    3. Einsteigerfragen
    4. Installation
    5. Docker Installation lädt admin Adapter nicht
      ferrog last edited by ferrog
      Ah, danke für den Hinweis, so schnell war ich noch nicht 🙂
      date	stream	content
      2023-05-13T15:32:52.953478109Z	stdout	================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      2023-05-13T15:32:52.951376295Z	stdout	^C================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
      2023-05-13T15:25:14.016070880Z	stdout	object system.meta.uuid created: 2455fa73-f1b5-45d3-a7c3-63861317ecdd
      2023-05-13T15:25:13.873186808Z	stdout	host.buanet-iobroker2 check instance "system.adapter.backitup.0" for host "buanet-iobroker2"
      2023-05-13T15:25:13.872639577Z	stdout	host.buanet-iobroker2 check instance "system.adapter.discovery.0" for host "buanet-iobroker2"
      2023-05-13T15:25:13.871644005Z	stdout	host.buanet-iobroker2 check instance "system.adapter.admin.0" for host "buanet-iobroker2"
      2023-05-13T15:25:12.885734845Z	stdout	##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
      2023-05-13T15:25:12.885710665Z	stdout
      2023-05-13T15:25:12.885674105Z	stdout	Starting ioBroker...
      2023-05-13T15:25:12.885631265Z	stdout
      2023-05-13T15:25:12.885495325Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:25:12.885119304Z	stdout	-----                    Step 5 of 5: ioBroker startup                     -----
      2023-05-13T15:25:12.885003154Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:25:12.863747636Z	stdout
      2023-05-13T15:25:12.863718906Z	stdout	For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
      2023-05-13T15:25:12.863688986Z	stdout	Some adapters have special requirements/ settings which can be activated by the use of environment variables.
      2023-05-13T15:25:12.863676746Z	stdout
      2023-05-13T15:25:12.863663166Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:25:12.863638556Z	stdout	-----                Step 4 of 5: Applying special settings                -----
      2023-05-13T15:25:12.863578356Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:25:12.862921955Z	stdout
      2023-05-13T15:25:12.862887165Z	stdout	[DEBUG] Controller "js-controller": 4.0.24   , installed 4.0.24
      2023-05-13T15:25:12.862858775Z	stdout	[DEBUG] Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      2023-05-13T15:25:12.862828765Z	stdout	[DEBUG] Adapter    "backitup"     : 2.6.19   , installed 2.5.12 [Updatable]
      2023-05-13T15:25:12.862799485Z	stdout	[DEBUG] Adapter    "admin"        : 6.3.5    , installed 6.3.5
      2023-05-13T15:25:12.862773995Z	stdout	[DEBUG] Used repository: stable
      2023-05-13T15:25:12.862749505Z	stdout	[DEBUG] ##### iobroker update #####
      2023-05-13T15:25:12.862729484Z	stdout
      2023-05-13T15:25:12.862701684Z	stdout	[DEBUG] Active repo(s): stable
      2023-05-13T15:25:12.862670724Z	stdout	[DEBUG] beta          : http://download.iobroker.net/sources-dist-latest.json
      2023-05-13T15:25:12.862636454Z	stdout	[DEBUG] stable        : http://download.iobroker.net/sources-dist.json
      2023-05-13T15:25:12.862612164Z	stdout	[DEBUG] ##### iobroker repo list #####
      2023-05-13T15:25:12.862592184Z	stdout
      2023-05-13T15:25:12.862569744Z	stdout	[DEBUG] + instance is alive
      2023-05-13T15:25:12.862541924Z	stdout	[DEBUG]   system.adapter.discovery.0              : discovery             : buanet-iobroker2                         -  enabled
      2023-05-13T15:25:12.862486514Z	stdout	[DEBUG]   system.adapter.backitup.0               : backitup              : buanet-iobroker2                         -  enabled
      2023-05-13T15:25:12.862402534Z	stdout	[DEBUG]   system.adapter.admin.0                  : admin                 : buanet-iobroker2                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      2023-05-13T15:25:12.861993163Z	stdout	[DEBUG] ##### iobroker list instances #####
      2023-05-13T15:24:35.351481749Z	stdout
      2023-05-13T15:24:35.351437549Z	stdout	[DEBUG] Collecting some more ioBroker debug information...
      2023-05-13T15:24:35.351400429Z	stdout
      2023-05-13T15:24:35.351254228Z	stdout	Done.
      2023-05-13T15:24:34.296632848Z	stdout	The host for instance "system.adapter.backitup.0" was changed from "buildkitsandbox" to "buanet-iobroker2".
      2023-05-13T15:24:34.293870473Z	stdout	The host for instance "system.adapter.discovery.0" was changed from "buildkitsandbox" to "buanet-iobroker2".
      2023-05-13T15:24:34.291511069Z	stdout	Updating hostname to buanet-iobroker2... The host for instance "system.adapter.admin.0" was changed from "buildkitsandbox" to "buanet-iobroker2".
      2023-05-13T15:24:23.670925705Z	stdout	Hostname in ioBroker does not match the hostname of this container.
      2023-05-13T15:24:23.651354941Z	stdout	[DEBUG] Detected admin hostname is: buildkitsandbox
      2023-05-13T15:24:11.916925702Z	stdout	[DEBUG] Detected admin instance is: system.adapter.admin.0
      2023-05-13T15:23:59.709060798Z	stdout
      2023-05-13T15:23:59.708923477Z	stdout	Fixing "sudo-bug" by replacing sudo with gosu... Done.
      2023-05-13T15:23:59.667966876Z	stdout
      2023-05-13T15:23:59.667822836Z	stdout	(Re)setting permissions (This might take a while! Please be patient!)... Done.
      2023-05-13T15:23:59.531726558Z	stdout
      2023-05-13T15:23:59.531662318Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:23:59.530993197Z	stdout	-----             Step 3 of 5: Checking ioBroker installation              -----
      2023-05-13T15:23:59.530909387Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:23:59.530000305Z	stdout
      2023-05-13T15:23:59.513679577Z	stdout	Restoring initial ioBroker installation... Done.
      2023-05-13T15:23:56.717911702Z	stdout	There is no data detected in /opt/iobroker.
      2023-05-13T15:23:56.706139421Z	stdout
      2023-05-13T15:23:56.706083651Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:23:56.705794520Z	stdout	-----             Step 2 of 5: Detecting ioBroker installation             -----
      2023-05-13T15:23:56.705664130Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:23:56.689471592Z	stdout
      2023-05-13T15:23:56.689392942Z	stdout	Registering maintenance script as command... Done.
      2023-05-13T15:23:56.655369463Z	stdout
      2023-05-13T15:23:56.655071742Z	stdout	Done.
      2023-05-13T15:23:54.017545455Z	stdout	Processing triggers for libc-bin (2.31-13+deb11u6) ...
      2023-05-13T15:23:53.560723389Z	stdout	Setting up libavahi-compat-libdnssd-dev:amd64 (0.8-5+deb11u2) ...
