      Sushibomba @Thomas Braun last edited by Homoran
      @thomas-braun sagte in Test Adapter ioBroker.backitup v2.6.x:
      iob diag
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       15:28:36 up 16:31,  1 user,  load average: 4.51, 3.65, 2.70
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=55.5'C
      volt=0.8625V
      *** Time and Time Zones ***
                     Local time: Wed 2023-05-03 15:28:36 CEST
                 Universal time: Wed 2023-05-03 13:28:36 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        2.5G         82M        3.0M        1.2G        1.8G
      Swap:            99M        3.0M         96M
      Total:          3.9G        2.5G        179M
               3793 M total memory
               2465 M used memory
               2292 M active memory
               1046 M inactive memory
                 82 M free memory
                153 M buffer memory
               1090 M swap cache
                 99 M total swap
                  3 M used swap
                 96 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      117G   18G   95G  16% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
      tmpfs          tmpfs     759M  856K  758M   1% /run
      /dev/sda1      vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Tue May  2 22:57:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:26:5C:BB vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=6b1df87b-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue May  2 22:57:18 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Tue May  2 22:57:18 2023] EXT4-fs (sda2): write access will be enabled during recovery
      [Tue May  2 22:57:18 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Tue May  2 22:57:18 2023] EXT4-fs (sda2): 18 orphan inodes deleted
      [Tue May  2 22:57:18 2023] EXT4-fs (sda2): recovery complete
      [Tue May  2 22:57:18 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue May  2 22:57:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Tue May  2 22:57:20 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      7.3G    /var/
      5.2G    /var/log
      3.9G    /var/log/journal/e62fdccebd65415cae66edd105f72d4f
      1.3G    /var/cache/apt/archives
      Archived and active journals take up 3.8G in the file system.
      /opt/iobroker/backups:
      3.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      921M    /opt/iobroker/iobroker-data/
      593M    /opt/iobroker/iobroker-data/files
      163M    /opt/iobroker/iobroker-data/backup-objects
      109M    /opt/iobroker/iobroker-data/history
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      27M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
      19M     /opt/iobroker/iobroker-data/states.jsonl
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.20.0
      /usr/bin/node           v16.20.0
      /usr/bin/npm            8.19.4
      /usr/bin/npx            8.19.4
      nodejs:
        Installed: 16.20.0-deb-1nodesource1
        Candidate: 16.20.0-deb-1nodesource1
        Version table:
       *** 16.20.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   4
      Adapter State
      + system.adapter.admin.0                  : admin                 : Pi4ioBroker128GB                         -  enabled, port: 8081, bind: 192.168.178.58, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : Pi4ioBroker128GB                         -  enabled
      + system.adapter.backitup.0               : backitup              : Pi4ioBroker128GB                         -  enabled
      + system.adapter.cloud.0                  : cloud                 : Pi4ioBroker128GB                         -  enabled
        system.adapter.daswetter.0              : daswetter             : Pi4ioBroker128GB                         -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : Pi4ioBroker128GB                         -  enabled
        system.adapter.devices.0                : devices               : Pi4ioBroker128GB                         -  enabled
      + system.adapter.discovery.0              : discovery             : Pi4ioBroker128GB                         -  enabled
        system.adapter.dwd.0                    : dwd                   : Pi4ioBroker128GB                         -  enabled
      + system.adapter.echarts.0                : echarts               : Pi4ioBroker128GB                         -  enabled
      + system.adapter.esphome.0                : esphome               : Pi4ioBroker128GB                         -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : Pi4ioBroker128GB                         - disabled
        system.adapter.flot.0                   : flot                  : Pi4ioBroker128GB                         - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : Pi4ioBroker128GB                         -  enabled
      + system.adapter.history.0                : history               : Pi4ioBroker128GB                         -  enabled
        system.adapter.ical.0                   : ical                  : Pi4ioBroker128GB                         -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : Pi4ioBroker128GB                         -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : Pi4ioBroker128GB                         -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : Pi4ioBroker128GB                         -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : Pi4ioBroker128GB                         -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Pi4ioBroker128GB                         -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Pi4ioBroker128GB                         -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Pi4ioBroker128GB                         -  enabled
      + system.adapter.influxdb.0               : influxdb              : Pi4ioBroker128GB                         -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : Pi4ioBroker128GB                         -  enabled
      + system.adapter.iot.0                    : iot                   : Pi4ioBroker128GB                         -  enabled
      + system.adapter.javascript.0             : javascript            : Pi4ioBroker128GB                         -  enabled
      + system.adapter.klipper-moonraker.0      : klipper-moonraker     : Pi4ioBroker128GB                         -  enabled
