    4. Test Adapter maveo v.0.0.x
    • N
      Nicky_86 @tombox last edited by
      @tombox
      Danke für deine Antwort.
      Habe ich jetzt neu installiert.
      Beim installieren ist mir neides mal aufgefallen, das nach dem:
      Installing TA2k/ioBroker.maveo#6d05add6ad8c70dafbc7d1f010beed7acb28c68d... (System call)
      relativ viel Zeit vergeht (bestimmt5 min), bis es mal weiter läuft. (Falls sowas relevant ist)
      Mein Problem besteht aber leider weiterhin:
      maveo.0
      2022-08-25 18:50:35.062 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
      maveo.0
      2022-08-25 18:50:35.060 info terminating
      maveo.0
      2022-08-25 18:50:35.026 error Cannot read property 'SessionToken' of undefined
      maveo.0
      2022-08-25 18:50:35.025 error TypeError: Cannot read property 'SessionToken' of undefined at Maveo.connectToWS (/opt/iobroker/node_modules/iobroker.maveo/main.js:199:62) at Maveo.onReady (/opt/iobroker/node_modules/iobroker.maveo/main.js:56:24)
      maveo.0
      2022-08-25 18:50:35.014 error unhandled promise rejection: Cannot read property 'SessionToken' of undefined
      maveo.0
      2022-08-25 18:50:35.013 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      maveo.0
      2022-08-25 18:50:34.050 error {"__type":"com.amazonaws.cognito.identity.model#NotAuthorizedException","message":"Logins don't match. Please include at least one valid login for this identity or identity pool."}
      maveo.0
      2022-08-25 18:50:34.049 error AxiosError: Request failed with status code 400
      maveo.0
      2022-08-25 18:50:31.523 info starting. Version 0.0.4 (non-npm: TA2k/ioBroker.maveo#6d05add6ad8c70dafbc7d1f010beed7acb28c68d) in /opt/iobroker/node_modules/iobroker.maveo, node: v14.19.3, js-controller: 4.0.23
      maveo.0
      2022-08-25 18:49:57.612 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
      maveo.0
      2022-08-25 18:49:57.608 info terminating
      maveo.0
      2022-08-25 18:49:57.558 error Cannot read property 'SessionToken' of undefined
      maveo.0
      2022-08-25 18:49:57.557 error TypeError: Cannot read property 'SessionToken' of undefined at Maveo.connectToWS (/opt/iobroker/node_modules/iobroker.maveo/main.js:199:62) at Maveo.onReady (/opt/iobroker/node_modules/iobroker.maveo/main.js:56:24)
      maveo.0
      2022-08-25 18:49:57.547 error unhandled promise rejection: Cannot read property 'SessionToken' of undefined
      maveo.0
      2022-08-25 18:49:57.545 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      maveo.0
      2022-08-25 18:49:56.679 error {"__type":"com.amazonaws.cognito.identity.model#NotAuthorizedException","message":"Logins don't match. Please include at least one valid login for this identity or identity pool."}
      maveo.0
      2022-08-25 18:49:56.678 error AxiosError: Request failed with status code 400
      maveo.0
      2022-08-25 18:49:54.219 info starting. Version 0.0.4 (non-npm: TA2k/ioBroker.maveo#6d05add6ad8c70dafbc7d1f010beed7acb28c68d) in /opt/iobroker/node_modules/iobroker.maveo, node: v14.19.3, js-controller: 4.0.23
      maveo.0
      2022-08-25 18:49:20.146 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
      maveo.0
      2022-08-25 18:49:20.143 info terminating
      maveo.0
      2022-08-25 18:49:20.108 error Cannot read property 'SessionToken' of undefined
      maveo.0
      2022-08-25 18:49:20.107 error TypeError: Cannot read property 'SessionToken' of undefined at Maveo.connectToWS (/opt/iobroker/node_modules/iobroker.maveo/main.js:199:62) at Maveo.onReady (/opt/iobroker/node_modules/iobroker.maveo/main.js:56:24)
      maveo.0
      2022-08-25 18:49:20.097 error unhandled promise rejection: Cannot read property 'SessionToken' of undefined
      maveo.0
      2022-08-25 18:49:20.095 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      maveo.0
      2022-08-25 18:49:19.130 error {"__type":"com.amazonaws.cognito.identity.model#NotAuthorizedException","message":"Logins don't match. Please include at least one valid login for this identity or identity pool."}
      maveo.0
      2022-08-25 18:49:19.129 error AxiosError: Request failed with status code 400
      maveo.0
      2022-08-25 18:49:16.542 info starting. Version 0.0.4 (non-npm: TA2k/ioBroker.maveo#6d05add6ad8c70dafbc7d1f010beed7acb28c68d) in /opt/iobroker/node_modules/iobroker.maveo, node: v14.19.3, js-controller: 4.0.23
        tombox @Nicky_86 last edited by
        @nicky_86 Die lange Installation liegt an nodejs 14 und npm 6
        Ich brauch dann Zugangsdaten um das zu fixen, am besten via PN
        R N 2 Replies Last reply Reply Quote 0
          Rushmed Most Active @tombox last edited by Rushmed
          @tombox Bei mir wird die Instanz auch nur ultrakurtz grün und dann wieder rot.
