    3. Einsteigerfragen
    4. MQTT Server sendet nur einmal
    • Y
      YARD2 last edited by
      Ich habe ein kleines Problem mit dem MQTT Server.
      Er sendet den geänderten Zustand nicht an die Clients.
      Beim Verbinden sendet er 1x (MQTTX) oder 3x (mqttExplorer, aber einen alten Wert, dann nie wieder.
      Egal ob ich nur das Topic oder alles (#) subscribe.
      Habe den IObroker auch neu installiert (Windows Version 6.3.5 mit Installer 2.2.1).
      Ne Idee woran das liegen könnte ?
      mqttExplorer
      _______________________
      2023-05-06 19:02:30.086 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] connected with secret 1683392550080_6810
      2023-05-06 19:02:30.088 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] with keepalive 60 set timeout to 90 seconds
      2023-05-06 19:02:30.098 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] received subscribe package {"cmd":"subscribe","retain":false,"qos":1,"dup":false,"length":6,"topic":null,"payload":null,"subscriptions":[{"topic":"#","qos":0}],"messageId":24694}
      2023-05-06 19:02:30.099 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] Handle subscribe: {"topic":"#","qos":0}
      2023-05-06 19:02:30.101 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] subscribes on "#" with regex /.*/
      2023-05-06 19:02:30.102 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] subscribes on "#" with regex /^mqtt\.0(\..*)?/
      2023-05-06 19:02:30.105 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] received subscribe package {"cmd":"subscribe","retain":false,"qos":1,"dup":false,"length":11,"topic":null,"payload":null,"subscriptions":[{"topic":"$SYS/#","qos":0}],"messageId":24695}
      2023-05-06 19:02:30.106 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] Handle subscribe: {"topic":"$SYS/#","qos":0}
      2023-05-06 19:02:30.107 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] subscribes on "$SYS/#" with regex /^\$SYS(\..*)?/
      2023-05-06 19:02:30.108 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] subscribes on "$SYS/#" with regex /^mqtt\.0\.\$SYS(\..*)?/
      2023-05-06 19:02:30.128 - debug: mqtt.0 (5032) stateChange mqtt.0.info.connection: {"val":"mqtt.mqtt.0,mqtt-explorer-9f9587cc","ack":true,"ts":1683392550120,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1683392550120}
      2023-05-06 19:02:30.313 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] publishOnSubscribe send all known states
      2023-05-06 19:02:30.315 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "info/connection": mqtt.mqtt.0
      2023-05-06 19:02:30.317 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "smartmeter/0/1-0:16_7_0__255/value": 396
      2023-05-06 19:02:30.319 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] publishOnSubscribe send all known states
      2023-05-06 19:02:30.321 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "info/connection": mqtt.mqtt.0
      2023-05-06 19:02:30.322 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "smartmeter/0/1-0:16_7_0__255/value": 396
      2023-05-06 19:02:31.073 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":405,"ack":true,"ts":1683392551060,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392551060}
      2023-05-06 19:02:32.098 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "info/connection": mqtt.mqtt.0
      2023-05-06 19:02:32.113 - debug: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] send to this client "smartmeter/0/1-0:16_7_0__255/value": 396
      2023-05-06 19:02:34.031 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":406,"ack":true,"ts":1683392554018,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392554018}
      2023-05-06 19:02:37.022 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":394,"ack":true,"ts":1683392557010,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392557010}
      2023-05-06 19:02:38.393 - info: mqtt.0 (5032) Client [mqtt-explorer-9f9587cc] connection closed: disconnected
      2023-05-06 19:02:38.411 - debug: mqtt.0 (5032) stateChange mqtt.0.info.connection: {"val":"mqtt.mqtt.0","ack":true,"ts":1683392558403,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1683392558403}
      2023-05-06 19:02:40.017 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":397,"ack":true,"ts":1683392560004,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392560004}
      2023-05-06 19:02:43.016 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":380,"ack":true,"ts":1683392563004,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392563004}
      2023-05-06 19:02:46.017 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":375,"ack":true,"ts":1683392566005,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392566005}
      2023-05-06 19:02:49.013 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":386,"ack":true,"ts":1683392569001,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683392569001}
      MQTTX
      ________________________________
      2023-05-06 19:16:57.999 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3216,"ack":true,"ts":1683393417995,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393417995}
      2023-05-06 19:17:01.000 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3223,"ack":true,"ts":1683393420995,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393420995}
      2023-05-06 19:17:03.995 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3230,"ack":true,"ts":1683393423991,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393423991}
      2023-05-06 19:17:06.984 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":1463,"ack":true,"ts":1683393426980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393426980}
      2023-05-06 19:17:09.985 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2373,"ack":true,"ts":1683393429980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393429980}
      2023-05-06 19:17:12.392 - info: mqtt.0 (5032) Client [mqttx_e52458bc] connected with secret 1683393432390_1044
      2023-05-06 19:17:12.395 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] with keepalive 60 set timeout to 90 seconds
      2023-05-06 19:17:12.409 - debug: mqtt.0 (5032) stateChange mqtt.0.info.connection: {"val":"mqtt.mqtt.0,mqttx_e52458bc","ack":true,"ts":1683393432403,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1683393432403}
