    3. Einsteigerfragen
    4. Installation
    5. IOBroker backup auf neue Rasperry übertragen
      Metzid @crunchip last edited by Homoran
      @crunchip
      pi@piiobroker:/opt/iobroker $ iobroker setup custom
      Current configuration:
      - Objects database:
        - Type: jsonl
        - Host/Unix Socket: 127.0.0.1
        - Port: 9001
      - States database:
        - Type: jsonl
        - Port: 9000
      - Data Directory: ../../iobroker-data/
      Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f
      Host / Unix Socket of objects DB(file), default[127.0.0.1]: f
      Port of objects DB(file), default[9001]:
      Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f
      Host / Unix Socket of states DB (file), default[f]: f
      Port of states DB (file), default[9000]:
      Host name of this machine [piiobroker]: piiobroker
      Please choose if this is a Master/single host (enter "m") or a Slave host (enter "S") you are about to edit. For Slave hosts the data migration will be skipped. [S/m]: m
      Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y
      Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y
      Connecting to previous DB "jsonl"...
      Creating backup ...
      This can take some time ... please be patient!
      host.piiobroker 1626 states saved
      host.piiobroker 2188 objects saved
      Backup created: /opt/iobroker/backups/2023_04_26-22_38_38_backupiobroker-migration.tar.gz
      updating conf/iobroker.json
      Connecting to new DB "file" (can take up to 20s) ...
      Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
      Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
      Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
      No connection to databases possible ...
      New Database could not be connected. Please check your settings. No settings have been changed.
      restoring conf/iobroker.json
      pi@piiobroker:/opt/iobroker $ iob start
        @crunchip
        pi@piiobroker:/opt/iobroker $ iob list instances
          system.adapter.admin.0                  : admin                 : piiobroker                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.broadlink2.0             : broadlink2            : piiobroker                               - disabled
          system.adapter.hm-rega.0                : hm-rega               : piiobroker                               - disabled
          system.adapter.hm-rpc.0                 : hm-rpc                : piiobroker                               - disabled, port: 0
          system.adapter.iot.0                    : iot                   : piiobroker                               - disabled
          system.adapter.javascript.0             : javascript            : piiobroker                               - disabled
          system.adapter.scenes.0                 : scenes                : piiobroker                               - disabled
          system.adapter.web.0                    : web                   : piiobroker                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
          crunchip Forum Testing Most Active @Metzid last edited by
          @metzid sagte in IOBroker backup auf neue Rasperry übertragen:
          Creating backup ...
          Also müsste ja eigentlich eine jeweilige jsonl vorhanden sein, aber wohl nur als backup
            @metzid da läuft kein admin, soweit man hier sehen kann
              @crunchip wie kann ich den admin
              starten
                @metzid
                iob start admin
                  @crunchip
                  pi@piiobroker:/opt/iobroker $ iob start admin
                  + instance is alive
                  Leider über Browser nicht erreichbar
                    @crunchip Hallo guten Morgen. Ich habe mir heute Nacht nochmals überlegt ob es Sinn macht das Image des neuen Raspberry mit neiem OS und iobroker nochmals einzuspielen dann die datenbank auf file/file umzustellen und dann ein restore des iobrokers zu fahren. Dann dürfte doch zumindest die datenbbank auf dem Level des restores dein. Oder mache ich da einen Denkfehler.
                    Noch eine kurze Frage wenn so ein Restore gefahren wird werden dann die ganzen Module /Datenbanken auf dem raspberry auf die Versionsnummer des Altgerätes zurückgestellt. Oder gibt es eine versionsabhängigkeit wo dann nur der Inhalt der verschiedenen Datenbank und Module zurückgespielt wird so dass keine Instalation auf die alten Level erfolgt also rein Daten eingespielt werden. Sollte man da schon die ganzen Adapter die auch im alten Backup hinterlegt sind schon in der neuen Version installieren so dass das System nur noch Daten zurück spielt und keine Adapter auf alte Versionen zurücksetzt. Oder gibt es da eine versionsabhängigkeit ab wann das iobroker Backup nur Daten oder auch Versionen zurückspielt.
                      nein, um ein backup zurückzuspielen, müssen keine Adapter im Vorfeld installiert werden, das beinhaltet alles das backup. Einzige Ausnahme aufgrund eines bugs, muss vis (falls genutzt wird) vor dem backup installiert werden.
                      kannst du versuchen
                      M 4 Replies Last reply Reply Quote 0
                        @crunchipnein habe kein vis
                        versuche es jetzt gleich
                          @crunchip @crunchip hier der log iobroker ist dann wieder problemlos gestartet
                          login as: pi
                          pi@192.168.178.172's password:
                          Linux piiobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                          The programs included with the Debian GNU/Linux system are free software;
                          the exact distribution terms for each program are described in the
                          individual files in /usr/share/doc/*/copyright.
                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                          permitted by applicable law.
                          Last login: Wed Apr 26 11:31:28 2023
                          Wi-Fi is currently blocked by rfkill.
                          Use raspi-config to set the country before use.
