    4. [Frage] Realisierung Adapter UDP Keba Wallbox
      darkiop Most Active @darkiop last edited by
      @Sneak-L8
      Auch mit DIP 1.2 = on kommts zum Fehler wenn X2 in der kecontact config gesetzt ist.
      2023-05-01 09:35:28.972  - ^[[32minfo^[[39m: kecontact.0 (183848) starting. Version 1.5.2 (non-npm: iobroker-community-adapters/ioBroker.kecontact) in /opt/iobroker/node_modules/iobroker.kecontact, node: v16.20.0, js-controller: 4.0.24
       2023-05-01 09:35:28.987  - ^[[32minfo^[[39m: kecontact.0 (183848) starting charging station in active mode
       2023-05-01 09:35:28.988  - ^[[32minfo^[[39m: kecontact.0 (183848) using default minimum amperage of 6000
       2023-05-01 09:35:28.989  - ^[[32minfo^[[39m: kecontact.0 (183848) minimum regard time not speficied or too low, using default value of 0
       2023-05-01 09:35:29.087  - ^[[32minfo^[[39m: kecontact.0 (183848) config host: 10.3.1.28
       2023-05-01 09:35:29.088  - ^[[32minfo^[[39m: kecontact.0 (183848) config passiveMode: false
       2023-05-01 09:35:29.089  - ^[[32minfo^[[39m: kecontact.0 (183848) config pollInterval: 0
       2023-05-01 09:35:29.089  - ^[[32minfo^[[39m: kecontact.0 (183848) config loadChargingSessions: true
       2023-05-01 09:35:29.089  - ^[[32minfo^[[39m: kecontact.0 (183848) config useX1forAutomatic: false
       2023-05-01 09:35:29.090  - ^[[32minfo^[[39m: kecontact.0 (183848) config stateRegard: alias.0.energie.stromzaehler.hausstrom_bezug_aktuell
       2023-05-01 09:35:29.090  - ^[[32minfo^[[39m: kecontact.0 (183848) config stateSurplus:
       2023-05-01 09:35:29.090  - ^[[32minfo^[[39m: kecontact.0 (183848) config stateBatteryCharging:
       2023-05-01 09:35:29.091  - ^[[32minfo^[[39m: kecontact.0 (183848) config stateBatteryDischarging:
       2023-05-01 09:35:29.091  - ^[[32minfo^[[39m: kecontact.0 (183848) config stateBatterySoC:
       2023-05-01 09:35:29.091  - ^[[32minfo^[[39m: kecontact.0 (183848) config batteryPower: 0
       2023-05-01 09:35:29.091  - ^[[32minfo^[[39m: kecontact.0 (183848) config batteryMinSoC: 10
       2023-05-01 09:35:29.092  - ^[[32minfo^[[39m: kecontact.0 (183848) config limitBatteryStoragePower: true
       2023-05-01 09:35:29.092  - ^[[32minfo^[[39m: kecontact.0 (183848) config statesIncludeWallbox: true
       2023-05-01 09:35:29.092  - ^[[32minfo^[[39m: kecontact.0 (183848) config.state1p3pSwitch:
       2023-05-01 09:35:29.092  - ^[[32minfo^[[39m: kecontact.0 (183848) config.1p3pViax2: true
       2023-05-01 09:35:29.092  - ^[[32minfo^[[39m: kecontact.0 (183848) config.1p3pSwitchIsNO: true, 1p = 0, 3p = 1, off = 0
       2023-05-01 09:35:29.093  - ^[[32minfo^[[39m: kecontact.0 (183848) config minAmperage: null
       2023-05-01 09:35:29.093  - ^[[32minfo^[[39m: kecontact.0 (183848) config addPower: null
       2023-05-01 09:35:29.093  - ^[[32minfo^[[39m: kecontact.0 (183848) config delta: 1000
       2023-05-01 09:35:29.093  - ^[[32minfo^[[39m: kecontact.0 (183848) config underusage: 500
       2023-05-01 09:35:29.093  - ^[[32minfo^[[39m: kecontact.0 (183848) config minTime: 3200
       2023-05-01 09:35:29.094  - ^[[32minfo^[[39m: kecontact.0 (183848) config regardTime: 0
       2023-05-01 09:35:29.094  - ^[[32minfo^[[39m: kecontact.0 (183848) config maxPower: null
       2023-05-01 09:35:29.094  - ^[[32minfo^[[39m: kecontact.0 (183848) config stateEnergyMeter1:
       2023-05-01 09:35:29.094  - ^[[32minfo^[[39m: kecontact.0 (183848) config stateEnergyMeter2:
       2023-05-01 09:35:29.094  - ^[[32minfo^[[39m: kecontact.0 (183848) config stateEnergyMeter3:
       2023-05-01 09:35:29.094  - ^[[32minfo^[[39m: kecontact.0 (183848) config wallboxNotIncluded: false
       2023-05-01 09:35:30.323  - ^[[32minfo^[[39m: kecontact.0 (183848) Keba firmware check: latest firmware installed
       2023-05-01 09:35:39.232  - ^[[32minfo^[[39m: kecontact.0 (183848) activating X2 source from 0 to 4 for phase switching
       2023-05-01 09:35:39.503  - ^[[31merror^[[39m: kecontact.0 (183848) Error received from wallbox: TCH-ERR:: not allowed
       2023-05-01 09:35:39.815  - ^[[32minfo^[[39m: kecontact.0 (183848) stop charging
       2023-05-01 09:35:44.928  - ^[[32minfo^[[39m: kecontact.0 (183848) activating X2 source from 0 to 4 for phase switching
       2023-05-01 09:35:45.193  - ^[[31merror^[[39m: kecontact.0 (183848) Error received from wallbox: TCH-ERR:: not allowed
        Sneak-L8 @darkiop last edited by Sneak-L8
        @darkiop aha, bereits das Setzen von x2src wird abgelehnt. Das ist komisch. Das soll ja gerade der Wallbox mitteilen, dass Du den KC10 schalten willst. Ändere dann doch nochmal den DIP, den dann war die aber Einstellung die richtige.
