    3. Off Topic
    4. Proxmox
    5. Proxmox / Influxdb V1 zu V2... wie?
    • Chris76e
      Chris76e @Guest last edited by
      @dp20eic
      Backup habe ich, teste das zuerst auch mit einem Clone LXC unter Proxmox.
      gehe jetzt nach dieser Anleitung
      https://linux.how2shout.com/how-to-install-influxdb-on-ubuntu-22-04-to-create-database/
      Jetzt kommen aber die ersten Fehler wenn ich an Punkt 4 der Anleitung bin
      chris@influxtest:~$ sudo apt update
      Hit:1 https://repos.influxdata.com/debian stable InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
      Hit:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
      Reading package lists... Done
      Building dependency tree... Done
      1 package can be upgraded. Run 'apt list --upgradable' to see it.
      chris@influxtest:~$ sudo apt list --upgradable
      Listing... Done
      influxdb/unknown 1.8.10-1 amd64 [upgradable from: 1.6.7~rc0-1ubuntu0.22.04.2]
      N: There are 2 additional versions. Please use the '-a' switch to see them.
      chris@influxtest:~$ ^C
      chris@influxtest:~$ sudo apt install influxdb2
      The following additional packages will be installed:
        influxdb2-cli
      The following packages will be REMOVED:
        influxdb
      The following NEW packages will be installed:
        influxdb2 influxdb2-cli
      0 upgraded, 2 newly installed, 1 to remove and 0 not upgraded.
      1 not fully installed or removed.
      Need to get 57.3 MB of archives.
      After this operation, 112 MB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Get:1 https://repos.influxdata.com/debian stable/main amd64 influxdb2 amd64 2.7.1-1 [45.9 MB]
      Get:2 https://repos.influxdata.com/debian stable/main amd64 influxdb2-cli amd64 2.7.3-1 [11.5 MB]
      Fetched 57.3 MB in 1s (48.9 MB/s)
      (Reading database ... 20839 files and directories currently installed.)
      Removing influxdb (1.6.7~rc0-1ubuntu0.22.04.2) ...
      Selecting previously unselected package influxdb2.
      (Reading database ... 20833 files and directories currently installed.)
      Preparing to unpack .../influxdb2_2.7.1-1_amd64.deb ...
      Unpacking influxdb2 (2.7.1-1) ...
      Selecting previously unselected package influxdb2-cli.
      Preparing to unpack .../influxdb2-cli_2.7.3-1_amd64.deb ...
      Unpacking influxdb2-cli (2.7.3-1) ...
      dpkg: error processing archive /var/cache/apt/archives/influxdb2-cli_2.7.3-1_amd64.deb (--unpack):
       trying to overwrite '/usr/bin/influx', which is also in package influxdb-client 1.6.7~rc0-1ubuntu0.22.04.2
      dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
      Errors were encountered while processing:
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      chris@influxtest:~$
        A Former User @Chris76e last edited by A Former User
        @chris76e
        Moin,
        Du hast bei Dir auch die CLI aus dem influxDB V 1.6 installiert, daher kann apt nicht die Version 2.x darüber installieren, Du musst erst das Paket deinstallieren
        VG
        Bernd
        P.S.: bevor Du weiter machst, schau auch mal hier wie es weitergeht, nach dem Update von influxDb https://docs.influxdata.com/influxdb/v2.7/upgrade/v1-to-v2/ da ist beschrieben wie man die V1.x Datenbank nach V. 2.x migriert.
        Chris76e 1 Reply Last reply Reply Quote 0
        • Chris76e
          @dp20eic sagte in Proxmox / Influxdb V1 zu V2... wie?:
          Die Anleitung ist ja die, die ich nicht verstehe???
          Thomas Braun ? 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @Chris76e last edited by
            @chris76e
            sudo apt remove influxdb-client
            sudo apt update
            Erst danach kann influxdb2 und des Client-Paket dazu installiert werden.
            • Chris76e
              Jetzt bin ich weiter gekommen, kann aber influx nicht mehr starten
              Failed to start influxdb.service: Unit influxdb.service is masked
              chris@influxdbtest:~$ sudo apt install influxdb2
                influxdb2-cli
                influxdb
              0 upgraded, 2 newly installed, 1 to remove and 1 not upgraded.
              Fetched 57.3 MB in 1s (51.1 MB/s)
              Removing influxdb (1.6.7~rc0-1ubuntu0.22.04.1) ...