        system.adapter.kodi.0                   : kodi                  : Pi4ioBroker128GB                         - disabled, port: 9090
      + system.adapter.logparser.0              : logparser             : Pi4ioBroker128GB                         -  enabled
        system.adapter.material.0               : material              : Pi4ioBroker128GB                         -  enabled
        system.adapter.meteoalarm.0             : meteoalarm            : Pi4ioBroker128GB                         -  enabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : Pi4ioBroker128GB                         - disabled, port: 54321
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Pi4ioBroker128GB                         -  enabled, port: 54321
      + system.adapter.musiccast.0              : musiccast             : Pi4ioBroker128GB                         -  enabled
      + system.adapter.net-tools.0              : net-tools             : Pi4ioBroker128GB                         -  enabled
      + system.adapter.octoprint.0              : octoprint             : Pi4ioBroker128GB                         -  enabled
        system.adapter.plex.0                   : plex                  : Pi4ioBroker128GB                         - disabled
      + system.adapter.scenes.0                 : scenes                : Pi4ioBroker128GB                         -  enabled
      + system.adapter.sonoff.0                 : sonoff                : Pi4ioBroker128GB                         -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.spotify-premium.0        : spotify-premium       : Pi4ioBroker128GB                         - disabled
        system.adapter.synology.0               : synology              : Pi4ioBroker128GB                         - disabled, port: 5000
        system.adapter.synology.1               : synology              : Pi4ioBroker128GB                         - disabled, port: 5000
        system.adapter.synology.2               : synology              : Pi4ioBroker128GB                         - disabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : Pi4ioBroker128GB                         -  enabled
      + system.adapter.telegram.0               : telegram              : Pi4ioBroker128GB                         -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : Pi4ioBroker128GB                         -  enabled
      + system.adapter.tr-064.0                 : tr-064                : Pi4ioBroker128GB                         -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : Pi4ioBroker128GB                         -  enabled
      + system.adapter.tuya.0                   : tuya                  : Pi4ioBroker128GB                         -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : Pi4ioBroker128GB                         - disabled
        system.adapter.upnp.0                   : upnp                  : Pi4ioBroker128GB                         - disabled
        system.adapter.uv-protect.0             : uv-protect            : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-history.0            : vis-history           : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : Pi4ioBroker128GB                         -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-metro.0              : vis-metro             : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : Pi4ioBroker128GB                         -  enabled
        system.adapter.vis.0                    : vis                   : Pi4ioBroker128GB                         -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : Pi4ioBroker128GB                         -  enabled
      + system.adapter.web.0                    : web                   : Pi4ioBroker128GB                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.wifilight.0              : wifilight             : Pi4ioBroker128GB                         - disabled
      + system.adapter.wled.0                   : wled                  : Pi4ioBroker128GB                         -  enabled
      + system.adapter.worx.0                   : worx                  : Pi4ioBroker128GB                         -  enabled
      + system.adapter.ws.0                     : ws                    : Pi4ioBroker128GB                         -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.yamaha.0                 : yamaha                : Pi4ioBroker128GB                         -  enabled
      + system.adapter.zigbee.0                 : zigbee                : Pi4ioBroker128GB                         -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_da9285a4d13aec1187a6a0957a0af07f-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "cloud"        : 4.3.0    , installed 4.3.0
      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "iot"          : 1.14.2   , installed 1.14.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "kodi"         : 2.0.9    , installed 2.0.9
      Adapter    "logparser"    : 2.1.1    , installed 2.1.1
      Adapter    "material"     : 1.1.2    , installed 1.1.2
      Adapter    "meteoalarm"   : 2.3.5    , installed 2.3.5
      Adapter    "mihome-vacuum": 3.9.5    , installed 3.8.8  [Updatable]
      Adapter    "musiccast"    : 0.1.5    , installed 0.1.5
      Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
      Adapter    "plex"         : 0.9.1    , installed 0.9.1
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
      Adapter    "synology"     : 2.1.13   , installed 2.1.13
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "text2command" : 2.3.0    , installed 2.3.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.13.1   , installed 3.13.1
      Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "uv-protect"   : 0.4.0    , installed 0.4.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      Adapter    "worx"         : 2.1.3    , installed 2.1.3
      Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects:        25536
      States:         21462
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 https://repos.influxdata.com/debian stable InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 https://apt.grafana.com stable InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Reading package lists...
