    • Negalein
      Negalein Global Moderator @Michael Roling last edited by Negalein
      @michael-roling sagte in Test Adapter telegram-menu v.0.1.x:
      Bei mir geht das, bitte einmal testen
      Konfig konnte wieder geladen werden.
      Aber Menü in Telegram passt nicht zu den Settings im Adapter.
      Scheint so, als nimmt er das Anfangsmenü.
      telegram-menu.0
      2023-05-11 22:25:56.351	debug	Send this to : "Christian"
      telegram-menu.0
      2023-05-11 22:25:56.351	debug	Send this Value : "Eintrag wurde nicht gefunden!"
      telegram-menu.0
      2023-05-11 22:25:56.351	debug	Menu {"Global":{"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"","toggle":true,"confirm":"","returnText":""}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]}},"Christian":{"Startside":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}}
      telegram-menu.0
      2023-05-11 22:25:56.350	debug	Nav {"Startside":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
      telegram-menu.0
      2023-05-11 22:25:56.350	debug	Todo: "Licht"
      telegram-menu.0
      2023-05-11 22:25:56.350	debug	User: "Christian"
      telegram-menu.0
      2023-05-11 22:25:56.350	debug	Value: "[Christian]Licht"
      telegram-menu.0
      2023-05-11 22:24:38.957	debug	Send this to : "Christian"
      telegram-menu.0
      2023-05-11 22:24:38.957	debug	Send this Value : "Wähle eine Aktion"
      telegram-menu.0
      2023-05-11 22:24:38.957	debug	User "Christian"
      telegram-menu.0
      2023-05-11 22:24:38.957	debug	User "Global"
      telegram-menu.0
      2023-05-11 22:24:38.957	debug	UserList ["Global","Christian"]
      telegram-menu.0
      2023-05-11 22:24:38.957	debug	Global User List: ["Christian"]
      telegram-menu.0
      2023-05-11 22:24:38.957	debug	Global User Activ: undefined
      telegram-menu.0
      2023-05-11 22:24:38.957	debug	UserList: ["Global","Christian"]
      telegram-menu.0
      2023-05-11 22:24:38.957	debug	Checkbox []
      telegram-menu.0
      2023-05-11 22:24:38.957	debug	Gen. Actions: {"Startside":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
      telegram-menu.0
      2023-05-11 22:24:38.956	debug	Array Buttons: [{"call":"Startside","value":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}]
      telegram-menu.0
      2023-05-11 22:24:38.956	debug	Name "Christian"
      telegram-menu.0
      2023-05-11 22:24:38.956	debug	SetForeignStates: []
      telegram-menu.0
      2023-05-11 22:24:38.956	debug	Obj set: {"Startside":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
      telegram-menu.0
      2023-05-11 22:24:38.956	debug	action : {"get":[],"set":[],"pic":[]}
      telegram-menu.0
      2023-05-11 22:24:38.956	debug	action pic: []
      telegram-menu.0
      2023-05-11 22:24:38.956	debug	action get: []
      telegram-menu.0
      2023-05-11 22:24:38.956	debug	action set: []
      telegram-menu.0
      2023-05-11 22:24:38.956	debug	New Structure: {"Startside":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
      telegram-menu.0
      2023-05-11 22:24:38.955	debug	Array [["Licht"," Steckdose "],[" Iobroker"," Heizung"]]
      telegram-menu.0
      2023-05-11 22:24:38.955	debug	Gen. Actions: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"","toggle":true,"confirm":"","returnText":""}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]}}
      telegram-menu.0
      2023-05-11 22:24:38.955	debug	Array Buttons: [{"call":"Start","value":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"}]
      telegram-menu.0
      2023-05-11 22:24:38.955	debug	Name "Global"
      telegram-menu.0
      2023-05-11 22:24:38.954	debug	SetForeignStates: ["hue.0.Wintergarten_Strip.on","hs100.0.10_0_1_76.state","hue.0.Wohnzimmer.on","hue.0.Wintergarten.on"]
      telegram-menu.0
      2023-05-11 22:24:38.954	debug	Trigger: ["Aussentemperatur"]
      telegram-menu.0
      2023-05-11 22:24:38.954	debug	Element get: {"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}
      telegram-menu.0
      2023-05-11 22:24:38.954	debug	Obj set: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"","toggle":true,"confirm":"","returnText":""}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"","toggle":true,"confirm":"","returnText":""}]}}
      telegram-menu.0
      2023-05-11 22:24:38.954	debug	Trigger: ["Wintergarten Licht"]
