Fehler im ioBroker
@codierknecht
und dann die adapter installiert mit ihren instanzen und davor gab es keine Fehler npm audit ist ohne Fehler durch gelaufenpi@ioBrokerPi:/opt/iobroker $ iob update Used repository: stable Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "alarm" : 3.3.9 , installed 3.3.9 Adapter "backitup" : 2.6.19 , installed 2.6.19 Adapter "bmw" : 2.5.7 , installed 2.5.7 Adapter "cloud" : 4.3.0 , installed 4.4.1 Adapter "daswetter" : 3.1.8 , installed 3.1.8 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "geofency" : 1.2.4 , installed 1.2.4 Adapter "homeconnect" : 1.1.1 , installed 1.1.1 Adapter "homekit-controller": 0.5.8, installed 0.5.8 Adapter "javascript" : 6.1.4 , installed 6.1.4 Controller "js-controller": 4.0.24 , installed 4.0.24 Adapter "landroid" : 1.0.3 , installed 1.0.3 Adapter "lg-thinq" : 0.1.4 , installed 0.1.4 Adapter "loxone" : 3.0.1 , installed 3.0.1 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "nina" : 0.0.25 , installed 0.0.25 Adapter "node-red" : 4.0.0 , installed 4.0.3 Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "samsung" : 0.5.11 , installed 0.5.11 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "solarwetter" : 1.0.0 , installed 1.0.2 Adapter "weatherunderground": 3.4.2, installed 3.4.2 Adapter "worx" : 2.1.3 , installed 2.1.3 Adapter "yahka" : 0.17.0 , installed 0.17.0 pi@ioBrokerPi:/opt/iobroker $
@tomme
Was sagt denniob diag
@codierknecht said in Fehler im ioBroker:
iob diag
Teil 1
Skript v.2023-04-16 *** BASE SYSTEM *** Model : Raspberry Pi 4 Model B Rev 1.5 Architecture : aarch64 Docker : false Virtualization : none Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" Systemuptime and Load: 21:58:49 up 1 day, 20:28, 4 users, load average: 0.46, 0.33, 0.34 CPU threads: 4 Raspberry only: throttled=0x0 Other values than 0x0 hint to temperature/voltage problems temp=54.0'C volt=0.9260V *** Time and Time Zones *** Local time: Thu 2023-04-27 21:58:50 CEST Universal time: Thu 2023-04-27 19:58:50 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker *** X-Server-Setup *** X-Server: true Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 2.5G 1.5G 78M 3.7G 5.0G Swap: 3.7G 0B 3.7G Total: 11G 2.5G 5.2G 7811 M total memory 2550 M used memory 3142 M active memory 2003 M inactive memory 1513 M free memory 328 M buffer memory 3418 M swap cache 3683 M total swap 0 M used swap 3683 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 24G 8.1G 15G 36% / devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 1.4M 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sda1 vfat 255M 31M 225M 13% /boot tmpfs tmpfs 782M 36K 782M 1% /run/user/1000 /dev/sda4 fuseblk 1000M 321M 680M 33% /media/pi/Austausch-USB /dev/mmcblk0p4 ext4 12G 312M 11G 3% /media/pi/Austausch-SD /dev/mmcblk0p2 ext4 14G 11G 2.1G 84% /media/pi/writable /dev/mmcblk0p1 vfat 253M 120M 133M 48% /media/pi/system-boot //192.168.7.1/BackItUp cifs 238G 183G 55G 77% /opt/iobroker/backups //192.168.7.1/BackItUp/ cifs 238G 183G 55G 77% /opt/iobroker/backups //192.168.7.1/ioBrokerPi cifs 238G 183G 55G 77% /mnt/LaptopIoBrokerPi Messages concerning ext4 filesystem in dmesg: [Wed Apr 26 01:30:03 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0A:D6:44 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=ee423409-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Wed Apr 26 01:30:06 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Wed Apr 26 01:30:06 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Wed Apr 26 01:30:08 2023] EXT4-fs (sda2): re-mounted. Quota mode: none. [Wed Apr 26 01:30:33 2023] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Quota mode: none. [Wed Apr 26 01:30:34 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime |-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro |-/mnt/LaptopIoBrokerPi //192.168.7.1/ioBrokerPi cifs rw,relatime,vers=2.1,cache=strict,username=Tomme,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.7.