    3. Einsteigerfragen
    4. Installation
    5. IOBroker backup auf neue Rasperry übertragen
      Metzid @crunchip last edited by
      @crunchip pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
      Current configuration:
      • Objects database:
        • Type: jsonl
        • Host/Unix Socket: 127.0.0.1
        • Port: 9001
      • States database:
        • Type: jsonl
        • Port: 9000
      • Data Directory: ../../iobroker-data/
      Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f
      Host / Unix Socket of objects DB(file), default[127.0.0.1]: f
      Port of objects DB(file), default[9001]: f
      Input another, please.
      Das schreibt er gerade was soll ich da einstellen was ist imput another please
      Thomas Braun M crunchip 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Metzid last edited by
        @metzid sagte in IOBroker backup auf neue Rasperry übertragen:
        sudo iobroker
        iobroker NIE in Verbindung mit sudo verwenden.
        Fixen:
        iob stop
        iob fix
        iob start
          Metzid @Metzid last edited by
          @metzid pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
          • Objects database:
            • Type: jsonl
            • Port: 9001
          • States database:
            • Type: jsonl
            • Port: 9000
          Port of objects DB(file), default[9001]: 9001
          Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f
          Host / Unix Socket of states DB (file), default[f]: f
          Port of states DB (file), default[9000]: 9000
          Host name of this machine [piiobroker]: piiobroker
          Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m
          Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y
          Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
          Connecting to previous DB "jsonl"...
          Creating backup ...
          This can take some time ... please be patient!
          host.piiobroker 1626 states saved
          host.piiobroker 2188 objects saved
          Backup created: /opt/iobroker/backups/2023_04_26-22_20_28_backupiobroker-migration.tar.gz
          updating conf/iobroker.json
          Connecting to new DB "file" (can take up to 20s) ...
          Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
          Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup!
          Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
          Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
          Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
          No connection to databases possible ...
          New Database could not be connected. Please check your settings. No settings have been changed.
          restoring conf/iobroker.json
            @metzid
            Nochmal...
            iobroker wird nie mit sudo eingeleitet.
            Fix das!
              Metzid @Thomas Braun last edited by Homoran
              pi@piiobroker:/opt/iobroker $ iob fix
              library: loaded
              Library version=2022-12-09
                  Welcome to the ioBroker installation fixer!
                  Script version: 2023-04-02
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/5)
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
              Reading package lists... Done
              Installed gcc-c++
                  Checking ioBroker user and directory permissions (2/5)
              Created /etc/sudoers.d/iobroker
              Fixing directory permissions...
                  Check and cleanup npm temporary directories (3/5)
              Done.
                  Database maintenance (4/5)
              Checking for uncompressed JSONL databases... This might take a while!
              Compressing /opt/iobroker/iobroker-data/states.jsonl
              Compressing /opt/iobroker/iobroker-data/objects.jsonl
              Compressed 2 JSONL files. Done
                  Checking autostart (5/5)
              Enabling autostart...
              Autostart enabled!
                  Your installation was fixed successfully
                  Run iobroker start to start ioBroker again!
              pi@piiobroker:/opt/iobroker $ iob start
              leider über browser nicht erreichbar
                @thomas-braun aber Fehler hat er beim fix nicht gebracht
                  crunchip Forum Testing Most Active @Metzid last edited by
                  @metzid wie schon geschrieben, ohne sudo
                  Du hast da ein f zu viel gedrückt, bei port einfach enter drücken, damit default übernommen wird
                    iob list instances
                      Der Fixer gibt auch keine Fehlerdiagnose aus, der fixt es einfach.
                        Metzid @crunchip last edited by Homoran
                        @crunchip
                        pi@piiobroker:/opt/iobroker $ iobroker setup custom
                        - Objects database:
                          - Type: jsonl
                          - Host/Unix Socket: 127.0.0.1
                          - Port: 9001
                        - States database:
                          - Type: jsonl
                          - Port: 9000
                        - Data Directory: ../../iobroker-data/
                        Creating backup ...
                        Backup created: /opt/iobroker/backups/2023_04_26-22_38_38_backupiobroker-migration.tar.gz
                          @crunchip
                          pi@piiobroker:/opt/iobroker $ iob list instances
                            system.adapter.admin.0                  : admin                 : piiobroker                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            system.adapter.broadlink2.0             : broadlink2            : piiobroker                               - disabled
                            system.adapter.hm-rega.0                : hm-rega               : piiobroker                               - disabled
                            system.adapter.hm-rpc.0                 : hm-rpc                : piiobroker                               - disabled, port: 0
                            system.adapter.iot.0                    : iot                   : piiobroker                               - disabled
                            system.adapter.javascript.0             : javascript            : piiobroker                               - disabled
                            system.adapter.scenes.0                 : scenes                : piiobroker                               - disabled
                            system.adapter.web.0                    : web                   : piiobroker                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + instance is alive
                            Creating backup ...
