    • simatec
      @sushibomba Dein System ist mit sehr großer Wahrscheinlichkeit nicht auf aktuellen Stand.
        Thomas Braun Most Active @Sushibomba last edited by
        @sushibomba
        iob stop
        iob fix
        iob start
        Abwarten bis der iobroker vollständig gestartet ist.
        iob diag
          Sushibomba @Thomas Braun last edited by Homoran
          @thomas-braun sagte in Test Adapter ioBroker.backitup v2.6.x:
          iob diag
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 4 Model B Rev 1.1
          Architecture    : aarch64
          Docker          : false
          Virtualization  : none
          Distributor ID: Raspbian
          Description:    Raspbian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          Systemuptime and Load:
           15:28:36 up 16:31,  1 user,  load average: 4.51, 3.65, 2.70
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          Other values than 0x0 hint to temperature/voltage problems
          temp=55.5'C
          volt=0.8625V
          *** Time and Time Zones ***
                         Local time: Wed 2023-05-03 15:28:36 CEST
                     Universal time: Wed 2023-05-03 13:28:36 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.8G        2.5G         82M        3.0M        1.2G        1.8G
          Swap:            99M        3.0M         96M
          Total:          3.9G        2.5G        179M
                   3793 M total memory
                   2465 M used memory
                   2292 M active memory
                   1046 M inactive memory
                     82 M free memory
                    153 M buffer memory
                   1090 M swap cache
                     99 M total swap
                      3 M used swap
                     96 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4      117G   18G   95G  16% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
          tmpfs          tmpfs     759M  856K  758M   1% /run
          /dev/sda1      vfat      253M   51M  202M  20% /boot
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Tue May  2 22:57:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:26:5C:BB vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=6b1df87b-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Tue May  2 22:57:18 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
          [Tue May  2 22:57:18 2023] EXT4-fs (sda2): write access will be enabled during recovery
          [Tue May  2 22:57:18 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
          [Tue May  2 22:57:18 2023] EXT4-fs (sda2): 18 orphan inodes deleted
          [Tue May  2 22:57:18 2023] EXT4-fs (sda2): recovery complete
          [Tue May  2 22:57:18 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue May  2 22:57:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Tue May  2 22:57:20 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          7.3G    /var/
          5.2G    /var/log
          3.9G    /var/log/journal/e62fdccebd65415cae66edd105f72d4f
          1.3G    /var/cache/apt/archives
          Archived and active journals take up 3.8G in the file system.
          /opt/iobroker/backups:
          3.2G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          921M    /opt/iobroker/iobroker-data/
          593M    /opt/iobroker/iobroker-data/files
          163M    /opt/iobroker/iobroker-data/backup-objects
          109M    /opt/iobroker/iobroker-data/history
          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
          33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
          27M     /opt/iobroker/iobroker-data/objects.jsonl
          27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
          19M     /opt/iobroker/iobroker-data/states.jsonl
          19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v16.20.0
          /usr/bin/node           v16.20.0
          /usr/bin/npm            8.19.4
          /usr/bin/npx            8.19.4
          nodejs:
            Installed: 16.20.0-deb-1nodesource1
            Candidate: 16.20.0-deb-1nodesource1
            Version table:
           *** 16.20.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u4 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          MULTIHOSTSERVICE/enabled: false
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     6.1.4
          Adapters from github:   4
          Adapter State
          + system.adapter.admin.0                  : admin                 : Pi4ioBroker128GB                         -  enabled, port: 8081, bind: 192.168.178.58, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : Pi4ioBroker128GB                         -  enabled
          + system.adapter.backitup.0               : backitup              : Pi4ioBroker128GB                         -  enabled
          + system.adapter.cloud.0                  : cloud                 : Pi4ioBroker128GB                         -  enabled
            system.adapter.daswetter.0              : daswetter             : Pi4ioBroker128GB                         -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : Pi4ioBroker128GB                         -  enabled
            system.adapter.devices.0                : devices               : Pi4ioBroker128GB                         -  enabled
          + system.adapter.discovery.0              : discovery             : Pi4ioBroker128GB                         -  enabled
            system.adapter.dwd.0                    : dwd                   : Pi4ioBroker128GB                         -  enabled
          + system.adapter.echarts.0                : echarts               : Pi4ioBroker128GB                         -  enabled
          + system.adapter.esphome.0                : esphome               : Pi4ioBroker128GB                         -  enabled
