    4. Test Adapter wireless-mbus v0.10.x
      Felidsche @smartboart last edited by Felidsche
      @smartboart hallo,
      habe jetzt mal die von dir verlinkte fw ausprobiert. flashen lässt sie sich, aber mit den von dir gezeigten verbindungseinstellung bekomme ich folgende meldungen:
      wireless-mbus.0
      2023-04-24 16:09:11.231	info	List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"},{"path":"/dev/ttyS0"}]
      wireless-mbus.0
      2023-04-24 16:05:21.397	debug	connected set to false
      wireless-mbus.0
      2023-04-24 16:05:21.351	error	Serialport error: Port is not open
      wireless-mbus.0
      2023-04-24 16:05:21.351	error	Serialport error: Error: Permission denied, cannot open /dev/ttyUSB0
      wireless-mbus.0
      2023-04-24 16:05:21.350	debug	CUL: TX: 560d0a
      wireless-mbus.0
      2023-04-24 16:05:21.348	debug	Created device of type: CUL
      wireless-mbus.0
      2023-04-24 16:05:21.321	info	starting. Version 0.8.10 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v16.19.1, js-controller: 4.0.24
      wireless-mbus.0
      2023-04-24 16:05:17.401	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      wireless-mbus.0
      2023-04-24 16:05:17.400	info	terminating
      wireless-mbus.0
      2023-04-24 16:05:17.400	info	Got terminate signal TERMINATE_YOURSELF
      wireless-mbus.0
      2023-04-24 16:05:13.259	info	List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"},{"path":"/dev/ttyS0"}]
      wireless-mbus.0
      2023-04-24 15:57:00.384	debug	connected set to false
      weist ja irgendwie auf ein rechteproblem hin, kann mir da jemand helfen? hat der iobroker user keine rechte auf den Usb stick zuzugreifen? wie ändere ich das?
      smartboart F 2 Replies Last reply Reply Quote 0
      • smartboart
        smartboart @Felidsche last edited by smartboart
        @felidsche also das es nicht erkannt wird liegt dann definitiv an deiner speziellen iobroker Umgebung...bei meinem rpi 4 wird der Stick mit den Einstellungen einwandfrei erkannt.. Leider kann ich dir mit der Installationsumgebung nicht helfen..
        • pille0557
          pille0557 @smartboart last edited by pille0557
          @smartboart
          ich habe den nanoCul verbaut, ...
          AES-Schlüssel habe ich auch ...
          er empfängt auch etwas ...
          Bildschirmfoto 2023-05-02 um 18.55.06.png Bildschirmfoto 2023-05-02 um 18.55.43.png
          die Anzeige des InfluxDb Inhaltes endet in grafana allerdings mit No Data
          F L smartboart 3 Replies Last reply Reply Quote 0
            fadk2wf @pille0557 last edited by
            @pille0557 ...stell mal den wmbus mode auf T Mode.
            Wenn der nanoCUl die Daten erkennt, dann generiert der wmbus automatisch die Objekte
              lvogt @pille0557 last edited by
              @pille0557
              Was erwartest du dir von den Rohdaten Telegrammen in Grafana?
              Der State sollte - in der Beschreibung steht - ja sowieso nur Daten bekommen wenn das Dekodieren des Telegramms fehlgeschlagen ist. Poste also mal bitte ein Debug Log.
              Die Telegramme die man im Screenshot sieht gehören vermutlich zu dem Gerät dem du auch den AES Schlüssel zugeordnet hast. Mein Tipp: Das ist nicht Zähler und daher passt dein Schlüssel auch nicht
              pille0557 1 Reply Last reply Reply Quote 0
              • pille0557
                pille0557 @lvogt last edited by pille0557
                @lvogt
                Debug-Log?
