    4. Anfrage Tahoma/Somfy IO Adapter
      SaschaS last edited by SaschaS
      beim Versuch den Adapter mit der lokalen API einzusetzen, erhalte ich nachstehendes Fehlerbild.
      Hat das Problem schon mal jemand gehabt bzw. kann mir einen Ratschlag geben? 🙂
      Starte ich den Adapter, connected dieser sich mMn ordnungsgemäß.
      2023-03-27 18:20:17.341  - info: tahoma.1 (25206) starting. Version 0.10.2 (non-npm: Excodibur/ioBroker.tahoma#cdd75a4022da146300dfe7286790bcc01711c08d) in /opt/iobroker/node_modules/iobroker.tahoma, node: v14.21.3, js-controller: 4.0.24
      2023-03-27 18:20:17.387  - info: tahoma.1 (25206) [START] Starting adapter tahoma v0.10.2.3
      2023-03-27 18:20:17.389  - info: tahoma.1 (25206) Configured polling interval: 600000
      2023-03-27 18:20:17.392  - info: tahoma.1 (25206) Adapter will connect to Tahoma Box via local API.
      2023-03-27 18:20:17.395  - info: tahoma.1 (25206) Using stored bearer token 64XXXXXXXXXXX
      2023-03-27 18:20:20.141  - info: tahoma.1 (25206) eventRegisterID = d1c72bf8-feba-467d-a492-58240cee035b
      Nach einer Weile (den Auslöser habe ich noch nicht gefunden) kommen alle 10 Minuten die Fehlermeldungen
      tahoma.1
      2023-03-27 20:11:29.702	warn	Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
      tahoma.1
      2023-03-27 20:11:29.701	warn	Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Mon, 27 Mar 2023 18:11:29 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-XXXX-XXXX-XXXX:8443","port":"8443","hostname":"gateway-XXXX-XXXX-XXXX","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch","href":"https://gateway-XXXX-XXXX-XXXX:8443/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 6421c23a13502a75ef65","Content-type":"application/json","accept":"application/json","content-length":2}}}
      tahoma.1
      2023-03-27 20:11:29.700	warn	error during request: null, request path: events/60918544-6520-4772-8711-a18a46f8e539/fetch with payload:{}
      tahoma.1
      2023-03-27 20:01:29.660	warn	Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
      tahoma.1
      2023-03-27 20:01:29.660	warn	Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Mon, 27 Mar 2023 18:01:29 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-XXXX-XXXX-XXXX:8443","port":"8443","hostname":"gateway-XXXX-XXXX-XXXX","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch","href":"https://gateway-XXXX-XXXX-XXXX:8443/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 6421c23a13502a75ef65","Content-type":"application/json","accept":"application/json","content-length":2}}}
      tahoma.1
      2023-03-27 20:01:29.659	warn	error during request: null, request path: events/60918544-6520-4772-8711-a18a46f8e539/fetch with payload:{}
      tahoma.1
      2023-03-27 19:51:29.658	warn	Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
      tahoma.1
      2023-03-27 19:51:29.658	warn	Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Mon, 27 Mar 2023 17:51:29 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-XXXX-XXXX-XXXX:8443","port":"8443","hostname":"gateway-XXXX-XXXX-XXXX","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch","href":"https://gateway-XXXX-XXXX-XXXX:8443/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 6421c23a13502a75ef65","Content-type":"application/json","accept":"application/json","content-length":2}}}
      tahoma.1
      2023-03-27 19:51:29.657	warn	error during request: null, request path: events/60918544-6520-4772-8711-a18a46f8e539/fetch with payload:{}
      tahoma.1
      2023-03-27 19:41:29.675	warn	Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
      tahoma.1
      2023-03-27 19:41:29.675	warn	Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Mon, 27 Mar 2023 17:41:29 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-XXXX-XXXX-XXXX:8443","port":"8443","hostname":"gateway-XXXX-XXXX-XXXX","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch","href":"https://gateway-XXXX-XXXX-XXXX:8443/enduser-mobile-web/1/enduserAPI/events/60918544-6520-4772-8711-a18a46f8e539/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 6421c23a13502a75ef65","Content-type":"application/json","accept":"application/json","content-length":2}}}
      tahoma.1
      2023-03-27 19:41:29.674	warn	error during request: null, request path: events/60918544-6520-4772-8711-a18a46f8e539/fetch with payload:{}
      Edit: Ich hab erst danach gesehen, dass @Willi-Wunder genau die gleiche Fehlermeldung in seinem Post hatte. Eine Lösung habe ich aber nicht gefunden..
