IOBroker backup auf neue Rasperry übertragen
@crunchip @crunchip hier der log iobroker ist dann wieder problemlos gestartet
login as: pi pi@192.168.178.172's password: Linux piiobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Wed Apr 26 11:31:28 2023 Wi-Fi is currently blocked by rfkill. Use raspi-config to set the country before use. pi@piiobroker:~ $ cd /opt/iobroker pi@piiobroker:/opt/iobroker $ iobroker stop pi@piiobroker:/opt/iobroker $ iobroker setup custom Current configuration: - Objects database: - Type: jsonl - Host/Unix Socket: 127.0.0.1 - Port: 9001 - States database: - Type: jsonl - Host/Unix Socket: 127.0.0.1 - Port: 9000 - Data Directory: ../../iobroker-data/ Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f Host / Unix Socket of objects DB(file), default[127.0.0.1]: Port of objects DB(file), default[9001]: Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f Host / Unix Socket of states DB (file), default[127.0.0.1]: Port of states DB (file), default[9000]: Data directory (file), default[../../iobroker-data/]: Host name of this machine [piiobroker]: piiobroker This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y Connecting to previous DB "jsonl"... Creating backup ... This can take some time ... please be patient! host.piiobroker 102 states saved host.piiobroker 143 objects saved Backup created: /opt/iobroker/backups/2023_04_27-09_30_42_backupiobroker-migration.tar.gz updating conf/iobroker.json Connecting to new DB "file" (can take up to 20s) ... Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup! Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup! Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset! Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset! Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects Cannot read system.config: null (OK when migrating or restoring) Restore backup ... This can take some time ... please be patient! iobroker controller daemon is not running host.piiobroker OK. host.piiobroker Clear all objects and states... clean 2 objects... clean 2 states... host.piiobroker done. host.piiobroker Processed 0/143 objects 143 objects restored. host.piiobroker Processed 0/102 states 102 states restored. upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5 upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript Reinstalling adapter "admin" from "iobroker.admin@6.3.5" removed 1 package, and changed 4 packages in 45s 45 packages are looking for funding run `npm fund` for details Reinstalling adapter "backitup" from "iobroker.backitup@2.6.19" up to date in 6s 45 packages are looking for funding run `npm fund` for details Could not migrate objects to corresponding sets: Cannot read properties of undefined (reading 'getObjectList') Backup restored - Migration successful Important: If your system consists of multiple hosts please execute "iobroker upload all" on the master AFTER all other hosts/slaves have also been updated to this states/objects database configuration AND are running! pi@piiobroker:/opt/iobroker $MOD-EDIT: Code in code-tags gesetzt
@crunchip nach dem restore startet der iobroker leider nicht mehr. Soll ich iobroker fix ausführen
@crunchip hier der log iobroker ist dann wieder problemlos gestartetlogin as: pi pi@192.168.178.172's password: Linux piiobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Wed Apr 26 11:31:28 2023 Wi-Fi is currently blocked by rfkill. Use raspi-config to set the country before use. pi@piiobroker:~ $ cd /opt/iobroker pi@piiobroker:/opt/iobroker $ iobroker stop pi@piiobroker:/opt/iobroker $ iobroker setup custom Current configuration: - Objects database: - Type: jsonl - Host/Unix Socket: 127.0.0.1 - Port: 9001 - States database: - Type: jsonl - Host/Unix Socket: 127.0.0.1 - Port: 9000 - Data Directory: ../../iobroker-data/ Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]: f Host / Unix Socket of objects DB(file), default[127.0.0.1]: Port of objects DB(file), default[9001]: Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [file]: f Host / Unix Socket of states DB (file), default[127.0.0.1]: Port of states DB (file), default[9000]: Data directory (file), default[../../iobroker-data/]: Host name of this machine [piiobroker]: piiobroker This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y Do you want to migrate objects and states from "jsonl/jsonl" to "file/file" [y/N]: y Migrating the objects database will overwrite all objects! Are you sure that this is not a slave host and you want to migrate the data? [y/N]: y Connecting to previous DB "jsonl"... Creating backup ... This can take some time ... please be patient! host.piiobroker 102 states saved host.piiobroker 143 objects saved Backup created: /opt/iobroker/backups/2023_04_27-09_30_42_backupiobroker-migration.tar.gz updating conf/iobroker.json Connecting to new DB "file" (can take up to 20s) ... Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup! Server Cannot load /opt/iobroker/iobroker-data/states.json: Database file /opt/iobroker/iobroker-data/states.json does not exists.. We try last Backup! Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset! Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: Database file /opt/iobroker/iobroker-data/states.json.bak does not exists.. Continue with empty dataset! Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects Cannot read system.config: null (OK when migrating or restoring) Restore backup ... This can take some time ... please be patient! iobroker controller daemon is not running host.piiobroker OK. host.piiobroker Clear all objects and states... clean 2 objects... clean 2 states... host.piiobroker done. host.piiobroker Processed 0/143 objects 143 objects restored. host.piiobroker Processed 0/102 states 102 states restored. upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5 upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript Reinstalling adapter "admin" from "iobroker.admin@6.3.5" removed 1 package, and changed 4 packages in 45s 45 packages are looking for funding run `npm fund` for details Reinstalling adapter "backitup" from "iobroker.backitup@2.6.19" up to date in 6s 45 packages are looking for funding run `npm fund` for details Could not migrate objects to corresponding sets: Cannot read properties of undefined (reading 'getObjectList') Backup restored - Migration successful Important: If your system consists of multiple hosts please execute "iobroker upload all" on the master AFTER all other hosts/slaves have also been updated to this states/objects database configuration AND are running! pi@piiobroker:/opt/iobroker $MOD-EDIT: Code in code-tags gesetzt!