      2023-05-13T15:23:53.222322029Z	stdout	Setting up libavahi-compat-libdnssd1:amd64 (0.8-5+deb11u2) ...
      2023-05-13T15:23:52.816860412Z	stdout	Setting up libavahi-client-dev:amd64 (0.8-5+deb11u2) ...
      2023-05-13T15:23:52.469275527Z	stdout	Setting up libavahi-client3:amd64 (0.8-5+deb11u2) ...
      2023-05-13T15:23:52.112847117Z	stdout	Setting up libc6-dev:amd64 (2.31-13+deb11u6) ...
      2023-05-13T15:23:51.762127415Z	stdout	Setting up libavahi-common-dev:amd64 (0.8-5+deb11u2) ...
      2023-05-13T15:23:51.206654268Z	stdout	Setting up git (1:2.30.2-1+deb11u2) ...
      2023-05-13T15:23:50.879717369Z	stdout	Setting up libavahi-common3:amd64 (0.8-5+deb11u2) ...
      2023-05-13T15:23:50.543579773Z	stdout	Setting up libc-devtools (2.31-13+deb11u6) ...
      2023-05-13T15:23:50.194256835Z	stdout	Setting up libxml2:amd64 (2.9.10+dfsg-6.7+deb11u4) ...
      2023-05-13T15:23:49.578313322Z	stdout	Setting up libc-dev-bin (2.31-13+deb11u6) ...
      2023-05-13T15:23:49.257868804Z	stdout	Setting up curl (7.74.0-1.3+deb11u7) ...
      2023-05-13T15:23:48.952464192Z	stdout	Setting up libtiff5:amd64 (4.2.0-1+deb11u4) ...
      2023-05-13T15:23:48.664435271Z	stdout	Setting up git-man (1:2.30.2-1+deb11u2) ...
      2023-05-13T15:23:48.346790998Z	stdout	Setting up libcurl4:amd64 (7.74.0-1.3+deb11u7) ...
      2023-05-13T15:23:48.038048570Z	stdout	Setting up libncursesw6:amd64 (6.2+20201114-2+deb11u1) ...
      2023-05-13T15:23:47.740104442Z	stdout	Setting up libudev-dev:amd64 (247.3-7+deb11u2) ...
      2023-05-13T15:23:47.381739608Z	stdout	invoke-rc.d: policy-rc.d denied execution of restart.
      2023-05-13T15:23:47.379350224Z	stdout	invoke-rc.d: could not determine current runlevel
      2023-05-13T15:23:46.305426125Z	stdout	Setting up udev (247.3-7+deb11u2) ...
      2023-05-13T15:23:45.969393350Z	stdout	Setting up libncurses6:amd64 (6.2+20201114-2+deb11u1) ...
      2023-05-13T15:23:45.493878933Z	stdout	Setting up libavahi-common-data:amd64 (0.8-5+deb11u2) ...
      2023-05-13T15:23:45.243521647Z	stdout
      2023-05-13T15:23:45.243435537Z	stdout	Run 'dpkg-reconfigure tzdata' if you wish to change it.
      2023-05-13T15:23:45.243208296Z	stdout	Universal Time is now:  Sat May 13 15:23:45 UTC 2023.
      2023-05-13T15:23:45.243070666Z	stdout	Local time is now:      Sat May 13 15:23:45 UTC 2023.
      2023-05-13T15:23:45.234665701Z	stdout	Current default time zone: 'Etc/UTC'
      2023-05-13T15:23:45.234507971Z	stdout
      2023-05-13T15:23:44.731440016Z	stdout	Setting up tzdata (2021a-1+deb11u10) ...
      2023-05-13T15:23:44.370955739Z	stdout	Setting up nodejs (16.20.0-deb-1nodesource1) ...
      2023-05-13T15:23:44.161156794Z	stdout	Generation complete.
      2023-05-13T15:23:44.158606129Z	stdout	  en_US.UTF-8... done
      2023-05-13T15:23:42.828299985Z	stdout	  de_DE.UTF-8... done
      2023-05-13T15:23:41.368858257Z	stdout	Generating locales (this might take a while)...
      2023-05-13T15:23:40.345553758Z	stdout	Setting up locales (2.31-13+deb11u6) ...
      2023-05-13T15:23:40.011193947Z	stdout	Setting up libcurl3-gnutls:amd64 (7.74.0-1.3+deb11u7) ...
      2023-05-13T15:23:39.613823236Z	stdout	Setting up linux-libc-dev:amd64 (5.10.179-1) ...
      2023-05-13T15:23:39.244771264Z	stdout	Setting up libxpm4:amd64 (1:3.5.12-1.1~deb11u1) ...
      2023-05-13T15:23:38.764508980Z	stdout	Setting up libc-l10n (2.31-13+deb11u6) ...
      2023-05-13T15:23:34.235898022Z	stdout	Unpacking nodejs (16.20.0-deb-1nodesource1) over (16.19.0-deb-1nodesource1) ...
      2023-05-13T15:23:33.901396881Z	stdout	Preparing to unpack .../18-nodejs_16.20.0-deb-1nodesource1_amd64.deb ...
      2023-05-13T15:23:33.064632838Z	stdout	Unpacking libxpm4:amd64 (1:3.5.12-1.1~deb11u1) over (1:3.5.12-1) ...
      2023-05-13T15:23:32.647313973Z	stdout	Preparing to unpack .../17-libxpm4_1%3a3.5.12-1.1~deb11u1_amd64.deb ...
      2023-05-13T15:23:31.780726599Z	stdout	Unpacking libxml2:amd64 (2.9.10+dfsg-6.7+deb11u4) over (2.9.10+dfsg-6.7+deb11u3) ...
      2023-05-13T15:23:31.316380083Z	stdout	Preparing to unpack .../16-libxml2_2.9.10+dfsg-6.7+deb11u4_amd64.deb ...
      2023-05-13T15:23:30.453658685Z	stdout	Unpacking libtiff5:amd64 (4.2.0-1+deb11u4) over (4.2.0-1+deb11u3) ...
      2023-05-13T15:23:30.026159363Z	stdout	Preparing to unpack .../15-libtiff5_4.2.0-1+deb11u4_amd64.deb ...
      2023-05-13T15:23:28.908873204Z	stdout	Unpacking libavahi-common-data:amd64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      2023-05-13T15:23:28.561414982Z	stdout	Preparing to unpack .../14-libavahi-common-data_0.8-5+deb11u2_amd64.deb ...
      2023-05-13T15:23:27.808324495Z	stdout	Unpacking libavahi-common3:amd64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      2023-05-13T15:23:27.340207083Z	stdout	Preparing to unpack .../13-libavahi-common3_0.8-5+deb11u2_amd64.deb ...
      2023-05-13T15:23:26.527165733Z	stdout	Unpacking libavahi-client3:amd64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      2023-05-13T15:23:26.171722236Z	stdout	Preparing to unpack .../12-libavahi-client3_0.8-5+deb11u2_amd64.deb ...
