    3. Off Topic
    4. Proxmox
    5. Proxmox LXC mit Frigate
      Radi @Radi last edited by Radi
      @Wal Da steht letztenendes dasselbe wie im Portainerlogfile drin. Ursächlich scheint wohl dies zu sein:
      2023-05-07 14:44:51.033075103  *************************************************************
      2023-05-07 14:44:51.033078419  *************************************************************
      2023-05-07 14:44:51.033079955  ***    Your config file is not valid!                     ***
      2023-05-07 14:44:51.033081414  ***    Please check the docs at                           ***
      2023-05-07 14:44:51.033082613  ***    https://docs.frigate.video/configuration/index     ***
      2023-05-07 14:44:51.033083997  *************************************************************
      2023-05-07 14:44:51.033085013  *************************************************************
      2023-05-07 14:44:51.033092726  ***    Config Validation Errors                           ***
      2023-05-07 14:44:51.033093828  *************************************************************
      2023-05-07 14:44:51.033094705  [Errno 21] Is a directory: '/config/config.yml'
      2023-05-07 14:44:51.033656750  Traceback (most recent call last):
      2023-05-07 14:44:51.033658821    File "/opt/frigate/frigate/app.py", line 351, in start
      2023-05-07 14:44:51.033659876      self.init_config()
      2023-05-07 14:44:51.033660984    File "/opt/frigate/frigate/app.py", line 80, in init_config
      2023-05-07 14:44:51.033661995      user_config = FrigateConfig.parse_file(config_file)
      2023-05-07 14:44:51.033662995    File "/opt/frigate/frigate/config.py", line 1064, in parse_file
      2023-05-07 14:44:51.033663850      with open(config_file) as f:
      2023-05-07 14:44:51.033664794  IsADirectoryError: [Errno 21] Is a directory: '/config/config.yml'
      2023-05-07 14:44:51.033665538
      2023-05-07 14:44:51.033666509  *************************************************************
      2023-05-07 14:44:51.033667457  ***    End Config Validation Errors                       ***
      2023-05-07 14:44:51.033668354  **********************************************************
      Nur weiß ich nicht, wie man diesen "IsADirectoryError" korrigiert. Findet Frigate in dem angegebenen Pfad nichts? Oder hat dies eine andere Ursache? Den Screenshot aus dem Filezilla habe ich ja schon weiter oben gepostet. Mit meinem bescheidenen oder nicht vorhandenen Wissen würde ich annehmen, dass der Pfad zur config.yaml so passt.
      Wal 2 Replies Last reply Reply Quote 0
      • Wal
        Wal Developer @Radi last edited by
        @radi ,
        wie erstellst du die config.yml ? mit nano ?
        • Wal
          Wal Developer @Radi last edited by Wal
          @radi ,
          mach mal im Container diesen Befehl:
          cat /config/config.yml
            Radi @Wal last edited by Radi
            @wal sagte in Proxmox LXC mit Frigate:
            Hallo Walter,
            das ganze verwirrt mich jetzt etwas. Die Ausgabe ist:
            cat: /config/config.yml: No such file or directory
            will ich das Verzeichnis erzeugen, kommt das:
            mkdir config
            mkdir: cannot create directory 'config': File exists
            Will ich mit nano eine neue config erzeugen kommt:
              GNU nano 6.4                        /config/config.yml
                                     [ Directory '/config' does not exist ]
            ^G Help       ^O Write Out  ^W Where Is   ^K Cut        ^T Execute    ^C Location
            ^X Exit       ^R Read File  ^\ Replace    ^U Paste      ^J Justify    ^/ Go To Line
            Wechsel ich dann zu Fuß in das Verzeichnis config und gebe dann deinen cat-Befehl angepasst ein kommt das:
            ~/config# cat config.yml
            detectors:
              cpu1:
                type: cpu
            mqtt:
              host: 192.168.69.159
              user: user
              password: xxx
            cameras:
              back:
                ffmpeg:
                  hwaccel_args: preset-vaapi
                  inputs:
                    - path: rtsp:/XXX:xxx@192.168.69.162:554/h264Preview_01_sub
                      roles:
                        - detect
                    - path: rtsp://XXX.xxx@192.168.69.162:554/h264Preview_01_main
                      roles:
                        - record
                detect:
                  width: 640
                  height: 360
                mqtt:
                  enabled: False
               objects:
                  track:
                    - person
                    - car
                    - truck
                    - bicycle
                    - motorcycle
                    - dog
                    - cat
            snapshots:
              enabled: True
              timestamp: False
              bounding_box: False
              crop: False
              height: 175
              required_zones: []
              retain:
                default: 10
                objects:
                      person: 15
            record:
              enabled: True
              retain:
                days: 7
                mode: motion
              events:
                retain:
                  default: 14
                  mode: active_objects
                  objects:
                    person: 14
                    dog: 2
                    car: 7
            Wal holzapfelauge 2 Replies Last reply Reply Quote 0
            • Wal
              @radi ,
              du musst da aufpassen.
              Im Docker-Container muss man diese Datei nicht erzeugen, die zeigt nur auf die Datei im LXC.
