    4. Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest
      karsten @Glasfaser last edited by
      @glasfaser ich hoffe das passt so 🙄
      sainlogic.0
      411	2023-04-12 20:17:11.038	debug	Target for windspeed unit is set: m/s, using conversion: roundTo(x / 3.6, 1)
      sainlogic.0
      411	2023-04-12 20:17:11.036	debug	Target for windspeed unit is set: m/s, using conversion: roundTo(x / 3.6, 1)
      sainlogic.0
      411	2023-04-12 20:17:11.034	debug	Target for windspeed unit is set: m/s, using conversion: roundTo(x / 3.6, 1)
      sainlogic.0
      411	2023-04-12 20:17:11.031	debug	Target for maxdailygust unit is set: m/s, using conversion: roundTo(x / 3.6, 1)
      sainlogic.0
      411	2023-04-12 20:17:11.028	debug	Target for windgustspeed unit is set: m/s, using conversion: roundTo(x / 3.6, 1)
      sainlogic.0
      411	2023-04-12 20:17:11.025	debug	Target for windgustspeed unit is set: m/s, using conversion: roundTo(x / 3.6, 1)
      sainlogic.0
      411	2023-04-12 20:17:11.012	debug	Target for windgustspeed unit is set: m/s, using conversion: roundTo(x / 3.6, 1)
      sainlogic.0
      411	2023-04-12 20:17:10.907	info	Unit changed for sainlogic.0.weather.maxvalues.daily.windspeed from km/h to m/s, updating data point
      sainlogic.0
      411	2023-04-12 20:17:10.906	info	Unit changed for sainlogic.0.weather.maxvalues.absolut.windspeed from km/h to m/s, updating data point
      sainlogic.0
      411	2023-04-12 20:17:10.904	info	Unit changed for sainlogic.0.weather.current.windspeed from km/h to m/s, updating data point
      sainlogic.0
      411	2023-04-12 20:17:10.902	info	Unit changed for sainlogic.0.weather.current.maxdailygust from km/h to m/s, updating data point
      sainlogic.0
      411	2023-04-12 20:17:10.899	info	Unit changed for sainlogic.0.weather.maxvalues.daily.windgustspeed from km/h to m/s, updating data point
      sainlogic.0
      411	2023-04-12 20:17:10.897	info	Unit changed for sainlogic.0.weather.maxvalues.absolut.windgustspeed from km/h to m/s, updating data point
      sainlogic.0
      411	2023-04-12 20:17:10.893	info	Unit changed for sainlogic.0.weather.current.windgustspeed from km/h to m/s, updating data point
      sainlogic.0
      411	2023-04-12 20:17:10.726	info	Starting Listener
      sainlogic.0
      411	2023-04-12 20:17:10.722	debug	Forward URL:
      sainlogic.0
      411	2023-04-12 20:17:10.721	debug	Listener protocol: ecowitt
      sainlogic.0
      411	2023-04-12 20:17:10.720	debug	Listener path: /data/report
      sainlogic.0
      411	2023-04-12 20:17:10.719	debug	Listener port: 45000
      sainlogic.0
      411	2023-04-12 20:17:10.708	debug	Listener IP: 0.0.0.0
      sainlogic.0
      411	2023-04-12 20:17:10.637	info	starting. Version 0.10.0 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v16.19.1, js-controller: 4.0.15
      synology.0
      1576	2023-04-12 20:17:10.235	info	Connecting to Synology 192.168.178.27:5001
      sainlogic.0
      411	2023-04-12 20:17:10.098	debug	States connected to redis: 127.0.0.1:9000
      sainlogic.0
      411	2023-04-12 20:17:10.046	debug	States create User PubSub Client
      sainlogic.0
      411	2023-04-12 20:17:10.043	debug	States create System PubSub Client
      sainlogic.0
      411	2023-04-12 20:17:10.013	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      sainlogic.0
      411	2023-04-12 20:17:09.956	debug	Objects connected to redis: 127.0.0.1:9001
      sainlogic.0
      411	2023-04-12 20:17:09.946	debug	Objects client initialize lua scripts
      sainlogic.0
      411	2023-04-12 20:17:09.852	debug	Objects create User PubSub Client
      sainlogic.0
      411	2023-04-12 20:17:09.849	debug	Objects create System PubSub Client
      sainlogic.0
      411	2023-04-12 20:17:09.846	debug	Objects client ready ... initialize now
      sainlogic.0
      411	2023-04-12 20:17:09.776	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.phoscon
      2023-04-12 20:17:07.931	info	instance system.adapter.sainlogic.0 started with pid 411
      host.phoscon
      2023-04-12 20:17:05.502	info	instance system.adapter.sainlogic.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      sainlogic.0
      30688	2023-04-12 20:17:04.848	info	Listener closed.