              (Reading database ... 20826 files and directories currently installed.)
              Setting up influxdb2 (2.7.1-1) ...
              Synchronizing state of influxdb.service with SysV service script with /lib/systemd/systemd-sysv-install.
              Executing: /lib/systemd/systemd-sysv-install enable influxdb
              Failed to enable unit: Unit file /etc/systemd/system/influxdb.service is masked.
              ! Important 1.x to 2.x Upgrade Notice !
              Thank you for installing InfluxDB v2.  Due to significant changes between
              the v1 and v2 versions, upgrading to v2 requires additional steps.  If
              upgrading to v2 was not intended, simply re-install the v1 package now.
              An upgrade helper script is available that should be reviewed and executed
              prior to starting the influxdb systemd service.  In order to start the v2
              upgrade, execute the following:
              sudo /usr/share/influxdb/influxdb2-upgrade.sh
              Visit our website for complete details on the v1 to v2 upgrade process:
              https://docs.influxdata.com/influxdb/latest/upgrade/v1-to-v2/
              For new or upgrade installations, please review the getting started guide:
              https://docs.influxdata.com/influxdb/latest/get-started/
              Setting up influxdb2-cli (2.7.3-1) ...
              Processing triggers for man-db (2.10.2-1) ...
              chris@influxdbtest:~$ sudo -u influxdb influxd upgrade
              {"level":"info","ts":1683120477.123403,"caller":"upgrade/upgrade.go:401","msg":"Starting InfluxDB 1.x upgrade"}
              {"level":"info","ts":1683120477.123551,"caller":"upgrade/upgrade.go:404","msg":"Upgrading config file","file":"/etc/influxdb/influxdb.conf"}
              {"level":"info","ts":1683120477.1238437,"caller":"upgrade/upgrade.go:408","msg":"Config file upgraded.","1.x config":"/etc/influxdb/influxdb.conf","2.x config":"/var/lib/influxdb/.influxdbv2/config.toml"}
              {"level":"info","ts":1683120477.1238594,"caller":"upgrade/upgrade.go:418","msg":"Upgrade source paths","meta":"/var/lib/influxdb/meta","data":"/var/lib/influxdb/data"}
              {"level":"info","ts":1683120477.1239064,"caller":"upgrade/upgrade.go:419","msg":"Upgrade target paths","bolt":"/var/lib/influxdb/.influxdbv2/influxd.bolt","engine":"/var/lib/influxdb/.influxdbv2/engine"}
              {"level":"info","ts":1683120477.147437,"caller":"bolt/bbolt.go:83","msg":"Resources opened","service":"bolt","path":"/var/lib/influxdb/.influxdbv2/influxd.bolt"}
              {"level":"info","ts":1683120477.1527815,"caller":"migration/migration.go:175","msg":"Bringing up metadata migrations","service":"migrations","migration_count":20}
              > Welcome to InfluxDB 2.0!
              ? Please type your primary username admin
              ? Please type your password ******
              X Sorry, your reply was invalid: value is too short. Min length is 8
              ? Please type your password **********
              ? Please type your password again **********
              ? Please type your primary organization name iob
              ? Please type your primary bucket name iobroker3
              ? Please type your retention period in hours, or 0 for infinite 0
              ? Setup with these parameters?
