    3. Off Topic
    4. Proxmox
    5. Proxmox / Influxdb V1 zu V2... wie?
      Thomas Braun Most Active @Chris76e last edited by
      @chris76e
      Unit influxdb.service is masked.
      Ich denke das wird in der entsprechenden Anleitung zu influxdb2 erwähnt.
        A Former User @Chris76e last edited by
        @chris76e sagte in Proxmox / Influxdb V1 zu V2... wie?:
        Die Anleitung ist ja die, die ich nicht verstehe???
        Moin,
        ich erstelle gerade eine Kopie meiner 1.8 influxDB Instanz. Dann kann ich das alles einmal durchgehen.
        VG
        Bernd
        Chris76e 1 Reply Last reply Reply Quote 0
        • Chris76e
          Chris76e @Guest last edited by
          @dp20eic sagte in Proxmox / Influxdb V1 zu V2... wie?:
          Danke, warte dann auf dich.
          Habe zwar jetzt was hinbekommen, aber keine Ahnung ob es richtig ist.
            Moin,
            hast Du das gelesen?
            ! Important 1.x to 2.x Upgrade Notice !
            Thank you for installing InfluxDB v2.  Due to significant changes between
            the v1 and v2 versions, upgrading to v2 requires additional steps.  If
            upgrading to v2 was not intended, simply re-install the v1 package now.
            An upgrade helper script is available that should be reviewed and executed
            prior to starting the influxdb systemd service.  In order to start the v2
            upgrade, execute the following:
            sudo /usr/share/influxdb/influxdb2-upgrade.sh                                <-----------------
            Dann macht der das von alleine
            [dp20eic@influxDB ~]$ sudo apt install influxdb2
            Reading package lists... Done
            Building dependency tree... Done
            The following additional packages will be installed:
              influxdb2-cli
            The following packages will be REMOVED:
              influxdb
            The following NEW packages will be installed:
              influxdb2 influxdb2-cli
            0 upgraded, 2 newly installed, 1 to remove and 0 not upgraded.
            Need to get 57.3 MB of archives.
            After this operation, 24.4 MB disk space will be freed.
            Do you want to continue? [Y/n]
            Get:1 https://repos.influxdata.com/debian stable/main amd64 influxdb2 amd64 2.7.1-1 [45.9 MB]
            Get:2 https://repos.influxdata.com/debian stable/main amd64 influxdb2-cli amd64 2.7.3-1 [11.5 MB]
            Fetched 57.3 MB in 2s (24.7 MB/s)
            (Reading database ... 23066 files and directories currently installed.)
            Removing influxdb (1.8.10-1) ...
            Selecting previously unselected package influxdb2.
            (Reading database ... 23046 files and directories currently installed.)
            Preparing to unpack .../influxdb2_2.7.1-1_amd64.deb ...
            Unpacking influxdb2 (2.7.1-1) ...
            Selecting previously unselected package influxdb2-cli.
            Preparing to unpack .../influxdb2-cli_2.7.3-1_amd64.deb ...
            Unpacking influxdb2-cli (2.7.3-1) ...
            Setting up influxdb2 (2.7.1-1) ...
            Synchronizing state of influxdb.service with SysV service script with /lib/systemd/systemd-sysv-install.