                          pi@piiobroker:~ $ cd /opt/iobroker
                          pi@piiobroker:/opt/iobroker $ iobroker stop
                          - Objects database:
                            - Type: jsonl
                            - Port: 9001
                          - States database:
                            - Type: jsonl
                            - Port: 9000
                          Host / Unix Socket of states DB (file), default[127.0.0.1]:
                          Data directory (file), default[../../iobroker-data/]:
                          This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
                          Creating backup ...
                          host.piiobroker 102 states saved
                          host.piiobroker 143 objects saved
                          Backup created: /opt/iobroker/backups/2023_04_27-09_30_42_backupiobroker-migration.tar.gz
                          Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup!
                          Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
                           Cannot read system.config: null (OK when migrating or restoring)
                          Restore backup ...
                          iobroker controller daemon is not running
                          host.piiobroker OK.
                          host.piiobroker Clear all objects and states...
                          clean 2 objects...
                          clean 2 states...
                          host.piiobroker done.
                          host.piiobroker Processed 0/143 objects
                          143 objects restored.
                          host.piiobroker Processed 0/102 states
                          102 states restored.
                          upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                          upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                          upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                          upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                          upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                          upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                          upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                          upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                          upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                          upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                          upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                          upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                          upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                          upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                          upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                          upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                          upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                          upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                          upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                          upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                          upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                          upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                          upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                          upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                          upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                          upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                          upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                          upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                          upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                          Reinstalling adapter "admin" from "iobroker.admin@6.3.5"
                          removed 1 package, and changed 4 packages in 45s
                          45 packages are looking for funding
                            run `npm fund` for details
                          Reinstalling adapter "backitup" from "iobroker.backitup@2.6.19"
                          up to date in 6s
                          Could not migrate objects to corresponding sets: Cannot read properties of undefined (reading 'getObjectList')
                          Backup restored - Migration successful
                          Important: If your system consists of multiple hosts please execute
                          "iobroker upload all" on the master AFTER all other hosts/slaves have
                          also been updated to this states/objects database configuration AND are
                          running!
                          MOD-EDIT: Code in code-tags gesetzt
                            @crunchip nach dem restore startet der iobroker leider nicht mehr. Soll ich iobroker fix ausführen
                            login as: pi
                            - Objects database:
                              - Type: jsonl
                              - Port: 9001
                            - States database:
                              - Type: jsonl
                              - Port: 9000
                            Creating backup ...
                            Restore backup ...
                            host.piiobroker OK.
                            clean 2 objects...
                            clean 2 states...
                            up to date in 6s
                            running!
                              @crunchip leider startet der ibroker jetzt nicht mehr soll ich den ibroker fix anstoßen
                                ein restore dauert auch eine Weile, wie lange hast du gewartet?
                                und generell, auf welchem Stand ist deine alte Installation bzw das backup?
                                  @crunchip Altsystem Raspberry 3B
                                  • Plattform: linux
                                  • Die Architektur: arm
                                  • CPUs: 4
                                  • Geschwindigkeit: 1200 MHz
                                  • Modell: ARMv7 Processor rev 4 (v7l)
                                  • RAM: 923.3 MB
                                  • System-Betriebszeit: 00:45:28
                                  • Node.js: v10.18.0
                                  • NPM: 6.13.4
                                  • Datenträgergröße: 12.9 GiB
                                  • Datenträger verfügbar: 7.5 GiB
                                  • Adapter-Anzahl: 471
                                  • Betriebszeit: 23:32:45
                                  • Aktive Instanzen: 8
                                  Betriebsystem Jessie
                                  Der Js-controller hat die Version ist 2.1.1 Jetzt wollte ich das System updaten leider scheint die installierte Raspbain GUN linux8 Jessie nicht mehr mit den neuen JS-controllern unterstützt zu werden. Wenn ich da einen update durchführen verhagelt er mir das ganze system. Leider konnte ich beim Altsystem kein Backup mit dem Backit
                                  Hier die Übersicht zum neuen System
                                  Neue System Raspberry 3B
                                  • Plattform: linux
                                  • Betriebssystem: linux
                                  • Architektur: arm64
                                  • CPUs: 4
                                  • Modell: Cortex-A53
                                  • RAM: 909.6 MB
                                  • System-Betriebszeit: 00:23:54
                                  • Node.js: v18.16.0
                                  • time: 1682502790750
                                  • timeOffset: -60
                                  • NPM: v9.5.1
                                  • Datenträgergröße: 14.3 GB
                                  • Freier Festplattenspeicher: 9.5 GB
                                  • Betriebszeit: 00:04:51
                                  • Aktive Instanzen: 3
                                  • Pfad: /opt/iobroker/
                                  • aktiv:
                                  • Der Js-controller hat die Version ist 4.0.24
                                  Betriebsystem bullseye
                                  Leider ließ sich auf dem Altsystem auch der Backitup Adapter nicht installieren.
                                  Somit habe ich über putty manuell über den command das Backup angestoßen.
                                  iobroker Backup erstellt.
                                  Das Backup habe ich dann auf das Neusystem kopiert und nach Stop des iobrokers das System versucht zurückzuspielen
                                  Welche Option habe ich jetzt noch
                                    Thomas Braun Most Active @Metzid last edited by
                                    @metzid
                                    Jag mal iob diag über das System.
