    4. MieleCloudService Adapter
    • Marc Berg
      Marc Berg Most Active @Grizzelbee last edited by Marc Berg
      @grizzelbee Nach dem Update startet der Adapter nicht mehr:
      2023-03-22 08:19:13.400 - error: mielecloudservice.0 (42886) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-03-22 08:19:13.401 - error: mielecloudservice.0 (42886) unhandled promise rejection: oauth.client is not a function
      2023-03-22 08:19:13.402 - error: mielecloudservice.0 (42886) TypeError: oauth.client is not a function
      at /opt/iobroker/node_modules/iobroker.mielecloudservice/source/mieleTools.js:85:49
      at new Promise ()
      at module.exports.getAuth (/opt/iobroker/node_modules/iobroker.mielecloudservice/source/mieleTools.js:82:12)
      at /opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:239:49
      at async Mielecloudservice.onReady (/opt/iobroker/node_modules/iobroker.mielecloudservice/main.js:237:17)
      2023-03-22 08:19:13.402 - error: mielecloudservice.0 (42886) oauth.client is not a function
      2023-03-22 08:19:13.411 - warn: mielecloudservice.0 (42886) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-03-22 08:19:13.964 - error: host.iobroker instance system.adapter.mielecloudservice.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-03-22 08:19:45.091 - error: mielecloudservice.0 (42925) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-03-22 08:19:45.092 - error: mielecloudservice.0 (42925) unhandled promise rejection: oauth.client is not a function
      2023-03-22 08:19:45.093 - error: mielecloudservice.0 (42925) TypeError: oauth.client is not a function
      at new Promise ()
      2023-03-22 08:19:45.093 - error: mielecloudservice.0 (42925) oauth.client is not a function
      2023-03-22 08:19:45.102 - warn: mielecloudservice.0 (42925) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-03-22 08:19:45.672 - error: host.iobroker instance system.adapter.mielecloudservice.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-03-22 08:20:10.311 - error: mielecloudservice.0 (42964) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-03-22 08:20:10.312 - error: mielecloudservice.0 (42964) unhandled promise rejection: oauth.client is not a function
      2023-03-22 08:20:10.313 - error: mielecloudservice.0 (42964) TypeError: oauth.client is not a function
      at new Promise ()
      2023-03-22 08:20:10.314 - error: mielecloudservice.0 (42964) oauth.client is not a function
      2023-03-22 08:20:10.329 - warn: mielecloudservice.0 (42964) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-03-22 08:20:10.897 - error: host.iobroker instance system.adapter.mielecloudservice.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-03-22 08:20:10.898 - warn: host.iobroker Do not restart adapter system.adapter.mielecloudservice.0 because restart loop detected
      Ich habe Node 18 installiert, falls das wichtig ist.
      Marc Berg Grizzelbee 2 Replies Last reply Reply Quote 0
      • Marc Berg
        Marc Berg Most Active @Marc Berg last edited by Marc Berg
        gelöscht
        • Grizzelbee
          Grizzelbee Developer @Marc Berg last edited by Grizzelbee
          @marc-berg sagte in MieleCloudService Adapter:
          Hmm. Komisch. Keine Ahnung wo das jetzt plötzlich herkommt.
          Gucke ich mir mal genauer an ...
          Danke für die Info.
          HomeZecke 1 Reply Last reply Reply Quote 0
          • HomeZecke
            HomeZecke @Grizzelbee last edited by
            @grizzelbee Hallo!
            Also den Adapter habe ich installiert bekommen. Aber ich kann keine Instanz hinzufügen. Immer noch :
            Invalid version of node. Required ^14.0.0. Current 16.18.1
            Ich bin zurück auf Version 6.30. Aber das gleiche Problem.
            Grüße..
            Grizzelbee 1 Reply Last reply Reply Quote 0
            • Grizzelbee
              Grizzelbee Developer @HomeZecke last edited by
              @homezecke
              Dann ist bei der Installation etwas schief gelaufen.
              Dieses Problem mit der Node-Version ist definitiv nur in der nie wirklich veröffentlichten Version 6.4.1 enthalten.