      Pending Updates: 52
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1017889    8604/io.sonoff.0
      tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       1022712    10007/python3
      tcp        0      0 0.0.0.0:8090            0.0.0.0:*               LISTEN      0          13122      866/motion
      tcp        0      0 192.168.178.58:8081     0.0.0.0:*               LISTEN      1001       1015314    8313/io.admin.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1015204    8269/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1015211    8269/iobroker.js-co
      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        12252      734/mariadbd
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          12846      691/apache2
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13660      649/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          17749      515/python2
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13006      616/influxd
      tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          13123      866/motion
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1018318    8922/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       1022194    9304/io.ws.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        13129      616/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13662      649/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      109        13218      779/grafana
      udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       1023035    9639/io.musiccast.0
      udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       1019058    8708/io.mihome-vacu
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1018049    8660/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1018050    8660/io.tuya.0
      udp        0      0 0.0.0.0:48144           0.0.0.0:*                           108        12064      502/avahi-daemon: r
      udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       1022721    10007/python3
      udp        0      0 192.168.178.58:5353     0.0.0.0:*                           1001       1022720    10007/python3
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1022715    10007/python3
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1023297    9912/io.esphome.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1018192    8929/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12062      502/avahi-daemon: r
      udp6       0      0 :::33362                :::*                                108        12065      502/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12063      502/avahi-daemon: r
      2023-05-03 15:28:00.345  - info: tuya.0 (8660) 50007884f4cfa22862f6: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.30:6668
      2023-05-03 15:28:02.769  - info: tankerkoenig.0 (9220) Start first request
      2023-05-03 15:28:12.825  - info: cloud.0 (9718) Trying to connect as system.user.admin to cloud
      2023-05-03 15:28:13.007  - info: cloud.0 (9718) Connection changed: connect
      2023-05-03 15:28:19.240  - debug: fullybrowser.0 (9067) get Information
      2023-05-03 15:28:21.049  - info: tuya.0 (8660) bf50531eb4322194f0vjim: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.26:6668
      2023-05-03 15:28:25.528  - info: tuya.0 (8660) bf5ed8fa1f086a6e20gtpf: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.52:6668
      2023-05-03 15:28:30.136  - info: tuya.0 (8660) 14407720c82b965de6ed: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.66:6668
      2023-05-03 15:28:37.017  - info: tuya.0 (8660) bfacc1df4320069c01qhho: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.65:6668
      2023-05-03 15:28:39.833  - info: tuya.0 (8660) bf3694683243c18e2aqufe: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.82:6668
      2023-05-03 15:28:43.417  - info: tuya.0 (8660) 50007884f4cfa22862f6: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.30:6668
      2023-05-03 15:28:43.547  - info: tuya.0 (8660) bfd296f711b61a5bc3lk8n: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.67:6668
      2023-05-03 15:28:48.601  - info: tuya.0 (8660) bf8e55efebd6170d14cqqc: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.38:6668
      2023-05-03 15:29:01.241  - info: alexa2.0 (8649) No smart home devices to query
      2023-05-03 15:29:14.011  - info: alexa2.0 (8649) Subscribing to states...