            Executing: /lib/systemd/systemd-sysv-install enable influxdb
            Visit our website for complete details on the v1 to v2 upgrade process:
            https://docs.influxdata.com/influxdb/latest/upgrade/v1-to-v2/
            For new or upgrade installations, please review the getting started guide:
            https://docs.influxdata.com/influxdb/latest/get-started/
            [dp20eic@influxDB ~]$ sudo /usr/share/influxdb/influxdb2-upgrade.sh
            {"level":"info","ts":1683120863.4011807,"caller":"upgrade/upgrade.go:401","msg":"Starting InfluxDB 1.x upgrade"}
            {"level":"info","ts":1683120863.4013894,"caller":"upgrade/upgrade.go:404","msg":"Upgrading config file","file":"/etc/influxdb/influxdb.conf"}
            {"level":"info","ts":1683120863.4016256,"caller":"upgrade/upgrade.go:408","msg":"Config file upgraded.","1.x config":"/etc/influxdb/influxdb.conf","2.x config":"/etc/influxdb/config.toml"}
            {"level":"info","ts":1683120863.401655,"caller":"upgrade/upgrade.go:418","msg":"Upgrade source paths","meta":"/var/lib/influxdb/meta","data":"/var/lib/influxdb/data"}
            {"level":"info","ts":1683120863.4016862,"caller":"upgrade/upgrade.go:419","msg":"Upgrade target paths","bolt":"/var/lib/influxdb/influxd.bolt","engine":"/var/lib/influxdb/engine"}
            {"level":"info","ts":1683120863.4033222,"caller":"bolt/bbolt.go:83","msg":"Resources opened","service":"bolt","path":"/var/lib/influxdb/influxd.bolt"}
            {"level":"info","ts":1683120863.4036214,"caller":"migration/migration.go:175","msg":"Bringing up metadata migrations","service":"migrations","migration_count":20}
            > Welcome to InfluxDB 2.0!
            ? Please type your primary username dp20eic
            ? Please type your password ***********
            ? Please type your password again ***********
            ? Please type your primary organization name iobroker
            ? Please type your primary bucket name iobroker
            ? Please type your retention period in hours, or 0 for infinite 0
            ? Setup with these parameters?
              Username:          dp20eic
              Organization:      iobroker
              Bucket:            iobroker
              Retention Period:  infinite
             Yes
            {"level":"info","ts":1683121542.855478,"caller":"upgrade/setup.go:73","msg":"CLI config has been stored.","path":"/root/.influxdbv2/configs"}
            {"level":"info","ts":1683121542.8555653,"caller":"upgrade/database.go:202","msg":"Checking available disk space"}
            {"level":"info","ts":1683121542.8631513,"caller":"upgrade/database.go:223","msg":"Computed disk space","free":"17 GB","required":"2.9 GB"}
            ? Proceeding will copy all V1 data to "/var/lib/influxdb"
              Space available: 17 GB
              Space required:  2.9 GB
             Yes
            {"level":"info","ts":1683121556.5976517,"caller":"upgrade/database.go:51","msg":"Upgrading databases"}
            {"level":"info","ts":1683121556.5980585,"caller":"upgrade/database.go:101","msg":"Creating mapping","database":"iobroker","retention policy":"global","orgID":"e252c40981d69d16","bucketID":"26e75b81215f75de"}
            {"level":"info","ts":1683121568.78221,"caller":"upgrade/database.go:101","msg":"Creating mapping","database":"telegraf","retention policy":"autogen","orgID":"e252c40981d69d16","bucketID":"b98918d0b4c6d11b"}
            {"level":"info","ts":1683121577.072777,"caller":"upgrade/database.go:195","msg":"Database upgrade complete","upgraded_count":2}
            {"level":"info","ts":1683121577.0735512,"caller":"upgrade/security.go:45","msg":"Upgrading 1.x users"}
            {"level":"warn","ts":1683121577.0737543,"caller":"upgrade/security.go:50","msg":"User is admin and will not be upgraded","username":"influxDb"}
            {"level":"info","ts":1683121577.0737848,"caller":"upgrade/security.go:115","msg":"User upgrade complete","upgraded_count":0}
            {"level":"info","ts":1683121577.0738018,"caller":"upgrade/upgrade.go:488","msg":"Upgrade successfully completed. Start the influxd service now, then log in","login_url":"http://localhost:8086"}
            The upgrade completed successfully.  Execute the following to start InfluxDB:
            sudo systemctl start influxdb
            A complete copy of v1 data was created as part of the upgrade process.
            After confirming v2 is functioning as intended, removal of v1 data can be
            performed by executing:
            sudo /var/tmp/influxdbv1-remove.sh
            NOTE: This script will erase all previous v1 data and config files!