          host.Smartazamba
          2022-08-25 23:44:19.006	info	Restart adapter system.adapter.maveo.0 because enabled
          host.Smartazamba
          2022-08-25 23:44:19.006	error	instance system.adapter.maveo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          host.Smartazamba
          2022-08-25 23:44:19.005	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
          host.Smartazamba
          2022-08-25 23:44:19.005	error	Caught by controller[1]: at Maveo.onReady (/opt/iobroker/node_modules/iobroker.maveo/main.js:56:24)
          host.Smartazamba
          2022-08-25 23:44:19.005	error	Caught by controller[1]: at Maveo.connectToWS (/opt/iobroker/node_modules/iobroker.maveo/main.js:199:62)
          host.Smartazamba
          2022-08-25 23:44:19.005	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'SessionToken')
          host.Smartazamba
          2022-08-25 23:44:19.005	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          maveo.0
          2022-08-25 23:44:18.373	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          maveo.0
          2022-08-25 23:44:18.369	info	terminating
          maveo.0
          2022-08-25 23:44:18.348	error	Cannot read properties of undefined (reading 'SessionToken')
          maveo.0
          2022-08-25 23:44:18.348	error	TypeError: Cannot read properties of undefined (reading 'SessionToken') at Maveo.connectToWS (/opt/iobroker/node_modules/iobroker.maveo/main.js:199:62) at Maveo.onReady (/opt/iobroker/node_modules/iobroker.maveo/main.js:56:24) at processTicksAndRejections (node:internal/process/task_queues:96:5)
          maveo.0
          2022-08-25 23:44:18.343	error	unhandled promise rejection: Cannot read properties of undefined (reading 'SessionToken')
          maveo.0
          2022-08-25 23:44:18.341	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          maveo.0
          2022-08-25 23:44:17.699	error	{"__type":"com.amazonaws.cognito.identity.model#NotAuthorizedException","message":"Logins don't match. Please include at least one valid login for this identity or identity pool."}
          maveo.0
          2022-08-25 23:44:17.698	error	AxiosError: Request failed with status code 400
          maveo.0
          2022-08-25 23:44:15.767	info	starting. Version 0.0.4 (non-npm: TA2k/ioBroker.maveo#6d05add6ad8c70dafbc7d1f010beed7acb28c68d) in /opt/iobroker/node_modules/iobroker.maveo, node: v16.17.0, js-controller: 4.0.23
          host.Smartazamba
          2022-08-25 23:44:13.466	info	instance system.adapter.maveo.0 started with pid 127007
          smartmeter.0
          2022-08-25 23:43:48.061	info	(COMPACT) Received 4 values, 2 updated
          host.Smartazamba
          2022-08-25 23:43:43.338	info	Restart adapter system.adapter.maveo.0 because enabled
          host.Smartazamba
          2022-08-25 23:43:43.338	error	instance system.adapter.maveo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          host.Smartazamba
          2022-08-25 23:43:43.338	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:96:5)
          host.Smartazamba
          2022-08-25 23:43:43.338	error	Caught by controller[0]: at Maveo.onReady (/opt/iobroker/node_modules/iobroker.maveo/main.js:56:24)
          host.Smartazamba
          2022-08-25 23:43:43.337	error	Caught by controller[0]: at Maveo.connectToWS (/opt/iobroker/node_modules/iobroker.maveo/main.js:199:62)
          host.Smartazamba
          2022-08-25 23:43:43.337	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'SessionToken')
          host.Smartazamba
          2022-08-25 23:43:43.337	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          maveo.0
          2022-08-25 23:43:42.723	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          maveo.0
          2022-08-25 23:43:42.719	info	terminating
          maveo.0
          2022-08-25 23:43:42.688	error	Cannot read properties of undefined (reading 'SessionToken')
          maveo.0
          2022-08-25 23:43:42.687	error	TypeError: Cannot read properties of undefined (reading 'SessionToken') at Maveo.connectToWS (/opt/iobroker/node_modules/iobroker.maveo/main.js:199:62) at Maveo.onReady (/opt/iobroker/node_modules/iobroker.maveo/main.js:56:24) at processTicksAndRejections (node:internal/process/task_queues:96:5)
          maveo.0
          2022-08-25 23:43:42.682	error	unhandled promise rejection: Cannot read properties of undefined (reading 'SessionToken')
          maveo.0
          2022-08-25 23:43:42.681	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          maveo.0
          2022-08-25 23:43:41.997	error	{"__type":"com.amazonaws.cognito.identity.model#NotAuthorizedException","message":"Logins don't match. Please include at least one valid login for this identity or identity pool."}
          maveo.0
          2022-08-25 23:43:41.996	error	AxiosError: Request failed with status code 400
          maveo.0
          2022-08-25 23:43:40.032	info	starting. Version 0.0.4 (non-npm: TA2k/ioBroker.maveo#6d05add6ad8c70dafbc7d1f010beed7acb28c68d) in /opt/iobroker/node_modules/iobroker.maveo, node: v16.17.0, js-controller: 4.0.23
          host.Smartazamba
          2022-08-25 23:43:37.323	info	instance system.adapter.maveo.0 started with pid 126641
          Steuer kann ich meine Antrieb wie hier beschrieben.