            system.adapter.fb-checkpresence.0       : fb-checkpresence      : Pi4ioBroker128GB                         - disabled
            system.adapter.flot.0                   : flot                  : Pi4ioBroker128GB                         - disabled
          + system.adapter.fullybrowser.0           : fullybrowser          : Pi4ioBroker128GB                         -  enabled
          + system.adapter.history.0                : history               : Pi4ioBroker128GB                         -  enabled
            system.adapter.ical.0                   : ical                  : Pi4ioBroker128GB                         -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : Pi4ioBroker128GB                         -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : Pi4ioBroker128GB                         -  enabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : Pi4ioBroker128GB                         -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : Pi4ioBroker128GB                         -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Pi4ioBroker128GB                         -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Pi4ioBroker128GB                         -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Pi4ioBroker128GB                         -  enabled
          + system.adapter.influxdb.0               : influxdb              : Pi4ioBroker128GB                         -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : Pi4ioBroker128GB                         -  enabled
          + system.adapter.iot.0                    : iot                   : Pi4ioBroker128GB                         -  enabled
          + system.adapter.javascript.0             : javascript            : Pi4ioBroker128GB                         -  enabled
          + system.adapter.klipper-moonraker.0      : klipper-moonraker     : Pi4ioBroker128GB                         -  enabled
            system.adapter.kodi.0                   : kodi                  : Pi4ioBroker128GB                         - disabled, port: 9090
          + system.adapter.logparser.0              : logparser             : Pi4ioBroker128GB                         -  enabled
            system.adapter.material.0               : material              : Pi4ioBroker128GB                         -  enabled
            system.adapter.meteoalarm.0             : meteoalarm            : Pi4ioBroker128GB                         -  enabled
            system.adapter.mihome-vacuum.0          : mihome-vacuum         : Pi4ioBroker128GB                         - disabled, port: 54321
          + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Pi4ioBroker128GB                         -  enabled, port: 54321
          + system.adapter.musiccast.0              : musiccast             : Pi4ioBroker128GB                         -  enabled
          + system.adapter.net-tools.0              : net-tools             : Pi4ioBroker128GB                         -  enabled
          + system.adapter.octoprint.0              : octoprint             : Pi4ioBroker128GB                         -  enabled
            system.adapter.plex.0                   : plex                  : Pi4ioBroker128GB                         - disabled
          + system.adapter.scenes.0                 : scenes                : Pi4ioBroker128GB                         -  enabled
          + system.adapter.sonoff.0                 : sonoff                : Pi4ioBroker128GB                         -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.spotify-premium.0        : spotify-premium       : Pi4ioBroker128GB                         - disabled
            system.adapter.synology.0               : synology              : Pi4ioBroker128GB                         - disabled, port: 5000
            system.adapter.synology.1               : synology              : Pi4ioBroker128GB                         - disabled, port: 5000
            system.adapter.synology.2               : synology              : Pi4ioBroker128GB                         - disabled, port: 5000
          + system.adapter.tankerkoenig.0           : tankerkoenig          : Pi4ioBroker128GB                         -  enabled
          + system.adapter.telegram.0               : telegram              : Pi4ioBroker128GB                         -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : Pi4ioBroker128GB                         -  enabled
          + system.adapter.tr-064.0                 : tr-064                : Pi4ioBroker128GB                         -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : Pi4ioBroker128GB                         -  enabled
          + system.adapter.tuya.0                   : tuya                  : Pi4ioBroker128GB                         -  enabled
            system.adapter.tvspielfilm.0            : tvspielfilm           : Pi4ioBroker128GB                         - disabled
            system.adapter.upnp.0                   : upnp                  : Pi4ioBroker128GB                         - disabled
            system.adapter.uv-protect.0             : uv-protect            : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-history.0            : vis-history           : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : Pi4ioBroker128GB                         -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-metro.0              : vis-metro             : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : Pi4ioBroker128GB                         -  enabled
            system.adapter.vis.0                    : vis                   : Pi4ioBroker128GB                         -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : Pi4ioBroker128GB                         -  enabled