            Ich bin jetzt mal für ne Stunde weg.
            VG
            Bernd
              Moin,
              dann zeig doch mal was jetzt so angezeigt wird
              # apt policy influxdb*
              # systemctl status influxd.service
              # systemctl status influxdb.service
              Und wenn alles up and running
              http://ip.influx.db:8086
              dann sollte das kommen
              Das erste Bucket im letzten Bild ist das, welches ich bei der Migration angelegt habe, das zweite iobroker/global ist das, welches aus der V1.8 migriert wurde. Das Telegraf Bucket ist eine DB die ich auch noch in der V 1.8 hatte.
              Dann ist das aber alles umgestellt auf die neue Abfragesprache FLUX, wenn Du weiter in influxQL unter Grafana werkeln willst, muss man noch etwas umstellen, suche ich gleich mal.
              VG
              Bernd
              • Chris76e
                @dp20eic
                scheint zulaufen 😊
                Oder muss ich nochwas machen?
                chris@influxdb3test:~$ apt policy influxdb*
                influxdb2-cli:
                  Installed: (none)
                  Candidate: 2.7.3-1
                  Version table:
                     2.7.3-1 500
                        500 https://repos.influxdata.com/debian stable/main amd64 Packages
                     2.7.1-2 500
                     2.6.1 500
                     2.6.0 500
                     2.5.0 500
                     2.4.0 500
                     2.3.0 500
                influxdb-client:
                  Installed: (none)
                  Candidate: 1.6.7~rc0-1ubuntu0.22.04.2
                  Version table:
                     1.6.7~rc0-1ubuntu0.22.04.2 500
                        500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                        500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                     1.6.7~rc0-1 500
                        500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                influxdb-dev:
                  Installed: (none)
                  Candidate: (none)
                  Version table:
                influxdb2-client:
                  Installed: (none)
                  Candidate: 2.7.1-1
                  Version table:
                     2.7.1-1 500
                influxdb:
                  Installed: (none)
                  Candidate: 1.8.10-1
                  Version table:
                     1.8.10-1 500
                     1.6.7~rc0-1ubuntu0.22.04.1 -1
                        100 /var/lib/dpkg/status
                     1.6.7~rc0-1 500
                influxdb2:
                  Installed: 2.7.1-1
                  Candidate: 2.7.1-1
                  Version table:
                 *** 2.7.1-1 500
                     2.7.0-1 500
                     2.6.1-1 500
                     2.6.0-1 500
                     2.5.1-1 500
                     2.4.0-1 500
                     2.3.0-1 500
                     2.2.0 500
                Thomas Braun ? 2 Replies Last reply Reply Quote 0
                  @chris76e
                  Für (unter anderem) Backups wird noch der
                  influxdb2-client
                  benötigt.
                    Moin,
                    na, wenn das jetzt Deine Daten im Bucket sind und nicht die vom Nachbarn, dann schaut das ja mal gut aus 🙂
                    Wenn Du Grafana nutzt, musst Du Dich entscheiden, ob Du vorhandene Panels/Dashboards auf die neue FLUX Abfragesprache umstellen möchtest oder ob Du da weiter mit influxQL Handtieren möchtest.
                    Ich bin komplett umgestiegen auf FLUX und kann Dir nicht sagen wie Du das Einstellen musst, vielleicht steht ja hier was https://docs.influxdata.com/influxdb/v2.7/upgrade/v1-to-v2/manual-upgrade/
                    Es gibt aber schon einige Posts hier im Forum, die das Thema behandeln.
                    Und wie @Thomas-Braun sagte, wenn Du den ioBroker - Backitup Adapter nutzt, musst Du den influxdb2-cli auf dem ioBroker installieren, ansonsten kannst Du keine Backups der influxDB machen.
                    @Thomas-Braun müsste das nicht influxdb2-cli sein?
                    VG
                    Bernd
                      @dp20eic
                      Ich weiß es nicht genau. Ich hab jetzt die Versionsnummer genommen die zur Hauptversion passt.