            Rushmed Most Active last edited by
            Hier ist eine Lösung zur Integration des Torantriebs ohne Cloud.
            • N
              @tombox
              Hatte das Thema ganz verdrängt 🙂
              Habe gerade gesehen das es eine neue Version gibt.
              Habe diese Installiert aber komme nicht weiter.
              Soll ich dir die Maveo Zugangsdaten zuschicken oder wie?
              Hier der LOG
              host.raspberrypi
              2022-10-11 17:38:24.107 warn Do not restart adapter system.adapter.maveo.0 because restart loop detected
              host.raspberrypi
              2022-10-11 17:38:24.107 info Restart adapter system.adapter.maveo.0 because enabled
              host.raspberrypi
              2022-10-11 17:38:24.106 error instance system.adapter.maveo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              host.raspberrypi
              2022-10-11 17:38:24.106 error Caught by controller[1]: at Maveo.onReady (/opt/iobroker/node_modules/iobroker.maveo/main.js:56:18)
              host.raspberrypi
              2022-10-11 17:38:24.106 error Caught by controller[1]: at Maveo.connectToWS (/opt/iobroker/node_modules/iobroker.maveo/main.js:199:56)
              host.raspberrypi
              2022-10-11 17:38:24.105 error Caught by controller[1]: TypeError: Cannot read property 'SessionToken' of undefined
              host.raspberrypi
              2022-10-11 17:38:24.104 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
              maveo.0
              2022-10-11 17:38:23.226 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
              maveo.0
              2022-10-11 17:38:23.223 info terminating
              maveo.0
              2022-10-11 17:38:23.201 error Cannot read property 'SessionToken' of undefined
              maveo.0
              2022-10-11 17:38:23.201 error TypeError: Cannot read property 'SessionToken' of undefined at Maveo.connectToWS (/opt/iobroker/node_modules/iobroker.maveo/main.js:199:56) at Maveo.onReady (/opt/iobroker/node_modules/iobroker.maveo/main.js:56:18)
              maveo.0
              2022-10-11 17:38:23.195 error unhandled promise rejection: Cannot read property 'SessionToken' of undefined
              maveo.0
              2022-10-11 17:38:23.194 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              maveo.0
              2022-10-11 17:38:22.210 error {"__type":"com.amazonaws.cognito.identity.model#NotAuthorizedException","message":"Logins don't match. Please include at least one valid login for this identity or identity pool."}
              maveo.0
              2022-10-11 17:38:22.209 error AxiosError: Request failed with status code 400
              maveo.0
              2022-10-11 17:38:19.776 info starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.maveo, node: v14.19.3, js-controller: 4.0.23
                @nicky_86 Ja wäre sinnvoll sonst kann ich das nicht beheben
                • Q
                  QBJack @tombox last edited by
                  @tombox Ich habe auch großes Interesse meine MaveoBox im IOB zu integrieren und könnte mit meinem Login zwecks Fehlerbehebung aushelfen.
                  Brauchst du noch Login Daten oder hast du bereits welche zum Testen bekommen?
                  Thomas
                    tombox @QBJack last edited by
                    @qbjack ja brauch ich nochmal
                    tombox2020@gmail.com
                      sandmann55 @tombox last edited by
                      Hallo
                      zusammen bei mir kommt schon trotz koreter Zugangsdaten
                      maveo.0
                      2023-05-13 12:35:55.567 error User does not exist.
                      getestet mit 0.0.5 und 0.0.4
                        tombox @sandmann55 last edited by
                        @sandmann55 Ja aufgrund von Änderung kann der Adapter nicht funktionieren. Es scheint so als müsste man nach jeder Neuinstallation der app die box hinzufügen was für den Adapter nicht möglich ist
                        1330
