimmer, da möchte ich, dass Shuttercontrol nur verschattet nach Helligkeit und Himmelsrichtung, aber dass kein Schließen und Öffnen nach Uhrzeit/Sonnenuntergang usw. stattfindet.
                                Ich habe bei diesen Rolläden unter "Art der Steuerung für schließen/öffnen des Rollladens" "Aus" oder auch "nur manueller Betrieb" gewählt, dann fahren die aber gar nicht.
                                Hat irgendwer eine Idee, wie ich das abbilden kann?
                                David Kurtze 1 Reply Last reply Reply Quote 0
                                  erazor86 @steimi last edited by
                                  @steimi hab seit gestern dann auch die 29er drauf. Hier ist kein Unterschied feststellbar, die Rolladen wo der Haken bei Frostalarm gesetzt ist und morgens auch der Frostalarm auf "wahr" steht, öffnen trotzdem auf 100%. Wenn ich die Funktion richtig verstanden habe, sollten diese Rolladen doch bei 0% stehen bleiben oder?
                                  • simatec
                                    simatec Developer Most Active @erazor86 last edited by
                                    @erazor86 Lies bitte die Doku.
                                    https://github.com/simatec/ioBroker.shuttercontrol/blob/master/docs/de/shuttercontrol.md#alarm-einstelljungen
                                      erazor86 @simatec last edited by
                                      @simatec danke für den link. Die Doku dazu habe ich bereits mehrfach gelesen und soweit auch verstanden. (hoffe es zumindest richtig verstanden zu haben 😅)
                                      Da ich sonst keine Alarme aktiviert habe die einen Einfluss haben könnten, müsste für mein Verständnis der Rolladen auf 0% geschlossen bleiben bei aktivem Frostschutz oder der liege ich hier falsch?
                                      • simatec
                                        @erazor86 Wenn du den Frostschutz aktiviert hast und es zu Frost kommt, fährt der Rollladen auf die eingestellte Frosthöhe, damit er nicht am Fensterbrett anfriert.
                                          @simatec achso jetzt verstehe ich wie das gedacht ist.. Quasi das beim schließvorgang nicht vollständig geschlossen wird? Ich hatte es so verstanden, dass die Rolladen dann erst garnicht öffnen und quasi bei 0 stehen bleiben (wenn man 0 einstellt).
                                          Schade denn das mit dem nicht komplett schließen habe ich in der vergangenheit schon öfter manuell probiert. Leider frieren die Rolladen dann aber trotzdem noch in sich fest. Daher wäre eine "du darfst jetzt nicht öffnen" Funktion für mich sinnvoller.
                                            somansch @erazor86 last edited by
                                            @simatec
                                            da ja heute Feiertag ist, hätte mein Schlafzimmerrollo um 10Uhr hochgehen sollen (wie Wochenende, richtig?). Folgende Einstellungen habe ich:
                                            Unter Info sehe ich 10:00, jedoch ging das Rollo 9:00 hoch. Habe ich etwas falsch eingestellt oder ist dies ein Bug? Ein Debug habe ich nicht, dazu müsste ich auf den nächsten Feiertag warten 😕
                                            332
                                            7408
                                            10588770