          + system.adapter.web.0                    : web                   : Pi4ioBroker128GB                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.wifilight.0              : wifilight             : Pi4ioBroker128GB                         - disabled
          + system.adapter.wled.0                   : wled                  : Pi4ioBroker128GB                         -  enabled
          + system.adapter.worx.0                   : worx                  : Pi4ioBroker128GB                         -  enabled
          + system.adapter.ws.0                     : ws                    : Pi4ioBroker128GB                         -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.yamaha.0                 : yamaha                : Pi4ioBroker128GB                         -  enabled
          + system.adapter.zigbee.0                 : zigbee                : Pi4ioBroker128GB                         -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_da9285a4d13aec1187a6a0957a0af07f-if00-port0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.3.5    , installed 6.3.5
          Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
          Adapter    "backitup"     : 2.6.19   , installed 2.6.19
          Adapter    "cloud"        : 4.3.0    , installed 4.3.0
          Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
          Adapter    "device-reminder": 1.2.9  , installed 1.2.9
          Adapter    "devices"      : 1.1.2    , installed 1.1.2
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
          Adapter    "echarts"      : 1.0.12   , installed 1.0.12
          Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
          Adapter    "flot"         : 1.11.0   , installed 1.11.0
          Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "ical"         : 1.13.2   , installed 1.13.2
          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "info"         : 1.9.26   , installed 1.9.26
          Adapter    "iot"          : 1.14.2   , installed 1.14.2
          Adapter    "javascript"   : 6.1.4    , installed 6.1.4
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Adapter    "kodi"         : 2.0.9    , installed 2.0.9
          Adapter    "logparser"    : 2.1.1    , installed 2.1.1
          Adapter    "material"     : 1.1.2    , installed 1.1.2
          Adapter    "meteoalarm"   : 2.3.5    , installed 2.3.5
          Adapter    "mihome-vacuum": 3.9.5    , installed 3.8.8  [Updatable]
          Adapter    "musiccast"    : 0.1.5    , installed 0.1.5
          Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
          Adapter    "plex"         : 0.9.1    , installed 0.9.1
          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
          Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
          Adapter    "synology"     : 2.1.13   , installed 2.1.13
          Adapter    "telegram"     : 1.15.2   , installed 1.15.2
          Adapter    "text2command" : 2.3.0    , installed 2.3.0
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "tuya"         : 3.13.1   , installed 3.13.1
          Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "uv-protect"   : 0.4.0    , installed 0.4.0
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
          Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
          Adapter    "weatherunderground": 3.4.2, installed 3.4.2
          Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
          Adapter    "wled"         : 0.6.7    , installed 0.6.7
          Adapter    "worx"         : 2.1.3    , installed 2.1.3
          Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
          Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
          Objects and States
          Objects:        25536
          States:         21462
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 https://repos.influxdata.com/debian stable InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:4 https://apt.grafana.com stable InRelease
          Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
          Reading package lists...
          Pending Updates: 52
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1017889    8604/io.sonoff.0
          tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       1022712    10007/python3
          tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      0          13122      866/motion
          tcp        0      0 192.168.178.58:8081     0.0.0.0:*               LISTEN      1001       1015314    8313/io.admin.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1015204    8269/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1015211    8269/iobroker.js-co
          tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        12252      734/mariadbd
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          12846      691/apache2
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13660      649/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          17749      515/python2
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13006      616/influxd
          tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          13123      866/motion
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1018318    8922/io.web.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       1022194    9304/io.ws.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        13129      616/influxd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13662      649/sshd: /usr/sbin
          tcp6       0      0 :::3000                 :::*                    LISTEN      109        13218      779/grafana
          udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       1023035    9639/io.musiccast.0
          udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       1019058    8708/io.mihome-vacu