      telegram-menu.0
      2023-05-11 22:24:38.954	debug	Element set: {"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}
      telegram-menu.0
      2023-05-11 22:24:38.954	debug	Trigger: ["Wohnzimmer Licht"]
      telegram-menu.0
      2023-05-11 22:24:38.953	debug	Element set: {"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]}
      telegram-menu.0
      2023-05-11 22:24:38.953	debug	Trigger: ["Pelletsofen"]
      telegram-menu.0
      2023-05-11 22:24:38.953	debug	Element set: {"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]}
      telegram-menu.0
      2023-05-11 22:24:38.953	debug	Trigger: ["Wintergarten Strip"]
      telegram-menu.0
      2023-05-11 22:24:38.953	debug	Element set: {"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]}
      telegram-menu.0
      2023-05-11 22:24:38.953	debug	action : {"get":[{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}],"set":[{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}],"pic":[]}
      telegram-menu.0
      2023-05-11 22:24:38.953	debug	action pic: []
      telegram-menu.0
      2023-05-11 22:24:38.952	debug	action get: [{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}]
      telegram-menu.0
      2023-05-11 22:24:38.952	debug	action set: [{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}]
      telegram-menu.0
      2023-05-11 22:24:38.952	debug	New Structure: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"}}
      telegram-menu.0
      2023-05-11 22:24:38.951	debug	Array [["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]]
      telegram-menu.0
      2023-05-11 22:24:38.951	debug	Action {"Global":{"get":[{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}],"set":[{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}],"pic":[]},"Christian":{"get":[],"set":[],"pic":[]}}
      telegram-menu.0
      2023-05-11 22:24:38.951	debug	Navigation {"Global":[{"call":"Start","value":"Wohnzimmer Licht, Wintergarten Licht, Wintergarten Strip && Pelletsofen, Aussentemperatur, Alexa","text":"Wählen Sie eine Aktion"}],"Christian":[{"call":"Startside","value":"Licht, Steckdose && Iobroker, Heizung","text":"Wähle eine Aktion"}]}
      telegram-menu.0
      2023-05-11 22:24:38.950	info	Telegram was found
      telegram-menu.0
      2023-05-11 22:24:38.504	debug	Datapoint "telegram.0.info.connection"
      telegram-menu.0
      2023-05-11 22:24:38.503	debug	Instance "telegram.0"
      telegram-menu.0
      2023-05-11 22:24:38.488	info	starting. Version 0.1.0 (non-npm: MiRo1310/ioBroker.telegram-menu#67c4a7363af82bdd256256c7b78764b4ddd213bb) in /opt/iobroker/node_modules/iobroker.telegram-menu, node: v16.19.1, js-controller: 4.0.24
      telegram-menu.0
      2023-05-11 22:24:37.546	debug	States connected to redis: 0.0.0.0:9000
      telegram-menu.0
      2023-05-11 22:24:37.036	debug	States create User PubSub Client
      telegram-menu.0
      2023-05-11 22:24:37.035	debug	States create System PubSub Client
      telegram-menu.0
      2023-05-11 22:24:36.973	debug	Redis States: Use Redis connection: 0.0.0.0:9000
      telegram-menu.0
      2023-05-11 22:24:36.918	debug	Objects connected to redis: 0.0.0.0:9001
      telegram-menu.0
      2023-05-11 22:24:36.913	debug	Objects client initialize lua scripts
      telegram-menu.0
      2023-05-11 22:24:36.772	debug	Objects create User PubSub Client
      telegram-menu.0
      2023-05-11 22:24:36.771	debug	Objects create System PubSub Client
      telegram-menu.0
      2023-05-11 22:24:36.770	debug	Objects client ready ... initialize now
      telegram-menu.0
      2023-05-11 22:24:36.704	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
      telegram-menu.0
      2023-05-11 22:24:33.213	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      telegram-menu.0
      2023-05-11 22:24:33.213	info	terminating
      telegram-menu.0
      2023-05-11 22:24:33.212	info	Got terminate signal TERMINATE_YOURSELF
      telegram-menu.0
      2023-05-11 22:22:53.279	debug	Send this to : "Christian"
      telegram-menu.0
      2023-05-11 22:22:53.278	debug	Send this Value : "Wähle eine Aktion"
      telegram-menu.0
      2023-05-11 22:22:53.278	debug	User "Christian"
      telegram-menu.0
      2023-05-11 22:22:53.278	debug	User "Global"
      telegram-menu.0
      2023-05-11 22:22:53.278	debug	UserList ["Global","Christian"]
      telegram-menu.0