      2023-05-06 19:17:12.435 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] received subscribe package {"cmd":"subscribe","retain":false,"qos":1,"dup":false,"length":6,"topic":null,"payload":null,"subscriptions":[{"topic":"#","qos":0}],"messageId":19888}
      2023-05-06 19:17:12.437 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] Handle subscribe: {"topic":"#","qos":0}
      2023-05-06 19:17:12.438 - info: mqtt.0 (5032) Client [mqttx_e52458bc] subscribes on "#" with regex /.*/
      2023-05-06 19:17:12.439 - info: mqtt.0 (5032) Client [mqttx_e52458bc] subscribes on "#" with regex /^mqtt\.0(\..*)?/
      2023-05-06 19:17:12.640 - info: mqtt.0 (5032) Client [mqttx_e52458bc] publishOnSubscribe send all known states
      2023-05-06 19:17:12.642 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] send to this client "info/connection": mqtt.mqtt.0
      2023-05-06 19:17:12.643 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] send to this client "smartmeter/0/1-0:16_7_0__255/value": 396
      2023-05-06 19:17:13.015 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2562,"ack":true,"ts":1683393433010,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393433010}
      2023-05-06 19:17:14.395 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] send to this client "info/connection": mqtt.mqtt.0
      2023-05-06 19:17:14.406 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] send to this client "smartmeter/0/1-0:16_7_0__255/value": 396
      2023-05-06 19:17:16.002 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2578,"ack":true,"ts":1683393435997,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393435997}
      2023-05-06 19:17:19.000 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2577,"ack":true,"ts":1683393438995,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393438995}
      2023-05-06 19:17:21.999 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2583,"ack":true,"ts":1683393441994,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393441994}
      2023-05-06 19:17:24.985 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2576,"ack":true,"ts":1683393444980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393444980}
      2023-05-06 19:17:27.985 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2553,"ack":true,"ts":1683393447980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393447980}
      2023-05-06 19:17:31.045 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2542,"ack":true,"ts":1683393451040,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393451040}
      2023-05-06 19:17:34.012 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2554,"ack":true,"ts":1683393454006,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393454006}
      2023-05-06 19:17:36.993 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2557,"ack":true,"ts":1683393456988,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393456988}
      2023-05-06 19:17:39.987 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2554,"ack":true,"ts":1683393459982,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393459982}
      2023-05-06 19:17:42.992 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":2562,"ack":true,"ts":1683393462986,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393462986}
      2023-05-06 19:17:45.985 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":1463,"ack":true,"ts":1683393465980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393465980}
      2023-05-06 19:17:48.999 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3193,"ack":true,"ts":1683393468994,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393468994}
      2023-05-06 19:17:52.012 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3197,"ack":true,"ts":1683393472007,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393472007}
      2023-05-06 19:17:54.988 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3206,"ack":true,"ts":1683393474980,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393474980}
      2023-05-06 19:17:57.986 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3205,"ack":true,"ts":1683393477981,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393477981}
      2023-05-06 19:18:00.206 - debug: mqtt.0 (5032) Client [mqtt.mqtt.0] pingreq
      2023-05-06 19:18:01.005 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3199,"ack":true,"ts":1683393481000,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393481000}
      2023-05-06 19:18:04.050 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3202,"ack":true,"ts":1683393484044,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393484044}
      2023-05-06 19:18:06.983 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3178,"ack":true,"ts":1683393486978,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393486978}
      2023-05-06 19:18:09.986 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":3183,"ack":true,"ts":1683393489981,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393489981}
      2023-05-06 19:18:12.984 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":1483,"ack":true,"ts":1683393492979,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393492979}
      2023-05-06 19:18:13.436 - debug: mqtt.0 (5032) Client [mqttx_e52458bc] pingreq
      2023-05-06 19:18:15.988 - debug: mqtt.0 (5032) stateChange smartmeter.0.1-0:16_7_0__255.value: {"val":1510,"ack":true,"ts":1683393495983,"q":0,"from":"system.adapter.smartmeter.0","user":"system.user.admin","lc":1683393495983}
      • Marc Berg
        Marc Berg Most Active @YARD2 last edited by
        @yard2 zeig mal die Einstellungen der Instanz "mqtt.0"
        • Y
          Hab schon einige settings probiert.
          • Marc Berg
            @yard2 Da deine Datenpunkte mit "ack" geändert werden.
            müsste das hier aktiviert werden:
            Y 1 Reply Last reply Reply Quote 0
            • Y
              YARD2 @Marc Berg last edited by YARD2
              @marc-berg
              Oh Mann. Danke das wars.
              Die Option hatte ich nicht ausprobiert 😉
              Nur warum steht da ack drin. Macht evtl der Smartmeter.
              • Marc Berg
                @yard2 sagte in MQTT Server sendet nur einmal:
                Gibt's dazu nicht einen Adapter oder wer schreibt dort Werte?
                • Y
                  @marc-berg
                  Ich nutze den SmartMeter Adapter