@crunchip leider startet der ibroker jetzt nicht mehr soll ich den ibroker fix anstoßen
@metzid sagte in IOBroker backup auf neue Rasperry übertragen:
ein restore dauert auch eine Weile, wie lange hast du gewartet?
und generell, auf welchem Stand ist deine alte Installation bzw das backup?
@crunchip Altsystem Raspberry 3B
• Plattform: linux
• Die Architektur: arm
• CPUs: 4
• Geschwindigkeit: 1200 MHz
• Modell: ARMv7 Processor rev 4 (v7l)
• RAM: 923.3 MB
• System-Betriebszeit: 00:45:28
• Node.js: v10.18.0
• NPM: 6.13.4
• Datenträgergröße: 12.9 GiB
• Datenträger verfügbar: 7.5 GiB
• Adapter-Anzahl: 471
• Betriebszeit: 23:32:45
• Aktive Instanzen: 8
Betriebsystem JessieDer Js-controller hat die Version ist 2.1.1 Jetzt wollte ich das System updaten leider scheint die installierte Raspbain GUN linux8 Jessie nicht mehr mit den neuen JS-controllern unterstützt zu werden. Wenn ich da einen update durchführen verhagelt er mir das ganze system. Leider konnte ich beim Altsystem kein Backup mit dem Backit
Hier die Übersicht zum neuen System
Neue System Raspberry 3B
• Plattform: linux
• Betriebssystem: linux
• Architektur: arm64
• CPUs: 4
• Modell: Cortex-A53
• RAM: 909.6 MB
• System-Betriebszeit: 00:23:54
• Node.js: v18.16.0
• time: 1682502790750
• timeOffset: -60
• NPM: v9.5.1
• Datenträgergröße: 14.3 GB
• Freier Festplattenspeicher: 9.5 GB
• Betriebszeit: 00:04:51
• Aktive Instanzen: 3
• Pfad: /opt/iobroker/
• aktiv:
• Der Js-controller hat die Version ist 4.0.24
Betriebsystem bullseyeLeider ließ sich auf dem Altsystem auch der Backitup Adapter nicht installieren.
Somit habe ich über putty manuell über den command das Backup angestoßen.
iobroker Backup erstellt.
Das Backup habe ich dann auf das Neusystem kopiert und nach Stop des iobrokers das System versucht zurückzuspielenWelche Option habe ich jetzt noch
Jag mal
iob diagüber das System.
Musst du direkt aufrufen, siehe in meiner Signatur. -
@metzid ok also immer noch auf deinem alten System der gleiche Stand wie zu Beginn im Thread.
ich würde mal versuchen den controller auf die V3.3(beinhaltet jsonl) zu bringen, den admin entsprechen auf 4.1 oder größer, also bewusst bestimmte versionen installieren, müsste ja mit deiner node10 uns jessi noch funktionieren
somit müsste auch der backitup adapter( auch eventuell in einer älteren version) funktionieren um ein passende backup zu erstellen, was auf einem neuen system dann eingespielt werden kann -
@crunchip danke für die Info gibt es eine Beschreibung wie man den controller auf die besagte Version bringt.