      2023-05-03 15:29:42.905  - info: tuya.0 (8660) bf3694683243c18e2aqufe: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.82:6668
      2023-05-03 15:29:46.489  - info: tuya.0 (8660) 50007884f4cfa22862f6: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.30:6668
      2023-05-03 15:30:00.161  - info: host.Pi4ioBroker128GB instance system.adapter.meteoalarm.0 started with pid 11096
      2023-05-03 15:30:04.620  - info: host.Pi4ioBroker128GB instance system.adapter.dwd.0 started with pid 11187
      2023-05-03 15:30:07.966  - info: meteoalarm.0 (11096) starting. Version 2.3.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v16.20.0, js-controller: 4.0.24
      2023-05-03 15:30:08.988  - info: host.Pi4ioBroker128GB instance system.adapter.daswetter.0 started with pid 11203
      iob diag has finished.
        Thomas Braun Most Active @Sushibomba last edited by
        @sushibomba sagte in Test Adapter ioBroker.backitup v2.6.x:
        Dein Dateisystem hat 'nen Schuss.
          Das heißt? Was kann ich jetzt machen? Wollte mein System eh komplett neu auf nen frisches 64Bit System wieder aufbauen und halt die Backups wieder einspielen damit ich meine ganzen Daten nicht verliere.
            @sushibomba
            Dann mach das. Auf einem neuen Speichermedium.
              Sushibomba @Thomas Braun last edited by Sushibomba
              Ja aber ich habe hier ja einen Post geöffnet, weil er sich beim backitup Adapter immer aufhängt.
              Oder meinste das müsste jetzt wieder klappen mit der MySQL Datenbank durch den iob fix?
                Homoran Global Moderator Administrators @Sushibomba last edited by
                Ja aber ich habe hier ja einen Post geöffnet, weil er dich beim backitup Adapter immer aufhängt.
                wie meinen?
                Aber wenn die Daten defekt sind, dass sie nicht lesbar sind, kann einiges passieren.
                  @sushibomba
                  Mit MySQL macht der iobroker fix gar nix.
                    Sushibomba @Homoran last edited by Sushibomba
                    @Thomas-Braun
                    Ja damit ich meine Daten nicht verliere nutze ich den backitup Adapter. Das hat auch in der Vergangenheit immer gut geklappt mit den Sicherungen.
                    Nur seit neuestem halt das Problem mit der MySQL Sicherung.
                    Diese könnte ich aber doch auch über phpmyadmin separat sichern oder und dann nur den Rest von backitup einspielen lassen oder?
                    Und noch ne Frage nebenbei. Wenn ich auf dem neuen System iobroker wieder installiert habe und den backitup Adapter installiert habe um die Backups einzuspielen, kann ich dann z.B. mein Grafana Backup wiederherstellen ohne vorher Grafana wieder installiert zu haben über PuTTY? Also macht er das dann suchtomstisch beim Backup einspielen oder muss ich das immer vorher installieren bevor ich Backups wiederherstelle? Also genauso für influxdb etc.?
                      wieso sollte der Backitup Adapter externe Fremdprogramme installieren?
                        Nein, das sind nur die Nutzdaten. Das Rahmenwerk muss natürlich bereitgestellt werden. Ist immer so.
                          @Homoran
                          Also erst alle Pakete wieder installieren wie influxdb, grafana, mysql etc. und erst dann das backup wiederherstellen korrekt?
                            korrekt
                            und natürlich ioBroker!
                              @simatec
                              Die mysql backups die automatisch durchgelaufen sind, sind übrigens nur ca. 13mb groß.
                              mysql_2023_04_28-02_01_57_backupiobroker.tar.gz
                                Noch ne kurze Info. Heute Nacht ist das auto Backup wieder einwandfrei durchgelaufen. Ich verstehe das nicht. Nur manuell angestoßen friert er ein und stürzt ab.
                                • Marc Berg
                                  Marc Berg Most Active last edited by
                                  @simatec
                                  Ich sichere mit dem Adapter u.a. zwei InfluxDB Buckets.
                                  Nach ein paar Tests habe ich gestern einen falschen Token in die Backitup Konfig geschrieben. Dadurch hat sich ein Problem gezeigt, bei dem ich mir nicht sicher bin, ob das so gewünscht ist.