      2023-05-11 22:22:53.278	debug	Global User List: ["Christian"]
      telegram-menu.0
      2023-05-11 22:22:53.278	debug	Global User Activ: undefined
      telegram-menu.0
      2023-05-11 22:22:53.278	debug	UserList: ["Global","Christian"]
      telegram-menu.0
      2023-05-11 22:22:53.278	debug	Checkbox []
      telegram-menu.0
      2023-05-11 22:22:53.278	debug	Gen. Actions: {"Startside":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
      telegram-menu.0
      2023-05-11 22:22:53.278	debug	Array Buttons: [{"call":"Startside","value":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}]
      telegram-menu.0
      2023-05-11 22:22:53.277	debug	Name "Christian"
      telegram-menu.0
      2023-05-11 22:22:53.277	debug	SetForeignStates: []
      telegram-menu.0
      2023-05-11 22:22:53.277	debug	Obj set: {"Startside":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
      telegram-menu.0
      2023-05-11 22:22:53.277	debug	action : {"get":[],"set":[],"pic":[]}
      telegram-menu.0
      2023-05-11 22:22:53.277	debug	action pic: []
      telegram-menu.0
      2023-05-11 22:22:53.277	debug	action get: []
      telegram-menu.0
      2023-05-11 22:22:53.277	debug	action set: []
      telegram-menu.0
      2023-05-11 22:22:53.277	debug	New Structure: {"Startside":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
      telegram-menu.0
      2023-05-11 22:22:53.276	debug	Array [["Licht"," Steckdose "],[" Iobroker"," Heizung"]]
      telegram-menu.0
      2023-05-11 22:22:53.276	debug	Gen. Actions: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"","toggle":true,"confirm":"","returnText":""}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]}}
      telegram-menu.0
      2023-05-11 22:22:53.276	debug	Array Buttons: [{"call":"Start","value":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"}]
      telegram-menu.0
      2023-05-11 22:22:53.276	debug	Name "Global"
      telegram-menu.0
      2023-05-11 22:22:53.276	debug	SetForeignStates: ["hue.0.Wintergarten_Strip.on","hs100.0.10_0_1_76.state","hue.0.Wohnzimmer.on","hue.0.Wintergarten.on"]
      telegram-menu.0
      2023-05-11 22:22:53.276	debug	Trigger: ["Aussentemperatur"]
      telegram-menu.0
      2023-05-11 22:22:53.276	debug	Element get: {"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}
      telegram-menu.0
      2023-05-11 22:22:53.275	debug	Obj set: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"","toggle":true,"confirm":"","returnText":""}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"","toggle":true,"confirm":"","returnText":""}]}}
      telegram-menu.0
      2023-05-11 22:22:53.275	debug	Trigger: ["Wintergarten Licht"]
      telegram-menu.0
      2023-05-11 22:22:53.275	debug	Element set: {"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}
      telegram-menu.0
      2023-05-11 22:22:53.275	debug	Trigger: ["Wohnzimmer Licht"]
      telegram-menu.0
      2023-05-11 22:22:53.275	debug	Element set: {"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]}
      telegram-menu.0
      2023-05-11 22:22:53.275	debug	Trigger: ["Pelletsofen"]
      telegram-menu.0
      2023-05-11 22:22:53.275	debug	Element set: {"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]}
      telegram-menu.0
      2023-05-11 22:22:53.274	debug	Trigger: ["Wintergarten Strip"]
      telegram-menu.0
      2023-05-11 22:22:53.274	debug	Element set: {"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]}
      telegram-menu.0
      2023-05-11 22:22:53.274	debug	action : {"get":[{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}],"set":[{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}],"pic":[]}
      telegram-menu.0
      2023-05-11 22:22:53.274	debug	action pic: []
      telegram-menu.0
      2023-05-11 22:22:53.274	debug	action get: [{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}]
      telegram-menu.0
      2023-05-11 22:22:53.273	debug	action set: [{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}]
      telegram-menu.0
      2023-05-11 22:22:53.273	debug	New Structure: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"}}
      telegram-menu.0
      2023-05-11 22:22:53.273	debug	Array [["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]]
      telegram-menu.0