      2023-05-13T15:23:25.265792545Z	stdout	Unpacking libavahi-compat-libdnssd1:amd64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      2023-05-13T15:23:24.881012708Z	stdout	Preparing to unpack .../11-libavahi-compat-libdnssd1_0.8-5+deb11u2_amd64.deb ...
      2023-05-13T15:23:23.981796669Z	stdout	Unpacking libavahi-common-dev:amd64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      2023-05-13T15:23:23.454756285Z	stdout	Preparing to unpack .../10-libavahi-common-dev_0.8-5+deb11u2_amd64.deb ...
      2023-05-13T15:23:22.614671589Z	stdout	Unpacking libavahi-client-dev:amd64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      2023-05-13T15:23:22.286017900Z	stdout	Preparing to unpack .../09-libavahi-client-dev_0.8-5+deb11u2_amd64.deb ...
      2023-05-13T15:23:21.367864988Z	stdout	Unpacking libavahi-compat-libdnssd-dev:amd64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      2023-05-13T15:23:20.947358870Z	stdout	Preparing to unpack .../08-libavahi-compat-libdnssd-dev_0.8-5+deb11u2_amd64.deb ...
      2023-05-13T15:23:19.412791821Z	stdout	Unpacking git (1:2.30.2-1+deb11u2) over (1:2.30.2-1+deb11u1) ...
      2023-05-13T15:23:18.778642863Z	stdout	Preparing to unpack .../07-git_1%3a2.30.2-1+deb11u2_amd64.deb ...
      2023-05-13T15:23:17.456454593Z	stdout	Unpacking libcurl3-gnutls:amd64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
      2023-05-13T15:23:16.585414174Z	stdout	Preparing to unpack .../06-libcurl3-gnutls_7.74.0-1.3+deb11u7_amd64.deb ...
      2023-05-13T15:23:15.108702278Z	stdout	Unpacking git-man (1:2.30.2-1+deb11u2) over (1:2.30.2-1+deb11u1) ...
      2023-05-13T15:23:14.537313689Z	stdout	Preparing to unpack .../05-git-man_1%3a2.30.2-1+deb11u2_all.deb ...
      2023-05-13T15:23:13.094639772Z	stdout	Unpacking libcurl4:amd64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
      2023-05-13T15:23:12.621995595Z	stdout	Preparing to unpack .../04-libcurl4_7.74.0-1.3+deb11u7_amd64.deb ...
      2023-05-13T15:23:11.207609088Z	stdout	Unpacking curl (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
      2023-05-13T15:23:10.775762381Z	stdout	Preparing to unpack .../03-curl_7.74.0-1.3+deb11u7_amd64.deb ...
      2023-05-13T15:23:09.236339708Z	stdout	Unpacking locales (2.31-13+deb11u6) over (2.31-13+deb11u5) ...
      2023-05-13T15:23:08.890933481Z	stdout	Preparing to unpack .../02-locales_2.31-13+deb11u6_all.deb ...
      2023-05-13T15:23:08.043285576Z	stdout	Unpacking libc-l10n (2.31-13+deb11u6) over (2.31-13+deb11u5) ...
      2023-05-13T15:23:07.754777237Z	stdout	Preparing to unpack .../01-libc-l10n_2.31-13+deb11u6_all.deb ...
      2023-05-13T15:23:06.029514425Z	stdout	Unpacking tzdata (2021a-1+deb11u10) over (2021a-1+deb11u8) ...
      2023-05-13T15:23:05.676015064Z	stdout	Preparing to unpack .../00-tzdata_2021a-1+deb11u10_all.deb ...
      2023-05-13T15:23:05.674066031Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:23:04.958603634Z	stdout	Setting up libudev1:amd64 (247.3-7+deb11u2) ...
      2023-05-13T15:23:04.131525835Z	stdout	Unpacking libudev1:amd64 (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      2023-05-13T15:23:03.815411979Z	stdout	Preparing to unpack .../libudev1_247.3-7+deb11u2_amd64.deb ...
      2023-05-13T15:23:02.031992849Z	stdout	Unpacking udev (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      2023-05-13T15:23:01.460794682Z	stdout	Preparing to unpack .../udev_247.3-7+deb11u2_amd64.deb ...
      2023-05-13T15:22:59.895108989Z	stdout	Unpacking libudev-dev:amd64 (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      2023-05-13T15:22:59.344803779Z	stdout	Preparing to unpack .../libudev-dev_247.3-7+deb11u2_amd64.deb ...
      2023-05-13T15:22:59.342948776Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:22:58.474566317Z	stdout	Setting up libtinfo6:amd64 (6.2+20201114-2+deb11u1) ...
      2023-05-13T15:22:57.543902521Z	stdout	Unpacking libtinfo6:amd64 (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
      2023-05-13T15:22:57.183123609Z	stdout	Preparing to unpack .../libtinfo6_6.2+20201114-2+deb11u1_amd64.deb ...
      2023-05-13T15:22:56.086705627Z	stdout	Unpacking libncursesw6:amd64 (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
      2023-05-13T15:22:55.756728898Z	stdout	Preparing to unpack .../libncursesw6_6.2+20201114-2+deb11u1_amd64.deb ...
      2023-05-13T15:22:54.662309420Z	stdout	Unpacking libncurses6:amd64 (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
      2023-05-13T15:22:54.213012075Z	stdout	Preparing to unpack .../libncurses6_6.2+20201114-2+deb11u1_amd64.deb ...
      2023-05-13T15:22:54.211155252Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:22:53.392663760Z	stdout	Setting up libgnutls30:amd64 (3.7.1-5+deb11u3) ...
      2023-05-13T15:22:52.477495033Z	stdout	Unpacking libgnutls30:amd64 (3.7.1-5+deb11u3) over (3.7.1-5+deb11u2) ...
      2023-05-13T15:22:52.073874647Z	stdout	Preparing to unpack .../libgnutls30_3.7.1-5+deb11u3_amd64.deb ...
      2023-05-13T15:22:52.072038824Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:22:51.605106879Z	stdout	Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-stable.gpg ...
      2023-05-13T15:22:51.605036209Z	stdout	Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-security-automatic.gpg ...
      2023-05-13T15:22:51.541608379Z	stdout	Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-automatic.gpg ...
      2023-05-13T15:22:50.136587038Z	stdout	Setting up debian-archive-keyring (2021.1.1+deb11u1) ...
      2023-05-13T15:22:49.255410949Z	stdout	Unpacking debian-archive-keyring (2021.1.1+deb11u1) over (2021.1.1) ...
      2023-05-13T15:22:48.661351696Z	stdout	Preparing to unpack .../debian-archive-keyring_2021.1.1+deb11u1_all.deb ...
      2023-05-13T15:22:48.659544603Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:22:47.989618659Z	stdout	Setting up libsystemd0:amd64 (247.3-7+deb11u2) ...