                                  2023-05-07 00:53:17.697  - error: backitup.0 (94526) [iobroker/influxDB] Error: Command failed: "/opt/iobroker/bin/influx" backup --bucket iobroker30d --host http://influxdb2:8086 -t k6RH6nLY7jwrOnKnVaJofW8MhQwTp1tGG2kX9IC48X61DH1IzKzyX2UwWSZeJYrUkStOyUP28qlZp0pBRIjR4Q== "/opt/iobroker/backups/influxDB_2023_05_07-00_53_17_iob30_backupiobroker"
                                  2023-05-07 00:53:17.703  - error: backitup.0 (94526) [iobroker/influxDB] 2023/05/07 00:53:17 INFO: Downloading metadata snapshot
                                  2023-05-07 00:53:17.703  - error: backitup.0 (94526) [iobroker/influxDB] Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: unauthorized access
                                  2023-05-07 00:53:17.703  - error: backitup.0 (94526) [iobroker] Error: Command failed: "/opt/iobroker/bin/influx" backup --bucket iobroker30d --host http://influxdb2:8086 -t k6RH6nLY7jwrOnKnVaJofW8MhQwTp1tGG2kX9IC48X61DH1IzKzyX2UwWSZeJYrUkStOyUP28qlZp0pBRIjR4Q== "/opt/iobroker/backups/influxDB_2023_05_07-00_53_17_iob30_backupiobroker"
                                  Das Backup wird nach dem fehlgeschlagenen Versuch, das Bucket "iobroker30d" zu sichern, abgebrochen. Weitere konfigurierte Sicherungen (grafana, jarvis, nodered) werden nicht durchgeführt UND (das finde ich problematisch) es wird keine Notification über den Fehler versendet. In meinem Fall wäre das Pushover, aber ich denke auch andere "notification types" haben das Problem.
                                  Wenn ich die Sicherung manuell anstosse, ergibt sich das gleiche Bild. Nach dem Fehler beim InfluxDB Backup bricht der Vorgang ab, das Fenster wird auch nach ein paar Minuten nicht geschlossen.
                                  • Adapter-Version: 2.6.20
                                  • Node.js v18.16.0
                                  • js-controller 4.0.24
                                  • simatec
                                    simatec Developer Most Active @Marc Berg last edited by
                                    @marc-berg Kannst du mal bitte versuchen den Fehler nachzustellen mit aktivierter Option zum ignorieren von Backupfehlern?
                                    So kann ich es besser eingrenzen.
                                    Marc Berg 1 Reply Last reply Reply Quote 1
                                    • Marc Berg
                                      Marc Berg Most Active @simatec last edited by Marc Berg
                                      @simatec
                                      Started iobroker ...
                                      [DEBUG] [iobroker] - host.iobroker 13133 states saved
                                      [DEBUG] [iobroker] - host.iobroker 13839 objects saved
                                      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_05_09-13_59_52_NUC_backupiobroker.tar.gz
                                      [DEBUG] [iobroker] - done
                                      [DEBUG] [influxDB] - InfluxDB-Backup for iob is started ...
                                      [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                      [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                      [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_05_09-13_59_58_iob_backupiobroker.tar.gz
                                      [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_05_09-13_59_58_iob_backupiobroker"
                                      [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_05_09-13_59_58_iob_backupiobroker" successfully deleted
                                      [DEBUG] [influxDB] - InfluxDB-Backup for iob is finish
                                      [DEBUG] [influxDB] - InfluxDB-Backup for iob30 is started ...
                                      [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_05_09-14_00_00_iob30_backupiobroker"
                                      [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_05_09-14_00_00_iob30_backupiobroker" successfully deleted
                                      [ERROR] [influxDB] - [IGNORED] Error: Command failed: "/opt/iobroker/bin/influx" backup --bucket iobroker30d --host http://influxdb2:8086 -t 1lfrRuCdhZfFW7xIkgNvc0Zgm8hY8Z03gIHXQQ2OaRCAgYJlN6Aetd5htIA75uEtKuTFUt45VDszBNQdXtazPxA== "/opt/iobroker/backups/influxDB_2023_05_09-14_00_00_iob30_backupiobroker"
                                      2023/05/09 14:00:00 INFO: Downloading metadata snapshot
                                      [DEBUG] [grafana] - Start Grafana Backup ...