      2023-05-11 22:22:53.273	debug	Action {"Global":{"get":[{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}],"set":[{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}],"pic":[]},"Christian":{"get":[],"set":[],"pic":[]}}
      telegram-menu.0
      2023-05-11 22:22:53.273	debug	Navigation {"Global":[{"call":"Start","value":"Wohnzimmer Licht, Wintergarten Licht, Wintergarten Strip && Pelletsofen, Aussentemperatur, Alexa","text":"Wählen Sie eine Aktion"}],"Christian":[{"call":"Startside","value":"Licht, Steckdose && Iobroker, Heizung","text":"Wähle eine Aktion"}]}
      telegram-menu.0
      2023-05-11 22:22:53.272	info	Telegram was found
      telegram-menu.0
      2023-05-11 22:22:52.819	debug	Datapoint "telegram.0.info.connection"
      telegram-menu.0
      2023-05-11 22:22:52.819	debug	Instance "telegram.0"
      • Michael Roling
        Michael Roling Developer @Negalein last edited by Michael Roling
        @negalein den Adapter hast du aber aktualisiert von Github? Evtl einen Adapter Upload machen.
        Du hast den Globalen Benutzer auch garncht aktiv, zudem solltest du den User Christian deaktivieren oder löschen, so ist klar das er das Menu für Christian schickt
        • frana120500
          frana120500 @Michael Roling last edited by
          @michael-roling und wie ruft man das Menü auf? Wenn ich "Startseite" eintippe pasiert nix. Und was kommt auf dem Navigationstab hinten in Spalte 3 wo steht "Wähle eine Aktion" rein?
          Ich glaube mir fehlt ein Enzym um den Adapter zu verstehen 🙂
          • Negalein
            beides Ja
            Upload bei GitHub sowieso 😉
            Stimmt, hab ich auch verade gesehen.
            Das ist mir erst jetzt aufgefallen, dass er den "globalen User" nicht speichert.
            Ich aktiviere ihn, aber nach "speichern & schließen" ist der Hacken wieder raus.
            telegram-menu.0
            2023-05-12 07:18:30.120	debug	User "Global"
            telegram-menu.0
            2023-05-12 07:18:30.119	debug	UserList ["Global"]
            telegram-menu.0
            2023-05-12 07:18:30.119	debug	Global User List: ["Christian"]
            telegram-menu.0
            2023-05-12 07:18:30.119	debug	Global User Activ: undefined
            telegram-menu.0
            2023-05-12 07:18:30.119	debug	UserList: ["Global"]
            telegram-menu.0
            2023-05-12 07:18:30.119	debug	Checkbox []
            telegram-menu.0
            2023-05-12 07:18:30.119	debug	Gen. Actions: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"","toggle":true,"confirm":"","returnText":""}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]}}
            telegram-menu.0
            2023-05-12 07:18:30.119	debug	Array Buttons: [{"call":"Start","value":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"}]
            telegram-menu.0
            2023-05-12 07:18:30.119	debug	Name "Global"
            telegram-menu.0
            2023-05-12 07:18:30.119	debug	SetForeignStates: ["hue.0.Wintergarten_Strip.on","hs100.0.10_0_1_76.state","hue.0.Wohnzimmer.on","hue.0.Wintergarten.on"]
            telegram-menu.0
            2023-05-12 07:18:30.119	debug	Trigger: ["Aussentemperatur"]
            telegram-menu.0
            2023-05-12 07:18:30.118	debug	Element get: {"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}
            telegram-menu.0
            2023-05-12 07:18:30.118	debug	Obj set: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"","toggle":true,"confirm":"","returnText":""}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"","toggle":true,"confirm":"","returnText":""}]}}
            telegram-menu.0
            2023-05-12 07:18:30.118	debug	Trigger: ["Wintergarten Licht"]
            telegram-menu.0
            2023-05-12 07:18:30.118	debug	Element set: {"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:18:30.118	debug	Trigger: ["Wohnzimmer Licht"]
            telegram-menu.0
            2023-05-12 07:18:30.118	debug	Element set: {"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:18:30.118	debug	Trigger: ["Pelletsofen"]
            telegram-menu.0
            2023-05-12 07:18:30.118	debug	Element set: {"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:18:30.118	debug	Trigger: ["Wintergarten Strip"]
            telegram-menu.0
            2023-05-12 07:18:30.118	debug	Element set: {"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:18:30.117	debug	action : {"get":[{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}],"set":[{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}],"pic":[]}
