    3. Einsteigerfragen
    4. Installation
    5. IOBroker backup auf neue Rasperry übertragen
      Thomas Braun Most Active @Metzid last edited by
      @metzid sagte in IOBroker backup auf neue Rasperry übertragen:
      sudo iobroker
      iobroker NIE in Verbindung mit sudo verwenden.
      Fixen:
      iob stop
      iob fix
      iob start
        Metzid @Metzid last edited by
        @metzid pi@piiobroker:/opt/iobroker $ sudo iobroker setup custom
        Current configuration:
        • Objects database:
          • Type: jsonl
          • Host/Unix Socket: 127.0.0.1
          • Port: 9001
        • States database:
          • Type: jsonl
          • Port: 9000
        • Data Directory: ../../iobroker-data/
        Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f
        Host / Unix Socket of objects DB(file), default[127.0.0.1]: f
        Port of objects DB(file), default[9001]: f
        Input another, please.
        Port of objects DB(file), default[9001]: 9001
        Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f
        Host / Unix Socket of states DB (file), default[f]: f
        Port of states DB (file), default[9000]: 9000
        Host name of this machine [piiobroker]: piiobroker
        Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m
        Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y
        Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
        Connecting to previous DB "jsonl"...
        Creating backup ...
        This can take some time ... please be patient!
        host.piiobroker 1626 states saved
        host.piiobroker 2188 objects saved
        Backup created: /opt/iobroker/backups/2023_04_26-22_20_28_backupiobroker-migration.tar.gz
        updating conf/iobroker.json
        Connecting to new DB "file" (can take up to 20s) ...
        Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
        Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup!
        Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
        Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
        Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
        No connection to databases possible ...
        New Database could not be connected. Please check your settings. No settings have been changed.
        restoring conf/iobroker.json
          @metzid
          Nochmal...
          iobroker wird nie mit sudo eingeleitet.
          Fix das!
            Metzid @Thomas Braun last edited by Homoran
            pi@piiobroker:/opt/iobroker $ iob fix
            library: loaded
            Library version=2022-12-09
                Welcome to the ioBroker installation fixer!
                Script version: 2023-04-02
                You might need to enter your password a couple of times.
                Installing prerequisites (1/5)
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
            Reading package lists... Done
            Installed gcc-c++
                Checking ioBroker user and directory permissions (2/5)
            Created /etc/sudoers.d/iobroker
            Fixing directory permissions...
                Check and cleanup npm temporary directories (3/5)
            Done.
                Database maintenance (4/5)
            Checking for uncompressed JSONL databases... This might take a while!
            Compressing /opt/iobroker/iobroker-data/states.jsonl
            Compressing /opt/iobroker/iobroker-data/objects.jsonl
            Compressed 2 JSONL files. Done
                Checking autostart (5/5)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            pi@piiobroker:/opt/iobroker $ iob start
            leider über browser nicht erreichbar
              @thomas-braun aber Fehler hat er beim fix nicht gebracht
                crunchip Forum Testing Most Active @Metzid last edited by
                @metzid wie schon geschrieben, ohne sudo
                Du hast da ein f zu viel gedrückt, bei port einfach enter drücken, damit default übernommen wird
                  iob list instances
                    Der Fixer gibt auch keine Fehlerdiagnose aus, der fixt es einfach.
                      Metzid @crunchip last edited by Homoran
                      @crunchip
                      pi@piiobroker:/opt/iobroker $ iobroker setup custom
                      - Objects database:
                        - Type: jsonl
                        - Host/Unix Socket: 127.0.0.1
                        - Port: 9001
                      - States database:
                        - Type: jsonl
                        - Port: 9000
                      - Data Directory: ../../iobroker-data/
                      Creating backup ...
                      Backup created: /opt/iobroker/backups/2023_04_26-22_38_38_backupiobroker-migration.tar.gz
                        @crunchip
                        pi@piiobroker:/opt/iobroker $ iob list instances
                          system.adapter.admin.0                  : admin                 : piiobroker                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.broadlink2.0             : broadlink2            : piiobroker                               - disabled
                          system.adapter.hm-rega.0                : hm-rega               : piiobroker                               - disabled
                          system.adapter.hm-rpc.0                 : hm-rpc                : piiobroker                               - disabled, port: 0
                          system.adapter.iot.0                    : iot                   : piiobroker                               - disabled
                          system.adapter.javascript.0             : javascript            : piiobroker                               - disabled
                          system.adapter.scenes.0                 : scenes                : piiobroker                               - disabled
                          system.adapter.web.0                    : web                   : piiobroker                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + instance is alive
                          Creating backup ...