              Das "requires node ^14.0.0." bedeutet: Eine Version, die kompatibel ist zu node 14.0.0.
              In der Version 6.5.0-beta1 steht aber: "node": ">=14.0.0".
              Das bedeutet: Das was Du installiert hast, ist entweder die 6.4.1 oder ein Mischmasch aus verschienen Versionen.
              Am besten löschst Du den Adapter und installierst von git komplett neu.
              • HomeZecke
                @grizzelbee
                Habe den Adapter jetzt noch einmal gelöscht. Und dann von git neu installiert. Aber ich kann immer noch keine Instanz erzeugen.
                • HomeZecke
                  HomeZecke @HomeZecke last edited by
                  heute noch einmal probiert und da hat es geklappt. Habe jetzt die 6.4.0 drauf. Komisch, ich konnte heute bei keinem meiner Adapter mehr eine Instanz erstellen. Kam immer die Meldung ich solle erst node installieren. Nach einem Browserreload ging es dann. Auch mit MieleCloudService.😊
                  Grüße..
                    Tobi68 last edited by
                    Kommt bei euch die Restzeit auch nicht mehr durch?
                      patrikp @Grizzelbee last edited by
                      @grizzelbee Heute habe ich den Adapter installiert. Ich möchte damit die Temperatur an einem Ofen vom Typ 12 steuern. Leider scheint sich der Ofen und das Licht gerade mal ein- und ausschalten, und ansonsten keine weiteren Actions möglich. Ist das richtig, oder mache ich etwa falsch. Die targetTemperatureZone-1 ist nicht zu verändern (so steht es auch in den device capabilities 1.0.6 von Miele), und müsste damit m. E. aus den Actions raus. Letzteres nur als Bemerkung/Anregung von mir.
                      Mit besten Grüßen
                      Patrik
                      • Grizzelbee
                        Grizzelbee Developer @patrikp last edited by
                        @patrikp
                        Hallo Patrik,
                        Da hast Du den wunden Punkt des Adapters gefunden - bist allerdings (anscheinend) auch der erste, der einen Ofen mit dem Adapter steuern möchte. 😉
                        Das Problem ist etwas größer:
                        • Der Ofen und die API können das grundsätzlich - über den Endpunkt /programs
                        Ich habe nur noch keine gute Idee gehabt, wie ich die dort geforderte Struktur, bzw. die dort geforderten Informationen, in unmissverständliche Datenpunkte für den ioB umsetze um sie dann bei Bedarf an die API zu senden. Unnötig zu erwähnen das es für andere Geräte andere Programme und Informationen gibt - was die Sache nicht einfacher und/oder strukturierter macht und ebenfalls nicht bedeutet, das es mit diesen Daten getan ist. Und - natürlich - müssen die Daten so abgelegt sein, dass man sie auch vernünftig in einer Visualisierung darstellen und ändern/einstellen kann.
                        Da ich aber keinen Ofen habe und bislang niemand danach gefragt hat, ist es aktuell, wie es ist. 😉 Das müsste ich also in einem zukünftigen Release einbauen - und: Nein. In der heute veröffentlichten/eingereichten v6.5.4 ist das noch nicht drin.
                        Wenn Du gute Ideen für die Umsetzung hast - immer her damit.
                        viele Grüße
                        Grizzelbee
                        HomeZecke K 2 Replies Last reply Reply Quote 0
                        • HomeZecke
                          @grizzelbee
                          Hallo!
                          Bei "API-Antwortsprache" kann ich einstellen was ich will, es ist immer auf Englisch..
                          Grüße...
                          Grizzelbee O 2 Replies Last reply Reply Quote 0
                          • Grizzelbee
                            Grizzelbee Developer @HomeZecke last edited by Grizzelbee
                            @homezecke
                            Ja - das Problem ist bekannt und tritt auch bei mir mit verschiedenen neuen und alten Versionen auf:
                            https://github.com/Grizzelbee/ioBroker.mielecloudservice/issues/376
                            Es scheint sich dabei um ein Problem bei Miele zu handeln - ich stehe lose mit denen in Kontakt. Noch behaupten sie das käme nicht von denen. Mal abwarten was draus wird.