                                      [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                      [DEBUG] [grafana] - Created dashboard directory
                                      [DEBUG] [grafana] - Created dashboards_manually_restore directory
                                      [DEBUG] [grafana] - Created datasource directory
                                      [DEBUG] [grafana] - start Grafana request ...
                                      [DEBUG] [grafana] - Grafana is available ... Status: 200
                                      [DEBUG] [grafana] - found Dashboard: waschmaschine
                                      [DEBUG] [grafana] - found Dashboard: elektro
                                      [DEBUG] [grafana] - found Dashboard: gasverbrauch
                                      [DEBUG] [grafana] - found Dashboard: elbestand
                                      [DEBUG] [grafana] - found Dashboard: heizung
                                      [DEBUG] [grafana] - found Dashboard: temperaturen
                                      [DEBUG] [grafana] - start Grafana backup compress ...
                                      [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2023_05_09-14_00_01_NUC_backupiobroker.tar.gz
                                      [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                      [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                                      [DEBUG] [grafana] - done
                                      [DEBUG] [jarvis] - Created jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis0"
                                      [DEBUG] [jarvis] - found Jarvis Instance: 0
                                      [DEBUG] [jarvis] - start Jarvis Backup for Instance 0...
                                      [DEBUG] [jarvis] - /opt/iobroker/iobroker-data/jarvis/0 copy success!
                                      [DEBUG] [jarvis] - Created states_tmp directory: "/opt/iobroker/backups/tmpJavis0/states"
                                      [DEBUG] [jarvis] - settings "theme" not found
                                      [DEBUG] [jarvis] - Try deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis0"
                                      [DEBUG] [jarvis] - Jarvis tmp directory "/opt/iobroker/backups/tmpJavis0" successfully deleted
                                      [DEBUG] [jarvis] - Backup created: /opt/iobroker/backups/jarvis.0_2023_05_09-14_00_06_NUC_backupiobroker.tar.gz
                                      [DEBUG] [jarvis] - done
                                      [DEBUG] [nodered] - Created noderedtmp directory
                                      [DEBUG] [nodered] - Node-Red tmp copy finish
                                      [DEBUG] [nodered] - Backup created: /opt/iobroker/backups/nodered.0_2023_05_09-14_00_07_NUC_backupiobroker.tar.gz
                                      [DEBUG] [nodered] - Try deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
                                      [DEBUG] [nodered] - node-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
                                      [DEBUG] [nodered] - found node-red database: node-red.0
                                      [DEBUG] [nodered] - done
                                      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                                      [DEBUG] [clean] - done
                                      [DEBUG] [pushover] - done
                                      [DEBUG] [historyHTML] - new history html values created
                                      [DEBUG] [historyHTML] - done
                                      [DEBUG] [historyJSON] - new history json values created
                                      [DEBUG] [historyJSON] - done
                                      [EXIT] 0
                                      Die Notification wird mit aktivierter "Ignore Errors" Option versendet.
                                      • simatec
                                        @marc-berg Hat die Notification auch den Fehler gemeldet?
                                        Marc Berg 2 Replies Last reply Reply Quote 0
                                        • Marc Berg
                                          @simatec ja, so sieht das aus:
                                          • Marc Berg
                                            @simatec
                                            Scheinbar habe ich noch einen Fehler im Adapter gefunden. Ich habe zwei InfluxDB2-Buckets, die ich sichere (iobroker und iobroker30d):
                                            Die Sicherung selbst funktioniert auch wie sie soll, allerdings lässt sich das zweite Bucket (iobroker30d) nicht wiederherstellen. Der Dialog meldet beim Versuch der Wiederherstellung keine Fehler, die Daten werden aber nicht geschrieben. Ich habe das Loglevel auf "silly" gestellt, mehr als diese Meldungen lassen sich aber nicht mitschneiden:
                                            2023-05-19 09:46:51.704 - silly: backitup.0 (5449) States system redis pmessage io.messagebox.system.adapter.backitup.0/io.messagebox.system.adapter.backitup.0:{"command":"getFileSystemInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":117,"ack":false,"time":1684482411698},"_id":73047936}
                                            2023-05-19 09:46:51.709 - silly: backitup.0 (5449) States system redis pmessage io.messagebox.system.adapter.backitup.0/io.messagebox.system.adapter.backitup.0:{"command":"getSystemInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":118,"ack":false,"time":1684482411699},"_id":73047937}
                                            2023-05-19 09:46:51.709 - silly: backitup.0 (5449) sendTo "getSystemInfo" to system.adapter.admin.0 from system.adapter.backitup.0
                                            2023-05-19 09:46:51.728 - debug: backitup.0 (5449) The local storage check was completed successfully. On the host "iobroker" are currently 1578 MB free space available!