                Username:          admin
                Organization:      iob
                Bucket:            iobroker3
                Retention Period:  infinite
               Yes
              {"level":"info","ts":1683120634.533276,"caller":"upgrade/setup.go:73","msg":"CLI config has been stored.","path":"/var/lib/influxdb/.influxdbv2/configs"}
              {"level":"info","ts":1683120634.533326,"caller":"upgrade/database.go:202","msg":"Checking available disk space"}
              {"level":"info","ts":1683120634.5367415,"caller":"upgrade/database.go:223","msg":"Computed disk space","free":"17 GB","required":"595 MB"}
              ? Proceeding will copy all V1 data to "/var/lib/influxdb/.influxdbv2"
                Space available: 17 GB
                Space required:  595 MB
               Yes
              {"level":"info","ts":1683120639.156735,"caller":"upgrade/database.go:51","msg":"Upgrading databases"}
              {"level":"info","ts":1683120639.1700745,"caller":"upgrade/database.go:101","msg":"Creating mapping","database":"iobroker","retention policy":"autogen","orgID":"e285f69fcf72fc03","bucketID":"f93ed287dd616025"}
              {"level":"info","ts":1683120641.8099163,"caller":"upgrade/database.go:195","msg":"Database upgrade complete","upgraded_count":1}
              {"level":"info","ts":1683120641.8100085,"caller":"upgrade/security.go:45","msg":"Upgrading 1.x users"}
              {"level":"warn","ts":1683120641.8101015,"caller":"upgrade/security.go:50","msg":"User is admin and will not be upgraded","username":"admin"}
              {"level":"info","ts":1683120641.8379087,"caller":"upgrade/security.go:115","msg":"User upgrade complete","upgraded_count":2}
              {"level":"info","ts":1683120641.838016,"caller":"upgrade/upgrade.go:488","msg":"Upgrade successfully completed. Start the influxd service now, then log in","login_url":"http://localhost:8086"}
              chris@influxdbtest:~$ sudo systemctl start influxdb
              Failed to start influxdb.service: Unit influxdb.service is masked.
              chris@influxdbtest:~$ service influxdb start
              Failed to start influxdb.service: Access denied
              See system logs and 'systemctl status influxdb.service' for details.
              chris@influxdbtest:~$ sudo systemctl status influxdb
              * influxdb.service
                   Loaded: masked (Reason: Unit influxdb.service is masked.)
                   Active: inactive (dead) since Wed 2023-05-03 13:25:29 UTC; 7min ago
                 Main PID: 912 (code=exited, status=0/SUCCESS)
                      CPU: 2.201s
              May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.439535Z lvl=info msg="Shutting down monitor service" log_id=0h_S6k~0000 service=monitor
              May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.439539Z lvl=info msg="Terminating storage of statistics" log_id=0h_S6k~0000 service=monitor
              May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.439547Z lvl=info msg="Terminating precreation service" log_id=0h_S6k~0000 service=shard-precr>
              May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.439552Z lvl=info msg="Terminating continuous query service" log_id=0h_S6k~0000 service=contin>
              May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.439572Z lvl=info msg="Closing retention policy enforcement service" log_id=0h_S6k~0000 servic>
              May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.446068Z lvl=info msg="Closed service" log_id=0h_S6k~0000 service=subscriber
              May 03 13:25:29 influxdbtest influxd[912]: ts=2023-05-03T13:25:29.446118Z lvl=info msg="Server shutdown completed" log_id=0h_S6k~0000
              May 03 13:25:29 influxdbtest systemd[1]: influxdb.service: Deactivated successfully.
              May 03 13:25:29 influxdbtest systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
              May 03 13:25:29 influxdbtest systemd[1]: influxdb.service: Consumed 2.201s CPU time.
                @chris76e
                Ich denke das wird in der entsprechenden Anleitung zu influxdb2 erwähnt.
                  @chris76e sagte in Proxmox / Influxdb V1 zu V2... wie?:
                  Moin,
                  ich erstelle gerade eine Kopie meiner 1.8 influxDB Instanz. Dann kann ich das alles einmal durchgehen.
                  VG
                  Bernd
                  • Chris76e
                    Danke, warte dann auf dich.
                    Habe zwar jetzt was hinbekommen, aber keine Ahnung ob es richtig ist.
                      Moin,
                      hast Du das gelesen?
                      sudo /usr/share/influxdb/influxdb2-upgrade.sh                                <-----------------
                      Dann macht der das von alleine
                      [dp20eic@influxDB ~]$ sudo apt install influxdb2
                        influxdb2-cli
                        influxdb
                      After this operation, 24.4 MB disk space will be freed.
                      Fetched 57.3 MB in 2s (24.7 MB/s)
                      (Reading database ... 23066 files and directories currently installed.)
                      Removing influxdb (1.8.10-1) ...
                      (Reading database ... 23046 files and directories currently installed.)
