    3. Off Topic
    4. Proxmox
    5. Proxmox LXC mit Frigate
      Radi @Wal last edited by
      @wal Dankeschön, ich schau mal, ob noch etwas mehr drin steht.
        Radi @Radi last edited by Radi
        @Wal Da steht letztenendes dasselbe wie im Portainerlogfile drin. Ursächlich scheint wohl dies zu sein:
        2023-05-07 14:44:51.033075103  *************************************************************
        2023-05-07 14:44:51.033078419  *************************************************************
        2023-05-07 14:44:51.033079955  ***    Your config file is not valid!                     ***
        2023-05-07 14:44:51.033081414  ***    Please check the docs at                           ***
        2023-05-07 14:44:51.033082613  ***    https://docs.frigate.video/configuration/index     ***
        2023-05-07 14:44:51.033083997  *************************************************************
        2023-05-07 14:44:51.033085013  *************************************************************
        2023-05-07 14:44:51.033092726  ***    Config Validation Errors                           ***
        2023-05-07 14:44:51.033093828  *************************************************************
        2023-05-07 14:44:51.033094705  [Errno 21] Is a directory: '/config/config.yml'
        2023-05-07 14:44:51.033656750  Traceback (most recent call last):
        2023-05-07 14:44:51.033658821    File "/opt/frigate/frigate/app.py", line 351, in start
        2023-05-07 14:44:51.033659876      self.init_config()
        2023-05-07 14:44:51.033660984    File "/opt/frigate/frigate/app.py", line 80, in init_config
        2023-05-07 14:44:51.033661995      user_config = FrigateConfig.parse_file(config_file)
        2023-05-07 14:44:51.033662995    File "/opt/frigate/frigate/config.py", line 1064, in parse_file
        2023-05-07 14:44:51.033663850      with open(config_file) as f:
        2023-05-07 14:44:51.033664794  IsADirectoryError: [Errno 21] Is a directory: '/config/config.yml'
        2023-05-07 14:44:51.033665538
        2023-05-07 14:44:51.033666509  *************************************************************
        2023-05-07 14:44:51.033667457  ***    End Config Validation Errors                       ***
        2023-05-07 14:44:51.033668354  **********************************************************
        Nur weiß ich nicht, wie man diesen "IsADirectoryError" korrigiert. Findet Frigate in dem angegebenen Pfad nichts? Oder hat dies eine andere Ursache? Den Screenshot aus dem Filezilla habe ich ja schon weiter oben gepostet. Mit meinem bescheidenen oder nicht vorhandenen Wissen würde ich annehmen, dass der Pfad zur config.yaml so passt.
        Wal 2 Replies Last reply Reply Quote 0
        • Wal
          Wal Developer @Radi last edited by
          @radi ,
          wie erstellst du die config.yml ? mit nano ?