            telegram-menu.0
            2023-05-12 07:18:30.117	debug	action pic: []
            telegram-menu.0
            2023-05-12 07:18:30.117	debug	action get: [{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}]
            telegram-menu.0
            2023-05-12 07:18:30.117	debug	action set: [{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}]
            telegram-menu.0
            2023-05-12 07:18:30.117	debug	New Structure: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"}}
            telegram-menu.0
            2023-05-12 07:18:30.117	debug	Array [["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]]
            telegram-menu.0
            2023-05-12 07:18:30.116	debug	Action {"Global":{"get":[{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}],"set":[{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}],"pic":[]}}
            telegram-menu.0
            2023-05-12 07:18:30.116	debug	Navigation {"Global":[{"call":"Start","value":"Wohnzimmer Licht, Wintergarten Licht, Wintergarten Strip && Pelletsofen, Aussentemperatur, Alexa","text":"Wählen Sie eine Aktion"}]}
            telegram-menu.0
            2023-05-12 07:18:30.116	info	Telegram was found
            telegram-menu.0
            2023-05-12 07:18:29.668	debug	Datapoint "telegram.0.info.connection"
            telegram-menu.0
            2023-05-12 07:18:29.667	debug	Instance "telegram.0"
            telegram-menu.0
            2023-05-12 07:18:29.653	info	starting. Version 0.1.0 (non-npm: MiRo1310/ioBroker.telegram-menu#67c4a7363af82bdd256256c7b78764b4ddd213bb) in /opt/iobroker/node_modules/iobroker.telegram-menu, node: v16.19.1, js-controller: 4.0.24
            telegram-menu.0
            2023-05-12 07:18:29.125	debug	States connected to redis: 0.0.0.0:9000
            telegram-menu.0
            2023-05-12 07:18:29.050	debug	States create User PubSub Client
            telegram-menu.0
            2023-05-12 07:18:29.049	debug	States create System PubSub Client
            telegram-menu.0
            2023-05-12 07:18:29.005	debug	Redis States: Use Redis connection: 0.0.0.0:9000
            telegram-menu.0
            2023-05-12 07:18:28.961	debug	Objects connected to redis: 0.0.0.0:9001
            telegram-menu.0
            2023-05-12 07:18:28.958	debug	Objects client initialize lua scripts
            telegram-menu.0
            2023-05-12 07:18:28.841	debug	Objects create User PubSub Client
            telegram-menu.0
            2023-05-12 07:18:28.841	debug	Objects create System PubSub Client
            telegram-menu.0
            2023-05-12 07:18:28.840	debug	Objects client ready ... initialize now
            telegram-menu.0
            2023-05-12 07:18:28.767	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
            telegram-menu.0
            2023-05-12 07:18:25.257	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            telegram-menu.0
            2023-05-12 07:18:25.257	info	terminating
            telegram-menu.0
            2023-05-12 07:18:25.256	info	Got terminate signal TERMINATE_YOURSELF
            telegram-menu.0
            2023-05-12 07:17:48.019	debug	User "Global"
            telegram-menu.0
            2023-05-12 07:17:48.019	debug	UserList ["Global"]
            telegram-menu.0
            2023-05-12 07:17:48.019	debug	Global User List: ["Christian"]
            telegram-menu.0
            2023-05-12 07:17:48.019	debug	Global User Activ: undefined
            telegram-menu.0
            2023-05-12 07:17:48.018	debug	UserList: ["Global"]
            telegram-menu.0
            2023-05-12 07:17:48.018	debug	Checkbox []
            telegram-menu.0
            2023-05-12 07:17:48.018	debug	Gen. Actions: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"","toggle":true,"confirm":"","returnText":""}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]}}
            telegram-menu.0
            2023-05-12 07:17:48.018	debug	Array Buttons: [{"call":"Start","value":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"}]
            telegram-menu.0
            2023-05-12 07:17:48.018	debug	Name "Global"
            telegram-menu.0