      @willi-wunder said in Anfrage Tahoma/Somfy IO Adapter:
      @memme
      Hast du deine Tahoma auch mal komplett stromlos gemacht? Daran lag es das letzte mal bei mir......Reboot hat nicht ausgereicht. Entwicklermodus ist in der Box auch aktiviert?
      Meine Einstellungen sind anders:
      Hab die V0.8.0
      Verzögerung zwischen den Anmeldeversuchen 60 sek.
      Verzögerung nach fehlgeschlagener Anmeldung 200 sek.
      Verzögerung vor dem erneuten Versuch der Apply-Warteschlange (Millisekunden) 500000
      Abrufintervall 500000
      Meine Fehlermeldung im Log ist:
      tahoma.0
      	2022-12-11 13:19:37.326	warn	Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
      tahoma.0
      	2022-12-11 13:19:37.325	warn	Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Sun, 11 Dec 2022 12:19:37 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-xxxx-xxxx-xxxx:8443","port":"8443","hostname":"gateway-xxxx-xxxx-xxxx","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/f8338c7f-113b-4707-9f0d-c5e7c76f9533/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/f8338c7f-113b-4707-9f0d-c5e7c76f9533/fetch","href":"https://gateway-xxxx-xxxx-xxxx:8443/enduser-mobile-web/1/enduserAPI/events/f8338c7f-113b-4707-9f0d-c5e7c76f9533/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 6263c4b71f21561a9245","Content-type":"application/json","accept":"application/json","content-length":2}}}
      tahoma.0
      	2022-12-11 13:19:37.325	warn	error during request: null, request path: events/f8338c7f-113b-4707-9f0d-c5e7c76f9533/fetch with payload:{}
      Läuft aber alles 🙂
        mrfloppy last edited by
        Hallo
        Habe mir auch eine Tahoma Box zugelgt.
        Einrichtung und so funktioniert.
        HAbe auch diese Fehelrmeldungen , sobald ich die Box mal kein LAN hat oder ich sie ab und wieder anstecke.
        Abhilfe bringt nur ein Neustart der Instanz.
        Kann man auf die Meldugen automatisch reagieren und die Instanz neu starten ?
        LG Thomas
        tahoma.0
        2023-04-10 08:26:50.169	info	eventRegisterID = 58151ee5-87c9-46bc-a3bf-75f5afb39920
        tahoma.0
        2023-04-10 08:26:49.356	info	Using stored bearer token 6430730c3f2cc8748c76
        tahoma.0
        2023-04-10 08:26:49.355	info	Adapter will connect to Tahoma Box via local API.
        tahoma.0
        2023-04-10 08:26:49.353	info	Configured polling interval: 20000
        tahoma.0
        2023-04-10 08:26:49.352	info	[START] Starting adapter tahoma v0.10.2.3
        tahoma.0
        2023-04-10 08:26:49.336	info	starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.tahoma, node: v18.15.0, js-controller: 4.0.24
        tahoma.0
        2023-04-10 08:26:45.155	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        tahoma.0
        2023-04-10 08:26:45.154	info	terminating
        tahoma.0
        2023-04-10 08:26:45.153	info	Got terminate signal TERMINATE_YOURSELF
        tahoma.0
        2023-04-10 08:26:29.643	warn	Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
        tahoma.0
        2023-04-10 08:26:29.643	warn	Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Mon, 10 Apr 2023 06:26:29 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1228-6859-1058:8443","port":"8443","hostname":"gateway-1228-6859-1058","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/65c50aec-3038-4b0e-b5a8-c393ebf6764c/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/65c50aec-3038-4b0e-b5a8-c393ebf6764c/fetch","href":"https://gateway-1228-6859-1058:8443/enduser-mobile-web/1/enduserAPI/events/65c50aec-3038-4b0e-b5a8-c393ebf6764c/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 6430730c3f2cc8748c76","Content-type":"application/json","accept":"application/json","content-length":2}}}
        tahoma.0
        2023-04-10 08:26:29.643	warn	error during request: null, request path: events/65c50aec-3038-4b0e-b5a8-c393ebf6764c/fetch with payload:{}
        tahoma.0
        2023-04-10 08:26:09.642	warn	Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
        tahoma.0
        2023-04-10 08:26:09.642	warn	Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Mon, 10 Apr 2023 06:26:09 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1228-6859-1058:8443","port":"8443","hostname":"gateway-1228-6859-1058","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/65c50aec-3038-4b0e-b5a8-c393ebf6764c/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/65c50aec-3038-4b0e-b5a8-c393ebf6764c/fetch","href":"https://gateway-1228-6859-1058:8443/enduser-mobile-web/1/enduserAPI/events/65c50aec-3038-4b0e-b5a8-c393ebf6764c/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 6430730c3f2cc8748c76","Content-type":"application/json","accept":"application/json","content-length":2}}}