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5 |-/media/pi/Austausch-USB /dev/sda4 fuseblk rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 |-/media/pi/Austausch-SD /dev/mmcblk0p4 ext4 rw,nosuid,nodev,relatime,errors=remount-ro |-/media/pi/writable /dev/mmcblk0p2 ext4 rw,nosuid,nodev,relatime,errors=remount-ro |-/media/pi/system-boot /dev/mmcblk0p1 vfat rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro `-/opt/iobroker/backups //192.168.7.1/BackItUp cifs rw,relatime,vers=2.1,cache=strict,username=Tomme,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.7.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5 `-/opt/iobroker/backups //192.168.7.1/BackItUp/ cifs rw,relatime,vers=2.0,cache=strict,username=Tomme,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.7.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5 Files in neuralgic directories: /var: 1.2G /var/ 491M /var/cache 482M /var/cache/apt 381M /var/cache/apt/archives 326M /var/log Archived and active journals take up 304.1M in the file system. /opt/iobroker/backups: 6.2M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 269M /opt/iobroker/iobroker-data/ 132M /opt/iobroker/iobroker-data/node-red/node_modules 132M /opt/iobroker/iobroker-data/node-red 91M /opt/iobroker/iobroker-data/files 51M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 14M /opt/iobroker/iobroker-data/objects.jsonl 11M /opt/iobroker/iobroker-data/states.jsonl 7.8M /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.52e68e8c.js 6.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map *** NodeJS-Installation *** /usr/bin/nodejs v18.16.0 /usr/bin/node v18.16.0 /usr/bin/npm 9.5.1 /usr/bin/npx 9.5.1 nodejs: Installed: 18.16.0-deb-1nodesource1 Candidate: 18.16.0-deb-1nodesource1 Version table: *** 18.16.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u3 500 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages 12.22.5~dfsg-2~11u1 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl MULTIHOSTSERVICE/enabled: false Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: 6.1.4 Adapters from github: 2 Adapter State + system.adapter.admin.0 : admin : ioBrokerPi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alarm.0 : alarm : ioBrokerPi - enabled + system.adapter.backitup.0 : backitup : ioBrokerPi - enabled + system.adapter.bmw.0 : bmw : ioBrokerPi - enabled + system.adapter.cloud.0 : cloud : ioBrokerPi - enabled system.adapter.daswetter.0 : daswetter : ioBrokerPi - enabled + system.adapter.discovery.0 : discovery : ioBrokerPi - enabled system.adapter.dwd.0 : dwd : ioBrokerPi - enabled + system.adapter.geofency.0 : geofency : ioBrokerPi - enabled, port: 7999, bind: 0.0.0.0 + system.adapter.homeconnect.0 : homeconnect : ioBrokerPi - enabled + system.adapter.homekit-controller.0 : homekit-controller : ioBrokerPi - enabled + system.adapter.javascript.0 : javascript : ioBrokerPi - enabled system.adapter.landroid.0 : landroid : ioBrokerPi - disabled + system.adapter.lg-thinq.0 : lg-thinq : ioBrokerPi - enabled + system.adapter.loxone.0 : loxone : ioBrokerPi - enabled, port: 80 + system.adapter.net-tools.0 : net-tools : ioBrokerPi - enabled + system.adapter.nina.0 : nina : ioBrokerPi - enabled + system.adapter.node-red.0 : node-red : ioBrokerPi - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.ping.0 : ping : ioBrokerPi - enabled system.adapter.reolink.0 : reolink : ioBrokerPi - disabled + system.adapter.reolink.1 : reolink : ioBrokerPi - disabled + system.adapter.reolink.2 : reolink : ioBrokerPi - enabled system.adapter.reolink.3 : reolink : ioBrokerPi - disabled system.adapter.reolink.4 : reolink : ioBrokerPi - disabled system.adapter.reolink.5 : reolink : ioBrokerPi - disabled + system.adapter.samsung.0 : samsung : ioBrokerPi - enabled + system.adapter.simple-api.0 : simple-api : ioBrokerPi - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.solarwetter.0 : solarwetter : ioBrokerPi - enabled system.adapter.weatherunderground.0 : weatherunderground : ioBrokerPi - enabled system.adapter.weatherunderground.1 : weatherunderground : ioBrokerPi - enabled + system.adapter.worx.0 : worx : ioBrokerPi - enabled + system.adapter.yahka.0 : yahka : ioBrokerPi - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : ioBrokerPi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.geofency.0 : geofency : ioBrokerPi - enabled, port: 7999, bind: 0.0.0.0 + system.adapter.loxone.0 : loxone : ioBrokerPi - enabled, port: 80 + system.adapter.node-red.0 : node-red : ioBrokerPi - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : ioBrokerPi - enabled, port: 8087, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "alarm" : 3.3.9 , installed 3.3.9 Adapter "backitup" : 2.6.19 , installed 2.6.19 Adapter "bmw" : 2.5.7 , installed 2.5.7 Adapter "cloud" : 4.3.0 , installed 4.4.1 Adapter "daswetter" : 3.1.8 , installed 3.1.8 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "geofency" : 1.2.4 , installed 1.2.4 Adapter "homeconnect" : 1.1.1 , installed 1.1.1 Adapter "homekit-controller": 0.5.8, installed 0.5.8 Adapter "javascript" : 6.1.4 , installed 6.1.4 Controller "js-controller": 4.0.24 , installed 4.0.24 Adapter "landroid" : 1.0.3 , installed 1.0.3 Adapter "lg-thinq" : 0.1.4 , installed 0.1.4 Adapter "loxone" : 3.0.1 , installed 3.0.1 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "nina" : 0.0.25 , installed 0.0.25 Adapter "node-red" : 4.0.0 , installed 4.0.3 Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "samsung" : 0.5.11 , installed 0.5.11 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "solarwetter" : 1.0.0 , installed 1.0.2 Adapter "weatherunderground": 3.4.2, installed 3.4.2 Adapter "worx" : 2.1.3 , installed 2.1.3 Adapter "yahka" : 0.17.0 , installed 0.17.0 Objects and States Please stand by - This may take a while Objects: 10450 States: 8419 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease Hit:4 http://deb.debian.org/debian bullseye-updates InRelease Hit:5 https://linux.teamviewer.com/deb stable InRelease Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease Hit:7 https://repo.homebridge.io stable InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:39619 0.0.0.0:* LISTEN 116 1027712 218340/homebridge: tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 612208 218206/node-red tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN 0 734 623/vncserver-x11-c tcp 0 0 0.0.0.0:5938 0.0.0.0:* LISTEN 0 1017263 406348/teamviewerd tcp 0 0 127.0.0.1:44549 0.0.0.0:* LISTEN 1001 616532 218875/io.yahka.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 638 656/sshd: /usr/sbin tcp 0 0 127.0.0.1:40435 0.0.0.0:* LISTEN 116 612338 218278/homebridge tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 610697 216843/iobroker.js- tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 612593 216843/iobroker.js- tcp 0 0 0.0.0.0:44083 0.0.0.0:* LISTEN 1001 614202 218875/io.yahka.0 tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 15354 921/exim4 tcp 0 0 127.0.0.1:36971 0.0.0.0:* LISTEN 116 1025518 218278/homebridge tcp 0 0 127.0.0.1:5939 0.0.0.0:* LISTEN 0 1017265 406348/teamviewerd tcp 0 0 127.0.0.1:6011 0.0.0.0:* LISTEN 1000 1356322 608524/sshd: pi@pts tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN 1000 1356914 608219/sshd: pi@pts tcp 0 0 127.0.0.1:46197 0.0.0.0:* LISTEN 116 1026919 218278/homebridge tcp6 0 0 :::54900 :::* LISTEN 116 612034 218346/homebridge: tcp6 0 0 :::5900 :::* LISTEN 0 733 623/vncserver-x11-c tcp6 0 0 :::5938 :::* LISTEN 0 1017261 406348/teamviewerd tcp6 0 0 :::34623 :::* LISTEN 116 612084 218340/homebridge: tcp6 0 0 ::1:25 :::* LISTEN 0 15355 921/exim4 tcp6 0 0 ::1:6011 :::* LISTEN 1000 1356321 608524/sshd: pi@pts tcp6 0 0 ::1:6010 :::* LISTEN 1000 1356913 608219/sshd: pi@pts tcp6 0 0 :::22 :::* LISTEN 0 640 656/sshd: /usr/sbin tcp6 0 0 :::41095 :::* LISTEN 116 611079 218339/homebridge: tcp6 0 0 :::8581 :::* LISTEN 116 613689 216910/hb-service tcp6 0 0 :::40463 :::* LISTEN 116 613864 218358/homebridge: tcp6 0 0 :::7999 :::* LISTEN 1001 611931 218198/io.geofency. tcp6 0 0 :::8087 :::* LISTEN 1001 616493 218783/io.simple-ap tcp6 0 0 :::8081 :::* LISTEN 1001 611773 216947/io.admin.0 tcp6 0 0 :::56771 :::* LISTEN 116 611115 218347/homebridge: tcp6 0 0 :::51619 :::* LISTEN 116 613763 218278/homebridge udp 0 0 0.0.0.0:68 0.0.0.0:* 0 16458 520/dhcpcd udp 0 0 0.0.0.0:58508 0.0.0.0:* 108 15402 442/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 614207 218875/io.yahka.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 614206 218875/io.yahka.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 615470 218634/io.homekit-c udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 613242 218206/node-red udp 0 0 0.0.0.0:5353 0.0.0.0:* 116 613686 216910/hb-service udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 15400 442/avahi-daemon: r udp6 0 0 :::5353 :::* 108 15401 442/avahi-daemon: r udp6 0 0 :::59619 :::* 108 15403 442/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-04-27 21:40:24.303 - info: bmw.0 (413780) Found 1 bmw vehicles 2023-04-27 21:42:58.735 - info: worx.0 (218834) No payload found 2023-04-27 21:45:00.055 - info: host.ioBrokerPi instance system.adapter.dwd.0 started with pid 620555 2023-04-27 21:45:02.739 - info: dwd.0 (620555) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24 2023-04-27 21:45:04.095 - info: host.ioBrokerPi instance system.adapter.daswetter.0 started with pid 620582 2023-04-27 21:45:04.828 - info: dwd.0 (620555) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-04-27 21:45:05.383 - info: host.ioBrokerPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-04-27 21:45:06.599 - info: daswetter.0 (620582) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.0, js-controller: 4.0.24 2023-04-27 21:45:07.765 - info: daswetter.0 (620582) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment 2023-04-27 21:45:08.284 - info: daswetter.0 (620582) cleaned everything up... 2023-04-27 21:45:08.303 - info: host.ioBrokerPi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-04-27 21:45:25.456 - info: bmw.0 (413780) Found 1 bmw vehicles 2023-04-27 21:50:00.046 - info: host.ioBrokerPi instance system.adapter.dwd.0 started with pid 621711 2023-04-27 21:50:02.542 - info: dwd.0 (621711) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24 2023-04-27 21:50:04.536 - info: dwd.0 (621711) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-04-27 21:50:05.121 - info: host.ioBrokerPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-04-27 21:50:24.777 - info: bmw.0 (413780) Found 1 bmw vehicles 2023-04-27 21:50:36.029 - info: homekit-controller.0 (218634) IP-7A:0C:6C:53:B1:DF (Bungalow) found without known pairing data and already paired: ignoring 2023-04-27 21:52:46.685 - info: admin.0 (216947) ==> Connected system.user.admin from ::ffff:192.168.7.1 2023-04-27 21:52:58.784 - info: worx.0 (218834) No payload found 2023-04-27 21:55:00.047 - info: host.ioBrokerPi instance system.adapter.dwd.0 started with pid 623022 2023-04-27 21:55:02.716 - info: dwd.0 (623022) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24 2023-04-27 21:55:04.411 - info: dwd.0 (623022) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-04-27 21:55:05.000 - info: host.ioBrokerPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-04-27 21:55:24.661 - info: bmw.0 (413780) Found 1 bmw vehicles ============ Mark until here for C&P ============= iob diag has finished. Press any key for a summary