            2023-05-12 07:17:48.018	debug	SetForeignStates: ["hue.0.Wintergarten_Strip.on","hs100.0.10_0_1_76.state","hue.0.Wohnzimmer.on","hue.0.Wintergarten.on"]
            telegram-menu.0
            2023-05-12 07:17:48.018	debug	Trigger: ["Aussentemperatur"]
            telegram-menu.0
            2023-05-12 07:17:48.017	debug	Element get: {"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}
            telegram-menu.0
            2023-05-12 07:17:48.017	debug	Obj set: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"","toggle":true,"confirm":"","returnText":""}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"","toggle":true,"confirm":"","returnText":""}]}}
            telegram-menu.0
            2023-05-12 07:17:48.017	debug	Trigger: ["Wintergarten Licht"]
            telegram-menu.0
            2023-05-12 07:17:48.017	debug	Element set: {"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:17:48.017	debug	Trigger: ["Wohnzimmer Licht"]
            telegram-menu.0
            2023-05-12 07:17:48.017	debug	Element set: {"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:17:48.017	debug	Trigger: ["Pelletsofen"]
            telegram-menu.0
            2023-05-12 07:17:48.016	debug	Element set: {"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:17:48.016	debug	Trigger: ["Wintergarten Strip"]
            telegram-menu.0
            2023-05-12 07:17:48.016	debug	Element set: {"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:17:48.016	debug	action : {"get":[{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}],"set":[{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}],"pic":[]}
            telegram-menu.0
            2023-05-12 07:17:48.016	debug	action pic: []
            telegram-menu.0
            2023-05-12 07:17:48.016	debug	action get: [{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}]
            telegram-menu.0
            2023-05-12 07:17:48.016	debug	action set: [{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}]
            telegram-menu.0
            2023-05-12 07:17:48.015	debug	New Structure: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"}}
            telegram-menu.0
            2023-05-12 07:17:48.015	debug	Array [["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]]
            telegram-menu.0
            2023-05-12 07:17:48.015	debug	Action {"Global":{"get":[{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}],"set":[{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}],"pic":[]}}
            telegram-menu.0
            2023-05-12 07:17:48.014	debug	Navigation {"Global":[{"call":"Start","value":"Wohnzimmer Licht, Wintergarten Licht, Wintergarten Strip && Pelletsofen, Aussentemperatur, Alexa","text":"Wählen Sie eine Aktion"}]}
            telegram-menu.0
            2023-05-12 07:17:48.014	info	Telegram was found
            telegram-menu.0
            2023-05-12 07:17:47.551	debug	Datapoint "telegram.0.info.connection"
            telegram-menu.0
            2023-05-12 07:17:47.550	debug	Instance "telegram.0"
            telegram-menu.0
            2023-05-12 07:17:47.532	info	starting. Version 0.1.0 (non-npm: MiRo1310/ioBroker.telegram-menu#67c4a7363af82bdd256256c7b78764b4ddd213bb) in /opt/iobroker/node_modules/iobroker.telegram-menu, node: v16.19.1, js-controller: 4.0.24
            telegram-menu.0
            2023-05-12 07:17:47.088	debug	States connected to redis: 0.0.0.0:9000
            telegram-menu.0
            2023-05-12 07:17:46.995	debug	States create User PubSub Client
            telegram-menu.0
            2023-05-12 07:17:46.994	debug	States create System PubSub Client
            telegram-menu.0
            2023-05-12 07:17:46.923	debug	Redis States: Use Redis connection: 0.0.0.0:9000
            telegram-menu.0
            2023-05-12 07:17:46.871	debug	Objects connected to redis: 0.0.0.0:9001
            telegram-menu.0
            2023-05-12 07:17:46.867	debug	Objects client initialize lua scripts
            telegram-menu.0
            2023-05-12 07:17:46.737	debug	Objects create User PubSub Client
            telegram-menu.0
            2023-05-12 07:17:46.736	debug	Objects create System PubSub Client
            telegram-menu.0
            2023-05-12 07:17:46.732	debug	Objects client ready ... initialize now
            telegram-menu.0
            2023-05-12 07:17:46.667	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
            telegram-menu.0