        Probiere mal, die Ladung mit dem Pause-state zu um und dann manuell die pad über den state zu schalten. Geht das?
          darkiop Most Active @Sneak-L8 last edited by
          @Sneak-L8
          Auch im Pause-Modus kommt direkt der not allowed.
          Unabhängig von dem Adapter - sollte die Keba nicht grundsätzlich mit 3P laufen und nur wenn zu wenig Eingangstrom anliegt anderen beiden Phasen ausschalten?
          Könntest du mal einen Blick auf die Installation selbst werfen? Vielleicht fällt da ja etwas auf.
            @darkiop ganz 100% lässt sich nicht als erkennen. Aber sollte schwarz nicht Phase 1 sein? Denn Phase 2 und 3 sind zu unterbrechen. Bin aber unterwegs und habe kein Schaltbild der Wallbox da, um zu prüfen, ob Phase 1 die ganz linke Klemme ist
              @sneak-l8 sagte in [Frage] Realisierung Adapter UDP Keba Wallbox:
              Da hast du recht, ist allerdings nur farblich vertauscht. Das korrigiere ich noch. L1/L2/L3 sind jeweils korrekt aufgelegt.
              Wir haben eben auch nochmal alles durchgemessen (inkl. der 24V vom Netzteil an X2).
              Ich habe jetzt X2.1 und X2.2 in der KC-S10 überbrückt - dann schaltet auch direkt der Schütz auf 3P.
              D.h. die Ursache ist imho die Keba - der X2 schließt nicht.
                @darkiop Ja, das erklärt auch, warum Du schon beim ersten Mal beim Kommando x2PhaseSwitch eine Fehlermeldung bekommst. Die Keba lässt Dich nicht schalten.
                Probiere mal den State x2PhaseSwitch manuell auf 1 zu setzen (gibt das Kommando "x2 1" aus und sollte auf 3phasiges Laden umschalten). Davor bitte Debug-Log aktivieren.
                Wenn das (wie bisher wieder "TCH-ERR not allowed" kommt, dann bitte auch mal das Webinterface der Keba öffenn und dort unter Log schauen, was da steht.
                Evtl. könntest Du mal noch x2src auf 2 anstelle 4 probieren.
                Unter x2 steht auch "When switching between the parameters, a cool down time of 5 minutes is
                required.". Ich hatte Keba so verstanden, dass die Keba selbständig den Ladevorgang pausiert, umschaltet und wieder startet.
                Das könntem an aber auch so lesen, dass Du den Ladevorgang unterbrechen und 5 Minuten warten musst, bis Du umschaltest. Aber vielleicht ist damit auch nur das Umschalten max. alle 5 Minuten gemeint und nicht die Zeit zum Unterbrechen der Ladung.
                Ich befürchte aber fast, dass wir Keba fragen müssen, was das Problem ist. Könnte ja auch die Firmware sein, die noch nicht stabil läuft ...
                  Das sieht nicht schlecht aus: Received TCH-OK :done
                  Der Finder hat reagiert und auf 3P geschaltet. Und mit 0 gehts auch wieder zurück auf 1P.
                  Danach versucht er wieder die 4 auf kecontact.0.x2phaseSource zu setzen.
                  Im Web Ui der Keba steht dazu nichts.
