    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    • Damrak2022
      Damrak2022 @JackDaniel last edited by
      @jackdaniel sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
      https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum.git
      Kann ich die Warnung in Zeile 4 ignorieren?
      $ iobroker url https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum.git --host homebridge --debug
      install iobroker-community-adapters/ioBroker.mihome-vacuum#455cd5c28dcb82630ba05e289eb999d11b669ae5
      NPM version: 9.5.1Installing iobroker-community-adapters/ioBroker.mihome-vacuum#455cd5c28dcb82630ba05e289eb999d11b669ae5... (System call)
      npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.mihome-vacuum.git
      upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
      upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
      upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
      upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
      Update "system.adapter.mihome-vacuum.0"
      Process exited with code 0
        A Former User @tombox last edited by A Former User
        @tombox
        Guten Morgen, leider ist heute die Karte nicht mehr in der App sichtbar, laedt auch keine in den Adapter, also keine Entwarnung mit der Git-Version.
        Einstellungen im Adapter:
        mihome-vacuum-debuglog.txt
          tombox @Guest last edited by
          @ilovegym Achso die option "enable map" muss deaktiviert sein
            @tombox sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
            hab ich jetzt mal gemacht.. heute laufen die Sauger wieder ... mal schauen, wann es wieder funktioniert...
            • Damrak2022
              Damrak2022 @Guest last edited by
              @ilovegym Nur mal zur Info:
              Ich habe die Map mal aktiviert gelassen und mit der Github Version wird mir die Karte heute ausnahmsweise mal in der App angezeigt und ich kann den Weg des Staubsaugers verfolgen. Allerdings funktioniert die Anzeige des Weges nicht am Rechner, was sonst immer ging.
                @ilovegym Ich habe nochmal was angepasst was den load reduziert auch wenn man die karte abfragt ist die frage ob die karte immer noch immer aktuell ist mit der aktuellen github version
                  @tombox
                  Bisher war es so, dass die Karte nach einem Reinigungsvorgang nicht mehr abrufbar war. Ich habe die letzten Tage daher den Adapter gestoppt, mein startscript so angepasst, dass erst der Adapter gestartet wird, dann der Sauger, und nach dem Saugvorgang der Adapter gestoppt wird..
                  So hatte ich eine aktuelle Karte.
                  Ich teste morgen mal die aktuelle Gitversion, mal schauen..
                    @ilovegym Die GitHub version funktioniert bei mir auch mit aktivierter karte.. wie sieht es bei dir aus
                    ? T 3 Replies Last reply Reply Quote 0
                      @tombox
                      Danke erstmal!
                      Hab gestern erst installiert, und vergessen mein startscript zu ändern, daher lief der Adapter nur wenn der Sauger aktiv war. Das hat soweit geklappt, Karte war da.
                      Hab seit eben den Adapter wieder immer laufen, mal sehen ob morgen früh die Karte noch da ist…
                        @tombox
                        nach 18 Stunden test und ein paar Reinigungsvorgaengen kann ich sagen, dass die Karte wieder geladen wird.
                        Auch in der App ist die Karte noch da.
                        Schaut also gut aus! Danke!
                          Tschaeens @tombox last edited by
                          @tombox
                          Welche Abfrageintervalle habt ihr denn im Adapter eingestellt?
                            tombox @Tschaeens last edited by
                            @tschaeens Ich habe eine 3.11.0 veröffentlich rein theoretisch ist keine Anpassung des Intervals notwendig
                              dirkhe Developer @tombox last edited by
                              @tombox Die Anpassung war so aber nicht richtig.
                              Du hast an der stelle, wo regrlmässig der allhemeine status abgefragt, jetzt zusätzlich die karte abgefragt.
                              Das !this.mapEnable bezog sich darauf, wenn nicht eh schon abgefragt wird, meine ich.
                              Also, wenn karte anabled, wird der mabpointer eh regelmässig abgefragt, wenn nicht, wird er nur ab und zu im zuge des allgemeinen status abgefragt. Ich meine, dass wird dafür gemacht, wenn du keine karte willst, so wie ich, dann bekommt man aber trotzdem mit, wenn die karte sich ändert, zb bei stockwerkswechsel.
                              Bitte baue das mal wieder zurück.
                                A Former User @dirkhe last edited by
                                @dirkhe @tombox
                                Zum Code kann ich nicht viel sagen, so genau versteh ich das nicht. Aber ich kann sagen, dass die letzte Gitversion (3.11) einwandfrei laeuft und die Karte immer geholt werden kann.
                                In der letzten Release 3.10.1 hatte es ja dazu gefuehrt, dass die Karte nach einem Saugvorgang +- 2h Adapterlaufzeit nicht mehr geladen werden konnte.. jetzt funktioniert das wieder.
                                  dirkhe Developer @Guest last edited by
                                  @ilovegym ich kann mir das ja nochmal genauer ansehen, so werden aber die Leute Probleme bekommen, die keine Karte nutzen.
                                  Normalerweise wird die Karte halt aktualisiert, wenn er saugt..
                                  Ich schaue die Tage Mal rein
                                  T ? 2 Replies Last reply Reply Quote 0
                                    tombox @dirkhe last edited by
                                    @dirkhe Da der Mappointer zu oft geholt wurde egal ob Karte aktiv ist oder nicht hat es zur einer Sperrung der Karte in der App geführt. Die Karte in der App ist glaube wichtiger für den Nutzer als in ioBroker zu sehen ob ein Stockwerkwechsel stattgefunden hat.
                                      @tombox ja, aber wenn jetzt einer die karte an an hat, wird sie noch öfter abgerufen. Die lösung wäre dann eher, die karte seltener abzurufen.
                                        @dirkhe Ja während eines Reinigungsvorgang wird sie zusätzlich noch alle 15min abgerufen. dazu müsste man wissen was das neue rate limit für map Abruf. so ist es erstmal für user die karte aktiviert haben wird es während des reinigen aktualisiert
                                        Damrak2022 D 2 Replies Last reply Reply Quote 0
                                        • Damrak2022
                                          Damrak2022 @tombox last edited by Damrak2022
                                          @tombox Ich habe ebenfalls die neueste Github Version installiert und kann den Sauger über das Dashboard starten. In der App wird mir auch die Karte und auch der Weg des Saugers angezeigt, allerdings nicht im Dashboard, was ich genauso eingebunden habe, wie es mir @bahnuhr erklärt hatte.
                                          https://forum.iobroker.net/post/747066
                                          Bevor es die Probleme gab, hat es so auch reibungslos funktioniert. Nur jetzt wird mir die Fahrt des Saugers nicht im Dashboard angezeigt.
                                            tombox @Damrak2022 last edited by
                                            @damrak2022 Meinst du die ganze karte oder nur die fahrt
                                            1198
                                            366471