          • Wal
            Wal Developer @Radi last edited by Wal
            @radi ,
            mach mal im Container diesen Befehl:
            cat /config/config.yml
              Radi @Wal last edited by Radi
              @wal sagte in Proxmox LXC mit Frigate:
              Hallo Walter,
              das ganze verwirrt mich jetzt etwas. Die Ausgabe ist:
              cat: /config/config.yml: No such file or directory
              will ich das Verzeichnis erzeugen, kommt das:
              mkdir config
              mkdir: cannot create directory 'config': File exists
              Will ich mit nano eine neue config erzeugen kommt:
                GNU nano 6.4                        /config/config.yml
                                       [ Directory '/config' does not exist ]
              ^G Help       ^O Write Out  ^W Where Is   ^K Cut        ^T Execute    ^C Location
              ^X Exit       ^R Read File  ^\ Replace    ^U Paste      ^J Justify    ^/ Go To Line
              Wechsel ich dann zu Fuß in das Verzeichnis config und gebe dann deinen cat-Befehl angepasst ein kommt das:
              ~/config# cat config.yml
              detectors:
                cpu1:
                  type: cpu
              mqtt:
                host: 192.168.69.159
                user: user
                password: xxx
              cameras:
                back:
                  ffmpeg:
                    hwaccel_args: preset-vaapi
                    inputs:
                      - path: rtsp:/XXX:xxx@192.168.69.162:554/h264Preview_01_sub
                        roles:
                          - detect
                      - path: rtsp://XXX.xxx@192.168.69.162:554/h264Preview_01_main
                        roles:
                          - record
                  detect:
                    width: 640
                    height: 360
                  mqtt:
                    enabled: False
                 objects:
                    track:
                      - person
                      - car
                      - truck
                      - bicycle
                      - motorcycle
                      - dog
                      - cat
              snapshots:
                enabled: True
                timestamp: False
                bounding_box: False
                crop: False
                height: 175
                required_zones: []
                retain:
                  default: 10
                  objects:
                        person: 15
              record:
                enabled: True
                retain:
                  days: 7
                  mode: motion
                events:
                  retain:
                    default: 14
                    mode: active_objects
                    objects:
                      person: 14
                      dog: 2
                      car: 7
              Wal holzapfelauge 2 Replies Last reply Reply Quote 0
              • Wal
                @radi ,
                du musst da aufpassen.
                Im Docker-Container muss man diese Datei nicht erzeugen, die zeigt nur auf die Datei im LXC.
                      - /home/frigate/frigate/config.yml:/config/config.yml
                also die Datei im LXC "/home/frigate/frigate/config.yml" wird im Docker auf "/config/config.yml" gemappt.
                das geht automatisch. Du musst nur die Datei wie hier im LXC "/home/frigate/frigate/config.yml" oder wie in deiner Docker-Config angegeben erzeugen.
                edit: oder mappst du die Datei in der Docker-Config gar nicht auf "/config/config.yml"
                editedit: der Docker Container ist fertig eingerichtet, da muss nichts verändert werden.
                  exitus @Wal last edited by exitus
                  danke euch allen
                  mit viel grübeln habe ich frigate am laufen aber nur minimal.
                  habe ein camera eingebunden mit minimal config rest mache ich weiter wenn mein tpu da ist.
                    exitus last edited by exitus
                    ich habe kamera eingebunden habe aber ein greenscreen nur
                    woran kann es liegen???
                    erledigt
                      Hallo was ist an diesem config falsch
                      detectors:
                        cpu1:
                          type: cpu
                      database:
                          path: /db/frigate.db
                      mqtt:
                        host: 172.16.0.10
                        port: 1689
                        user: admin
                        password: passwort
                      cameras:
                        Parkplatz:
                          ffmpeg:
                            output_args:
                              record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -st>
                              rtmp: -c:v copy -c:a aac -f flv
                            inputs:
                      	  - path: rtsp://admin:passwort@172.16.0.147:554/Streaming/Channels/102/?trans>
                                roles:
                                  - detect
                                  - path: rtsp://admin:passwort1@172.16.0.147:554/Streaming/Channels/101?tr>
                                roles:
                                  - record
                          rtmp:
                            enabled: False
                      detect:
                            width: 640
                            height: 480
                      objects:
                            track:
                              - person
                              - car
                              - dog
                      snapshots:
                            enabled: true
                      	  timestamp: true
                            bounding_box: true
                            retain:
                              default: 2
                      record:
                            enabled: true
                            retain:
                              days: 10
                      was sind das für errors
                      [2023-05-10 06:39:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                      [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                      [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                      [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                      [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                      [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5613b818fec0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                      [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                      [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                      [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                      [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                      [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                      [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                      [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x565490d5b080] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                      [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                      [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                      [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                      [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                      [2023-05-10 06:39:46] ws4py                          INFO    : Terminating websocket [Local => 127.0.0.1:5002 | Remote => 127.0.0.1:51710]
                      [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                      [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                      [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55d19e0b4f40] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                      [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                      [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                      [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                      [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                      [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                      [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                      [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c154580500] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                      [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                      [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                      [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                      [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                      [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                      [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                      [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x561611bada80] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                      [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                      [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                      [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                      [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                      [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                      [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                      [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55cdb7c11380] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                      [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                      [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                      [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                      [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                      [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                      [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                      [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x555cad1cc4c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                      [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                      [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                      [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                      [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                      [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                      [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                      [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c7da0535c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                      [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                      [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                      [cont-finish.d] executing container finish scripts...