@metzid dazu musst du ins entsprechende Verzeichnis
/opt/iobrokerVon da via npm install
Z.b. admin
npm install admin @4.0npm install iobroker.js-controller@version
pi@raspberrypi:/opt/iobroker $ iob diag Commands: iobroker setup [--objects <host>] [--states <host>] [custom] iobroker start iobroker stop iobroker start <adapter> iobroker stop <adapter> iobroker start all iobroker restart iobroker restart <adapter> iobroker info iobroker logs [adapter] [--watch] [--lines=1000] iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>] iobroker install <adapter> iobroker url <url> [<name>] iobroker del <adapter> iobroker del <adapter>.<instance> iobroker update [repository url] [--updatable/--u] [--installed/--i] iobroker upgrade [repository url] iobroker upgrade self [repository url] iobroker upgrade <adapter> [repository url] iobroker upload <pathToLocalFile> <pathIniobroker> iobroker upload all iobroker upload <adapter> iobroker object get <id> iobroker object set <id> <json-value> iobroker object set <id> propertyname=value iobroker object del <id|pattern> [--yes] iobroker object chmod <object-mode> [state-mode] <id> iobroker object chown <user> <group> <id> iobroker object list <id> iobroker state get <id> iobroker state getplain <id> [--pretty] iobroker state getvalue <id> iobroker state set <id> <value> [ack] iobroker state del <id> iobroker message <adapter>[.instanceid] <command> [<message>] iobroker list <type> [filter] iobroker chmod <mode> <file> iobroker chown <user> <group> <file> iobroker touch <file> iobroker rm <file> iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>] iobroker file write <filesystem-path-to-read> <iobroker-path-to-write> iobroker file sync iobroker user add <user> [--ingroup group] [--password pass] iobroker user del <user> iobroker user passwd <user> [--password pass] iobroker user enable <user> iobroker user disable <user> iobroker user get <user> iobroker user check <user> [--password pass] iobroker group add <group> iobroker group del <group> iobroker group list <group> iobroker group enable <group> iobroker group disable <group> iobroker group get <group> iobroker group adduser <group> <user> iobroker group deluser <group> <user> iobroker host this iobroker host <hostname> iobroker host set <hostname> iobroker host remove <hostname> iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false] iobroker license <license.file or license.text> iobroker cert create iobroker cert view [<certificate name>] iobroker clean iobroker backup iobroker restore <backup name or path> iobroker <command> --timeout 5000 iobroker status [all] iobroker repo [name] iobroker repo add <name> <path or url> iobroker repo set <name> iobroker repo del <name> iobroker uuid iobroker unsetup iobroker multihost <enable|disable> [--secure true|false] iobroker multihost browse iobroker multihost connect iobroker compact status iobroker compact <enable|on|disable|off> iobroker compact <adapter>.<instance> status iobroker compact <adapter>.<instance> group <group-id> iobroker compact <adapter>.<instance> <disable|off> iobroker compact <adapter>.<instance> <enable|on> [group-id] iobroker version [adapter] iobroker [adapter] -v Optionen: --help Hilfe anzeigen [boolean] --version Version anzeigen [boolean] pi@raspberrypi:/opt/iobroker $MOD-EDIT: Code in code-tags gesetzt!
@metzid setz das in code tags </>
@crunchip muss ich für die Prozedur den iobroker beenden. Muss mir erst noch eine neue sd erstellen. Gibt es eine Anleitung wie die code tags hesetzt werden. Bin nicht oft in Foren unterwegs
Du musst es mit dem vollen Pfad aus meiner Signatur aufrufen. Die Kurzform
iob diagfunktioniert nur mit aktuellen Versionen. -
Du klickst das zeichen über deinen editor an und kopierst deinen text da rein
Ich habe jetzt doch mal über die Neuinstallation das iobroker fix laufen gelassen und dann iobroker start. Plötzlich war die Webseite wieder da und fie konfiguration zurückgespielt. Klasse!!!!!
Wie gehe ich jetzt weiter vor die Adapter und der iobroker haben ja jetzt das alte Treiberversionen und die Datenbank ist auf file file.
Einfach das Betriebssystem updaten und dann auch den iobroker und die prozedur spielt die neuen Versionen ein und stellt fann auch in dem Zug die die Datenbank auf das mormale Format um -
@metzid jetzt komm ich grad nicht ganz mit, der neue mit dem backup läuft jetzt?
@crunchip ja der neue läuft jetzt. Alle adapter haben jetzt die alte Release Version drauf. Nur der js controller ist stat der alten version 2.1... die neue version 3.3.... Drauf
@metzid und was klappt jetzt nicht bzw was ist nun das Problem?
@crunchip ia ich wollte halt fragen wie ich am besten jetzt auf die neusten adapterversionen und Betriebsysteme update. Ich würde es so machen im iobroker die Adapter über das ui updaten dann das Betriebsystem über putty updaten zum Schluss den iobroker über putti updaten dann Backup von der sd karte dann bachup über das ui von iobroker. Wäre das so ok