      2023-05-13T15:22:47.011263263Z	stdout	Unpacking libsystemd0:amd64 (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      2023-05-13T15:22:46.340204318Z	stdout	Preparing to unpack .../libsystemd0_247.3-7+deb11u2_amd64.deb ...
      2023-05-13T15:22:46.337646623Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:22:45.301201259Z	stdout	Setting up ncurses-base (6.2+20201114-2+deb11u1) ...
      2023-05-13T15:22:44.456021494Z	stdout	Unpacking ncurses-base (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
      2023-05-13T15:22:44.088529661Z	stdout	Preparing to unpack .../ncurses-base_6.2+20201114-2+deb11u1_all.deb ...
      2023-05-13T15:22:44.086524378Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:22:41.224390332Z	stdout	Setting up libc-bin (2.31-13+deb11u6) ...
      2023-05-13T15:22:40.192542567Z	stdout	Unpacking libc-bin (2.31-13+deb11u6) over (2.31-13+deb11u5) ...
      2023-05-13T15:22:39.848252385Z	stdout	Preparing to unpack .../libc-bin_2.31-13+deb11u6_amd64.deb ...
      2023-05-13T15:22:39.846142311Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:22:37.670945910Z	stdout	Setting up libc6:amd64 (2.31-13+deb11u6) ...
      2023-05-13T15:22:36.249371286Z	stdout	Unpacking libc6:amd64 (2.31-13+deb11u6) over (2.31-13+deb11u5) ...
      2023-05-13T15:22:35.538582995Z	stdout	Preparing to unpack .../libc6_2.31-13+deb11u6_amd64.deb ...
      2023-05-13T15:22:34.043125845Z	stdout	Unpacking linux-libc-dev:amd64 (5.10.179-1) over (5.10.162-1) ...
      2023-05-13T15:22:33.739223073Z	stdout	Preparing to unpack .../linux-libc-dev_5.10.179-1_amd64.deb ...
      2023-05-13T15:22:32.997671709Z	stdout	Unpacking libc-dev-bin (2.31-13+deb11u6) over (2.31-13+deb11u5) ...
      2023-05-13T15:22:32.680684204Z	stdout	Preparing to unpack .../libc-dev-bin_2.31-13+deb11u6_amd64.deb ...
      2023-05-13T15:22:31.080373955Z	stdout	Unpacking libc6-dev:amd64 (2.31-13+deb11u6) over (2.31-13+deb11u5) ...
      2023-05-13T15:22:30.502232023Z	stdout	Preparing to unpack .../libc6-dev_2.31-13+deb11u6_amd64.deb ...
      2023-05-13T15:22:29.774888944Z	stdout	Unpacking libc-devtools (2.31-13+deb11u6) over (2.31-13+deb11u5) ...
      2023-05-13T15:22:29.272700862Z	stdout	Preparing to unpack .../libc-devtools_2.31-13+deb11u6_amd64.deb ...
      2023-05-13T15:22:29.270866439Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:22:28.339812320Z	stdout	Setting up ncurses-bin (6.2+20201114-2+deb11u1) ...
      2023-05-13T15:22:27.498619707Z	stdout	Unpacking ncurses-bin (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
      2023-05-13T15:22:27.075358810Z	stdout	Preparing to unpack .../ncurses-bin_6.2+20201114-2+deb11u1_amd64.deb ...
      2023-05-13T15:22:27.073342017Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:22:26.451648570Z	stdout	Setting up grep (3.6-1+deb11u1) ...
      2023-05-13T15:22:25.556923235Z	stdout	Unpacking grep (3.6-1+deb11u1) over (3.6-1) ...
      2023-05-13T15:22:25.146649261Z	stdout	Preparing to unpack .../grep_3.6-1+deb11u1_amd64.deb ...
      2023-05-13T15:22:25.144787788Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:22:23.929308953Z	stdout	Installing new version of config file /etc/debian_version ...
      2023-05-13T15:22:23.768000797Z	stdout	Setting up base-files (11.1+deb11u7) ...
      2023-05-13T15:22:22.699172804Z	stdout	Unpacking base-files (11.1+deb11u7) over (11.1+deb11u6) ...
      2023-05-13T15:22:22.140488276Z	stdout	Preparing to unpack .../base-files_11.1+deb11u7_amd64.deb ...
      2023-05-13T15:22:22.138277632Z	stdout	(Reading database ...  (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29425 files and directories currently installed.)
      2023-05-13T15:22:20.847563690Z	stdout	Preconfiguring packages ...
      2023-05-13T15:22:20.843694353Z	stdout	Extracting templates from packages: 78% Extracting templates from packages: 100%
      2023-05-13T15:22:02.556728883Z	stdout	Updating Linux packages on first run...
      2023-05-13T15:22:02.556615622Z	stdout
      2023-05-13T15:22:02.556579912Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:22:02.556228392Z	stdout	-----                  Step 1 of 5: Preparing container                   -----
      2023-05-13T15:22:02.556185412Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:22:02.555795781Z	stdout
      2023-05-13T15:22:02.555779201Z	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      2023-05-13T15:22:02.555757631Z	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
      2023-05-13T15:22:02.555732831Z	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
      2023-05-13T15:22:02.555700351Z	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
      2023-05-13T15:22:02.555656541Z	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
      2023-05-13T15:22:02.555613551Z	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
      2023-05-13T15:22:02.555574701Z	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
      2023-05-13T15:22:02.555526530Z	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      2023-05-13T15:22:02.555457770Z	stdout
      2023-05-13T15:22:02.555423050Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:22:02.555031810Z	stdout	-----                    SETUID:              1000                         -----
      2023-05-13T15:22:02.554751199Z	stdout	-----                    SETGID:              1000                         -----
      2023-05-13T15:22:02.542779149Z	stdout	-----                    DEBUG:               true                         -----
      2023-05-13T15:22:02.542633698Z	stdout	-----                        Environment Variables                         -----
      2023-05-13T15:22:02.542593548Z	stdout	-----        -----
      2023-05-13T15:22:02.542165148Z	stdout	-----                    npm:                 8.19.3                       -----
      2023-05-13T15:21:59.977111297Z	stdout	-----                    node:                v16.19.0                     -----
      2023-05-13T15:21:59.063453398Z	stdout	-----                    build:               2023-02-10T23:45:25+00:00    -----
      2023-05-13T15:21:59.063042877Z	stdout	-----                    image:               v7.2.0                       -----
      2023-05-13T15:21:59.062757916Z	stdout	-----                          Version Information                         -----
      2023-05-13T15:21:59.062723406Z	stdout	-----        -----
      2023-05-13T15:21:59.062608976Z	stdout	-----                    hostname:            buanet-iobroker2             -----
      2023-05-13T15:21:59.024092790Z	stdout	-----                    arch:                x86_64                       -----
      2023-05-13T15:21:58.986581146Z	stdout	-----                          System Information                          -----
      2023-05-13T15:21:58.986486586Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:21:58.986199866Z	stdout
      2023-05-13T15:21:58.986093696Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:21:58.986042105Z	stdout	-----                          Please be patient!                          -----
      2023-05-13T15:21:58.986011035Z	stdout	-----                    Startupscript is now running!                     -----
      2023-05-13T15:21:58.985985895Z	stdout	-----              Welcome to your ioBroker Docker container!              -----
      2023-05-13T15:21:58.985967175Z	stdout	-----        -----
      2023-05-13T15:21:58.985940525Z	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
      2023-05-13T15:21:58.985917315Z	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
      2023-05-13T15:21:58.985896345Z	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
      2023-05-13T15:21:58.985871685Z	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
      2023-05-13T15:21:58.985825435Z	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
      2023-05-13T15:21:58.985468124Z	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
      2023-05-13T15:21:58.985429664Z	stdout	-----        -----
      2023-05-13T15:21:58.985384714Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:21:58.984959424Z	stdout	-------------------------     2023-05-13 17:21:58      -------------------------
      2023-05-13T15:21:58.984205972Z	stdout	--------------------------------------------------------------------------------
      2023-05-13T15:21:58.983299011Z	stdout
      der Rest folgt gleich 🙂
      Auf dem Browser unter Windows (chromium, edge) ist übrigens auch kein weiterkommen...