                  2023-05-02 18:01:43.314  - debug: kecontact.0 (18074) History ID received: 00
                  2023-05-02 18:01:46.053  - debug: kecontact.0 (18074) Sent 'x2 1' to 10.3.1.28:7090
                  2023-05-02 18:01:46.055  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: 'TCH-OK :done'
                  2023-05-02 18:01:46.055  - debug: kecontact.0 (18074) Received TCH-OK :done
                  2023-05-02 18:01:57.412  - debug: kecontact.0 (18074) Sent 'report 2' to 10.3.1.28:7090
                  2023-05-02 18:01:57.413  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "2",
                  "State": 1,
                  "Error1": 0,
                  "Error2": 0,
                  "Plug": 3,
                  "AuthON": 0,
                  "Authreq": 0,
                  "Enable sys": 0,
                  "Enable user": 0,
                  "Max curr": 0,
                  "Max curr %": 1000,
                  "Curr HW": 16000,
                  "Curr user": 63000,
                  "Curr FS": 0,
                  "Tmo FS": 0,
                  "Curr timer": 0,
                  "Tmo CT": 0,
                  "Setenergy": 0,
                  "Output": 1,
                  "Input": 0,
                  "X2 phaseSwitch source": 4,
                  "X2 phaseSwitch": 1,
                  "Serial": "21216522",
                  "Sec": 935
                  2023-05-02 18:01:57.470  - info: kecontact.0 (18074) activating X2 source from 0 to 4 for phase switching
                  2023-05-02 18:01:57.712  - debug: kecontact.0 (18074) Sent 'x2src 4' to 10.3.1.28:7090
                  2023-05-02 18:01:57.715  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: 'TCH-ERR:: not allowed'
                  2023-05-02 18:01:57.716  - error: kecontact.0 (18074) Error received from wallbox: TCH-ERR:: not allowed
                  2023-05-02 18:01:58.014  - debug: kecontact.0 (18074) Sent 'report 3' to 10.3.1.28:7090
                  2023-05-02 18:01:58.015  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "3",
                  "U1": 0,
                  "U2": 0,
                  "U3": 0,
                  "I1": 0,
                  "I2": 0,
                  "I3": 0,
                  "P": 0,
                  "PF": 0,
                  "E pres": 0,
                  "E total": 43721726,
                  "Sec": 936
                  2023-05-02 18:01:58.036  - debug: kecontact.0 (18074) Available surplus: 1819
                  2023-05-02 18:01:58.315  - debug: kecontact.0 (18074) Sent 'report 100' to 10.3.1.28:7090
                  2023-05-02 18:01:58.316  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "100",
                  "Session ID": 0,
                  "Curr HW": 0,
                  "E start": 0,
                  "E pres": 0,
                  "started[s]": 0,
                  "ended[s]": 0,
                  "started": "0",
                  "ended": "0",
                  "reason": 0,
                  "timeQ": 0,
                  "RFID tag": "0000000000000000",
                  "RFID class": "00000000000000000000",
                  "Sec": 936
                  2023-05-02 18:01:58.317  - debug: kecontact.0 (18074) History ID received: 00
                  2023-05-02 18:02:12.413  - debug: kecontact.0 (18074) Sent 'report 2' to 10.3.1.28:7090
                  2023-05-02 18:02:12.414  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "2",
                  "State": 1,
                  "Error1": 0,
                  "Error2": 0,
                  "Plug": 3,
                  "AuthON": 0,
                  "Authreq": 0,
                  "Enable sys": 0,
                  "Enable user": 0,
                  "Max curr": 0,
                  "Max curr %": 1000,
                  "Curr HW": 16000,
                  "Curr user": 63000,
                  "Curr FS": 0,
                  "Tmo FS": 0,
                  "Curr timer": 0,
                  "Tmo CT": 0,
                  "Setenergy": 0,
                  "Output": 1,
                  "Input": 0,
                  "Sec": 950
                  2023-05-02 18:02:12.451  - info: kecontact.0 (18074) activating X2 source from 0 to 4 for phase switching
                  2023-05-02 18:02:12.714  - debug: kecontact.0 (18074) Sent 'x2src 4' to 10.3.1.28:7090
                  2023-05-02 18:02:12.715  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: 'TCH-ERR:: not allowed
                  2023-05-02 18:02:12.716  - error: kecontact.0 (18074) Error received from wallbox: TCH-ERR:: not allowed
                  2023-05-02 18:02:13.015  - debug: kecontact.0 (18074) Sent 'report 3' to 10.3.1.28:7090
                  2023-05-02 18:02:13.016  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "3",
                  "U1": 0,
                  "U2": 0,
                  "U3": 0,
                  "I1": 0,
                  "I2": 0,
                  "I3": 0,
                  "P": 0,
                  "PF": 0,
                  "E pres": 0,
                  "Sec": 951
                  2023-05-02 18:02:13.042  - debug: kecontact.0 (18074) Available surplus: 2128
                  2023-05-02 18:02:13.042  - debug: kecontact.0 (18074) not enough power for charging ...