                                            2023-05-19 09:46:51.729 - silly: backitup.0 (5449) sendTo "getFileSystemInfo" to system.adapter.admin.0 from system.adapter.backitup.0
                                            2023-05-19 09:46:54.627 - silly: backitup.0 (5449) States system redis pmessage io.messagebox.system.adapter.backitup.0/io.messagebox.system.adapter.backitup.0:{"command":"list","message":"local","from":"system.adapter.admin.0","callback":{"message":"local","id":119,"ack":false,"time":1684482414626},"_id":73047938}
                                            2023-05-19 09:46:54.628 - debug: backitup.0 (5449) Backup list be read ...
                                            2023-05-19 09:46:56.629 - silly: backitup.0 (5449) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
                                            2023-05-19 09:47:00.809 - silly: backitup.0 (5449) States system redis pmessage io.messagebox.system.adapter.backitup.0/io.messagebox.system.adapter.backitup.0:{"command":"restore","message":{"type":"local","fileName":"/opt/iobroker/backups/influxDB_2023_05_18-00_53_18_iob30_backupiobroker.tar.gz","currentTheme":"react-dark","stopIOB":false},"from":"system.adapter.admin.0","callback":{"message":{"type":"local","fileName":"/opt/iobroker/backups/influxDB_2023_05_18-00_53_18_iob30_backupiobroker.tar.gz","currentTheme":"react-dark","stopIOB":false},"id":120,"ack":false,"time":1684482420807},"_id":73047939}
                                            2023-05-19 09:47:00.812 - debug: backitup.0 (5449) set chmod for "/opt/iobroker/backups" successfully
                                            2023-05-19 09:47:00.813 - debug: backitup.0 (5449) [influxDB] Created tmp directory
                                            2023-05-19 09:47:00.813 - debug: backitup.0 (5449) [influxDB] Start infuxDB Restore ...
                                            2023-05-19 09:47:00.993 - debug: backitup.0 (5449) [influxDB] influxdb.0 is stopped
                                            2023-05-19 09:47:01.030 - debug: backitup.0 (5449) [influxDB] influxdb.1 is stopped
                                            2023-05-19 09:47:01.362 - debug: backitup.0 (5449) [influxDB] Try deleting the InfluxDB tmp directory
                                            2023-05-19 09:47:01.374 - debug: backitup.0 (5449) [influxDB] InfluxDB tmp directory was successfully deleted
                                            2023-05-19 09:47:01.375 - debug: backitup.0 (5449) [influxDB] infuxDB Restore completed successfully
                                            2023-05-19 09:47:01.375 - silly: backitup.0 (5449) sendTo "restore" to system.adapter.admin.0 from system.adapter.backitup.0
                                            2023-05-19 09:47:01.384 - debug: backitup.0 (5449) [influxDB] influxdb.0 started
                                            2023-05-19 09:47:01.386 - debug: backitup.0 (5449) [influxDB] influxdb.1 started
                                            Das Bucket existiert noch nicht auf der DB. Die Wiederherstellung funktioniert manuell auf der Kommandozeile via
                                            influx restore --bucket iobroker30d --host http://influxdb2:8086 -t lfrRuCdhZfFW7xIkgNvc0Zgm8hY8Z03gIHXQQ2OaRCAgYJlN6Aetd5htIA75uEtKuTFUt45VDszBNQdXtazPxA== "/opt/iobroker/backups/influxDB_2023_05_18-00_53_18_iob30_backupiobroker"
                                            Was könnte ich noch einstellen, um das Log etwas gesprächiger zu bekommen?
                                            • Backitup 2.6.20
                                            • node.js v18.16.0
                                            170
                                            2780
                                            2334533