                      [cont-finish.d] done.
                      [s6-finish] waiting for services.
                      [s6-finish] sending all processes the TERM signal.
                      [s6-finish] sending all processes the KILL signal and exiting.
                      [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
                      [s6-init] ensuring user provided files have correct perms...exited 0.
                      [fix-attrs.d] applying ownership & permissions fixes...
                      [fix-attrs.d] done.
                      [cont-init.d] executing container initialization scripts...
                      [cont-init.d] done.
                      [services.d] starting services
                      [services.d] done.
                      [2023-05-10 06:40:49] frigate.app                    INFO    : Starting Frigate (0.11.1-2eada21)
                      Starting migrations
                      [2023-05-10 06:40:49] peewee_migrate                 INFO    : Starting migrations
                      There is nothing to migrate
                      [2023-05-10 06:40:49] peewee_migrate                 INFO    : There is nothing to migrate
                      [2023-05-10 06:40:49] detector.cpu1                  INFO    : Starting detection process: 216
                      [2023-05-10 06:40:49] frigate.app                    INFO    : Output process started: 218
                      [2023-05-10 06:40:49] frigate.edgetpu                WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
                      [2023-05-10 06:40:49] ws4py                          INFO    : Using epoll
                      [2023-05-10 06:40:49] frigate.app                    INFO    : Camera processor started for Parkplatz: 222
                      [2023-05-10 06:40:49] frigate.app                    INFO    : Capture process started for Parkplatz: 224
                      [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                      [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                      [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                      [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                      [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5621d50b8800] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                      [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                      [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                      snapshot bewegung wird erkannt aber ich habe keine aufnahmen oder clips
                      • Wal
                        Wal Developer @exitus last edited by
                        @exitus sagte in Proxmox LXC mit Frigate:
                        output_args:
                        Was möchtest du damit erreichen ?
                        Wenn du was transcodieren möchtest nimmt man in frigate 0.12.0 go2rtc das ist mit dabei.
                          @wal eigentlich garnichts habe es irgendwo gefunden und eingefügt damit ich kein greenscreen habe.
                          haben annke nc400 möchte das es erkennt und aufnimmt.
                          Bei mir werden bilder gemach aber keine clips.
                          Mein kamera sendet h264
                          • Wal
                            Wal Developer @exitus last edited by Wal
                            @exitus ,
                            meine reolink auch und habe keinen Greenscreen.
                              camera1:
                                ffmpeg:
                                  inputs:
                                    - path: rtsp://admin:08154711@192.168.122.100:554/h264Preview_01_sub
                                      roles:
                                        - detect
                                    - path: rtsp://admin:08154711@192.168.122.122:554/h264Preview_01_main
                                      roles:
                                        - record
                                detect:
                                  width: 640
                                  height: 360
                                mqtt:
                                  enabled: False
                            Greenscreen hatte ich mit einem Raspi4 mit aktivierter Hardwarebeschleunigung.
                            • Wal
                              @exitus ,
                              lese gerade das die Kamera auch h265 kann.
                              Hier ist ein Video für das Einbinden einer nc400, zwar für Hass aber das geht auch über frigate. Etwa bei 8:30 min
                                wäre jemand nett und könnte mir helfen wie ich synology nas freigabe in meinem container wo frigate läuft mounten damit ich die aufnahmen auf dem nas habe.