        tahoma.0
        2023-04-10 08:26:09.642	warn	error during request: null, request path: events/65c50aec-3038-4b0e-b5a8-c393ebf6764c/fetch with payload:{}
        tahoma.0
        2023-04-10 08:25:49.638	warn	Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
        tahoma.0
        2023-04-10 08:25:49.638	warn	Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Mon, 10 Apr 2023 06:25:49 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1228-6859-1058:8443","port":"8443","hostname":"gateway-1228-6859-1058","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/65c50aec-3038-4b0e-b5a8-c393ebf6764c/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/65c50aec-3038-4b0e-b5a8-c393ebf6764c/fetch","href":"https://gateway-1228-6859-1058:8443/enduser-mobile-web/1/enduserAPI/events/65c50aec-3038-4b0e-b5a8-c393ebf6764c/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 6430730c3f2cc8748c76","Content-type":"application/json","accept":"application/json","content-length":2}}}
        LG Thomas
          jumbo125 @mrfloppy last edited by
          Hallo zusammen
          ich habe mir das alles durchgelesen und bin mir nun nicht sicher...
          ich besitzte seit kurzem eine Tahoma Switch. Zusätzlich habe ich die außen jalousien.
          Kann ich diese mit iobroker steueren?
          ich habe bereits den developer modus aktiviert.
          Tahomalink.com kann ich nicht nutzen, da es für die switch nicht geht. Jedoch habe ich gelesen, das es auch mit der localen api funtkionieren sollte.
          Ich habe die den adapter im iobroker v. 010 geladen und meine daten eingegeben.
          in der log datei steht auch ein token. aber dannach kommen ein paar errors
          error during request: Error: connect ECONNREFUSED 10.0.0.113:8443, request path: setup with payload:{
          ich bin für jeden ratschlag dankbar
          J G 2 Replies Last reply Reply Quote 0
            jumbo125 @jumbo125 last edited by
            @jumbo125
            Ich hab zwar nun nach einem neustart keine fehlermeldung mehr, aber wie geht es weiter? ich habe den adapter installiert, ABER in den datenpunkten steht leider nichts.
            Wie kann man nun die einzelnen rollos bedienen?
              Murphys234d @jumbo125 last edited by Murphys234d
              @jumbo125 Du setzt einfach den Datenpunkt "ClosureState" des Objektes. Beispiel
              tahoma.0.devices.[name der jalousie].states.core:ClosureState
              übergibst du 100, geht es komplett zu, bei 0 geht es komplett auf.
              J 3 Replies Last reply Reply Quote 0
                jumbo125 @Murphys234d last edited by jumbo125
                @murphys234d
                ah, super. versuche ich. wiegesagt, es ist kein datenpunkt derzeit angelegt.
                Wisst ihr wo es eine liste mit den datenpunkten gibt?
                woher weiß man den namen der jalousie?
                wäre auch toll wenn man den status der rollo abfragen kann. also wieweit sie offen ist zur zeit
                Danke!
                  @murphys234d said in Anfrage Tahoma/Somfy IO Adapter:
                  tahoma.0.devices.
                  alles neu gestartet und installiert.
                  Nun wird es angezeigt 🙂
                    @jumbo125 ah entschuldige das mit den fehlenden Devices hatte ich überlesen. Wenn man mal eben surft während man auf der Arbeit wartet 😇
                    Du kannst dir auf jeden Fall noch einmal den Adapter shuttercontrol anschauen. Mit dem lässt sich öffnen und schließen sehr gut automatisieren. Ich selber nutze einen Bruchteil der möglichen Optionen davon.
                      @murphys234d
                      super danke.
                      heißt das, dass ich dann den tahoma adapter nicht mehr brauche??
                        @jumbo125 doch doch, den brauchst du weiterhin. Shuttercontrol macht die Logik und steuert den Tahoma, wenn du so willst.
                        In Shuttercontrol wählst du die vom Tahoma angebotenen Jalousien aus und kannst dann z.b. sagen, dass Jalousie 1,2 und 3 Wochentags - wenn kein Feiertag ist - zum Sonnenaufgang öffnen sollen.