                      [dp20eic@influxDB ~]$ sudo /usr/share/influxdb/influxdb2-upgrade.sh
                      {"level":"info","ts":1683120863.4011807,"caller":"upgrade/upgrade.go:401","msg":"Starting InfluxDB 1.x upgrade"}
                      {"level":"info","ts":1683120863.4013894,"caller":"upgrade/upgrade.go:404","msg":"Upgrading config file","file":"/etc/influxdb/influxdb.conf"}
                      {"level":"info","ts":1683120863.4016256,"caller":"upgrade/upgrade.go:408","msg":"Config file upgraded.","1.x config":"/etc/influxdb/influxdb.conf","2.x config":"/etc/influxdb/config.toml"}
                      {"level":"info","ts":1683120863.401655,"caller":"upgrade/upgrade.go:418","msg":"Upgrade source paths","meta":"/var/lib/influxdb/meta","data":"/var/lib/influxdb/data"}
                      {"level":"info","ts":1683120863.4016862,"caller":"upgrade/upgrade.go:419","msg":"Upgrade target paths","bolt":"/var/lib/influxdb/influxd.bolt","engine":"/var/lib/influxdb/engine"}
                      {"level":"info","ts":1683120863.4033222,"caller":"bolt/bbolt.go:83","msg":"Resources opened","service":"bolt","path":"/var/lib/influxdb/influxd.bolt"}
                      {"level":"info","ts":1683120863.4036214,"caller":"migration/migration.go:175","msg":"Bringing up metadata migrations","service":"migrations","migration_count":20}
                      ? Please type your primary username dp20eic
                      ? Please type your password ***********
                      ? Please type your password again ***********
                      ? Please type your primary organization name iobroker
                        Username:          dp20eic
                        Organization:      iobroker
                        Bucket:            iobroker
                       Yes
                      {"level":"info","ts":1683121542.855478,"caller":"upgrade/setup.go:73","msg":"CLI config has been stored.","path":"/root/.influxdbv2/configs"}
                      {"level":"info","ts":1683121542.8555653,"caller":"upgrade/database.go:202","msg":"Checking available disk space"}
                      {"level":"info","ts":1683121542.8631513,"caller":"upgrade/database.go:223","msg":"Computed disk space","free":"17 GB","required":"2.9 GB"}
                      ? Proceeding will copy all V1 data to "/var/lib/influxdb"
                        Space required:  2.9 GB
                       Yes
                      {"level":"info","ts":1683121556.5976517,"caller":"upgrade/database.go:51","msg":"Upgrading databases"}
                      {"level":"info","ts":1683121556.5980585,"caller":"upgrade/database.go:101","msg":"Creating mapping","database":"iobroker","retention policy":"global","orgID":"e252c40981d69d16","bucketID":"26e75b81215f75de"}
                      {"level":"info","ts":1683121568.78221,"caller":"upgrade/database.go:101","msg":"Creating mapping","database":"telegraf","retention policy":"autogen","orgID":"e252c40981d69d16","bucketID":"b98918d0b4c6d11b"}
                      {"level":"info","ts":1683121577.072777,"caller":"upgrade/database.go:195","msg":"Database upgrade complete","upgraded_count":2}
                      {"level":"info","ts":1683121577.0735512,"caller":"upgrade/security.go:45","msg":"Upgrading 1.x users"}
                      {"level":"warn","ts":1683121577.0737543,"caller":"upgrade/security.go:50","msg":"User is admin and will not be upgraded","username":"influxDb"}
                      {"level":"info","ts":1683121577.0737848,"caller":"upgrade/security.go:115","msg":"User upgrade complete","upgraded_count":0}
                      {"level":"info","ts":1683121577.0738018,"caller":"upgrade/upgrade.go:488","msg":"Upgrade successfully completed. Start the influxd service now, then log in","login_url":"http://localhost:8086"}
                      The upgrade completed successfully.  Execute the following to start InfluxDB:
                      A complete copy of v1 data was created as part of the upgrade process.
                      After confirming v2 is functioning as intended, removal of v1 data can be
                      performed by executing:
                      sudo /var/tmp/influxdbv1-remove.sh
                      NOTE: This script will erase all previous v1 data and config files!
                      Ich bin jetzt mal für ne Stunde weg.
                      VG
                      Bernd
                        Moin,
                        dann zeig doch mal was jetzt so angezeigt wird
                        # apt policy influxdb*
                        # systemctl status influxd.service
                        # systemctl status influxdb.service
                        Und wenn alles up and running
                        http://ip.influx.db:8086
                        dann sollte das kommen
                        Das erste Bucket im letzten Bild ist das, welches ich bei der Migration angelegt habe, das zweite iobroker/global ist das, welches aus der V1.8 migriert wurde. Das Telegraf Bucket ist eine DB die ich auch noch in der V 1.8 hatte.