                                wäre nett wenn jemand schritt für schritt erklärt.
                                gemout habe ich es bekommen aber wenn ich den frigate container starten möchte steht immer acces denied
                                • Wal
                                  @exitus ,
                                  du machst das Laufwerk unter dem Proxmox Host verfügbar z.B. unter '/media/synology' so als wäre es ein normales Laufwerk.
                                  Danach gibst du in der lxc.conf den Ordner für den Frigate LXC frei.
                                  arch: amd64
                                  cores: 4
                                  features: keyctl=1,nesting=1
                                  hostname: testfrigate
                                  memory: 8192
                                  mp0: /media/synology,mp=/media/frigate
                                  danach ist der Ordner im LXC unter '/media/frigate' verfügbar und du kannst ihn im Docker hinzufügen.
                                      volumes:
                                        - /etc/localtime:/etc/localtime:ro
                                        - /home/frigate/config/config.yml:/config/config.yml
                                        - /media/frigate:/media/frigate
                                    @wal das habe ich gemacht, ich kann auch über die Konsole vom lxc kann ich die freigabe sehen aber habe kein schreib zugriff.
                                    Ich habe über den Host in fstab die freigabe eingetragen , über den Host habe ich die schreib und leserechte von der nas aber über die lxc container vo docker und frigate läuft nicht
                                    • Wal
                                      @exitus,
                                      ok da kann ich jetzt nicht helfen.
                                      Ich mache es anders rum, habe eine USB Festplatte als LXC-Backup und Datenspeicher eingerichtet und gebe diese über einen Samba LXC im Netzwerk frei. Damit habe ich Zugriff auf alle Dateien die ich im Proxmox speichere.
                                      • Wal
                                        @exitus ,
                                        schau dir das mal an, könnte helfen.
                                          @wal habe es geschafft jetz anderes problem habe 2 cameras beide machen screenshots dedection klappt bei einen habe ich clips bei den anderen nur bilder ohne clips wo kein clips sind ist die kamera mit der bezeichnung back
                                          ier mein config
                                          database:
                                            path: /media/frigate/db/frigate.db
                                          detectors:
                                            cpu1:
                                              type: cpu
                                          ui:
                                            use_experimental: false
                                            live_mode: mse
                                          mqtt:
                                            host: 172.16.0.10
                                            port: 12345
                                            user: xxxxxxx
                                            password: exxxxx
                                          cameras:
                                            back1:
                                              ffmpeg:
                                                inputs:
                                                  - path: rtsp://admin:xxxxx@172.16.0.177:554/channel=2
                                                    roles:
                                                      - detect
                                                      - rtmp
                                                  - path: rtsp://admin:xxxxxxx@172.16.0.177:554/channel=1
                                                    roles:
                                                      - record
                                            back:
                                              ffmpeg:
                                                inputs:
                                                  - path: rtsp://admin:xxxxxxxx@172.16.0.147:554/Streaming/Channels/102?transportmode=unicast&profile=Profile_2
                                                    roles:
                                                      - detect
                                                      - rtmp
                                                    roles:
                                                      - record
                                          detect:
                                                width: 640
                                                height: 480
                                                fps: 5
                                          objects:
                                                track:
                                                  - person
                                                  - dog
                                                  - bicycle
                                                  - cat
                                                filters:
                                                  person:
                                                    min_score: 0.7
                                                    threshold: 0.5
                                                    min_area: 700
                                          snapshots:
                                                enabled: true
                                                timestamp: true
                                                bounding_box: true
                                                crop: True
                                                height: 500
                                                retain:
                                                  default: 1
                                          record:
                                            enabled: True
                                            events:
                                              retain:
                                                default: 10
                                          birdseye:
                                            enabled: True
                                            mode: continuous
                                          • Wal
                                            @exitus ,
                                            schau mal im Adapter ob das dort eingeschaltet ist.
                                            176
                                            42683