            2023-05-12 07:17:43.196	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            telegram-menu.0
            2023-05-12 07:17:43.196	info	terminating
            telegram-menu.0
            2023-05-12 07:17:43.196	info	Got terminate signal TERMINATE_YOURSELF
            telegram-menu.0
            2023-05-12 07:17:24.414	debug	User "Global"
            telegram-menu.0
            2023-05-12 07:17:24.414	debug	Global User List: ["Christian"]
            telegram-menu.0
            2023-05-12 07:17:24.414	debug	Global User Activ: undefined
            telegram-menu.0
            2023-05-12 07:17:24.413	debug	Checkbox []
            telegram-menu.0
            2023-05-12 07:17:24.413	debug	Array Buttons: [{"call":"Start","value":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"}]
            telegram-menu.0
            2023-05-12 07:17:24.413	debug	SetForeignStates: ["hue.0.Wintergarten_Strip.on","hs100.0.10_0_1_76.state","hue.0.Wohnzimmer.on","hue.0.Wintergarten.on"]
            telegram-menu.0
            2023-05-12 07:17:24.414	debug	UserList ["Global"]
            telegram-menu.0
            2023-05-12 07:17:24.413	debug	Trigger: ["Aussentemperatur"]
            telegram-menu.0
            2023-05-12 07:17:24.412	debug	Obj set: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"","toggle":true,"confirm":"","returnText":""}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"","toggle":true,"confirm":"","returnText":""}]}}
            telegram-menu.0
            2023-05-12 07:17:24.412	debug	Element set: {"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:17:24.412	debug	Element set: {"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:17:24.413	debug	Name "Global"
            telegram-menu.0
            2023-05-12 07:17:24.413	debug	Gen. Actions: {"Start":{"nav":[["Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip "],[" Pelletsofen"," Aussentemperatur"," Alexa"]],"text":"Wählen Sie eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"","toggle":true,"confirm":"","returnText":""}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"","toggle":true,"confirm":"","returnText":""}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]}}
            telegram-menu.0
            2023-05-12 07:17:24.413	debug	UserList: ["Global"]
            telegram-menu.0
            2023-05-12 07:17:24.412	debug	Trigger: ["Pelletsofen"]
            telegram-menu.0
            2023-05-12 07:17:24.411	debug	Trigger: ["Wintergarten Strip"]
            telegram-menu.0
            2023-05-12 07:17:24.411	debug	action : {"get":[{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}],"set":[{"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]},{"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wohnzimmer.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wohnzimmer Licht"],"values":[""],"returnText":[""]},{"IDs":["hue.0.Wintergarten.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Licht"],"values":[""],"returnText":[""]}],"pic":[]}
            telegram-menu.0
            2023-05-12 07:17:24.412	debug	Trigger: ["Wohnzimmer Licht"]
            telegram-menu.0
            2023-05-12 07:17:24.412	debug	Trigger: ["Wintergarten Licht"]
            telegram-menu.0
            2023-05-12 07:17:24.412	debug	Element get: {"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}
            telegram-menu.0
            2023-05-12 07:17:24.411	debug	action pic: []
            telegram-menu.0
            2023-05-12 07:17:24.411	debug	Element set: {"IDs":["hue.0.Wintergarten_Strip.on"],"checkboxes":["true"],"confirm":[""],"trigger":["Wintergarten Strip"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:17:24.411	debug	Element set: {"IDs":["hs100.0.10_0_1_76.state"],"checkboxes":["true"],"confirm":[""],"trigger":["Pelletsofen"],"values":[""],"returnText":[""]}
            telegram-menu.0
            2023-05-12 07:17:24.410	debug	action get: [{"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"checkboxes":["true"],"trigger":["Aussentemperatur"],"text":["Aussentemperatur && °C"]}]
            • Michael Roling
              Michael Roling Developer @frana120500 last edited by
              @frana120500
              Wähle eine Aktion ist erstmal uninteressant. Das ist nur ein beschreibender Text. Wenn das Menu läuft erklärt sich das von alleine.