                          Also müsste ja eigentlich eine jeweilige jsonl vorhanden sein, aber wohl nur als backup
                            @metzid da läuft kein admin, soweit man hier sehen kann
                              @crunchip wie kann ich den admin
                              starten
                                @metzid
                                iob start admin
                                  @crunchip
                                  pi@piiobroker:/opt/iobroker $ iob start admin
                                  + instance is alive
                                  Leider über Browser nicht erreichbar
                                    @crunchip Hallo guten Morgen. Ich habe mir heute Nacht nochmals überlegt ob es Sinn macht das Image des neuen Raspberry mit neiem OS und iobroker nochmals einzuspielen dann die datenbank auf file/file umzustellen und dann ein restore des iobrokers zu fahren. Dann dürfte doch zumindest die datenbbank auf dem Level des restores dein. Oder mache ich da einen Denkfehler.
                                    Noch eine kurze Frage wenn so ein Restore gefahren wird werden dann die ganzen Module /Datenbanken auf dem raspberry auf die Versionsnummer des Altgerätes zurückgestellt. Oder gibt es eine versionsabhängigkeit wo dann nur der Inhalt der verschiedenen Datenbank und Module zurückgespielt wird so dass keine Instalation auf die alten Level erfolgt also rein Daten eingespielt werden. Sollte man da schon die ganzen Adapter die auch im alten Backup hinterlegt sind schon in der neuen Version installieren so dass das System nur noch Daten zurück spielt und keine Adapter auf alte Versionen zurücksetzt. Oder gibt es da eine versionsabhängigkeit ab wann das iobroker Backup nur Daten oder auch Versionen zurückspielt.
                                      nein, um ein backup zurückzuspielen, müssen keine Adapter im Vorfeld installiert werden, das beinhaltet alles das backup. Einzige Ausnahme aufgrund eines bugs, muss vis (falls genutzt wird) vor dem backup installiert werden.
                                      kannst du versuchen
                                      M 4 Replies Last reply Reply Quote 0
                                        @crunchipnein habe kein vis
                                        versuche es jetzt gleich
                                          @crunchip @crunchip hier der log iobroker ist dann wieder problemlos gestartet
                                          login as: pi
                                          pi@192.168.178.172's password:
                                          Linux piiobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                                          The programs included with the Debian GNU/Linux system are free software;
                                          the exact distribution terms for each program are described in the
                                          individual files in /usr/share/doc/*/copyright.
                                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                          permitted by applicable law.
                                          Last login: Wed Apr 26 11:31:28 2023
                                          Wi-Fi is currently blocked by rfkill.
                                          Use raspi-config to set the country before use.
                                          pi@piiobroker:~ $ cd /opt/iobroker
                                          pi@piiobroker:/opt/iobroker $ iobroker stop
                                          - Objects database:
                                            - Type: jsonl
                                            - Port: 9001
                                          - States database:
                                            - Type: jsonl
                                            - Port: 9000
                                          Host / Unix Socket of states DB (file), default[127.0.0.1]:
                                          Data directory (file), default[../../iobroker-data/]:
                                          This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
                                          Creating backup ...
                                          host.piiobroker 102 states saved
                                          host.piiobroker 143 objects saved
                                          Backup created: /opt/iobroker/backups/2023_04_27-09_30_42_backupiobroker-migration.tar.gz
                                           Cannot read system.config: null (OK when migrating or restoring)
                                          Restore backup ...
                                          iobroker controller daemon is not running
                                          host.piiobroker OK.
                                          host.piiobroker Clear all objects and states...
                                          clean 2 objects...
                                          clean 2 states...
                                          host.piiobroker done.
                                          host.piiobroker Processed 0/143 objects
                                          143 objects restored.
                                          host.piiobroker Processed 0/102 states
                                          102 states restored.
                                          upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                          upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                                          upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                                          upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                                          upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                                          upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                                          upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                                          upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                                          upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                                          upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                                          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                                          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                                          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                                          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                          upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                          upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                          upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                          upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                          upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                          upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                          upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                          upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                          upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                          upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                          upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                          upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                          upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                          upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                          upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                          upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                          upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                          upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                          upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                          Reinstalling adapter "admin" from "iobroker.admin@6.3.5"
                                          removed 1 package, and changed 4 packages in 45s
                                          45 packages are looking for funding
                                            run `npm fund` for details
                                          Reinstalling adapter "backitup" from "iobroker.backitup@2.6.19"
                                          up to date in 6s
                                          Could not migrate objects to corresponding sets: Cannot read properties of undefined (reading 'getObjectList')
                                          Backup restored - Migration successful
                                          Important: If your system consists of multiple hosts please execute
                                          "iobroker upload all" on the master AFTER all other hosts/slaves have
                                          also been updated to this states/objects database configuration AND are
                                          running!
                                          MOD-EDIT: Code in code-tags gesetzt
                                            @crunchip nach dem restore startet der iobroker leider nicht mehr. Soll ich iobroker fix ausführen
                                            login as: pi
                                            - Objects database:
                                              - Type: jsonl
                                              - Port: 9001
                                            - States database:
                                              - Type: jsonl
                                              - Port: 9000
                                            Creating backup ...
                                            Restore backup ...
                                            host.piiobroker OK.
                                            clean 2 objects...
                                            clean 2 states...
                                            up to date in 6s
                                            running!
                                            3527