                            Hinweis Für dieses spezielle Problem bitte den Thread https://forum.iobroker.net/topic/65927/klartextwerte-eines-adapters-plötzlich-alle-auf-englisch/7?_=1685868096679 oder den gitHub issue verwenden. Sonst müssen wir das an drei Stellen pflegen ... 😉
                            Jailobeam created this issue in Grizzelbee/ioBroker.mielecloudservice
                            closed Miele API-Antwortsprache immer Englisch #376
                            • O
                              oxident @HomeZecke last edited by
                              @homezecke Ja, das ist einigen Tagen so. Hat der Entwickler auch schon an Miele gemeldet.
                              Ist etwas ärgerlich wenn man auf die DP triggert... aber ist bestimmt bald gefixt.
                              Oder aber, man nutzt immer die englische Version. Dann ist man auf der sicheren Seite.
                              • Grizzelbee
                                Grizzelbee Developer @Grizzelbee last edited by
                                @HomeZecke
                                Miele hat soeben den Bug auf seiner Seite bestätigt:
                                Hallo Hanjo,
                                wir haben tatsächlich ein Problem mit dem Lokalisierungsservice. Der Bug ist eingestellt und wird kurzfristig bearbeitet.
                                Kind regards
                                Miele 3rd party API Team
                                Fix ist auf dem Weg ...
                                HomeZecke 1 Reply Last reply Reply Quote 2
                                • HomeZecke
                                  @grizzelbee
                                  Danke...👍
                                    deta Most Active last edited by
                                    Gerde von Miele gekommen.
                                     Technische Information
                                    Miele App
                                    Sehr geehrte Miele-Kundin, geehrter Miele-Kunde,
                                    am 14.06.2023 werden Sie automatisch aus der Miele App ausgeloggt. Grund dafür ist ein technisches Update der Authentifizierung.
                                    Damit Sie sich nach diesem Update wieder problemlos einloggen können, empfehlen wir Ihnen Folgendes:
                                        Aktualisieren Sie Ihre App auf die neueste Version. Dieser Schritt wird normalerweise automatisch durchgeführt und ist nur notwendig, wenn Sie die automatischen Updates deaktiviert haben. In diesem Fall können Sie die App über den App Store aktualisieren.
                                        Halten Sie Ihre Zugangsdaten bereit. Sie haben Ihr Passwort vergessen? Dann können Sie über die Miele-App ein neues Passwort anfordern.
                                    Mit freundlichen Grüßen
                                    Ihr Miele-App-Team
                                    • O
                                      oxident last edited by
                                      Oh oh ... hoffe, @Grizzelbee hat Zeit, sich das anzuschauen. Sonst ist der Adapter vielleicht erstmal stillgelegt.
                                      • Grizzelbee
                                        Grizzelbee Developer @oxident last edited by
                                        @oxident sagte in MieleCloudService Adapter:
                                        Tatsächlich gehe ich davon aus dass genau das Gegenteil passiert. Für mich scheint es so zu sein, das Miele den Sprachparameter beim SSE-Login ignoriert und deswegen alles in Englisch kommt. Ich gehe zur Zeit davon aus dass die genau das an dem Termin fixen - was bedeuten würde dass der Adapter danach wieder richtig funktionieren sollte. 🙂
                                        Homoran 1 Reply Last reply Reply Quote 2
                                          Homoran Global Moderator Administrators @Grizzelbee last edited by
                                          @grizzelbee passt!
                                          hier gab es noch so einen Thread
                                          https://forum.iobroker.net/topic/65927/klartextwerte-eines-adapters-plötzlich-alle-auf-englisch?_=1686236347538
                                          • Grizzelbee
                                            @homezecke @deta
                                            Bei mir läuft das jetzt wieder richtig in deutsch - das darf also als gelöst betrachtet werden.
                                            HomeZecke 1 Reply Last reply Reply Quote 1
                                            miele mieleathome mielecloudservice
                                            90
                                            849
                                            203342