      • Glasfaser
        Glasfaser @ferrog last edited by
        @ferrog sagte in Docker Installation lädt admin Adapter nicht:
        kommt da noch was ... damit kann man erstmal nichts anfangen !
        und wie schon gesagt .. altes Image
          Von der latest-v8 habe ich auch den debug log da, wenn das hilft. 🙂
          date	stream	content
          2023-05-13T15:47:44.269891044Z	stdout	host.buanet-iobroker4 check instance "system.adapter.backitup.0" for host "buanet-iobroker4"
          2023-05-13T15:47:44.268936383Z	stdout	host.buanet-iobroker4 check instance "system.adapter.discovery.0" for host "buanet-iobroker4"
          2023-05-13T15:47:44.261773893Z	stdout	host.buanet-iobroker4 check instance "system.adapter.admin.0" for host "buanet-iobroker4"
          2023-05-13T15:47:43.324870664Z	stdout	##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
          2023-05-13T15:47:43.324854124Z	stdout
          2023-05-13T15:47:43.324826964Z	stdout	Starting ioBroker...
          2023-05-13T15:47:43.324810644Z	stdout
          2023-05-13T15:47:43.324792724Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:47:43.324763044Z	stdout	-----                    Step 5 of 5: ioBroker startup                     -----
          2023-05-13T15:47:43.324711303Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:47:43.151326844Z	stdout
          2023-05-13T15:47:43.137833545Z	stdout
          2023-05-13T15:47:43.137783764Z	stdout	For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
          2023-05-13T15:47:43.137721904Z	stdout	Some adapters have special requirements/ settings which can be activated by the use of environment variables.
          2023-05-13T15:47:43.137666384Z	stdout
          2023-05-13T15:47:43.137549184Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:47:43.137178864Z	stdout	-----                Step 4 of 5: Applying special settings                -----
          2023-05-13T15:47:43.137121543Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:47:43.136801153Z	stdout
          2023-05-13T15:47:43.136780253Z	stdout	Controller "js-controller": 4.0.24   , installed 4.0.24
          2023-05-13T15:47:43.136755553Z	stdout	Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          2023-05-13T15:47:43.136734123Z	stdout	Adapter    "backitup"     : 2.6.19   , installed 2.6.19
          2023-05-13T15:47:43.136705853Z	stdout	Adapter    "admin"        : 6.3.5    , installed 6.3.5
          2023-05-13T15:47:43.136686453Z	stdout	Used repository: stable
          2023-05-13T15:47:43.136667773Z	stdout	[DEBUG] ##### iobroker update #####
          2023-05-13T15:47:43.136652193Z	stdout
          2023-05-13T15:47:43.136633283Z	stdout	Active repo(s): stable
          2023-05-13T15:47:43.136613743Z	stdout
          2023-05-13T15:47:43.136592113Z	stdout	beta          : http://download.iobroker.net/sources-dist-latest.json
          2023-05-13T15:47:43.136560053Z	stdout	stable        : http://download.iobroker.net/sources-dist.json
          2023-05-13T15:47:43.136483833Z	stdout	[DEBUG] ##### iobroker repo list #####
          2023-05-13T15:47:43.136467842Z	stdout
          2023-05-13T15:47:43.136448812Z	stdout	+ instance is alive
          2023-05-13T15:47:43.136432622Z	stdout
          2023-05-13T15:47:43.136410302Z	stdout	  system.adapter.discovery.0              : discovery             : buanet-iobroker4                         -  enabled
          2023-05-13T15:47:43.136383492Z	stdout	  system.adapter.backitup.0               : backitup              : buanet-iobroker4                         -  enabled
          2023-05-13T15:47:43.136333662Z	stdout	  system.adapter.admin.0                  : admin                 : buanet-iobroker4                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          2023-05-13T15:47:43.135936152Z	stdout	[DEBUG] ##### iobroker list instances #####
          2023-05-13T15:47:05.768075168Z	stdout
          2023-05-13T15:47:05.768028778Z	stdout	[DEBUG] Collecting some more ioBroker debug information...
          2023-05-13T15:47:05.767986918Z	stdout
          2023-05-13T15:47:05.767659268Z	stdout	Done.
          2023-05-13T15:47:04.692537448Z	stdout	The host for instance "system.adapter.backitup.0" was changed from "buildkitsandbox" to "buanet-iobroker4".
          2023-05-13T15:47:04.689835954Z	stdout	The host for instance "system.adapter.discovery.0" was changed from "buildkitsandbox" to "buanet-iobroker4".
          2023-05-13T15:47:04.687277530Z	stdout	Updating hostname to "buanet-iobroker4"... The host for instance "system.adapter.admin.0" was changed from "buildkitsandbox" to "buanet-iobroker4".
          2023-05-13T15:46:54.079547659Z	stdout	Hostname in ioBroker does not match the hostname of this container.
          2023-05-13T15:46:54.059817621Z	stdout	[DEBUG] Detected admin hostname is: buildkitsandbox
          2023-05-13T15:46:42.302764294Z	stdout	[DEBUG] Detected admin instance is: system.adapter.admin.0
          2023-05-13T15:46:30.593054575Z	stdout
          2023-05-13T15:46:30.592681875Z	stdout	Initializing a fresh installation of ioBroker... Done.
          2023-05-13T15:46:17.017145250Z	stdout
          2023-05-13T15:46:17.017122470Z	stdout	[DEBUG] Done.
          2023-05-13T15:46:17.017103560Z	stdout	[DEBUG] No custom states db settings detected.
          2023-05-13T15:46:17.017079960Z	stdout	[DEBUG] Checking custom states db settings...
          2023-05-13T15:46:17.017056440Z	stdout
          2023-05-13T15:46:17.017036120Z	stdout	[DEBUG] Done.
          2023-05-13T15:46:17.017016910Z	stdout	[DEBUG] No custom objects db settings detected.