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1018049    8660/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1018050    8660/io.tuya.0
          udp        0      0 0.0.0.0:48144           0.0.0.0:*                           108        12064      502/avahi-daemon: r
          udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       1022721    10007/python3
          udp        0      0 192.168.178.58:5353     0.0.0.0:*                           1001       1022720    10007/python3
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1022715    10007/python3
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1023297    9912/io.esphome.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1018192    8929/io.wled.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12062      502/avahi-daemon: r
          udp6       0      0 :::33362                :::*                                108        12065      502/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        12063      502/avahi-daemon: r
          2023-05-03 15:28:00.345  - info: tuya.0 (8660) 50007884f4cfa22862f6: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.30:6668
          2023-05-03 15:28:02.769  - info: tankerkoenig.0 (9220) Start first request
          2023-05-03 15:28:12.825  - info: cloud.0 (9718) Trying to connect as system.user.admin to cloud
          2023-05-03 15:28:13.007  - info: cloud.0 (9718) Connection changed: connect
          2023-05-03 15:28:19.240  - debug: fullybrowser.0 (9067) get Information
          2023-05-03 15:28:21.049  - info: tuya.0 (8660) bf50531eb4322194f0vjim: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.26:6668
          2023-05-03 15:28:25.528  - info: tuya.0 (8660) bf5ed8fa1f086a6e20gtpf: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.52:6668
          2023-05-03 15:28:30.136  - info: tuya.0 (8660) 14407720c82b965de6ed: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.66:6668
          2023-05-03 15:28:37.017  - info: tuya.0 (8660) bfacc1df4320069c01qhho: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.65:6668
          2023-05-03 15:28:39.833  - info: tuya.0 (8660) bf3694683243c18e2aqufe: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.82:6668
          2023-05-03 15:28:43.417  - info: tuya.0 (8660) 50007884f4cfa22862f6: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.30:6668
          2023-05-03 15:28:43.547  - info: tuya.0 (8660) bfd296f711b61a5bc3lk8n: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.67:6668
          2023-05-03 15:28:48.601  - info: tuya.0 (8660) bf8e55efebd6170d14cqqc: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.38:6668
          2023-05-03 15:29:01.241  - info: alexa2.0 (8649) No smart home devices to query
          2023-05-03 15:29:14.011  - info: alexa2.0 (8649) Subscribing to states...
          2023-05-03 15:29:42.905  - info: tuya.0 (8660) bf3694683243c18e2aqufe: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.82:6668
          2023-05-03 15:29:46.489  - info: tuya.0 (8660) 50007884f4cfa22862f6: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.30:6668
          2023-05-03 15:30:00.161  - info: host.Pi4ioBroker128GB instance system.adapter.meteoalarm.0 started with pid 11096
          2023-05-03 15:30:04.620  - info: host.Pi4ioBroker128GB instance system.adapter.dwd.0 started with pid 11187
          2023-05-03 15:30:07.966  - info: meteoalarm.0 (11096) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v16.20.0, js-controller: 4.0.24
          2023-05-03 15:30:08.988  - info: host.Pi4ioBroker128GB instance system.adapter.daswetter.0 started with pid 11203
          iob diag has finished.
            @sushibomba sagte in Test Adapter ioBroker.backitup v2.6.x:
            Dein Dateisystem hat 'nen Schuss.
              Das heißt? Was kann ich jetzt machen? Wollte mein System eh komplett neu auf nen frisches 64Bit System wieder aufbauen und halt die Backups wieder einspielen damit ich meine ganzen Daten nicht verliere.
                @sushibomba
                Dann mach das. Auf einem neuen Speichermedium.
                  Sushibomba @Thomas Braun last edited by Sushibomba
                  Ja aber ich habe hier ja einen Post geöffnet, weil er sich beim backitup Adapter immer aufhängt.
                  Oder meinste das müsste jetzt wieder klappen mit der MySQL Datenbank durch den iob fix?
                    Homoran Global Moderator Administrators @Sushibomba last edited by
                    Ja aber ich habe hier ja einen Post geöffnet, weil er dich beim backitup Adapter immer aufhängt.
                    wie meinen?
                    Aber wenn die Daten defekt sind, dass sie nicht lesbar sind, kann einiges passieren.
                      @sushibomba
                      Mit MySQL macht der iobroker fix gar nix.
                        Sushibomba @Homoran last edited by Sushibomba
                        @Thomas-Braun
                        Ja damit ich meine Daten nicht verliere nutze ich den backitup Adapter. Das hat auch in der Vergangenheit immer gut geklappt mit den Sicherungen.
                        Nur seit neuestem halt das Problem mit der MySQL Sicherung.
                        Diese könnte ich aber doch auch über phpmyadmin separat sichern oder und dann nur den Rest von backitup einspielen lassen oder?
                        Und noch ne Frage nebenbei. Wenn ich auf dem neuen System iobroker wieder installiert habe und den backitup Adapter installiert habe um die Backups einzuspielen, kann ich dann z.B. mein Grafana Backup wiederherstellen ohne vorher Grafana wieder installiert zu haben über PuTTY? Also macht er das dann suchtomstisch beim Backup einspielen oder muss ich das immer vorher installieren bevor ich Backups wiederherstelle? Also genauso für influxdb etc.?