      sainlogic.0
      30688	2023-04-12 20:17:04.846	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      sainlogic.0
      30688	2023-04-12 20:17:04.844	info	terminating
      sainlogic.0
      30688	2023-04-12 20:17:04.843	info	Sainlogic Adapter gracefully shut down...
      sainlogic.0
      30688	2023-04-12 20:17:04.840	info	Got terminate signal TERMINATE_YOURSE
      App_Einstellungen.jfif
        karsten @karsten last edited by
        @karsten sagte in Test Adapter ioBroker.sainlogic v0.6.X GitHub/Latest:
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        synology.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        host.phoscon
        host.phoscon
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        sainlogic.0
        PS: in der App-Einstellung ist der host=pi ; ist der, mit dem ich mich auf dem PI anmelde !?
        Thomas Braun Boronsbruder 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @karsten last edited by Thomas Braun
          @karsten
          Bring dein System in Gänze auf einen aktuellen Stand.
          Das ist offenbar furchtbar lange nicht mehr getan worden, denn
          stable:	4.0.24 for 3 months
          • Fabio
            Fabio @karsten last edited by Fabio
            @karsten es sieht ja so aus das keine Daten empfangen werden. Da sie ja auf den Webseiten vorhanden sind kann es sein das die Station evtl. nicht unterstützt wird?
            Wenn sie dann auf den Webseiten vorhanden sind müssten sie dann auch eigentlich im Adapter erscheinen wenn alle Einstellungen korrekt sind.
            Welche Version hat der Adapter?
            Ist die Station Firmware mäßig aktuell?
            Vielleicht kann sich das auch mal @Fogg ansehen.
            Ist ioBroker auf aktuellem Stand?
            Fabio
            • Boronsbruder
              Boronsbruder @karsten last edited by Boronsbruder
              @karsten
              Der Eintrag bei SERVER IP / Hostname passt doch nicht? ( im screenshot)
              Soll heißen Server IP ODER Hostname...
              Lass mal das "/admin" weg
              Hostname ist übrigens der Name des Rechners der im System zugewiesen wird:
              Der Hostname (auch Sitename)[1] ist die eindeutige Bezeichnung eines Rechners in einem Netzwerk.
                karsten @Boronsbruder last edited by
                @boronsbruder Dankeee !!!! das war es !
                Was für ein Brett vor dem Kopf !!
                Vielen Dank an Euch !!
                @Thomas-Braun wird das damit nicht aktualisiert ??```
                sudo apt update
                sudo apt full.update
                  Nein, der iobroker und dessen Bestandteile werden nicht über apt aktuell gehalten, dafür hat der eigene Werkzeuge.
                    lesiflo Most Active last edited by lesiflo
                    Hi, ich habe mal versucht über den Adapter meine Ecowitt GW1100A zu verbinden. Leider kommen nach dem Start im Protokoll diese Meldungen hier:
                    2023-05-05 10:57:16.468 - error: sainlogic.0 (31550) Scheduler received data for unkown command 80 subcommand 71
                    2023-05-05 10:57:18.106 - error: sainlogic.0 (31550) Scheduler received data for unkown command 91 subcommand 97
                    2023-05-05 10:57:18.313 - error: sainlogic.0 (31550) Scheduler received data for unkown command 91 subcommand 97
                    2023-05-05 10:57:19.616 - error: sainlogic.0 (31550) Scheduler received data for unkown command 91 subcommand 97
                    2023-05-05 10:57:19.824 - error: sainlogic.0 (31550) Scheduler received data for unkown command 91 subcommand 97
                    2023-05-05 10:57:20.121 - error: sainlogic.0 (31550) Scheduler received data for unkown command 91 subcommand 97
                    2023-05-05 10:57:30.437 - error: sainlogic.0 (31550) Scheduler received data for unkown command 80 subcommand 71
                    2023-05-05 10:57:30.453 - error: sainlogic.0 (31550) Scheduler received data for unkown command 91 subcommand 97
                    2023-05-05 10:57:30.463 - error: sainlogic.0 (31550) Scheduler received data for unkown command 91 subcommand 97
                    2023-05-05 10:57:30.476 - error: sainlogic.0 (31550) Scheduler received data for unkown command 91 subcommand 97
                    2023-05-05 10:57:30.491 - error: sainlogic.0 (31550) Scheduler received data for unkown command 91 subcommand 97
                    2023-05-05 10:57:30.507 - error: sainlogic.0 (31550) Scheduler received data for unkown command 91 subcommand 97
                    Einstellungen:
                      Thomas Braun Most Active @lesiflo last edited by
                      @lesiflo
                      Meine Station liefert über den Listener und nicht über den Zeitplan.
                      Fogg 1 Reply Last reply Reply Quote 1
                      • Fogg
                        Fogg @Thomas Braun last edited by
                        Nach langem habe ich mal wieder Updates eingebaut.