                  2023-05-02 18:02:13.315  - debug: kecontact.0 (18074) Sent 'report 100' to 10.3.1.28:7090
                  2023-05-02 18:02:13.317  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "100",
                  "Session ID": 0,
                  "Curr HW": 0,
                  "E start": 0,
                  "E pres": 0,
                  "started[s]": 0,
                  "ended[s]": 0,
                  "started": "0",
                  "ended": "0",
                  "reason": 0,
                  "timeQ": 0,
                  "Sec": 951
                  2023-05-02 18:02:13.317  - debug: kecontact.0 (18074) History ID received: 00
                  2023-05-02 18:02:27.414  - debug: kecontact.0 (18074) Sent 'report 2' to 10.3.1.28:7090
                  2023-05-02 18:02:27.416  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "2",
                  "State": 1,
                  "Error1": 0,
                  "Error2": 0,
                  "Plug": 3,
                  "AuthON": 0,
                  "Authreq": 0,
                  "Enable sys": 0,
                  "Enable user": 0,
                  "Max curr": 0,
                  "Max curr %": 1000,
                  "Curr HW": 16000,
                  "Curr user": 63000,
                  "Curr FS": 0,
                  "Tmo FS": 0,
                  "Curr timer": 0,
                  "Tmo CT": 0,
                  "Setenergy": 0,
                  "Output": 1,
                  "Input": 0,
                  "Sec": 965
                  2023-05-02 18:02:27.450  - info: kecontact.0 (18074) activating X2 source from 0 to 4 for phase switching
                  2023-05-02 18:02:27.714  - debug: kecontact.0 (18074) Sent 'x2src 4' to 10.3.1.28:7090
                  2023-05-02 18:02:27.715  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: 'TCH-ERR:: not allowed
                  2023-05-02 18:02:27.715  - error: kecontact.0 (18074) Error received from wallbox: TCH-ERR:: not allowed
                  2023-05-02 18:02:28.014  - debug: kecontact.0 (18074) Sent 'report 3' to 10.3.1.28:7090
                  2023-05-02 18:02:28.015  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "3",
                  "U1": 0,
                  "U2": 0,
                  "U3": 0,
                  "I1": 0,
                  "I2": 0,
                  "I3": 0,
                  "P": 0,
                  "PF": 0,
                  "E pres": 0,
                  "Sec": 966
                  2023-05-02 18:02:28.032  - debug: kecontact.0 (18074) Available surplus: 2237
                  2023-05-02 18:02:28.315  - debug: kecontact.0 (18074) Sent 'report 100' to 10.3.1.28:7090
                  2023-05-02 18:02:28.316  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "100",
                  "Session ID": 0,
                  "Curr HW": 0,
                  "E start": 0,
                  "E pres": 0,
                  "started[s]": 0,
                  "ended[s]": 0,
                  "started": "0",
                  "ended": "0",
                  "reason": 0,
                  "timeQ": 0,
                  "Sec": 966
                  2023-05-02 18:02:28.317  - debug: kecontact.0 (18074) History ID received: 00
                  2023-05-02 18:02:42.415  - debug: kecontact.0 (18074) Sent 'report 2' to 10.3.1.28:7090
                  2023-05-02 18:02:42.417  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "2",
                  "State": 1,
                  "Error1": 0,
                  "Error2": 0,
                  "Plug": 3,
                  "AuthON": 0,
                  "Authreq": 0,
                  "Enable sys": 0,
                  "Enable user": 0,
                  "Max curr": 0,
                  "Max curr %": 1000,
                  "Curr HW": 16000,
                  "Curr user": 63000,
                  "Curr FS": 0,
                  "Tmo FS": 0,
                  "Curr timer": 0,
                  "Tmo CT": 0,
                  "Setenergy": 0,
                  "Output": 1,
                  "Input": 0,
                  "Sec": 980
                  2023-05-02 18:02:42.458  - info: kecontact.0 (18074) activating X2 source from 0 to 4 for phase switching
                  2023-05-02 18:02:42.715  - debug: kecontact.0 (18074) Sent 'x2src 4' to 10.3.1.28:7090
                  2023-05-02 18:02:42.716  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: 'TCH-ERR:: not allowed
                  2023-05-02 18:02:42.716  - error: kecontact.0 (18074) Error received from wallbox: TCH-ERR:: not allowed
                  2023-05-02 18:02:43.016  - debug: kecontact.0 (18074) Sent 'report 3' to 10.3.1.28:7090
                  2023-05-02 18:02:43.017  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "3",
                  "U1": 0,
                  "U2": 0,
                  "U3": 0,
                  "I1": 0,
                  "I2": 0,
                  "I3": 0,
                  "P": 0,
                  "PF": 0,
                  "E pres": 0,
                  "Sec": 981
                  2023-05-02 18:02:43.036  - debug: kecontact.0 (18074) Available surplus: 2351
                  2023-05-02 18:02:43.037  - debug: kecontact.0 (18074) not enough power for charging ...