Copy text starting here: ======================= SUMMARY ======================= v.2023-04-16 Operatingsystem: Debian GNU/Linux 11 (bullseye) Kernel: 6.1.21-v8+ Installation: Native Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 X-Server: true Boot Target: graphical.target Pending OS-Updates: 0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v18.16.0 /usr/bin/node v18.16.0 /usr/bin/npm 9.5.1 /usr/bin/npx 9.5.1 Recommended versions are nodejs 18.x.y and npm 9.x.y Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.8G 2.5G 1.5G 78M 3.8G 5.0G Swap: 3.7G 0B 3.7G Total: 11G 2.5G 5.2G Active iob-Instances: 23 Active repo(s): stable ioBroker Core: js-controller 4.0.24 admin 6.3.5 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : ioBrokerPi - enabled, port: 8081, bind: 0.0.0.0, run as: admin Objects: 10450 States: 8419 Size of iob-Database: 14M /opt/iobroker/iobroker-data/objects.jsonl 12M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ==================== pi@ioBrokerPi:/opt/iobroker $
iwi fehlt da immer der reolink adapter ... davon habe ich 6 instanzen ... aber wird nicht angezeigt ich schau mal ob die gelöscht sind ;/
... sind noch da
@tomme
Da läuft ein Desktop. Der hat auf 'nem Server nix verloren.
Und das Boot-Target sollte dann auch gleich aufmulti-user.target
umgestellt werden. -
den desktop schalte ich aus wenn alles läuft
und von dem anderen habe ich keine ahnung ... leider
hab ich jetzt was falsch gemacht?
pi@ioBrokerPi:/opt/iobroker $ iob setup Successfully migrated 10450 objects to Redis Sets object 0_userdata.0.example_state yet exists object 0_userdata.0 yet exists object alias.0 yet exists object system.certificates yet exists object system.licenses yet exists object system.repositories yet exists object system.config yet exists object enum.functions yet exists object enum.rooms yet exists object system.group.user yet exists object system.group.administrator yet exists object _design/system updated pi@ioBrokerPi:/opt/iobroker $
@tomme sagte in Fehler im ioBroker:
Wenn Du den nur ausschaltest, schleppst Du den Kram ja trotzdem weiterhin mit.
Nur damit da keine falsche Hoffnung aufkommt: Ich auch nicht wirklich - ich nutze an der Ecke einen fertigen Container.
Vielleicht kann ja mal @Thomas-Braun hier drüberschauen?
woher weißt du wie ich heiße??? ist ja witzig
an docker habe ich mich noch nicht ran getraut ... wollte erstmal hiermit klar kommen
Finger weg von
npm audit fix --force
Das zieht dir ggfls. unwiederbringlich die Installation auf Links.
Und ein Desktop inkl. Teamviewer hat auf einem Server nic verloren.
Installier es neu, diesmal gescheit.
moin,
alles neu?
kriegen wir wenigstens das backup vorher zum laufen???
teamviewer ist schnell gelöscht -
Hast du etwa keins von vor dem Blödsinn?
na nee darum bin ich ja hier ...
du heißt übrigens genau wie ich ... das ist sehr löblich
@codierknecht sagte in Fehler im ioBroker:
Wie hast Du den denn installiert?
Mit dem (auch noch per --force) reingeballerten audit fix.
Der installiert dann ohne Rücksicht auf Verluste die letzte Version, die den auditierten Fehler noch nicht enthält.
Und deswegen lässt man die Finger von dem Befehl.
Von dem Trümmerfeld brauchste jetzt auch kein Backup mehr machen.
@thomas-braun said in Fehler im ioBroker:
Und deswegen lässt man die Finger von dem Befehl.ich gelobe besserung! das hab ich aus irgend einem forumbeitrag im raspiforum gefischt ...
ich bin echt totaler frischling -
Warum installierst du nodejs überhaupt separat?
Die passende Version kommt mit dem iobroker-Installer auf das System.
