    4. [neuer Adapter] smartgarden adapter for Gardena smart system
      SaschaS @jpgorganizer last edited by
      @jpgorganizer Hab jetzt das Loglevel auf 3 geändert.
      Connection failure: return with error
      Hoffentlich ist man dann beim nächsten Mal schlauer. Ich tue mir schwer auf den Logs jetzt irgendwas erkennen zu können. 😞
      jpgorganizer 1 Reply Last reply Reply Quote 0
      • jpgorganizer
        jpgorganizer @SaschaS last edited by
        @saschas
        du hast die LoginProcedur noch nicht umgestellt auf Application Secret und API-Key. Es gibt von mir keinen Support mehr für Login mit USername + Passwort. .... Steht auch im Readme
          @jpgorganizer Danke für den Tipp! Das war mir gar nicht so bewusst, dass bei mir der Adapter nicht auf Application Secret und API-Key läuft. Als ich den Adapter seinerseits installiert habe, habe ich offenbar nur Application Key, aber nicht den Application Secret eingetragen gehabt. 😲
          Warum weiß ich auch nicht. Die Informationen waren ja da...
          Also mal kurz die Daten eingetragen. Adapter neugestartet. Jetzt abwarten bis zum nächsten Triggerpunkt. Erstmal schauen die Logins fehlerfrei aus 🙂
          smartgarden.0
          2022-08-04 12:54:57.833	info	3/ get_locations ...
          smartgarden.0
          2022-08-04 12:54:57.832	info	3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXX-XXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXX-XXXXXXXXXXXXXX
          smartgarden.0
          2022-08-04 12:54:57.830	info	3/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
          smartgarden.0
          2022-08-04 12:54:57.829	info	3/ Connection: successful: response.statusCode / statusMessage=200 / OK
          smartgarden.0
          2022-08-04 12:54:57.745	info	3/ ---> State change by device: state sg.0.info.adapterversion changed: 2.0.0 (ack = true)
          smartgarden.0
          2022-08-04 12:54:57.659	info	3/ ---> State change by device: state sg.0.info.revision changed: Main: 2831 / API: 2831 (ack = true)
          smartgarden.0
          2022-08-04 12:54:57.655	info	3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
          smartgarden.0
          2022-08-04 12:54:57.647	info	3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
          smartgarden.0
          2022-08-04 12:54:57.637	info	3/ sgSetState: info.revision value=Main: 2831 / API: 2831 ack=true
          smartgarden.0
          2022-08-04 12:54:57.562	info	3/ connect ... using client credentials grant
          smartgarden.0
          2022-08-04 12:54:57.561	info	3/ connect ... empty password
          smartgarden.0
          2022-08-04 12:54:57.560	info	3/ connect ... empty username
          smartgarden.0
          2022-08-04 12:54:57.560	info	3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
          smartgarden.0
          2022-08-04 12:54:57.559	info	3/ connecting to Gardena Smart System Service ...
          smartgarden.0
          2022-08-04 12:54:57.557	info	3/ sgSetState: info.connection value=false ack=true
          smartgarden.0
          2022-08-04 12:54:57.553	info	3/ connectToGardena...
          smartgarden.0
          2022-08-04 12:54:57.551	info	3/ getConnection...
          smartgarden.0
          2022-08-04 12:54:57.488	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v14.19.3, js-controller: 4.0.23
          smartgarden.0
          2022-08-04 12:54:51.480	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          smartgarden.0
          2022-08-04 12:54:51.479	info	terminating
          DANKE!!!
            mameier1234 @jpgorganizer last edited by
            @jpgorganizer Kaum beobachtet man die Sache, passiert es nicht mehr 🙂
            Ich hatte jetzt keinerlei Probleme mehr.. (und das Logging wieder rungtergedreht..)
              mk712 last edited by mk712
              ich habe meinen Sileno Mäher ein paar Wochen "ausgesetzt", demzufolge Adapter und Scripte pausiert. Jetzt, nach der Re-Aktivierung und Aktualisierung des Adapters habe ich war sofort wieder Verbindung bekommen (alles hübsch grün), jedoch aktualisieren sich die DP nicht mehr. Der Zeitstempel wird regelmäßig gesetzt, aber eben ohne Aktualisierung. Eine Befehlsübergabe per Script oder DP-Eintrag an den Mäher funktioniert, es kommt nur nichts zurück. Zudem fehlen nach der "Neuanlage" des DP-Baumes einige mir wichtige Datenpunkte wie z.B. "lastErrorCode_value". Dazu habe ich im Changelog der neuen Adapterversion 2 zwar etwas gelesen (function and configuration parameter pre-define states removed. All Gardena data points get deleted and created again) - da steh aber nix von gibt es nicht mehr?!
              Kann mir da jemand folgen und helfen?
              btw. - hab nur einen Mäher, keine weiteren Geräte.