                  2023-05-02 18:02:43.316  - debug: kecontact.0 (18074) Sent 'report 100' to 10.3.1.28:7090
                  2023-05-02 18:02:43.317  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "100",
                  "Session ID": 0,
                  "Curr HW": 0,
                  "E start": 0,
                  "E pres": 0,
                  "started[s]": 0,
                  "ended[s]": 0,
                  "started": "0",
                  "ended": "0",
                  "reason": 0,
                  "timeQ": 0,
                  "Sec": 981
                  2023-05-02 18:02:43.318  - debug: kecontact.0 (18074) History ID received: 00
                  2023-05-02 18:02:57.416  - debug: kecontact.0 (18074) Sent 'report 2' to 10.3.1.28:7090
                  2023-05-02 18:02:57.418  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "2",
                  "State": 1,
                  "Error1": 0,
                  "Error2": 0,
                  "Plug": 3,
                  "AuthON": 0,
                  "Authreq": 0,
                  "Enable sys": 0,
                  "Enable user": 0,
                  "Max curr": 0,
                  "Max curr %": 1000,
                  "Curr HW": 16000,
                  "Curr user": 63000,
                  "Curr FS": 0,
                  "Tmo FS": 0,
                  "Curr timer": 0,
                  "Tmo CT": 0,
                  "Setenergy": 0,
                  "Output": 1,
                  "Input": 0,
                  "Sec": 995
                  2023-05-02 18:02:57.453  - info: kecontact.0 (18074) activating X2 source from 0 to 4 for phase switching
                  2023-05-02 18:02:57.717  - debug: kecontact.0 (18074) Sent 'x2src 4' to 10.3.1.28:7090
                  2023-05-02 18:02:57.718  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: 'TCH-ERR:: not allowed
                  2023-05-02 18:02:57.719  - error: kecontact.0 (18074) Error received from wallbox: TCH-ERR:: not allowed
                  2023-05-02 18:02:58.017  - debug: kecontact.0 (18074) Sent 'report 3' to 10.3.1.28:7090
                  2023-05-02 18:02:58.019  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "3",
                  "U1": 0,
                  "U2": 0,
                  "U3": 0,
                  "I1": 0,
                  "I2": 0,
                  "I3": 0,
                  "P": 0,
                  "PF": 0,
                  "E pres": 0,
                  "Sec": 996
                  2023-05-02 18:02:58.039  - debug: kecontact.0 (18074) Available surplus: 2315
                  2023-05-02 18:02:58.318  - debug: kecontact.0 (18074) Sent 'report 100' to 10.3.1.28:7090
                  2023-05-02 18:02:58.319  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "100",
                  "Session ID": 0,
                  "Curr HW": 0,
                  "E start": 0,
                  "E pres": 0,
                  "started[s]": 0,
                  "ended[s]": 0,
                  "started": "0",
                  "ended": "0",
                  "reason": 0,
                  "timeQ": 0,
                  "Sec": 996
                  2023-05-02 18:02:58.320  - debug: kecontact.0 (18074) History ID received: 00
                  2023-05-02 18:03:12.416  - debug: kecontact.0 (18074) Sent 'report 2' to 10.3.1.28:7090
                  2023-05-02 18:03:12.418  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "2",
                  "State": 1,
                  "Error1": 0,
                  "Error2": 0,
                  "Plug": 3,
                  "AuthON": 0,
                  "Authreq": 0,
                  "Enable sys": 0,
                  "Enable user": 0,
                  "Max curr": 0,
                  "Max curr %": 1000,
                  "Curr HW": 16000,
                  "Curr user": 63000,
                  "Curr FS": 0,
                  "Tmo FS": 0,
                  "Curr timer": 0,
                  "Tmo CT": 0,
                  "Setenergy": 0,
                  "Output": 1,
                  "Input": 0,
                  "Sec": 1010
                  2023-05-02 18:03:12.440  - info: kecontact.0 (18074) activating X2 source from 0 to 4 for phase switching
                  2023-05-02 18:03:12.716  - debug: kecontact.0 (18074) Sent 'x2src 4' to 10.3.1.28:7090
                  2023-05-02 18:03:12.717  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: 'TCH-ERR:: not allowed'
                  2023-05-02 18:03:12.717  - error: kecontact.0 (18074) Error received from wallbox: TCH-ERR:: not allowed
                  2023-05-02 18:03:13.017  - debug: kecontact.0 (18074) Sent 'report 3' to 10.3.1.28:7090
                  2023-05-02 18:03:13.018  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "3",
                  "U1": 0,
                  "U2": 0,
                  "U3": 0,
                  "I1": 0,
                  "I2": 0,
                  "I3": 0,
                  "P": 0,
                  "PF": 0,
                  "E pres": 0,
                  "Sec": 1011
                  2023-05-02 18:03:13.038  - debug: kecontact.0 (18074) Available surplus: 2307
                  2023-05-02 18:03:13.038  - debug: kecontact.0 (18074) not enough power for charging ...