              Ist dein Adapter denn grün ? Wenn nein , stell in den settings deine Telegram Instanz ein. Der User muss identisch mit dem in Telegramm sein. Dann sollte das Menu automatisch gesendet werden
              frana120500 1 Reply Last reply Reply Quote 0
              • frana120500
                @michael-roling ja, die Instanz ist grün. Was muss ich denn eingeben um das Menü aufzurufen?
                Mein Telegram Script habe ich deaktiviert
                • Michael Roling
                  @frana120500 wenn der User richtig ist und aktiv ist wird das Menu automatisch geschickt
                  • Michael Roling
                    @negalein
                    Ok dann weiß ich wonach ich heute Abend gucken muss.
                    Melde mich
                    • Michael Roling
                      @frana120500
                      Stell mal den Adapter auf debug und sende das log mal
                      • I
                        intruder7 last edited by
                        Guten Morgen,
                        würde den Adapter tatsächlich auch gerne testen, aber bei mir ist so kaum was zu erkennen in der Konfig
                        • Michael Roling
                          Michael Roling Developer @intruder7 last edited by Michael Roling
                          @intruder7 hallo. Ja das liegt am darkmode, müsstest den dafür ausschalten
                          Versuche das aber am Wochenende zu beheben
                          • Michael Roling
                            @negalein so das habe ich gefixt
                            • Negalein
                              Danke, funktioniert wieder 1A
                              • Michael Roling
                                @intruder7 so das problem mit dem Darkmode ist behoben
                                • Michael Roling
                                  Michael Roling Developer @Wszene last edited by
                                  @wszene So das Problem mit dem Darkmode ist behoben, ebenso kannst du in den Rückgabetext einfach an einer Stelle {novalue} rein schreiben, dann bekommst du nicht den gesetzten Wert mit geschickt!
                                    Speedy012 @Michael Roling last edited by
                                    @michael-roling Moin moin, sehr cool der Adapter, vorher über Text to Command mit Skripten war umständlich.
                                    Wäre es möglich unter Navigation eine Sortierfunktion einzubauen?
                                    Also das man die Menüs eine Zeile rauf oder runter schieben kann?
                                    Dann könnte man es etwas übersichtlicher gestalten.
                                    Aber ansonsten TOP das Ding.
                                    • Michael Roling
                                      Michael Roling Developer @Speedy012 last edited by
                                      @speedy012 hi danke.
                                      Ja da habe ich auch schon dran gedacht. Packe ich mit auf die todo Liste.
                                      S Wszene 2 Replies Last reply Reply Quote 1
                                        Speedy012 @Michael Roling last edited by Speedy012
                                        @michael-roling ich habe eben auf der Terrasse gesessen mit Laptop und einiges eingerichtet.
                                        Jetzt sitze ich am Rechner.
                                        Hier werden mir unter Aktion als Auslöser immer nur die Navigations Elemente von Global angezeigt.
                                        Es ist egal welchen User ich vorher anklicke.
                                        Hat sich erledigt, ich habe bei Activ einmal den Haken raus, gespeichert und dann wieder rein.
                                        Jetzt geht es.
                                        • Wszene
                                          Wszene @Michael Roling last edited by
                                          @michael-roling
                                          Vielen Dank
                                          Ich habe mal eine Frage
                                          Wie kann ich ein Update machen?
                                          Da wird mir schon ohne meines Zutuns die Version 0.1.0 angezeigt
                                          Aber ich habe noch immer das Darkmode Problem
                                          PS:
                                          Hast du schon einen Zeitplan wann der Adapter in die Beta-Repo kommt?
                                          Marcel
                                          • Michael Roling
                                            @wszene es gibt auch noch kein neues Release. Einfach über die Katze erneut installieren. Evtl einen Upload machen.
                                            1795
                                            784293