                      Man müsste man in influxdb2-cli und influxdb2-client hineinschauen und checken was da drin ist
                      • Chris76e
                        Chris76e @Thomas Braun last edited by
                        @thomas-braun sagte in Proxmox / Influxdb V1 zu V2... wie?:
                        influxdb2-client
                        Bin nach der offiziellen Anleitung gegangen
                        Download from the command line
                        # amd64
                        wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-amd64.tar.gz
                        # arm
                        wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-arm64.tar.gz
                        Unpackage the downloaded package.
                        Note: The following commands are examples. Adjust the filenames, paths, and utilities if necessary.
                        # amd64
                        tar xvzf path/to/influxdb2-client-2.7.1-linux-amd64.tar.gz
                        # arm
                        tar xvzf path/to/influxdb2-client-2.7.1-linux-arm64.tar.gz
                        Aber scheint nicht zufunktionieren
                        chris@influxdb3test:~$ wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-amd64.tar.gz
                        --2023-05-03 16:02:32--  https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.7.1-linux-amd64.tar.gz
                        Resolving dl.influxdata.com (dl.influxdata.com)... 18.154.63.120, 18.154.63.100, 18.154.63.19, ...
                        Connecting to dl.influxdata.com (dl.influxdata.com)|18.154.63.120|:443... connected.
                        HTTP request sent, awaiting response... 200 OK
                        Length: 11265848 (11M) [application/x-tar]
                        Saving to: 'influxdb2-client-2.7.1-linux-amd64.tar.gz'
                        influxdb2-client-2.7.1-linux-amd64.tar. 100%[===============================================================================>]  10.74M  --.-KB/s    in 0.1s
                        2023-05-03 16:02:33 (82.0 MB/s) - 'influxdb2-client-2.7.1-linux-amd64.tar.gz' saved [11265848/11265848]
                        chris@influxdb3test:~$ tar xvzf ./influxdb2-client-2.7.1-linux-amd64.tar.gz
                        ./LICENSE
                        ./README.md
                        ./influx
                        influxdb2-cli:
                          Installed: (none)
                          Candidate: 2.7.3-1
                          Version table:
                             2.7.3-1 500
                             2.7.1-2 500
                             2.6.1 500
                             2.6.0 500
                             2.5.0 500
                             2.4.0 500
                             2.3.0 500
                        influxdb-client:
                          Installed: (none)
                          Version table:
                             1.6.7~rc0-1 500
                        influxdb-dev:
                          Installed: (none)
                          Candidate: (none)
                          Version table:
                        influxdb2-client:
                          Installed: (none)
                          Candidate: 2.7.1-1
                          Version table:
                             2.7.1-1 500
                        influxdb:
                          Installed: (none)
                          Candidate: 1.8.10-1
                          Version table:
                             1.8.10-1 500
                             1.6.7~rc0-1 500
                        influxdb2:
                          Installed: 2.7.1-1
                          Candidate: 2.7.1-1
                          Version table:
                         *** 2.7.1-1 500
                             2.7.0-1 500
                             2.6.1-1 500
                             2.6.0-1 500
                             2.5.1-1 500
                             2.4.0-1 500
                             2.3.0-1 500
                             2.2.0 500
                        ? Thomas Braun 2 Replies Last reply Reply Quote 0
                          Moin,
                          was versuchst Du gerade?
                          Die erste Frage ist, nutzt Du den ioBrober Backitup Adapter?
                          Wenn, ja, dann musst Du auf dem ioBroker den Client installieren, damit der ioBroker das Bucket, in welches Du schreibst, mit sichern kann, fehlt der Client, kann man nicht remote auf die influxDB zugreifen.
                          Wenn alles ioBroker u. influxDB auf demselben Server läuft, dann ist das nicht nötig.
