    3. Einsteigerfragen
    4. Installation
    5. IOBroker backup auf neue Rasperry übertragen
      Homoran Global Moderator Administrators @Metzid last edited by
      @metzid sagte in IOBroker backup auf neue Rasperry übertragen:
      liege ich da falsch
      ja!
      nodejs ist die Laufzeitumgebung auf die ioBroker aufgesetzt ist.
        Metzid @Homoran last edited by Homoran
        @homoran Hallo
        ich habe nochmals mit dem Fix probiert wie beim Backup sagt er es ist alles secessfull
        pi@piiobroker:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
        library: loaded
        Library version=2022-12-09
            Welcome to the ioBroker installation fixer!
            Script version: 2023-04-02
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
        Fetched 44.1 kB in 3s (16.2 kB/s)
        Reading package lists... Done
        Installed gcc-c++
            Checking ioBroker user and directory permissions (2/5)
        Created /etc/sudoers.d/iobroker
        Fixing directory permissions...
            Check and cleanup npm temporary directories (3/5)
        Done.
            Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        Compressing /opt/iobroker/iobroker-data/states.jsonl
        Cannot compress states.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
            at JsonlDB.open (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@alcalzone/jsonl-db/build/lib/db.js:185:19)
            at async compressDB (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:37:9)
            at async main (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:78:17)
        Compressing /opt/iobroker/iobroker-data/objects.jsonl
        Cannot compress objects.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
            at async main (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:93:17)
        No relevant JSONL files found to compress, skip
            Checking autostart (5/5)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        pi@piiobroker:~ $ cd /opt/iobroker
        pi@piiobroker:/opt/iobroker $ iobroker start
        pi@piiobroker:/opt/iobroker $ ps -A | grep iobroke
            515 ?        00:02:05 iobroker.js-con
        Auch wenn ich den controller abfrage kommt ein ergebnis zurück, wie kann ich die Versionen von iobroker auf putty abfragen
          ich denke er startet nicht wegen deiner Datenbank, jsonl gab es früher noch nicht, denke da musst du umstellen auf file/file
            Metzid @crunchip last edited by
            @crunchip hallo denke da musst du umstellen auf file/file. Wie kann ich das umstellen. Ist das auf der alten oder neuen Maschine
              crunchip Forum Testing Most Active @Metzid last edited by
              @metzid auf deiner neuen Installation
              iobroker stop
              iobroker setup custom
              Aber ist aus meiner Sicht nur eine Vermutung das es daran liegt.
                @homoran danke für die Info. Leider habe ich das alte Betriebsystem bereits versucht upzudaten und danach den iobroker. Aber dann musste ich wieder das alte Image zurückspielen iobroker hat sich auf dem alten System danach micht starten lassen.
                  @crunchip pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
                  Current configuration:
                  • Objects database:
                    • Type: jsonl
                    • Host/Unix Socket: 127.0.0.1
                    • Port: 9001
                  • States database:
                    • Type: jsonl
                    • Port: 9000
                  • Data Directory: ../../iobroker-data/
                  Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f
                  Host / Unix Socket of objects DB(file), default[127.0.0.1]: f
                  Port of objects DB(file), default[9001]: f
                  Input another, please.
                  Das schreibt er gerade was soll ich da einstellen was ist imput another please
                  Thomas Braun M crunchip 3 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @Metzid last edited by
                    sudo iobroker
                    iobroker NIE in Verbindung mit sudo verwenden.
                    Fixen:
                    iob stop
                    iob fix
                    iob start
                      Metzid @Metzid last edited by
                      @metzid pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
                      • Objects database:
                        • Type: jsonl
                        • Port: 9001
                      • States database:
                        • Type: jsonl
                        • Port: 9000
                      Port of objects DB(file), default[9001]: 9001
                      Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f
                      Host / Unix Socket of states DB (file), default[f]: f
                      Port of states DB (file), default[9000]: 9000
                      Host name of this machine [piiobroker]: piiobroker
                      Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m
                      Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y
                      Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
                      Connecting to previous DB "jsonl"...
                      Creating backup ...
                      This can take some time ... please be patient!
                      host.piiobroker 1626 states saved
                      host.piiobroker 2188 objects saved
                      Backup created: /opt/iobroker/backups/2023_04_26-22_20_28_backupiobroker-migration.tar.gz
                      updating conf/iobroker.json
                      Connecting to new DB "file" (can take up to 20s) ...
                      Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
                      Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup!
                      Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
                      Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
                      Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
                      No connection to databases possible ...
                      New Database could not be connected. Please check your settings. No settings have been changed.
                      restoring conf/iobroker.json
                        @metzid
                        Nochmal...
                        iobroker wird nie mit sudo eingeleitet.
                        Fix das!
                          Metzid @Thomas Braun last edited by Homoran
                          pi@piiobroker:/opt/iobroker $ iob fix
                          library: loaded
                          Installed gcc-c++
                          Done.
                          Compressed 2 JSONL files. Done
                          Autostart enabled!
                          pi@piiobroker:/opt/iobroker $ iob start
                          leider über browser nicht erreichbar
                            @thomas-braun aber Fehler hat er beim fix nicht gebracht
                              @metzid wie schon geschrieben, ohne sudo
                              Du hast da ein f zu viel gedrückt, bei port einfach enter drücken, damit default übernommen wird
                                iob list instances
                                  Der Fixer gibt auch keine Fehlerdiagnose aus, der fixt es einfach.
                                    Metzid @crunchip last edited by Homoran
                                    @crunchip
                                    pi@piiobroker:/opt/iobroker $ iobroker setup custom
                                    - Objects database:
                                      - Type: jsonl
                                      - Host/Unix Socket: 127.0.0.1
                                      - Port: 9001
                                    - States database:
                                      - Type: jsonl
                                      - Port: 9000
                                    - Data Directory: ../../iobroker-data/
                                    Creating backup ...
                                    Backup created: /opt/iobroker/backups/2023_04_26-22_38_38_backupiobroker-migration.tar.gz
                                      @crunchip
                                      pi@piiobroker:/opt/iobroker $ iob list instances
                                        system.adapter.admin.0                  : admin                 : piiobroker                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        system.adapter.broadlink2.0             : broadlink2            : piiobroker                               - disabled
                                        system.adapter.hm-rega.0                : hm-rega               : piiobroker                               - disabled
                                        system.adapter.hm-rpc.0                 : hm-rpc                : piiobroker                               - disabled, port: 0
                                        system.adapter.iot.0                    : iot                   : piiobroker                               - disabled
                                        system.adapter.javascript.0             : javascript            : piiobroker                               - disabled
                                        system.adapter.scenes.0                 : scenes                : piiobroker                               - disabled
                                        system.adapter.web.0                    : web                   : piiobroker                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                        Creating backup ...
                                        Also müsste ja eigentlich eine jeweilige jsonl vorhanden sein, aber wohl nur als backup
                                          @metzid da läuft kein admin, soweit man hier sehen kann
                                            @crunchip wie kann ich den admin
                                            starten
                                            3359