                        Es gibt nun 0.10.3 im Git repo.
                        Changelog steht auch im Git... ganz grob:
                        • Forwarding geht wieder
                        • Änderung von Einheiten geht nun auch
                        • Kleine Fixes für Ecowitt Benutzer
                        manuxi B T 3 Replies Last reply Reply Quote 4
                        • Fabio
                          Fabio @Fogg last edited by Fabio
                          Hallo @fogg herzlichen Dank für die neue Version 0.10.3.👍
                          Fabio
                          M H 2 Replies Last reply Reply Quote 1
                            martinschm @Fabio last edited by
                            Wird die ecowitt GW1101 auch unterstützt?
                            Hat die jemand erfolgreich eingebunden?
                            Viele Grüße
                            Martin
                              hardl @Fabio last edited by
                              @fa-bio Ich habe die WS3500 und den Adapter neu installiert und möchte die Regendaten zur Steuerung einer Beregnungsautomatik nutzen.
                              Die Definition der Datenpunkte:
                              rain (aktuelle Hochrechnung/h ?)
                              totalrain (seit Installation ?),
                              dailyrain (seit 0 Uhr ?),
                              eventrain nur Piezo (Menge seit Regenbeginn ?)
                              finde ich nirgends.
                              Um eine Aussetzung der Beregnung im Skript zu erreichen würde eine 24-Stunden Regenmenge eventuell besser passen. Diese Daten werden in der Ecowitt App aber nur im Diagramm angezeigt.
                              Sind die _Piezo Daten nur von Zusatzsensoren?
                              Ich hab schon viele Beiträge im Internet gelesen, ohne die genaue Definition zu finden und da es schon länger bei uns nicht regnet, kann ich auch nicht optimal testen.
                              Fabio 1 Reply Last reply Reply Quote 0
                              • Fabio
                                Fabio @hardl last edited by
                                @hardl das kann ich dir leider nicht sagen, sind denn alle anderen Daten im Adapter da? Ansonsten sollte sich das mal bitte @Fogg anschauen.
                                Herzliche Grüße
                                Fabio
                                  @fa-bio Entschuldige bitte, ich wollte eigentlich @Fogg fragen.
                                  Die meisten Datenpunkte sind ok, nur die Piezo Datenpunkte sind leer und was das bedeutet weiß und finde ich leider nicht.
                                  Viele Grüße
                                  Reinhard
                                    Letzi @karsten last edited by
                                    @karsten
                                    Hallo.
                                    Ich habe das gleiche Problem wie Karsten. Auch bei mir werden nur die Einheiten und keine Werte im ioBroker angezeigt. Wie Kasten habe ich kein Admin hinter der IP Adresse des USB Dongle stehen. Der Dongle (DP1500 ) ist erreichbar. Ich habe mich inzwichen auch bei https://www.ecowitt.net/ angemeldet, kann ja sein, das der Hersteller das inzwischen möchte.
                                    Wäre super, wenn einer von Euch seine Einstellungen teilt.
                                      Letzi last edited by
                                      Update: zu empfehlen ist die Anleitung https://www.npmjs.com/package/iobroker.sainlogic
                                      Ich musste die Zeitplaneinstellung deaktivieren, damit die Fehlermeldungen aufhören. Im WIFI Dongle selbst kann man den Zeitplan festlegen.
                                      Damit ist mein Problem gelöst.
                                      • manuxi
                                        manuxi @Fogg last edited by
                                        @fogg Ich habe es jetzt erst gesehen & getestet, endlich wird weather underground geupdatet! Ein herzliches Dankeschön!!!
                                        manuxi 1 Reply Last reply Reply Quote 0
                                        • manuxi
                                          manuxi @manuxi last edited by
                                          Nur zur Info: Ich bekomme ständig die Warning 'State value to set for "sainlogic.0.weather.current.yearlyrain" has value "-253974.6" less than min "0"'.
                                          Nicht weiter wild, scheint eher ein kosmetisches Problem zu sein...
                                            Banis @Fogg last edited by
                                            @fogg Vielen Dank für den Adapter ist wirklich super.
                                            Hab allerdings das Problem, dass ich nur Werte im Listener Modus empfange. Wenn ich auf den Scheduler Modus umstelle bekomme ich folgende Fehlermeldung im Log:
                                            Weiß du woran das liegt? Hab eine Froggit DP1500 (also Ecowitt GW1100).
                                            Im Adapter habe ich Listener Einstellungen deaktiviert und Zeitplan aktiviert mit Ip der Wetterstation Post 45000 und Intervall 15.
                                            1.0k
                                            adapter froggit wh4000sh sainlogic wetterstation ws980wifi
                                            60
                                            326
                                            73995