                                    Musst du direkt aufrufen, siehe in meiner Signatur.
                                      @metzid ok also immer noch auf deinem alten System der gleiche Stand wie zu Beginn im Thread.
                                      ich würde mal versuchen den controller auf die V3.3(beinhaltet jsonl) zu bringen, den admin entsprechen auf 4.1 oder größer, also bewusst bestimmte versionen installieren, müsste ja mit deiner node10 uns jessi noch funktionieren
                                      somit müsste auch der backitup adapter( auch eventuell in einer älteren version) funktionieren um ein passende backup zu erstellen, was auf einem neuen system dann eingespielt werden kann
                                        @crunchip danke für die Info gibt es eine Beschreibung wie man den controller auf die besagte Version bringt.
                                          crunchip Forum Testing Most Active @Metzid last edited by crunchip
                                          @metzid dazu musst du ins entsprechende Verzeichnis
                                          /opt/iobroker
                                          Von da via npm install
                                          Z.b. admin
                                          npm install admin @4.0
                                          npm install iobroker.js-controller@version
                                            Metzid @Thomas Braun last edited by Homoran
                                            pi@raspberrypi:/opt/iobroker $ iob diag
                                            Commands:
                                            iobroker setup [--objects <host>] [--states <host>] [custom]
                                            iobroker start
                                            iobroker stop
                                            iobroker start <adapter>
                                            iobroker stop <adapter>
                                            iobroker start all
                                            iobroker restart
                                            iobroker restart <adapter>
                                            iobroker info
                                            iobroker logs [adapter] [--watch] [--lines=1000]
                                            iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
                                            iobroker install <adapter>
                                            iobroker url <url> [<name>]
                                            iobroker del <adapter>
                                            iobroker del <adapter>.<instance>
                                            iobroker update [repository url] [--updatable/--u] [--installed/--i]
                                            iobroker upgrade [repository url]
                                            iobroker upgrade self [repository url]
                                            iobroker upgrade <adapter> [repository url]
                                            iobroker upload <pathToLocalFile> <pathIniobroker>
                                            iobroker upload all
                                            iobroker upload <adapter>
                                            iobroker object get <id>
                                            iobroker object set <id> <json-value>
                                            iobroker object set <id> propertyname=value
                                            iobroker object del <id|pattern> [--yes]
                                            iobroker object chmod <object-mode> [state-mode] <id>
                                            iobroker object chown <user> <group> <id>
                                            iobroker object list <id>
                                            iobroker state get <id>
                                            iobroker state getplain <id> [--pretty]
                                            iobroker state getvalue <id>
                                            iobroker state set <id> <value> [ack]
                                            iobroker state del <id>
                                            iobroker message <adapter>[.instanceid] <command> [<message>]
                                            iobroker list <type> [filter]
                                            iobroker chmod <mode> <file>
                                            iobroker chown <user> <group> <file>
                                            iobroker touch <file>
                                            iobroker rm <file>
                                            iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
                                            iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
                                            iobroker file sync
                                            iobroker user add <user> [--ingroup group] [--password pass]
                                            iobroker user del <user>
                                            iobroker user passwd <user> [--password pass]
                                            iobroker user enable <user>
                                            iobroker user disable <user>
                                            iobroker user get <user>
                                            iobroker user check <user> [--password pass]
                                            iobroker group add <group>
                                            iobroker group del <group>
                                            iobroker group list <group>
                                            iobroker group enable <group>
                                            iobroker group disable <group>
                                            iobroker group get <group>
                                            iobroker group adduser <group> <user>
                                            iobroker group deluser <group> <user>
                                            iobroker host this
                                            iobroker host <hostname>
                                            iobroker host set <hostname>
                                            iobroker host remove <hostname>
                                            iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
                                            iobroker license <license.file or license.text>
                                            iobroker cert create
                                            iobroker cert view [<certificate name>]
                                            iobroker clean
                                            iobroker backup
                                            iobroker restore <backup name or path>
                                            iobroker <command> --timeout 5000
                                            iobroker status [all]
                                            iobroker repo [name]
                                            iobroker repo add <name> <path or url>
                                            iobroker repo set <name>
                                            iobroker repo del <name>
                                            iobroker uuid
                                            iobroker unsetup
                                            iobroker multihost <enable|disable> [--secure true|false]
                                            iobroker multihost browse
                                            iobroker multihost connect
                                            iobroker compact status
                                            iobroker compact <enable|on|disable|off>
                                            iobroker compact <adapter>.<instance> status
                                            iobroker compact <adapter>.<instance> group <group-id>
                                            iobroker compact <adapter>.<instance> <disable|off>
                                            iobroker compact <adapter>.<instance> <enable|on> [group-id]
                                            iobroker version [adapter]
                                            iobroker [adapter] -v
                                            Optionen:
                                              --help     Hilfe anzeigen  [boolean]
                                              --version  Version anzeigen  [boolean]
                                            crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                            1.2k
                                            3527