          2023-05-13T15:46:17.016986970Z	stdout	[DEBUG] Checking custom objects db settings...
          2023-05-13T15:46:17.016960290Z	stdout
          2023-05-13T15:46:17.016887570Z	stdout	[DEBUG] Done.
          2023-05-13T15:46:17.016850860Z	stdout	[DEBUG] No multihost settings detected.
          2023-05-13T15:46:17.016789910Z	stdout	[DEBUG] Checking multihost settings...
          2023-05-13T15:46:17.016514139Z	stdout
          2023-05-13T15:46:17.016138619Z	stdout	Fixing "sudo-bug" by replacing sudo with gosu... Done.
          2023-05-13T15:46:16.659789089Z	stdout
          2023-05-13T15:46:16.659637289Z	stdout	(Re)setting permissions (This might take a while! Please be patient!)... Done.
          2023-05-13T15:46:16.532957762Z	stdout
          2023-05-13T15:46:16.532852711Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:46:16.532518601Z	stdout	-----             Step 3 of 5: Checking ioBroker installation              -----
          2023-05-13T15:46:16.532442081Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:46:16.531808700Z	stdout
          2023-05-13T15:46:16.454032021Z	stdout	Restoring initial ioBroker installation... Done.
          2023-05-13T15:46:13.558289354Z	stdout	There is no data detected in /opt/iobroker.
          2023-05-13T15:46:13.540199328Z	stdout
          2023-05-13T15:46:13.540141338Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:46:13.539836648Z	stdout	-----             Step 2 of 5: Detecting ioBroker installation             -----
          2023-05-13T15:46:13.539720848Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:46:13.515052223Z	stdout
          2023-05-13T15:46:13.498686700Z	stdout	Registering maintenance script as command... Done.
          2023-05-13T15:46:13.489624958Z	stdout
          2023-05-13T15:46:11.611708519Z	stdout	Updating Linux packages on first run... Done.
          2023-05-13T15:44:58.139563752Z	stdout
          2023-05-13T15:44:58.139484412Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:44:58.139150351Z	stdout	-----                   Step 1 of 5: Preparing container                   -----
          2023-05-13T15:44:58.139113601Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:44:58.138838381Z	stdout
          2023-05-13T15:44:58.138825271Z	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          2023-05-13T15:44:58.138808701Z	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
          2023-05-13T15:44:58.138786791Z	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
          2023-05-13T15:44:58.138750911Z	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
          2023-05-13T15:44:58.138700951Z	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
          2023-05-13T15:44:58.138671261Z	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
          2023-05-13T15:44:58.138639391Z	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
          2023-05-13T15:44:58.138606510Z	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          2023-05-13T15:44:58.138574610Z	stdout
          2023-05-13T15:44:58.138538920Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:44:58.138133950Z	stdout	-----                    SETUID:              1000                         -----
          2023-05-13T15:44:58.137795309Z	stdout	-----                    SETGID:              1000                         -----
          2023-05-13T15:44:58.137270609Z	stdout	-----                    DEBUG:               true                         -----
          2023-05-13T15:44:58.136890868Z	stdout	-----                        Environment Variables                         -----
          2023-05-13T15:44:58.136862518Z	stdout	-----        -----
          2023-05-13T15:44:58.136566958Z	stdout	-----                    npm:                 9.5.1                        -----
          2023-05-13T15:44:56.354084526Z	stdout	-----                    node:                v18.16.0                     -----
          2023-05-13T15:44:55.910835981Z	stdout	-----                    build:               2023-04-26T23:45:40+00:00    -----
          2023-05-13T15:44:55.910802491Z	stdout	-----                    image:               v8.0.1                       -----
          2023-05-13T15:44:55.910770791Z	stdout	-----                          Version Information                         -----
          2023-05-13T15:44:55.910743501Z	stdout	-----        -----
          2023-05-13T15:44:55.910709461Z	stdout	-----                    hostname:            buanet-iobroker4             -----
          2023-05-13T15:44:55.910592891Z	stdout	-----                    arch:                x86_64                       -----
          2023-05-13T15:44:55.905641184Z	stdout	-----                          System Information                          -----
          2023-05-13T15:44:55.905620354Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:44:55.905600374Z	stdout
          2023-05-13T15:44:55.905577174Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:44:55.905550654Z	stdout	-----                          Please be patient!                          -----
          2023-05-13T15:44:55.905521824Z	stdout	-----                    Startupscript is now running!                     -----
          2023-05-13T15:44:55.905477654Z	stdout	-----              Welcome to your ioBroker Docker container!              -----
          2023-05-13T15:44:55.905451524Z	stdout	-----        -----
          2023-05-13T15:44:55.905419324Z	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
          2023-05-13T15:44:55.905390034Z	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
          2023-05-13T15:44:55.905361324Z	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
          2023-05-13T15:44:55.905330424Z	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
          2023-05-13T15:44:55.905294234Z	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
          2023-05-13T15:44:55.905256144Z	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
          2023-05-13T15:44:55.905231994Z	stdout	-----        -----
          2023-05-13T15:44:55.905202714Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:44:55.905086203Z	stdout	-------------------------     2023-05-13 17:44:55      -------------------------
          2023-05-13T15:44:55.901358018Z	stdout	--------------------------------------------------------------------------------
          2023-05-13T15:44:55.900853518Z	stdout	 ```
          • Glasfaser
            Glasfaser last edited by
            @ferrog
            in deinen beigestellten Logs ist nichts zu erkennen ... sollte alles funktionieren .
            Dann bitte die V8 installieren , starten ....
            und die Full Ausgabe von
            iob diag
            Nimm auch bitte einen anderen Browser den du noch nie für IoBroker genutzt hast , und rufe die Seite auf !
              Anbei dann noch die Diag von v8:
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Architecture    : x86_64
              Docker          : v8.0.1
              Virtualization  : Unknown (buanet/Synology?)
