    4. Yahka Adapter in iobroker im Docker Container
      Tomme @Glasfaser last edited by
      @glasfaser wenn ich in portainer ein terminal öffne ist das root bei mir
      • Glasfaser
        Glasfaser @Tomme last edited by
        @tomme sagte in Yahka Adapter in iobroker im Docker Container:
        Alles gut !
          root@iobroker:/opt/iobroker# pkill -u iobroker
          iob fix
          iob start
          iob diag
          library: loaded
          Library version=2022-12-09
              Welcome to the ioBroker installation fixer!
              Script version: 2023-04-02
              Installing prerequisites (1/5)
          Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
          Get:2 https://deb.nodesource.com/node_18.x bullseye InRelease [4.586 B]
          Get:3 http://deb.debian.org/debian-security bullseye-security InRelease [48,4 kB]
          Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
          Get:5 http://deb.debian.org/debian bullseye/main arm64 Packages [8.071 kB]
          Get:6 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages [776 B]
          Get:7 http://deb.debian.org/debian-security bullseye-security/main arm64 Packages [235 kB]
          Get:8 http://deb.debian.org/debian bullseye-updates/main arm64 Packages [12,0 kB]
          Fetched 8.531 kB in 12s (722 kB/s)
          Reading package lists... Done
          Installed gcc-c++
          Docker detected!
          If you have any adapters that need the CAP_NET_ADMIN capability,
          you need to start the docker container with the option --cap-add=NET_ADMIN
          and manually add that capability to node
              Checking ioBroker user and directory permissions (2/5)
          visudo: /etc/sudo.conf is world writable
          Created /etc/sudoers.d/iobroker
          sudo: error in /etc/sudo.conf, line 0 while loading plugin "sudoers_policy"
          sudo: /usr/lib/sudo/sudoers.so must be only be writable by owner
          sudo: fatal error, unable to load plugins
          Fixing directory permissions...
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          main: line 12: [: -lt: unary operator expected
              Checking autostart (5/5)
          Unsupported init system, cannot enable autostart!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          diag kommt gleich ... nur die zusammenfassung oder auch das davor?
            Tomme @Tomme last edited by
            root@iobroker:/opt/iobroker# iob start
            iob diag
            • Glasfaser
              Glasfaser last edited by Glasfaser
              Alles umsetzten auf Docker
              pkill -u iobroker
              iob fix
              Container neu starten über Portainer ..
              dann
              iob diag
              kein start und stop im Container !
              T 3 Replies Last reply Reply Quote 0
                @glasfaser aso
                  @glasfaser auch nach neustart container gleiche meldung (ohne iob start)
                  ich versuche es in ner minute nochmal vielleicht war ich wieder zu schnell
                    @glasfaser
                    root@iobroker:/opt/iobroker# iob diag
                    root@iobroker:/opt/iobroker# iobroker diag
                    • Glasfaser
                      @Thomas-Braun
                      ich habe kein Plan , was mit seiner Pi los ist ...
                      Kannst du vielleicht helfen !?
                      T Thomas Braun 2 Replies Last reply Reply Quote 0
                        @glasfaser ist das jetzt auf dem lokalen rechner? neenee oder?
                        Glasfaser 2 Replies Last reply Reply Quote 0
                        • Glasfaser
                          @tomme
                          Keine Ahnung warum im Docker soetwas kommt .
                          ich habe mal eine andere Frage ... warum überhaupt Docker auf der Pi !?
                          DJMarc75 T 2 Replies Last reply Reply Quote 1
                          • DJMarc75
                            DJMarc75 @Glasfaser last edited by
                            @glasfaser
                            https://forum.iobroker.net/topic/65177/yahka-adapter-in-iobroker-im-docker-container/2
                            So hab ich im Beitrag gleich auch reagiert.
                            Glasfaser 1 Reply Last reply Reply Quote 1
                            • Glasfaser
                              Glasfaser @DJMarc75 last edited by
                              @djmarc75
                              ja... gerade auch gelesen ... wohl übersehn 🙂
                              • Glasfaser
                                @tomme
                                Vorschlag , da ich wie gesagt nicht weiterkomme mit deinem Sudo Problem :
                                Installiere doch ioBroker normal auf der Pi
                                und dann Grafana über Docker ... geht doch auch
                                  @glasfaser
                                  das ist vielleicht auch quatsch aber ...
                                  bei meiner stand alone installation danke nochmal an @thomasBraun hatte ich den iobroker grafana influx homebridge und noch iwas drauf und lief auch eigentlich
                                  dann wollte ich trenddaten von meinem loxone aufgehübscht mit grafana an meinen telegram account schicken ... ich weiß ist ne gute idee für n anfänger aber ich hatte zu dem zeitpunkt n paar daten in influx mitgeschrieben und wollte die halt zu telegram ... naja
                                  auf jeden fall war dann ich glaube in grafana n plugin zu laden das sich auf dem raspi nicht laden ließ und in irgend einem forum ich weiß nicht mehr wo stand das das nur geht wenn man das über docker löst also grafana im docker
                                  und da ich das hier gelernte ja auch in der kammer anwenden will war das mit dem docker eigentlich ne geile sache so dass die lehrlinge und meisterschüler nicht immer das gesamte system platt machen wenn bei einem teil was nicht geht und sie zu fummeln anfangen sondern halt nur einen container versauen der ja schnell mal neu gemacht ist ...
                                  ich hab ja nur begrenzte zeit mit denen im unterricht da fand ich das gut und hab das neu gemacht mit docker halt
                                    Thomas Braun Most Active @Glasfaser last edited by
                                    @glasfaser
                                    Um Docker-Installationen kümmer ich mich nicht. Grundsätzlich nicht.
                                      @glasfaser sagte in Yahka Adapter in iobroker im Docker Container:
                                      ja das würde für mich privat natürlich auch gehen da hast du recht ist halt nur ein größerer aufwand wenn man den neu machen muss
                                      • Glasfaser
                                        Glasfaser @Thomas Braun last edited by Glasfaser
                                        @thomas-braun sagte in Yahka Adapter in iobroker im Docker Container:
                                        es ging nicht um Docker ... etwas stimmt mit seiner Pi nicht !
                                        • Glasfaser
                                          weil ich mit Grafana Trenddaten an Telegram schicken wollte
                                          Habe ich auch 😉
                                            Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
                                            @glasfaser
                                            Ist das nicht jetzt ein Docker auf einem Pi?
                                            Warum auch immer man sowas machen will.
                                            Auf jeden Fall ist da an sudo herumgefummelt worden.
                                            sudo apt update
                                            sudo apt install --reinstall sudo
                                            könnte das evtl. wieder einrenken.
                                            Und eigentlich habe ich auch wenig Lust mich durch die permanente Kleinschreibung des TE zu kämpfen.
                                            Glasfaser T 2 Replies Last reply Reply Quote 2
                                            27554