                    - /home/frigate/frigate/config.yml:/config/config.yml
              also die Datei im LXC "/home/frigate/frigate/config.yml" wird im Docker auf "/config/config.yml" gemappt.
              das geht automatisch. Du musst nur die Datei wie hier im LXC "/home/frigate/frigate/config.yml" oder wie in deiner Docker-Config angegeben erzeugen.
              edit: oder mappst du die Datei in der Docker-Config gar nicht auf "/config/config.yml"
              editedit: der Docker Container ist fertig eingerichtet, da muss nichts verändert werden.
                exitus @Wal last edited by exitus
                danke euch allen
                mit viel grübeln habe ich frigate am laufen aber nur minimal.
                habe ein camera eingebunden mit minimal config rest mache ich weiter wenn mein tpu da ist.
                  exitus last edited by exitus
                  ich habe kamera eingebunden habe aber ein greenscreen nur
                  woran kann es liegen???
                  erledigt
                    Hallo was ist an diesem config falsch
                    detectors:
                      cpu1:
                        type: cpu
                    database:
                        path: /db/frigate.db
                    mqtt:
                      host: 172.16.0.10
                      port: 1689
                      user: admin
                      password: passwort
                    cameras:
                      Parkplatz:
                        ffmpeg:
                          output_args:
                            record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -st>
                            rtmp: -c:v copy -c:a aac -f flv
                          inputs:
                    	  - path: rtsp://admin:passwort@172.16.0.147:554/Streaming/Channels/102/?trans>
                              roles:
                                - detect
                                - path: rtsp://admin:passwort1@172.16.0.147:554/Streaming/Channels/101?tr>
                              roles:
                                - record
                        rtmp:
                          enabled: False
                    detect:
                          width: 640
                          height: 480
                    objects:
                          track:
                            - person
                            - car
                            - dog
                    snapshots:
                          enabled: true
                    	  timestamp: true
                          bounding_box: true
                          retain:
                            default: 2
                    record:
                          enabled: true
                          retain:
                            days: 10
                    was sind das für errors
                    [2023-05-10 06:39:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                    [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                    [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                    [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                    [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                    [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5613b818fec0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                    [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                    [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                    [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                    [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                    [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                    [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                    [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x565490d5b080] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                    [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                    [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                    [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                    [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                    [2023-05-10 06:39:46] ws4py                          INFO    : Terminating websocket [Local => 127.0.0.1:5002 | Remote => 127.0.0.1:51710]
                    [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                    [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                    [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55d19e0b4f40] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                    [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                    [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                    [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                    [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                    [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                    [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                    [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c154580500] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                    [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                    [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                    [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                    [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                    [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                    [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                    [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x561611bada80] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                    [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                    [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                    [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                    [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                    [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                    [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                    [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55cdb7c11380] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                    [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                    [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                    [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                    [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                    [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                    [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                    [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x555cad1cc4c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                    [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                    [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                    [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                    [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                    [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                    [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                    [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c7da0535c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                    [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                    [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                    [cont-finish.d] executing container finish scripts...
                    [cont-finish.d] done.
                    [s6-finish] waiting for services.
                    [s6-finish] sending all processes the TERM signal.
                    [s6-finish] sending all processes the KILL signal and exiting.
                    [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
                    [s6-init] ensuring user provided files have correct perms...exited 0.
                    [fix-attrs.d] applying ownership & permissions fixes...
                    [fix-attrs.d] done.
                    [cont-init.d] executing container initialization scripts...
                    [cont-init.d] done.
                    [services.d] starting services
                    [services.d] done.
                    [2023-05-10 06:40:49] frigate.app                    INFO    : Starting Frigate (0.11.1-2eada21)
                    Starting migrations
                    [2023-05-10 06:40:49] peewee_migrate                 INFO    : Starting migrations
                    There is nothing to migrate
                    [2023-05-10 06:40:49] peewee_migrate                 INFO    : There is nothing to migrate
                    [2023-05-10 06:40:49] detector.cpu1                  INFO    : Starting detection process: 216
                    [2023-05-10 06:40:49] frigate.app                    INFO    : Output process started: 218
                    [2023-05-10 06:40:49] frigate.edgetpu                WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
                    [2023-05-10 06:40:49] ws4py                          INFO    : Using epoll
                    [2023-05-10 06:40:49] frigate.app                    INFO    : Camera processor started for Parkplatz: 222
                    [2023-05-10 06:40:49] frigate.app                    INFO    : Capture process started for Parkplatz: 224
                    [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
                    [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
                    [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
                    [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
                    [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5621d50b8800] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
                    [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
                    [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
                    snapshot bewegung wird erkannt aber ich habe keine aufnahmen oder clips
                    • Wal
                      Wal Developer @exitus last edited by
                      @exitus sagte in Proxmox LXC mit Frigate:
                      output_args:
                      Was möchtest du damit erreichen ?
                      Wenn du was transcodieren möchtest nimmt man in frigate 0.12.0 go2rtc das ist mit dabei.
                        @wal eigentlich garnichts habe es irgendwo gefunden und eingefügt damit ich kein greenscreen habe.
                        haben annke nc400 möchte das es erkennt und aufnimmt.