              Distributor ID:	Debian
              Description:	Debian GNU/Linux 11 (bullseye)
              Release:	11
              Codename:	bullseye
              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
              NAME="Debian GNU/Linux"
              VERSION_ID="11"
              VERSION="11 (bullseye)"
              VERSION_CODENAME=bullseye
              ID=debian
              HOME_URL="https://www.debian.org/"
              SUPPORT_URL="https://www.debian.org/support"
              BUG_REPORT_URL="https://bugs.debian.org/"
              Systemuptime and Load:
               18:08:27 up  3:20,  0 users,  load average: 0.73, 0.84, 0.80
              CPU threads: 4
              *** Time and Time Zones ***
              Sat May 13 16:08:27 UTC 2023
              Sat May 13 18:08:27 CEST 2023
              CEST +0200
              Etc/UTC
              *** User and Groups ***
              root
              /root
              root
              *** X-Server-Setup ***
              X-Server: 	false
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:            3.9G        1.3G        246M        1.1G        2.3G        950M
              Swap:           4.4G        181M        4.2G
              Total:          8.3G        1.5G        4.4G
                       3890 M total memory
                       1304 M used memory
                        902 M active memory
                       1076 M inactive memory
                        246 M free memory
                         11 M buffer memory
                       2327 M swap cache
                       4383 M total swap
                        181 M used swap
                       4202 M free swap
              *** FILESYSTEM ***
              Filesystem             Type   Size  Used Avail Use% Mounted on
              /dev/mapper/cachedev_1 btrfs  8.8T  3.7T  5.1T  42% /
              tmpfs                  tmpfs   64M     0   64M   0% /dev
              tmpfs                  tmpfs  1.9G     0  1.9G   0% /sys/fs/cgroup
              shm                    tmpfs   64M     0   64M   0% /dev/shm
              /dev/mapper/cachedev_1 btrfs  8.8T  3.7T  5.1T  42% /opt/iobroker
              /dev/mapper/cachedev_1 btrfs  8.8T  3.7T  5.1T  42% /etc/hosts
              tmpfs                  tmpfs  1.9G     0  1.9G   0% /proc/acpi
              tmpfs                  tmpfs  1.9G     0  1.9G   0% /proc/scsi
              tmpfs                  tmpfs  1.9G     0  1.9G   0% /sys/firmware
              [Sat May 13 14:49:02 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
              [Sat May 13 14:49:02 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
              [Sat May 13 14:49:03 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
              [Sat May 13 14:49:03 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
              [Sat May 13 14:49:03 2023] EXT4-fs (loop0): couldn't mount as ext3 due to feature incompatibilities
              [Sat May 13 14:49:03 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
              [Sat May 13 14:49:08 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
              [Sat May 13 14:49:08 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
              [Sat May 13 14:49:08 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
              [Sat May 13 14:49:31 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
              Show mounted filesystems (real ones only):
              TARGET             SOURCE        FSTYPE OPTIONS
              /                  /dev/mapper/cachedev_1[/@syno/@docker/btrfs/subvolumes/e6ecc9255012492ebd334775a6260c88c76a08edb3c0b775424d72fe73930282]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=440,subvol=/@syno/@docker/btrfs/subvolumes/e6ecc9255012492ebd334775a6260c88c76a08edb3c0b775424d72fe73930282
              |-/opt/iobroker    /dev/mapper/cachedev_1[/@syno/docker/iobv81]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=257,subvol=/@syno/docker/iobv81
              |-/etc/resolv.conf /dev/mapper/cachedev_1[/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/resolv.conf
              |-/etc/hostname    /dev/mapper/cachedev_1[/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hostname
              `-/etc/hosts       /dev/mapper/cachedev_1[/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hosts
              /var:
              33M	/var/
              30M	/var/lib
              18M	/var/lib/apt/lists
              18M	/var/lib/apt
              13M	/var/lib/dpkg
              /opt/iobroker/backups:
              0	/opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              18M	/opt/iobroker/iobroker-data/
              14M	/opt/iobroker/iobroker-data/files
              13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
              6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              3.3M	/opt/iobroker/iobroker-data/objects.jsonl
              2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
              1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
              652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
              *** NodeJS-Installation ***
              /usr/bin/nodejs 	v18.16.0
              /usr/bin/node 		v18.16.0
              /usr/bin/npm 		9.5.1
              /usr/bin/npx 		9.5.1
              nodejs:
                Installed: 18.16.0-deb-1nodesource1
                Candidate: 18.16.0-deb-1nodesource1
                Version table:
               *** 18.16.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                      100 /var/lib/dpkg/status
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                   12.22.12~dfsg-1~deb11u3 500
                      500 http://deb.debian.org/debian bullseye/main amd64 Packages
              No problems detected
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              MULTIHOSTSERVICE/enabled: false
              Core adapters versions
              js-controller: 	4.0.24
              admin: 		6.3.5
              javascript: 	"javascript" not found
              Adapters from github: 	0
              Adapter State
              + system.adapter.admin.0                  : admin                 : buanet-iobroker4                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : buanet-iobroker4                         -  enabled
              + system.adapter.discovery.0              : discovery             : buanet-iobroker4                         -  enabled
              + instance is alive
              ioBroker-Repositories
              Installed ioBroker-Instances
              Objects and States
              Objects: 	143
              States: 	104
              Hit:1 http://deb.debian.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
              Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
              Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1575259    -
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1575252    -
              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1576185    -
              2023-05-13 17:47:43.755  - info: host.buanet-iobroker4 iobroker.js-controller version 4.0.24 js-controller starting
              2023-05-13 17:47:43.758  - info: host.buanet-iobroker4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
              2023-05-13 17:47:43.759  - info: host.buanet-iobroker4 hostname: buanet-iobroker4, node: v18.16.0
              2023-05-13 17:47:43.759  - info: host.buanet-iobroker4 ip addresses: 172.17.0.6
              2023-05-13 17:47:44.092  - info: host.buanet-iobroker4 connected to Objects and States
              2023-05-13 17:47:44.102  - info: host.buanet-iobroker4 Node.js version has changed from unknown to 18.16.0
              2023-05-13 17:47:44.123  - info: host.buanet-iobroker4 added notifications configuration of host
              2023-05-13 17:47:44.258  - info: host.buanet-iobroker4 3 instances found
              2023-05-13 17:47:44.270  - info: host.buanet-iobroker4 starting 3 instances
              2023-05-13 17:47:44.296  - info: host.buanet-iobroker4 instance system.adapter.admin.0 started with pid 1828
              2023-05-13 17:47:44.522  - info: host.buanet-iobroker4 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
              2023-05-13 17:47:45.624  - info: admin.0 (1828) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
              2023-05-13 17:47:45.641  - info: admin.0 (1828) requesting all states
              2023-05-13 17:47:45.641  - info: admin.0 (1828) requesting all objects
              2023-05-13 17:47:45.792  - info: admin.0 (1828) received all objects
              2023-05-13 17:47:45.918  - info: admin.0 (1828) http server listening on port 8081
              2023-05-13 17:47:45.919  - info: admin.0 (1828) Use link "http://localhost:8081" to configure.
              2023-05-13 17:47:45.922  - info: admin.0 (1828) socket.io server listening on port 8081
              2023-05-13 17:47:48.281  - info: host.buanet-iobroker4 instance system.adapter.discovery.0 started with pid 1856
              2023-05-13 17:47:48.835  - info: discovery.0 (1856) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
              2023-05-13 17:47:52.281  - info: host.buanet-iobroker4 instance system.adapter.backitup.0 started with pid 1871
              2023-05-13 17:47:52.895  - info: backitup.0 (1871) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
              2023-05-13 17:47:52.996  - info: backitup.0 (1871) [iobroker] backup will be activated at 02:40 every 1 day(s)
              		     v.2023-04-16
              Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
              Kernel: 		4.4.180+
              Installation: 		Docker
              Timezone: 		Etc/UTC
              User-ID: 		0
              X-Server: 		false
              Pending OS-Updates: 	0
              Pending iob updates: 	0
              Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
              			/usr/bin/npm 		9.5.1
              			/usr/bin/npx 		9.5.1
              Recommended versions are nodejs 18.x.y and npm 9.x.y
              MEMORY:
              Mem:            3.9G        1.3G        285M        1.1G        2.3G        917M
              Swap:           4.4G        184M        4.2G
              Total:          8.3G        1.5G        4.5G
              Active iob-Instances: 	4
              ioBroker Core: 		js-controller 		4.0.24
              			admin 			6.3.5
              ioBroker Status: 	iobroker is running on this host.