                  2023-05-02 18:03:13.317  - debug: kecontact.0 (18074) Sent 'report 100' to 10.3.1.28:7090
                  2023-05-02 18:03:13.319  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "100",
                  "Session ID": 0,
                  "Curr HW": 0,
                  "E start": 0,
                  "E pres": 0,
                  "started[s]": 0,
                  "ended[s]": 0,
                  "started": "0",
                  "ended": "0",
                  "reason": 0,
                  "timeQ": 0,
                  "Sec": 1011
                  Die 4 hatte ich manuell nochmal gesetzt und dann die 2.
                  Werte setzen über kecontact.0.x2phaseSource mag er nicht 🙂
                  2023-05-02 18:14:00.154  - debug: kecontact.0 (18074) Sent 'x2src 4' to 10.3.1.28:7090
                  2023-05-02 18:14:00.157  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: 'TCH-ERR:: not allowed'
                  2023-05-02 18:14:00.157  - error: kecontact.0 (18074) Error received from wallbox: TCH-ERR:: not allowed
                  2023-05-02 18:14:06.119  - debug: kecontact.0 (18074) Sent 'x2src 2' to 10.3.1.28:7090
                  2023-05-02 18:14:06.120  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: 'TCH-ERR:: not allowed'
                  2023-05-02 18:14:06.121  - error: kecontact.0 (18074) Error received from wallbox: TCH-ERR:: not allowed
                  2023-05-02 18:14:12.447  - debug: kecontact.0 (18074) Sent 'report 2' to 10.3.1.28:7090
                  2023-05-02 18:14:12.448  - debug: kecontact.0 (18074) UDP datagram from 10.3.1.28:7090: '{
                  "ID": "2",
                  "State": 1,
                  "Error1": 0,
                  "Error2": 0,
                  "Plug": 3,
                  "AuthON": 0,
                  "Authreq": 0,
                  "Enable sys": 0,
                  "Enable user": 0,
                  "Max curr": 0,
                  "Max curr %": 1000,
                  "Curr HW": 16000,
                  "Curr user": 63000,
                  "Curr FS": 0,
                  "Tmo FS": 0,
                  "Curr timer": 0,
                  "Tmo CT": 0,
                  "Setenergy": 0,
                  "Output": 0,
                  "Input": 0,
                  "X2 phaseSwitch": 0,
                  "Sec": 1670
                    @darkiop ok. Das sieht mit so aus, als wenn der Adapter das x2src nicht korrekt interpretiert. Da muss ich wohl noch mal nacharbeiten.Werde ich aber frühestens morgen Abend schaffen. Dann gibt's wohl ne korrigierte Version.
                      @darkiop So, der x2-Fehler sollte nun mit der neusten Version behoben sein. Ich hatte die Einstellung einfach falsch ausgelesen.
                      Bitte mal probieren.
                      Warum Du in der Konfigseite keine gescheiten Texte sieht, ist mir nicht klar. Bei mir sehen die einwandfrei aus. Welche Sprache hast Du eingestellt (deutsch oder englisch)?
                        Gutes Timing, gerade heimgekommen und schnell geschaut 😉
                        Der X2 Fehler ist weg, das passt. Danke!
                        Nach Freigabe von zusätzlichen Watt hat auch die Ladung mit einer Phase gestartet. Ich werd mal schauen das ich dafür ein kleines Monitoring aufsetze und es die Tage beobachten.
                        2023-05-03 18:48:42.575  - debug: kecontact.0 (115408) Available surplus: 886.287
                        2023-05-03 18:48:42.575  - debug: kecontact.0 (115408) power: 886.287 / voltage: 230 * 1000 / delta: 1000 / phases: 1 * delta = 4000
                        2023-05-03 18:48:42.575  - debug: kecontact.0 (115408) check with additional power of: 3001
                        2023-05-03 18:48:42.575  - debug: kecontact.0 (115408) power: 3887.2870000000003 / voltage: 230 * 1000 / delta: 1000 / phases: 1 * delta = 17000
                        2023-05-03 18:48:42.575  - debug: kecontact.0 (115408) Minimum amperage reached by addPower of 3001
                        2023-05-03 18:48:42.576  - debug: kecontact.0 (115408) wallbox set to charging maximum of 6000 mA
                        2023-05-03 18:48:42.849  - debug: kecontact.0 (115408) Sent 'report 100' to 10.3.1.28:7090
                        2023-05-03 18:48:42.850  - debug: kecontact.0 (115408) UDP datagram from 10.3.1.28:7090: '{
                        "ID": "100",
                        "Session ID": 366,
                        "Curr HW": 16000,
                        "E start": 43721726,
                        "E pres": 869,
                        "started[s]": 89901,
                        "ended[s]": 0,
                        "started": "89901000",
                        "ended": "0",
                        "reason": 5,
                        "timeQ": 0,
                        "Sec": 90141
                        Englisch, aber das war wohl ein Browsercache Thema ... hat sich hier am Macbook jetzt erledigt.
                        Danke nochmals für deine Arbeit an dem Adapter!!
