IOBroker backup auf neue Rasperry übertragen
@homoran danke für die Info. Leider habe ich das alte Betriebsystem bereits versucht upzudaten und danach den iobroker. Aber dann musste ich wieder das alte Image zurückspielen iobroker hat sich auf dem alten System danach micht starten lassen.
@crunchip pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
Current configuration:- Objects database:
- Type: jsonl
- Host/Unix Socket: 127.0.0.1
- Port: 9001
- States database:
- Type: jsonl
- Port: 9000
- Data Directory: ../../iobroker-data/
Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f
Host / Unix Socket of objects DB(file), default[127.0.0.1]: f
Port of objects DB(file), default[9001]: f
Input another, please.
Port of objects DB(file), default[9001]:Das schreibt er gerade was soll ich da einstellen was ist imput another please
- Objects database:
@metzid sagte in IOBroker backup auf neue Rasperry übertragen:
sudo iobroker
iobroker NIE in Verbindung mit sudo verwenden.
Fixen:
iob stop iob fix iob start -
@metzid pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
- Type: jsonl
- Port: 9001
- States database:
- Type: jsonl
- Port: 9000
Port of objects DB(file), default[9001]: 9001
Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f
Host / Unix Socket of states DB (file), default[f]: f
Port of states DB (file), default[9000]: 9000
Host name of this machine [piiobroker]: piiobroker
Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: mDo you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y
Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
Connecting to previous DB "jsonl"...
Creating backup ...
This can take some time ... please be patient!
host.piiobroker 1626 states saved
host.piiobroker 2188 objects saved
Backup created: /opt/iobroker/backups/2023_04_26-22_20_28_backupiobroker-migration.tar.gz
updating conf/iobroker.jsonConnecting to new DB "file" (can take up to 20s) ...
Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup!
Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
No connection to databases possible ...New Database could not be connected. Please check your settings. No settings have been changed.
restoring conf/iobroker.json
pi@piiobroker:/opt/iobroker $ - Objects database:
pi@piiobroker:/opt/iobroker $ iob fix library: loaded Library version=2022-12-09 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2023-04-02 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/5) ========================================================================== Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://deb.debian.org/debian bullseye InRelease Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB] Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease Reading package lists... Done Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/5) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Check and cleanup npm temporary directories (3/5) ========================================================================== Done. ========================================================================== Database maintenance (4/5) ========================================================================== Checking for uncompressed JSONL databases... This might take a while! Compressing /opt/iobroker/iobroker-data/states.jsonl Compressing /opt/iobroker/iobroker-data/objects.jsonl Compressed 2 JSONL files. Done ========================================================================== Checking autostart (5/5) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== pi@piiobroker:/opt/iobroker $ iob startMOD-EDIT: Code in code-tags gesetzt!
leider über browser nicht erreichbar
@thomas-braun aber Fehler hat er beim fix nicht gebracht
@metzid wie schon geschrieben, ohne sudo
Du hast da ein f zu viel gedrückt, bei port einfach enter drücken, damit default übernommen wird -
iob list instances -
Der Fixer gibt auch keine Fehlerdiagnose aus, der fixt es einfach.
pi@piiobroker:/opt/iobroker $ iobroker setup custom Current configuration: - Objects database: - Type: jsonl - Host/Unix Socket: 127.0.0.1 - Port: 9001 - States database: - Type: jsonl - Host/Unix Socket: 127.0.0.1 - Port: 9000 - Data Directory: ../../iobroker-data/ Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f Host / Unix Socket of objects DB(file), default[127.0.0.1]: f Port of objects DB(file), default[9001]: Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f Host / Unix Socket of states DB (file), default[f]: f Port of states DB (file), default[9000]: Host name of this machine [piiobroker]: piiobroker Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y Connecting to previous DB "jsonl"... Creating backup ... This can take some time ... please be patient! host.piiobroker 1626 states saved host.piiobroker 2188 objects saved Backup created: /opt/iobroker/backups/2023_04_26-22_38_38_backupiobroker-migration.tar.gz updating conf/iobroker.json Connecting to new DB "file" (can take up to 20s) ... Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup! Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset! Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects No connection to databases possible ... New Database could not be connected. Please check your settings. No settings have been changed. restoring conf/iobroker.json pi@piiobroker:/opt/iobroker $ iob startMOD-EDIT: Code in code-tags gesetzt!
pi@piiobroker:/opt/iobroker $ iob list instances system.adapter.admin.0 : admin : piiobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.broadlink2.0 : broadlink2 : piiobroker - disabled system.adapter.hm-rega.0 : hm-rega : piiobroker - disabled system.adapter.hm-rpc.0 : hm-rpc : piiobroker - disabled, port: 0 system.adapter.iot.0 : iot : piiobroker - disabled system.adapter.javascript.0 : javascript : piiobroker - disabled system.adapter.scenes.0 : scenes : piiobroker - disabled system.adapter.web.0 : web : piiobroker - disabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is alive pi@piiobroker:/opt/iobroker $MOD-EDIT: Code in code-tags gesetzt!
Creating backup ...
updating conf/iobroker.jsonAlso müsste ja eigentlich eine jeweilige jsonl vorhanden sein, aber wohl nur als backup
@metzid da läuft kein admin, soweit man hier sehen kann
@crunchip wie kann ich den admin
starten -
@metzid
iob start admin -
pi@piiobroker:/opt/iobroker $ iob start admin pi@piiobroker:/opt/iobroker $ iob list instances system.adapter.admin.0 : admin : piiobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.broadlink2.0 : broadlink2 : piiobroker - disabled system.adapter.hm-rega.0 : hm-rega : piiobroker - disabled system.adapter.hm-rpc.0 : hm-rpc : piiobroker - disabled, port: 0 system.adapter.iot.0 : iot : piiobroker - disabled system.adapter.javascript.0 : javascript : piiobroker - disabled system.adapter.scenes.0 : scenes : piiobroker - disabled system.adapter.web.0 : web : piiobroker - disabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is alive pi@piiobroker:/opt/iobroker $MOD-EDIT: Code in code-tags gesetzt!
Leider über Browser nicht erreichbar
@crunchip Hallo guten Morgen. Ich habe mir heute Nacht nochmals überlegt ob es Sinn macht das Image des neuen Raspberry mit neiem OS und iobroker nochmals einzuspielen dann die datenbank auf file/file umzustellen und dann ein restore des iobrokers zu fahren. Dann dürfte doch zumindest die datenbbank auf dem Level des restores dein. Oder mache ich da einen Denkfehler.
Noch eine kurze Frage wenn so ein Restore gefahren wird werden dann die ganzen Module /Datenbanken auf dem raspberry auf die Versionsnummer des Altgerätes zurückgestellt. Oder gibt es eine versionsabhängigkeit wo dann nur der Inhalt der verschiedenen Datenbank und Module zurückgespielt wird so dass keine Instalation auf die alten Level erfolgt also rein Daten eingespielt werden. Sollte man da schon die ganzen Adapter die auch im alten Backup hinterlegt sind schon in der neuen Version installieren so dass das System nur noch Daten zurück spielt und keine Adapter auf alte Versionen zurücksetzt. Oder gibt es da eine versionsabhängigkeit ab wann das iobroker Backup nur Daten oder auch Versionen zurückspielt.
nein, um ein backup zurückzuspielen, müssen keine Adapter im Vorfeld installiert werden, das beinhaltet alles das backup. Einzige Ausnahme aufgrund eines bugs, muss vis (falls genutzt wird) vor dem backup installiert werden.
kannst du versuchen
@crunchipnein habe kein vis
versuche es jetzt gleich