              Objects type: jsonl
              States  type: jsonl
              Objects: 		143
              States: 		104
              Size of iob-Database:
              228K	/opt/iobroker/iobroker-data/states.jsonl
              Habe extra Firefox runtergeladen, funktioniert aber leider auch nicht 😞
              Glasfaser 2 Replies Last reply Reply Quote 0
              • Glasfaser
                ... auch ein Loop mit dem ioBroker Zeichen !?
                Hast du eine Host oder Bridge Netzwerk !
                  Ja, auch in loop.
                  Ich habe noch den alten "raspi" iobroker im Netz, aber nicht aktiv host bzw. slave konfiguriert. Sind die sich dann auch ohne Konfiguration im Wege?
                  Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @ferrog last edited by Thomas Braun
                    @ferrog
                    tcp6       0      0 :::8081
                    Da läuft der Admin wohl nur auf ipv6.
                    Edith: Vergiss es, ist bei mir auch so.
                    • Glasfaser
                      Nein .. passt so .
                      Was ist mit :
                      @glasfaser sagte in Docker Installation lädt admin Adapter nicht:
                      Bitte immer alle Fragen beantworten !
                      Wenn Bridge ... dann versuche zum Test Host .
                      • Glasfaser
                        Sehe gerade ...
                        Also Bridge
                          Ah, gemeint war docker. Ja das war Bridge, habe gerade auch Host versucht, leider genau so. Liegt das vielleicht an der Bereitstellung des Ports durch DSM „Webstation“?
                          Oder kann der Port 8081 auch einfach gemappt werden? (Habe leider noch nicht zum Laufen bekommen…)
                          • Glasfaser
                            Glasfaser @ferrog last edited by Glasfaser
                            Welcher Port hat er denn ,
                            dann würdest du aber nicht ioBroker mit 8081 erreichen !
                            Der Loop ist ein anderer ( Fehler ) . kann Ihn aber nicht erkennen .
                            Zeige mal die Ausgabe von
                            iob logs --watch
                            wenn du im Loop bist
                              Logs —watch von latest-v8:
                              2023-05-13 18:49:56.226  - info: host.buanet-iobroker3 iobroker.js-controller version 4.0.24 js-controller starting
                              2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                              2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 hostname: buanet-iobroker3, node: v18.16.0
                              2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 ip addresses: 192.168.178.3 fd9b:f2b9:802:4f06:9209:d0ff:fe32:33f3 2003:cd:f47:c000:9209:d0ff:fe32:33f3 fe80::9209:d0ff:fe32:33f3 172.17.0.1 fe80::42:caff:fe53:7492 fe80::5ca4:c5ff:fec1:c9b fe80::6054:cbff:fe48:42d2 fe80::8c55:c1ff:fee3:f31b fe80::f4c1:fbff:fe20:3a8f fe80::c866:afff:fe37:903a
                              2023-05-13 18:49:56.474  - info: host.buanet-iobroker3 connected to Objects and States
                              2023-05-13 18:49:56.481  - info: host.buanet-iobroker3 Node.js version has changed from unknown to 18.16.0
                              2023-05-13 18:49:56.501  - info: host.buanet-iobroker3 added notifications configuration of host
                              2023-05-13 18:49:56.658  - info: host.buanet-iobroker3 3 instances found
                              2023-05-13 18:49:56.661  - info: host.buanet-iobroker3 starting 3 instances
                              2023-05-13 18:49:56.680  - info: host.buanet-iobroker3 instance system.adapter.admin.0 started with pid 1761
                              2023-05-13 18:49:57.314  - info: host.buanet-iobroker3 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                              2023-05-13 18:49:58.050  - info: admin.0 (1761) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                              2023-05-13 18:49:58.067  - info: admin.0 (1761) requesting all states
                              2023-05-13 18:49:58.068  - info: admin.0 (1761) requesting all objects
                              2023-05-13 18:49:58.127  - info: admin.0 (1761) received all objects
                              2023-05-13 18:49:58.151  - info: admin.0 (1761) Request actual repository...
                              2023-05-13 18:49:58.160  - info: host.buanet-iobroker3 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                              2023-05-13 18:49:58.300  - warn: admin.0 (1761) Repository cannot be read: Active repo - stable
                              2023-05-13 18:49:58.301  - warn: admin.0 (1761) Active repository "stable" cannot be read
                              2023-05-13 18:49:58.763  - error: admin.0 (1761) port 8081 already in use
                              2023-05-13 18:49:58.764  - info: admin.0 (1761) Terminated (ADAPTER_REQUESTED_TERMINATION): port 8081 already in use
                              2023-05-13 18:49:59.277  - info: admin.0 (1761) terminating http server on port 8081
                              2023-05-13 18:49:59.289  - error: host.buanet-iobroker3 instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                              2023-05-13 18:49:59.290  - info: host.buanet-iobroker3 Do not restart adapter system.adapter.admin.0 because desired by instance
                              2023-05-13 18:50:00.676  - info: host.buanet-iobroker3 instance system.adapter.discovery.0 started with pid 1785
                              2023-05-13 18:50:01.342  - info: discovery.0 (1785) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                              2023-05-13 18:50:04.690  - info: host.buanet-iobroker3 instance system.adapter.backitup.0 started with pid 1804
                              2023-05-13 18:50:05.314  - info: backitup.0 (1804) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                              2023-05-13 18:50:05.446  - info: backitup.0 (1804) [iobroker] backup will be activated at 02:40 every 1 day(s)
                              • Glasfaser
                                Logs
                                Bitte aktuell zeigen !!
                                  Ahh, sorry falsche Datei, ist korrigiert. Da gibts auch errors…
                                  • Glasfaser
                                    Da läuft was doppelt , deshalb startet jetzt in diesem Log der ioBroker nicht
                                    • Glasfaser
                                      Glasfaser @Glasfaser last edited by
                                      @ferrog
                                      Kann du nicht meine Fragen beantworten !?
                                        Homoran Global Moderator Administrators @Glasfaser last edited by
                                        @ferrog
                                        bitte lesen und befolgen!
                                          Ich habe das nicht als Frage verstanden.
                                          Natürlich reicht die Webstation den Port 8081 an den Docker Container weiter.
                                          • Glasfaser
                                            Lösche alle diese Einträge !
                                            Hier wird nur der Port vorgegeben :
                                            siehe Beispiel Containereinstellung
                                            und das ausschalten / haken bei dir raus
                                            1285