                          wieso sollte der Backitup Adapter externe Fremdprogramme installieren?
                            Nein, das sind nur die Nutzdaten. Das Rahmenwerk muss natürlich bereitgestellt werden. Ist immer so.
                              @Homoran
                              Also erst alle Pakete wieder installieren wie influxdb, grafana, mysql etc. und erst dann das backup wiederherstellen korrekt?
                                korrekt
                                und natürlich ioBroker!
                                  @simatec
                                  Die mysql backups die automatisch durchgelaufen sind, sind übrigens nur ca. 13mb groß.
                                  mysql_2023_04_28-02_01_57_backupiobroker.tar.gz
                                    Noch ne kurze Info. Heute Nacht ist das auto Backup wieder einwandfrei durchgelaufen. Ich verstehe das nicht. Nur manuell angestoßen friert er ein und stürzt ab.
                                    • Marc Berg
                                      Marc Berg Most Active last edited by
                                      @simatec
                                      Ich sichere mit dem Adapter u.a. zwei InfluxDB Buckets.
                                      Nach ein paar Tests habe ich gestern einen falschen Token in die Backitup Konfig geschrieben. Dadurch hat sich ein Problem gezeigt, bei dem ich mir nicht sicher bin, ob das so gewünscht ist.
                                      2023-05-07 00:53:17.697  - error: backitup.0 (94526) [iobroker/influxDB] Error: Command failed: "/opt/iobroker/bin/influx" backup --bucket iobroker30d --host http://influxdb2:8086 -t k6RH6nLY7jwrOnKnVaJofW8MhQwTp1tGG2kX9IC48X61DH1IzKzyX2UwWSZeJYrUkStOyUP28qlZp0pBRIjR4Q== "/opt/iobroker/backups/influxDB_2023_05_07-00_53_17_iob30_backupiobroker"
                                      2023-05-07 00:53:17.703  - error: backitup.0 (94526) [iobroker/influxDB] 2023/05/07 00:53:17 INFO: Downloading metadata snapshot
                                      2023-05-07 00:53:17.703  - error: backitup.0 (94526) [iobroker/influxDB] Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: unauthorized access
                                      2023-05-07 00:53:17.703  - error: backitup.0 (94526) [iobroker] Error: Command failed: "/opt/iobroker/bin/influx" backup --bucket iobroker30d --host http://influxdb2:8086 -t k6RH6nLY7jwrOnKnVaJofW8MhQwTp1tGG2kX9IC48X61DH1IzKzyX2UwWSZeJYrUkStOyUP28qlZp0pBRIjR4Q== "/opt/iobroker/backups/influxDB_2023_05_07-00_53_17_iob30_backupiobroker"
                                      Das Backup wird nach dem fehlgeschlagenen Versuch, das Bucket "iobroker30d" zu sichern, abgebrochen. Weitere konfigurierte Sicherungen (grafana, jarvis, nodered) werden nicht durchgeführt UND (das finde ich problematisch) es wird keine Notification über den Fehler versendet. In meinem Fall wäre das Pushover, aber ich denke auch andere "notification types" haben das Problem.
                                      Wenn ich die Sicherung manuell anstosse, ergibt sich das gleiche Bild. Nach dem Fehler beim InfluxDB Backup bricht der Vorgang ab, das Fenster wird auch nach ein paar Minuten nicht geschlossen.
                                      • Adapter-Version: 2.6.20
                                      • Node.js v18.16.0
                                      • js-controller 4.0.24
                                      • simatec
                                        simatec Developer Most Active @Marc Berg last edited by
                                        @marc-berg Kannst du mal bitte versuchen den Fehler nachzustellen mit aktivierter Option zum ignorieren von Backupfehlern?
                                        So kann ich es besser eingrenzen.
                                        Marc Berg 1 Reply Last reply Reply Quote 1
                                        • Marc Berg
                                          Marc Berg Most Active @simatec last edited by Marc Berg
                                          @simatec
                                          Started iobroker ...
                                          [DEBUG] [iobroker] - host.iobroker 13133 states saved
                                          [DEBUG] [iobroker] - host.iobroker 13839 objects saved
                                          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_05_09-13_59_52_NUC_backupiobroker.tar.gz
                                          [DEBUG] [iobroker] - done
                                          [DEBUG] [influxDB] - InfluxDB-Backup for iob is started ...