                          Sollte der ioBroker im eigenen Container laufen, dann musst Du da auch das korrekten Repository anlegen und dann mit
                          # sudo apt install influxdb2-client
                          installieren
                          VG
                          Bernd
                          • Chris76e
                            @dp20eic
                            InfluxDB läuft auf einem eigene LXC, Backups werden mit Proxmox gemacht
                              @chris76e
                              Hatten wir nicht oben bereits gesagt, dass man keine tar.gz wildherunterlädt, sondern seinen PAKETTMANAGER benutzt? Dafür ist der nämlich da.
                              Lösch den Mist wieder.
                              • Chris76e
                                was soll man denn machen wenn man nicht viel Ahnung von Linux hat? Das ist doch die offizielle Anleitung von influx. https://docs.influxdata.com/influxdb/v2.7/tools/influx-cli/?t=Linux
                                Du schreibst:
                                influxdb2-client
                                benötigt.
                                dann habe ich nach influxdb2-client gesucht.....
                                  @chris76e
                                  So installiert man Software unter Debian:
                                  sudo apt install PAKETNAME
                                  Entsprechende Quelle muss u.U. noch angelegt werden.
                                  Andere Linux-Geschmacksrichtungen haben andere Paketmanager.
                                  • Chris76e
                                    So sieht es jetzt aus
                                    influxdb2-cli:
                                      Installed: (none)
                                      Candidate: 2.7.3-1
                                      Version table:
                                         2.7.3-1 500
                                         2.7.1-2 500
                                         2.6.1 500
                                         2.6.0 500
                                         2.5.0 500
                                         2.4.0 500
                                         2.3.0 500
                                    influxdb-client:
                                      Installed: (none)
                                      Version table:
                                         1.6.7~rc0-1 500
                                    influxdb-dev:
                                      Installed: (none)
                                      Candidate: (none)
                                      Version table:
                                    influxdb2-client:
                                      Installed: 2.7.1-1
                                      Candidate: 2.7.1-1
                                      Version table:
                                     *** 2.7.1-1 500
                                    influxdb:
                                      Installed: (none)
                                      Candidate: 1.8.10-1
                                      Version table:
                                         1.8.10-1 500
                                         1.6.7~rc0-1 500
                                    influxdb2:
                                      Installed: 2.7.1-1
                                      Candidate: 2.7.1-1
                                      Version table:
                                     *** 2.7.1-1 500
                                         2.7.0-1 500
                                         2.6.1-1 500
                                         2.6.0-1 500
                                         2.5.1-1 500
                                         2.4.0-1 500
                                         2.3.0-1 500
                                         2.2.0 500
                                      @dp20eic
                                      Moin,
                                      dann bist Du erst einmal fertig, denn nur wenn Du den ioBroker Adapter 3fb67c71-a435-42a7-b174-424ed437d40c-grafik.png nutzt, brauchst Du den Client auf dem ioBroker Server.
                                      Solange Du die Backups mit Proxmox machst, ist das dann nicht nötig.
                                      VG
                                      Bernd
                                      P.S.: und wie @Thomas-Braun schon sagte, lösche das, was Du da heruntergeladen hast.
                                      Chris76e Thomas Braun 2 Replies Last reply Reply Quote 0
                                      • Chris76e
                                        @dp20eic
                                        Danke 👍
                                          @dp20eic
                                          Wobei ich vermutlich bei den Backups zweigleisig fahren würde. Falls entsprechend ausreichend Speicherplatz vorhanden ist jedenfalls.
                                            Moin,
                                            das ist für den aktuellen Betrieb erst einmal ausreichend.
                                            Du kannst bei der 2er-Version viel mittels der WEB-UI einstellen und administrieren, aber manches geht nur auf der Kommandozeile, dafür brauchst Du dann das influxDB2-cli, das kann entweder auf dem influxDB Server mit installiert sein oder auf irgendeinem anderen.
                                            Mach aber erst mal weiter und wenn alles erst mal läuft eine Sicherung nicht vergessen 🙂
                                            VG
                                            Bernd
                                            81.1k
                                            221
                                            36141