                        Da musst du dich aber selbst einlesen.
                          @murphys234d allses klar. schon getan. das isst mehr oder weniger ein adapter damit ich mir die javascript programmierung von feiertagen etc. erspare
                            bitte verzeih die störung. sag mal, gibt es ein state wo man sieht, ob die jalousie gerade in bewegung ist? bzw. ob gerade ein vorgang im laufen ist?
                            danjaolusie
                              wusa @jumbo125 last edited by
                              @jumbo125
                              Ich habe den Status selber noch nie benötigt.
                              Aber es würde 2 Einträge darauf hin deuten:
                              core:MovingState
                              und
                              moving
                              Vielleicht kannst du mit einem der beiden Einträge etwas anfangen.
                                bischemer @wusa last edited by
                                Hallo Community,
                                ich möchte auch meine Jalousien (Somfy Motor) jetzt im Sommer über den ioBroker steuern und habe eine Frage zum benötigten Tahoma Switch. Folgenden habe ich im Netz gefunden ==>
                                Somfy TaHoma 1870594 Switch
                                Wäre das der richtige für die Nutzung mit diesem Adapter oder gibt es sogar noch günstigere Optionen. Vielen Dank vorab für eine kurze Rückmeldung, damit das nächste Projekt starten kann 😉
                                  Willi-Wunder @bischemer last edited by Willi-Wunder
                                  @bischemer
                                  Hi, wenn deine Somfy Motoren mit Funk (io oder RTS) sind, dann geht das mit dieser Box. Hiermit hast du alle Möglichkeiten
                                  auch wenns später Erweiterungen gibt, sprich Sonnen- oder Temperatur Sensor von Somfy. Gibt auch günstigere Lösungen soweit ich weiß mit entsprechenden Abspeckungen. Mit der Switch bleiben alle Möglichkeiten offen.
                                  Gruß Willi
                                    bischemer @Willi-Wunder last edited by
                                    @willi-wunder
                                    vielen Dank für die schnelle Antwort. Ja es sind io Motoren. Noch eine kurze Frage, kann ich mit diesem Tahoma Switch die ioBroker Anbindung auch rein lokal betreiben oder geht die Kommunikation dann immer über eine Cloud ?
                                      @bischemer
                                      Die Switch kann aktuell auch Lokal mit dem Tahoma Adapter im iobroker genutzt werden.
                                      Ansonsten läuft es über dem Somfy Server.
                                        bischemer @Willi-Wunder last edited by bischemer
                                        @willi-wunder
                                        nochmals Danke für die schnelle Info ... der Switch ist bestellt 😉
                                          derdominik last edited by
                                          Hallo, ich habe heute festgestellt, dass ich bei meiner Somfy Connexoon mittlerweile ebenfalls den Developer-Mode und damit die lokale API aktivieren kann.
                                          Siehe https://github.com/Somfy-Developer/Somfy-TaHoma-Developer-Mode/issues/9#ref-issue-1551752855
                                          Der erste Test hat geklappt, ich bekomme die Adapter-Meldung in den Logs, dass die lokale API genutzt wird.
                                          Ich habe 2 Rollos und 4 Dachfenster-Markisen, wobei sich eines der Fenster elektrisch öffnen lässt.
                                          Bei dem DFF, welches sich elektrisch öffnen lässt, verhält es sich mit der lokalen API allerdings seltsam:
                                          Ohne lokale API wird für das Fenster die Markisensteuerung angezeigt, das Objekt ist ein "Awning blind":
                                          Sobald ich aber die PIN für die lokale API aktiviere, ändert sich das gleiche Objekt in einen "Window Operator" und ist damit für das Öffnen/Schließen des Fensters zuständig, aber nicht mehr für die Markisensteuerung:
                                          Entferne ich die PIN für die lokale API, wechselt das Objekt wieder zurück zu "Awning blind" - der Markisensteuerung.
                                          Ich würde gerne die lokale API nutzen und gleichzeitig die Markisensteuerung behalten... was könnte ich tun?
                                            Willi-Wunder @derdominik last edited by
                                            @derdominik
                                            Welche Version hast du laufen? Evtl. von Github mal die neuste installieren, vielleicht wurde der Fehler schon behoben. Kann es leider nicht testen, habe keine Dachfenster. Ansonsten müßte @Excodibur sich das mal ansehen.
                                            605
                                            157221