                        Bei mir werden bilder gemach aber keine clips.
                        Mein kamera sendet h264
                        • Wal
                          Wal Developer @exitus last edited by Wal
                          @exitus ,
                          meine reolink auch und habe keinen Greenscreen.
                            camera1:
                              ffmpeg:
                                inputs:
                                  - path: rtsp://admin:08154711@192.168.122.100:554/h264Preview_01_sub
                                    roles:
                                      - detect
                                  - path: rtsp://admin:08154711@192.168.122.122:554/h264Preview_01_main
                                    roles:
                                      - record
                              detect:
                                width: 640
                                height: 360
                              mqtt:
                                enabled: False
                          Greenscreen hatte ich mit einem Raspi4 mit aktivierter Hardwarebeschleunigung.
                          • Wal
                            @exitus ,
                            lese gerade das die Kamera auch h265 kann.
                            Hier ist ein Video für das Einbinden einer nc400, zwar für Hass aber das geht auch über frigate. Etwa bei 8:30 min
                              wäre jemand nett und könnte mir helfen wie ich synology nas freigabe in meinem container wo frigate läuft mounten damit ich die aufnahmen auf dem nas habe.
                              wäre nett wenn jemand schritt für schritt erklärt.
                              gemout habe ich es bekommen aber wenn ich den frigate container starten möchte steht immer acces denied
                              • Wal
                                @exitus ,
                                du machst das Laufwerk unter dem Proxmox Host verfügbar z.B. unter '/media/synology' so als wäre es ein normales Laufwerk.
                                Danach gibst du in der lxc.conf den Ordner für den Frigate LXC frei.
                                arch: amd64
                                cores: 4
                                features: keyctl=1,nesting=1
                                hostname: testfrigate
                                memory: 8192
                                mp0: /media/synology,mp=/media/frigate
                                danach ist der Ordner im LXC unter '/media/frigate' verfügbar und du kannst ihn im Docker hinzufügen.
                                    volumes:
                                      - /etc/localtime:/etc/localtime:ro
                                      - /home/frigate/config/config.yml:/config/config.yml
                                      - /media/frigate:/media/frigate
                                  @wal das habe ich gemacht, ich kann auch über die Konsole vom lxc kann ich die freigabe sehen aber habe kein schreib zugriff.
                                  Ich habe über den Host in fstab die freigabe eingetragen , über den Host habe ich die schreib und leserechte von der nas aber über die lxc container vo docker und frigate läuft nicht
                                  • Wal
                                    @exitus,
                                    ok da kann ich jetzt nicht helfen.
                                    Ich mache es anders rum, habe eine USB Festplatte als LXC-Backup und Datenspeicher eingerichtet und gebe diese über einen Samba LXC im Netzwerk frei. Damit habe ich Zugriff auf alle Dateien die ich im Proxmox speichere.
                                    • Wal
                                      @exitus ,
                                      schau dir das mal an, könnte helfen.
                                        @wal habe es geschafft jetz anderes problem habe 2 cameras beide machen screenshots dedection klappt bei einen habe ich clips bei den anderen nur bilder ohne clips wo kein clips sind ist die kamera mit der bezeichnung back
                                        ier mein config
                                        database:
                                          path: /media/frigate/db/frigate.db
                                        detectors:
                                          cpu1:
                                            type: cpu
                                        ui:
                                          use_experimental: false
                                          live_mode: mse
                                        mqtt:
                                          host: 172.16.0.10
                                          port: 12345
                                          user: xxxxxxx
                                          password: exxxxx
                                        cameras:
                                          back1:
                                            ffmpeg:
                                              inputs:
                                                - path: rtsp://admin:xxxxx@172.16.0.177:554/channel=2
                                                  roles:
                                                    - detect
                                                    - rtmp
                                                - path: rtsp://admin:xxxxxxx@172.16.0.177:554/channel=1
                                                  roles:
                                                    - record
                                          back:
                                            ffmpeg:
                                              inputs:
                                                - path: rtsp://admin:xxxxxxxx@172.16.0.147:554/Streaming/Channels/102?transportmode=unicast&profile=Profile_2
                                                  roles:
                                                    - detect
                                                    - rtmp
                                                  roles:
                                                    - record
                                        detect:
                                              width: 640
                                              height: 480
                                              fps: 5
                                        objects:
                                              track:
                                                - person
                                                - dog
                                                - bicycle
                                                - cat
                                              filters:
                                                person:
                                                  min_score: 0.7
                                                  threshold: 0.5
                                                  min_area: 700
                                        snapshots:
                                              enabled: true
                                              timestamp: true
                                              bounding_box: true
                                              crop: True
                                              height: 500
                                              retain:
                                                default: 1
                                        record:
                                          enabled: True
                                          events:
                                            retain:
                                              default: 10
                                        birdseye:
                                          enabled: True
                                          mode: continuous
                                        • Wal
                                          @exitus ,
                                          schau mal im Adapter ob das dort eingeschaltet ist.
                                            @wal bei mir steht OFF wo kann man es den einschalten im config ist ja true,
                                            warum ist der eine on und der andere off
                                            176
                                            42694