                wireless-mbus.0
                2023-05-03 19:50:16.833 info CUL: Receiver set to T-MODE and data reporting with RSSI
                wireless-mbus.0
                2023-05-03 19:50:16.809 info CUL: Error getting CUL version: Timeout waiting for response
                wireless-mbus.0
                2023-05-03 19:50:13.727 info starting. Version 0.8.10 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v16.19.1, js-controller: 4.0.24
                host.raspi-iobroker
                2023-05-03 19:50:11.802 info instance system.adapter.wireless-mbus.0 started with pid 30071
                host.raspi-iobroker
                2023-05-03 19:50:09.278 info instance system.adapter.wireless-mbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                admin.0
                2023-05-03 19:50:08.905 info <== Disconnect system.user.admin from ::ffff:192.168.0.78
                host.raspi-iobroker
                2023-05-03 19:50:08.700 info stopInstance system.adapter.wireless-mbus.0 send kill signal
                wireless-mbus.0
                2023-05-03 19:50:08.659 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                wireless-mbus.0
                2023-05-03 19:50:08.658 info terminating
                wireless-mbus.0
                2023-05-03 19:50:08.655 info Got terminate signal TERMINATE_YOURSELF
                host.raspi-iobroker
                2023-05-03 19:50:08.651 info stopInstance system.adapter.wireless-mbus.0 (force=false, process=true)
                wireless-mbus.0
                2023-05-03 19:50:05.458 info CUL: Receiver set to T-MODE and data reporting with RSSI
                wireless-mbus.0
                2023-05-03 19:50:05.438 info CUL: Error getting CUL version: Timeout waiting for response
                wireless-mbus.0
                2023-05-03 19:50:05.288 info List of port: [{"path":"/dev/ttyUSB1","manufacturer":"FTDI","serialNumber":"A50285BI","pnpId":"usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0","vendorId":"0403","productId":"6001"},{"path":"/dev/ttyUSB0","manufacturer":"Prolific Technology Inc. ","serialNumber":"BMBLt114J20","pnpId":"usb-Prolific_Technology_Inc._USB-Serial_Controller_BMBLt114J20-if00-port0","vendorId":"067b","productId":"23a3"},{"path":"/dev/ttyAMA0"}]
                wireless-mbus.0
                2023-05-03 19:50:02.354 info starting. Version 0.8.10 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v16.19.1, js-controller: 4.0.24
                admin.0
                2023-05-03 19:50:01.787 info ==> Connected system.user.admin from ::ffff:192.168.0.78
                host.raspi-iobroker
                2023-05-03 19:50:00.381 info instance system.adapter.wireless-mbus.0 started with pid 30053
                host.raspi-iobroker
                2023-05-03 19:49:57.785 info instance system.adapter.wireless-mbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                admin.0
                2023-05-03 19:49:57.471 info <== Disconnect system.user.admin from ::ffff:192.168.0.78
                host.raspi-iobroker
                2023-05-03 19:49:57.282 info stopInstance system.adapter.wireless-mbus.0 send kill signal
                wireless-mbus.0
                2023-05-03 19:49:57.228 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                doch ich denke schon, jedenfalls korrespondiert es mit dem Aufdruck ... ?
                  @pille0557 Dann wäre das Debug Log wohl um so wichtiger...
                  • pille0557
                    @lvogt wo finde ich das?
                    smartboart 1 Reply Last reply Reply Quote 0
                    • smartboart
                      smartboart @pille0557 last edited by smartboart
                      @pille0557 sagte in Test Adapter wireless-mbus v0.8.x:
                      Hi, kannst du mal einen link schicken was genau du gekauft hast? Ich bekomme es mit 2 unterschiedlichen nano cul nicht hin. Bzw. es werden keine Daten empfangen.
                      • pille0557
                        @smartboart
                        nicht der Preishit, aber ging wenigstens schnell ...
                        nanoCul bei Amazon
                        hoffe ja, dass die 868MHz Variante die richtige ist🙄
                        • smartboart
                          @pille0557 Also meine IPERL sendet angeblich mit 433MhZ laut Versorger, habe aber beide Varianten ausprobiert.
                          • smartboart
                            @pille0557 im Admin bei dem wmbus Adapter den log level auf Debug stellen
                            pille0557 2 Replies Last reply Reply Quote 0
                            • pille0557
                              @smartboart Danke!
                              ja ist auch iPerl
                              • pille0557
                                @smartboart so sieht das jetzt aus:
                                2023-05-06 09:05:50.956 debug connected set to true
                                wireless-mbus.0
                                2023-05-06 09:05:50.894 info CUL: Receiver set to T-MODE and data reporting with RSSI
                                wireless-mbus.0
                                2023-05-06 09:05:50.891 debug CUL: RX: 544d4f44450d0a
                                wireless-mbus.0
                                2023-05-06 09:05:50.875 debug CUL: TX: 5832310d0a6272740d0a
                                wireless-mbus.0
                                2023-05-06 09:05:50.873 info CUL: Error getting CUL version: Timeout waiting for response
                                wireless-mbus.0
                                2023-05-06 09:05:47.923 debug connected set to false
                                wireless-mbus.0
                                2023-05-06 09:05:47.864 debug CUL: TX: 560d0a
                                wireless-mbus.0
                                2023-05-06 09:05:47.858 debug Created device of type: CUL
                                wireless-mbus.0
                                2023-05-06 09:05:47.785 info starting. Version 0.8.10 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v16.19.1, js-controller: 4.0.24
                                wireless-mbus.0