                          darkiop Most Active last edited by darkiop
                          @Sneak-L8
                          Hatte diese Woche leider keine Zeit mich weiter mit dem Thema zu beschäftigen.
                          Was mir heut aufgefallen ist, müsste die WB nicht bei dieser Ausgangsituation auf 1P umschalten und mit 1380W laden?
                          2023-05-12 13:54:54.540  - debug: kecontact.0 (485108) Available surplus: 1416
                          2023-05-12 13:54:54.540  - debug: kecontact.0 (485108) power: 1416 / voltage: 230 * 1000 / delta: 1000 / phases: 3 * delta = 2000
                          2023-05-12 13:54:54.540  - debug: kecontact.0 (485108) not enough power for charging ...
                          2023-05-12 13:54:54.815  - debug: kecontact.0 (485108) Sent 'report 100' to 10.3.1.28:7090
                          2023-05-12 13:54:54.817  - debug: kecontact.0 (485108) UDP datagram from 10.3.1.28:7090: '{
                          "ID": "100",
                          "Session ID": 369,
                          "Curr HW": 16000,
                          "E start": 44293071,
                          "E pres": 58944,
                          "started[s]": 842342,
                          "ended[s]": 0,
                          "started": "842342000",
                          "ended": "0",
                          "reason": 5,
                          "timeQ": 0,
                          "Sec": 850110
                          2023-05-12 14:00:54.551  - debug: kecontact.0 (485108) Available surplus: 2232
                          2023-05-12 14:00:54.551  - debug: kecontact.0 (485108) power: 2232 / voltage: 230 * 1000 / delta: 1000 / phases: 3 * delta = 3000
                          2023-05-12 14:00:54.551  - debug: kecontact.0 (485108) not enough power for charging ...
                          2023-05-12 14:00:54.832  - debug: kecontact.0 (485108) Sent 'report 100' to 10.3.1.28:7090
                          2023-05-12 14:00:54.834  - debug: kecontact.0 (485108) UDP datagram from 10.3.1.28:7090: '{
                          "ID": "100",
                          "Session ID": 369,
                          "Curr HW": 16000,
                          "E pres": 58944,
                          "ended[s]": 0,
                          "ended": "0",
                          "reason": 5,
                          "timeQ": 0,
                          "Sec": 850470
                          Die Einstellungen sehen aktuell wie folgt aus:
                            @darkiop Du hast recht. Das war noch ein Fehler. Ich hatte nur auf die Einstellung "stateFor1p3p" geschaut, um festzustellen, ob eine Phasenumschaltung möglich ist. Ich muss aber alternativ auch auf die X2-Option abfragen.
                            Bitte neuste github-Version installieren und probieren.
                              @sneak-l8
                              Super, muss nun leider los und kanns wohl erst wieder übers WE testen - je nach Sonnenstand 🙂
                              Melde mich dann.
                              Danke!
                                @Sneak-L8
                                Bin doch etwas früher nach Hause gekomme und etwas Sonne liegt noch an 🙂 (aber alternativ könnt ich ja auch dem Adapter einen anderen Wert anstelle des echten Stromzähler geben).
                                2023-05-12 17:02:23.455  - warn: kecontact.0 (498144) Invalid value für 1p3p switch: null (type object)
                                Da hat sich wohl noch ein Fehler eingeschlichen 😉
                                  @darkiop Ok, auch die Abfrage ob 1p oder 3p war noch auf den Umschalt-State und nicht X2 ausgerichtet. Bitte nochmal.
                                    darkiop Most Active @Sneak-L8 last edited by darkiop
                                    @sneak-l8
                                    Die Warnung ist weg. Ich häng heut Abend mal nen virtuellen Stromzähler in den Adapter und teste - aktuell gibts nicht ausreichend Strom vom Dach 😉
                                    2023-05-12 17:34:50.230  - debug: kecontact.0 (500436) Available surplus: 398.5770000000002
                                    2023-05-12 17:34:50.230  - debug: kecontact.0 (500436) power: 398.5770000000002 / voltage: 230 * 1000 / delta: 1000 / phases: 1 * delta = 2000
                                    2023-05-12 17:34:50.230  - debug: kecontact.0 (500436) not enough power for charging ...