                                          [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                          [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                          [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_05_09-13_59_58_iob_backupiobroker.tar.gz
                                          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_05_09-13_59_58_iob_backupiobroker"
                                          [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_05_09-13_59_58_iob_backupiobroker" successfully deleted
                                          [DEBUG] [influxDB] - InfluxDB-Backup for iob is finish
                                          [DEBUG] [influxDB] - InfluxDB-Backup for iob30 is started ...
                                          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_05_09-14_00_00_iob30_backupiobroker"
                                          [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_05_09-14_00_00_iob30_backupiobroker" successfully deleted
                                          [ERROR] [influxDB] - [IGNORED] Error: Command failed: "/opt/iobroker/bin/influx" backup --bucket iobroker30d --host http://influxdb2:8086 -t 1lfrRuCdhZfFW7xIkgNvc0Zgm8hY8Z03gIHXQQ2OaRCAgYJlN6Aetd5htIA75uEtKuTFUt45VDszBNQdXtazPxA== "/opt/iobroker/backups/influxDB_2023_05_09-14_00_00_iob30_backupiobroker"
                                          2023/05/09 14:00:00 INFO: Downloading metadata snapshot
                                          [DEBUG] [grafana] - Start Grafana Backup ...
                                          [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                          [DEBUG] [grafana] - Created dashboard directory
                                          [DEBUG] [grafana] - Created dashboards_manually_restore directory
                                          [DEBUG] [grafana] - Created datasource directory
                                          [DEBUG] [grafana] - start Grafana request ...
                                          [DEBUG] [grafana] - Grafana is available ... Status: 200
                                          [DEBUG] [grafana] - found Dashboard: waschmaschine
                                          [DEBUG] [grafana] - found Dashboard: elektro
                                          [DEBUG] [grafana] - found Dashboard: gasverbrauch
                                          [DEBUG] [grafana] - found Dashboard: elbestand
                                          [DEBUG] [grafana] - found Dashboard: heizung
                                          [DEBUG] [grafana] - found Dashboard: temperaturen
                                          [DEBUG] [grafana] - start Grafana backup compress ...
                                          [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2023_05_09-14_00_01_NUC_backupiobroker.tar.gz
                                          [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                          [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                                          [DEBUG] [grafana] - done
                                          [DEBUG] [jarvis] - Created jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis0"
                                          [DEBUG] [jarvis] - found Jarvis Instance: 0
                                          [DEBUG] [jarvis] - start Jarvis Backup for Instance 0...
                                          [DEBUG] [jarvis] - /opt/iobroker/iobroker-data/jarvis/0 copy success!
                                          [DEBUG] [jarvis] - Created states_tmp directory: "/opt/iobroker/backups/tmpJavis0/states"
                                          [DEBUG] [jarvis] - settings "theme" not found
                                          [DEBUG] [jarvis] - Try deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis0"
                                          [DEBUG] [jarvis] - Jarvis tmp directory "/opt/iobroker/backups/tmpJavis0" successfully deleted
                                          [DEBUG] [jarvis] - Backup created: /opt/iobroker/backups/jarvis.0_2023_05_09-14_00_06_NUC_backupiobroker.tar.gz
                                          [DEBUG] [jarvis] - done
                                          [DEBUG] [nodered] - Created noderedtmp directory
                                          [DEBUG] [nodered] - Node-Red tmp copy finish
                                          [DEBUG] [nodered] - Backup created: /opt/iobroker/backups/nodered.0_2023_05_09-14_00_07_NUC_backupiobroker.tar.gz
                                          [DEBUG] [nodered] - Try deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
                                          [DEBUG] [nodered] - node-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
                                          [DEBUG] [nodered] - found node-red database: node-red.0
                                          [DEBUG] [nodered] - done
                                          [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                                          [DEBUG] [clean] - done
                                          [DEBUG] [pushover] - done
                                          [DEBUG] [historyHTML] - new history html values created
                                          [DEBUG] [historyHTML] - done
                                          [DEBUG] [historyJSON] - new history json values created
                                          [DEBUG] [historyJSON] - done
                                          [EXIT] 0
                                          Die Notification wird mit aktivierter "Ignore Errors" Option versendet.
                                          • simatec
                                            @marc-berg Hat die Notification auch den Fehler gemeldet?
                                            Marc Berg 2 Replies Last reply Reply Quote 0
                                            170
                                            2780
                                            2334543