                        Dann ist das aber alles umgestellt auf die neue Abfragesprache FLUX, wenn Du weiter in influxQL unter Grafana werkeln willst, muss man noch etwas umstellen, suche ich gleich mal.
                        VG
                        Bernd
                        • Chris76e
                          @dp20eic
                          scheint zulaufen 😊
                          Oder muss ich nochwas machen?
                          chris@influxdb3test:~$ apt policy influxdb*
                          influxdb2-cli:
                            Installed: (none)
                            Candidate: 2.7.3-1
                            Version table:
                               2.7.3-1 500
                                  500 https://repos.influxdata.com/debian stable/main amd64 Packages
                               2.7.1-2 500
                               2.6.1 500
                               2.6.0 500
                               2.5.0 500
                               2.4.0 500
                               2.3.0 500
                          influxdb-client:
                            Installed: (none)
                            Candidate: 1.6.7~rc0-1ubuntu0.22.04.2
                            Version table:
                               1.6.7~rc0-1ubuntu0.22.04.2 500
                                  500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                                  500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                               1.6.7~rc0-1 500
                                  500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                          influxdb-dev:
                            Installed: (none)
                            Candidate: (none)
                            Version table:
                          influxdb2-client:
                            Installed: (none)
                            Candidate: 2.7.1-1
                            Version table:
                               2.7.1-1 500
                          influxdb:
                            Installed: (none)
                            Candidate: 1.8.10-1
                            Version table:
                               1.8.10-1 500
                               1.6.7~rc0-1ubuntu0.22.04.1 -1
                                  100 /var/lib/dpkg/status
                               1.6.7~rc0-1 500
                          influxdb2:
                            Installed: 2.7.1-1
                            Candidate: 2.7.1-1
                            Version table:
                           *** 2.7.1-1 500
                               2.7.0-1 500
                               2.6.1-1 500
                               2.6.0-1 500
                               2.5.1-1 500
                               2.4.0-1 500
                               2.3.0-1 500
                               2.2.0 500
                            @chris76e
                            Für (unter anderem) Backups wird noch der
                            influxdb2-client
                            benötigt.
                              Moin,
                              na, wenn das jetzt Deine Daten im Bucket sind und nicht die vom Nachbarn, dann schaut das ja mal gut aus 🙂
                              Wenn Du Grafana nutzt, musst Du Dich entscheiden, ob Du vorhandene Panels/Dashboards auf die neue FLUX Abfragesprache umstellen möchtest oder ob Du da weiter mit influxQL Handtieren möchtest.
                              Ich bin komplett umgestiegen auf FLUX und kann Dir nicht sagen wie Du das Einstellen musst, vielleicht steht ja hier was https://docs.influxdata.com/influxdb/v2.7/upgrade/v1-to-v2/manual-upgrade/
                              Es gibt aber schon einige Posts hier im Forum, die das Thema behandeln.
                              Und wie @Thomas-Braun sagte, wenn Du den ioBroker - Backitup Adapter nutzt, musst Du den influxdb2-cli auf dem ioBroker installieren, ansonsten kannst Du keine Backups der influxDB machen.
                              @Thomas-Braun müsste das nicht influxdb2-cli sein?
                              VG
                              Bernd
                                @dp20eic
                                Ich weiß es nicht genau. Ich hab jetzt die Versionsnummer genommen die zur Hauptversion passt.
                                Man müsste man in influxdb2-cli und influxdb2-client hineinschauen und checken was da drin ist
                                • Chris76e
                                  Chris76e @Thomas Braun last edited by
                                  @thomas-braun sagte in Proxmox / Influxdb V1 zu V2... wie?:
                                  influxdb2-client
                                  Bin nach der offiziellen Anleitung gegangen
                                  Download from the command line
                                  # amd64
                                  wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-amd64.tar.gz
                                  # arm
                                  wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-arm64.tar.gz
                                  Unpackage the downloaded package.
                                  Note: The following commands are examples. Adjust the filenames, paths, and utilities if necessary.
                                  # amd64
                                  tar xvzf path/to/influxdb2-client-2.7.1-linux-amd64.tar.gz
                                  # arm
                                  tar xvzf path/to/influxdb2-client-2.7.1-linux-arm64.tar.gz
                                  Aber scheint nicht zufunktionieren
                                  chris@influxdb3test:~$ wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-amd64.tar.gz
                                  --2023-05-03 16:02:32--  https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-amd64.tar.gz
                                  Resolving dl.influxdata.com (dl.influxdata.com)... 18.154.63.120, 18.154.63.100, 18.154.63.19, ...