                                    2023-05-12 17:34:50.513  - debug: kecontact.0 (500436) Sent 'report 100' to 10.3.1.28:7090
                                    2023-05-12 17:34:50.516  - debug: kecontact.0 (500436) UDP datagram from 10.3.1.28:7090: '{
                                    "ID": "100",
                                    "Session ID": 370,
                                    "Curr HW": 16000,
                                    "E start": 44366785,
                                    "E pres": 19092,
                                    "started[s]": 861353,
                                    "ended[s]": 0,
                                    "started": "861353000",
                                    "ended": "0",
                                    "reason": 5,
                                    "timeQ": 0,
                                    "Sec": 863305
                                      @Sneak-L8
                                      Hallo Volker, hab eben nochmal etwas getestet, folgendes ist mir aufgefallen:
                                      1. Vom Dach kommen 500W, addPower steht auf 1200:
                                      • Ladung startete 1-phasig mit rund 1.2kW/h
                                      • Wird jetzt addPower verändert (über den DP direkt), z.B. auf 6000, wird weiterhin mit 1.2kW/h geladen
                                      1. Das ändern von kecontact.0.automatic.addPower wirkt sich nicht auf die Einstellung der Adapter-Instanz - hier blieben die 1200
                                      2. Das ändern von kecontact.0.x2phaseSwitch schaltet direkt die Phasen um. Hast du eine Ahnung wie das mit der "Zwangspause" innerhalb der Keba gelöst ist? Die Ladung des Autos sollte vorher ja gestoppt werden (inkl. der Zwangspause von 5min).
                                      3. Wenn der SoC des Autoakkus auf 100% steht, reguliert der Adapter trotzdem den Ladestrom der Keba, z.B. regulate wallbox from 13000 to 11000mA. Wie wäre es dem Adapter noch den SoC des Autoakkus mitzuteilen und das dann bei 100% pausieren. Ggf. sollte man dann aber auch über einen Zweiten Punkt, der maximal erlaubtenLadung des Akkus (z.B. 80%) nachdenken.
                                      Fürs Testen mit einem virtuellen Zähler, reicht es aus hier einfach ein DP vom Typ number zu nehmen und einen Wert, z.B. -8000W für die PV-Produktion, zu übergeben? Wartet dein Adapter auf die aktulisierung des Zähler DPs oder prüft er selbst nach x-Sekunden?
                                        @Sneak-L8
                                        2023-05-12 20:43:48.975  - info: kecontact.0 (507026) change of photovoltaics automatic from true to false
                                        2023-05-12 20:43:51.486  - info: kecontact.0 (507026) change pause status of wallbox from true to false
                                        2023-05-12 20:43:51.810  - info: kecontact.0 (507026) updating X2 for switch of phases from 0 to 1...
                                        2023-05-12 20:43:51.810  - info: kecontact.0 (507026) (re)start charging
                                        2023-05-12 20:44:35.526  - info: kecontact.0 (507026) vehicle (re)starts to charge
                                        2023-05-12 20:55:18.485  - info: kecontact.0 (507026) change pause status of wallbox from false to true
                                        2023-05-12 20:55:18.814  - info: kecontact.0 (507026) updating X2 for switch of phases from 1 to 0...
                                        2023-05-12 20:55:18.814  - info: kecontact.0 (507026) stop charging
                                        1. Die Ladung lief mit deaktivierter PV-Automatik auf 3P mit 11kW/h. Beim stoppen des Vorgang wird wohl 2x kecontact.0.x2phaseSwitch auf 0 gesetzt.
                                          @darkiop addPower dient nur dazu, den Ladevorgang aufrechtzuerhalten. D.h. es wird nur so viel vom Netz geholt, um mit 6A laden zu können. Daher wirkt sich Deine Änderung auch nicht aus.
                                          Den X2 kannst Du natürlich auch manuell schalten. Dann bist Du selbst für die 5 Minuten verantwortlich. Das unterbrechen der Ladung macht die Keba laut Doku selbst, so dass ich hier im Adapter nur das Kommando senden muss.
                                          Ja, die Wallbox regelt sich bei 100% noch nach. Ist jetzt aber auch nicht so schlimm. Klar mit Phasen-Automatik schaltet dann auch der Schütz unnötig. Man kann einen SoC natürlich anbinden, aber dann kann schlecht auch mal jemand anderes laden. Daher würde ich keinen SoC berücksichtigen. Kannst ja aber ein Skript schreiben, das bei SoC 100 den Adapter pausiert.
                                          Der Adapter prüft alle 15 Sekunden die Werte und regelt alle 30 Sekunden neu.
                                          Das 2x schalten kann ich mit noch anschauen. Macht aber eigentlich nichts, da beim 2x Mal der Wert ja nicht geändert wird. Oder hast Du da Aktivität am Schütz /S10 bemerkt?
                                            Guten Abend.
                                            Ok, d.h. es ist auch völlig in Ordnung (aus deiner Sicht der Idee dahinter) das Einstellungen des Adapters und Wert im DP nicht immer synchron sind?
                                            Gut zu Wissen 😉 Wäre es nicht Sinnvoll. um die Ladelektronik der Autos zu schonen, vorher immer ein stop chargeing zu senden?
                                            Ok, passt - so hatte ich das dann auch gelöst. Hauptsächlich um das schalten Schützes zu verringern.
                                            Denke der Ansatz mit dem virtuellen Zähler hat sich erstmal erledigt - die letzten Tage hat das regeln / schalten ganz gut funktioniert.
                                            Nein, keine Aktivität - ist mir nur im Log aufgefallen.
                                            81.1k
                                            1267
                                            428654