                                2023-05-06 09:05:47.531 debug States connected to redis: 127.0.0.1:9000
                                wireless-mbus.0
                                2023-05-06 09:05:47.461 debug States create User PubSub Client
                                wireless-mbus.0
                                2023-05-06 09:05:47.459 debug States create System PubSub Client
                                wireless-mbus.0
                                2023-05-06 09:05:47.396 debug Redis States: Use Redis connection: 127.0.0.1:9000
                                wireless-mbus.0
                                2023-05-06 09:05:47.363 debug Objects connected to redis: 127.0.0.1:9001
                                wireless-mbus.0
                                2023-05-06 09:05:47.356 debug Objects client initialize lua scripts
                                wireless-mbus.0
                                2023-05-06 09:05:47.301 debug Objects create User PubSub Client
                                wireless-mbus.0
                                2023-05-06 09:05:47.299 debug Objects create System PubSub Client
                                wireless-mbus.0
                                2023-05-06 09:05:47.297 debug Objects client ready ... initialize now
                                wireless-mbus.0
                                2023-05-06 09:05:47.239 debug Redis Objects: Use Redis connection: 127.0.0.1:9001
                                host.raspi-iobroker
                                2023-05-06 09:05:45.751 info instance system.adapter.wireless-mbus.0 started with pid 7019
                                host.raspi-iobroker
                                2023-05-06 09:05:43.181 info instance system.adapter.wireless-mbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.raspi-iobroker
                                2023-05-06 09:05:42.660 info stopInstance system.adapter.wireless-mbus.0 send kill signal
                                wireless-mbus.0
                                2023-05-06 09:05:42.625 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                wireless-mbus.0
                                2023-05-06 09:05:42.623 info terminating
                                wireless-mbus.0
                                2023-05-06 09:05:42.617 info Got terminate signal TERMINATE_YOURSELF
                                sehe gerade, dass der iobroker 1h hinterher hängt, der raspi hat aber die Sommerzeit! ... ?
                                  Felidsche @Felidsche last edited by
                                  @smartboart danke für Deine Hilfe.
                                  habe jetzt einen Stick mit der richtigen Firmware bestellt: https://www.amazon.de/dp/B0BG3JD6FV/ref=pe_27091401_487027711_TE_SCE_3p_dp_1
                                  gemäß meiner infos oben habe ich den in meiner Proxmox umgebung erfolgreich durchgereicht. in iobroker auch entsprechend erreichbar mit folgenden Einstellungen:
                                  und: Es funktioniert 🙂
                                  der adapter verbindet erfolgreich zum Stick und hört.
                                  nach einiger Zeit kommt der erste ping von meinem Sensus Iperl und der objektbaum zeigt im Feld info... raw date einen Eintrag.
                                  auch kommt die Id des wasserzählers im Tab AES schlüssel... habe hier noch den korrekten AES schlüssel eingegeben und nach einiger Zeit warten interpretiert der Adapter den Wert richtig und dann wird der Wasserzähler auch mit den korrekten entschlüsselten Daten im Objektbaum angezeigt.
                                  Als wem's hilft und wer einen Sensus Iperl auslesen möchte, mit den einstellungen im Screenshot funktioniert es 🙂
                                  einzige Frage die ich habe: kann man das Sendeintervall des Wasserzählers irgendwie beeinflussen? es scheint, dass der nur jede Stunde sendet...
                                  pille0557 F 2 Replies Last reply Reply Quote 0
                                  • pille0557
                                    pille0557 @Felidsche last edited by pille0557
                                    @felidsche said in Test Adapter wireless-mbus v0.8.x:
                                    tja, bei mir alles genauso, id des Wasserzählers stimmt auch, raw date auch da, aber dann nix im Objektbaum ... ?
                                    evtl. muss ich den AES-Schlüssel nochmal kontrollieren lassen
                                    was hast du hier gewählt:
                                    L F 2 Replies Last reply Reply Quote 0
                                      @pille0557
                                      Ich hätte wohl konkreter sein müssen: Es geht um ein Debug Log was auch ein ankommendes Telegramm enthält. Dann sollte dort nämlich auch was dazu stehen was beim Parsen schief gelaufen ist.
                                      Was du gepostet hast zeigt ja nur den Adapter Start.
                                      • smartboart
                                        @felidsche sagte in Test Adapter wireless-mbus v0.8.x:
                                        Hallo, heißt das, das der Stick so wie er geliefert wurde funktioniert? Ohne angepasste firmware? Also funktioniert dein iperl im 868Mhz Bereich?
                                        • smartboart
                                          @pille0557 in dem log sieht man nur das der Stick aufgenommen. Wurde.. vom iperl ist nichts zu sehen. Sieht aus wie bei mir..
                                            Felidsche @pille0557 last edited by
                                            @pille0557 hi pille, da habe ich
                                            @pille0557 said in Test Adapter wireless-mbus v0.8.x:
                                            hi pille da habe ich nichts gewählt bzw. nichts geändert. Wenn der AES Key korrekt ist, sollte er es auch interpretieren. und es wird soweit ich verstanden habe erst ein objekt im Objektbaum angelegt, wenn einmal richtig interpretiert wurde.
                                            mbus wireless wm-bus wmbus
                                            64
                                            564
                                            166262