                                  Connecting to dl.influxdata.com (dl.influxdata.com)|18.154.63.120|:443... connected.
                                  HTTP request sent, awaiting response... 200 OK
                                  Length: 11265848 (11M) [application/x-tar]
                                  Saving to: 'influxdb2-client-2.7.1-linux-amd64.tar.gz'
                                  influxdb2-client-2.7.1-linux-amd64.tar. 100%[===============================================================================>]  10.74M  --.-KB/s    in 0.1s
                                  2023-05-03 16:02:33 (82.0 MB/s) - 'influxdb2-client-2.7.1-linux-amd64.tar.gz' saved [11265848/11265848]
                                  chris@influxdb3test:~$ tar xvzf ./influxdb2-client-2.7.1-linux-amd64.tar.gz
                                  ./LICENSE
                                  ./README.md
                                  ./influx
                                  influxdb2-cli:
                                    Installed: (none)
                                    Candidate: 2.7.3-1
                                    Version table:
                                       2.7.3-1 500
                                       2.7.1-2 500
                                       2.6.1 500
                                       2.6.0 500
                                       2.5.0 500
                                       2.4.0 500
                                       2.3.0 500
                                  influxdb-client:
                                    Installed: (none)
                                    Version table:
                                       1.6.7~rc0-1 500
                                  influxdb-dev:
                                    Installed: (none)
                                    Candidate: (none)
                                    Version table:
                                  influxdb2-client:
                                    Installed: (none)
                                    Candidate: 2.7.1-1
                                    Version table:
                                       2.7.1-1 500
                                  influxdb:
                                    Installed: (none)
                                    Candidate: 1.8.10-1
                                    Version table:
                                       1.8.10-1 500
                                       1.6.7~rc0-1 500
                                  influxdb2:
                                    Installed: 2.7.1-1
                                    Candidate: 2.7.1-1
                                    Version table:
                                   *** 2.7.1-1 500
                                       2.7.0-1 500
                                       2.6.1-1 500
                                       2.6.0-1 500
                                       2.5.1-1 500
                                       2.4.0-1 500
                                       2.3.0-1 500
                                       2.2.0 500
                                  ? Thomas Braun 2 Replies Last reply Reply Quote 0
                                    Moin,
                                    was versuchst Du gerade?
                                    Die erste Frage ist, nutzt Du den ioBrober Backitup Adapter?
                                    Wenn, ja, dann musst Du auf dem ioBroker den Client installieren, damit der ioBroker das Bucket, in welches Du schreibst, mit sichern kann, fehlt der Client, kann man nicht remote auf die influxDB zugreifen.
                                    Wenn alles ioBroker u. influxDB auf demselben Server läuft, dann ist das nicht nötig.
                                    Sollte der ioBroker im eigenen Container laufen, dann musst Du da auch das korrekten Repository anlegen und dann mit
                                    # sudo apt install influxdb2-client
                                    installieren
                                    VG
                                    Bernd
                                    • Chris76e
                                      @dp20eic
                                      InfluxDB läuft auf einem eigene LXC, Backups werden mit Proxmox gemacht
                                        @chris76e
                                        Hatten wir nicht oben bereits gesagt, dass man keine tar.gz wildherunterlädt, sondern seinen PAKETTMANAGER benutzt? Dafür ist der nämlich da.
                                        Lösch den Mist wieder.
                                        • Chris76e
                                          was soll man denn machen wenn man nicht viel Ahnung von Linux hat? Das ist doch die offizielle Anleitung von influx. https://docs.influxdata.com/influxdb/v2.7/tools/influx-cli/?t=Linux
                                          Du schreibst:
                                          influxdb2-client
                                          benötigt.
                                          dann habe ich nach influxdb2-client gesucht.....
                                            @chris76e
                                            So installiert man Software unter Debian:
                                            sudo apt install PAKETNAME
                                            Entsprechende Quelle muss u.U. noch angelegt werden.
                                            Andere Linux-Geschmacksrichtungen haben andere Paketmanager.
                                            1.0k
                                            81.1k
                                            221
                                            36141