              Danke und Grüße
              MK
              EDIT 1: es sieht wohl so aus, das der Mäher das Problem selbst verursacht, also keine Meldungen an das System inkl. sich selbst absetzt...
              EDIT 2: am Mähroboter hatte sich wohl das Funkmodul "aufgehängt", nach dem Ab- und Anstecken des Akku, was einen Neustart des Funkmoduls initiierte, läuft alles wie gehabt.
              Ein großes Dankeschön für diesen wertvollen Adapter!
                manuel35i @SaschaS last edited by
                Kurze Frage warum ist bei mir das Feld Application Secret ausgegraut.
                Kann leider nichts eingeben.
                  mameier1234 @manuel35i last edited by
                  @manuel35i Weil entweder Secret oder Benutzername-Passwort...
                    manuel35i @mameier1234 last edited by
                    @mameier1234
                    Dankeschön für die Info
                      Roadrunner last edited by
                      zwar etwas Off-Topic, aber hat eigentlich schon jemand versucht das Ganze ohne das Gardena Gateway aufzuziehen? (zB esp32 und 868Mhz-Modul oder Lemonbeat-Dongle)
                      Schöne Grüße!
                        ChrisChros last edited by
                        Hat sonst noch wer Problem mit der Verbindung zum Server von Gardena?
                        Bekomme seit heute Mittag folgende Fehlermeldung:
                        2023-05-03 11:38:59.156 - error: smartgarden.0 (20631) Error: request returned 403 Forbidden
                        Das ganze wiederholt sich alle 5 Minuten.
                        Gruß Chris
                        B N M 3 Replies Last reply Reply Quote 0
                          BlueBook @ChrisChros last edited by BlueBook
                          @chrischros is bei mir auch so 😞
                          Ich hab das firmware update durchgeführt. Ich denke daran liegt es 😕
                          Obwohl du hast recht. Es gab vorher auch schon Probleme.
                          Über die App von Gardena läuft es, hm
                            ChrisChros @BlueBook last edited by
                            @bluebook ich denke an dem Update liegt es nicht denn das habe ich schon seit dem Wochenende drauf als ich alles wieder reaktiviert habe.
                            Die Fehlermeldung habe ich aber erst seit heute, davor gab es keine Auffälligkeiten.
                            • N
                              netfriend @ChrisChros last edited by
                              @chrischros sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                              Gruß Chris
                              Ja, ist bei mir auch so.
                              Ich habe aber keinerlei Änderungen am System vorgenommen.
                              • JohGre
                                JohGre last edited by
                                gibt schon eine Thread dazu.
                                https://forum.iobroker.net/topic/65105/adapter-smartgarden-fehler-403?_=1683132394304
                                  mirage @ChrisChros last edited by
                                  @chrischros
                                  bei mir das Gleiche, seit 13:30 alle 5 min die selbe Fehlermeldung.
                                  Keine Änderung am System.
                                    Pino72 @mirage last edited by
                                    Dito....
                                    • jpgorganizer
                                      jpgorganizer @Pino72 last edited by
                                      https://forum.iobroker.net/topic/65105/adapter-smartgarden-fehler-403/5?_=1683207342760
                                        Pistus @jpgorganizer last edited by
                                        @jpgorganizer Hallo, auf meinem Raspberry Py 3B V2.1 habe ich iobroker installiert und kann mittels ssh und auch über die URL auf iobroker zugreifen.
                                        Bei Husqvarna habe ich mich registriert und habe jetzt eine Authentication API, eine Automover Connect API und eine Gardena smart System API. Alle drei API's haben ein Applications Key un ein Applications sekret
                                        Gardena smart Garden habe ich installiert und muss in der Instanz jetzt key und secret eintragen. Aber von welcher API? Entschuldigt bitte die simple Frage, aber ich bin absoluter Neuling und unbedarft. Ich möchte iobroker nutzen um meinen smart Sileno Möhroboter bei Regen zu stoppen.
                                        Grüße, Franz
                                        • jpgorganizer
                                          jpgorganizer @Pistus last edited by
                                          @pistus sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                          .... ich habe jetzt eine Authentication API, eine Automover Connect API und eine Gardena smart System API. Alle drei API's haben ein Applications Key un ein Applications sekret ...
                                          falsch, du hast eine Applikation mit zugeordneten APIs und die Applikation hat einen key und ein secret - ich glaube nicht, dass das bei dir anders sein wird
                                          und die Automower Connect API brauchst du für den smartgarden Adapter nicht.
                                          siehe https://github.com/jpgorganizer/ioBroker.smartgarden#requirements
                                            @jpgorganizer Danke für die Info und den Link, den ich noch nicht kannte.
                                            gardena smart system smartgarden
                                            108
                                            1080
                                            277622