                            Also müsste ja eigentlich eine jeweilige jsonl vorhanden sein, aber wohl nur als backup
                              @metzid da läuft kein admin, soweit man hier sehen kann
                                @crunchip wie kann ich den admin
                                starten
                                  @metzid
                                  iob start admin
                                    @crunchip
                                    pi@piiobroker:/opt/iobroker $ iob start admin
                                    + instance is alive
                                    Leider über Browser nicht erreichbar
                                      @crunchip Hallo guten Morgen. Ich habe mir heute Nacht nochmals überlegt ob es Sinn macht das Image des neuen Raspberry mit neiem OS und iobroker nochmals einzuspielen dann die datenbank auf file/file umzustellen und dann ein restore des iobrokers zu fahren. Dann dürfte doch zumindest die datenbbank auf dem Level des restores dein. Oder mache ich da einen Denkfehler.
                                      Noch eine kurze Frage wenn so ein Restore gefahren wird werden dann die ganzen Module /Datenbanken auf dem raspberry auf die Versionsnummer des Altgerätes zurückgestellt. Oder gibt es eine versionsabhängigkeit wo dann nur der Inhalt der verschiedenen Datenbank und Module zurückgespielt wird so dass keine Instalation auf die alten Level erfolgt also rein Daten eingespielt werden. Sollte man da schon die ganzen Adapter die auch im alten Backup hinterlegt sind schon in der neuen Version installieren so dass das System nur noch Daten zurück spielt und keine Adapter auf alte Versionen zurücksetzt. Oder gibt es da eine versionsabhängigkeit ab wann das iobroker Backup nur Daten oder auch Versionen zurückspielt.
                                        nein, um ein backup zurückzuspielen, müssen keine Adapter im Vorfeld installiert werden, das beinhaltet alles das backup. Einzige Ausnahme aufgrund eines bugs, muss vis (falls genutzt wird) vor dem backup installiert werden.
                                        kannst du versuchen
                                        M 4 Replies Last reply Reply Quote 0
                                          @crunchipnein habe kein vis
                                          versuche es jetzt gleich
                                            @crunchip @crunchip hier der log iobroker ist dann wieder problemlos gestartet
                                            login as: pi
                                            pi@192.168.178.172's password:
                                            Linux piiobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                                            The programs included with the Debian GNU/Linux system are free software;
                                            the exact distribution terms for each program are described in the
                                            individual files in /usr/share/doc/*/copyright.
                                            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                            permitted by applicable law.
                                            Last login: Wed Apr 26 11:31:28 2023
                                            Wi-Fi is currently blocked by rfkill.
                                            Use raspi-config to set the country before use.
                                            pi@piiobroker:~ $ cd /opt/iobroker
                                            pi@piiobroker:/opt/iobroker $ iobroker stop
                                            - Objects database:
                                              - Type: jsonl
                                              - Port: 9001
                                            - States database:
                                              - Type: jsonl
                                              - Port: 9000
                                            Host / Unix Socket of states DB (file), default[127.0.0.1]:
                                            Data directory (file), default[../../iobroker-data/]:
                                            This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
                                            Creating backup ...
                                            host.piiobroker 102 states saved
                                            host.piiobroker 143 objects saved
                                            Backup created: /opt/iobroker/backups/2023_04_27-09_30_42_backupiobroker-migration.tar.gz
                                             Cannot read system.config: null (OK when migrating or restoring)
                                            Restore backup ...
                                            iobroker controller daemon is not running
                                            host.piiobroker OK.
                                            host.piiobroker Clear all objects and states...
                                            clean 2 objects...
                                            clean 2 states...
                                            host.piiobroker done.
                                            host.piiobroker Processed 0/143 objects
                                            143 objects restored.
                                            host.piiobroker Processed 0/102 states
                                            102 states restored.
                                            upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                            upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                                            upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                                            upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                                            upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                                            upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                                            upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                                            upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                                            upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                                            upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                                            upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                                            upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                                            upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                                            upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                            upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                            upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                            upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                            upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                            upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                            upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                            upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                            upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                            upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                            upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                            upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                            upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                            upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                            upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                            upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                            upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                            upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                            upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                            upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                            upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                            upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                            upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                            upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                            upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                            upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                            upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                            upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                            upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                            upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                            upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                            upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                            upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                            upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                            upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                            upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                            upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                            Reinstalling adapter "admin" from "iobroker.admin@6.3.5"
                                            removed 1 package, and changed 4 packages in 45s
                                            45 packages are looking for funding
                                              run `npm fund` for details
                                            Reinstalling adapter "backitup" from "iobroker.backitup@2.6.19"
                                            up to date in 6s
                                            Could not migrate objects to corresponding sets: Cannot read properties of undefined (reading 'getObjectList')
                                            Backup restored - Migration successful
                                            Important: If your system consists of multiple hosts please execute
                                            "iobroker upload all" on the master AFTER all other hosts/slaves have
                                            also been updated to this states/objects database configuration AND are
                                            running!
                                            MOD-EDIT: Code in code-tags gesetzt
                                            1.2k
                                            3527
